Connecting your Computer to a Television
    It is a nasty surprise when you switch your monitor on and nothing appears on screen after a patient wait. Even though the resolution is much low, a television may help you to conduct basic procedures (copying your files for example) in such an emergency. You may think that this is only possible through expensive VGA cards but it's not true. A simple circuit can combine the VGA synchronization signals into composite TV synchronization signal. Following circuit by  Tomi Engdahl  carries out this job successfully without any problems. It utilizes a TTL IC, two transistors and a few resistors.
VGA to TV converter by Tomi Engdahl
    By putting all of the components on a PCB makes it easier to prepare a portable VGA to TV adapter. You'll need a male VGA connector to be connected to your PC and a Scart connector for your TV. Six lines of cable goes from VGA Card to TV without any alteration, only three of them is needed to be connected to the PCB board. Here is a PCB design I suggest using. Download this  TIFF file  which is set to be printed at 300DPI. You may refer to my  PCB design page  to learn how to create your own PCB arts on the computer.
PCB artwork for the VGA to TV converter
PCB design for the converter
    You'll need VGA connector's and Scart's pinouts also, so here they are. Check out Nikola Asuni's award winning  excellent web site  of great pinout collection and other information on electronics.
15pin VGA connector pinouts
Pinouts for VGA Connector
SCART connector pinouts
Pinouts for SCART Connector
    Since circuit does not utilizes high currents, a very thin PCB plate would be enough. After drawing and etching processes, drill the holes and solder the components. Attach wires to the proper connection points and apply +5V supply voltage. If there's nothing wrong, you should measure nearly 75 mA current drag for a 74LS86 low power Schottky TTL type IC and again nearly 100 mA current drag for a 74S86 type IC.
Completed PCB
PCB completed and VGA connector attached
    Since sweeping frequencies of the VGA boards are higher than the TV's, a software is needed to alter it. Here is one called  Television Eyes  which both enables you to use circuit in DOS and Microsoft Windows (at 640 x 480 resolution). Just start your PC in DOS mode and run  'te.com'  to install it as a TSR. If you press  ALT - Left SHIFT - E  keys simultaneously, the sweeping frequency of the VGA board will be changed and your TV will be able to sync the signal it receives. Here are screenshots showing the unsynched and synched states of the TV screen displaying DOS.
Unsynced TV output Synced TV output
Screen output on TV before and after the synchronization
    Text mode applications on DOS works pleasant, as long as they are not have details too much. For example good old Norton Commander looks very good on the TV. After switching the Windows to 640 x 480, 16 colors mode (standard VGA) and applying  'te.com'  after a reboot, you may be able to view Windows too. File  'winte.exe'  enables/disables the frequency alteration and makes it possible to adjust alignment of the screen.
Norton Commander on TV! Windows on TV
Norton Commander and Windows on the TV
    Picture quality is worse in Windows that even texts of the icons are unreadable. But as stated earlier, this work is intended to make it possible to use your PC in case of a monitor emergency. To blind-boot your PC in such an emergency condition; prepare a  .BAT  file with a simple name (for example  't.bat' ) which calls the  te.com  where it is located. Than you can connect the circuit to your PC and TV, boot the computer in DOS mode, and type  't'  then press  ALT - Left SHIFT - E  to get everything in order.
 E-mail me at : incepinar@yahoo.com
