-- Company:
-- Engineer:
-- Create Date:    19:23:07 08/11/2010
-- Design Name:
-- Module Name:    clock1 - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;                                         -- Library declaration
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity clock1 is
   Port ( CLK_10M : in std_logic;                    -- 1/200000 counter INPUT
           CLK_50 : out std_logic );                    -- 1/200000 counter OUTPUT
 -- attribute pin_assign : string;                      -- Pin assign
  --attribute pin_assign of S : signal is "6,2";
 -- attribute pin_assign of R : signal is "4,44";
  --attribute pin_assign of Q : signal is "42,40";
  --attribute pin_assign of CLK_10M : signal is "7";
  --attribute pin_assign of CLK_50 : signal is "39";
  --attribute pin_assign of A : signal is "37";
  --attribute pin_assign of B : signal is "35";
  --attribute pin_assign of C : signal is "33";
  --attribute pin_assign of DEC : signal is "27,25,28,26,22,20,18,24";
end clock1;
architecture Behavioral of clock1 is
  signal Q100K : std_logic_vector(16 downto 0):="00000000000000000";       -- 1/100000 counter
  signal QCLK : std_logic_vector(0 downto 0):="0";         -- 1/2 counter
begin
-- ** 1/200000 counter **
  CLK_50 <= QCLK(0);                                  -- Set OUTPUT
  process( CLK_10M ) begin
    if CLK_10M = '1' and CLK_10M'event then             -- Clock rising edge ?
      if Q100K = 99999 then                             -- Count = 100000 ?
         Q100K <= "00000000000000000";                -- YES. Clear counter
         QCLK <= QCLK + '1';                          -- Set 1/200000 counter
      else                                            -- No.
         Q100K <= Q100K + '1';                        -- Count-up
      end if;
    end if;
  end process;
end Behavioral;
