////   Library for a MicroChip 93C56 configured for a x8 org           ////
////   Uses hardware SSP unit.                                         ////
////   init_ext_eeprom();    Call before the other functions are used  ////
////   write_ext_eeprom(a, d);  Write the byte d to the address a      ////
////   d = read_ext_eeprom(a);   Read the byte d from the address a    ////
////        (C) Copyright 1996,2003 Custom Computer Services           ////
//// This source code may only be used by licensed users of the CCS C  ////
//// compiler.  This source code may only be distributed to other      ////
//// licensed users of the CCS C compiler.  No other use, reproduction ////
//// or distribution is permitted without written permission.          ////
//// Derivative programs created using this software in object code    ////
//// form are not restricted in any way.                               ////
#if defined(__PCD__)
 #define EEPROM_SELECT PIN_B0
 #define EEPROM_DI     PIN_F2
 #define EEPROM_DO     PIN_F3
 #define EEPROM_CLK    PIN_E8
#else
 #define EEPROM_DI     PIN_C5
 #define EEPROM_DO     PIN_C4
 #define EEPROM_CLK    PIN_C3
#endif
#define EEPROM_ADDRESS BYTE
#define EEPROM_SIZE    256
void init_ext_eeprom() {
   int1 i;
   output_low(EEPROM_DI);
   output_low(EEPROM_CLK);
   output_low(EEPROM_SELECT);
   i=input(EEPROM_DO);
   setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_16);
   output_high(EEPROM_SELECT);
   spi_write(0x9);
   spi_write(0x80);
void write_ext_eeprom(EEPROM_ADDRESS address, BYTE data) {
   spi_write(0xa);
   spi_write(address);
   spi_write(data);
   delay_ms(11);
BYTE read_ext_eeprom(EEPROM_ADDRESS address) {
   BYTE data;
   spi_write(0x18);
   spi_write(address);
   data=spi_read(0);
   return(data);
