#include "piccolo_all.h"
#include <delays.h>
/* 8-bit or 4-bit interface type
 * For 8-bit operation uncomment the #define BIT8
//#define BIT8
/* When in 4-bit interface define if the data is in the upper
* or lower nibble. For lower nibble, comment the #define UPPER
#define UPPER
/* DATA_PORT defines the port to which the LCD data lines are connected */
#define DATA_PORT PORTD
#define TRIS_DATA_PORT TRISD
/* CTRL_PORT defines the port which the control signals are connected to.
Following codes are just for references. They may be amended to match your application.
#define RW_PIN PORTAbits.RA2 		/* PORT for RW */
#define TRIS_RW DDRAbits.RA2 		/* TRIS for RW */
#define RS_PIN PORTAbits.RA3 		/* PORT for RS */
#define TRIS_RS DDRAbits.RA3 		/* TRIS for RS */
#define E_PIN PORTAbits.RA1 		/* PORT for E */
#define TRIS_E DDRAbits.RA1 		/* TRIS for E */
//-- Display ON/OFF Control defines -------
#define DON 0b00001111 				/* Display on */
#define DOFF 0b00001011 			/* Display off */
#define CURSOR_ON 0b00001111 		/* Cursor on */
#define CURSOR_OFF 0b00001101 		/* Cursor off */
#define BLINK_ON 0b00001111 		/* Cursor Blink */
#define BLINK_OFF 0b00001110 		/* Cursor No Blink */
//-- Cursor or Display Shift defines ------
#define SHIFT_CUR_LEFT 0b00010011 	/* Cursor shifts to the left */
#define SHIFT_CUR_RIGHT 0b00010111 	/* Cursor shifts to the right */
#define SHIFT_DISP_LEFT 0b00011011	/* Display shifts to the left */
#define SHIFT_DISP_RIGHT 0b00011111	/* Display shifts to the right */
//-- Function Set defines -----------------
#define FOUR_BIT 0b00101111			/* 4-bit Interface */
#define EIGHT_BIT 0b00111111		/* 8-bit Interface */
#define LINE_5X7 0b00110011			/* 5x7 characters, single line */
#define LINE_5X10 0b00110111		/* 5x10 characters */
#define LINES_5X7 0b00111011		/* 5x7 characters, multiple line */
#define PARAM_SCLASS auto
#define MEM_MODEL near 				/* Change this to near for small memory model */
//-- Forward declarations -----------------
void OpenXLCD(PARAM_SCLASS unsigned char);
void SetCGRamAddr(PARAM_SCLASS unsigned char);
void SetDDRamAddr(PARAM_SCLASS unsigned char);
unsigned char BusyXLCD(void);
unsigned char ReadAddrXLCD(void);
char ReadDataXLCD(void);
void WriteCmdXLCD(PARAM_SCLASS unsigned char);
void WriteDataXLCD(PARAM_SCLASS char);
#define putcXLCD WriteDataXLCD
void putsXLCD(PARAM_SCLASS char *);
void putrsXLCD(PARAM_SCLASS const MEM_MODEL rom char *);
/* User defines these routines according to the oscillator frequency */
extern void DelayFor18TCY(void);
extern void DelayPORXLCD(void);
extern void DelayXLCD(void);
* Function Name: BusyXLCD                                           *
* Return Value: char: busy status of LCD controller                 *
* Parameters: void                                                  *
* Description: This routine reads the busy status of the            *
* Hitachi HD44780 LCD controller.                                   *
unsigned char BusyXLCD(void) {
    RW_PIN = 1; 						// Set the control bits for read
    RS_PIN = 0;
    DelayFor18TCY();
    E_PIN = 1; 							// Clock in the command
    DelayFor18TCY();
#ifdef BIT8 							// 8-bit interface
    if (DATA_PORT&0x80) 				// Read bit 7 (busy bit)
    { // If high
        E_PIN = 0; 						// Reset clock line
        RW_PIN = 0; 					// Reset control line
        return 1; 						// Return TRUE
    } else { 							// Bit 7 low
        return 0; 						// Return FALSE
#else 									// 4-bit interface
	#ifdef UPPER 						// Upper nibble interface
    	if (DATA_PORT&0x80)
	#else 								// Lower nibble interface
        if (DATA_PORT&0x08)
	#endif
            DelayFor18TCY();
            E_PIN = 1; 					// Clock out other nibble
            DelayFor18TCY();
            E_PIN = 0;
        } else { 						// Busy bit is low
            DelayFor18TCY();
            DelayFor18TCY();
            E_PIN = 0;
#endif
* Function Name: OpenXLCD                                             *
* Return Value: void                                                  *
* Parameters: lcdtype: set the type of LCD (lines)                    *
* Description: This routine configures the LCD. Based on              *
* the Hitachi HD44780 LCD controller. The                             *
* routine will configure the I/O pins of the                          *
* microcontroller, setup the LCD for 4- or                            *
* 8-bit mode and clear the display. The user                          *
* must provide three delay routines:                                  *
* DelayFor18TCY() provides a 18 Tcy delay                             *
* DelayPORXLCD() provides at least 15ms delay                         *
* DelayXLCD() provides at least 5ms delay                             *
void OpenXLCD(unsigned char lcdtype) {
// The data bits must be from either a 8-bit port or the upper and
// lower 4-bit port. These pins should be set to input
#ifdef BIT8 									// 8-bit mode, use whole port
    DATA_PORT &= 0;
    TRIS_DATA_PORT |= 0xff;
#else 											// 4-bit mode
	#ifdef UPPER 								// Upper 4-bits of the port
    	DATA_PORT &= 0x0f;
    	TRIS_DATA_PORT |= 0xf0;
	#else 										// Lower 4-bits of the port
    	DATA_PORT &= 0xf0;
    	TRIS_DATA_PORT |= 0x0f;
	#endif
#endif
    TRIS_RW = 0; 								// All control signals made outputs
    TRIS_RS = 0;
    TRIS_E = 0;
    RW_PIN = 0; 								// R/W pin made low
    RS_PIN = 0; 								// Register select pin made low
    E_PIN = 0; 									// Clock pin made low
//-- Delay for 15ms to allow for LCD Power on reset
    DelayPORXLCD();
//-- Setup interface to LCD
#ifdef BIT8 									// 8-bit mode interface
    TRIS_DATA_PORT &= 0; 						// Data port output
    DATA_PORT &= 0;
    DATA_PORT |= 0b00110000; 					// Function set cmd(8-bit interface)
#else 											// 4-bit mode interface
    	TRIS_DATA_PORT &= 0x0f;
    	DATA_PORT &= 0x0f;
    	DATA_PORT |= 0b00100000; 				// Function set cmd(4-bit interface)
	    TRIS_DATA_PORT &= 0xf0;
	    DATA_PORT &= 0xf0;
	    DATA_PORT |= 0b00000010; 				// Function set cmd(4-bit interface)
	#endif
#endif
    E_PIN = 1; 									// Clock the cmd in
    DelayFor18TCY();
    E_PIN = 0;
    DelayXLCD();								// Delay for at least 4.1ms
    DATA_PORT &= 0;
    	DATA_PORT &= 0x0f; 						// Function set cmd(4-bit interface)
	    DATA_PORT &= 0xf0; 						// Function set cmd(4-bit interface)
	#endif
#endif
    DelayFor18TCY();
    E_PIN = 0;
    DelayXLCD();								// Delay for at least 100us
    DATA_PORT &= 0;
	#endif
#endif
    E_PIN = 1; 									// Clock cmd in
    DelayFor18TCY();
    E_PIN = 0;
    TRIS_DATA_PORT |= 0xff; 					// Make data port input
    	TRIS_DATA_PORT |= 0xf0; 				// Make data nibble input
    	TRIS_DATA_PORT |= 0x0f; 				// Make data nibble input
	#endif
#endif
//-- Set data interface width, # lines, font
    while (BusyXLCD()); 						// Wait if LCD busy
    WriteCmdXLCD(lcdtype); 						// Function set cmd
//-- Turn the display on then off
    WriteCmdXLCD(DOFF); 						// Display OFF/Blink OFF
    WriteCmdXLCD(DON); 							// Display ON/Blink ON
    WriteCmdXLCD(BLINK_OFF&CURSOR_OFF); 		// Display ON/Blink ON
//-- Clear display
    WriteCmdXLCD(0x01); 						// Clear display
//-- Set entry mode inc, no shift
    WriteCmdXLCD(SHIFT_CUR_LEFT); 				// Entry Mode
//-- Set DD Ram address to 0
    SetDDRamAddr(0); 							// Set Display data ram address to 0
    return;
* Function Name: putrsXLCD
* Parameters: buffer: pointer to string
* Description: This routine writes a string of bytes to the
* Hitachi HD44780 LCD controller. The user
* must check to see if the LCD controller is
* busy before calling this routine. The data
* is written to the character generator RAM or
* the display data RAM depending on what the
* previous SetxxRamAddr routine was called.
void putrsXLCD(const rom char *buffer)
	while(*buffer) {							// Write data to LCD up to null
		while(BusyXLCD()); 						// Wait while LCD is busy
		WriteDataXLCD(*buffer); 				// Write character to LCD
		buffer++; 								// Increment buffer
	return;
* Function Name: putsXLCD
void putsXLCD(char *buffer) {
    while (*buffer) { 							// Write data to LCD up to null
        while (BusyXLCD()); 					// Wait while LCD is busy
    return;
* Function Name: ReadAddrXLCD                                        *
* Return Value: char: address from LCD controller                    *
* Description: This routine reads an address byte from the           *
* Hitachi HD44780 LCD controller. The user                           *
* must check to see if the LCD controller is                         *
* busy before calling this routine. The address                      *
* is read from the character generator RAM or                        *
* the display data RAM depending on what the                         *
* previous SetxxRamAddr routine was called.                          *
unsigned char ReadAddrXLCD(void) {
    char data; 							// Holds the data retrieved from the LCD
    RW_PIN = 1; 						// Set control bits for the read
    RS_PIN = 0;
    DelayFor18TCY();
    E_PIN = 1; 							// Clock data out of the LCD controller
    DelayFor18TCY();
    data = DATA_PORT; 					// Save the data in the register
    E_PIN = 0;
    RW_PIN = 0; 						// Reset the control bits
    RS_PIN = 0;
    DelayFor18TCY();
    DelayFor18TCY();
	    data = DATA_PORT&0xf0; 			// Read the nibble into the upper nibble of data
	    data = (DATA_PORT<<4)&0xf0; 	// Read the nibble into the upper nibble of data
	#endif
    E_PIN = 0; 							// Reset the clock
    DelayFor18TCY();
    E_PIN = 1; 							// Clock out the lower nibble
    DelayFor18TCY();
    data |= (DATA_PORT>>4)&0x0f; 		// Read the nibble into the lower nibble of data
    data |= DATA_PORT&0x0f; 			// Read the nibble into the lower nibble of data
#endif
    E_PIN = 0;
    RW_PIN = 0; 						// Reset the control lines
#endif
    return (data&0x7f); 				// Return the address, Mask off the busy bit
* Function Name: ReadDataXLCD *
* Return Value: char: data byte from LCD controller *
* Description: This routine reads a data byte from the *
* busy before calling this routine. The data *
char ReadDataXLCD(void) {
    char data;
    RS_PIN = 1; // Set the control bits
    RW_PIN = 1;
    DelayFor18TCY();
    E_PIN = 1; // Clock the data out of the LCD
    DelayFor18TCY();
    data = DATA_PORT; // Read the data
    E_PIN = 0;
    RS_PIN = 0; // Reset the control bits
    RW_PIN = 0;
    RW_PIN = 1;
    RS_PIN = 1;
    DelayFor18TCY();
    DelayFor18TCY();
    data = DATA_PORT&0xf0; // Read the upper nibble of data
    data = (DATA_PORT<<4)&0xf0; // read the upper nibble of data
#endif
    E_PIN = 0; // Reset the clock line
    DelayFor18TCY();
    E_PIN = 1; // Clock the next nibble out of the LCD
    DelayFor18TCY();
    data |= (DATA_PORT>>4)&0x0f; // Read the lower nibble of data
    data |= DATA_PORT&0x0f; // Read the lower nibble of data
#endif
    E_PIN = 0;
    RW_PIN = 0;
#endif
    return(data); // Return the data byte
* Function Name: SetCGRamAddr *
* Parameters: CGaddr: character generator ram address *
* Description: This routine sets the character generator *
* address of the Hitachi HD44780 LCD *
* controller. The user must check to see if *
* the LCD controller is busy before calling *
* this routine. *
void SetCGRamAddr(unsigned char CGaddr) {
    TRIS_DATA_PORT = 0; // Make data port ouput
    DATA_PORT = CGaddr | 0b01000000; // Write cmd and address to port
    RW_PIN = 0; // Set control signals
    RS_PIN = 0;
    DelayFor18TCY();
    E_PIN = 1; // Clock cmd and address in
    DelayFor18TCY();
    E_PIN = 0;
    DelayFor18TCY();
    TRIS_DATA_PORT = 0xff; // Make data port inputs
    TRIS_DATA_PORT &= 0x0f; // Make nibble input
    DATA_PORT &= 0x0f; // and write upper nibble
    DATA_PORT |= ((CGaddr | 0b01000000) & 0xf0);
    TRIS_DATA_PORT &= 0xf0; // Make nibble input
    DATA_PORT &= 0xf0; // and write upper nibble
    DATA_PORT |= (((CGaddr |0b01000000)>>4) & 0x0f);
#endif
    RS_PIN = 0;
    DelayFor18TCY();
    DelayFor18TCY();
    E_PIN = 0;
    DATA_PORT &= 0x0f; // Write lower nibble
    DATA_PORT |= ((CGaddr<<4)&0xf0);
    DATA_PORT &= 0xf0; // Write lower nibble
    DATA_PORT |= (CGaddr&0x0f);
#endif
    DelayFor18TCY();
    DelayFor18TCY();
    E_PIN = 0;
    TRIS_DATA_PORT |= 0xf0; // Make inputs
    TRIS_DATA_PORT |= 0x0f; // Make inputs
#endif
#endif
    return;
* Function Name: SetDDRamAddr *
* Parameters: CGaddr: display data address *
* Description: This routine sets the display data address *
* of the Hitachi HD44780 LCD controller. The *
* user must check to see if the LCD controller*
* is busy before calling this routine. *
void SetDDRamAddr(unsigned char DDaddr) {
    TRIS_DATA_PORT = 0; // Make port output
    DATA_PORT = DDaddr | 0b10000000; // Write cmd and address to port
    RW_PIN = 0; // Set the control bits
    RS_PIN = 0;
    DelayFor18TCY();
    E_PIN = 1; // Clock the cmd and address in
    DelayFor18TCY();
    E_PIN = 0;
    DelayFor18TCY();
    TRIS_DATA_PORT = 0xff; // Make port input
    TRIS_DATA_PORT &= 0x0f; // Make port output
    DATA_PORT |= ((DDaddr | 0b10000000) & 0xf0);
    TRIS_DATA_PORT &= 0xf0; // Make port output
    DATA_PORT |= (((DDaddr | 0b10000000)>>4) & 0x0f);
#endif
    RW_PIN = 0; // Set control bits
    RS_PIN = 0;
    DelayFor18TCY();
    DelayFor18TCY();
    E_PIN = 0;
    DATA_PORT |= ((DDaddr<<4)&0xf0);
    DATA_PORT |= (DDaddr&0x0f);
#endif
    DelayFor18TCY();
    DelayFor18TCY();
    E_PIN = 0;
    TRIS_DATA_PORT |= 0xf0; // Make port input
    TRIS_DATA_PORT |= 0x0f; // Make port input
#endif
#endif
    return;
* Function Name: WriteCmdXLCD *
* Parameters: cmd: command to send to LCD *
* Description: This routine writes a command to the Hitachi*
* HD44780 LCD controller. The user must check *
* to see if the LCD controller is busy before *
* calling this routine. *
void WriteCmdXLCD(unsigned char cmd) {
    DATA_PORT &= 0;
    DATA_PORT |= cmd; // Write command to data port
    RW_PIN = 0; // Set the control signals
    RS_PIN = 0; // for sending a command
    DelayFor18TCY();
    E_PIN = 1; // Clock the command in
    DelayFor18TCY();
    E_PIN = 0;
    DelayFor18TCY();
    TRIS_DATA_PORT |= 0xff; // Data port input
    DATA_PORT &= 0x0f;
    DATA_PORT |= cmd&0xf0;
    DATA_PORT &= 0xf0;
    DATA_PORT |= (cmd>>4)&0x0f;
#endif
    RW_PIN = 0; // Set control signals for command
    RS_PIN = 0;
    DelayFor18TCY();
    E_PIN = 1; // Clock command in
    DelayFor18TCY();
    E_PIN = 0;
    DATA_PORT &= 0x0f;
    DATA_PORT |= (cmd<<4)&0xf0;
    DATA_PORT &= 0xf0;
    DATA_PORT |= cmd&0x0f;
#endif
    DelayFor18TCY();
    DelayFor18TCY();
    E_PIN = 0;
#ifdef UPPER // Make data nibble input
#else
#endif
#endif
    return;
* Function Name: WriteDataXLCD *
* Parameters: data: data byte to be written to LCD *
* Description: This routine writes a data byte to the *
* is written to the character generator RAM or*
void WriteDataXLCD(char data) {
    DATA_PORT = data; // Write data to port
    RS_PIN = 1; // Set control bits
    RW_PIN = 0;
    DelayFor18TCY();
    E_PIN = 1; // Clock data into LCD
    DelayFor18TCY();
    E_PIN = 0;
    RS_PIN = 0; // Reset control bits
    DATA_PORT &= 0x0f;
    DATA_PORT |= data&0xf0;
    DATA_PORT &= 0xf0;
    DATA_PORT |= ((data>>4)&0x0f);
#endif
    RW_PIN = 0;
    DelayFor18TCY();
    E_PIN = 1; // Clock nibble into LCD
    DelayFor18TCY();
    E_PIN = 0;
    DATA_PORT &= 0x0f;
    DATA_PORT |= ((data<<4)&0xf0);
    DATA_PORT &= 0xf0;
    DATA_PORT |= (data&0x0f);
#endif
    DelayFor18TCY();
    DelayFor18TCY();
    E_PIN = 0;
#endif
#endif
    return;
void DelayFor18TCY( void ) {
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
void DelayPORXLCD (void) {
    Delay1KTCYx(75); // Delay of 15ms
// Cycles = (TimeDelay * Fosc) / 4
// Cycles = (15ms * 20MHz) / 4
// Cycles = 75,000
    return;
void DelayXLCD (void) {
    Delay1KTCYx(25); // Delay of 5ms
// Cycles = (5ms * 20MHz) / 4
// Cycles = 25,000
    return;
// Initializtion
void init(void) {
    CMCON=0b00000111; // Close Comparator
    TRISA=0b00000001;
    TRISB=0b00010000;
    TRISC=0b00000000;
    TRISD=0b00000000;
    TRISE=0b00001000;
    ADCON1=0b00001110; // Configure to digital all but AN0
// Main Programmer
void main( void ) {
    unsigned char i;
    char display_name[]="PICCOLO project";
    char display_Ver[]= "LCD 8-bit mode";
#else
    char display_Ver[]= "LCD 4-bit mode";
#endif
    init();
// Configure external LCD
    OpenXLCD( EIGHT_BIT&LINES_5X7 );
#else
    OpenXLCD( FOUR_BIT&LINES_5X7 );
#endif
// Write to LCD
    putsXLCD(display_name);
// Write to LCD
    SetDDRamAddr(0x40);
    putsXLCD(display_Ver);
    while (1) {};
