; Source created with Parsic Version 3.x
; at              : 2010.10.24. 20:39:36
; Project File    : C:\PROGRA~1\Parsic\PROJEK~1\FM_test.PIC
; Project Version : 1.0.1
; Created         : 2010.10.24. 20:27:57
; Last change     : 2010.10.24. 20:39:34
	PROCESSOR 16F877
	INCLUDE P16F877.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC & _LVP_OFF & _CPD_OFF & _DEBUG_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
ZV1	= 32	; located in Bank 0
ZV1_HI	= 33	; located in Bank 0
ZV1_FD	= 34	; located in Bank 0
S1	= 35	; located in Bank 0
S1_HI	= 36	; located in Bank 0
S3	= 37	; located in Bank 0
OS1_FD	= 38	; located in Bank 0
TR1	= 39	; located in Bank 0
TR1_HI	= 40	; located in Bank 0
OS2_FD	= 41	; located in Bank 0
OS3_FD	= 42	; located in Bank 0
OS4_FD	= 43	; located in Bank 0
S0	= 44	; located in Bank 0
LT1_FD	= 45	; located in Bank 0
S2	= 46	; located in Bank 0
S2_HI	= 47	; located in Bank 0
RAM	= 48	; located in Bank 0
SYS_TMP1	= 114	; located in Bank 0, 1, 2, 3
SYS_WSAV	= 115	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 116	; located in Bank 0, 1, 2, 3
SYS_PSAV	= 117	; located in Bank 0, 1, 2, 3
SYS_TMP2	= 118	; located in Bank 0, 1, 2, 3
SYS_TMP3	= 119	; located in Bank 0, 1, 2, 3
SYS_TMP4	= 120	; located in Bank 0, 1, 2, 3
SYS_TMP5	= 121	; located in Bank 0, 1, 2, 3
SYS_TMP6	= 122	; located in Bank 0, 1, 2, 3
SYS_TMP9	= 123	; located in Bank 0, 1, 2, 3
SYS_TMP10	= 124	; located in Bank 0, 1, 2, 3
SYS_TMP7	= 125	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 126	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	MOVLW HIGH SYS_INIT	; set page
	MOVWF PCLATH
	GOTO SYS_INIT
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	MOVFW PCLATH
	MOVWF SYS_PSAV
	CLRF PCLATH
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
EXITINT
	MOVFW SYS_PSAV
	MOVWF PCLATH
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Multiplikation 16 - Bit
; OP1 = SYS_TMP1,2
; OP2 = SYS_TMP3,4
SYSMUL16
	MOVLW 16	; set loopcounter
	MOVWF SYS_TMP7
	CLRF SYS_TMP5	; clear result
	CLRF SYS_TMP6
SYSMUL16_1
	RRF SYS_TMP4,F
	RRF SYS_TMP3,F
	BTFSS STATUS,CARRY
	GOTO SYSMUL16_2
	MOVFW SYS_TMP2	; add High-Byte
	ADDWF SYS_TMP6,F
	MOVFW SYS_TMP1	; add Low-Byte
	ADDWF SYS_TMP5,F
	BTFSC STATUS,CARRY	; carry ?
	INCF SYS_TMP6,F	; add 256 to result
SYSMUL16_2
	BCF STATUS,CARRY
	RLF SYS_TMP1,F
	RLF SYS_TMP2,F
	DECFSZ SYS_TMP7,F
	GOTO SYSMUL16_1
	RETURN
; Subroutines
; Subroutines for LB1
LCD_LB1_INIT
	BCF PORTB,4	; ir-register
LCD_LB1_L1
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L1
	MOVFW PORTB
	ANDLW H'F0'
	IORLW B'0011'	; Function Set
	MOVWF PORTB
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	BSF SYS_TMP1,5	; wait
LCD_LB1_L2
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L2
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	BCF PORTB,0	; 4-Bit Interface
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	MOVLW B'00101000'	; Function Set 4-Bit,2-Lines
	CALL LCD_LB1_OUT
	MOVLW B'00001100'	; Display on, Cursor off, Blink off
	CALL LCD_LB1_OUT
	MOVLW B'00000110'	; Entrymode set
	CALL LCD_LB1_OUT
LCD_LB1_CLR
	MOVLW B'00000001'	; Display clear
	CALL LCD_LB1_OUT
LCD_LB1_L3
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L3
	GOTO LCD_LB1_OUT4
LCD_LB1_GOTOXY
	MOVLW H'40'
	BTFSC SYS_TMP2,0	; Ypos
	ADDWF SYS_TMP1,F
	MOVLW D'20'
	BTFSC SYS_TMP2,1	; Ypos
	ADDWF SYS_TMP1,F
	BSF SYS_TMP1,7	; select dd-ram
	GOTO LCD_LB1_OUT1
LCD_LB1_WRITESTR
	BSF PORTB,4	; dd-ram
LCD_LB1_WRITESTR1
	CALL LCD_LB1_CHAROUT
	BSF INTCON,GIE
	ANDLW H'FF'	; last is zero
	BTFSC STATUS,ZERO
	RETURN
	MOVWF SYS_TMP1
	MOVLW HIGH LCD_LB1_OUT1	; set page
	MOVWF PCLATH
	CALL LCD_LB1_OUT1
	INCFSZ SYS_TMP4,F	; next char
	GOTO LCD_LB1_WRITESTR1
	INCF SYS_TMP5,F	; next page
LCD_LB1_CHAROUT
	BCF INTCON,GIE
	MOVFW SYS_TMP5
	MOVWF PCLATH
	MOVFW SYS_TMP4
	MOVWF PCL
LCD_LB1_DEZO10000
	MOVLW LOW 10000
	MOVWF SYS_TMP1
	MOVLW HIGH 10000
	MOVWF SYS_TMP2
	CALL LCD_LB1_CONVERTDEZ
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO1000
	CALL LCD_LB1_CHECKNULL
LCD_LB1_DEZO1000
	MOVLW LOW 1000
	MOVWF SYS_TMP1
	MOVLW HIGH 1000
	MOVWF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
LCD_LB1_DEZO100
	MOVLW LOW 100
	MOVWF SYS_TMP1
	CLRF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO10
LCD_LB1_DEZO10
	MOVLW LOW 10
	MOVWF SYS_TMP1
	CLRF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO1
LCD_LB1_DEZO1
	MOVLW 48
	ADDWF SYS_TMP4,W
	GOTO LCD_LB1_WRITECHAR
LCD_LB1_CONVERTDEZ
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	DECF SYS_TMP9,F
	CLRF SYS_TMP6
LCD_LB1_CONVERTDEZ2
	INCF SYS_TMP6,F
	MOVFW SYS_TMP1
	SUBWF SYS_TMP4,F
	MOVFW SYS_TMP2
	BTFSS STATUS,CARRY
	INCFSZ SYS_TMP2,W
	SUBWF SYS_TMP5,F
	BTFSC STATUS,CARRY
	GOTO LCD_LB1_CONVERTDEZ2
	MOVFW SYS_TMP2
	ADDWF SYS_TMP5,F
	MOVFW SYS_TMP1
	ADDWF SYS_TMP4,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP5,F
	DECF SYS_TMP6,W
	BTFSS STATUS,ZERO
	BSF SYS_TMP10,0
	RETURN
LCD_LB1_CONVERTHEX
	ANDLW 15
	MOVWF SYS_TMP1
	MOVLW 48
	ADDWF SYS_TMP1,F
	MOVLW 58
	SUBWF SYS_TMP1,W
	BTFSS STATUS,CARRY
	GOTO $+3
	MOVLW 7
	ADDWF SYS_TMP1,F
	MOVFW SYS_TMP1
LCD_LB1_WRITECHAR
LCD_LB1_OUT
	MOVWF SYS_TMP1	; store
LCD_LB1_OUT1
	CLRF SYS_TMP3	; LCDWriteStr (first nibble)
LCD_LB1_OUT2
	SWAPF SYS_TMP1,W	;high nibble
LCD_LB1_OUT3
	ANDLW H'0F'	; mask
	MOVWF SYS_TMP2	; store
	MOVFW PORTB	; load port
	ANDLW H'F0'	; mask
	IORWF SYS_TMP2,W	; add cmd
	MOVWF PORTB	; out
	BSF PORTB,5	; E high
	GOTO $+1
	BCF PORTB,5	; E low
	BTFSC SYS_TMP3,3	; ready ?
	GOTO LCD_LB1_OUT4	; yes
	BSF SYS_TMP3,3	; second nibble
	MOVFW SYS_TMP1
	GOTO LCD_LB1_OUT3	; next nibble
LCD_LB1_OUT4
LCD_LB1_OUTV
	DECFSZ SYS_TMP3,F
	GOTO LCD_LB1_OUTV
	RETURN
LCD_LB1_CHECKNULL
	BTFSS STATUS,ZERO
	DECF SYS_TMP9,F
	MOVWF SYS_TMP1
	BTFSS STATUS,ZERO
	BSF SYS_TMP10,0
	MOVLW 48
	BTFSC SYS_TMP10,0
	ADDWF SYS_TMP1,f
	MOVLW 32
	BTFSS SYS_TMP10,0
	ADDWF SYS_TMP1,F
	MOVFW SYS_TMP1
; 00ED
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW B'00000000'
	MOVWF PORTC
	MOVLW B'00000000'
	MOVWF PORTD
	MOVLW B'00000000'
	MOVWF PORTE
	MOVLW 143
	BSF STATUS,RP0	; Bank 1
	MOVWF OPTION_REG
	MOVLW 6	; all Digital
	MOVWF ADCON1
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'11000000'
	MOVWF TRISB
	MOVLW B'11111111'
	MOVWF TRISC
	MOVLW B'11111111'
	MOVWF TRISD
	MOVLW B'00000111'
	MOVWF TRISE
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 16
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'70'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	MOVLW 144
	MOVWF FSR
CR4
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR4
; Init LCD -> LB1
	CALL LCD_LB1_INIT
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; Zähler -> ZV1
	BTFSS S3,5	; Reset ?
	GOTO LABEL_ZV1_COUNT
	CLRF ZV1
	CLRF ZV1_HI
	GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf positive Flanke
	BTFSS S3,0
	GOTO LABEL_ZV1_SETFD
	BTFSC ZV1_FD,0
	BSF ZV1_FD,0
	BTFSC S3,6	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV1_BACKWARD
	INCFSZ ZV1,F
	INCF ZV1_HI,F
LABEL_ZV1_BACKWARD
	DECF ZV1,F
	INCFSZ ZV1,W
	DECF ZV1_HI,F
LABEL_ZV1_SETOUT
LABEL_ZV1_SETFD
; Test auf negative Flanke
	BTFSC S3,0
	GOTO LABEL_ZV1_EXIT
	BCF ZV1_FD,0
LABEL_ZV1_EXIT
; Multiplexer -> MX1
	CLRF SYS_TMP1
	MOVFW S0
	BTFSS STATUS,ZERO
	GOTO LABEL_MX1_CHECKCONTROL1
	MOVFW S1
	MOVWF S1
	MOVFW S1_HI
	MOVWF S1_HI
	GOTO LABEL_MX1_END
	INCF SYS_TMP1,F
	MOVFW S0
	SUBWF SYS_TMP1,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MX1_CHECKCONTROL2
	MOVFW ZV1
	MOVWF S1
	MOVFW ZV1_HI
	MOVWF S1_HI
	GOTO LABEL_MX1_END
LABEL_MX1_END
; One Shot -> OS1
	BTFSS S3,1
	GOTO LABEL_OS1_1
	BTFSC OS1_FD,0
	GOTO LABEL_OS1_1
	BSF OS1_FD,0
	BSF S3,0
	GOTO LABEL_OS1_2
LABEL_OS1_1
	BCF S3,0
	BTFSC S3,1
	GOTO LABEL_OS1_2
	BCF OS1_FD,0
LABEL_OS1_2
; Timer -> TR1
	MOVLW 7	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 161
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 161
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S3,2
	GOTO LABEL_TR1_CLR
	BSF S3,2
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S3,2
LABEL_TR1_ENDE
; One Shot -> OS2
	BTFSS S3,2
	GOTO LABEL_OS2_1
	BTFSC OS2_FD,0
	GOTO LABEL_OS2_1
	BSF OS2_FD,0
	BSF S3,3
	GOTO LABEL_OS2_2
LABEL_OS2_1
	BCF S3,3
	BTFSC S3,2
	GOTO LABEL_OS2_2
	BCF OS2_FD,0
LABEL_OS2_2
; One Shot -> OS3
	BTFSC S3,3
	GOTO LABEL_OS3_1
	BTFSC OS3_FD,0
	GOTO LABEL_OS3_1
	BSF OS3_FD,0
	BSF S3,4
	GOTO LABEL_OS3_2
LABEL_OS3_1
	BCF S3,4
	BTFSS S3,3
	GOTO LABEL_OS3_2
	BCF OS3_FD,0
LABEL_OS3_2
; One Shot -> OS4
	BTFSS S3,4
	GOTO LABEL_OS4_1
	BTFSC OS4_FD,0
	GOTO LABEL_OS4_1
	BSF OS4_FD,0
	BSF S3,5
	GOTO LABEL_OS4_2
LABEL_OS4_1
	BCF S3,5
	BTFSC S3,4
	GOTO LABEL_OS4_2
	BCF OS4_FD,0
LABEL_OS4_2
; Verteiler -> BV1
	MOVLW 0 
	BTFSC S3,3	; IN0
	IORLW 1
	MOVWF S0	; OUT
; LCD -> LT1
; test of positiv edge
	BTFSC LT1_FD,0
	GOTO LABEL_LT1_SETFD
	BTFSS S3,5
	MOVLW 0
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVLW HIGH LCD_LB1_GOTOXY	; set page
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVFW S2
	MOVWF SYS_TMP4
	MOVFW S2_HI
	MOVWF SYS_TMP5
	BCF SYS_TMP10,0
	CLRF SYS_TMP9
	MOVLW HIGH LCD_LB1_DEZO10000	; set page
	MOVWF PCLATH
	CALL LCD_LB1_DEZO10000
	BCF PCLATH,3	; Page 0
	BCF PCLATH,4	; Page 0
LABEL_LT1_SETFD
	BTFSS S3,5
	GOTO LABEL_LT1_SETFD2
	BSF LT1_FD,0
	GOTO LABEL_LT1_END
LABEL_LT1_SETFD2
	BCF LT1_FD,0
LABEL_LT1_END
; GND
	BCF S3,6	; immer Low
;AF1
	MOVLW LOW 100
	MOVWF SYS_TMP1
	MOVLW HIGH 100
	MOVWF SYS_TMP2
	MOVFW S1
	MOVWF SYS_TMP3
	MOVFW S1_HI
	MOVWF SYS_TMP4
	MOVLW HIGH SYSMUL16
	MOVWF PCLATH
	CALL SYSMUL16
	MOVLW HIGH LABEL_AF1
	MOVWF PCLATH
LABEL_AF1
	MOVFW SYS_TMP5
	MOVWF S2
	MOVFW SYS_TMP6
	MOVWF S2_HI
LABEL_AF1_EXIT
	GOTO MAIN
	END
