To english readers: since I only have experience with german mailorder
distributors, this list is mainly dedicated for users from Germany
To US people: check SmashTV's Website for a Mouser orderlist:
http://mbhp.coinoptech.com
MBHP Core Orderlist (last update: 06-2006)
All prices in EUR (Euro)
Exchange rate: 1 EUR = 0.85 US$
Other exchange rates: see http://www.xe.com
at http://www.reichelt.de
| Description                                  | Qty   | Part #             | Price | Total  |
| PIC18F452-I/P                                |     1 | PIC 18F452-I/P     |  6.70 |   6.70 |
| Crystal 10 MHz                               |     1 | 10,0000-HC49U-S    |  0.24 |   0.24 |
| Voltage Regulator 7805                       |     1 | uA 7805            |  0.28 |   0.28 |
| IC-Socket for PIC                            |     1 | GS 40              |  0.11 |   0.11 |
| Optocoupler 6N138                            |     1 | 6N 138             |  0.69 |   0.69 |
| IC-Socket for Optocoupler                    |     1 | GS 8               |  0.04 |   0.04 |
| Transistor BC337                             |     1 | BC 337-16          |  0.06 |   0.06 |
| Resistor 10 kOhm                             |     3 | 1/4W 10k           |  0.03 |   0.09 |
| Resistor 5.6 kOhm                            |     1 | 1/4W 5.6k          |  0.03 |   0.03 |
| Resistor 1.2 kOhm                            |     1 | 1/4W 1.2k          |  0.03 |   0.03 |
| Resistor 1 kOhm                              |     3 | 1/4W 1.0k          |  0.03 |   0.09 |
| Resistor 220 Ohm                             |     3 | 1/4W 220           |  0.03 |   0.09 |
| Resistor 100 Ohm                             |     1 | 1/4W 100           |  0.03 |   0.03 |
| Ceramic Cap 100 nF                           |     3 | Z5U-2,5 100n       |  0.06 |   0.18 |
| Ceramic Cap 330 nF                           |     1 | MKS-2 330n         |  0.17 |   0.17 |
| Ceramic Cap 33 pF                            |     2 | Kerko 33p          |  0.04 |   0.08 |
| Polarised Capacitor 10 uF                    |     1 | rad 10/35          |  0.05 |   0.05 |
| Polarised Capacitor 2200 uF                  |     1 | rad 2.200/16       |  0.26 |   0.26 |
| Diode 1N4148                                 |     1 | 1N 4148            |  0.02 |   0.02 |
| Rectifier                                    |     1 | B80C800RUND        |  0.18 |   0.18 |
| TrimmPot 10 k                                |     2 | PIHER 10-S 10K     |  0.19 |   0.38 |
| MIDI Sockets                                 |     4 | MAB 5S             |  0.25 |   1.00 |
| 1-row SIL Headers (about 30 pins)            |     1 | SL 1X40G 2,54      |  0.18 |   0.18 |
| 2-row SIL Headers (about 2*22pins)           |     1 | SL 2X40G 2,54      |  0.27 |   0.27 |
| Ribbon cable 3 meters                        |     3 | AWG 28-16G         |  0.66 |   1.98 |
| Wall adapter (Power supply) 500 mA           |     1 | MW 17-GS/6         |  5.35 |   5.35 |
| Socket for Power Supply                      |     1 | HEBLM 21           |  0.77 |   0.77 |
Note 1: The IC socket for the PIC is strongly recommented! The chip is reprogrammable and without
        the Socket you cannot burn bootloader updates or replace by a better PIC later.
Note 2: the ribbon cable is listed for people who don't have alread cable at home ;-)
Note 3: if you don't already own MIDI cables, just build them yourself: for each cable
        order two 5 pol DIN plugs and cable - sometimes called HIFI cable
Note 4: ...or buy MIDI cables from Reichelt: AVK121 (2.5m, EUR 0.67) or AVK192 (5m, EUR 1.10)
Note 5: outside europe the BC337 is hard to find, the 2N3904 is a good replacement
        But note that the outer pins (E and C) are exchanged - you have to upturn the
        transistor to get the E, B, C pin matching with the PCB
Note 6: the PIC can be alternatively ordered at:
           o http://www.voti.nl       : Part #PIC18F452 (10.85 EUR)
           o http://www.farnell.de    : Part #4113792 (11.30 EUR)
           o http://www.schuricht.de  : Part #646587 (13.44 EUR)
           o http://www.conrad.de     : Part #165154 - 14 (16.40 EUR)
           o http://www.microchip.com : PIC18F452 available as free sample
NOTE 7: for MIDIbox SEQ V3 the PIC18F452 has to be replaced by a PIC18F4620
NOTE 8: for MIDIbox SID V2 the PIC18F452 has to be replaced by a PIC18F4685
        (can be ordered "preburned" from SmashTV (US) or doc (Europe))
Thorsten.Klose@midibox.org
