void ir_read(void);   // IR routines
void ir_get_rise(void);
void ir_get_fall(void);
void ir_build_bytes(void);
int32    ir_tempbyte_hi=0;
int16    ir_tempbyte_lo=0;
int8     rx_status   =0;
int8     protocol    =0;
int16    headp       =0;
int16    heads       =0;
int16    rise        =0;
int16    fall        =0;
int8     bitcount    =0;
int8     sample_RC5  =0;
int1     bit_prev    =0;
int1     bit_RC5     =0;
#define IR_SENSOR PIN_B0                  //infra
#define IR (!input(IR_SENSOR))
#byte keys      =0x06   //b
#bit CP1      =keys.0   // RC2 **** IR RX
void ir_read(void)
ir_tempbyte_hi=0;
ir_tempbyte_lo=0;
protocol=0;
rx_status=0;         // reset rx_status to error code 0
ir_get_rise();         // get headp & heads to see what protocol it is  0-ról 1 re
headp=rise;
ir_get_fall();         // 1ről 0-ra
heads=fall;
if ((headp>8800)&&(headp<9090)&&(heads>4200)&&(heads<4570)){protocol=2;}         // NEC
else if ((headp>2340)&&(headp<2480)&&(heads>470)&&(heads<575)){protocol=4;}         // SIRCS
else if ((headp>680)&&(headp<970)&&(heads>680)&&(heads<885)){protocol=5;}         // RC5
else if ((headp>3300)&&(headp<3590)&&(heads>1500)&&(heads<1695)){protocol=7;}      // JAPAN
else if ((headp>4305)&&(headp<4695)&&(heads>4200)&&(heads<4550)){protocol=8;}      // SAMSUNG
//end if;
if (protocol>0){rx_status=2;ir_build_bytes();} // got sequence_start, now trying to read data bits
else if (protocol==0){rx_status=1;}   // check: return if no prtocol recognized, set rx_status to error code 1
delay_ms(100);   // only for test
void ir_get_rise(void){
set_timer1(0);
while(IR);          // wait for signal to go high    // RC2, CCP1, pin 17
rise = get_timer1();
void ir_get_fall(void){
set_timer1(0);
while(CP1);          // wait for signal to go low 
fall = get_timer1();
if (protocol==2){            // if NEC protocol   ************************************************************
   for (bitcount=0;bitcount!=32;bitcount++){
      ir_get_rise();
      ir_get_fall();
      if ((rise>450)&&(rise<650)&&(fall>1400)&&(fall<1655)){ir_tempbyte_hi|=1;}   // bit=1
      else if   ((rise>450)&&(rise<650)&&(fall>390)&&(fall<600)){;}               // bit=0
      else return;                                                // error detection      
      if (bitcount<31){ir_tempbyte_hi<<=1;}      // don't shift last bit
   if (bitcount==32)rx_status=3;   // reception is valid
if (protocol==4){            // if SIRCS protocol   ************************************************************
   for (bitcount=0;bitcount!=11;bitcount++){
      ir_get_rise();
      ir_get_fall();
      if ((rise>1050)&&(rise<1250)&&(fall>400)&&(fall<620)){ir_tempbyte_hi|=1;}   // bit=1
      else if   ((rise>400)&&(rise<620)&&(fall>400)&&(fall<620)){;}               // bit=0
      ir_tempbyte_hi<<=1;      
   ir_get_rise();
      if ((rise>1050)&&(rise<1250)&&(fall>400)&&(fall<620)){ir_tempbyte_hi|=1;bitcount++;}      // last bit=1
      else if   ((rise>400)&&(rise<620)&&(fall>400)&&(fall<620)){bitcount++;}               // last bit=0
   if (bitcount==12)rx_status=3;   // reception is valid
else if (protocol==5){         // if RC5 protocol   ************************************************************
   bit_prev=1;      // start bit was 1   
   sample_RC5=0;
   for (bitcount=0;bitcount!=12;){
      if (!CP1){
      ir_get_rise();
      if ((rise>600)&&(rise<970)){sample_RC5=1;}
      else if ((rise>1500)&&(rise<1720)){sample_RC5=3;}
      else if (CP1){
      ir_get_fall();
      if ((fall>600)&&(fall<970)){sample_RC5=0;}
      else if ((fall>1500)&&(fall<1720)){sample_RC5=2;}
      if (sample_RC5>1){bit_RC5^=bit_prev; ir_tempbyte_hi|=bit_RC5; bitcount++; bit_prev=bit_RC5;}
      else if (sample_RC5==1){bit_RC5=bit_prev; ir_tempbyte_hi|=bit_RC5; bitcount++; bit_prev=bit_RC5;}
      else if (sample_RC5==0);
      if ((sample_RC5>0)&&(bitcount<12)){ir_tempbyte_hi<<=1;}
else if (protocol==7){            // if JAPAN protocol   ************************************************************
      ir_get_rise();
      ir_get_fall();
      if ((rise>300)&&(rise<500)&&(fall>1000)&&(fall<1450)){ir_tempbyte_hi|=1;}   // bit=1
      else if   ((rise>300)&&(rise<500)&&(fall>250)&&(fall<450)){;}               // bit=0
   for (bitcount=32;bitcount!=48;bitcount++){
      ir_get_rise();
      ir_get_fall();
      if ((rise>300)&&(rise<500)&&(fall>1000)&&(fall<1450)){ir_tempbyte_lo|=1;}   // bit=1
      if (bitcount<47){ir_tempbyte_lo<<=1;}      // don't shift last bit
   if (bitcount==48)rx_status=3;   // reception is valid
else if (protocol==8){         // if SAMSUNG protocol   ************************************************************
      ir_get_rise();
      ir_get_fall();
      if ((rise>380)&&(rise<670)&&(fall>1250)&&(fall<1750)){ir_tempbyte_hi|=1;}   // bit=1
      else if   ((rise>380)&&(rise<670)&&(fall>300)&&(fall<650)){;}               // bit=0
