Configuration settings available for processor 18F4520
  Oscillator Selection bits:
    OSC = LP       	LP oscillator
    OSC = XT       	XT oscillator
    OSC = HS       	HS oscillator
    OSC = RC       	External RC oscillator, CLKO function on RA6
    OSC = EC       	EC oscillator, CLKO function on RA6
    OSC = ECIO6    	EC oscillator, port function on RA6
    OSC = HSPLL    	HS oscillator, PLL enabled (Clock Frequency = 4 x FOSC1)
    OSC = RCIO6    	External RC oscillator, port function on RA6
    OSC = INTIO67  	Internal oscillator block, port function on RA6 and RA7
    OSC = INTIO7   	Internal oscillator block, CLKO function on RA6, port function on RA7
  Fail-Safe Clock Monitor Enable bit:
    FCMEN = OFF    	Fail-Safe Clock Monitor disabled
    FCMEN = ON     	Fail-Safe Clock Monitor enabled
  Internal/External Oscillator Switchover bit:
    IESO = OFF     	Oscillator Switchover mode disabled
    IESO = ON      	Oscillator Switchover mode enabled
  Power-up Timer Enable bit:
    PWRT = ON      	PWRT enabled
    PWRT = OFF     	PWRT disabled
  Brown-out Reset Enable bits:
    BOREN = OFF    	Brown-out Reset disabled in hardware and software
    BOREN = ON     	Brown-out Reset enabled and controlled by software (SBOREN is enabled)
    BOREN = NOSLP  	Brown-out Reset enabled in hardware only and disabled in Sleep mode (SBOREN is disabled)
    BOREN = SBORDIS	Brown-out Reset enabled in hardware only (SBOREN is disabled)
  Brown-out Reset Voltage bits:
    BORV = 0       	Maximum setting
    BORV = 1
    BORV = 2
    BORV = 3       	Minimum setting
  Watchdog Timer Enable bit:
    WDT = OFF      	WDT disabled (control is placed on the SWDTEN bit)
    WDT = ON       	WDT enabled
  Watchdog Timer Postscale Select bits:
    WDTPS = 1      	1:1
    WDTPS = 2      	1:2
    WDTPS = 4      	1:4
    WDTPS = 8      	1:8
    WDTPS = 16     	1:16
    WDTPS = 32     	1:32
    WDTPS = 64     	1:64
    WDTPS = 128    	1:128
    WDTPS = 256    	1:256
    WDTPS = 512    	1:512
    WDTPS = 1024   	1:1024
    WDTPS = 2048   	1:2048
    WDTPS = 4096   	1:4096
    WDTPS = 8192   	1:8192
    WDTPS = 16384  	1:16384
    WDTPS = 32768  	1:32768
  MCLR Pin Enable bit:
    MCLRE = OFF    	RE3 input pin enabled; MCLR disabled
    MCLRE = ON     	MCLR pin enabled; RE3 input pin disabled
  Low-Power Timer1 Oscillator Enable bit:
    LPT1OSC = OFF  	Timer1 configured for higher power operation
    LPT1OSC = ON   	Timer1 configured for low-power operation
  PORTB A/D Enable bit:
    PBADEN = OFF   	PORTB<4:0> pins are configured as digital I/O on Reset
    PBADEN = ON    	PORTB<4:0> pins are configured as analog input channels on Reset
  CCP2 MUX bit:
    CCP2MX = PORTBE	CCP2 input/output is multiplexed with RB3
    CCP2MX = PORTC 	CCP2 input/output is multiplexed with RC1
  Stack Full/Underflow Reset Enable bit:
    STVREN = OFF   	Stack full/underflow will not cause Reset
    STVREN = ON    	Stack full/underflow will cause Reset
  Single-Supply ICSP Enable bit:
    LVP = OFF      	Single-Supply ICSP disabled
    LVP = ON       	Single-Supply ICSP enabled
  Extended Instruction Set Enable bit:
    XINST = OFF    	Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
    XINST = ON     	Instruction set extension and Indexed Addressing mode enabled
  Background Debugger Enable bit:
    DEBUG = ON     	Background debugger enabled, RB6 and RB7 are dedicated to In-Circuit Debug
    DEBUG = OFF    	Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins
  Code Protection bit Block 0:
    CP0 = ON       	Block 0 (000800-001FFFh) code-protected
    CP0 = OFF      	Block 0 (000800-001FFFh) not code-protected
  Code Protection bit Block 1:
    CP1 = ON       	Block 1 (002000-003FFFh) code-protected
    CP1 = OFF      	Block 1 (002000-003FFFh) not code-protected
  Code Protection bit Block 2:
    CP2 = ON       	Block 2 (004000-005FFFh) code-protected
    CP2 = OFF      	Block 2 (004000-005FFFh) not code-protected
  Code Protection bit Block 3:
    CP3 = ON       	Block 3 (006000-007FFFh) code-protected
    CP3 = OFF      	Block 3 (006000-007FFFh) not code-protected
  Boot Block Code Protection bit:
    CPB = ON       	Boot block (000000-0007FFh) code-protected
    CPB = OFF      	Boot block (000000-0007FFh) not code-protected
  Data EEPROM Code Protection bit:
    CPD = ON       	Data EEPROM code-protected
    CPD = OFF      	Data EEPROM not code-protected
  Write Protection bit Block 0:
    WRT0 = ON      	Block 0 (000800-001FFFh) write-protected
    WRT0 = OFF     	Block 0 (000800-001FFFh) not write-protected
  Write Protection bit Block 1:
    WRT1 = ON      	Block 1 (002000-003FFFh) write-protected
    WRT1 = OFF     	Block 1 (002000-003FFFh) not write-protected
  Write Protection bit Block 2:
    WRT2 = ON      	Block 2 (004000-005FFFh) write-protected
    WRT2 = OFF     	Block 2 (004000-005FFFh) not write-protected
  Write Protection bit Block 3:
    WRT3 = ON      	Block 3 (006000-007FFFh) write-protected
    WRT3 = OFF     	Block 3 (006000-007FFFh) not write-protected
  Boot Block Write Protection bit:
    WRTB = ON      	Boot block (000000-0007FFh) write-protected
    WRTB = OFF     	Boot block (000000-0007FFh) not write-protected
  Configuration Register Write Protection bit:
    WRTC = ON      	Configuration registers (300000-3000FFh) write-protected
    WRTC = OFF     	Configuration registers (300000-3000FFh) not write-protected
  Data EEPROM Write Protection bit:
    WRTD = ON      	Data EEPROM write-protected
    WRTD = OFF     	Data EEPROM not write-protected
  Table Read Protection bit Block 0:
    EBTR0 = ON     	Block 0 (000800-001FFFh) protected from table reads executed in other blocks
    EBTR0 = OFF    	Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
  Table Read Protection bit Block 1:
    EBTR1 = ON     	Block 1 (002000-003FFFh) protected from table reads executed in other blocks
    EBTR1 = OFF    	Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
  Table Read Protection bit Block 2:
    EBTR2 = ON     	Block 2 (004000-005FFFh) protected from table reads executed in other blocks
    EBTR2 = OFF    	Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
  Table Read Protection bit Block 3:
    EBTR3 = ON     	Block 3 (006000-007FFFh) protected from table reads executed in other blocks
    EBTR3 = OFF    	Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
  Boot Block Table Read Protection bit:
    EBTRB = ON     	Boot block (000000-0007FFh) protected from table reads executed in other blocks
    EBTRB = OFF    	Boot block (000000-0007FFh) not protected from table reads executed in other blocks
