#include <12F675.h>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOCPD                    //No EE protection
#FUSES PROTECT                  //Code protected from reads
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOBROWNOUT               //No brownout reset
#FUSES BANDGAP_HIGH          
#use delay(clock=4000000)
int i=0;
int j=0;
void main()
   setup_adc_ports(NO_ANALOGS|VSS_VDD);
   setup_adc(ADC_OFF);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_comparator(NC_NC);
   setup_vref(FALSE);
   while(1)
   if((input(PIN_A2))&& i==0)//ha kapcs fel és még nem futott le
      i++;
      for (j=1;j<=20;++j)//20x 1mp(2x500ms)
         Output_high(PIN_a1);
         delay_ms(500);
         Output_low(PIN_a1);
         delay_ms(500);
      }//end for
   }//end if
   }//end while
}//end main
