This package contains the following files.
DECODER.TXT  This is the assembly code for the DCC compatible decoder. It
should be renamed to DECODER.ASM before assembling the code into a HEX file.
The program is setup so that any of the I/O pins can be used as the signal
input or driver outputs. You will need to redefine the port assignments
in the variable declaration and change the TRIS instuctions in the init
routine to match.
DECODER.XLS  This is an EXCEL spreadsheet that shows the timing of the
decode sequence. If you plan to make changes to the code (such as for an
accessory decoder or for extended addressing), you should use this
spreadsheet to ensure the timing is not altered.
