-- Company:
-- Engineer:
-- Create Date:    16:13:46 01/04/2011
-- Design Name:
-- Module Name:    KnightRiderFutofeny - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity KnightRiderFutofeny is
    Port ( pCLK : in  STD_LOGIC;
			  pRESET	: in STD_LOGIC;
           pLED0_9 : out  STD_LOGIC_VECTOR (9 downto 0));
end KnightRiderFutofeny;
architecture Behavioral of KnightRiderFutofeny is
	signal sLED0_9 : STD_LOGIC_VECTOR (9 downto 0);
	signal sDir, sRESET 	: STD_LOGIC;
begin
	pLED0_9 <= sLED0_9;
	sRESET <= pRESET;
	--ClockDeMux :
	process(pCLK, sRESET, sDIR)
	begin
		if (sRESET = '1') then
			 sDir <= '0';
			 sLED0_9 <= 	"0000000001";
		elsif (pCLK' event and pCLK = '1') then
				if sDir = '0' then
					case sLED0_9  is
						when "0000000001" => sLED0_9 <= "0000000010";
						when "0000000010" => sLED0_9 <= "0000000100";
						when "0000000100" => sLED0_9 <= "0000001000";
						when "0000001000" => sLED0_9 <= "0000010000";
						when "0000010000" => sLED0_9 <= "0000100000";
						when "0000100000" => sLED0_9 <= "0001000000";
						when "0001000000" => sLED0_9 <= "0010000000";
						when "0010000000" => sLED0_9 <= "0100000000";
						when others => sLED0_9 <= "0000000000";
					end case;
					if sLED0_9 = "0100000000" then
						sDir <= '1';
						sLED0_9 <= 	"1000000000";
					end if;
				end if;		
				if sDir = '1' then
					case sLED0_9  is
						when "1000000000" => sLED0_9 <= "0100000000";
						when "0100000000" => sLED0_9 <= "0010000000";
						when "0010000000" => sLED0_9 <= "0001000000";
						when "0001000000" => sLED0_9 <= "0000100000";
						when "0000100000" => sLED0_9 <= "0000010000";
						when "0000010000" => sLED0_9 <= "0000001000";
						when "0000001000" => sLED0_9 <= "0000000100";
						when "0000000100" => sLED0_9 <= "0000000010";
					end case;
					if sLED0_9 = "0000000010" then
						sDir <= '0';
					end if;
				end if;
		end if;
	end process;
end Behavioral;
