Partlist
Exported from bandidoII.sch at 27.01.2006 16:59:37
EAGLE Version 4.15 Copyright (c) 1988-2005 CadSoft
Part      Value          Device     Package  Library        Sheet
BATT                     M02        02P      con-amp-quick  1
C1        47n            CAPNP-5    C-5      discrete       1
C2        470n           CAPNP-5    C-5      discrete       1
C4        100u           ELC-5      ES-5     discrete       1
C5        100u           ELC-5      ES-5     discrete       1
C6        220u           ELC-5      ES-5     discrete       1
C8        220u           ELC-5      ES-5     discrete       1
C9        100p           CAPNP-5    C-5      discrete       1
C10       120p           CAPNP-5    C-5      discrete       1
C12       180p           CAPNP-5    C-5      discrete       1
C13       22p            CAPNP-5    C-5      discrete       1
C14       18p            CAPNP-5    C-5      discrete       1
C15       33n            CAPNP-5    C-5      discrete       1
C16       120p           CAPNP-5    C-5      discrete       1
C17       220n           CAPNP-5    C-5      discrete       1
C18       30p            CAPNP-5    C-5      discrete       1
C42       100u           ELC-5      ES-5     discrete       1
D2                       DIODE-7,5  D-7,5    discrete       1
D3                       DIODE-7,5  D-7,5    discrete       1
D4                       DIODE-7,5  D-7,5    discrete       1
D5                       DIODE-7,5  D-7,5    discrete       1
D7                       DIODE-7,5  D-7,5    discrete       1
DISK100K                 M03        03P      con-amp-quick  1
GROUND50K                M03        03P      con-amp-quick  1
IC1       4024           4024N      DIL14    40xx           1
IC4                      78XXS      78XXS    v-reg          1
IC5       LM393          LM393N     DIL08    linear         1
IC7       MC33178        LF442N     DIL08    linear         1
PAD2                     2,15/1,0   2,15/1,0 wirepad        1
PAD6                     2,15/1,0   2,15/1,0 wirepad        1
PAD7                     2,15/1,0   2,15/1,0 wirepad        1
Q1        2N3906         2N3906     TO92     transistor-pnp 1
Q2        2N3904         2N3904     TO92     transistor-npn 1
Q3        2N3904         2N3904     TO92     transistor-npn 1
Q4        2N3906         2N3906     TO92     transistor-pnp 1
Q5        2N3906         2N3906     TO92     transistor-pnp 1
Q6        2N3904         2N3904     TO92     transistor-npn 1
Q7        2N3906         2N3906     TO92     transistor-pnp 1
R1        1.2k           RESEU-7,5  R-7,5    discrete       1
R2        12k            RESEU-7,5  R-7,5    discrete       1
R3        20k            RESEU-7,5  R-7,5    discrete       1
R4        47k            RESEU-7,5  R-7,5    discrete       1
R5        10k            RESEU-7,5  R-7,5    discrete       1
R6        10k            RESEU-7,5  R-7,5    discrete       1
R7        2.2k           RESEU-7,5  R-7,5    discrete       1
R14       20             RESEU-7,5  R-7,5    discrete       1
R15       5.1k           RESEU-7,5  R-7,5    discrete       1
R16       150            RESEU-7,5  R-7,5    discrete       1
R17       100            RESEU-7,5  R-7,5    discrete       1
R19       82k            RESEU-7,5  R-7,5    discrete       1
R20       1k             RESEU-7,5  R-7,5    discrete       1
R21       10k            RESEU-7,5  R-7,5    discrete       1
R22       20k            RESEU-7,5  R-7,5    discrete       1
R23       100k           RESEU-7,5  R-7,5    discrete       1
R25       20k            RESEU-7,5  R-7,5    discrete       1
R26       5.1k           RESEU-7,5  R-7,5    discrete       1
R27       5.1k           RESEU-7,5  R-7,5    discrete       1
R28       100k           RESEU-7,5  R-7,5    discrete       1
R29       100k           RESEU-7,5  R-7,5    discrete       1
R30       1k             RESEU-7,5  R-7,5    discrete       1
R34       47k            RESEU-7,5  R-7,5    discrete       1
R63       100k           RESEU-7,5  R-7,5    discrete       1
R64       10k            RESEU-7,5  R-7,5    discrete       1
R65       2.2k           RESEU-7,5  R-7,5    discrete       1
R67       1k             RESEU-7,5  R-7,5    discrete       1
R68       10k            RESEU-7,5  R-7,5    discrete       1
R69       27k            RESEU-7,5  R-7,5    discrete       1
R70       10k            RESEU-7,5  R-7,5    discrete       1
RX-COIL                  M02        02P      con-amp-quick  1
SL3                      M03        03P      con-amp-quick  1
SL4                      M03        03P      con-amp-quick  1
SPEAKER                  M02        02P      con-amp-quick  1
TX-COIL                  M02        02P      con-amp-quick  1
