											;KIVEZÉRLÉSJELZŐ
	LIST P=PIC18F45K20, F=INHX32	
	#include <P18F45K20.INC>	
	ERRORLEVEL -230
	__CONFIG	_CONFIG1H,	B'00001000'		;BELSŐ OSZCILLÁTOR KIVÁLASZTVA,FAIL-SAFE CLOCK MONITOR TILTVA,IESO TILTVA
	__CONFIG	_CONFIG2L,	B'00000110'		;BOREN ENGEDÉLYEZVE,PWRTEN TILTVA,BORV 3V
 	__CONFIG	_CONFIG2H,	B'00000000'		;WDT TILTVA
 	__CONFIG	_CONFIG3H,	B'00000000'		;CCP2 RB3 LÁBON,PORTB A/D TILTVA,MCLR TILTVA
 	__CONFIG	_CONFIG4L,	B'10000001'		;STVR ENGEDÉLYEZVE,LVP TILTVA,KÜLSŐ DEBUGGER TILTVA,
 	__CONFIG	_CONFIG5L,	B'00001111'		;CODE PROTECT TILTVA
 	__CONFIG	_CONFIG5H,	B'11000000'		;CPB TILTVA,CPD TILTVA
 	__CONFIG	_CONFIG6L,	B'00001111'		;WRITE PROTECT TILTVA
 	__CONFIG	_CONFIG6H,	B'11100000'		;EEPROM WRITE,BOOT WRITE,CONF REG WRITE PROTECT TILTVA
 	__CONFIG	_CONFIG7L,  B'00001111'		;TABLE READ PROTECTION TILTVA
 	__CONFIG	_CONFIG7H,	B'01000000'		;BOOT READ PROTECT TILTVA
;***ID LOCATION DEFINE
    __IDLOCS _IDLOC0, 'K'
    __IDLOCS _IDLOC1, 'R'
    __IDLOCS _IDLOC2, 'I'
    __IDLOCS _IDLOC3, 'S'
    __IDLOCS _IDLOC4, 'S'
;............................................ VÁLTOZÓ DEKLARÁLÁS ..................................................
    CBLOCK	0X0020
	SZAML						;BITFORGATÁS VÁLTOZÓJA
	SZAMLTMP					;FORGATANDÓ BITEK SZÁMÁT TÁROLJA
	FULL						;BITSZÁMLÁLÓ VÁLTOZÓJA
	FULLTMP						;MAXLED BITSZÁMLÁLÓ VÁLTOZÓJA
	MAXLED						;MAXIMÁLIS SZINTET JELZŐ LED
	PORTATMP					;PORTA ÉRTÉKÉT TÁROLJA
	PORTBTMP					;PORTB ÉRTÉKÉT TÁROLJA
	PORTCTMP					;PORTC ÉRTÉKÉT TÁROLJA
	PORTDTMP					;PORTD ÉRTÉKÉT TÁROLJA
	PORTETMP					;PORTE ÉRTÉKÉT TÁROLJA
	DEL2TMP						;KÉSLELTETÉS IDEJÉT TÁROLJA
	DEL3TMP						;KÉSLELTETÉS IDEJÉT TÁROLJA
	DEL4TMP						;KÉSLELTETÉS IDEJÉT TÁROLJA
	DEL0						;KÉSLELTETÉS VÁLTOZÓJA
	DEL1						;KÉSLELTETÉS VÁLTOZÓJA
	DEL2						;KÉSLELTETÉS VÁLTOZÓJA		
	DEL3						;ZUHANÁS MEGKEZDÉSÉNEK KÉSLELTETÉSE
	DEL4						;ZUHANÁS SEBESSÉGE
	DEL5						;ZUHANÁS MEGKEZDÉSÉNEK KÉSLELTETÉSE
	DEL6						;STROBOSZKÓP VILLANÁSI IDEJE
	OSZTO						;A/D ÉRTÉKÉNEK OSZTÓJA
	UGR							;TÁBLA UGRÁS ÉRTÉKE
	SZINT						;LEDEK MAXIMÁLIS SZINTJE
	FLAG						;JELZŐBIT
	IRSZAML						;HA BETELIK EGY BÁJT UGRIK A KÖVETKEZŐRE
	TMR1ET						;TIMER1 LEFUTÁSÁNAK SZÁMA
	JELTMP						;IR JEL EGY BÁJTJA
	JELTMP1:4					;IR JEL
	JEL:4						;AZ ELLEŐRZÉS IDEJÉIG TÁROLT IRJEL 32 BITJE
	JELSTROB:4					;1.GOMBHOZ TARTOZÓ IR JEL
	JELKIV:4					;2.GOMBHOZ TARTOZÓ IR JEL
	ENDC
;................................................ RESET PONT ......................................................   
	ORG	0X0000
   	BRA		INI					;INICIALIZÁLÁSOK
    ORG	0X0008 		  			;HIGH PRIORITÁSÚ MEGSZAKÍTÁS
	BRA		HPM
    ORG	0X0018					;LOW PRIORITÁSÚ MEGSZAKÍTÁS
  	BRA		LPM
;............................................. INICIALIZÁLÁSOK ....................................................
INI
	MOVLW	B'10000000'			;PORTA,PORTE DIGITÁLIS I/O, RE2 ANALÓG
	MOVWF	ANSEL
	MOVLW	B'00000000'			;PORTB DIGITÁLIS I/O
	MOVWF	ANSELH
	MOVLW	B'00011101'			;A/D ENGEDÉLYEZVE
	MOVWF	ADCON0
	MOVLW	B'00000000'			;A/D VREF KONFIGURÁLÁSA
	MOVWF	ADCON1
	MOVLW	B'10000001'			;A/D RIGHT JUSTIFIED BEÁLLÍTVA
	MOVWF	ADCON2
	MOVLW	B'01010000'
	MOVWF	OSCCON				;BELSŐ OSC 8MHZ, NINCS FREKI HANGOLÁS   
	MOVLW	B'11100000'			
	MOVWF	INTCON				;GIE,PEIE,TMR0IE ENGEDÉLYEZVE
	MOVLW	B'00000001'
	MOVWF	IPR1				;TIMER1 HIGH PRIORITÁSÚ MEGSZAKÍTÁS KIVÁLASZTÁSA
	MOVLW	B'00000001'
	MOVWF	PIE1				;TIMER1,MEGSZAKÍTÁS ENGEDÉLYEZÁSE
	MOVLW	B'11000000'			;TIMER0 KONFIGURÁLÁSA
	MOVWF	T0CON
	MOVLW	B'00000001'
	MOVWF	T1CON				;TIMER1 BEKAPCSOLVA,8 BITES MÓD,ELŐOSZTÁS 1:1
    CLRF	PORTA
    CLRF	LATA
    CLRF	PORTB
    CLRF	LATB		
    CLRF	PORTC				;KI ÉS BEMENETI TÁROLÓK TÖRLÉSE
    CLRF	LATC
    CLRF	PORTD
    CLRF	LATD
	CLRF	PORTE
    CLRF	LATE
    MOVLW	B'00000000'         
    MOVWF	TRISA           
    MOVLW	B'00000000'
    MOVWF	TRISB
    MOVLW	B'00000000'        ;I/O PORTOK BEÁLLÍTÁSA
    MOVWF	TRISC
	MOVLW	B'00000000'        
    MOVWF	TRISD
 	MOVLW	B'00001100'        
    MOVWF	TRISE
;.................................................. ÉRTÉKADÁSOK ...................................................
	SETF	TMR1H				;TIMER1 KÉSLELTETÉS BEÁLLÍTÁSA BEJÖVŐ IR JELNÉL
	MOVLW	B'01001011'
	MOVWF	JELSTROB
	MOVLW	B'00101010'
	MOVWF	JELSTROB+1
	MOVLW	B'10110100'
	MOVWF	JELSTROB+2
	MOVLW	B'10111111'
	MOVWF	JELSTROB+3
	MOVLW	B'01010011'
	MOVWF	JELKIV
	MOVLW	B'00101011'
	MOVWF	JELKIV+1
	MOVLW	B'00101010'
	MOVWF	JELKIV+2
	MOVLW	B'10111111'
	MOVWF	JELKIV+3
	MOVLW	D'7'
	MOVWF	OSZTO
	MOVLW	D'5'				;ZUHANÁS MEGKEZDÉSÉNEK KÉSLELTETÉSE
	MOVWF	DEL3TMP
	MOVWF	DEL3
	MOVLW	D'80'				;ZUHANÁS SEBESSÉGE
	MOVWF	DEL4TMP
	MOVLW	D'25'
	MOVWF	DEL1
	MOVLW	D'15'
	MOVWF	DEL2TMP				;KÉSLELTETÉS LEFELÉ
	MOVWF	DEL2
	CLRF	ADRESL	
	CLRF	ADRESH				
	CLRF	FULL
	CLRF	UGR
	CLRF	SZINT
	CLRF	DEL0
	CLRF	DEL4	
	CLRF	DEL5
	CLRF	DEL6
	CLRF	SZAML
	CLRF	SZAMLTMP
	CLRF	FULLTMP
	CLRF	MAXLED
	CLRF	PORTATMP			;VÁLTOZÓK ALAPHELYZETBE ÁLLÍTVA
	CLRF	PORTBTMP
	CLRF	PORTCTMP
	CLRF	PORTDTMP
	CLRF	PORTETMP	
	CLRF	FLAG
	CLRF	IRSZAML
	CLRF	TMR1ET
	CLRF	JELTMP						
	CLRF	JELTMP1
	CLRF	JELTMP1+1
	CLRF	JELTMP1+2
	CLRF	JELTMP1+3				
	CLRF	JEL					
	CLRF	JEL+1
	CLRF	JEL+2	
	CLRF	JEL+3	
	BRA		PRG
;.......................................... HIGH PRIORITÁSÚ MEGSZAKÍTÁS ...........................................
HPM
	BTFSC	PIR1,TMR1IF
	GOTO	TIMER1				;TIMER2 MEGSZAKÍTÁS AZONOSÍTÁSA
	BCF		INTCON,TMR0IF
	BTFSS	FLAG,1
	BRA		F0
	DECFSZ	DEL5
	RETFIE
	DECFSZ	DEL3				;ZUHANÁS MEGKEZDÉSÉNEK KÉSLELTETÉSE
	RETFIE	FAST
	MOVFF	DEL3TMP,DEL3
	BCF		FLAG,1
F0
	DECFSZ	DEL4				;ZUHANÁS KÉSLELTETÉSE
	RETFIE	FAST
	MOVFF	DEL4TMP,DEL4
	MOVF	FULLTMP,W			;HA FULLTMP < = FULL AKKOR KILÉPÉS A SZUBRUTINBÓL
	CPFSLT	FULL
	RETFIE	FAST
	DECF	FULLTMP
	RRNCF	MAXLED
	MOVLW	D'32'
	CPFSGT	FULLTMP				;HA FULLTEMP > 32 AKKOR MAXLED KIÍRÓDIK PORTE-RE
	BRA		F1
	MOVFF	PORTETMP,PORTE
	MOVF	MAXLED,W
	IORWF	PORTE
	RETFIE	FAST
F1
	MOVLW	D'24'
	CPFSGT	FULLTMP				;HA FULLTEMP > 24 AKKOR MAXLED KIÍRÓDIK PORTD-RE
	BRA		F2
	CLRF	PORTE
	MOVFF	PORTDTMP,PORTD
	MOVF	MAXLED,W
	IORWF	PORTD
	RETFIE	FAST
F2
	MOVLW	D'16'
	CPFSGT	FULLTMP				;HA FULLTEMP > 16 AKKOR MAXLED KIÍRÓDIK PORTC-RE
	BRA		F3
	CLRF	PORTD
	MOVFF	PORTCTMP,PORTC
	MOVF	MAXLED,W
	IORWF	PORTC
	RETFIE	FAST
F3
	MOVLW	D'8'
	CPFSGT	FULLTMP				;HA FULLTEMP > 8 AKKOR MAXLED KIÍRÓDIK PORTB-RE
	BRA		F4
	CLRF	PORTC	
	MOVFF	PORTBTMP,PORTB
	MOVF	MAXLED,W
	IORWF	PORTB
	RETFIE	FAST
F4
	CLRF	PORTB
	MOVFF	PORTATMP,PORTA		;HA FULLTEMP NEM > 8 AKKOR MAXLED KIÍRÓDIK PORTA-RA
	MOVF	MAXLED,W
	IORWF	PORTA
	TSTFSZ	FULLTMP
	RETFIE	FAST
	CLRF	PORTA				;HA FULLTMP 0 AKKOR PORTA IS 0
	RETFIE	FAST
;............................................... IR JELFELISMERÉS .................................................
TIMER1
	BCF		PIR1,TMR1IF
	SETF	TMR1H
	BTFSC	FLAG,2
	BRA		IR0
	BTFSC	PORTE,3
	RETFIE	FAST
	MOVLW	D'33'				;TIMER1 MÁSODSZORI LEFUTÁSÁNAK KÉSLELTETÉSE
	MOVWF	TMR1ET
	BSF		FLAG,2
	RETFIE	FAST
IR0
	DCFSNZ	TMR1ET
	BRA		KI0		
	BTFSC	PORTE,3
	BSF		JELTMP,0			;TÁROLJA AZ IR JEL LOGIKAI SZINTJÉT
	BTFSS	PORTE,3
	BCF		JELTMP,0
	INCF	IRSZAML,F			;SZAML NÖVELÉSE
	MOVLW	D'8'
	CPFSEQ	IRSZAML,W			;HA BETELIK A JEL 8 BITJE UGRÁS A TÁROLÁSHOZ						 
	BRA		A0
	MOVFF	JELTMP,JELTMP1
A0
	MOVLW	D'16'
	BRA		A1
	MOVFF	JELTMP,JELTMP1+1
A1
	MOVLW	D'24'
	BRA		A2
	MOVFF	JELTMP,JELTMP1+2
A2
	MOVLW	D'32'
	BRA		A3
	MOVFF	JELTMP,JELTMP1+3
	BCF		FLAG,3				;IRJEL ELLENŐRZÉS TILTÁSA
	MOVFF	JELTMP1,JEL
	MOVFF	JELTMP1+1,JEL+1
	MOVFF	JELTMP1+2,JEL+2		;IR JEL MÁSOLÁSA ELLENŐRZÉSHEZ
	MOVFF	JELTMP1+3,JEL+3
	BCF		FLAG,2
	BSF		FLAG,3				;IRJEL ELLENŐRZÉS ENGEDÉLYEZÉSE	
	CLRF	TMR1ET
	BRA		KI0
A3
	RLNCF	JELTMP,F			;BALRA FORGATJA A JEL BITJEIT MIELŐTT BEÍRÁSRA KERÜL A KÖVETKEZŐ SZINT ÉRTÉKE
	MOVLW	D'252'
	MOVWF	TMR1H				;KÉSLELTETÉS BEÁLLÍTÁSA
	MOVLW	D'195'
	MOVWF	TMR1L
	RETFIE	FAST
KI0
	CLRF	IRSZAML	
	BTFSS	FLAG,3
	BCF		FLAG,2
	RETFIE	FAST
;.......................................... LOW PRIORITÁSÚ MEGSZAKÍTÁS ............................................
LPM
	RETFIE
;................................................... FŐPROGRAM ....................................................
PRG
	BTFSC	FLAG,3				;IR JEL ELLENŐRZÉSRE KÉSZ
	CALL	ELL0
	BSF		ADCON0,1
	BTFSC	ADCON0,1			;A/D MINTAVÉTELEZÉS INDÍTÁSA, VÁRÁS A BEFEJEZÉSIG
	BRA		$-2
	MOVFF	ADRESL,SZAMLTMP
	BTFSC	FLAG,4
	GOTO	STROBI
	MOVLW	B'00000000'
	CPFSGT	ADRESH
	BRA		IDE	
	MOVLW	D'48'
	ADDWF	UGR
	MOVLW	D'23'
	ADDWF	SZINT
	MOVLW	B'00000001'
	CPFSGT	ADRESH
	BRA		IDE	
	MOVLW	D'16'
	ADDWF	UGR
	MOVLW	D'7'
	ADDWF	SZINT
	MOVLW	B'00000010'
	CPFSGT	ADRESH
	BRA		IDE	
	MOVLW	D'6'
	ADDWF	UGR
	MOVLW	D'2'
	ADDWF	SZINT
IDE
	MOVLW	D'255'
	CPFSEQ	SZAMLTMP
	BRA		ERTEK
	DECF	SZAMLTMP
;............................................... SZINTEK MEGADÁSA .................................................
ERTEK
	MOVLW	HIGH	TABLA		;UGRÓTÁBLA LÉTREHOZÁSA
	MOVWF	PCLATH
	INCF	UGR,F
	INCF	UGR,F
	MOVLW	LOW		TABLA
	ADDWF	UGR,W
	BTFSC	STATUS,C
	INCF	PCLATH,F	
	CALL	TABLA
	CPFSLT	SZAMLTMP
	INCF	SZINT
	CPFSLT	SZAMLTMP
	BRA		ERTEK
	MOVFF	SZINT,SZAMLTMP
	CLRF	SZINT
	CLRF	UGR
	BRA		TESZT	
TABLA
	MOVWF	PCL
;00
	RETLW D'2'
	RETLW D'9'
	RETLW D'16'
	RETLW D'23'
	RETLW D'31'
	RETLW D'39'
	RETLW D'47'
	RETLW D'55'
	RETLW D'64'
	RETLW D'73'
	RETLW D'82'
	RETLW D'92'
	RETLW D'103'
	RETLW D'114'
	RETLW D'125'
	RETLW D'137'
	RETLW D'150'
	RETLW D'163'
	RETLW D'178'
	RETLW D'193'
	RETLW D'209'
	RETLW D'227'
	RETLW D'245'
	RETLW D'255'	;23
;01
	RETLW D'13'
	RETLW D'36'
	RETLW D'62'
	RETLW D'92'
	RETLW D'126'
	RETLW D'167'
	RETLW D'225'
	RETLW D'255'	;30
;10
	RETLW D'25'
	RETLW D'200'
	RETLW D'255'	;32
;11
	RETLW D'2'
	RETLW D'70'
	RETLW D'255'	;34
;............................................ BEMENETI FESZÜLTSÉG KIÉRTÉKELÉSE ....................................
TESZT
	MOVF	SZAML,W
	CPFSEQ	SZAMLTMP			;HA SZAML ÉS SZAMLTMP EGYENLŐEK UGRÁS PRG
	BRA		NAGYOBB
	BRA		PRG
NAGYOBB
	MOVF	SZAML,W
	CPFSGT	SZAMLTMP			;HA SZAMLTMP NAGYOBB KIVON
	BRA		LEDKI
	BRA		KIVON
KIVON
	MOVF	SZAML,W	
	SUBWF	SZAMLTMP,W			;SZAMLTEMP-SZAML=SZAML
	MOVWF	SZAML
	MOVLW	D'32'
	CPFSLT	FULL				;HA PORTD TELE UGRÁS PORTE
	BRA		PRTE
	MOVLW	D'24'
	CPFSLT	FULL				;HA PORTC TELE UGRÁS PORTD
	BRA		PRTD
	MOVLW	D'16'
	CPFSLT	FULL				;HA PORTB TELE UGRÁS PORTC
	BRA		PRTC	
	MOVLW	D'8'
	CPFSLT	FULL				;HA PORTA TELE UGRÁS PORTB
	BRA		PRTB
;................................................... LEDEK BEKAPCSOLÁSA .............................................
PRTA
	MOVLW	D'8'
	CPFSLT	FULL				;HA FULL=8 PORTA TELE UGRÁS PORTB
	BRA		PRTB
	INCF	FULL,F				;FULL+1
	BSF		STATUS,C
	RLCF	PORTATMP,F			;+1 LED KIGYULLAD
	MOVF	PORTATMP,W
	IORWF	PORTA
	MOVF	FULL,W
	CPFSEQ	FULLTMP
	CALL	DELAY				;KÉSLELTETÉS
	DECFSZ	SZAML,F				;SZAML-1 HA 0 UGRÁS PRG
	BRA		PRTA
	MOVFF	SZAMLTMP,SZAML		;SZAMLTMP=SZAML
	BRA		PRG
PRTB
	MOVLW	D'16'
	CPFSLT	FULL				;HA FULL=16 PORTB TELE UGRÁS PORTC
	BRA		PRTC
	INCF	FULL,F				;FULL+1
	BSF		STATUS,C
	RLCF	PORTBTMP,F			;+1 LED KIGYULLAD
	MOVF	PORTBTMP,W
	IORWF	PORTB
	MOVF	FULL,W
	CPFSEQ	FULLTMP
	BRA		PRTB
	BRA		PRG
PRTC
	MOVLW	D'24'
	CPFSLT	FULL				;HA FULL=16 PORTC TELE UGRÁS PORTD
	BRA		PRTD
	INCF	FULL,F				;FULL+1
	BSF		STATUS,C
	RLCF	PORTCTMP,F			;+1 LED KIGYULLAD
	MOVF	PORTCTMP,W
	IORWF	PORTC
	MOVF	FULL,W
	CPFSEQ	FULLTMP
	BRA		PRTC
	BRA		PRG
PRTD
	MOVLW	D'32'
	CPFSLT	FULL				;HA FULL=32 PORTD TELE UGRÁS PORTE
	BRA		PRTE
	INCF	FULL,F				;FULL+1
	BSF		STATUS,C
	RLCF	PORTDTMP,F			;+1 LED KIGYULLAD
	MOVF	PORTDTMP,W
	IORWF	PORTD
	MOVF	FULL,W
	CPFSEQ	FULLTMP
	BRA		PRTD
	BRA		PRG
PRTE
	MOVLW	D'34'
	CPFSLT	FULL				;HA FULL=40 PORTD TELE UGRÁS LEDKI
	MOVWF	SZAML
	BRA		PRG
	INCF	FULL,F				;FULL+1
	BSF		STATUS,C
	RLCF	PORTETMP,F			;+1 LED KIGYULLAD
	MOVF	PORTETMP,W
	IORWF	PORTE
	BRA		PRTD
	BRA		PRG
;................................................... LEDEK KIKAPCSOLÁSA .............................................
LEDKI
	DECFSZ	DEL1
	BRA		PRG
	MOVLW	D'25'
	MOVWF	DEL1
	DECFSZ	DEL2				;KÉSLELTETÉS LEFELÉ
	BRA		PRG
	MOVFF	DEL2TMP,DEL2
	BCF		STATUS,C			;CARRY TÖRLÉSE
	MOVLW	D'8'
	CPFSGT	FULL				;HA FULL < = 8 +1 LED ELALSZIK PORTA-N
	CALL	LEDSTOPA
	MOVLW	D'8'
	CPFSGT	FULL				;HA FULL > 8 UGRIK	
	BRA		L1
	MOVLW	D'16'
	CPFSGT	FULL				;HA FULL > 8 ÉS < = 16 AKKOR +1 LED ELALSZIK PORTB-N
	CALL	LEDSTOPB
	MOVLW	D'16'
	CPFSGT	FULL				;HA FULL > 16 UGRIK
	BRA		L1
	MOVLW	D'24'
	CPFSGT	FULL				;HA FULL > 16 ÉS < = 24 AKKOR +1 LED ELALSZIK PORTC-N		
	CALL	LEDSTOPC
	MOVLW	D'24'
	CPFSGT	FULL				;HA FULL > 24 UGRIK	
	BRA		L1
	MOVLW	D'32'
	CPFSGT	FULL				;HA FULL > 24 ÉS < = 32 AKKOR +1 LED ELALSZIK PORTD-N	
	CALL	LEDSTOPD
	MOVLW	D'32'
	CPFSGT	FULL				;HA FULL > 32 UGRIK	
	BRA		L1
	MOVLW	D'34'
	CPFSGT	FULL				;HA FULL > 32 ÉS < = 34 AKKOR +1 LED ELALSZIK PORTE-N			
	CALL	LEDSTOPE
L1
	DECF	FULL,F				;FULL-1
	DECF	SZAML,F				;SZAML-1
	BRA		PRG
;.............................................. ZUHANÓ LED KEZDŐ POZÍCIÓJA ..........................................
LEDSTOPA
	MOVF	FULL,W
	CPFSGT	FULLTMP				;HA ALACSONYABB SZINT JÖN UGRÁS ALEDKI
	BCF		FLAG,0
	BTFSC	FLAG,0				;HA MAGASABB SZINT JÖN MAXLED BEKAPCSOLÁSA
	BRA		ALEDKI
	MOVFF	PORTATMP,MAXLED
	BCF		STATUS,C							
	RRCF	PORTATMP,W			;MAXIMÁLIS SZINTET JELZŐ LED MEGHATÁROZÁSA
	XORWF	MAXLED,F
	BSF		FLAG,0				;MAXIMÁLIS SZINTET JELZŐ LED DETEKTÁLVA
	BSF		FLAG,1				;ZUHANÓ LED VÁRAKOZTATÁSA
	MOVFF	FULL,FULLTMP
ALEDKI
	BCF		STATUS,C
	RRCF	PORTATMP,F			;+1 LED ELALSZIK PORTA-N
	MOVF	MAXLED,W
	BTFSC	PORTE,0
	RETURN
	BTFSC	PORTE,1
	RETURN
	TSTFSZ	PORTD
	RETURN
	TSTFSZ	PORTC				;ZUHANÓ LED ENGEDÉLYEZÉSE CSAK AKKOR HA AZ ELŐZŐ PORTOK MÁR ÜRESEK
	RETURN
	TSTFSZ	PORTB
	RETURN
	IORWF	PORTA,F
	RETURN
LEDSTOPB
	MOVF	FULL,W
	CPFSGT	FULLTMP				;HA ALACSONYABB SZINT JÖN UGRÁS BLEDKI
	BCF		FLAG,0
	BRA		BLEDKI
	MOVFF	PORTBTMP,MAXLED
	BCF		STATUS,C							
	RRCF	PORTBTMP,W			;MAXIMÁLIS SZINTET JELZŐ LED MEGHATÁROZÁSA
	XORWF	MAXLED,F
	MOVFF	FULL,FULLTMP
BLEDKI
	BCF		STATUS,C
	RRCF	PORTBTMP,F			;+1 LED ELALSZIK PORTB-N
	MOVF	MAXLED,W
	BTFSC	PORTE,0
	RETURN
	BTFSC	PORTE,1
	RETURN
	TSTFSZ	PORTD
	RETURN
	RETURN
	IORWF	PORTB,F
	RETURN
LEDSTOPC
	MOVF	FULL,W
	CPFSGT	FULLTMP				;HA ALACSONYABB SZINT JÖN UGRÁS CLEDKI
	BCF		FLAG,0
	BRA		CLEDKI
	MOVFF	PORTCTMP,MAXLED
	BCF		STATUS,C							
	RRCF	PORTCTMP,W			;MAXIMÁLIS SZINTET JELZŐ LED MEGHATÁROZÁSA
	XORWF	MAXLED,F
	MOVFF	FULL,FULLTMP
CLEDKI
	BCF		STATUS,C
	RRCF	PORTCTMP,F			;+1 LED ELALSZIK PORTC-N
	MOVF	MAXLED,W
	BTFSC	PORTE,0
	RETURN
	BTFSC	PORTE,1
	RETURN
	TSTFSZ	PORTD				;ZUHANÓ LED ENGEDÉLYEZÉSE CSAK AKKOR HA AZ ELŐZŐ PORTOK MÁR ÜRESEK
	RETURN
	IORWF	PORTC,F
	RETURN
LEDSTOPD
	MOVF	FULL,W
	CPFSGT	FULLTMP				;HA ALACSONYABB SZINT JÖN UGRÁS DLEDKI
	BCF		FLAG,0
	BRA		DLEDKI
	MOVFF	PORTDTMP,MAXLED
	BCF		STATUS,C							
	RRCF	PORTDTMP,W			;MAXIMÁLIS SZINTET JELZŐ LED MEGHATÁROZÁSA
	XORWF	MAXLED,F
	MOVFF	FULL,FULLTMP
DLEDKI
	BCF		STATUS,C
	RRCF	PORTDTMP,F			;+1 LED ELALSZIK PORTD-N
	MOVF	MAXLED,W
	BTFSC	PORTE,0
	RETURN
	BTFSC	PORTE,1				;ZUHANÓ LED ENGEDÉLYEZÉSE CSAK AKKOR HA AZ ELŐZŐ PORT MÁR ÜRES
	RETURN
	IORWF	PORTD,F
	RETURN
LEDSTOPE
	MOVF	FULL,W
	CPFSGT	FULLTMP				;HA ALACSONYABB SZINT JÖN UGRÁS ELEDKI
	BCF		FLAG,0
	BRA		ELEDKI
	MOVFF	PORTETMP,MAXLED
	BCF		STATUS,C							
	RRCF	PORTETMP,W			;MAXIMÁLIS SZINTET JELZŐ LED MEGHATÁROZÁSA
	XORWF	MAXLED,F
	MOVFF	FULL,FULLTMP
ELEDKI
	BCF		STATUS,C
	RRCF	PORTETMP,F			;+1 LED ELALSZIK PORTE-N
	MOVF	MAXLED,W
	IORWF	PORTE,F
	RETURN
;....................................................... ZUHANÓ LED .................................................
DELAY
	DECFSZ	DEL0
	BRA		DELAY
	RETURN
;........................................................ STROBOSZKÓP ...............................................
STROBI
	MOVLW	D'0'
	CPFSGT	ADRESH
	GOTO	PRG	
	SETF	PORTA
	SETF	PORTB
	SETF	PORTC
	SETF	PORTD
	SETF	PORTE
	MOVLW	D'30'
	MOVWF	DEL6
	CALL	DELAY1
	CLRF	PORTA
	CLRF	PORTB
	CLRF	PORTC
	CLRF	PORTD
	CLRF	PORTE
	MOVLW	D'50'
	MOVWF	DEL6
	CALL	DELAY1
	GOTO	PRG
DELAY1
	DECFSZ	DEL0
	BRA		DELAY1
	DECFSZ	DEL6
	BRA		DELAY1
	RETURN
;............................................... IR JELELLENŐRZÉS .................................................
ELL0
	MOVF	JEL,W
	CPFSEQ	JELSTROB
	BRA		E1
	BRA		E2
E1
	BTG		WREG,3
	BTG		WREG,4				;IRJEL 3.ÉS 4.BITJÉNEK KOMPLEMENTÁLÁSA HOGY A GOMB MINDEN MÁSODIK MEGNYOMÁSA IS FELISMERÉSRE KERÜLJÖN
	CPFSEQ	JELSTROB
	BRA		ELL1
E2
	MOVF	JEL+1,W
	CPFSEQ	JELSTROB+1
	BRA		ELL1			
	MOVF	JEL+2,W
	CPFSEQ	JELSTROB+2			;MAX.GOMBHOZ TARTOZÓ IRJEL ELLENŐRZÉSE
	BRA		ELL1
	MOVF	JEL+3,W
	CPFSEQ	JELSTROB+3
	BRA		ELL1
	BSF		FLAG,4				;STROBOSZKÓP ÜZEMMÓD
	CLRF	PORTA
	CLRF	PORTB
	CLRF	PORTC
	CLRF	PORTD				;KIMENETEK NULLÁZÁSA
	CLRF	PORTE
	CLRF	FULLTMP				;ZUHANÓ LED TILTVA
ELL1
	MOVF	JEL,W
	CPFSEQ	JELKIV
	BRA		E3
	BRA		E4
E3
	BTG		WREG,3
	CPFSEQ	JELKIV
	BRA		ELL2
E4
	MOVF	JEL+1,W
	CPFSEQ	JELKIV+1
	BRA		ELL2			
	MOVF	JEL+2,W
	CPFSEQ	JELKIV+2			;MAX.GOMBHOZ TARTOZÓ IRJEL ELLENŐRZÉSE
	BRA		ELL2
	MOVF	JEL+3,W
	CPFSEQ	JELKIV+3
	BRA		ELL2
	BCF		FLAG,4				;KIVEZÉRLÉSJELZŐ ÜZEMMÓD
	MOVFF	PORTCTMP,PORTC		;ÉRTÉKEK VISSZAÁLLÍTÁSA A KIMENETEKRE
ELL2
	BCF		FLAG,3				;IR JEL ELLENŐRIZVE
	RETURN
	END
