;//frecventmetru PC.
;//Serban Ioan, 2005. serbanioan@yahoo.com
	include "P16F628.inc"
; Heap block 0, size:80
__HEAP_BLOCK0_BANK               EQU	0x00000001
__HEAP_BLOCK0_START_OFFSET       EQU	0x00000020
__HEAP_BLOCK0_END_OFFSET         EQU	0x0000006F
; Heap block 1, size:30
__HEAP_BLOCK1_BANK               EQU	0x00000000
__HEAP_BLOCK1_START_OFFSET       EQU	0x00000052
__HEAP_BLOCK1_END_OFFSET         EQU	0x0000006F
; Heap block 2, size:15
__HEAP_BLOCK2_BANK               EQU	0x00000000
__HEAP_BLOCK2_START_OFFSET       EQU	0x00000071
__HEAP_BLOCK2_END_OFFSET         EQU	0x0000007F
; Heap block 3, size:0
__HEAP_BLOCK3_BANK               EQU	0x00000000
__HEAP_BLOCK3_START_OFFSET       EQU	0x00000000
__HEAP_BLOCK3_END_OFFSET         EQU	0x00000000
gbl_status                       EQU	0x00000003 ; bytes:1
gbl_indf                         EQU	0x00000000 ; bytes:1
gbl_tmr0                         EQU	0x00000001 ; bytes:1
gbl_pcl                          EQU	0x00000002 ; bytes:1
gbl_fsr                          EQU	0x00000004 ; bytes:1
gbl_porta                        EQU	0x00000005 ; bytes:1
gbl_portb                        EQU	0x00000006 ; bytes:1
gbl_pclath                       EQU	0x0000000A ; bytes:1
gbl_intcon                       EQU	0x0000000B ; bytes:1
gbl_pir1                         EQU	0x0000000C ; bytes:1
gbl_tmr1l                        EQU	0x0000000E ; bytes:1
gbl_tmr1h                        EQU	0x0000000F ; bytes:1
gbl_t1con                        EQU	0x00000010 ; bytes:1
gbl_tmr2                         EQU	0x00000011 ; bytes:1
gbl_t2con                        EQU	0x00000012 ; bytes:1
gbl_ccpr1l                       EQU	0x00000015 ; bytes:1
gbl_ccpr1h                       EQU	0x00000016 ; bytes:1
gbl_ccp1con                      EQU	0x00000017 ; bytes:1
gbl_rcsta                        EQU	0x00000018 ; bytes:1
gbl_txreg                        EQU	0x00000019 ; bytes:1
gbl_rcreg                        EQU	0x0000001A ; bytes:1
gbl_cmcon                        EQU	0x0000001F ; bytes:1
gbl_option_reg                   EQU	0x00000081 ; bytes:1
gbl_trisa                        EQU	0x00000085 ; bytes:1
gbl_trisb                        EQU	0x00000086 ; bytes:1
gbl_pie1                         EQU	0x0000008C ; bytes:1
gbl_pcon                         EQU	0x0000008E ; bytes:1
gbl_pr2                          EQU	0x00000092 ; bytes:1
gbl_txsta                        EQU	0x00000098 ; bytes:1
gbl_spbrg                        EQU	0x00000099 ; bytes:1
gbl_eedata                       EQU	0x0000009A ; bytes:1
gbl_eeadr                        EQU	0x0000009B ; bytes:1
gbl_eecon1                       EQU	0x0000009C ; bytes:1
gbl_eecon2                       EQU	0x0000009D ; bytes:1
gbl_vrcon                        EQU	0x0000009F ; bytes:1
gbl_eroareReceptie               EQU	0x00000020 ; bytes:1
gbl_ctrlReceptie                 EQU	0x00000021 ; bytes:1
gbl_ctrlTransmisie               EQU	0x00000022 ; bytes:1
gbl_startStopFrecv               EQU	0x00000023 ; bytes:1
gbl_transmisieQueue              EQU	0x00000024 ; bytes:1
gbl_startStopGenSemnal           EQU	0x00000025 ; bytes:1
gbl_contorCerereID               EQU	0x00000026 ; bytes:1
gbl_receptie                     EQU	0x00000027 ; bytes:5
gbl_receptieTemp                 EQU	0x0000002C ; bytes:5
gbl_transmisie                   EQU	0x00000031 ; bytes:8
gbl_pointerReceptie              EQU	0x00000039 ; bytes:1
gbl_pointerTransmisie            EQU	0x0000003A ; bytes:1
gbl_vartemp1                     EQU	0x0000003B ; bytes:1
gbl_timeBaseL                    EQU	0x0000003C ; bytes:1
gbl_timeBaseH                    EQU	0x0000003D ; bytes:1
gbl_adresaTransmisie             EQU	0x0000003E ; bytes:1
gbl_dataTransmisie               EQU	0x0000003F ; bytes:1
gbl_genPWMPr2                    EQU	0x00000040 ; bytes:1
gbl_genPWMPresc                  EQU	0x00000041 ; bytes:1
gbl_genPWMLsb                    EQU	0x00000042 ; bytes:1
gbl_genPWMdutyCycle              EQU	0x00000043 ; bytes:1
gbl_tmr1a                        EQU	0x00000044 ; bytes:2
gbl_tmr1b                        EQU	0x00000046 ; bytes:2
gbl_tmr1c                        EQU	0x00000048 ; bytes:2
gbl_timeBase                     EQU	0x0000004A ; bytes:2
gbl_tmr2b                        EQU	0x0000004C ; bytes:2
receptieSe_00013_1_recTemp       EQU	0x00000051 ; bytes:1
Int1Context                      EQU	0x00000070 ; bytes:1
Int1BContext                     EQU	0x0000004E ; bytes:3
	ORG 0x00000000
	GOTO	_startup
	ORG 0x00000004
	MOVWF Int1Context
	SWAPF STATUS, W
	BCF STATUS, RP0
	BCF STATUS, RP1
	MOVWF Int1BContext
	SWAPF PCLATH, W
	MOVWF Int1BContext+D'1'
	SWAPF FSR, W
	MOVWF Int1BContext+D'2'
	BCF PCLATH,3
	BCF PCLATH,4
	GOTO	interrupt
	ORG 0x00000010
timeBaseTm_00015
; { timeBaseTmr2 ; function begin
	BCF STATUS, RP0
	BCF STATUS, RP1
	MOVF gbl_startStopFrecv, F
	BTFSC STATUS,Z
	GOTO	label268436601
	MOVF gbl_timeBase, F
	BTFSS STATUS,Z
	GOTO	label268436639
	MOVF gbl_timeBase+D'1', F
	BTFSS STATUS,Z
	GOTO	label268436639
	BCF gbl_t1con,0
	BCF gbl_t2con,2
	MOVF gbl_tmr1a, W
	MOVWF gbl_tmr1b
	MOVF gbl_tmr1a+D'1', W
	MOVWF gbl_tmr1b+D'1'
	MOVF gbl_tmr1l, W
	MOVWF gbl_tmr1c
	MOVF gbl_tmr1h, W
	MOVWF gbl_tmr1c+D'1'
	CLRF gbl_tmr1a
	CLRF gbl_tmr1a+D'1'
	CLRF gbl_tmr1l
	CLRF gbl_tmr1h
	MOVF gbl_tmr2, W
	MOVWF gbl_tmr2b
	CLRF gbl_tmr2b+D'1'
	CLRF gbl_tmr2
	MOVF gbl_timeBaseL, W
	MOVWF gbl_timeBase
	MOVF gbl_timeBaseH, W
	MOVWF gbl_timeBase+D'1'
	BSF gbl_t2con,2
	BSF gbl_t1con,0
	MOVF gbl_startStopGenSemnal, F
	BTFSC STATUS,Z
	BSF gbl_portb,3
	BSF gbl_transmisieQueue,0
	XORLW 0xF4
	BTFSC STATUS,Z
	GOTO	label268436630
	XORLW 0x88
	BTFSC STATUS,Z
	GOTO	label268436632
	XORLW 0x50
	BTFSC STATUS,Z
	GOTO	label268436634
	GOTO	label268436635
label268436630
	INCF gbl_contorCerereID, F
	GOTO	label268436635
label268436632
	MOVLW 0x0A
	ADDWF gbl_contorCerereID, F
	GOTO	label268436635
label268436634
	MOVLW 0x1E
label268436635
	MOVLW 0x32
	SUBWF gbl_contorCerereID, W
	BTFSS STATUS,C
	GOTO	label268436639
	BCF gbl_portb,3
	CLRF gbl_startStopFrecv
	BCF gbl_t2con,2
label268436639
	BTFSC STATUS,Z
	DECF gbl_timeBase+D'1', F
	DECF gbl_timeBase, F
label268436601
	BCF gbl_pir1,1
	RETURN
; } timeBaseTmr2 function end
	ORG 0x00000058
tmr1_00000
; { tmr1 ; function begin
	BCF STATUS, RP0
	BCF STATUS, RP1
	INCF gbl_tmr1a, F
	BTFSC STATUS,Z
	INCF gbl_tmr1a+D'1', F
	BCF gbl_pir1,0
	RETURN
; } tmr1 function end
	ORG 0x0000005F
transmisie_00014
; { transmisieSeriala ; function begin
label268436578
	MOVLW 0x01
	BCF STATUS, RP0
	BCF STATUS, RP1
	MOVWF gbl_ctrlTransmisie
	BCF	STATUS,IRP
	MOVLW LOW(gbl_transmisie+D'0')
	MOVWF FSR
	MOVF gbl_pointerTransmisie, W
	ADDWF FSR, F
	MOVF INDF, W
	MOVWF gbl_txreg
	INCF gbl_pointerTransmisie, F
	XORLW 0x07
	BTFSS STATUS,Z
	GOTO	label268436583
	CLRF gbl_pointerTransmisie
	BTFSC STATUS,Z
	BCF gbl_portb,3
	CLRF gbl_ctrlTransmisie
	BSF STATUS, RP0
	BCF gbl_pie1,4
	GOTO	label268436593
label268436583
	BTFSC gbl_pir1,4
	GOTO	label268436578
label268436593
	RETURN
; } transmisieSeriala function end
	ORG 0x0000007A
receptieSe_00013
; { receptieSeriala ; function begin
	BCF STATUS, RP0
	BCF STATUS, RP1
	BCF gbl_status,5
	BTFSC gbl_rcsta,1
	GOTO	label268436535
	BTFSC gbl_rcsta,2
	GOTO	label268436536
	GOTO	label268436537
label268436535
	BCF gbl_rcsta,4
	MOVF gbl_rcreg, W
	MOVF gbl_rcreg, W
	MOVF gbl_rcreg, W
	BSF gbl_rcsta,4
	RETURN
label268436536
	MOVF gbl_rcreg, W
	RETURN
label268436537
	MOVF gbl_rcreg, W
	MOVWF receptieSe_00013_1_recTemp
	MOVF gbl_pointerReceptie, F
	BTFSS STATUS,Z
	GOTO	label268436540
	MOVF receptieSe_00013_1_recTemp, W
	XORLW 0x0A
	BTFSS STATUS,Z
	GOTO	label268436540
	MOVLW 0x01
	MOVWF gbl_pointerReceptie
	MOVWF gbl_receptieTemp
	MOVLW 0x01
	MOVWF gbl_ctrlReceptie
	GOTO	label268436549
label268436540
	BTFSC STATUS,Z
	GOTO	label268436549
	BCF	STATUS,IRP
	MOVLW LOW(gbl_receptieTemp+D'0')
	MOVWF FSR
	MOVF gbl_pointerReceptie, W
	ADDWF FSR, F
	MOVWF INDF
	INCF gbl_pointerReceptie, F
label268436549
	XORLW 0x04
	BTFSS STATUS,Z
	GOTO	label268436555
	CLRF gbl_pointerReceptie
	CLRF gbl_ctrlReceptie
	MOVF gbl_receptieTemp, W
	MOVWF gbl_receptie
	MOVF gbl_receptieTemp+D'1', W
	MOVWF gbl_receptie+D'1'
	MOVF gbl_receptieTemp+D'2', W
	MOVWF gbl_receptie+D'2'
	MOVF gbl_receptieTemp+D'3', W
	MOVWF gbl_receptie+D'3'
	MOVF gbl_receptieTemp+D'4', W
	MOVWF gbl_receptie+D'4'
label268436555
	BTFSC gbl_pir1,5
	GOTO	label268436537
	RETURN
; } receptieSeriala function end
	ORG 0x000000B8
main
; { main ; function begin
	MOVLW 0x20
	BCF STATUS, RP0
	BCF STATUS, RP1
	MOVWF gbl_fsr
label268436649
	MOVLW 0x6E
	SUBWF gbl_fsr, W
	BTFSC STATUS,C
	GOTO	label268436650
	CLRF gbl_indf
	INCF gbl_fsr, F
	GOTO	label268436649
label268436650
	MOVLW 0xA0
	MOVWF gbl_fsr
label268436654
	MOVLW 0xEE
	SUBWF gbl_fsr, W
	BTFSC STATUS,C
	GOTO	label268436655
	CLRF gbl_indf
	INCF gbl_fsr, F
	GOTO	label268436654
label268436655
	CLRF gbl_eroareReceptie
	CLRF gbl_receptie
	MOVLW 0x0A
	MOVWF gbl_transmisie
	MOVLW 0x01
	CLRF gbl_tmr1a
	CLRF gbl_tmr1a+D'1'
	CLRF gbl_tmr1b
	CLRF gbl_tmr1b+D'1'
	CLRF gbl_contorCerereID
	CLRF gbl_status
	BCF gbl_intcon,7
	MOVLW 0xFF
	BSF STATUS, RP0
	MOVWF gbl_trisa
	MOVLW 0xD3
	MOVWF gbl_trisb
	CLRF gbl_option_reg
	MOVLW 0x43
	BCF STATUS, RP0
	MOVWF gbl_intcon
	MOVLW 0x23
	BSF STATUS, RP0
	MOVWF gbl_pie1
	CLRF gbl_pcon
	CLRF gbl_vrcon
	BCF STATUS, RP0
	CLRF gbl_porta
	CLRF gbl_portb
	MOVLW 0x07
	MOVWF gbl_cmcon
	MOVLW 0xF9
	BSF STATUS, RP0
	MOVWF gbl_pr2
	MOVLW 0x06
	BCF STATUS, RP0
	MOVWF gbl_t1con
	MOVLW 0x01
	MOVWF gbl_t2con
	CLRF gbl_ccp1con
	CLRF gbl_pir1
	MOVLW 0x40
	BSF STATUS, RP0
	MOVWF gbl_spbrg
	MOVLW 0x24
	MOVWF gbl_txsta
	MOVLW 0x90
	BCF STATUS, RP0
	MOVWF gbl_rcsta
	MOVF gbl_rcreg, W
	MOVF gbl_rcreg, W
	MOVF gbl_rcreg, W
	BCF gbl_rcsta,4
	BSF gbl_rcsta,4
	BSF gbl_intcon,7
	MOVLW 0x88
	MOVWF gbl_timeBaseL
	MOVLW 0x13
	MOVWF gbl_timeBaseH
label268436698
	NOP
	BCF STATUS, RP0
	MOVF gbl_ctrlReceptie, F
	BTFSS STATUS,Z
	GOTO	label268436805
	MOVLW 0x01
	MOVF gbl_receptie+D'1', F
	BTFSC STATUS,Z
	GOTO	label268436710
	MOVF gbl_receptie+D'2', W
	XORLW 0x01
	BTFSC STATUS,Z
	GOTO	label268436713
	XORLW 0x02
	BTFSC STATUS,Z
	GOTO	label268436715
	XORLW 0x03
	BTFSC STATUS,Z
	GOTO	label268436717
	XORLW 0x04
	BTFSC STATUS,Z
	GOTO	label268436719
	XORLW 0x05
	BTFSC STATUS,Z
	GOTO	label268436721
	XORLW 0x06
	BTFSC STATUS,Z
	GOTO	label268436723
	XORLW 0x07
	BTFSC STATUS,Z
	GOTO	label268436725
	XORLW 0x08
	BTFSC STATUS,Z
	GOTO	label268436727
	XORLW 0x09
	BTFSC STATUS,Z
	GOTO	label268436729
	GOTO	label268436730
label268436713
	MOVF gbl_receptie+D'3', W
	MOVWF gbl_startStopFrecv
	BTFSS STATUS,Z
	GOTO	label268436733
	BCF gbl_t1con,0
	BCF gbl_t2con,2
	BSF STATUS, RP0
	BCF gbl_pie1,1
	BCF STATUS, RP0
	BCF gbl_pir1,1
	GOTO	label268436740
label268436733
	CLRF gbl_startStopGenSemnal
	CLRF gbl_ccp1con
	CLRF gbl_tmr1a
	CLRF gbl_tmr1a+D'1'
	CLRF gbl_tmr1l
	CLRF gbl_tmr1h
	CLRF gbl_tmr2
	MOVWF gbl_timeBase
	MOVLW 0xF9
	BSF STATUS, RP0
	MOVWF gbl_pr2
	MOVLW 0x01
	BCF STATUS, RP0
	MOVWF gbl_t2con
	BSF gbl_t2con,2
	BSF gbl_t1con,0
	BSF STATUS, RP0
	BSF gbl_pie1,1
	BCF STATUS, RP0
	BCF gbl_pir1,1
label268436740
	GOTO	label268436730
label268436715
	MOVWF gbl_timeBaseL
	GOTO	label268436730
label268436717
	MOVWF gbl_timeBaseH
	MOVWF gbl_timeBase
	GOTO	label268436730
label268436719
	MOVWF gbl_startStopGenSemnal
	BSF STATUS, RP0
	BCF gbl_pie1,1
	BCF STATUS, RP0
	BCF gbl_t1con,0
	BTFSS STATUS,Z
	GOTO	label268436774
	BCF gbl_t2con,2
	CLRF gbl_ccp1con
	BCF gbl_portb,3
	GOTO	label268436780
label268436774
	BCF gbl_t2con,2
	MOVF gbl_genPWMPr2, W
	BSF STATUS, RP0
	MOVWF gbl_pr2
	BCF STATUS, RP0
	MOVF gbl_genPWMPresc, W
	MOVWF gbl_t2con
	MOVF gbl_genPWMLsb, W
	MOVWF gbl_ccp1con
	MOVF gbl_genPWMdutyCycle, W
	MOVWF gbl_ccpr1l
	BSF gbl_t2con,2
label268436780
	GOTO	label268436730
label268436721
	NOP
	GOTO	label268436730
label268436723
	MOVWF gbl_genPWMPr2
	BSF STATUS, RP0
	MOVWF gbl_pr2
	GOTO	label268436730
label268436725
	MOVWF gbl_genPWMLsb
	MOVWF gbl_ccp1con
	GOTO	label268436730
label268436727
	MOVWF gbl_genPWMPresc
	MOVWF gbl_t2con
	GOTO	label268436730
label268436729
	MOVWF gbl_genPWMdutyCycle
	MOVWF gbl_ccpr1l
label268436730
	GOTO	label268436805
label268436710
	MOVF gbl_receptie+D'2', F
	BTFSC STATUS,Z
	GOTO	label268436809
	XORLW 0x01
	BTFSC STATUS,Z
	GOTO	label268436811
	XORLW 0x03
	BTFSC STATUS,Z
	GOTO	label268436813
	GOTO	label268436814
label268436809
	MOVWF gbl_adresaTransmisie
	MOVLW 0xB7
	MOVWF gbl_dataTransmisie
	GOTO	label268436814
label268436811
	MOVF gbl_startStopFrecv, W
	GOTO	label268436814
label268436813
	MOVF gbl_timeBase+D'1', W
label268436814
	BSF gbl_transmisieQueue,1
label268436805
	BCF STATUS, RP0
	MOVF gbl_ctrlTransmisie, F
	BTFSS STATUS,Z
	GOTO	label268436876
	MOVF gbl_transmisieQueue, F
	BTFSS STATUS,Z
	GOTO	label268436833
	NOP
	GOTO	label268436876
label268436833
	BTFSS gbl_transmisieQueue,0
	GOTO	label268436841
	BTFSC STATUS,Z
	GOTO	label268436841
	BCF gbl_transmisieQueue,0
	MOVLW 0x01
	MOVWF gbl_transmisie+D'1'
	MOVF gbl_tmr1b+D'1', W
	MOVWF gbl_vartemp1
	MOVF gbl_vartemp1, W
	MOVWF gbl_transmisie+D'2'
	MOVF gbl_tmr1b, W
	MOVWF gbl_vartemp1
	MOVWF gbl_transmisie+D'3'
	MOVF gbl_tmr1c+D'1', W
	MOVWF gbl_vartemp1
	MOVWF gbl_transmisie+D'4'
	MOVF gbl_tmr1c, W
	MOVWF gbl_vartemp1
	MOVWF gbl_transmisie+D'5'
	MOVF gbl_tmr2b, W
	MOVWF gbl_transmisie+D'6'
	BSF STATUS, RP0
	BSF gbl_pie1,4
	GOTO	label268436876
label268436841
	BTFSS gbl_transmisieQueue,1
	GOTO	label268436876
	BCF gbl_transmisieQueue,1
	CLRF gbl_transmisie+D'1'
	MOVF gbl_adresaTransmisie, W
	MOVF gbl_dataTransmisie, W
	CLRF gbl_transmisie+D'4'
	CLRF gbl_transmisie+D'5'
	CLRF gbl_transmisie+D'6'
	BSF STATUS, RP0
	BSF gbl_pie1,4
label268436876
	GOTO	label268436698
; } main function end
	ORG 0x000001ED
_startup
	BCF PCLATH,3
	BCF PCLATH,4
	GOTO	main
	ORG 0x000001F0
interrupt
; { interrupt ; function begin
	BCF STATUS, RP0
	BCF STATUS, RP1
	BTFSC gbl_pir1,1
	CALL timeBaseTm_00015
	BTFSC gbl_pir1,0
	CALL tmr1_00000
	BTFSC gbl_pir1,5
	CALL receptieSe_00013
	BTFSS gbl_pir1,4
	GOTO	label268436906
	BSF STATUS, RP0
	BTFSS gbl_pie1,4
	GOTO	label268436906
	CALL transmisie_00014
label268436906
	BCF STATUS, RP0
	SWAPF Int1BContext+D'2', W
	MOVWF FSR
	SWAPF Int1BContext+D'1', W
	MOVWF PCLATH
	SWAPF Int1BContext, W
	MOVWF STATUS
	SWAPF Int1Context, F
	SWAPF Int1Context, W
	RETFIE
; } interrupt function end
	END
