  LIST P=16F877-4
	#INCLUDE	<P16F877.INC>
	__CONFIG _CP_OFF & _WDT_OFF & _BODEN_OFF & _PWRTE_ON & _XT_OSC & _WRT_ENABLE_ON & _LVP_OFF & _DEBUG_OFF & _CPD_OFF
;PICGN220.ASM 21 APR 2000 - JOHN BECKER - EPE PIC FUNCTION GEN + FREQ COUNT
;PIC16F877-4, 3.2768Hz, WDT OFF, POR ON, XTAL XT
;Config register bits (all PIC TOOLKIT MK2 defaults)
; CP1 CP0 DBG NIL WRT CPD LVP BOR CP1 CP0 POR WDT OS1 OS0
;  1   1   1   1   1   1   0   0   1   1   0   0   0   1
;N.B. Logic 1/0 do NOT necessarily mean that the function is On/Off
;respectively - refer to PIC '87 data sheet.
;#DEFINE PAGE0   	BCF 0x03,0x5
;#DEFINE PAGE1   	BSF 0x03,0x5
	INDF:    	EQU 0x00  ;page 0, 1, 2, 3
	TMR0:    	EQU 0x01  ;page 0, 2
	OPTION:  	EQU 0x01  ;page 1, 3
	PCL:     	EQU 0x02  ;page 0, 1, 2, 3
	STATUS:  	EQU 0x03  ;page 0, 1, 2, 3
	FSR:     	EQU 0x04  ;page 0, 1, 2, 3
	PORTA:   	EQU 0x05  ;page 0
;	TRISA:   	EQU 0x05  ;page 1
	PORTB:   	EQU 0x06  ;page 0, 2
;	TRISB:   	EQU 0x06  ;page 1, 3
	PORTC:   	EQU 0x07  ;page 0
;	TRISC:   	EQU 0x07  ;page 1
	PORTD:   	EQU 0x08  ;page 0
;	TRISD:   	EQU 0x08  ;page 1
	PORTE:   	EQU 0x09  ;page 0
;	TRISE:   	EQU 0x09  ;page 1
	INTCON:  	EQU 0x0B  ;page 0, 1, 2, 3
	ADCON0:  	EQU 0x1F  ;page 0
;	ADCON1:  	EQU 0x1F  ;page 1
	LOOPA:   	EQU 0x20       ;loop used by LCD send routine
	LOOPB:   	EQU 0x21       ;general loop
	STORE:   	EQU 0x22       ;general store
	STORE1:  	EQU 0x23       ;general store
	STORE2:  	EQU 0x24       ;general store
	STORE3:  	EQU 0x25       ;general store
	RSLINE:  	EQU 0x26       ;LCD function flag store
	SWITCH:  	EQU 0x27       ;switch status store
	MARK1:   	EQU 0x28       ;freq count polarity marker 1
	MARK2:   	EQU 0x29       ;freq count polarity marker 2
	DEC1:    	EQU 0x2A       ;decimalisation byte 1
	DEC2:    	EQU 0x2B       ; byte 2
	DEC3:    	EQU 0x2C       ; byte 3
	DEC4:    	EQU 0x2D       ; byte 4
	DEC5:    	EQU 0x2E       ; byte 5
	DEC6:    	EQU 0x2F       ; byte 6 (dummy)      
	ANSA1:   	EQU 0x30       ;decimalisation answer store 1
	ANSA2:   	EQU 0x31       ; answer 2
	ANSA3:   	EQU 0x32       ; answer 3
	ANSA4:   	EQU 0x33       ; answer 4
	ANSA5:   	EQU 0x34       ; answer 5
	FREQ0:   	EQU 0x35       ;frequency counter lsb
	FREQ1:   	EQU 0x36       ;frequency counter nsb
	FREQ2:   	EQU 0x37       ;frequency counter nsb
	FREQ3:  	EQU 0x38       ;frequency counter nsb
	FREQ4:   	EQU 0x39       ;frequency counter msb
	CLKCNT:  	EQU 0x3A       ;timing counter
	SLOWIT:  	EQU 0x3B       ;delay factor for PAUSE
	LOOPX:   	EQU 0x3C       ;delay loop for LCDOUT
	OUT7:    	EQU 0x3D       ;8 bytes for freq store and output to LCD
	OUT6:    	EQU 0x3E
	OUT5:    	EQU 0x3F
	OUT4:    	EQU 0x40
	OUT3:    	EQU 0x41
	OUT2:    	EQU 0x42
	OUT1:    	EQU 0x43
	OUT0:    	EQU 0x44
	LCDSTOR1: 	EQU 0x45
	LCDSTOR2: 	EQU 0x46
	STOREC:   	EQU 0x47
	STORED:   	EQU 0x48
	TENFLG:   	EQU 0x49
	TENCNT:   	EQU 0x4A
	RANGE:    	EQU 0x4B      ;frequency cap selection
	SHAPE:    	EQU 0x4C      ;waveform shape selection
	SAMPLE:   	EQU 0x4D      ;1sec/10sec flag
	CLKVAL1:  	EQU 0x4E
	CLKVAL2:  	EQU 0x4F
	W:       	EQU 0
	F:       	EQU 1
	C:       	EQU 0
	DC:      	EQU 1
	Z:       	EQU 2
	RP0:     	EQU 5         ;STATUS reg
	RP1:     	EQU 6         ;STATUS reg
	GIE:     	EQU 7         ;INTCON reg
        ORG 	0x0004      		;Interrupt vector address
        GOTO 	START      	;Jump to interrupt routine on interrupt
        ORG 	0x0005      		;Start of program memory
        clrf 	INTCON
GIEOFF: 
	BCF 	INTCON,GIE  ;turn off global interrupts
        BTFSC 	INTCON,GIE
        goto 	GIEOFF
	goto 	START
TABLCD: 					;LCD initialisation table, itt állítja be a kijelzőt
	addwf 	PCL,F     	;PCL-->PC+1	és mivel az akkuban 0 van, ezért nem változik a PCL értéke
        retlw 	B'00110011' 	;visszateszi az értéket az akkuba, initialise lcd - first byte
        retlw 	B'00110011' 	;2nd byte (repeat of first)
        retlw 	B'00110010' 	;set for 4-bit operation
        retlw 	B'00101100' 	;set for 2 lines
        retlw 	B'00000110' 	;set entry mode to increment each address
        retlw 	B'00001100' 	;set display on, cursor off, blink off
        retlw 	B'00000001' 	;clear display
        retlw 	B'00000010' 	;return home, cursor & RAM to zero
                        	;end initialisation table
TBDEC1:                 	;table for decimalisation lsb
        addwf 	PCL,F     	;add program counter
        retlw 	0x10	    	;lsb of 10000
        retlw 	0xE8       	;lsb of 1000
        retlw 	0x64       	;lsb of 100
        retlw 	0x0A       	;lsb of 10
TBDEC2:                 	;table for decimalisation msb
        retlw 	0x27       	;msb of 10000
        retlw 	0x03       	;msb of 1000
        retlw 	0	      	;msb of 100
        retlw 	0       	;msb of 10
RANGIT: 
	addwf 	PCL,F     	;range control vals
        retlw 	B'11111111'
        retlw 	B'11111101'
        retlw 	B'11111011'
        retlw 	B'11110111'
        retlw 	B'11101111'
        retlw 	B'11011111'
        retlw 	B'10111111'
        retlw 	B'01111111'
WAVEIT: 
	addwf 	PCL,F     ;waveform message routing
        goto 	SQUARE
        goto 	TRNGLE
        goto 	SINE
SINE:   
	movf 	LOOPA,W
        addwf 	PCL,F     ;sine message route
        retlw 	'S'
        retlw 	'I'
        retlw 	'N'
        retlw 	'.'
SQUARE: 
	movf 	LOOPA,W
        addwf 	PCL,F     ;square message route
        retlw 	'S'
        retlw 	'Q'
        retlw 	'R'
        retlw 	'.'
TRNGLE: 
	movf 	LOOPA,W
        addwf 	PCL,F     ;triangle message route
        retlw 	'T'
        retlw 	'R'
        retlw 	'I'
        retlw 	'.'
START:  
       	bcf 	STATUS,RP0		;BANK0 kiválasztása
        bcf 	STATUS,RP1
	clrf 	PORTA			;kimenetek törlése
        clrf 	PORTB
        clrf 	PORTC
        clrf 	PORTD
        clrf 	PORTE
;       PAGE1							;---------------------------------------------------------EZT MÓDOSÍTOTTAM
	bsf 	STATUS,RP0		;BANK1 kiválasztása
       	bcf 	STATUS,RP1
        clrf 	TRISA          		;PORTA kimenet	
       	movlw 	B'00111111'		
        movwf 	TRISB         		;PORTB bemenet
        movlw 	255
        movwf 	TRISC         		;PORTC bemenet
        movlw 	B'11001111'
        movwf 	TRISD         		;RD0-RD3, RD6-RD7 bemenet, RD4-RD5 kimenet
        movlw 	B'00000111'
        movwf 	TRISE         		;PORTE bemenet
        movlw 	B'00000111'    		;RA0-RA4 digitális kimenet
        movwf 	ADCON1
        movlw 	B'10000110'    		;EREDETI: B'10000110'   PORTB felhúzó ell. kikapcs., timer 1:128 (1/25th sec)
        movwf 	OPTION_REG
;       PAGE0						;---------------------------------------------------------EZT MÓDOSÍTOTTAM
	bcf 	STATUS,RP0		;BANK0-ra váltás
        bcf 	STATUS,RP1
        call 	PAUSIT			;késleltető rutin meghívása
LCDSET: 
	clrf 	LOOPB			;általános	hurok törlése
        clrf 	RSLINE			;törli az RS vonalat
LCDST2: 	
	movf 	LOOPB,W			;loopb értékét az akkuba teszi
        call 	TABLCD			;itt állítja be a kijelzőt
        call 	LCDOUT
        incf 	LOOPB,F
        btfss 	LOOPB,3			;16X lefut ez a rutin
        goto 	LCDST2
        call 	PAUSIT
        clrf 	MARK2
        clrf 	SWITCH
        clrf 	FREQ0
        clrf 	FREQ1
        clrf 	FREQ2
        clrf 	FREQ3
        clrf 	FREQ4
        clrf 	ANSA1
        clrf 	ANSA2
        clrf 	ANSA3
        clrf 	ANSA4
        clrf 	ANSA5
        clrf 	DEC1
        clrf 	DEC2
        clrf 	DEC3
        clrf 	DEC4
        clrf 	DEC5
        clrf 	DEC6
        clrf 	TENFLG
        clrf 	TENCNT
        clrf 	MARK1
        clrf 	MARK2
        clrf 	RANGE
        clrf 	SAMPLE
        movlw 	0            ;......2
        movwf 	SHAPE
        call 	WAVE1
        movlw 	25
        movwf 	CLKVAL1
        movlw 	250
        movwf 	CLKVAL2
        movf 	CLKVAL1,W
        movwf 	CLKCNT
        bsf 	PORTD,4        ;reset counter IC6
        bcf 	PORTD,4
        bsf 	PORTD,5        ;enable clock input
        movlw 	4
        movwf 	RANGE
        bcf 	INTCON,2
        goto 	SHWRNG
;............................ END OF SETUP
MAIN:   
	btfss 	INTCON,2
        goto 	MF1
        bcf 	INTCON,2
        movf 	PORTE,W       	;is a range switch pressed?
        btfss 	STATUS,Z
        goto 	RANGESW      	;yes
        btfsc 	PORTB,0      	;is waveshape switch pressed?
        call 	WAVEFRM       	;yes
        decfsz 	CLKCNT,F    	;dec timing counter, is it 0
        goto 	MF1           	;no
        goto 	GETFREQ      	;yes
MF1:    
	call 	INCCNT
        goto 	MAIN
INCCNT: 
	btfss 	PORTC,0
        goto 	MF2
        bsf 	MARK2,0
        return
MF2:    
	btfss 	MARK2,0      	;is MARK2 = 1?
        return             		;no
        bcf 	MARK2,0
        incfsz 	FREQ2,F     	;yes, inc counters accordingly
        return             		;(responds to negative-going aspect of IC6 Q12)
        incfsz	FREQ3,F
        return
        incf 	FREQ4,F
        return
;............show freq routine
GETFREQ:
	bcf 	PORTD,5        ;turn off clock input
        nop
        nop
        call 	INCCNT        ;*****
        movf 	PORTD,W       ;get pins which include Q0-Q3
        movwf 	STORED
        movf 	PORTC,W
        movwf 	STOREC
        bsf 	PORTD,5        ;turn on clock input
        bcf 	STATUS,C       ;shift freq counters right by 4 places
        rrf 	FREQ4,F
        rrf 	FREQ3,F
        rrf 	FREQ2,F
        rrf 	FREQ1,F
        bcf 	STATUS,C
        rrf 	FREQ4,F
        rrf 	FREQ3,F
        rrf 	FREQ2,F
        rrf 	FREQ1,F
        bcf 	STATUS,C
        rrf 	FREQ4,F
        rrf 	FREQ3,F
        rrf 	FREQ2,F
        rrf 	FREQ1,F
        bcf 	STATUS,C
        rrf 	FREQ4,F
        rrf 	FREQ3,F
        rrf 	FREQ2,F
        rrf 	FREQ1,F
        btfsc 	STORED,1     ;Q1
        bsf 	FREQ0,0
        btfsc 	STORED,2     ;Q2
        bsf 	FREQ0,1
        btfsc 	STORED,3     ;Q3
        bsf 	FREQ0,2
        btfsc 	STOREC,4     ;Q4
        bsf 	FREQ0,3
        btfsc 	STOREC,6     ;Q5
        bsf 	FREQ0,4
        btfsc 	STOREC,7     ;Q6
        bsf 	FREQ0,5
        btfsc 	STOREC,5     ;Q7
        bsf 	FREQ0,6
        btfsc 	STOREC,3     ;Q8
        bsf 	FREQ0,7
        btfsc 	STORED,0     ;Q9
        bsf 	FREQ1,0
        btfsc 	STOREC,2     ;Q10
        bsf 	FREQ1,1
        btfsc 	STOREC,1     ;Q11
        bsf 	FREQ1,2
        btfsc 	STOREC,0     ;Q12
        bsf 	FREQ1,3
        movlw 	FREQ0
        call 	DECIML        ;decimalise digits 1 to 4 
        movf 	DEC1,W        ;copy answer into OUT-OUT3
        movwf 	OUT0
        movf 	ANSA1,W
        movwf 	OUT1
        movf 	ANSA2,W
        movwf 	OUT2
        movf 	ANSA3,W
        movwf 	OUT3
GF3:   
	movf 	ANSA4,W       ;copy overflow val into prev freq positions
        movwf 	FREQ0
        movf 	ANSA5,W
        movwf 	FREQ1
        clrf 	FREQ2
        clrf 	FREQ3
        clrf 	FREQ4
        movlw 	FREQ0
        call 	DECIML        ;now decimal digits 5 to 8
        movf 	ANSA3,W       ;copy answer into OUT4 to OUT7
        movwf 	OUT7
        movf 	ANSA2,W
        movwf 	OUT6
        movf 	ANSA1,W
        movwf 	OUT5
     	movf 	DEC1,W
        movwf 	OUT4
GF4:   
	call 	LCD5          ;output freq data to LCD
        bsf 	RSLINE,4
        clrf 	MARK1         ;clear leading zero flag
        movlw 	OUT7
        movwf 	FSR
        movlw 	8
        movwf 	LOOPA
MAINA:   
	movf 	INDF,W
        btfss 	STATUS,Z     ;is val = 0?
        goto 	MAINB         ;no
        btfsc 	MARK1,0      ;has val >0 been output?
        goto 	MAINB         ;yes
        movf 	LOOPA,W       ;is it the last byte of the loop?
        xorlw 	1
        btfsc 	STATUS,Z
        goto 	MAINB         ;yes
        movlw 	' '          ;clear leading zero
        goto 	MAINC
MAINB:  
	bsf 	MARK1,0        ;format as ASCII decimal val
        andlw 	15
        iorlw 	48
MAINC:  
	call 	LCDOUT
        incf 	FSR,F
        decfsz 	LOOPA,F
        goto	MAINA
        btfss 	SAMPLE,0
        goto 	GF5
        call 	LCD12
        bsf 	RSLINE,4
        movlw 	'.'
        call 	LCDOUT
        decf 	FSR,F
        movf 	INDF,W
        andlw 	15
        iorlw 	48
        call 	LCDOUT
        goto 	GF6
GF5:    
	movlw 	' '
        call 	LCDOUT
GF6:    
	movlw 	'H'
        call 	LCDOUT
        movlw 	'z'
        call 	LCDOUT
MAINX:  
	clrf 	FREQ0         ;clear freq counters
        clrf	FREQ1
        clrf 	FREQ2
        clrf 	FREQ3
        clrf 	FREQ4
        clrf 	MARK2
        movf 	CLKVAL1,W
        btfsc 	SAMPLE,0     ;is 10sec rate on?
        movf 	CLKVAL2,W
        movwf	CLKCNT
        bcf 	PORTD,4
        clrf 	TMR0
        bcf	INTCON,2       ;clear interrupt
        goto 	MAIN          ;start sampling next batch
PAUSIT: 					;Ez egy sima késleltető rutin.
	movlw 	7		;ide 7 KELL 
        movwf 	SLOWIT
        bcf 	INTCON,2
PAUSE:   
	btfss 	INTCON,2      
	goto 	PAUSE
        bcf 	INTCON,2
        decfsz 	SLOWIT
        goto	PAUSE
        return
LCD1:   
	movlw 	B'10000000'    ;LCD cell position codes - not all used
        goto 	LCDLIN
LCD5:   
	movlw 	B'10000101'
        goto 	LCDLIN
LCD6:   
	movlw 	B'10000110'
        goto 	LCDLIN
LCD7:   
	movlw 	B'10000111'
        goto 	LCDLIN
LCD9:   
	movlw 	B'10001001'
        goto 	LCDLIN
LCD12:  
	movlw 	B'10001100'
        goto 	LCDLIN
LCD21:  
	movlw 	B'11000000'
        goto 	LCDLIN
LCD24:  
	movlw 	B'11000100'
        goto 	LCDLIN
LCD25:  
	movlw 	B'11000101'
        goto 	LCDLIN
LCD26:  
	movlw 	B'11000110'
        goto 	LCDLIN
LCD27:  
	movlw 	B'11000111'
        goto 	LCDLIN
LCD28:  
	movlw 	B'11001000'
        goto 	LCDLIN
LCD29:  
	movlw 	B'11001001'
        goto 	LCDLIN
LCDLIN: 
	BCF 	RSLINE,4
LCDOUT: 
	movwf 	STORE
        movlw 	50
        movwf 	LOOPX
DELAY: 
	decfsz 	LOOPX,F
        goto 	DELAY
        call 	SENDIT
SENDIT: 
	swapf 	STORE,F
        movf 	STORE,W
        andlw 	15
        iorwf 	RSLINE,W
        movwf 	LCDSTOR1
        clrf 	LCDSTOR2
        movlw 	6
        movwf 	LOOPX
SHIFT:  
	bcf 	STATUS,C      ;rearrange bits to suit PORTA pin order
        rrf 	LCDSTOR1,F
        rlf 	LCDSTOR2,F
        decfsz 	LOOPX,F
        goto 	SHIFT
        movf 	LCDSTOR2,W
        movwf 	PORTA
        bsf 	PORTA,0 	;toggle LCD line E  
        bcf 	PORTA,0
        bsf 	PORTA,5       ;turn on IC2 sync output line
        return
;..............convert binary to hex - not used in final model
LCDHEX: 
	movwf 	STORE2    ;split & format decimal byte as HEX for LCD
        swapf 	STORE2,W  ;get tens nibble
        andlw 	15
        movwf 	STORE1
        addlw 	6
        btfss 	STATUS,DC
        goto 	HEX2
        movf 	STORE1,W
        addlw 	55      ;set as alpha
        goto 	HEX3
HEX2:   
	movf 	STORE1,W
        iorlw 	48        ;set as numeral
HEX3:   
	call	LCDOUT     ;send it
        movf 	STORE2,W   ;get units
        andlw 	15
        movwf 	STORE1
        addlw 	6
        btfss 	STATUS,DC
        goto 	HEX4
        movf 	STORE1,W
        goto 	HEX5
HEX4:   
	movf 	STORE1,W
HEX5:   
	call 	LCDOUT
        return
;........... used to convert binary bytes to decimal for LCD
DECIML:                 ;decimalise binary number
                        ;copy source into working area at DEC
                        ;source address is brought in on W
                        ;DEC1-5 becomes source
                        ;answer goes into ANSA
        call 	COPYFD     ;copy data at FSR into DEC
        clrf 	STORE1
        clrf 	STORE3
        clrf 	ANSA5
        movlw 	ANSA4     ;set answer store address
        movwf 	FSR
        clrf 	LOOPA
DCML0: 
	movf 	LOOPA,W
        call 	TBDEC1     ;subtract lsb from source value
        subwf 	DEC1,F
        btfsc 	STATUS,C  ;is there a borrow?
        goto 	DCML1      ;no, so sub msb
        movlw 	1
        subwf 	DEC2,F    ;yes so decrement next byte
        movlw 	1         ;yes
        subwf 	DEC3,F
        movlw 	1         ;yes
        subwf 	DEC4,F
        movlw 	1         ;yes
        subwf 	DEC5,F
DCML3:  
	movf 	LOOPA,W    ;yes, so re-add last table values lsb
        call 	TBDEC1
        addwf 	DEC1,F
        btfss 	STATUS,C  ;is there a carry?
        goto 	DCML5      ;no so exit loop
        incf 	DEC2,F     ;yes so inc next byte
        btfss 	STATUS,Z  ;is there a carry? (is it zero)
        incf 	DEC3,F     ;yes
        incf 	DEC4,F     ;yes
        incf 	DEC5,F     ;yes
        goto 	DCML5      ;exit loop
DCML1:  
	movf 	LOOPA,W
        call 	TBDEC2     ;subtract msb from source value
        subwf 	DEC2,F
        goto 	DCML2      ;no
        movlw 	1
        subwf 	DEC3,F    ;yes so decrement next byte
        goto 	DCML2      ;no
        movlw 	1
        subwf 	DEC4,F    ;yes so decrement next byte
        goto 	DCML2      ;no
        movlw 	1
        subwf 	DEC5,F    ;yes so decrement next byte
        btfss 	STATUS,C  ;is there a borrow?
        goto 	DCML4      ;yes
DCML2:  
	incfsz 	STORE1,F ;inc counter & continue looping till zero
        goto 	DCML0
        incf 	STORE3,F
        goto 	DCML0
DCML4:  
	movf 	LOOPA,W    ;re-add last table values lsb
        call 	TBDEC1
        addwf 	DEC1,F
        goto 	DCML4A     ;no so add msb
        incf 	DEC3,F     ;yes, so inc next byte
        incf 	DEC4,F     ;yes, so inc next byte
        incf 	DEC5,F     ;yes, so inc next byte
DCML4A: 
	movf 	LOOPA,W    ;re-add last table values msb
        call 	TBDEC2
        addwf 	DEC2,F
        goto 	DCML5      ;no
        goto 	DCML5      ;no
        goto 	DCML5      ;no
DCML5: 
	movf 	STORE3,W
        btfss 	STATUS,Z
        movwf 	ANSA5
        movf 	STORE1,W   ;store counter and loop for next values
        movwf 	INDF      ;INDF here is ANSA group
        clrf 	STORE1
        clrf 	STORE3
        decf 	FSR,F
        incf 	LOOPA,F
        btfss 	LOOPA,2   ;is it = 4?
        goto 	DCML0      ;no
DCML6:  
	return
COPYFD: 
	movwf 	FSR       ;copy data at FSR to DEC
        movf 	INDF,W
        movwf 	DEC1
        incf 	FSR,F
        movf 	INDF,W
        movwf 	DEC2
        incf 	FSR,F
        movf 	INDF,W
        movwf 	DEC3
        incf 	FSR,F
        movf 	INDF,W
        movwf 	DEC4
        incf 	FSR,F
        movf 	INDF,W
        movwf 	DEC5
        clrf 	DEC6
        return
;...........range switch
RANGESW:  
	btfsc 	PORTE,2		
        goto 	SAMRATE
        call 	OK
        btfsc 	PORTE,1
        goto 	DECRNG
INCRNG: 
	incf 	RANGE,W
      	goto 	SHWRNG
DECRNG:
	decf 	RANGE,W
SHWRNG:   
	andlw 	7
        movwf 	RANGE
        call 	LCD21
        bsf 	RSLINE,4
        movlw 	'R'
        call 	LCDOUT
        movlw 	'a'
        call 	LCDOUT
        movlw 	'n'
        call 	LCDOUT
        movlw 	'g'
        call 	LCDOUT
        movlw 	'e'
        call 	LCDOUT
        movf 	RANGE,W
        sublw 	7
        iorlw 	48
        call 	LCDOUT
        movf 	PORTB,W
        andlw 	B'11000000'
        movwf 	PORTB
        bcf 	PORTD,6
        bcf 	PORTD,7
        movf 	RANGE,W
        call 	RANGIT
        andlw 	B'00111111'
	PAGE1
        movwf TRISB
        PAGE0	
        movf 	RANGE,W
        call 	RANGIT
        andlw 	B'11000000'
        iorlw 	B'00001111'
       	bcf 	STATUS,RP1
        movwf TRISD
        bcf 	STATUS,RP1
        call 	PAUSIT
        call 	PAUSIT
        movf 	PORTE,W
      	andlw 	D'3'
        btfss 	STATUS,Z
        goto 	RANGESW
        goto 	SAM1
;...........set sample rate 1sec/10sec
SAMRATE:
	incf 	SAMPLE,F
        bcf 	SAMPLE,1
        call 	OK
SAM1:   
        clrf 	FREQ1
        clrf 	FREQ2
        clrf 	FREQ3
        clrf 	FREQ4
        clrf 	MARK2
        call 	LCD27
        bsf 	RSLINE,4
        movlw 	'T'
        call 	LCDOUT
        movlw 	'i'
        call 	LCDOUT
        movlw 	'm'
        call 	LCDOUT
        movlw 	'e'
        call 	LCDOUT
        movlw 	'1'
        call 	LCDOUT
        movlw 	' '
        btfsc 	SAMPLE,0
        movlw 	'0'
        call 	LCDOUT
        movlw 	's'
        call 	LCDOUT
        movlw 	'e'
        call 	LCDOUT
        movlw 	'c'
        call 	LCDOUT
SAM3: 	
	movf 	PORTE,W
        andlw 	7
        btfss 	STATUS,Z
        goto 	SAM3
        bsf 	RSLINE,4
        movlw 	' '
        call 	LCDOUT
        movlw 	' '
        call 	LCDOUT
        movlw 	'C'
        call 	LCDOUT
        movlw 	'O'
        call 	LCDOUT
        movlw 	'U'
        call 	LCDOUT
        movlw 	'N'
        call 	LCDOUT
        movlw 	'T'
        call 	LCDOUT
        movlw 	'I'
        call 	LCDOUT
        movlw 	'N'
        call 	LCDOUT
        movlw 	'E'
        call 	LCDOUT
        movlw 	' '
        call 	LCDOUT
        movf 	CLKVAL1,W
        btfsc 	SAMPLE,0
        movf 	CLKVAL2,W
        movwf 	CLKCNT
        bcf 	PORTD,4
        goto 	MAIN
OK:   
        bsf 	RSLINE,4
        movlw 	' '
        call 	LCDOUT
        movlw 	' '
        call 	LCDOUT
        movlw 	'O'
        call 	LCDOUT
        movlw 	'K'
        call 	LCDOUT
        movlw 	7
        movwf 	LOOPA
OK2:   
	movlw 	' '
        call 	LCDOUT
        decfsz 	LOOPA,F
        goto 	OK2
        movlw 	0
        call 	LCDOUT
        return
WAVEFRM:
	incf 	SHAPE,F
        movf 	SHAPE,W
        xorlw 	B'00000011'
        btfsc 	STATUS,Z
        clrf 	SHAPE
WAVE1: 
	call 	LCD1          ;output freq data to LCD
        bsf 	RSLINE,4
        clrf 	LOOPA
WAVE2:  
	movf 	SHAPE,W
        call 	WAVEIT
        call 	LCDOUT
        incf	LOOPA,F
        btfss 	LOOPA,2
        goto 	WAVE2
        swapf 	SHAPE,W
        movwf 	STORE
        rlf 	STORE,F
        rlf 	STORE,W
        andlw 	B'11000000'
        movwf 	STORE
        movf 	PORTB,W
        andlw 	B'00111111'
        iorwf 	STORE,W
        movwf 	PORTB
WAVE3: 
	btfsc 	PORTB,0
        goto 	WAVE3
        call 	PAUSIT
        return
        END
