; Source created with Parsic Version 3.x
; at              : 2011.02.08. 21:52:59
; Project File    : C:\PROGRA~1\PARSIC\PROJEK~1\mcp97_82.PIC
; Project Version : 1.0.42
; Created         : 2010.11.17. 21:51:00
; Last change     : 2011.02.08. 21:52:55
	PROCESSOR 16F876
	INCLUDE P16F876.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC & _LVP_OFF & _CPD_OFF & _DEBUG_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
LT1_FD	= 32	; located in Bank 0
ADC4	= 33	; located in Bank 0
ADC4_HI	= 34	; located in Bank 0
S1	= 35	; located in Bank 0
S1_HI	= 36	; located in Bank 0
S2	= 37	; located in Bank 0
S2_HI	= 38	; located in Bank 0
S3	= 39	; located in Bank 0
S3_HI	= 40	; located in Bank 0
LT2_FD	= 41	; located in Bank 0
S8	= 42	; located in Bank 0
S4	= 43	; located in Bank 0
S5	= 44	; located in Bank 0
S6	= 45	; located in Bank 0
S6_HI	= 46	; located in Bank 0
LT3_FD	= 47	; located in Bank 0
S0	= 48	; located in Bank 0
S0_HI	= 49	; located in Bank 0
S7	= 50	; located in Bank 0
TR1	= 51	; located in Bank 0
TR1_HI	= 52	; located in Bank 0
LT4_FD	= 53	; located in Bank 0
RAM	= 54	; located in Bank 0
SYS_TMP1	= 114	; located in Bank 0, 1, 2, 3
SYS_TMP2	= 115	; located in Bank 0, 1, 2, 3
SYS_TMP3	= 116	; located in Bank 0, 1, 2, 3
SYS_TMP4	= 117	; located in Bank 0, 1, 2, 3
SYS_TMP5	= 118	; located in Bank 0, 1, 2, 3
SYS_TMP6	= 119	; located in Bank 0, 1, 2, 3
SYS_TMP9	= 120	; located in Bank 0, 1, 2, 3
SYS_TMP10	= 121	; located in Bank 0, 1, 2, 3
SYS_TMP7	= 122	; located in Bank 0, 1, 2, 3
SYS_WSAV	= 123	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 124	; located in Bank 0, 1, 2, 3
SYS_PSAV	= 125	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 126	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	MOVLW HIGH SYS_INIT	; set page
	MOVWF PCLATH
	GOTO SYS_INIT
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	MOVFW PCLATH
	MOVWF SYS_PSAV
	CLRF PCLATH
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
EXITINT
	MOVFW SYS_PSAV
	MOVWF PCLATH
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Multiplikation 16 - Bit
; OP1 = SYS_TMP1,2
; OP2 = SYS_TMP3,4
SYSMUL16
	MOVLW 16	; set loopcounter
	MOVWF SYS_TMP7
	CLRF SYS_TMP5	; clear result
	CLRF SYS_TMP6
SYSMUL16_1
	RRF SYS_TMP4,F
	RRF SYS_TMP3,F
	BTFSS STATUS,CARRY
	GOTO SYSMUL16_2
	MOVFW SYS_TMP2	; add High-Byte
	ADDWF SYS_TMP6,F
	MOVFW SYS_TMP1	; add Low-Byte
	ADDWF SYS_TMP5,F
	BTFSC STATUS,CARRY	; carry ?
	INCF SYS_TMP6,F	; add 256 to result
SYSMUL16_2
	BCF STATUS,CARRY
	RLF SYS_TMP1,F
	RLF SYS_TMP2,F
	DECFSZ SYS_TMP7,F
	GOTO SYSMUL16_1
	RETURN
; Division 16 - Bit
; OP1 = SYS_TMP1,2
; OP2 = SYS_TMP3,4
SYSDIV16
	MOVFW SYS_TMP3	; Division durch 0 ?
	IORWF SYS_TMP4,W
	BTFSC STATUS,ZERO
	GOTO SYSDIV16_ERROR
	CLRF SYS_TMP5	; Ergebnis löschen
	CLRF SYS_TMP6
	MOVLW 1
	MOVWF SYS_TMP7
SYSDIV16_0
	BTFSC SYS_TMP4,7	; OP2 linksbündig
	GOTO SYSDIV16_1
	INCF SYS_TMP7,F
	BCF STATUS,CARRY
	RLF SYS_TMP3,F
	RLF SYS_TMP4,F
	GOTO SYSDIV16_0
SYSDIV16_1
	MOVFW SYS_TMP4	; OP1 und OP2 vergleichen
	SUBWF SYS_TMP2,W	; F-W -> W
	BTFSS STATUS,ZERO
	GOTO SYSDIV16_2
	MOVFW SYS_TMP3
	SUBWF SYS_TMP1,W	; F-W -> W
SYSDIV16_2
	BTFSS STATUS,CARRY
	GOTO SYSDIV16_3
	MOVFW SYS_TMP4	; OP1-OP2
	SUBWF SYS_TMP2,F	; F-W -> F
	MOVFW SYS_TMP3
	SUBWF SYS_TMP1,F	; F-W -> F
	BTFSS STATUS,CARRY
	DECF SYS_TMP2,F
	BSF STATUS,CARRY
SYSDIV16_3
	RLF SYS_TMP5,F	; Ergebnis aktualisieren
	RLF SYS_TMP6,F
	RRF SYS_TMP4,F	; OP2 nach rechts schieben
	RRF SYS_TMP3,F
	DECFSZ SYS_TMP7,F	; Zähler -1
	GOTO SYSDIV16_1
	RETURN
SYSDIV16_ERROR
	MOVLW 255
	MOVWF SYS_TMP5
	MOVWF SYS_TMP6
	RETURN
; Subroutines
; Read  -> AN4
READ_AN4
	MOVLW B'010'
	BSF STATUS,RP0	; Bank 1
	BCF STATUS,RP1	; Bank 1
	MOVWF ADCON1
	BSF TRISA,5
	BSF ADCON1,ADFM	; Right-Justified
	MOVLW B'11100001'	; CH4
	MOVWF ADCON0
	MOVLW 5
	MOVWF SYS_TMP1
SYS_ADC_LABEL_0
	DECFSZ SYS_TMP1,F
	GOTO SYS_ADC_LABEL_0
	BSF ADCON0,GO	; Start convert
SYS_ADC_LABEL_1
	BTFSC ADCON0,GO	; ready ?
	GOTO SYS_ADC_LABEL_1	; no
	MOVFW ADRESL
	MOVWF ADC4
	MOVFW ADRESH
	MOVWF ADC4_HI
	MOVLW 6
	MOVWF ADCON1
	MOVLW B'11111111'
	MOVWF TRISA
	RETURN
; Subroutines for LB1
LCD_LB1_INIT
	BCF PORTB,4	; ir-register
LCD_LB1_L1
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L1
	MOVFW PORTB
	ANDLW H'F0'
	IORLW B'0011'	; Function Set
	MOVWF PORTB
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	BSF SYS_TMP1,5	; wait
LCD_LB1_L2
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L2
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	BCF PORTB,0	; 4-Bit Interface
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	MOVLW B'00101000'	; Function Set 4-Bit,2-Lines
	CALL LCD_LB1_OUT
	MOVLW B'00001100'	; Display on, Cursor off, Blink off
	CALL LCD_LB1_OUT
	MOVLW B'00000110'	; Entrymode set
	CALL LCD_LB1_OUT
LCD_LB1_CLR
	MOVLW B'00000001'	; Display clear
	CALL LCD_LB1_OUT
LCD_LB1_L3
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L3
	GOTO LCD_LB1_OUT4
LCD_LB1_GOTOXY
	MOVLW H'40'
	BTFSC SYS_TMP2,0	; Ypos
	ADDWF SYS_TMP1,F
	BSF SYS_TMP1,7	; select dd-ram
	GOTO LCD_LB1_OUT1
LCD_LB1_WRITESTR
	BSF PORTB,4	; dd-ram
LCD_LB1_WRITESTR1
	CALL LCD_LB1_CHAROUT
	BSF INTCON,GIE
	ANDLW H'FF'	; last is zero
	BTFSC STATUS,ZERO
	RETURN
	MOVWF SYS_TMP1
	MOVLW HIGH LCD_LB1_OUT1	; set page
	MOVWF PCLATH
	CALL LCD_LB1_OUT1
	INCFSZ SYS_TMP4,F	; next char
	GOTO LCD_LB1_WRITESTR1
	INCF SYS_TMP5,F	; next page
LCD_LB1_CHAROUT
	BCF INTCON,GIE
	MOVFW SYS_TMP5
	MOVWF PCLATH
	MOVFW SYS_TMP4
	MOVWF PCL
LCD_LB1_DEZO10000
	MOVLW LOW 10000
	MOVWF SYS_TMP1
	MOVLW HIGH 10000
	MOVWF SYS_TMP2
	CALL LCD_LB1_CONVERTDEZ
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO1000
	CALL LCD_LB1_CHECKNULL
LCD_LB1_DEZO1000
	MOVLW LOW 1000
	MOVWF SYS_TMP1
	MOVLW HIGH 1000
	MOVWF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
LCD_LB1_DEZO100
	MOVLW LOW 100
	MOVWF SYS_TMP1
	CLRF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO10
LCD_LB1_DEZO10
	MOVLW LOW 10
	MOVWF SYS_TMP1
	CLRF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO1
LCD_LB1_DEZO1
	MOVLW 48
	ADDWF SYS_TMP4,W
	GOTO LCD_LB1_WRITECHAR
LCD_LB1_CONVERTDEZ
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	DECF SYS_TMP9,F
	CLRF SYS_TMP6
LCD_LB1_CONVERTDEZ2
	INCF SYS_TMP6,F
	MOVFW SYS_TMP1
	SUBWF SYS_TMP4,F
	MOVFW SYS_TMP2
	BTFSS STATUS,CARRY
	INCFSZ SYS_TMP2,W
	SUBWF SYS_TMP5,F
	BTFSC STATUS,CARRY
	GOTO LCD_LB1_CONVERTDEZ2
	MOVFW SYS_TMP2
	ADDWF SYS_TMP5,F
	MOVFW SYS_TMP1
	ADDWF SYS_TMP4,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP5,F
	DECF SYS_TMP6,W
	BTFSS STATUS,ZERO
	BSF SYS_TMP10,0
	RETURN
LCD_LB1_CONVERTHEX
	ANDLW 15
	MOVWF SYS_TMP1
	MOVLW 48
	ADDWF SYS_TMP1,F
	MOVLW 58
	SUBWF SYS_TMP1,W
	BTFSS STATUS,CARRY
	GOTO $+3
	MOVLW 7
	ADDWF SYS_TMP1,F
	MOVFW SYS_TMP1
LCD_LB1_WRITECHAR
LCD_LB1_OUT
	MOVWF SYS_TMP1	; store
LCD_LB1_OUT1
	CLRF SYS_TMP3	; LCDWriteStr (first nibble)
LCD_LB1_OUT2
	SWAPF SYS_TMP1,W	;high nibble
LCD_LB1_OUT3
	ANDLW H'0F'	; mask
	MOVWF SYS_TMP2	; store
	MOVFW PORTB	; load port
	ANDLW H'F0'	; mask
	IORWF SYS_TMP2,W	; add cmd
	MOVWF PORTB	; out
	BSF PORTB,5	; E high
	GOTO $+1
	BCF PORTB,5	; E low
	BTFSC SYS_TMP3,3	; ready ?
	GOTO LCD_LB1_OUT4	; yes
	BSF SYS_TMP3,3	; second nibble
	MOVFW SYS_TMP1
	GOTO LCD_LB1_OUT3	; next nibble
LCD_LB1_OUT4
LCD_LB1_OUTV
	DECFSZ SYS_TMP3,F
	GOTO LCD_LB1_OUTV
	RETURN
LCD_LB1_CHECKNULL
	BTFSS STATUS,ZERO
	DECF SYS_TMP9,F
	MOVWF SYS_TMP1
	BTFSS STATUS,ZERO
	BSF SYS_TMP10,0
	MOVLW 48
	BTFSC SYS_TMP10,0
	ADDWF SYS_TMP1,f
	MOVLW 32
	BTFSS SYS_TMP10,0
	ADDWF SYS_TMP1,F
	MOVFW SYS_TMP1
; 012F
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW B'00000000'
	MOVWF PORTC
	MOVLW 143
	MOVWF OPTION_REG
	MOVLW 6	; all Digital
	MOVWF ADCON1
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'11000000'
	MOVWF TRISB
	MOVLW B'11111111'
	MOVWF TRISC
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 16
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'70'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	MOVLW 144
	MOVWF FSR
CR4
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR4
	MOVLW B'00000100'
	MOVWF S8
; Init LCD -> LB1
	CALL LCD_LB1_INIT
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
	CALL READ_AN4
; LCD -> LT1
; test of positiv edge
	BTFSC LT1_FD,0
	GOTO LABEL_LT1_SETFD
	BTFSS S8,1
	MOVLW 3
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVLW HIGH LCD_LB1_GOTOXY	; set page
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT1
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT1
	MOVWF SYS_TMP5
	MOVLW HIGH LCD_LB1_WRITESTR	; set page
	MOVWF PCLATH
	CALL LCD_LB1_WRITESTR
	BCF PCLATH,3	; Page 0
	BCF PCLATH,4	; Page 0
LABEL_LT1_SETFD
	BTFSS S8,1
	GOTO LABEL_LT1_SETFD2
	BSF LT1_FD,0
	GOTO LABEL_LT1_END
LABEL_LT1_SETFD2
	BCF LT1_FD,0
LABEL_LT1_END
;AF1
	MOVFW S0
	MOVWF SYS_TMP1
	MOVFW S0_HI
	MOVWF SYS_TMP2
	MOVLW LOW 125
	MOVWF SYS_TMP3
	MOVLW HIGH 125
	MOVWF SYS_TMP4
	MOVLW HIGH SYSMUL16
	MOVWF PCLATH
	CALL SYSMUL16
	MOVLW HIGH LABEL_AF1
	MOVWF PCLATH
LABEL_AF1
	MOVFW SYS_TMP5
	MOVWF S1
	MOVFW SYS_TMP6
	MOVWF S1_HI
LABEL_AF1_EXIT
;AF2
	MOVFW S1
	MOVWF SYS_TMP1
	MOVFW S1_HI
	MOVWF SYS_TMP2
	MOVLW LOW 256
	MOVWF SYS_TMP3
	MOVLW HIGH 256
	MOVWF SYS_TMP4
	MOVLW HIGH SYSDIV16
	MOVWF PCLATH
	CALL SYSDIV16
	MOVLW HIGH LABEL_AF2
	MOVWF PCLATH
LABEL_AF2
	MOVFW SYS_TMP5
	MOVWF S2
	MOVFW SYS_TMP6
	MOVWF S2_HI
LABEL_AF2_EXIT
;AF3
	MOVLW HIGH 50
	SUBWF S2_HI,W
	MOVWF S3_HI
	MOVLW LOW 50
	SUBWF S2,W
	MOVWF S3
	BTFSS STATUS,CARRY
	DECF S3_HI,F
LABEL_AF3_EXIT
; LCD -> LT2
	BTFSC LT2_FD,0
	GOTO LABEL_LT2_SETFD
	BTFSS S8,0
	MOVLW 4
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVFW S4
	MOVWF SYS_TMP4
	CLRF SYS_TMP5
	BCF SYS_TMP10,0
	MOVLW 1
	MOVWF SYS_TMP9
	MOVLW HIGH LCD_LB1_DEZO100	; set page
	MOVWF PCLATH
	CALL LCD_LB1_DEZO100
LABEL_LT2_SETFD
	BTFSS S8,0
	GOTO LABEL_LT2_SETFD2
	BSF LT2_FD,0
	GOTO LABEL_LT2_END
LABEL_LT2_SETFD2
	BCF LT2_FD,0
LABEL_LT2_END
; Vergleich -> IF1
	MOVLW HIGH 50
	SUBWF S2_HI,W	; F - W -> W
	BTFSS STATUS,ZERO	; Wenn ZERO gesetzt LOW-Byte testen
	GOTO LABEL_IF1_CHECK
	MOVLW LOW 50
	SUBWF S2,W	; F - W -> W
LABEL_IF1_CHECK
	BTFSS STATUS,CARRY	; Test auf -> >
	GOTO LABEL_IF1_FALSE
	BTFSC STATUS,ZERO
LABEL_IF1_TRUE
	BCF S8,2
	GOTO LABEL_IF1_EXIT
LABEL_IF1_FALSE
	BSF S8,2
LABEL_IF1_EXIT
; Multiplexer -> MX1
	CLRF SYS_TMP1
	MOVFW S5
	BTFSS STATUS,ZERO
	GOTO LABEL_MX1_CHECKCONTROL1
	MOVFW S3
	MOVWF S4
	GOTO LABEL_MX1_END
	INCF SYS_TMP1,F
	MOVFW S5
	SUBWF SYS_TMP1,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MX1_CHECKCONTROL2
	MOVFW S6
	MOVWF S4
	GOTO LABEL_MX1_END
LABEL_MX1_END
; Verteiler -> BV1
	MOVLW 0 
	BTFSC S8,2	; IN0
	IORLW 1
	MOVWF S5	; OUT
;AF4
	MOVFW S2_HI
	SUBLW HIGH 50
	MOVWF S6_HI
	MOVFW S2
	SUBLW LOW 50
	MOVWF S6
	BTFSS STATUS,CARRY
	DECF S6_HI,F
LABEL_AF4_EXIT
; UND - Gatter -> LG1
LABEL_LG1_1
	BTFSS S8,0
	GOTO LABEL_LG1_FALSE
LABEL_LG1_2
	BTFSS S8,3
LABEL_LG1_TRUE
	BSF S8,1
	GOTO LABEL_LG1_ENDE
LABEL_LG1_FALSE
	BCF S8,1
LABEL_LG1_ENDE
; LCD -> LT3
	BTFSC LT3_FD,0
	GOTO LABEL_LT3_SETFD
	BTFSS S8,4
	MOVLW 3
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT3
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT3
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT3_SETFD
	BTFSS S8,4
	GOTO LABEL_LT3_SETFD2
	BSF LT3_FD,0
	GOTO LABEL_LT3_END
LABEL_LT3_SETFD2
	BCF LT3_FD,0
LABEL_LT3_END
; UND - Gatter -> LG2
LABEL_LG2_1
	BTFSS S8,0
	GOTO LABEL_LG2_FALSE
LABEL_LG2_2
	BTFSC S8,3
LABEL_LG2_TRUE
	BSF S8,4
	GOTO LABEL_LG2_ENDE
LABEL_LG2_FALSE
	BCF S8,4
LABEL_LG2_ENDE
; Vergleich -> IF2
	MOVLW HIGH 50
	GOTO LABEL_IF2_CHECK
	MOVLW LOW 50
LABEL_IF2_CHECK
	BTFSC STATUS,CARRY	; Test auf -> <
	GOTO LABEL_IF2_FALSE
LABEL_IF2_TRUE
	BSF S8,3
	GOTO LABEL_IF2_EXIT
LABEL_IF2_FALSE
	BCF S8,3
LABEL_IF2_EXIT
; Limiter -> LM1
	BCF S8,5
	BCF S8,6
	MOVFW ADC4
	MOVWF S0
	MOVFW ADC4_HI
	MOVWF S0_HI
	MOVLW HIGH 349
	SUBWF S0_HI,W
	BTFSS STATUS,ZERO
	GOTO LABEL_LM1_CHECK1
	MOVLW LOW 349
	SUBWF S0,W
LABEL_LM1_CHECK1
	BTFSS STATUS,CARRY
	GOTO LABEL_LM1_BOTTOM
	BTFSC STATUS,ZERO
	BSF S8,5
	MOVLW LOW 349
	MOVWF S0
	MOVLW HIGH 349
	MOVWF S0_HI
	GOTO LABEL_LM1_EXIT
LABEL_LM1_BOTTOM
	MOVLW HIGH 61
	SUBWF S0_HI,W
	BTFSS STATUS,ZERO
	GOTO LABEL_LM1_CHECK2
	MOVLW LOW 61
	SUBWF S0,W
LABEL_LM1_CHECK2
	BTFSC STATUS,CARRY
	GOTO LABEL_LM1_EXIT
	BSF S8,6
	MOVLW LOW 61
	MOVWF S0
	MOVLW HIGH 61
	MOVWF S0_HI
LABEL_LM1_EXIT
; Multiplexer -> MX2
	CLRF SYS_TMP1
	MOVFW S7
	BTFSS STATUS,ZERO
	GOTO LABEL_MX2_CHECKCONTROL1
	MOVFW ADC4
	MOVWF S0
	MOVFW ADC4_HI
	MOVWF S0_HI
	GOTO LABEL_MX2_END
	INCF SYS_TMP1,F
	MOVFW S7
	SUBWF SYS_TMP1,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MX2_CHECKCONTROL2
	MOVLW LOW 103
	MOVWF S0
	MOVLW HIGH 103
	MOVWF S0_HI
	GOTO LABEL_MX2_END
LABEL_MX2_END
; Verteiler -> BV2
	MOVLW 0 
	BTFSC S8,7	; IN0
	IORLW 1
	MOVWF S7	; OUT
; ODER - Gatter -> LG3
LABEL_LG3_1
	BTFSC S8,5
	GOTO LABEL_LG3_TRUE
LABEL_LG3_2
	BTFSC S8,6
	GOTO LABEL_LG3_TRUE
LABEL_LG3_FALSE
	BCF S8,7
	GOTO LABEL_LG3_ENDE
LABEL_LG3_TRUE
	BSF S8,7
LABEL_LG3_ENDE
; Timer -> TR1
	MOVLW 3	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 209
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 209
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S8,0
	GOTO LABEL_TR1_CLR
	BSF S8,0
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S8,0
LABEL_TR1_ENDE
; LCD -> LT4
	BTFSC LT4_FD,0
	GOTO LABEL_LT4_SETFD
	BTFSS S8,0
	MOVLW 7
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT4
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT4
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT4_SETFD
	BTFSS S8,0
	GOTO LABEL_LT4_SETFD2
	BSF LT4_FD,0
	GOTO LABEL_LT4_END
LABEL_LT4_SETFD2
	BCF LT4_FD,0
LABEL_LT4_END
	GOTO MAIN
TAB_LT1
	RETLW 45	; -
	RETLW 0	; end
TAB_LT3
	RETLW 32	;  
	RETLW 0	; end
TAB_LT4
	RETLW 67	; C
	RETLW 0	; end
	END
