; Source created with Parsic Version 3.x
; at              : 2011.02.17. 15:05:10
; Project File    : C:\Jagodits\PIC\SAJATP~1\stora6.PIC
; Project Version : 1.0.1
; Created         : 2011.01.23. 11:57:00
; Last change     : 2011.02.17. 15:05:07
	PROCESSOR 16F877
	INCLUDE P16F877.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC & _LVP_OFF & _CPD_OFF & _DEBUG_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
TR1	= 32	; located in Bank 0
TR1_HI	= 33	; located in Bank 0
S4	= 34	; located in Bank 0
ZR1	= 35	; located in Bank 0
ZR1_FD	= 36	; located in Bank 0
S5	= 37	; located in Bank 0
ZR2	= 38	; located in Bank 0
ZR2_FD	= 39	; located in Bank 0
S0	= 40	; located in Bank 0
ZR3	= 41	; located in Bank 0
ZR3_FD	= 42	; located in Bank 0
ZR4	= 43	; located in Bank 0
ZR4_FD	= 44	; located in Bank 0
ZR5	= 45	; located in Bank 0
ZR5_FD	= 46	; located in Bank 0
S1	= 47	; located in Bank 0
S2	= 48	; located in Bank 0
S3	= 49	; located in Bank 0
MF1	= 50	; located in Bank 0
MF1_HI	= 51	; located in Bank 0
MF1_FD	= 52	; located in Bank 0
RAM	= 53	; located in Bank 0
SYS_WSAV	= 115	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 116	; located in Bank 0, 1, 2, 3
SYS_PSAV	= 117	; located in Bank 0, 1, 2, 3
SYS_TMP1	= 118	; located in Bank 0, 1, 2, 3
SYS_TMP2	= 119	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	MOVLW HIGH SYS_INIT	; set page
	MOVWF PCLATH
	GOTO SYS_INIT
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW PCLATH
	MOVWF SYS_PSAV
	CLRF PCLATH
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
	INCFSZ MF1,F
	GOTO SYS_INT_LABEL_1
	INCF MF1_HI,F
SYS_INT_LABEL_1
EXITINT
	MOVFW SYS_PSAV
	MOVWF PCLATH
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
; Direct jump into a table
SYSTABJMP
	BCF INTCON,GIE
	BTFSC INTCON,GIE
	GOTO SYSTABJMP
	MOVFW SYS_TMP2
	MOVWF PCLATH
	MOVFW SYS_TMP1
	MOVWF PCL
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW B'00000000'
	MOVWF PORTC
	MOVLW B'00000000'
	MOVWF PORTD
	MOVLW B'00000000'
	MOVWF PORTE
	MOVLW 15
	BSF STATUS,RP0	; Bank 1
	MOVWF OPTION_REG
	MOVLW 6	; all Digital
	MOVWF ADCON1
; Richtung setzen
	MOVLW B'11110000'
	MOVWF TRISA
	MOVLW B'11100001'
	MOVWF TRISB
	MOVLW B'11110000'
	MOVWF TRISC
	MOVLW B'11111000'
	MOVWF TRISD
	MOVLW B'00000111'
	MOVWF TRISE
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 16
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'70'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	MOVLW 144
	MOVWF FSR
CR4
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR4
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; Timer -> TR1
	MOVLW 38	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 38
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 38
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S4,0
	GOTO LABEL_TR1_CLR
	BSF S4,0
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S4,0
LABEL_TR1_ENDE
; Vergleich -> IF1
	MOVLW 10
	SUBWF ZR1,W	; F - W -> W
LABEL_IF1_CHECK
	BTFSS STATUS,ZERO	; Test auf -> =
	GOTO LABEL_IF1_FALSE
LABEL_IF1_TRUE
	BSF S4,1
	GOTO LABEL_IF1_EXIT
LABEL_IF1_FALSE
	BCF S4,1
LABEL_IF1_EXIT
; Zähler -> ZR1
	BTFSS S4,1	; Reset ?
	GOTO LABEL_ZR1_COUNT
	CLRF ZR1
	GOTO LABEL_ZR1_SETOUT
LABEL_ZR1_COUNT
; Test auf positive Flanke
	BTFSC ZR1_FD,0
	GOTO LABEL_ZR1_SETFD
	BTFSS S4,0
	INCF ZR1,F
LABEL_ZR1_SETOUT
; Output Q0
	BTFSS ZR1,0
	GOTO LABEL_ZR1_SETOUT0
	BSF S5,0
	GOTO LABEL_ZR1_SETOUT0_END
LABEL_ZR1_SETOUT0
	BCF S5,0
LABEL_ZR1_SETFD
	BTFSS S4,0
	GOTO LABEL_ZR1_SETFD2
	BSF ZR1_FD,0
	GOTO LABEL_ZR1_END
LABEL_ZR1_SETFD2
	BCF ZR1_FD,0
LABEL_ZR1_END
; Zähler -> ZR2
	BTFSS S4,2	; Reset ?
	GOTO LABEL_ZR2_COUNT
	CLRF ZR2
	GOTO LABEL_ZR2_SETOUT
LABEL_ZR2_COUNT
	BTFSC ZR2_FD,0
	GOTO LABEL_ZR2_SETFD
	BTFSS S4,1
	INCF ZR2,F
LABEL_ZR2_SETOUT
; Output Q0
	BTFSS ZR2,0
	GOTO LABEL_ZR2_SETOUT0
	BSF S0,2
	GOTO LABEL_ZR2_SETOUT0_END
LABEL_ZR2_SETOUT0
	BCF S0,2
LABEL_ZR2_SETFD
	BTFSS S4,1
	GOTO LABEL_ZR2_SETFD2
	BSF ZR2_FD,0
	GOTO LABEL_ZR2_END
LABEL_ZR2_SETFD2
	BCF ZR2_FD,0
LABEL_ZR2_END
; Vergleich -> IF2
	MOVFW ZR2
	SUBLW 6	; K - W -> W
LABEL_IF2_CHECK
	GOTO LABEL_IF2_FALSE
LABEL_IF2_TRUE
	BSF S4,2
	GOTO LABEL_IF2_EXIT
LABEL_IF2_FALSE
	BCF S4,2
LABEL_IF2_EXIT
; Zähler -> ZR3
	BTFSS S4,3	; Reset ?
	GOTO LABEL_ZR3_COUNT
	CLRF ZR3
	GOTO LABEL_ZR3_SETOUT
LABEL_ZR3_COUNT
	BTFSC ZR3_FD,0
	GOTO LABEL_ZR3_SETFD
	BTFSS S4,5
	INCF ZR3,F
LABEL_ZR3_SETOUT
; Output Q0
	BTFSS ZR3,0
	GOTO LABEL_ZR3_SETOUT0
	BSF S0,3
	GOTO LABEL_ZR3_SETOUT0_END
LABEL_ZR3_SETOUT0
	BCF S0,3
LABEL_ZR3_SETFD
	BTFSS S4,5
	GOTO LABEL_ZR3_SETFD2
	BSF ZR3_FD,0
	GOTO LABEL_ZR3_END
LABEL_ZR3_SETFD2
	BCF ZR3_FD,0
LABEL_ZR3_END
; Zähler -> ZR4
	BTFSS S4,4	; Reset ?
	GOTO LABEL_ZR4_COUNT
	CLRF ZR4
	GOTO LABEL_ZR4_SETOUT
LABEL_ZR4_COUNT
	BTFSC ZR4_FD,0
	GOTO LABEL_ZR4_SETFD
	BTFSS S4,3
	INCF ZR4,F
LABEL_ZR4_SETOUT
LABEL_ZR4_SETFD
	BTFSS S4,3
	GOTO LABEL_ZR4_SETFD2
	BSF ZR4_FD,0
	GOTO LABEL_ZR4_END
LABEL_ZR4_SETFD2
	BCF ZR4_FD,0
LABEL_ZR4_END
; Vergleich -> IF3
	MOVFW ZR3
	SUBLW 10	; K - W -> W
LABEL_IF3_CHECK
	GOTO LABEL_IF3_FALSE
LABEL_IF3_TRUE
	BSF S4,3
	GOTO LABEL_IF3_EXIT
LABEL_IF3_FALSE
	BCF S4,3
LABEL_IF3_EXIT
; Vergleich -> IF4
	MOVFW ZR4
LABEL_IF4_CHECK
	GOTO LABEL_IF4_FALSE
LABEL_IF4_TRUE
	BSF S4,4
	GOTO LABEL_IF4_EXIT
LABEL_IF4_FALSE
	BCF S4,4
LABEL_IF4_EXIT
; Zähler -> ZR5
	BTFSS S4,6	; Reset ?
	GOTO LABEL_ZR5_COUNT
	CLRF ZR5
	GOTO LABEL_ZR5_SETOUT
LABEL_ZR5_COUNT
	BTFSC ZR5_FD,0
	GOTO LABEL_ZR5_SETFD
	BTFSS S4,7
	INCF ZR5,F
LABEL_ZR5_SETOUT
LABEL_ZR5_SETFD
	BTFSS S4,7
	GOTO LABEL_ZR5_SETFD2
	BSF ZR5_FD,0
	GOTO LABEL_ZR5_END
LABEL_ZR5_SETFD2
	BCF ZR5_FD,0
LABEL_ZR5_END
; Vergleich -> IF5
	MOVFW ZR5
	SUBLW 24	; K - W -> W
LABEL_IF5_CHECK
	GOTO LABEL_IF5_FALSE
LABEL_IF5_TRUE
	BSF S4,6
	GOTO LABEL_IF5_EXIT
LABEL_IF5_FALSE
	BCF S4,6
LABEL_IF5_EXIT
; ODER - Gatter -> LG1
LABEL_LG1_1
	BTFSC S4,2
	GOTO LABEL_LG1_TRUE
LABEL_LG1_2
	BTFSC PORTB,7
	GOTO LABEL_LG1_TRUE
LABEL_LG1_FALSE
	BCF S4,5
	GOTO LABEL_LG1_ENDE
LABEL_LG1_TRUE
	BSF S4,5
LABEL_LG1_ENDE
; Call subroutine TAB1
	MOVLW LOW TAB1
	MOVWF SYS_TMP1
	MOVLW HIGH TAB1
	MOVWF SYS_TMP2
	MOVFW ZR3
	ADDWF SYS_TMP1,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP2,F
	MOVLW HIGH SYSTABJMP	; set page
	MOVWF PCLATH
	CALL SYSTABJMP
	MOVWF S0
	BSF INTCON,GIE
	BCF PCLATH,3	; Page 0
	BCF PCLATH,4	; Page 0
; Verteiler -> BV1
	BTFSC S0,0
	GOTO LABEL_BV1_0
	BCF PORTA,0
	GOTO LABEL_BV1_0_END
LABEL_BV1_0
	BSF PORTA,0
LABEL_BV1_0_END
	BTFSC S0,1
	GOTO LABEL_BV1_1
	BCF PORTA,1
	GOTO LABEL_BV1_1_END
LABEL_BV1_1
	BSF PORTA,1
LABEL_BV1_1_END
	BTFSC S0,2
	GOTO LABEL_BV1_2
	BCF PORTA,2
	GOTO LABEL_BV1_2_END
LABEL_BV1_2
	BSF PORTA,2
LABEL_BV1_2_END
	BTFSC S0,3
	GOTO LABEL_BV1_3
	BCF PORTA,3
	GOTO LABEL_BV1_3_END
LABEL_BV1_3
	BSF PORTA,3
LABEL_BV1_3_END
; Call subroutine TAB2
	MOVLW LOW TAB2
	MOVWF SYS_TMP1
	MOVLW HIGH TAB2
	MOVWF SYS_TMP2
	MOVFW ZR4
	ADDWF SYS_TMP1,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP2,F
	MOVWF PCLATH
	CALL SYSTABJMP
	MOVWF S1
	BSF INTCON,GIE
; Verteiler -> BV2
	BTFSC S1,0
	GOTO LABEL_BV2_0
	BCF PORTB,1
	GOTO LABEL_BV2_0_END
LABEL_BV2_0
	BSF PORTB,1
LABEL_BV2_0_END
	BTFSC S1,1
	GOTO LABEL_BV2_1
	BCF PORTB,2
	GOTO LABEL_BV2_1_END
LABEL_BV2_1
	BSF PORTB,2
LABEL_BV2_1_END
	BTFSC S1,2
	GOTO LABEL_BV2_2
	BCF PORTB,3
	GOTO LABEL_BV2_2_END
LABEL_BV2_2
	BSF PORTB,3
LABEL_BV2_2_END
	BTFSC S1,3
	GOTO LABEL_BV2_3
	BCF PORTB,4
	GOTO LABEL_BV2_3_END
LABEL_BV2_3
	BSF PORTB,4
LABEL_BV2_3_END
; Call subroutine TAB3
	MOVLW LOW TAB3
	MOVWF SYS_TMP1
	MOVLW HIGH TAB3
	MOVWF SYS_TMP2
	MOVFW ZR5
	ADDWF SYS_TMP1,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP2,F
	MOVWF PCLATH
	CALL SYSTABJMP
	MOVWF S2
	BSF INTCON,GIE
; Verteiler -> BV3
	BTFSC S2,0
	GOTO LABEL_BV3_0
	BCF PORTC,0
	GOTO LABEL_BV3_0_END
LABEL_BV3_0
	BSF PORTC,0
LABEL_BV3_0_END
	BTFSC S2,1
	GOTO LABEL_BV3_1
	BCF PORTC,1
	GOTO LABEL_BV3_1_END
LABEL_BV3_1
	BSF PORTC,1
LABEL_BV3_1_END
	BTFSC S2,2
	GOTO LABEL_BV3_2
	BCF PORTC,2
	GOTO LABEL_BV3_2_END
LABEL_BV3_2
	BSF PORTC,2
LABEL_BV3_2_END
	BTFSC S2,3
	GOTO LABEL_BV3_3
	BCF PORTC,3
	GOTO LABEL_BV3_3_END
LABEL_BV3_3
	BSF PORTC,3
LABEL_BV3_3_END
; ODER - Gatter -> LG2
LABEL_LG2_1
	BTFSC S4,4
	GOTO LABEL_LG2_TRUE
LABEL_LG2_2
	BTFSC PORTB,6
	GOTO LABEL_LG2_TRUE
LABEL_LG2_FALSE
	BCF S4,7
	GOTO LABEL_LG2_ENDE
LABEL_LG2_TRUE
	BSF S4,7
LABEL_LG2_ENDE
; Verteiler -> BV4
	BTFSC S3,0
	GOTO LABEL_BV4_0
	BCF PORTD,0
	GOTO LABEL_BV4_0_END
LABEL_BV4_0
	BSF PORTD,0
LABEL_BV4_0_END
	BTFSC S3,1
	GOTO LABEL_BV4_1
	BCF PORTD,1
	GOTO LABEL_BV4_1_END
LABEL_BV4_1
	BSF PORTD,1
LABEL_BV4_1_END
; Call subroutine TAB4
	MOVLW LOW TAB4
	MOVWF SYS_TMP1
	MOVLW HIGH TAB4
	MOVWF SYS_TMP2
	MOVFW ZR5
	ADDWF SYS_TMP1,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP2,F
	MOVWF PCLATH
	CALL SYSTABJMP
	MOVWF S3
	BSF INTCON,GIE
; Mono-Flop -> MF1
; Läuft der Impuls ?
	BTFSC MF1_FD,1
	GOTO LABEL_MF1_CHKTIME
	BTFSC MF1_FD,0
	GOTO LABEL_MF1_SETFD
	BTFSS S5,0
LABEL_MF1_RESET
	CLRF MF1
	CLRF MF1_HI
	BSF MF1_FD,1
	BSF PORTD,2
LABEL_MF1_CHKTIME
	MOVLW 76
	SUBWF MF1_HI,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MF1_CHECK
	MOVLW 75
	SUBWF MF1,W
LABEL_MF1_CHECK
	BTFSS STATUS,CARRY
LABEL_MF1_TO
	BCF MF1_FD,1
	BCF PORTD,2
LABEL_MF1_SETFD
	BTFSS S5,0
	GOTO LABEL_MF1_CLR
	BSF MF1_FD,0
	GOTO LABEL_MF1_ENDE
LABEL_MF1_CLR
	BCF MF1_FD,0
LABEL_MF1_ENDE
	GOTO MAIN
; Table -> TAB1
TAB1
	RETLW 0	; // INDEX 0
	RETLW 1	; // INDEX 1
	RETLW 2	; // INDEX 2
	RETLW 3	; // INDEX 3
	RETLW 4	; // INDEX 4
	RETLW 5	; // INDEX 5
	RETLW 6	; // INDEX 6
	RETLW 7	; // INDEX 7
	RETLW 8	; // INDEX 8
	RETLW 9	; // INDEX 9
	RETLW 0	; // INDEX 10
; Table -> TAB2
TAB2
; Table -> TAB3
TAB3
	RETLW 1	; // INDEX 11
	RETLW 2	; // INDEX 12
	RETLW 3	; // INDEX 13
	RETLW 4	; // INDEX 14
	RETLW 5	; // INDEX 15
	RETLW 6	; // INDEX 16
	RETLW 7	; // INDEX 17
	RETLW 8	; // INDEX 18
	RETLW 9	; // INDEX 19
	RETLW 0	; // INDEX 20
	RETLW 1	; // INDEX 21
	RETLW 2	; // INDEX 22
	RETLW 3	; // INDEX 23
	RETLW 0	; // INDEX 24
; Table -> TAB4
TAB4
	RETLW 0	; // INDEX 3
	RETLW 0	; // INDEX 4
	RETLW 0	; // INDEX 5
	RETLW 0	; // INDEX 6
	RETLW 0	; // INDEX 7
	RETLW 0	; // INDEX 8
	RETLW 0	; // INDEX 9
	RETLW 1	; // INDEX 10
	RETLW 1	; // INDEX 12
	RETLW 1	; // INDEX 13
	RETLW 1	; // INDEX 14
	RETLW 1	; // INDEX 15
	RETLW 1	; // INDEX 16
	RETLW 1	; // INDEX 17
	RETLW 1	; // INDEX 18
	RETLW 1	; // INDEX 19
	RETLW 2	; // INDEX 20
	RETLW 2	; // INDEX 21
	RETLW 2	; // INDEX 23
	END
