;	Digital Thermometer						*
;	WWW.Guidecircuit.com						*
list      p=16f628            	
#include <p16f628.inc>        
errorlevel 0,-302
CBLOCK	0x20
DS_DAT	
DS_SIGN	
DUMMY0	
DUMMY1	
DUMMY2	
DUMMY3	
DUMMY4	
SEND	
COUNT	
NUM1	
NUM2	
NUM3	
DATA1	
HALF
	endc
#define	DAT_PIN	PORTB,0		; 74595 DATA pin
#define LATCH	PORTB,4		; 74595 LATCH pin 
#define CLK	PORTB,5		; 74595 CLK pin
#Define	DQ	PORTA,0
	org	0x000
	goto	Start
Table_	addwf	PCL,f
	dt	0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
Start	clrf	PORTA		; Set port A for digital I/O	
	movlw	0x07
	movwf	CMCON
	bsf	STATUS,RP0	
	movlw	b'00000110'	; Set port B for displaying via LED 7 segments
	movwf	PORTB
	bcf	STATUS,RP0
Main	call	RD_Temp	; Read data from DS1820
	clrf	HALF		; A Half digit
	bcf	STATUS,C
	rrf	DS_DAT,w	; Use 7-bit upper
	rlf	HALF,f		; Store a half degree 
	movwf	DATA1		; Data for convert to decimal
	call	Convert		; Convert data to decimal
	call	Delay3		; Display data delay
	goto	Main
;	Display On 7 Segment 					      *
Delay3	clrf	DUMMY4		; Display data delay
DelayLp	call	Disp
	decfsz	DUMMY4,f
	goto	DelayLp	
	return
Delay2	clrf	DUMMY3		; Delay for scanning LED 7 segments	
	decfsz	DUMMY3,f
	goto	$-1	
	return	
Disp	movf	NUM1,w		; Load data to DSP1		
	call	Table_		; Convert
	btfsc	HALF,0		; Show a half degree on dot-point LED
	addlw	0x80
	call	Send_Dat		; Send data to LED 7 segments
	bcf	PORTB,6		; ON DSP1 Display 
	call	Delay2
	bsf	PORTB,6
	movf	NUM2,w		; Load data to DSP2
	bcf	PORTB,7		; On DSP2
	call	Delay2
	bsf	PORTB,7		; Off DSP2
	return
Send_Dat movwf	SEND		; Load data
	movlw	0x08		; Loop 8 times for sending 8-bit data
	movwf	COUNT
Chk_Bit	bcf	DAT_PIN		; 
	btfsc	SEND,7		; Check bit 7 "0" or "1"	
	bsf	DAT_PIN		; Send bit 7 to shift register
Clock	bsf	CLK		; Clock pulse
	bcf	CLK		
Rotate	rlf	SEND,f		; Rotate bit for sending next bit
	decfsz	COUNT,f		; Test loop 8 times ?
	goto	Chk_Bit		; If no, send bit again
Latch	bsf	LATCH		; Latch data for displaying
	bcf	LATCH
	return	
;	Macro for DS1820					      *
DQLOW	macro
	bcf	DQ		; DQ bit ready
	bsf	STATUS,RP0
	bcf	DQ		; Set DQ to output
	bcf	STATUS,RP0
	endm
DQHIZ	macro
	bsf	STATUS,RP0
	bsf	DQ		; Set DQ to input
	bcf	STATUS,RP0
	endm
PAUSE	macro	DELAY		; Generate delay time
	movlw	DELAY
	movwf	DUMMY0
	call	Delay5
	endm
;    	DS1820 1-Wire bus                                             *
RD_Temp	call	DS_Rx		; Check chip status
	addlw	0x01		
	btfss	STATUS,Z	; Z set = ready
	return			; W is not zero = not ready
Get_Temp call	DS_Reset
	movlw	0xcc		; Skip ROM
	call	DS_Tx
	movlw	0xbe		; Read scratch pad RAM of DS1820
	call	DS_Tx
	call	DS_Rx		; Read 8-bit data 
	movwf	DS_DAT
	call	DS_Reset	; Restart
	call	DS_Tx
	movlw	0x44		; Start conversion
	call	DS_Tx
Delay5	nop			; Delay for PAUSE  macro
	nop	
	decfsz	DUMMY0,f
	goto	Delay5
	return
DS_Reset DQLOW
	PAUSE	0x77		; 600 microcsecond delay
	DQHIZ
	PAUSE	0x0c		; Wait  for response pulse (67 microsecond)
	nop
	nop
	movf	PORTA,w		; Read response
	andlw	0x01		; Use RA0 only
	movwf	DUMMY1
	PAUSE	0x3b		; 300 microcsecond delay
	movf	DUMMY1,w	; Response in W
	return
DS_Tx	movwf	DUMMY2		; Transmission data 
	movlw	0x08		; Prepare 8-bit counter for sending data
	movwf	DUMMY1		; Define loop counter
Tx_Loop	DQLOW			; Macro of DQ pin to low, This is start bit
	PAUSE	0x01		; 10 microsecond delay
	rrf	DUMMY2,f	; Rotate data to Carry flag
	btfsc	STATUS,C	; Test Carry flag
	bsf	DQ		; If Carry flag = "1" , set DQ to high
	PAUSE	0x0d		; 70 microsecond delay
	DQHIZ
	nop
	decfsz	DUMMY1,f	; 8 times ?
	goto	Tx_Loop		; No, send again
	return
DS_Rx	movlw	0x08		; Recieve 8-bit data
	movwf	DUMMY1
Rx_Loop	DQLOW			; Macro of DQ pin to low, this is start bit
	DQHIZ			; Back to high for receiving
	nop
	nop
	movf	PORTA,w		; Read data
	andlw	0x01		; Get data bit 0 only
	addlw	0xff		; Move data bit 0 to Carry flag with addition method
	rrf	DUMMY2,f	; Move data bit 0 to DUMMY bit 7
	PAUSE	0x0b		; 60 microsecond delay
	decfsz	DUMMY1,f	; Loop 8 times
	goto	Rx_Loop		; Read again
	movf	DUMMY2,w	; Save data to W register
	return
;    	Convert Hex to  Decimal	(3 Digit)			      *
Convert	clrf	NUM2		; Clear register of 10's unit
Check	movlw	0x0A		; 
	subwf	DATA1,w		; Subtract with 10 until lower 10
	btfss	STATUS,C	; Check subtraction result lower 10 ?
	goto	Less1		; If yes then return
	incf	NUM2,f		; If no, increase 10's unit value 
	movlw	0x0A		;  
	subwf	DATA1,f		;  Subtract with 10 until lower 10 and check result again 
	goto	Check
Less1	movf	DATA1,w		; 
	movwf	NUM1		; Send data to 1's unit display
	clrf	NUM3		; Check hundred unit
Check2	movlw	0x0A
	subwf	NUM2,w		; 
	btfss	STATUS,C	; 10's unit over 10 ?
	return			; If no then return
	incf	NUM3,f
	movlw	0x0A		; If yes, subtract again and check until the result is lower 10
	subwf	NUM2,f		
	goto	Check2
	end
