//////// Standard Header file for the PIC16F887 device ////////////////
#device PIC16F887
#nolist
//////// Program memory: 8192x14  Data RAM: 367  Stack: 8
//////// I/O: 36   Analog Pins: 14
//////// Data EEPROM: 256
//////// C Scratch area: 77   ID Location: 2000
//////// Fuses: LP,XT,HS,EC_IO,INTRC_IO,INTRC,RC_IO,RC,NOWDT,WDT,NOPUT,PUT
//////// Fuses: NOMCLR,MCLR,NOPROTECT,PROTECT,NOCPD,CPD,NOBROWNOUT,BROWNOUT
//////// Fuses: BROWNOUT_NOSL,BROWNOUT_SW,NOIESO,IESO,NOFCMEN,FCMEN,NOLVP
//////// Fuses: LVP,NODEBUG,DEBUG,WRT,NOWRT,BORV40,BORV21
////////////////////////////////////////////////////////////////// I/O
// Discrete I/O Functions: SET_TRIS_x(), OUTPUT_x(), INPUT_x(),
//                         PORT_x_PULLUPS(), INPUT(),
//                         OUTPUT_LOW(), OUTPUT_HIGH(),
//                         OUTPUT_FLOAT(), OUTPUT_BIT()
// Constants used to identify pins in the above are:
#define PIN_A0  40
#define PIN_A1  41
#define PIN_A2  42
#define PIN_A3  43
#define PIN_A4  44
#define PIN_A5  45
#define PIN_A6  46
#define PIN_A7  47
#define PIN_B0  48
#define PIN_B1  49
#define PIN_B2  50
#define PIN_B3  51
#define PIN_B4  52
#define PIN_B5  53
#define PIN_B6  54
#define PIN_B7  55
#define PIN_C0  56
#define PIN_C1  57
#define PIN_C2  58
#define PIN_C3  59
#define PIN_C4  60
#define PIN_C5  61
#define PIN_C6  62
#define PIN_C7  63
#define PIN_D0  64
#define PIN_D1  65
#define PIN_D2  66
#define PIN_D3  67
#define PIN_D4  68
#define PIN_D5  69
#define PIN_D6  70
#define PIN_D7  71
#define PIN_E0  72
#define PIN_E1  73
#define PIN_E2  74
#define PIN_E3  75
////////////////////////////////////////////////////////////////// Useful defines
#define FALSE 0
#define TRUE 1
#define BYTE int8
#define BOOLEAN int1
#define getc getch
#define fgetc getch
#define getchar getch
#define putc putchar
#define fputc putchar
#define fgets gets
#define fputs puts
////////////////////////////////////////////////////////////////// Control
// Control Functions:  RESET_CPU(), SLEEP(), RESTART_CAUSE()
// Constants returned from RESTART_CAUSE() are:
#define WDT_FROM_SLEEP  3     
#define WDT_TIMEOUT     11    
#define MCLR_FROM_SLEEP 19    
#define MCLR_FROM_RUN   27    
#define NORMAL_POWER_UP 25    
#define BROWNOUT_RESTART 26   
////////////////////////////////////////////////////////////////// Timer 0
// Timer 0 (AKA RTCC)Functions: SETUP_COUNTERS() or SETUP_TIMER_0(),
//                              SET_TIMER0() or SET_RTCC(),
//                              GET_TIMER0() or GET_RTCC()
// Constants used for SETUP_TIMER_0() are:
#define T0_INTERNAL   0
#define T0_EXT_L_TO_H 32
#define T0_EXT_H_TO_L 48
#define T0_DIV_1      8
#define T0_DIV_2      0
#define T0_DIV_4      1
#define T0_DIV_8      2
#define T0_DIV_16     3
#define T0_DIV_32     4
#define T0_DIV_64     5
#define T0_DIV_128    6
#define T0_DIV_256    7
#define T0_8_BIT      0     
#define RTCC_INTERNAL   0      // The following are provided for compatibility
#define RTCC_EXT_L_TO_H 32     // with older compiler versions
#define RTCC_EXT_H_TO_L 48
#define RTCC_DIV_1      8
#define RTCC_DIV_2      0
#define RTCC_DIV_4      1
#define RTCC_DIV_8      2
#define RTCC_DIV_16     3
#define RTCC_DIV_32     4
#define RTCC_DIV_64     5
#define RTCC_DIV_128    6
#define RTCC_DIV_256    7
#define RTCC_8_BIT      0     
// Constants used for SETUP_COUNTERS() are the above
// constants for the 1st param and the following for
// the 2nd param:
////////////////////////////////////////////////////////////////// WDT
// Watch Dog Timer Functions: SETUP_WDT() or SETUP_COUNTERS() (see above)
//                            RESTART_WDT()
// WDT base is 18ms
#define WDT_18MS        8   
#define WDT_36MS        9   
#define WDT_72MS       10   
#define WDT_144MS      11   
#define WDT_288MS      12   
#define WDT_576MS      13   
#define WDT_1152MS     14   
#define WDT_2304MS     15   
// One of the following may be OR'ed in with the above:
#define WDT_ON             0x4100   
#define WDT_OFF            0       
#define WDT_DIV_16         0x100
#define WDT_DIV_8          0x300
#define WDT_DIV_4          0x500
#define WDT_DIV_2          0x700
#define WDT_TIMES_1        0x900  // Default
#define WDT_TIMES_2        0xB00
#define WDT_TIMES_4        0xD00
#define WDT_TIMES_8        0xF00
#define WDT_TIMES_16      0x1100
#define WDT_TIMES_32      0x1300
#define WDT_TIMES_64      0x1500
#define WDT_TIMES_128     0x1700
////////////////////////////////////////////////////////////////// Timer 1
// Timer 1 Functions: SETUP_TIMER_1, GET_TIMER1, SET_TIMER1
// Constants used for SETUP_TIMER_1() are:
//      (or (via |) together constants from each group)
#define T1_DISABLED         0
#define T1_INTERNAL         5
#define T1_EXTERNAL         7
#define T1_EXTERNAL_SYNC    3
#define T1_CLK_OUT          8
#define T1_DIV_BY_1         0
#define T1_DIV_BY_2         0x10
#define T1_DIV_BY_4         0x20
#define T1_DIV_BY_8         0x30
#define T1_GATE           0x40
#define T1_GATE_INVERTED  0xC0
////////////////////////////////////////////////////////////////// Timer 2
// Timer 2 Functions: SETUP_TIMER_2, GET_TIMER2, SET_TIMER2
// Constants used for SETUP_TIMER_2() are:
#define T2_DISABLED         0
#define T2_DIV_BY_1         4
#define T2_DIV_BY_4         5
#define T2_DIV_BY_16        6
////////////////////////////////////////////////////////////////// CCP
// CCP Functions: SETUP_CCPx, SET_PWMx_DUTY
// CCP Variables: CCP_x, CCP_x_LOW, CCP_x_HIGH
// Constants used for SETUP_CCPx() are:
#define CCP_OFF                         0
#define CCP_CAPTURE_FE                  4
#define CCP_CAPTURE_RE                  5
#define CCP_CAPTURE_DIV_4               6
#define CCP_CAPTURE_DIV_16              7
#define CCP_COMPARE_SET_ON_MATCH        8
#define CCP_COMPARE_CLR_ON_MATCH        9
#define CCP_COMPARE_INT                 0xA
#define CCP_COMPARE_RESET_TIMER         0xB
#define CCP_PWM                         0xC
#define CCP_PWM_PLUS_1                  0x1c
#define CCP_PWM_PLUS_2                  0x2c
#define CCP_PWM_PLUS_3                  0x3c
#word   CCP_1    =                      getenv("SFR:CCPR1L")
#byte   CCP_1_LOW=                      getenv("SFR:CCPR1L")
#byte   CCP_1_HIGH=                     getenv("SFR:CCPR1H")
// The following should be used with the ECCP unit only (or these in)
#define CCP_PWM_H_H                     0x0c
#define CCP_PWM_H_L                     0x0d
#define CCP_PWM_L_H                     0x0e
#define CCP_PWM_L_L                     0x0f
#define CCP_PWM_FULL_BRIDGE             0x40
#define CCP_PWM_FULL_BRIDGE_REV         0xC0
#define CCP_PWM_HALF_BRIDGE             0x80
#define CCP_SHUTDOWN_ON_COMP1           0x100000
#define CCP_SHUTDOWN_ON_COMP2           0x200000
#define CCP_SHUTDOWN_ON_COMP            0x300000
#define CCP_SHUTDOWN_ON_INT0            0x400000
#define CCP_SHUTDOWN_ON_COMP1_INT0      0x500000
#define CCP_SHUTDOWN_ON_COMP2_INT0      0x600000
#define CCP_SHUTDOWN_ON_COMP_INT0       0x700000
#define CCP_SHUTDOWN_AC_L               0x000000
#define CCP_SHUTDOWN_AC_H               0x040000
#define CCP_SHUTDOWN_AC_F               0x080000
#define CCP_SHUTDOWN_BD_L               0x000000
#define CCP_SHUTDOWN_BD_H               0x010000
#define CCP_SHUTDOWN_BD_F               0x020000
#define CCP_SHUTDOWN_RESTART            0x80000000
#define CCP_PULSE_STEERING_A            0x01000000
#define CCP_PULSE_STEERING_B            0x02000000
#define CCP_PULSE_STEERING_C            0x04000000
#define CCP_PULSE_STEERING_D            0x08000000
#define CCP_PULSE_STEERING_SYNC         0x10000000
#word   CCP_2    =                      getenv("SFR:CCPR2L")
#byte   CCP_2_LOW=                      getenv("SFR:CCPR2L")
#byte   CCP_2_HIGH=                     getenv("SFR:CCPR2H")
////////////////////////////////////////////////////////////////// SPI
// SPI Functions: SETUP_SPI, SPI_WRITE, SPI_READ, SPI_DATA_IN
// Constants used in SETUP_SPI() are:
#define SPI_MASTER       0x20
#define SPI_SLAVE        0x24
#define SPI_L_TO_H       0
#define SPI_H_TO_L       0x10
#define SPI_CLK_DIV_4    0
#define SPI_CLK_DIV_16   1
#define SPI_CLK_DIV_64   2
#define SPI_CLK_T2       3
#define SPI_SS_DISABLED  1
#define SPI_SAMPLE_AT_END 0x8000
#define SPI_XMIT_L_TO_H  0x4000
////////////////////////////////////////////////////////////////// UART
// Constants used in setup_uart() are:
// FALSE - Turn UART off
// TRUE  - Turn UART on
#define UART_ADDRESS           2
#define UART_DATA              4
#define UART_AUTODETECT        8
#define UART_AUTODETECT_NOWAIT 9
#define UART_WAKEUP_ON_RDA     10
#define UART_SEND_BREAK        13
////////////////////////////////////////////////////////////////// COMP
// Comparator Variables: C1OUT, C2OUT
// Constants used in setup_comparator() are:
#define NC_NC_NC_NC   0x00
#define NC_NC         0x00
//Pick one constant for COMP1
#define CP1_A0_A3     0x00090080
#define CP1_A1_A3     0x000A0081
#define CP1_B3_A3     0x00880082
#define CP1_B1_A3     0x00280083
#define CP1_A0_VREF   0x00010084
#define CP1_A1_VREF   0x00020085
#define CP1_B3_VREF   0x00800086
#define CP1_B1_VREF   0x00200087
//Optionally OR with one or both of the following
#define CP1_OUT_ON_A4 0x00000020
#define CP1_INVERT    0x00000010
#define CP1_ABSOLUTE_VREF  0x20000000
//OR with one constant for COMP2
#define CP2_A0_A2     0x00058000
#define CP2_A1_A2     0x00068100
#define CP2_B3_A2     0x00848200
#define CP2_B1_A2     0x00248300
#define CP2_A0_VREF   0x00018400
#define CP2_A1_VREF   0x00028500
#define CP2_B3_VREF   0x00808600
#define CP2_B1_VREF   0x00208700
#define CP2_OUT_ON_A5 0x00002000
#define CP2_INVERT    0x00001000
#define CP2_ABSOLUTE_VREF  0x10000000
#define CP2_T1_SYNC   0x01000000
#define CP2_T1_GATE   0x02000000
#bit C1OUT = 0x107.6
#bit C2OUT = 0x108.6
////////////////////////////////////////////////////////////////// VREF
// Constants used in setup_vref() are:
#define VREF_LOW  0xa0
#define VREF_HIGH 0x80
// Or (with |) the above with a number 0-15
////////////////////////////////////////////////////////////////// INTERNAL RC
// Constants used in setup_oscillator() are:
#define OSC_31KHZ   1
#define OSC_125KHZ  0x11
#define OSC_250KHZ  0x21
#define OSC_500KHZ  0x31
#define OSC_1MHZ    0x41
#define OSC_2MHZ    0x51
#define OSC_4MHZ    0x61
#define OSC_8MHZ    0x71
#define OSC_INTRC   1
#define OSC_NORMAL  0
// Result may be (ignore all other bits)
#define OSC_STATE_STABLE 4
#define OSC_31KHZ_STABLE 2
////////////////////////////////////////////////////////////////// ADC
// ADC Functions: SETUP_ADC(), SETUP_ADC_PORTS() (aka SETUP_PORT_A),
//                SET_ADC_CHANNEL(), READ_ADC()
// Constants used for SETUP_ADC() are:
#define ADC_OFF                0          // ADC Off
#define ADC_CLOCK_DIV_2    0x100
#define ADC_CLOCK_DIV_8     0x40
#define ADC_CLOCK_DIV_32    0x80
#define ADC_CLOCK_INTERNAL  0xc0          // Internal 2-6us
// Constants used in SETUP_ADC_PORTS() are:
#define sAN0            1       //| A0
#define sAN1            2       //| A1
#define sAN2            4       //| A2
#define sAN3            8       //| A3
#define sAN4            16      //| A5
#define sAN5            32      //| E0
#define sAN6            64      //| E1
#define sAN7            128     //| E2
#define sAN8        0x10000     //| B2
#define sAN9        0x20000     //| B3
#define sAN10       0x40000     //| B1
#define sAN11       0x80000     //| B4
#define sAN12      0x100000     //| B0
#define sAN13      0x200000     //| B5
#define NO_ANALOGS      0       // None
#define ALL_ANALOG   0x1F00FF    // A0 A1 A2 A3 A5 E0 E1 E2 B0 B1 B2 B3 B4 B5
// One of the following may be OR'ed in with the above using |
#define VSS_VDD              0x0000        //| Range 0-Vdd
#define VSS_VREF             0x1000        //| Range 0-Vref
#define VREF_VREF            0x3000        //| Range Vref-Vref
#define VREF_VDD             0x2000        //| Range Vref-Vdd
// Constants used in READ_ADC() are:
#define ADC_START_AND_READ     7   // This is the default if nothing is specified
#define ADC_START_ONLY         1
#define ADC_READ_ONLY          6
// Interrupt Functions: ENABLE_INTERRUPTS(), DISABLE_INTERRUPTS(),
//                      CLEAR_INTERRUPT(), INTERRUPT_ACTIVE(),
//                      EXT_INT_EDGE()
// Constants used in EXT_INT_EDGE() are:
#define L_TO_H              0x40
#define H_TO_L                 0
// Constants used in ENABLE/DISABLE_INTERRUPTS() are:
#define GLOBAL                    0x0BC0
#define INT_RTCC                  0x000B20
#define INT_RB                    0x01FF0B08
#define INT_EXT_L2H               0x50000B10
#define INT_EXT_H2L               0x60000B10
#define INT_EXT                   0x000B10
#define INT_AD                    0x008C40
#define INT_TBE                   0x008C10
#define INT_RDA                   0x008C20
#define INT_TIMER1                0x008C01
#define INT_TIMER2                0x008C02
#define INT_CCP1                  0x008C04
#define INT_CCP2                  0x008D01
#define INT_SSP                   0x008C08
#define INT_BUSCOL                0x008D08
#define INT_EEPROM                0x008D10
#define INT_TIMER0                0x000B20
#define INT_OSC_FAIL              0x008D80
#define INT_COMP                  0x008D20
#define INT_COMP2                 0x008D40
#define INT_ULPWU                 0x008D04
#define INT_RB0                   0x0010B08
#define INT_RB1                   0x0020B08
#define INT_RB2                   0x0040B08
#define INT_RB3                   0x0080B08
#define INT_RB4                   0x0100B08
#define INT_RB5                   0x0200B08
#define INT_RB6                   0x0400B08
#define INT_RB7                   0x0800B08
#list
