HWiNFO32 v3.71-1190
Creation Time31.03.2011 19:19
MS-COMPUTER
[Current Computer]
Computer Name:MS-COMPUTER
Computer Brand Name:Hewlett-Packard Pavilion ze4400 (DK581A)
[Operating System]
Operating System:Microsoft Windows XP Professional Build 2600
Service Pack:Szervizcsomag 2
Central Processor(s)
[CPU Unit Count]
Number Of Processor Packages (Physical):1
Number Of Processors Cores:1
Number Of Logical Processors:1
Mobile AMD Athlon XP XP2200+
[General Information]
Processor Name:Mobile AMD Athlon XP XP2200+
Current Processor Frequency:1788.9 MHz
Current Processor Frequency [MHz]:1789
CPU ID:00000681
Extended CPU ID:00000781
CPU Brand Name:mobile AMD Athlon(tm) XP2200+
CPU Vendor:AuthenticAMD
CPU Stepping:B0
CPU Code Name:Thoroughbred
Number of CPU Cores:1
Number of Logical CPUs:1
[Operating Points]
CPU Current:1788.9 MHz = 13.50 x 132.5 MHz
CPU Bus Type:FSB (DDR)
[Cache and TLB]
L1 Cache:Instruction: 64 KBytes, Data: 64 KBytes
L2 Cache:Integrated: 256 KBytes
Instruction TLB:Fully associative, 16 entries
Data TLB:Fully associative, 32 entries
[Standard Feature Flags]
FPU on ChipPresent
Enhanced Virtual-86 ModePresent
I/O BreakpointsPresent
Page Size ExtensionsPresent
Time Stamp CounterPresent
Pentium-style Model Specific RegistersPresent
Physical Address ExtensionPresent
Machine Check ExceptionPresent
CMPXCHG8B InstructionPresent
APIC On Chip / PGE (AMD)Not Present
Fast System CallPresent
Memory Type Range RegistersPresent
Page Global FeaturePresent
Machine Check ArchitecturePresent
CMOV InstructionPresent
Page Attribute TablePresent
36-bit Page Size ExtensionsPresent
Processor NumberNot Present
CLFLUSH InstructionNot Present
Debug Trace and EMON StoreNot Present
Internal ACPI SupportNot Present
MMX TechnologyPresent
Fast FP Save/Restore (IA MMX-2)Present
Streaming SIMD ExtensionsPresent
Streaming SIMD Extensions 2Not Present
Self-SnoopNot Present
Multi-Threading CapableNot Present
Automatic Clock ControlNot Present
IA-64 ProcessorNot Present
Signal Break on FERRNot Present
Streaming SIMD Extensions 3Not Present
PCLMULQDQ Instruction SupportNot Present
MONITOR/MWAIT SupportNot Present
Supplemental Streaming SIMD Extensions 3Not Present
FMA ExtensionNot Present
CMPXCHG16B SupportNot Present
Streaming SIMD Extensions 4.1Not Present
Streaming SIMD Extensions 4.2Not Present
x2APICNot Present
POPCNT InstructionNot Present
AES Cryptography SupportNot Present
XSAVE/XRSTOR/XSETBV/XGETBV InstructionsNot Present
XGETBV/XSETBV OS EnabledNot Present
AVX SupportNot Present
Half-Precision Convert (CVT16)Not Present
[Extended Feature Flags]
FPU on ChipPresent
AMD-style Model Specific RegistersPresent
APIC On ChipNot Present
SYSCALL and SYSRET InstructionsPresent
Multi-Processing / Brand featurePresent
No ExecuteNot Present
MMX+ ExtensionsPresent
Fast FP Save/RestorePresent
Fast FP Save/Restore OptimizationsNot Present
1 GB large page supportNot Present
RDTSCP InstructionNot Present
x86-64 Long ModeNot Present
3DNow! Technology ExtensionsPresent
3DNow! TechnologyPresent
LAHF/SAHF Long Mode SupportNot Present
Core Multi-Processing Legacy ModeNot Present
Secure Virtual MachineNot Present
Extended APIC Register SpaceNot Present
LOCK MOV CR0 SupportNot Present
Advanced Bit ManipulationNot Present
SSE4A SupportNot Present
Misaligned SSE ModeNot Present
PREFETCH(W) SupportNot Present
OS Visible Work-around SupportNot Present
Instruction Based SamplingNot Present
XOP Instruction SupportNot Present
SKINIT, STGI, and DEV SupportNot Present
Watchdog Timer SupportNot Present
TBM0 Instruction SupportNot Present
Lightweight Profiling SupportNot Present
FMA4 Instruction SupportNot Present
Translation Cache ExtensionNot Present
NodeId SupportNot Present
Trailing Bit ManipulationNot Present
Topology ExtensionsNot Present
Core Performance Counter ExtensionsNot Present
NB Performance Counter ExtensionsNot Present
[Enhanced Features]
Core Performance BoostNot Supported
[Memory Ranges]
Maximum Physical Address Size:34-bit (16 GBytes)
Maximum Virtual Address Size:32-bit (4 GBytes)
[MTRRs]
Range 0-20000000 (0MB-512MB) Type:Write Back (WB)
Range 20000000-28000000 (512MB-640MB) Type:Write Back (WB)
Range 28000000-2C000000 (640MB-704MB) Type:Write Back (WB)
Motherboard
[Computer]
[Motherboard]
Motherboard Model:Hewlett-Packard 0024
Motherboard Chipset:ATI IGP-320M (U2) + M1533
Motherboard Slots:1xPCI, 1xAGP v2.0
USB Version Supported:v1.0
[BIOS]
BIOS Manufacturer:Phoenix Technologies
BIOS Date:05/04/05
BIOS Version:KAM1.60
EFI BIOSNot Capable
Super-IO/LPC Chip:Unknown
Plug-and-Play System Nodes
Motherboard Resources
Node Number:0
Device ID:PNP0C02
Device Name:Motherboard Resources
Device Type Code:088000
[System Resources]
I/O Port:0080
I/O Port:0370
Memory Location:FFFC0000-FFFFFFFF
[Flags]
Removable Device:Not Present
Docking:Not Supported
IPL:Not Supported
Primary Input Device:Not Capable
Primary Output Device:Not Capable
Configurable Device:Not Supported
Disableable Device:Not Supported
System Board Extension
Node Number:1
Device ID:PNP0C01
Device Name:System Board Extension
Device Type Code:050000
[System Resources]
Memory Location:00000000-0009FFFF
Memory Location:000E4000-000FFFFF
Memory Location:00100000-2BEFFFFF
[Flags]
IPL:Not Supported
DMA Controller
Node Number:2
Device ID:PNP0200
Device Name:DMA Controller
Device Type Code:080101
[System Resources]
DMA:4
I/O Port:0000
I/O Port:0081
I/O Port:00C0
[Flags]
IPL:Not Supported
Programmable Interrupt Controller
Node Number:3
Device ID:PNP0000
Device Name:Programmable Interrupt Controller
Device Type Code:080001
[System Resources]
IRQ:2
I/O Port:0020
I/O Port:00A0
[Flags]
IPL:Not Supported
System Timer
Node Number:4
Device ID:PNP0100
Device Name:System Timer
Device Type Code:080201
[System Resources]
IRQ:0
I/O Port:0040
[Flags]
IPL:Not Supported
RealTime Clock
Node Number:5
Device ID:PNP0B00
Device Name:RealTime Clock
Device Type Code:080301
[System Resources]
IRQ:8
I/O Port:0070
[Flags]
IPL:Not Supported
101/102-Key or MS Natural Keyboard
Node Number:6
Device ID:PNP0303
Device Name:101/102-Key or MS Natural Keyboard
Device Type Code:090000
[System Resources]
IRQ:1
I/O Port:0060
I/O Port:0064
[Flags]
IPL:Not Supported
Numeric Data Processor
Node Number:7
Device ID:PNP0C04
Device Name:Numeric Data Processor
Device Type Code:0B8000
[System Resources]
IRQ:13
I/O Port:00F0
[Flags]
IPL:Not Supported
PC Speaker
Node Number:8
Device ID:PNP0800
Device Name:PC Speaker
Device Type Code:040100
[System Resources]
I/O Port:0061
[Flags]
IPL:Not Supported
Node Number:9
Device ID:PNP0C02
[System Resources]
Memory Location:000DC000
[Flags]
IPL:Not Supported
PCI Bus
Node Number:10
Device ID:PNP0A03
Device Name:PCI Bus
Device Type Code:060400
[System Resources]
I/O Port:0CF8
[Flags]
IPL:Not Supported
Node Number:11
Device ID:PNP0C02
Device Type Code:060100
[System Resources]
I/O Port:04D0
I/O Port:0092
I/O Port:040B
I/O Port:0480
I/O Port:04D6
I/O Port:8000
I/O Port:8040
[Flags]
IPL:Not Supported
Node Number:12
Device ID:PNP0C02
[System Resources]
Memory Location:000DB000
[Flags]
IPL:Not Supported
Node Number:13
Device ID:PNP0C02
[System Resources]
Memory Location:000CF800-000CFFFF
[Flags]
IPL:Not Supported
16550A-compatible UART Serial Port
Node Number:14
Device ID:PNP0501
Device Name:16550A-compatible UART Serial Port
Device Type Code:070002
[System Resources]
IRQ:4
I/O Port:03F8
[Flags]
IPL:Not Supported
Configurable Device:Supported
Disableable Device:Supported
Logitech PS/2 Port Mouse
Node Number:16
Device ID:PNP0F13
Device Name:Logitech PS/2 Port Mouse
Device Type Code:090200
[System Resources]
IRQ:12
[Flags]
IPL:Not Supported
Primary Input Device:Capable
Floppy Controller
Node Number:17
Device ID:PNP0700
Device Name:Floppy Controller
Device Type Code:010200
[System Resources]
IRQ:6
DMA:2
I/O Port:03F0
I/O Port:03F7
[Flags]
IPL:Supported
ECP Parallel Port
Node Number:19
Device ID:PNP0401
Device Name:ECP Parallel Port
Device Type Code:070102
[System Resources]
IRQ:7
DMA:0
I/O Port:0378
I/O Port:0778
[Flags]
IPL:Not Supported
ACPI Devices
Microsoft AC-adapter
Device Name:Microsoft AC-adapter
AMD K7 processzor
Device Name:AMD K7 processzor
ACPI-beépített lehetőség gombja
Device Name:ACPI-beépített lehetőség gombja
HP konfigurációs illesztő
Device Name:HP konfigurációs illesztő
Programozható megszakításvezérlő
Device Name:Programozható megszakításvezérlő
[Assigned Resources]
I/O Port:0020 - 0021
I/O Port:00A0 - 00A1
[Alternative 1]
Rendszeridőzítő
Device Name:Rendszeridőzítő
I/O Port:0040 - 0043
IRQ:0
[Alternative 1]
IRQ:0
DMA-vezérlő
Device Name:DMA-vezérlő
I/O Port:0000 - 000F
I/O Port:0081 - 008F
I/O Port:00C0 - 00DF
DMA:4
[Alternative 1]
DMA:4
Szabványos 101/102 gombos vagy Microsoft Natural PS/2 billentyűzet
Device Name:Szabványos 101/102 gombos vagy Microsoft Natural PS/2 billentyűzet
I/O Port:0060
I/O Port:0064
IRQ:1
[Alternative 1]
I/O Port:0060
I/O Port:0064
IRQ:1
ECP nyomtatóport
Device Name:ECP nyomtatóport
I/O Port:0378 - 037F
I/O Port:0778 - 077F
IRQ:7
DMA:0
[Alternative 1]
IRQ:5
DMA:0
[Alternative 2]
I/O Port:0278 - 027F
I/O Port:0678 - 067F
IRQ:5
DMA:0
[Alternative 3]
I/O Port:03BC - 03BF
I/O Port:07BC - 07BF
IRQ:5
DMA:0
[Alternative 4]
IRQ:7
DMA:0
[Alternative 5]
IRQ:7
DMA:0
[Alternative 6]
IRQ:7
DMA:0
[Alternative 7]
IRQ:5
DMA:1
[Alternative 8]
IRQ:5
DMA:1
[Alternative 9]
IRQ:5
DMA:1
[Alternative 10]
IRQ:7
DMA:1
[Alternative 11]
IRQ:7
DMA:1
[Alternative 12]
IRQ:7
DMA:1
[Alternative 13]
IRQ:5
DMA:3
[Alternative 14]
IRQ:5
DMA:3
[Alternative 15]
IRQ:5
DMA:3
[Alternative 16]
IRQ:7
DMA:3
[Alternative 17]
IRQ:7
DMA:3
[Alternative 18]
IRQ:7
DMA:3
Kommunikációs port
Device Name:Kommunikációs port
I/O Port:03F8 - 03FF
IRQ:4
[Alternative 1]
IRQ:4
[Alternative 2]
I/O Port:02F8 - 02FF
IRQ:3
[Alternative 3]
I/O Port:03E8 - 03EF
IRQ:4
[Alternative 4]
I/O Port:02E8 - 02EF
IRQ:3
[Alternative 5]
IRQ:3
[Alternative 6]
IRQ:4
[Alternative 7]
IRQ:3
[Alternative 8]
IRQ:4
Szabványos hajlékonylemez-vezérlő
Device Name:Szabványos hajlékonylemez-vezérlő
I/O Port:03F0 - 03F5
I/O Port:03F7
IRQ:6
DMA:2
[Alternative 1]
I/O Port:03F7
IRQ:6
DMA:2
Rendszerhangszóró
Device Name:Rendszerhangszóró
I/O Port:0061
[Alternative 1]
I/O Port:0061
PCI busz
Device Name:PCI busz
I/O Port:0000 - 0CF7
I/O Port:0D00 - FFFF
Memory Location:000A0000 - 000BFFFF
Memory Location:000A0000 - 000CEFFF
Memory Location:000C0000 - 000C3FFF
Memory Location:000C4000 - 000C7FFF
Memory Location:000C8000 - 000CBFFF
Memory Location:000CC000 - 000CFFFF
Memory Location:000D0000 - 000D7FFF
Memory Location:2C000000 - FFF7FFFF
[Alternative 1]
Általános busz
Device Name:Általános busz
Bővített IO-busz
Device Name:Bővített IO-busz
A rendszer CMOS/valós idejű órája
Device Name:A rendszer CMOS/valós idejű órája
I/O Port:0070 - 0073
IRQ:8
[Alternative 1]
IRQ:8
Rendszerlap
Device Name:Rendszerlap
Alaplap erőforrásai
Device Name:Alaplap erőforrásai
I/O Port:0080
I/O Port:00B0 - 00B3
I/O Port:0092
I/O Port:040B
I/O Port:0480 - 048F
I/O Port:04D0 - 04D1
I/O Port:04D6
I/O Port:8000 - 807F
I/O Port:FF00 - FF01
I/O Port:8004 - 8005
I/O Port:FE00 - FEFE
Memory Location:D0400000 - D0400FFF
[Alternative 1]
I/O Port:0080
I/O Port:0092
I/O Port:040B
I/O Port:04D6
Numerikus adatprocesszor
Device Name:Numerikus adatprocesszor
I/O Port:00F0 - 00FE
IRQ:13
[Alternative 1]
IRQ:13
Microsoft ACPI szabványnak megfelelő beágyazott vezérlő
Device Name:Microsoft ACPI szabványnak megfelelő beágyazott vezérlő
I/O Port:0062
I/O Port:0066
[Alternative 1]
I/O Port:0062
I/O Port:0066
Microsoft ACPI szabványnak megfelelő vezérlőmódú telep
Device Name:Microsoft ACPI szabványnak megfelelő vezérlőmódú telep
ACPI-bekapcsológomb
Device Name:ACPI-bekapcsológomb
ACPI fedője
Device Name:ACPI fedője
SCSI/RAID Host Controller
Device Name:SCSI/RAID Host Controller
[Alternative 1]
I/O Port:0010 - FFF0
IRQ:0 - -1
PS/2-kompatibilis egér
Device Name:PS/2-kompatibilis egér
IRQ:12
[Alternative 1]
IRQ:12
ACPI-termikus zóna
Device Name:ACPI-termikus zóna
SMBIOS DMI
BIOS
BIOS Vendor:Phoenix Technologies Ltd.
BIOS Release Date:05/04/2005
BIOS Start Segment:E468
BIOS Size:512 KBytes
ISA Support:Present
MCA Support:Not Present
EISA Support:Not Present
PCI Support:Present
PC Card (PCMCIA) Support:Present
Plug-and-Play Support:Present
APM Support:Not Present
Flash BIOS:Present
BIOS Shadow:Present
VL-VESA Support:Not Present
ESCD Support:Present
Boot from CD:Present
Selectable Boot:Present
BIOS ROM Socketed:Present
Boot from PC Card:Present
EDD Support:Present
NEC PC-98 Support:Not Present
ACPI Support:Present
USB Legacy Support:Present
AGP Support:Present
I2O Boot Support:Not Present
LS-120 Boot Support:Not Present
ATAPI ZIP Drive Boot Support:Not Present
IEE1394 Boot Support:Not Present
Smart Battery Support:Not Present
System
System Manufacturer:Hewlett-Packard
Product Name:Pavilion ze4400 (DK581A)
Product Version:KAM1.60
Product Serial Number:CNF3291LBV
UUID:{E8A859E0-A9DE-11D7-42BE-439D0D009825}
Mainboard
Mainboard Manufacturer:Hewlett-Packard
Mainboard Name:0024
Mainboard Version:PQ1A84
Mainboard Serial Number:None
System Enclosure
Case Type:Notebook
Version:N/A
Serial Number:None
Asset Tag Number:No Asset Tag
Processor
Processor Manufacturer:AuthenticAMD
Processor Version:AMD Athlon
External Clock:133 MHz
Maximum Clock Supported:1795 MHz
Current Clock:1795 MHz
CPU Socket:Populated
CPU Status:Enabled
Processor Type:Central Processor
Processor Voltage:1.5 V
Processor Upgrade:ZIF
Socket Designation:mPGA462B
Memory Devices
Memory Controller
Error Detecting Method:None
Error Correction:
Supported Interleave:1-Way
Current Interleave:1-Way
Max. Memory Module Size:16 MBytes
Supported Memory Speed:70 ns, 60 ns
Supported Memory Type:FPM, EDO, DIMM, SDRAM
Supported Memory Voltage:3.3 V
Associated Memory Slots:2
DIMM 1
Socket Designation:DIMM 1
Memory Type:DIMM, SDRAM
Memory Speed:60 ns
Installed size:256 MBytes
Enabled size:256 MBytes
DIMM 2
Socket Designation:DIMM 2
Memory Speed:60 ns
Installed size:512 MBytes
Enabled size:512 MBytes
L2 Cache
Socket Designation:L2 Cache
Cache State:Enabled
Cache Type:Internal
Cache Scheme:Write-Back
Supported SRAM Type:Burst, Pipeline Burst
Current SRAM Type:Synchronous
Cache Speed:Unknown
Error Correction Type:Unknown
Maximum Cache Size:1024 KBytes
Installed Cache Size:256 KBytes
Cache Associativity:2-way Set-Associative
Port Connectors
Port Connector
Port Type:Unknown
Internal Reference:Primary IDE
Internal Connector Type:On Board IDE
External Reference:Unknown
External Connector Type:None
Port Connector
Port Type:Unknown
Internal Reference:Secondary IDE
Port Connector
Port Type:Unknown
Internal Reference:FLOPPY
Internal Connector Type:On Board Floppy
Serial Port XT/AT Compatible
Port Type:Serial Port XT/AT Compatible
Internal Reference:Unknown
Internal Connector Type:None
External Reference:COM1
External Connector Type:DB-9 pin male
Port Connector
Port Type:Unknown
External Reference:FIR
External Connector Type:Infrared
Parallel Port ECP/EPP
Port Type:Parallel Port ECP/EPP
External Reference:Printer
External Connector Type:DB25 pin female
Keyboard Port
Port Type:Keyboard Port
External Reference:KBD
External Connector Type:PS/2
Mouse Port
Port Type:Mouse Port
External Reference:Mouse
Port Connector
Port Type:Unknown
Internal Reference:CD_IN
Internal Connector Type:On Board Sound Input from CD-ROM
Audio Port
Port Type:Audio Port
External Reference:MIC_IN
External Connector Type:Mini-jack (headphones)
Audio Port
External Reference:LINE_IN
Audio Port
External Reference:LINE_OUT
USB
Port Type:USB
External Reference:USB1
External Connector Type:Unknown
USB
Port Type:USB
External Reference:USB2
System Slots
PCI Slot 1
Slot Designation:PCI Slot 1
Slot Type:PCI
Slot Usage:Unknown
Slot Data Bus Width:32-bit
Slot Length:Long
On Board Device
Device Description:ALi 1535 Sound
Device Type:Audio Device
Device Status:<Disabled>
OEM Strings
Hewlett-Packard NoteBook Series
Service ID: 13263
$MODEL: DK581
$OS:
$LOCAL: ABA
$OPTION:
$DC:
System Event Log
Physical Memory Array
Array Location:System board
Array Use:System memory
Memory Capacity:1048576 KBytes
Memory Devices:2
Memory Device
Total Width:72 bits
Data Width:64 bits
Device Size:256 MBytes
Device Form Factor:DIMM
Device Locator:M1
Bank Locator:Bank 0
Device Type:DRAM
Device Type Detail:Synchronous
Memory Device
Total Width:72 bits
Data Width:64 bits
Device Size:512 MBytes
Device Locator:M2
Bank Locator:Bank 1
Device Type:DRAM
Memory Array Mapped Address
Starting Address:00000000
Ending Address:000BFFFF
Partition Width:2
Memory Device Mapped Address
Ending Address:0003FFFF
Partition Row Position:1
Interleave Position:Non-interleaved
Interleave Data Depth:0
System Reset
Reset Count:Unknown
Reset Limit:Unknown
Timer interval:Unknown
Timeout:Unknown
Hardware Security
Power-on Password:Disabled
Keyboard Password:Unknown
Administrator Password:Enabled
Front Panel Reset:Unknown
System Power Controls
Voltage Probe
Description:Voltage Probe
Status:OK
Maximum Value:Unknown
Minimum Value:Unknown
Resolution:Unknown
Tolerance:Unknown
Accuracy:Unknown
Cooling Device
Type:Fan
Status:OK
Temperature Probe
Description:Temperature Probe
Status:OK
Resolution:Unknown
Tolerance:Unknown
Accuracy:Unknown
Electrical Current Probe
Description:Electrical Current Probe
Status:OK
Resolution:Unknown
Tolerance:Unknown
Accuracy:Unknown
Out-of-Band Remote Access
Manufacturer:Intel
Inbound Connection:Enabled
Outbound Connection:Disabled
System Boot Information
Boot Status:Unknown
Memory
[General information]
Total Memory Size:768 MBytes
Total Memory Size [MB]:768
[Current Performance Settings]
Current Timing (tCAS-tRCD-tRP-tRAS):2.5-3-3-6
Memory Runs At:Single-Channel
Row: 0 - 256 MB PC2100 DDR-SDRAM Micron Tech. 8VDDT3264HDG-265C3
[General Module Information]
Module Number:0
Module Size:256 MBytes
Memory Type:DDR-SDRAM
Error Check/Correction:None
Memory Speed:133.3 MHz (PC2100)
Module Manufacturer:Micron Tech.
Module Model:8VDDT3264HDG-265C3
Serial Number:819396655
Manufacturing Date:Year: 2003, Week: 28
[Module characteristics]
Module Width:64-bits
Module Voltage:SSTL 2.5V
SPD Revision:N/A
Number Of Rows:2
Row Address Bits:Bank 1: 13, Bank 2: 13
Column Address Bits:Bank 1: 9, Bank 2: 9
Number Of Banks:4
[Module timing]
Supported Burst Lengths:2, 4, 8
Refresh Rate:Reduced 0.5x (7.8 us)
Min. Back-to-Back Clock Delay:1
Supported CAS Latencies (tCAS):2.5, 2.0
Min. RAS-to-CAS Delay (tRCD):20.00 ns
Min. Row Precharge Time (tRP):20.00 ns
Min. RAS Pulse Width (tRAS):45 ns
Supported Module Timing at 133.3 MHz:2.5-3-3-6
Supported Module Timing at 100.0 MHz:2.0-2-2-5
Min. Row-Activate To Row-Activate Delay (tRRD):15.00 ns
Supported CS Latency:0
Supported WE Latency:1
[Features]
Buffered Address/Control Inputs:Not Supported
Registered Address/Control Inputs:Not Supported
On-card PLL For Clock:Not Supported
Buffered DQMB Inputs:Not Supported
Registered DQMB Inputs:Not Supported
Differential Clock Input:Supported
Redundant Row Address:Not Supported
Row: 1 - 512 MB PC3200 DDR-SDRAM
Module Number:1
Module Size:512 MBytes
Memory Speed:200.0 MHz (PC3200)
Module Manufacturer:Unknown
Module Model:
Serial Number:N/A
Manufacturing Date:N/A
SPD Revision:1.0
Number Of Rows:2
Column Address Bits:Bank 1: 10, Bank 2: 10
Number Of Banks:4
[Module timing]
Supported CAS Latencies (tCAS):3.0, 2.5
Min. RAS-to-CAS Delay (tRCD):15.00 ns
Min. Row Precharge Time (tRP):15.00 ns
Min. RAS Pulse Width (tRAS):40 ns
Supported Module Timing at 200.0 MHz:3.0-3-3-8
Supported Module Timing at 166.7 MHz:2.5-3-3-7
Min. Row-Activate To Row-Activate Delay (tRRD):10.00 ns
Supported WE Latency:2
[Features]
Bus
PCI Bus #0
ATI IGP-320(M) Host-to-PCI Bridge (S2K)
Original Device Name:ATI IGP-320(M) Host-to-PCI Bridge (S2K)
Device Class:Host-to-PCI Bridge
Revision ID:13
Bus Number:0
Device Number:0
Function Number:0
PCI Latency Timer:32
Hardware ID:PCI\VEN_1002&DEV_CAB0&SUBSYS_00000000&REV_13
[System Resources]
Interrupt Line:N/A
Interrupt Pin:N/A
Memory Base Address 0D4000000
Memory Base Address 1D0400000
I/O Base Address 28090
[Features]
Bus Mastering:Enabled
Running At 66 MHz:Capable
Fast Back-to-Back Transactions:Not Capable
ATI IGP-320(M) A.G.P. Controller
Original Device Name:ATI IGP-320(M) A.G.P. Controller
Device Class:PCI-to-PCI Bridge
Revision ID:1
Bus Number:0
Device Number:1
Function Number:0
PCI Latency Timer:99
Hardware ID:PCI\VEN_1002&DEV_700F&SUBSYS_00000000&REV_01
[System Resources]
Interrupt Line:N/A
Interrupt Pin:N/A
[Features]
AGP 4x Bus (PCI Bus #1)
ATI IGP-320M (U1) Video Adapter
Original Device Name:ATI IGP-320M (U1) Video Adapter
Device Class:VGA Compatible Adapter
Revision ID:0
Bus Number:1
Device Number:5
Function Number:0
PCI Latency Timer:255
Hardware ID:PCI\VEN_1002&DEV_4336&SUBSYS_0024103C&REV_00
[System Resources]
Interrupt Line:IRQ10
Interrupt Pin:INTA#
Memory Base Address 0E0000000
I/O Base Address 19000
Memory Base Address 2D0100000
[Features]
Fast Back-to-Back Transactions:Capable
ALi/ULi M5237 OHCI USB Host Controller
Original Device Name:ALi/ULi M5237 OHCI USB Host Controller
Device Class:Universal Serial Bus (USB)
Revision ID:3
Bus Number:0
Device Number:2
Function Number:0
PCI Latency Timer:64
Hardware ID:PCI\VEN_10B9&DEV_5237&SUBSYS_0024103C&REV_03
[System Resources]
Interrupt Line:IRQ3
Interrupt Pin:INTA#
Memory Base Address 0D0002000
[Features]
Running At 66 MHz:Not Capable
ALi/ULi M5451 AC'97 Audio Controller
Original Device Name:ALi/ULi M5451 AC'97 Audio Controller
Device Class:Multimedia Audio Adapter
Revision ID:2
Bus Number:0
Device Number:6
Function Number:0
Hardware ID:PCI\VEN_10B9&DEV_5451&SUBSYS_0024103C&REV_02
[System Resources]
Interrupt Line:IRQ5
Interrupt Pin:INTA#
I/O Base Address 08400
Memory Base Address 1D0003000
[Features]
ALi/ULi M1533 PCI-to-ISA Bridge
Original Device Name:ALi/ULi M1533 PCI-to-ISA Bridge
Device Class:PCI-to-ISA Bridge
Revision ID:0
Bus Number:0
Device Number:7
Function Number:0
PCI Latency Timer:0
Hardware ID:PCI\VEN_10B9&DEV_1533&SUBSYS_153310B9&REV_00
[System Resources]
Interrupt Line:N/A
Interrupt Pin:N/A
[Features]
ALi/ULi M5457 AC'97 Modem Controller
Original Device Name:ALi/ULi M5457 AC'97 Modem Controller
Device Class:Generic Modem
Revision ID:0
Bus Number:0
Device Number:8
Function Number:0
Hardware ID:PCI\VEN_10B9&DEV_5457&SUBSYS_0024103C&REV_00
[System Resources]
Interrupt Line:IRQ3
Interrupt Pin:INTA#
Memory Base Address 0D0004000
I/O Base Address 18800
[Features]
Bus Mastering:Disabled
Broadcom BCM4309 802.11b/g Wireless NIC
Original Device Name:Broadcom BCM4309 802.11b/g Wireless NIC
Device Class:Unknown Network Adapter
Revision ID:2
Bus Number:0
Device Number:9
Function Number:0
Hardware ID:PCI\VEN_14E4&DEV_4318&SUBSYS_50101468&REV_02
[System Resources]
Interrupt Pin:INTA#
Memory Base Address 0D0000000
[Features]
O2Micro OZ6912/711E0 CardBus Controller
Original Device Name:O2Micro OZ6912/711E0 CardBus Controller
Device Class:CardBus Bridge
Revision ID:0
Bus Number:0
Device Number:10
Function Number:0
Hardware ID:PCI\VEN_1217&DEV_6972&SUBSYS_0000FD01&REV_00
[System Resources]
Interrupt Line:IRQ11
Interrupt Pin:INTA#
Memory Base Address 0FFEFE000
[Features]
PCI Bus #2 - CardBus
NEC/Renesas Electronics uPD720101 USB OpenHCI Controller
Original Device Name:NEC/Renesas Electronics uPD720101 USB OpenHCI Controller
Revision ID:43
Bus Number:2
Device Number:0
Function Number:0
Hardware ID:PCI\VEN_1033&DEV_0035&SUBSYS_FFFFFFFF&REV_43
[System Resources]
Interrupt Line:N/A
Interrupt Pin:INT?#
Memory Base Address 0FFEFD000
[Features]
Revision ID:43
Bus Number:2
Device Number:0
Function Number:1
Hardware ID:PCI\VEN_1033&DEV_0035&SUBSYS_10331033&REV_43
[System Resources]
Interrupt Pin:INTB#
Memory Base Address 0FFEFC000
[Features]
ALi/ULi M5229 E-IDE Controller
Original Device Name:ALi/ULi M5229 E-IDE Controller
Device Class:IDE Controller
Revision ID:C4
Bus Number:0
Device Number:16
Function Number:0
Hardware ID:PCI\VEN_10B9&DEV_5229&SUBSYS_0024103C&REV_C4
[System Resources]
Interrupt Line:N/A
Interrupt Pin:INTA#
I/O Base Address 48080
[Features]
ALi/ULi 7101 Power Management Controller
Original Device Name:ALi/ULi 7101 Power Management Controller
Device Class:Unknown Bridge
Revision ID:0
Bus Number:0
Device Number:17
Function Number:0
PCI Latency Timer:0
Hardware ID:PCI\VEN_10B9&DEV_7101&SUBSYS_0024103C&REV_00
[System Resources]
Interrupt Line:N/A
Interrupt Pin:N/A
[Features]
National Semiconductor DP83815 10/100 Fast Ethernet Adapter (MacPhyter)
Original Device Name:National Semiconductor DP83815 10/100 Fast Ethernet Adapter (MacPhyter)
Device Class:Ethernet Adapter
Revision ID:0
Bus Number:0
Device Number:18
Function Number:0
PCI Latency Timer:90
Hardware ID:PCI\VEN_100B&DEV_0020&SUBSYS_0024103C&REV_00
[System Resources]
Interrupt Pin:INTA#
I/O Base Address 08C00
Memory Base Address 1D0005000
[Features]
Video Adapter
ATI IGP-320M (U1)
[Video chipset]
Video Chipset:ATI IGP-320M (U1)
Video Memory:64 MBytes
[Video Card]
Video Card:ATI IGP-320M (U1) Video Adapter [Hewlett-Packard]
Video Bus:AGP 4X
Video RAMDAC:Internal DAC(400MHz)
Video BIOS Version:BK5.0.0 VR001.000.007.005.009.001.001.001 c6kt3.hp v611
[Performance]
Processor Clock:133.0 MHz
Memory Clock:160.0 MHz
Monitor
Digital Flat Panel (1024x768)
Monitor Name:Digital Flat Panel (1024x768)
Serial Number:Unknown
Date Of Manufacture:Week: 0, Year: 1990
Max. Vertical Size:30 cm
Max. Horizontal Size:40 cm
[Advanced parameters]
Input Signal:Analog: 0.700 V / 0.300 V (1.000 V p-p)
Display Type:Non-RGB multi-color
Gamma Factor:1.00
[DPMS Modes]
Standby:Supported
Suspend:Supported
Active Off:Supported
Standard Colour Space:Not Supported
Preferred Timing Mode:Supported
Default GTF Supported:Not Supported
[DPMS Input Signal]
Serration VSync:Supported
Sync On Green:Not Supported
Composite Sync:Not Supported
Separate Syncs:Not Supported
Blank-to-black Setup:Not Supported
[Supported Video Modes]
640 x 48060 Hz
800 x 60060 Hz
1024 x 76860 Hz
1024 x 7680 x 0 mm, Pixel Clock 65.00 MHz
Drives
Floppy Drives
(S)ATA/ATAPI Drives
WDC WD2500BEVE-00WZT0
Drive Controller:E-IDE (ATA-8)
Drive Channel:Primary, Master
Drive Model:WDC WD2500BEVE-00WZT0
Drive Revision:01.01A01
Drive Serial Number:WD-WXH109636288
Drive Capacity:238,475 MBytes (250 GB)
Drive Capacity [MB]:238475
[Drive Geometry]
Number of Cylinders:16383
Number of Heads:16
Sectors Per Track:63
Bytes Per Sector:Unknown
Bytes Per Track:Unknown
Number Of ECC Bytes:50
Number of Sectors:16514064
Total 32-bit LBA Sectors:268435455
Total 48-bit LBA Sectors:488397168
Cache Buffer Size:8192 KBytes
Controller Type:Not Specified
[Transfer Modes]
Sectors Per Interrupt:Total: 16, Active: 16
Max. PIO Transfer Mode:4
Multiword DMA Mode:Total: 2, Active: -
Singleword DMA Mode:Total: -, Active: -
Ultra-DMA Mode:Total: 5 (ATA-100), Active: 5 (ATA-100)
Max. Multiword DMA Transfer Rate:16.7 MBytes/s
Max. PIO with IORDY Transfer Rate:16.7 MBytes/s
Max. PIO w/o IORDY Transfer Rate:16.7 MBytes/s
Transfer Width:16-bit
Native Command Queuing:Not Supported
TRIM Command:Not Supported
[Device flags]
Fixed Drive:Present
Removable Drive:Not Present
Magnetic Storage:Present
LBA Mode:Supported
DMA Mode:Supported
IORDY:Supported
IORDY Disableable:Supported
[Features]
Write Cache:Present, Active
S.M.A.R.T. Feature:Present, Active
Security Feature:Present, Inactive
Removable Media Feature:Not Present, Disabled
Power Management:Present, Active
Advanced Power Management:Present, Active
Packet Interface:Not Present, Disabled
Look-Ahead Buffer:Present, Active
Host Protected Area:Present, Enabled
Power-Up In Standby:Not Suppported, Inactive
Automatic Acoustic Management:Supported, Inactive
48-bit LBA:Supported, Active
[Self-Monitoring, Analysis and Reporting Technology]
Raw Read Error Rate:200/51, Worst: 200
Spin Up Time:192/21, Worst: 186 (Data = 1400)
Start/Stop Count:100/Always OK, Worst: 100 (Data = 153)
Reallocated Sector Count:200/140, Worst: 200
Seek Error Rate:200/51, Worst: 200
Power-On Hours/Cycle Count:78/Always OK, Worst: 78 (Data = 16215)
Spin Retry Count:100/51, Worst: 100
Calibration Retry Count:100/51, Worst: 100
Power Cycle Count:100/Always OK, Worst: 100 (Data = 112)
End to End Error Detection Count:100/Always OK, Worst: 100
Power-Off Retract Count:200/Always OK, Worst: 200 (Data = 98)
Load/Unload Cycle Count:185/Always OK, Worst: 185 (Data = 46134)
Temperature106/Always OK, Worst: 93 (Data = 41.0 °C)
Reallocation Event Count:200/Always OK, Worst: 200
Current Pending Sector Count:200/Always OK, Worst: 200
Off-Line Uncorrectable Sector Count:200/Always OK, Worst: 200
UltraDMA/SATA CRC Error Rate:200/Always OK, Worst: 200
Write Error Rate:200/51, Worst: 200
Optiarc DVD RW AD-7590A
Drive Model:Optiarc DVD RW AD-7590A
Drive Revision:1.41
Serial Number:1192056Q111
Device Type:DVD+R DL
[Device capabilities]
Drive can read:CD-R, CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM, DVD+R DL
Drive can write:CD-R, CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM, DVD+R DL
SCSI Devices
EN2211L NDF454P
[Device address]
SCSI Port Number:0
SCSI Bus Number:0
SCSI Target ID:0
SCSI Logical Unit Number:0
Device Description:EN2211L NDF454P
Device Revision:2.0B
Device Type:DVD-ROM
SCSI Version:SCSI-0
[Device flags]
Removable Device:Capable
Tagged Command Queuing:Not Supported
Linked Commands:Not Supported
Synchronous Data Transfer:Not Supported
Relative Addressing:Not Supported
Asynchronous Event Notification:Not Supported
Drive can read:CD-R, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD+R DL, DVD+RW DL
Audio
Audio Adapter:ALi/ULi M5451 AC'97 Audio Controller
Audio Controller Hardware ID:PCI\VEN_10B9&DEV_5451&SUBSYS_0024103C&REV_02
Network
Broadcom 802.11g hálózati adapter
Network Card:Broadcom 802.11g hálózati adapter
Vendor Description:Broadcom 802.11g hálózati adapter
MAC Address:00-16-CF-14-ED-46
[Capabilities]
Maximum Link Speed:18 Mbps
Physical Media:Wireless LAN
Transmit Buffer Size:Unknown
Receive Buffer Size:524288 Bytes
National Semiconductor DP83815 alapú PCI gyors Ethernet-adapter
Network Card:National Semiconductor DP83815 alapú PCI gyors Ethernet-adapter
Vendor Description:NETGEAR FA312 Fast Ethernet PCI Adapter
MAC Address:00-0D-9D-43-25-98
[Capabilities]
Maximum Link Speed:100 Mbps
Transmit Buffer Size:6056 Bytes
Receive Buffer Size:96896 Bytes
Ports
Serial Ports
COM1
Parallel Ports
LPT1
USB
ALi PCI -> USB nyílt állomásvezérlő
USB Hub
[Port1] : No Device Connected
[Port2] : No Device Connected
[Port3] : No Device Connected
[Port4] : No Device Connected
Szabványos bővített PCI-USB állomásvezérlő
USB Hub
[Port2] : USB-háttértár
Device Manufacturer:Super Top
Product Name:USB 2.0 SATA BRIDGE
Serial Number:M6116018VF16
USB Version Supported:2.00
Driver Description:USB-háttértár
Hardware ID:USB\VID_14CD&PID_6116
[Port5] : No Device Connected
NEC PCI -> USB nyílt állomásvezérlő
USB Hub
USB Hub
[Port2] : Cambridge Silicon Wave Linker BTM01C2AC Bluetooth Adapter
Product Name:
Serial Number:
Driver Description:CSR Bluetooth Device
Hardware ID:USB\VID_0A12&PID_0001
Smart Battery
Battery #0
[General Properties]
Device Name:01KT
Manufacturer Name:SMP-PA
Unique ID:1SMP-PA01KT
Chemistry:Lithium Ion
Designed Capacity:65120 mWh
Full Charged Capacity:42624 mWh
Wear Level:34.5 %
[Current Power Status]
Power Status:On AC Power
Current Voltage:16.352 V
