Electronic Card- Lock System
 The circuit presented here can be- used as a lock for important elec- tronic/electrical appliances. When card is
 inserted inside its mechanism, depending upon the position of punched hole on the card, a particular
 appliance would be switched on. The card is inserted just like a floppy disk inside the disk drive. This card
 should be rectangular in shape with only one punched hole on it. The circuit uses eight photo-transistors (T1
 through T8). When there is no card in the lock, light from incandescent lamp L1 (40-watt, 230V) falls on all the
 photo- transistor detectors. Transistor T8 is used as enable detector for IC1 (74LS244). When light is incident
 on it, it conducts and its collector voltage goes low. This makes transistor T16 to cut-off, and its collector
 voltage goes high. This logic high on its collector terminal will inhibit IC1 as long as light is present on
 photo-transistor T8. IC1 will get enabled only when the card is completely inserted inside the lock mechanism.
 This arrangement ensures that only the selected appliance is switched on and prevents false operation of the
 system. You can make these cards using a black, opaque plastic sheet. A small rectangular notch is made on
 this card to indicate proper direction for insertion of the card. If an attempt is made to insert the card wrongly, it
 will not go completely inside the mechanism and the system will not be enabled. When card for any appliance
 (say appliance 1) is completely inserted in the mechanism, the light will fall only on photo-transistor T1. So only
 T1 will be on and other photo-transistors will be in off state. When transistor T1 is on, its collector voltage falls,
 making transistor T9 to cut-off. As a result, collector voltage of transistor T9 as also pin 2 of IC1 go logic high.
 This causes pin 18 (output Q1) also to go high, switching LED1 on. Simultaneously, output Q1 is connected to
 pin 1 of IC2 (ULN2003) for driving the relay corresponding to appliance 1. Similarly, if card for appliance 2 is
 inserted, only output pin 16 (Q2) of IC1 will go highmaking LED2 on while at the same time energising relay
 for appliance 2 via ULN2003. The same is true for other cases/appliances also. The time during which card is
 present inside the mechanism, the system generates musical tone. This is achieved with the help of diodes D1
 through D7 which provide a wired-OR connection at their common-cathode junction. When any of the outputs
 of IC1 is logic high, the common-cathode junction of diodes D1 through D7 also goes logic high, enabling IC3
 (UM66) to generate a musical tone. In this circuit IC1 (74LS244) is used as buffer with Schmitt trigger. All
 outputs (Q1 through Q7) of this IC are connected to IC2 (ULN2003) which is used as relay driver. IC2 consists
 of seven high-current relay drivers having integral diodes. External free-wheeling diodes are therefore not
 required. When input of this IC is made logic high, the corresponding output will go logic low and relay
 connected to that pin gets energised. This switches on a specific appliance and the corresponding LED. Once
 a specific card is inserted to switch on a specific relay, that relay gets latched through its second pair of
 contacts. Thus even when the card is removed, the specific appliance rem- ains on. The same holds true for all
 other relays/appliances as well. The only way to de-energise a latched relay after removal of the corresponding
 card is to switch off the corresponding switch (S1 through S7) which would cut-off the supply to the desired
 relay. The +5V and +12V supplies can be obtained with conventional arrangement using a step-down
 transformer followed by rectifier, filter and regulator (using 7805 and 7812 etc).
