;   This file is a basic code template for assembly code generation   *
;   on the PIC12F675. This file contains the basic code               *
;   building blocks to build upon.                                    *
;   Refer to the MPASM User's Guide for additional information on     *
;   features of the assembler (Document DS33014).                     *
;   Refer to the respective PIC data sheet for additional             *
;   information on the instruction set.                               *
;    Filename:	    xxx.asm                                           *
;    Date:                                                            *
;    File Version:                                                    *
;    Author:                                                          *
;    Company:                                                         *
;    Files Required: P12F675.INC                                      *
;    Notes:                                                           *
	list      p=12f675           ; list directive to define processor
	#include <p12f675.inc>        ; processor specific variable definitions
	errorlevel  -302              ; suppress message 302 from list file
	__CONFIG   _CP_OFF & _CPD_OFF & _BODEN_OFF & _MCLRE_ON & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT 
; '__CONFIG' directive is used to embed configuration word within .asm file.
; The lables following the directive are located in the respective .inc file.
; See data sheet for additional information on configuration word settings.
;***** VARIABLE DEFINITIONS
w_temp        EQU     0x20        ; variable used for context saving 
status_temp   EQU     0x21        ; variable used for context saving
		ORG     0x000             ; processor reset vector
		goto    main              ; go to beginning of program
		ORG     0x004             ; interrupt vector location
		movwf   w_temp            ; save off current W register contents
		movf	STATUS,w          ; move status register into W register
		movwf	status_temp       ; save off contents of STATUS register
; isr code can go here or be located as a call subroutine elsewhere
		movf    status_temp,w     ; retrieve copy of STATUS register
		movwf	STATUS            ; restore pre-isr STATUS register contents
		swapf   w_temp,f
		swapf   w_temp,w          ; restore pre-isr W register contents
		retfie                    ; return from interrupt
; these first 4 instructions are not required if the internal oscillator is not used
main
		call    0x3FF             ; retrieve factory calibration value
		bsf     STATUS,RP0        ; set file register bank to 1 
		movwf   OSCCAL            ; update register with factory cal value 
		bcf     STATUS,RP0        ; set file register bank to 0
; remaining code goes here
; initialize eeprom locations
		ORG	0x2100
		DE	0x00, 0x01, 0x02, 0x03
		END                       ; directive 'end of program'
