;LMX2306 PLL vezérlő program NOAA15-17-18-19 meteorológiai műholdak vételéhez
;Felső keveréses 10,7MHz KF frekvenciájú vevőkhöz
;Referencia oszcillátor 10MHz 
;Fázisdetektor frekvencia 10kHz
;Készítette: Ferkógyerek 2011 Május
;V2.0 egy nyomógombos változat
	PROCESSOR 16F628A
	INCLUDE P16F628A.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_OFF & _WDT_OFF & _BODEN_OFF & _INTRC_OSC_NOCLKOUT & _LVP_OFF & _MCLRE_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
SZAML	=32
RAM	= 33	; located in Bank 0
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
	RETURN
; Subroutines
;Initialisierung
SYS_INIT
	MOVLW B'00000000'
	MOVWF INTCON
; Set output before direction
	BCF STATUS,RP0			; Bank 0
	BCF STATUS,RP1			; Bank 0
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW 15
	BSF STATUS,RP0			; Bank 1
	MOVWF OPTION_REG
	MOVLW B'00000000'		;PORTA KIMENET
	MOVWF TRISA
	MOVLW B'00010000'		;RB0-RB3 RB5-RB7 KIMENET  RB4 BEMENET
	MOVWF TRISB
	MOVLW 7				; Comparators off
	MOVWF CMCON
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'50'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	BSF INTCON,RBIE
	BSF INTCON,GIE
	CLRF	SZAML		;Számláló regiszter törlése
				;PORTB 1 LE
				;PORTB 2 DATA
				;PORTB 3 CLOCK
;;;;;;;;;;;;;; FŐPROGRAM ;;;;;;;;;;;;;;;;;;;;;;
;;;;;;;;;;; F REGISZTER ÍRÁSA ;;;;;;;;;;;;;;
START	CALL	CLOCK		;ELSŐ 11 BIT 0
	NOP
	CALL	CLOCK
	NOP
	CALL	CLOCK
	NOP
	CALL	CLOCK
	NOP
	CALL	CLOCK
	NOP
	CALL	CLOCK
	NOP
	CALL	CLOCK
	NOP 
	CALL	CLOCK
	NOP
	CALL	CLOCK
	NOP
	CALL	CLOCK
	NOP
	CALL	CLOCK		;11. BIT 0
	BSF	PORTB,2
	CALL	CLOCK		;12. BIT 1  10-12.bit = FastLock Mode #1 
	BCF	PORTB,2
	CALL	CLOCK		;13. BIT 0  Charge pump gain ACTIVE
	BSF	PORTB,2
	CALL	CLOCK		;14. BIT 1 = VCO KARAKTERISZTIKA +
	BCF	PORTB,2
	CALL	CLOCK		;15. BIT 0		
	NOP
	CALL	CLOCK		;16. BIT 0
	BSF	PORTB,2
	CALL	CLOCK		;17. BIT 1  15-17.bit = Digital Lock Detect
	BCF	PORTB,2
	CALL	CLOCK		;18. BIT 0
	NOP
	CALL	CLOCK		;19. BIT 0
	BSF	PORTB,2
	CALL	CLOCK		;20. BIT 1
	BCF	PORTB,2
	CALL	CLOCK		;21. BIT 0
	NOP
	CALL	LE		;F REGISZTER ÁTÍRÁSA
;;;;;;;;;;;;;; R REGISZTER ÍRÁSA  (R osztása 1000) ;;;;;;;;;;;;;;;;;
	BSF	PORTB,2		;1. BIT 1 = LD PRECISION 5 CIKLUS
	CALL	CLOCK
	BCF	PORTB,2
	CALL	CLOCK		;2.- 9. BIT 0
	NOP
	CALL	CLOCK
	NOP
	CALL	CLOCK
	NOP
	CALL	CLOCK
	NOP
	CALL	CLOCK
	NOP
	CALL	CLOCK
	NOP
	CALL	CLOCK
	NOP
	CALL	CLOCK		;9. BIT 0
	BSF	PORTB,2		
	CALL	CLOCK		;10. BIT 1
	NOP
	CALL	CLOCK		;11. BIT 1
	NOP
	NOP
	CALL	CLOCK		;13. BIT 1
	NOP
	BCF	PORTB,2
	BSF	PORTB,2
	CALL	CLOCK		;16. BIT 1
	BCF	PORTB,2
	CALL	CLOCK		;17. BIT 0
	NOP
	NOP
	NOP
	CALL	CLOCK		;20. BIT 0
	NOP
	NOP
	CALL	LE		;R REGISZTER ÁTÍRÁSA
	GOTO	NOAA15		;induláskor automatikusan a NOAA15 frekijét állítja be			
ALTAT:	BCF	INTCON,RBIF	
	BSF	INTCON,GIE
	BCF	STATUS,RP0
	BCF	STATUS,RP1
	MOVFW	PORTB
	SLEEP
BEGOMB:	BTFSC	PORTB,4		;PORTB 4 tesztelése és ugrás ha 0
	GOTO	ALTAT		;Felfutó él volt ezért altatás
	INCF	SZAML,f		;Lefutó él volt ezért növeli a számláló regiszter értékét egyel
	MOVFW	SZAML		;Számláló értékének betöltése W-be
	XORLW	d'4'		;W XORolása 4-el
	BTFSC	STATUS,Z	;Status regiszter Zero jelzőbitjének vizsgálata és ugrás ha 0
	CLRF	SZAML		;a számláló regiszter értéke elérte a négyet, ezért nullázzuk
	XORLW	d'0'		;W XORolása 0-val
	GOTO	NOAA15		;a számláló regiszter értéke 0, UGRÁS NOAA15 FREKI BETÖLTÉSHEZ
	MOVFW	SZAML
	XORLW	d'1'		;W XORolása 1-el
	BTFSC	STATUS,Z
	GOTO	NOAA17
	MOVFW	SZAML
	XORLW	d'2'
	BTFSC	STATUS,Z
	GOTO	NOAA18
	MOVFW	SZAML
	XORLW	d'3'
	BTFSC	STATUS,Z
	GOTO	NOAA19
	GOTO	ALTAT
;;;;;;;;; N regiszter írása NOAA 15 frekijének megfelelően VCO frekvencia 148,32MHz (N osztása 14832);;;;;;;;;;
NOAA15:	BCF	PORTB,1		;LE láb alacsonyra húzása
	BSF	PORTB,2
	CALL	CLOCK		;1. BIT 1 = ICP0=1mA
	BCF	PORTB,2
	CALL	CLOCK		;2. BIT 0
	NOP
	CALL	CLOCK		;3. BIT 0
	BSF	PORTB,2
	CALL	CLOCK		;4. BIT 1
	NOP
	CALL	CLOCK		;5. BIT 1
	NOP
	CALL	CLOCK		;6. BIT 1
	BCF	PORTB,2
	CALL	CLOCK		;7. BIT 0
	NOP
	CALL	CLOCK		;8. BIT 0
	BSF	PORTB,2
	CALL	CLOCK		;9. BIT 1
	NOP
	NOP
	NOP
	NOP
	BCF	PORTB,2
	CALL	CLOCK		;14. BIT 0
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	BSF	PORTB,2
	CALL	CLOCK		;21. BIT 1
	BCF	PORTB,2		;DATA láb alacsonyra húzása
	BSF	PORTB,1		;LE láb magasra húzása R regiszter átírása miatt 
				;és magasan tartása a további zavarvédelem miatt
	MOVLW	B'00000001'
	MOVWF	PORTA		;RA0 láb magasra húzása a többi pedig alacsonyra
	GOTO	ALTAT		;ugrás a PIC altatásához következő gombnyomásig
;;;;;;;;; N regiszter írása NOAA 17 frekijének megfelelően VCO frekvencia 148,2MHz (N osztása 14820);;;;;
NOAA17:	BCF	PORTB,1		;LE láb alacsonyra húzása
	BSF	PORTB,2
	BCF	PORTB,2
	NOP
	BSF	PORTB,2
	NOP
	NOP
	BCF	PORTB,2
	NOP
	BSF	PORTB,2
	NOP
	NOP
	NOP
	BCF	PORTB,2
	NOP
	NOP
	NOP
	BSF	PORTB,2
	BCF	PORTB,2
	NOP
	NOP
	BSF	PORTB,2
	MOVLW	B'00000010'
	MOVWF	PORTA		;RA1 láb magasra húzása a többi pedig alacsonyra
;;;;;;;,, N regiszter írása NOAA 18 frekijének megfelelően VCO frekvencia 148,61MHz (N osztása 14861);;;;;;
NOAA18:	BCF	PORTB,1		;LE láb alacsonyra húzása
	BSF	PORTB,2
	BCF	PORTB,2
	NOP
	BSF	PORTB,2
	NOP
	NOP
	BCF	PORTB,2
	BSF	PORTB,2
	CALL	CLOCK		;8. BIT 1
	BCF	PORTB,2
	NOP
	CALL	CLOCK		;10. BIT 0
	NOP
	NOP
	CALL	CLOCK		;12. BIT 0
	NOP
	BSF	PORTB,2
	BCF	PORTB,2
	NOP
	BSF	PORTB,2
	BCF	PORTB,2
	BSF	PORTB,2
	CALL	CLOCK		;19. BIT 1
	BCF	PORTB,2
	BSF	PORTB,2
	MOVLW	B'00000100'
	MOVWF	PORTA		;RA2 láb magasra húzása a többi pedig alacsonyra
;;;;;;;;; N regiszter írása NOAA 19 frekijének megfelelően VCO frekvencia 147,8MHz (N osztása 14780);;;;;;;;;;
NOAA19:	BCF	PORTB,1		;LE láb alacsonyra húzása
	BSF	PORTB,2
	BCF	PORTB,2
	NOP
	BSF	PORTB,2
	NOP
	NOP
	BCF	PORTB,2
	NOP
	BSF	PORTB,2
	NOP
	BCF	PORTB,2
	BSF	PORTB,2
	NOP
	NOP
	BCF	PORTB,2
	NOP
	BSF	PORTB,2
	BCF	PORTB,2
	NOP
	NOP
	BSF	PORTB,2
	MOVLW	B'00001000'
	MOVWF	PORTA		;RA3 láb magasra húzása a többi pedig alacsonyra
CLOCK:	BSF	PORTB,3
	NOP
	BCF	PORTB,3
	RETURN
LE:	BSF	PORTB,1
	NOP
	BCF	PORTB,1
	RETURN
 	END
