; Source created with Parsic Version 3.x
; at              : 2011.05.29. 23:36:04
; Project File    : C:\DOCUME~1\ALLUSE~1\Asztal\3XNYOM.PIC
; Project Version : 1.0.0
; Created         : 2011.05.29. 20:08:00
; Last change     : 2011.05.29. 23:36:00
	PROCESSOR 16F628A
	INCLUDE P16F628A.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC & _LVP_OFF & _MCLRE_ON
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
ZV1	= 32	; located in Bank 0
ZV1_FD	= 33	; located in Bank 0
MF1	= 34	; located in Bank 0
MF1_HI	= 35	; located in Bank 0
MF1_FD	= 36	; located in Bank 0
S0	= 37	; located in Bank 0
S1	= 38	; located in Bank 0
OS1_FD	= 39	; located in Bank 0
OS2_FD	= 40	; located in Bank 0
OS3_FD	= 41	; located in Bank 0
MF2	= 42	; located in Bank 0
MF2_HI	= 43	; located in Bank 0
MF2_FD	= 44	; located in Bank 0
S2	= 45	; located in Bank 0
MF3	= 46	; located in Bank 0
MF3_HI	= 47	; located in Bank 0
MF3_FD	= 48	; located in Bank 0
OS4_FD	= 49	; located in Bank 0
OS5_FD	= 50	; located in Bank 0
OS6_FD	= 51	; located in Bank 0
TR1	= 52	; located in Bank 0
TR1_HI	= 53	; located in Bank 0
TR2	= 54	; located in Bank 0
TR2_HI	= 55	; located in Bank 0
S3	= 56	; located in Bank 0
TR3	= 57	; located in Bank 0
TR3_HI	= 58	; located in Bank 0
TR4	= 59	; located in Bank 0
TR4_HI	= 60	; located in Bank 0
RAM	= 61	; located in Bank 0
SYS_WSAV	= 112	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 113	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 114	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ MF1,F
	GOTO SYS_INT_LABEL_0
	INCF MF1_HI,F
SYS_INT_LABEL_0
	INCFSZ MF2,F
	GOTO SYS_INT_LABEL_1
	INCF MF2_HI,F
SYS_INT_LABEL_1
	INCFSZ MF3,F
	GOTO SYS_INT_LABEL_2
	INCF MF3_HI,F
SYS_INT_LABEL_2
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_3
	INCF TR1_HI,F
SYS_INT_LABEL_3
	INCFSZ TR2,F
	GOTO SYS_INT_LABEL_4
	INCF TR2_HI,F
SYS_INT_LABEL_4
	INCFSZ TR3,F
	GOTO SYS_INT_LABEL_5
	INCF TR3_HI,F
SYS_INT_LABEL_5
	INCFSZ TR4,F
	GOTO SYS_INT_LABEL_6
	INCF TR4_HI,F
SYS_INT_LABEL_6
NOTMR0INT
EXITINT
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW 143
	BSF STATUS,RP0	; Bank 1
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'11111100'
	MOVWF TRISA
	MOVLW B'11110011'
	MOVWF TRISB
	MOVLW 7	; Comparators off
	MOVWF CMCON
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'50'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; Zähler -> ZV1
	BTFSS S0,4	; Reset ?
	GOTO LABEL_ZV1_COUNT
	CLRF ZV1
	GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf positive Flanke
	BTFSS S0,1
	GOTO LABEL_ZV1_SETFD
	BTFSC ZV1_FD,0
	BSF ZV1_FD,0
	BTFSC S2,1	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV1_BACKWARD
	INCF ZV1,F
LABEL_ZV1_BACKWARD
	DECF ZV1,F
LABEL_ZV1_SETOUT
LABEL_ZV1_SETFD
; Test auf negative Flanke
	BTFSC S0,1
	GOTO LABEL_ZV1_EXIT
	BCF ZV1_FD,0
LABEL_ZV1_EXIT
; Mono-Flop -> MF1
	BTFSC MF1_FD,0
	GOTO LABEL_MF1_CHKTIME
	BTFSS S0,2
LABEL_MF1_RESET
	CLRF MF1
	CLRF MF1_HI
	BSF MF1_FD,1
	BSF S0,0
LABEL_MF1_CHKTIME
; Läuft der Impuls ?
	BTFSS MF1_FD,1
	GOTO LABEL_MF1_SETFD
	MOVLW 76
	SUBWF MF1_HI,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MF1_CHECK
	MOVLW 75
	SUBWF MF1,W
LABEL_MF1_CHECK
	BTFSS STATUS,CARRY
LABEL_MF1_TO
	BCF MF1_FD,1
	BCF S0,0
LABEL_MF1_SETFD
	BTFSS S0,2
	GOTO LABEL_MF1_CLR
	BSF MF1_FD,0
	GOTO LABEL_MF1_ENDE
LABEL_MF1_CLR
	BCF MF1_FD,0
LABEL_MF1_ENDE
; One Shot -> OS1
	BTFSC S0,0
	GOTO LABEL_OS1_1
	BTFSC OS1_FD,0
	GOTO LABEL_OS1_1
	BSF OS1_FD,0
	BSF S1,1
	GOTO LABEL_OS1_2
LABEL_OS1_1
	BCF S1,1
	BTFSS S0,0
	GOTO LABEL_OS1_2
	BCF OS1_FD,0
LABEL_OS1_2
; RS-FLIP-FLOP -> RS1
	BTFSC S0,4
	GOTO LABEL_RS1_RESET
	BTFSS S0,1
	GOTO LABEL_RS1_ENDE
	BSF S0,3	; Ausgang setzen
	GOTO LABEL_RS1_ENDE
LABEL_RS1_RESET
	BCF S0,3	; Ausgang zurücksetzen
LABEL_RS1_ENDE
; One Shot -> OS2
	BTFSS S0,3
	GOTO LABEL_OS2_1
	BTFSC OS2_FD,0
	GOTO LABEL_OS2_1
	BSF OS2_FD,0
	BSF S0,2
	GOTO LABEL_OS2_2
LABEL_OS2_1
	BCF S0,2
	BTFSC S0,3
	GOTO LABEL_OS2_2
	BCF OS2_FD,0
LABEL_OS2_2
; One Shot -> OS3
	BTFSS PORTA,2
	GOTO LABEL_OS3_1
	BTFSC OS3_FD,0
	GOTO LABEL_OS3_1
	BSF OS3_FD,0
	BSF S0,1
	GOTO LABEL_OS3_2
LABEL_OS3_1
	BCF S0,1
	BTFSC PORTA,2
	GOTO LABEL_OS3_2
	BCF OS3_FD,0
LABEL_OS3_2
; Vergleich -> IF1
	MOVLW 3
	SUBWF ZV1,W	; F - W -> W
LABEL_IF1_CHECK
	BTFSS STATUS,ZERO	; Test auf -> =
	GOTO LABEL_IF1_FALSE
LABEL_IF1_TRUE
	BSF S0,5
	GOTO LABEL_IF1_EXIT
LABEL_IF1_FALSE
	BCF S0,5
LABEL_IF1_EXIT
; RS-FLIP-FLOP -> RS2
	BTFSC S0,7
	GOTO LABEL_RS2_RESET
	BTFSS S0,6
	GOTO LABEL_RS2_ENDE
	BSF PORTB,2	; Ausgang setzen
	GOTO LABEL_RS2_ENDE
LABEL_RS2_RESET
	BCF PORTB,2	; Ausgang zurücksetzen
LABEL_RS2_ENDE
; UND - Gatter -> LG1
LABEL_LG1_1
	BTFSC S0,0
	GOTO LABEL_LG1_FALSE
LABEL_LG1_2
	BTFSS S0,5
LABEL_LG1_TRUE
	BSF S0,6
	GOTO LABEL_LG1_ENDE
LABEL_LG1_FALSE
	BCF S0,6
LABEL_LG1_ENDE
; Mono-Flop -> MF2
	BTFSC MF2_FD,0
	GOTO LABEL_MF2_CHKTIME
	BTFSS S0,4
LABEL_MF2_RESET
	CLRF MF2
	CLRF MF2_HI
	BSF MF2_FD,1
	BSF S2,0
LABEL_MF2_CHKTIME
	BTFSS MF2_FD,1
	GOTO LABEL_MF2_SETFD
	MOVLW 30
	SUBWF MF2_HI,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MF2_CHECK
	MOVLW 132
	SUBWF MF2,W
LABEL_MF2_CHECK
	BTFSS STATUS,CARRY
LABEL_MF2_TO
	BCF MF2_FD,1
	BCF S2,0
LABEL_MF2_SETFD
	BTFSS S0,4
	GOTO LABEL_MF2_CLR
	BSF MF2_FD,0
	GOTO LABEL_MF2_ENDE
LABEL_MF2_CLR
	BCF MF2_FD,0
LABEL_MF2_ENDE
; Vergleich -> IF2
	MOVLW 3
LABEL_IF2_CHECK
	BTFSS STATUS,CARRY	; Test auf -> >
	GOTO LABEL_IF2_FALSE
	BTFSC STATUS,ZERO
LABEL_IF2_TRUE
	BSF S1,0
	GOTO LABEL_IF2_EXIT
LABEL_IF2_FALSE
	BCF S1,0
LABEL_IF2_EXIT
; ODER - Gatter -> LG2
LABEL_LG2_1
	BTFSC S1,5
	GOTO LABEL_LG2_TRUE
LABEL_LG2_2
	BTFSC S1,1
	GOTO LABEL_LG2_TRUE
LABEL_LG2_FALSE
	BCF S0,4
	GOTO LABEL_LG2_ENDE
LABEL_LG2_TRUE
	BSF S0,4
LABEL_LG2_ENDE
; RS-FLIP-FLOP -> RS3
	BTFSC S1,4
	GOTO LABEL_RS3_RESET
	BTFSS S1,7
	GOTO LABEL_RS3_ENDE
	BSF PORTB,3	; Ausgang setzen
	GOTO LABEL_RS3_ENDE
LABEL_RS3_RESET
	BCF PORTB,3	; Ausgang zurücksetzen
LABEL_RS3_ENDE
; Mono-Flop -> MF3
	BTFSC MF3_FD,0
	GOTO LABEL_MF3_CHKTIME
	BTFSS S1,2
LABEL_MF3_RESET
	CLRF MF3
	CLRF MF3_HI
	BSF MF3_FD,1
	BSF S1,3
LABEL_MF3_CHKTIME
	BTFSS MF3_FD,1
	GOTO LABEL_MF3_SETFD
	MOVLW 228
	SUBWF MF3_HI,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MF3_CHECK
	MOVLW 226
	SUBWF MF3,W
LABEL_MF3_CHECK
	BTFSS STATUS,CARRY
LABEL_MF3_TO
	BCF MF3_FD,1
	BCF S1,3
LABEL_MF3_SETFD
	BTFSS S1,2
	GOTO LABEL_MF3_CLR
	BSF MF3_FD,0
	GOTO LABEL_MF3_ENDE
LABEL_MF3_CLR
	BCF MF3_FD,0
LABEL_MF3_ENDE
; One Shot -> OS4
	BTFSS S1,0
	GOTO LABEL_OS4_1
	BTFSC OS4_FD,0
	GOTO LABEL_OS4_1
	BSF OS4_FD,0
	BSF S1,2
	GOTO LABEL_OS4_2
LABEL_OS4_1
	BCF S1,2
	BTFSC S1,0
	GOTO LABEL_OS4_2
	BCF OS4_FD,0
LABEL_OS4_2
; One Shot -> OS5
	BTFSC S1,3
	GOTO LABEL_OS5_1
	BTFSC OS5_FD,0
	GOTO LABEL_OS5_1
	BSF OS5_FD,0
	BSF S1,4
	GOTO LABEL_OS5_2
LABEL_OS5_1
	BCF S1,4
	BTFSS S1,3
	GOTO LABEL_OS5_2
	BCF OS5_FD,0
LABEL_OS5_2
; UND - Gatter -> LG3
LABEL_LG3_1
	BTFSS S1,6
	GOTO LABEL_LG3_FALSE
LABEL_LG3_2
	BTFSS S1,1
LABEL_LG3_TRUE
	BSF S1,5
	GOTO LABEL_LG3_ENDE
LABEL_LG3_FALSE
	BCF S1,5
LABEL_LG3_ENDE
; Vergleich -> IF3
	MOVLW 3
LABEL_IF3_CHECK
	BTFSC STATUS,CARRY	; Test auf -> <
	GOTO LABEL_IF3_FALSE
LABEL_IF3_TRUE
	BSF S1,6
	GOTO LABEL_IF3_EXIT
LABEL_IF3_FALSE
	BCF S1,6
LABEL_IF3_EXIT
; ODER - Gatter -> LG4
LABEL_LG4_1
	BTFSC S1,0
	GOTO LABEL_LG4_TRUE
LABEL_LG4_2
	BTFSC S0,4
	GOTO LABEL_LG4_TRUE
LABEL_LG4_FALSE
	BCF S1,7
	GOTO LABEL_LG4_ENDE
LABEL_LG4_TRUE
	BSF S1,7
LABEL_LG4_ENDE
; One Shot -> OS6
	BTFSC S2,0
	GOTO LABEL_OS6_1
	BTFSC OS6_FD,0
	GOTO LABEL_OS6_1
	BSF OS6_FD,0
	BSF S0,7
	GOTO LABEL_OS6_2
LABEL_OS6_1
	BCF S0,7
	BTFSS S2,0
	GOTO LABEL_OS6_2
	BCF OS6_FD,0
LABEL_OS6_2
; GND
	BCF S2,1	; immer Low
; UND - Gatter -> LG5
LABEL_LG5_1
	BTFSS S0,0
	GOTO LABEL_LG5_FALSE
LABEL_LG5_2
	BTFSS S2,2
LABEL_LG5_TRUE
	BSF PORTA,1
	GOTO LABEL_LG5_ENDE
LABEL_LG5_FALSE
	BCF PORTA,1
LABEL_LG5_ENDE
; Timer -> TR1
	MOVLW 0	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 195
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 195
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S2,2
	GOTO LABEL_TR1_CLR
	BSF S2,2
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S2,2
LABEL_TR1_ENDE
; UND - Gatter -> LG6
LABEL_LG6_1
	BTFSS S2,5
	GOTO LABEL_LG6_FALSE
LABEL_LG6_2
	BTFSS PORTB,3
LABEL_LG6_TRUE
	BSF PORTA,0
	GOTO LABEL_LG6_ENDE
LABEL_LG6_FALSE
	BCF PORTA,0
LABEL_LG6_ENDE
; UND - Gatter -> LG7
LABEL_LG7_1
	BTFSS S2,7
	GOTO LABEL_LG7_FALSE
LABEL_LG7_2
	BTFSS S2,6
LABEL_LG7_TRUE
	BSF S2,4
	GOTO LABEL_LG7_ENDE
LABEL_LG7_FALSE
	BCF S2,4
LABEL_LG7_ENDE
; UND - Gatter -> LG8
LABEL_LG8_1
	BTFSS S3,0
	GOTO LABEL_LG8_FALSE
LABEL_LG8_2
	BTFSC S2,6
LABEL_LG8_TRUE
	BSF S2,3
	GOTO LABEL_LG8_ENDE
LABEL_LG8_FALSE
	BCF S2,3
LABEL_LG8_ENDE
; ODER - Gatter -> LG9
LABEL_LG9_1
	BTFSC S2,3
	GOTO LABEL_LG9_TRUE
LABEL_LG9_2
	BTFSC S2,4
	GOTO LABEL_LG9_TRUE
LABEL_LG9_FALSE
	BCF S2,5
	GOTO LABEL_LG9_ENDE
LABEL_LG9_TRUE
	BSF S2,5
LABEL_LG9_ENDE
; Timer -> TR2
	SUBWF TR2_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR2_CHECK
	MOVLW 4
	SUBWF TR2,W	;F-W -> W
LABEL_TR2_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR2_ENDE
LABEL_TR2_RESET
	SUBWF TR2_HI,F	;F-W -> F
	MOVLW 4
	SUBWF TR2,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR2_HI,F
LABEL_TR2_SET	; toggel output
	BTFSC S3,0
	GOTO LABEL_TR2_CLR
	BSF S3,0
	GOTO LABEL_TR2_ENDE
LABEL_TR2_CLR
	BCF S3,0
LABEL_TR2_ENDE
; Timer -> TR3
	SUBWF TR3_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR3_CHECK
	MOVLW 16
	SUBWF TR3,W	;F-W -> W
LABEL_TR3_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR3_ENDE
LABEL_TR3_RESET
	SUBWF TR3_HI,F	;F-W -> F
	MOVLW 16
	SUBWF TR3,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR3_HI,F
LABEL_TR3_SET	; toggel output
	BTFSC S2,7
	GOTO LABEL_TR3_CLR
	BSF S2,7
	GOTO LABEL_TR3_ENDE
LABEL_TR3_CLR
	BCF S2,7
LABEL_TR3_ENDE
; Timer -> TR4
	MOVLW 11	; Test auf >=
	SUBWF TR4_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR4_CHECK
	MOVLW 114
	SUBWF TR4,W	;F-W -> W
LABEL_TR4_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR4_ENDE
LABEL_TR4_RESET
	SUBWF TR4_HI,F	;F-W -> F
	MOVLW 114
	SUBWF TR4,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR4_HI,F
LABEL_TR4_SET	; toggel output
	BTFSC S2,6
	GOTO LABEL_TR4_CLR
	BSF S2,6
	GOTO LABEL_TR4_ENDE
LABEL_TR4_CLR
	BCF S2,6
LABEL_TR4_ENDE
	GOTO MAIN
	END
