float kalman(float gyro_rate, float accel_angle)
// Update the State Estimation and compute the Kalman Gain.
// The estimated angle is returned.
    // Inputs.
    float u = gyro_rate;
    float y = accel_angle;
    // Output.
    static float x_00 = 0.0;
    static float x_10 = 0.0;
    // Persistant states.
    static float P_00 = 0.001;
    static float P_01 = 0.003;
    static float P_10 = 0.003;
    static float P_11 = 0.003;
    // Constants.  
    // These are the delta in seconds between samples.
    const float A_01 = -0.019968;
    const float B_00 = 0.019968;
    // Data read from 1000 samples of the accelerometer had a variance of 0.07701688.
    const float Sz = 0.07701688;
    // Data read from 1000 samples of the gyroscope had a variance of 0.00025556.
    // XXX The values below were pulled from the autopilot site, but I'm not sure how to
    // XXX plug them into the process noise covariance matrix.  This needs to be
    // XXX further explored.
    const float Sw_00 = 0.001;
    const float Sw_01 = 0.003;
    const float Sw_10 = 0.003;
    const float Sw_11 = 0.003;
    // Temp.
    float s_00;
    float inn_00;
    float K_00;
    float K_10;
    float AP_00;
    float AP_01;
    float AP_10;
    float AP_11;
    float APAT_00;
    float APAT_01;
    float APAT_10;
    float APAT_11;
    float KCPAT_00;
    float KCPAT_01;
    float KCPAT_10;
    float KCPAT_11;
    // Update the state estimate by extrapolating current state estimate with input u.
    // x = A * x + B * u
    x_00 += (A_01 * x_10) + (B_00 * u);
    // Compute the innovation -- error between measured value and state.
    // inn = y - c * x
    inn_00 = y - x_00;
    // Compute the covariance of the innovation.
    // s = C * P * C' + Sz
    s_00 = P_00 + Sz;
    // Compute AP matrix for use below.
    // AP = A * P
    AP_00 = P_00 + A_01 * P_10;
    AP_01 = P_01 + A_01 * P_11;
    AP_10 = P_10;
    AP_11 = P_11;
    // Compute the kalman gain matrix.
    // K = A * P * C' * inv(s)
    K_00 = AP_00 / s_00;
    K_10 = AP_10 / s_00;
    // Update the state estimate.
    // x = x + K * inn
    x_00 += K_00 * inn_00;
    x_10 += K_10 * inn_00;
    // Compute the new covariance of the estimation error.
    // P = A * P * A' - K * C * P * A' + Sw
    APAT_00 = AP_00 + (AP_01 * A_01);
    APAT_01 = AP_01;
    APAT_10 = AP_10 + (AP_11 * A_01);
    APAT_11 = AP_11;
    KCPAT_00 = (K_00 * P_00) + (K_00 * P_01) * A_01;
    KCPAT_01 = (K_00 * P_01);
    KCPAT_10 = (K_10 * P_00) + (K_10 * P_01) * A_01;
    KCPAT_11 = (K_10 * P_01);
    P_00 = APAT_00 - KCPAT_00 + Sw_00;
    P_01 = APAT_01 - KCPAT_01 + Sw_01;
    P_10 = APAT_10 - KCPAT_10 + Sw_10;
    P_11 = APAT_11 - KCPAT_11 + Sw_11;
    // Return the estimate.
    return x_00;
