[/] Components=77 Document Type=KSimus Document Version=KSimus 0.3.5 [/Component 0/] Max Count=0xf Min Count=0x0 Reset Count=0x0 Serial Number=1 Type=Boolean/Counter/with RCO and RBO [/Component 0/Sheet/] Pos=152,72 [/Component 0/connPack/Output/] Connector Count=4 [/Component 1/] Max Count=0xf Min Count=0x0 Reset Count=0x0 Serial Number=4 Type=Boolean/Counter/with RCO and RBO [/Component 1/Sheet/] Pos=176,232 [/Component 1/connPack/Output/] Connector Count=4 [/Component 10/] Serial Number=71 Type=Boolean/Gates/XNOR [/Component 10/Sheet/] Pos=176,448 [/Component 10/connPack/Input/] Connector Count=2 [/Component 11/] Serial Number=85 Type=Boolean/Flip Flop/Multiple D Latches [/Component 11/Sheet/] Pos=536,56 [/Component 11/connPack/Input/] Connector Count=4 [/Component 11/connPack/Output/] Connector Count=4 [/Component 12/] Serial Number=86 Type=Boolean/Input/Const True [/Component 12/Sheet/] Pos=448,40 [/Component 13/] Serial Number=88 Type=Boolean/Input/Const True [/Component 13/Sheet/] Pos=320,32 [/Component 14/] Serial Number=108 Type=Boolean/Flip Flop/D Latch [/Component 14/Conn2/] Hide=false [/Component 14/Conn3/] Hide=false [/Component 14/Sheet/] Pos=192,752 [/Component 15/] Serial Number=122 Type=Boolean/Gates/AND [/Component 15/Sheet/] Pos=408,520 [/Component 15/connPack/Input/] Connector Count=3 [/Component 16/] Serial Number=125 Type=Boolean/Gates/Clock Generator [/Component 16/High Time/] Time=5000000000 Unit=s [/Component 16/Low Time/] Time=5000000000 Unit=s [/Component 16/Sheet/] Pos=96,504 [/Component 16/Start Delay/] Time=10000000000 Unit=s [/Component 17/] Serial Number=2 Type=Boolean/Output/7 Segment Display [/Component 17/Sheet/] Pos=448,120 Size=72,72 [/Component 17/User/] Pos=0,48 Size=32,48 [/Component 18/] Serial Number=3 Type=Boolean/Output/7 Segment Display [/Component 18/Sheet/] Pos=392,280 Size=64,72 [/Component 18/User/] Pos=0,96 Size=32,48 [/Component 19/] Frame Enabled=false Serial Number=5 Type=Boolean/Input/Button [/Component 19/Sheet/] Pos=0,72 Size=88,24 [/Component 19/User/] Pos=0,144 Size=80,24 [/Component 2/] Serial Number=38 Type=Boolean/Gates/XOR [/Component 2/Conn0/] Neg=true [/Component 2/Sheet/] Pos=112,368 [/Component 2/connPack/Input/] Connector Count=2 [/Component 20/] Frame Enabled=false Serial Number=6 Type=Boolean/Input/Button [/Component 20/Sheet/] Pos=224,600 Size=88,24 [/Component 20/User/] Pos=0,176 Size=80,24 [/Component 21/] Serial Number=24 Type=Boolean/Output/LED [/Component 21/Sheet/] Pos=248,504 Size=32,24 [/Component 21/User/] Pos=0,208 Size=24,24 [/Component 22/] Serial Number=32 Type=Boolean/Output/LED [/Component 22/Sheet/] Pos=544,200 Size=32,24 [/Component 22/User/] Pos=0,240 Size=24,24 [/Component 23/] Serial Number=33 Type=Boolean/Output/LED [/Component 23/Sheet/] Pos=552,312 Size=32,24 [/Component 23/User/] Pos=0,272 Size=24,24 [/Component 24/] Serial Number=34 Type=Boolean/Output/LED [/Component 24/Sheet/] Pos=664,232 Size=32,24 [/Component 24/User/] Pos=0,304 Size=24,24 [/Component 25/] Serial Number=35 Type=Boolean/Output/LED [/Component 25/Sheet/] Pos=664,384 Size=32,24 [/Component 25/User/] Pos=0,336 Size=24,24 [/Component 26/] Serial Number=36 Type=Boolean/Output/LED [/Component 26/Sheet/] Pos=552,400 Size=32,24 [/Component 26/User/] Pos=0,368 Size=24,24 [/Component 27/] Serial Number=37 Type=Boolean/Output/LED [/Component 27/Sheet/] Pos=552,464 Size=32,24 [/Component 27/User/] Pos=0,400 Size=24,24 [/Component 28/] Serial Number=39 Type=Boolean/Output/LED [/Component 28/Sheet/] Pos=176,376 Size=32,24 [/Component 28/User/] Pos=0,432 Size=24,24 [/Component 29/] Frame Enabled=false Serial Number=40 Type=Boolean/Input/Toggle Button [/Component 29/Sheet/] Pos=0,352 Size=88,24 [/Component 29/User/] Pos=0,464 Size=80,24 [/Component 3/] Serial Number=45 Type=Boolean/Gates/XNOR [/Component 3/Sheet/] Pos=504,224 [/Component 3/connPack/Input/] Connector Count=2 [/Component 30/] Frame Enabled=false Serial Number=41 Type=Boolean/Input/Toggle Button [/Component 30/Sheet/] Pos=8,408 Size=88,24 [/Component 30/User/] Pos=32,32 Size=80,24 [/Component 31/] Frame Enabled=false Serial Number=96 Type=Boolean/Input/Button [/Component 31/Sheet/] Pos=192,24 Size=88,24 [/Component 31/User/] Pos=32,96 Size=80,24 [/Component 32/] Frame Enabled=false Serial Number=98 Type=Boolean/Input/Toggle Button [/Component 32/Sheet/] Pos=280,72 Size=88,24 [/Component 32/User/] Pos=32,64 Size=80,24 [/Component 33/] Serial Number=101 Type=Boolean/Output/LED [/Component 33/Sheet/] Pos=640,24 Size=32,24 [/Component 33/User/] Pos=32,0 Size=24,24 [/Component 34/] Serial Number=102 Type=Boolean/Output/LED [/Component 34/Sheet/] Pos=680,56 Size=32,24 [/Component 34/User/] Pos=32,208 Size=24,24 [/Component 35/] Serial Number=103 Type=Boolean/Output/LED [/Component 35/Sheet/] Pos=688,88 Size=32,24 [/Component 35/User/] Pos=32,240 Size=24,24 [/Component 36/] Serial Number=104 Type=Boolean/Output/LED [/Component 36/Sheet/] Pos=688,120 Size=32,24 [/Component 36/User/] Pos=32,272 Size=24,24 [/Component 37/] Serial Number=109 Type=Boolean/Output/LED [/Component 37/Sheet/] Pos=392,728 Size=32,24 [/Component 37/User/] Pos=32,304 Size=24,24 [/Component 38/] Serial Number=110 Type=Boolean/Output/LED [/Component 38/Sheet/] Pos=384,792 Size=32,24 [/Component 38/User/] Pos=32,336 Size=24,24 [/Component 39/] Frame Enabled=false Serial Number=111 Type=Boolean/Input/Button [/Component 39/Sheet/] Pos=40,776 Size=88,24 [/Component 39/User/] Pos=32,368 Size=80,24 [/Component 4/] Serial Number=46 Type=Boolean/Gates/XNOR [/Component 4/Sheet/] Pos=488,336 [/Component 4/connPack/Input/] Connector Count=2 [/Component 40/] Frame Enabled=false Serial Number=116 Type=Boolean/Input/Button [/Component 40/Sheet/] Pos=48,816 Size=88,24 [/Component 40/User/] Pos=32,400 Size=80,24 [/Component 41/] Frame Enabled=false Serial Number=117 Type=Boolean/Input/Button [/Component 41/Sheet/] Pos=32,736 Size=88,24 [/Component 41/User/] Pos=32,432 Size=80,24 [/Component 42/] Frame Enabled=false Serial Number=118 Type=Boolean/Input/Button [/Component 42/Sheet/] Pos=24,696 Size=88,24 [/Component 42/User/] Pos=64,208 Size=80,24 [/Component 43/] Serial Number=7 Type=Wire/Wire [/Component 43/Connections/] Number=2 [/Component 43/Connections/Connection 0/] Component=5 Connector=Output [/Component 43/Connections/Connection 1/] Component=1 Connector=Clock Up [/Component 43/Property/] Type=wire/property/boolean [/Component 44/] Serial Number=13 Type=Wire/Wire [/Component 44/Connections/] Number=3 [/Component 44/Connections/Connection 0/] Component=4 Connector=Output A [/Component 44/Connections/Connection 1/] Component=3 Connector=Input 1 [/Component 44/Connections/Connection 2/] Component=45 Connector=Input B [/Component 44/Property/] Type=wire/property/boolean [/Component 45/] Serial Number=14 Type=Wire/Wire [/Component 45/Connections/] Number=3 [/Component 45/Connections/Connection 0/] Component=4 Connector=Output B [/Component 45/Connections/Connection 1/] Component=3 Connector=Input 2 [/Component 45/Connections/Connection 2/] Component=48 Connector=Input B [/Component 45/Property/] Type=wire/property/boolean [/Component 46/] Serial Number=15 Type=Wire/Wire [/Component 46/Connections/] Number=3 [/Component 46/Connections/Connection 0/] Component=4 Connector=Output C [/Component 46/Connections/Connection 1/] Component=3 Connector=Input 4 [/Component 46/Connections/Connection 2/] Component=46 Connector=Input B [/Component 46/Property/] Type=wire/property/boolean [/Component 47/] Serial Number=16 Type=Wire/Wire [/Component 47/Connections/] Number=3 [/Component 47/Connections/Connection 0/] Component=4 Connector=Output D [/Component 47/Connections/Connection 1/] Component=3 Connector=Input 8 [/Component 47/Connections/Connection 2/] Component=47 Connector=Input B [/Component 47/Property/] Type=wire/property/boolean [/Component 48/] Serial Number=42 Type=Wire/Wire [/Component 48/Connections/] Number=2 [/Component 48/Connections/Connection 0/] Component=40 Connector=Output [/Component 48/Connections/Connection 1/] Component=38 Connector=Input A [/Component 48/Property/] Type=wire/property/boolean [/Component 49/] Serial Number=43 Type=Wire/Wire [/Component 49/Connections/] Number=2 [/Component 49/Connections/Connection 0/] Component=41 Connector=Output [/Component 49/Connections/Connection 1/] Component=38 Connector=Input B [/Component 49/Property/] Type=wire/property/boolean [/Component 5/] Serial Number=47 Type=Boolean/Gates/XNOR [/Component 5/Sheet/] Pos=480,416 [/Component 5/connPack/Input/] Connector Count=2 [/Component 50/] Serial Number=44 Type=Wire/Wire [/Component 50/Connections/] Number=2 [/Component 50/Connections/Connection 0/] Component=38 Connector=Output [/Component 50/Connections/Connection 1/] Component=39 Connector=Input [/Component 50/Property/] Type=wire/property/boolean [/Component 51/] Serial Number=62 Type=Wire/Wire [/Component 51/Connections/] Number=2 [/Component 51/Connections/Connection 0/] Component=45 Connector=Output [/Component 51/Connections/Connection 1/] Component=59 Connector=Input A [/Component 51/Property/] Type=wire/property/boolean [/Component 52/] Serial Number=63 Type=Wire/Wire [/Component 52/Connections/] Number=2 [/Component 52/Connections/Connection 0/] Component=48 Connector=Output [/Component 52/Connections/Connection 1/] Component=59 Connector=Input B [/Component 52/Property/] Type=wire/property/boolean [/Component 53/] Serial Number=64 Type=Wire/Wire [/Component 53/Connections/] Number=2 [/Component 53/Connections/Connection 0/] Component=46 Connector=Output [/Component 53/Connections/Connection 1/] Component=60 Connector=Input A [/Component 53/Property/] Type=wire/property/boolean [/Component 54/] Serial Number=65 Type=Wire/Wire [/Component 54/Connections/] Number=2 [/Component 54/Connections/Connection 0/] Component=47 Connector=Output [/Component 54/Connections/Connection 1/] Component=60 Connector=Input B [/Component 54/Property/] Type=wire/property/boolean [/Component 55/] Serial Number=66 Type=Wire/Wire [/Component 55/Connections/] Number=2 [/Component 55/Connections/Connection 0/] Component=59 Connector=Output [/Component 55/Connections/Connection 1/] Component=61 Connector=Input A [/Component 55/Property/] Type=wire/property/boolean [/Component 56/] Serial Number=67 Type=Wire/Wire [/Component 56/Connections/] Number=2 [/Component 56/Connections/Connection 0/] Component=60 Connector=Output [/Component 56/Connections/Connection 1/] Component=61 Connector=Input B [/Component 56/Property/] Type=wire/property/boolean [/Component 57/] Serial Number=68 Type=Wire/Wire [/Component 57/Connections/] Number=3 [/Component 57/Connections/Connection 0/] Component=61 Connector=Output [/Component 57/Connections/Connection 1/] Component=24 Connector=Input [/Component 57/Connections/Connection 2/] Component=122 Connector=Input A [/Component 57/Property/] Type=wire/property/boolean [/Component 58/] Serial Number=81 Type=Wire/Wire [/Component 58/Connections/] Number=2 [/Component 58/Connections/Connection 0/] Component=1 Connector=Output A [/Component 58/Connections/Connection 1/] Component=2 Connector=Input 1 [/Component 58/Property/] Type=wire/property/boolean [/Component 59/] Serial Number=82 Type=Wire/Wire [/Component 59/Connections/] Number=2 [/Component 59/Connections/Connection 0/] Component=1 Connector=Output B [/Component 59/Connections/Connection 1/] Component=2 Connector=Input 2 [/Component 59/Property/] Type=wire/property/boolean [/Component 6/] Serial Number=48 Type=Boolean/Gates/XNOR [/Component 6/Sheet/] Pos=496,288 [/Component 6/connPack/Input/] Connector Count=2 [/Component 60/] Serial Number=83 Type=Wire/Wire [/Component 60/Connections/] Number=2 [/Component 60/Connections/Connection 0/] Component=1 Connector=Output C [/Component 60/Connections/Connection 1/] Component=2 Connector=Input 4 [/Component 60/Property/] Type=wire/property/boolean [/Component 61/] Serial Number=84 Type=Wire/Wire [/Component 61/Connections/] Number=2 [/Component 61/Connections/Connection 0/] Component=1 Connector=Output D [/Component 61/Connections/Connection 1/] Component=2 Connector=Input 8 [/Component 61/Property/] Type=wire/property/boolean [/Component 62/] Serial Number=91 Type=Wire/Wire [/Component 62/Connections/] Number=3 [/Component 62/Connections/Connection 0/] Component=85 Connector=Output A [/Component 62/Connections/Connection 1/] Component=45 Connector=Input A [/Component 62/Connections/Connection 2/] Component=101 Connector=Input [/Component 62/Property/] Type=wire/property/boolean [/Component 63/] Serial Number=92 Type=Wire/Wire [/Component 63/Connections/] Number=3 [/Component 63/Connections/Connection 0/] Component=85 Connector=Output B [/Component 63/Connections/Connection 1/] Component=48 Connector=Input A [/Component 63/Connections/Connection 2/] Component=102 Connector=Input [/Component 63/Property/] Type=wire/property/boolean [/Component 64/] Serial Number=93 Type=Wire/Wire [/Component 64/Connections/] Number=3 [/Component 64/Connections/Connection 0/] Component=85 Connector=Output C [/Component 64/Connections/Connection 1/] Component=46 Connector=Input A [/Component 64/Connections/Connection 2/] Component=103 Connector=Input [/Component 64/Property/] Type=wire/property/boolean [/Component 65/] Serial Number=94 Type=Wire/Wire [/Component 65/Connections/] Number=3 [/Component 65/Connections/Connection 0/] Component=85 Connector=Output D [/Component 65/Connections/Connection 1/] Component=47 Connector=Input A [/Component 65/Connections/Connection 2/] Component=104 Connector=Input [/Component 65/Property/] Type=wire/property/boolean [/Component 66/] Serial Number=106 Type=Wire/Wire [/Component 66/Connections/] Number=3 [/Component 66/Connections/Connection 0/] Component=98 Connector=Output [/Component 66/Connections/Connection 1/] Component=85 Connector=Input A [/Component 66/Connections/Connection 2/] Component=85 Connector=Input D [/Component 66/Property/] Type=wire/property/boolean [/Component 67/] Serial Number=107 Type=Wire/Wire [/Component 67/Connections/] Number=2 [/Component 67/Connections/Connection 0/] Component=96 Connector=Output [/Component 67/Connections/Connection 1/] Component=85 Connector=Enable [/Component 67/Property/] Type=wire/property/boolean [/Component 68/] Serial Number=112 Type=Wire/Wire [/Component 68/Connections/] Number=2 [/Component 68/Connections/Connection 0/] Component=108 Connector=Output [/Component 68/Connections/Connection 1/] Component=109 Connector=Input [/Component 68/Property/] Type=wire/property/boolean [/Component 69/] Serial Number=113 Type=Wire/Wire [/Component 69/Connections/] Number=2 [/Component 69/Connections/Connection 0/] Component=108 Connector=/Output [/Component 69/Connections/Connection 1/] Component=110 Connector=Input [/Component 69/Property/] Type=wire/property/boolean [/Component 7/] Serial Number=59 Type=Boolean/Gates/AND [/Component 7/Sheet/] Pos=616,256 [/Component 7/connPack/Input/] Connector Count=2 [/Component 70/] Serial Number=115 Type=Wire/Wire [/Component 70/Connections/] Number=2 [/Component 70/Connections/Connection 0/] Component=111 Connector=Output [/Component 70/Connections/Connection 1/] Component=108 Connector=Enable [/Component 70/Property/] Type=wire/property/boolean [/Component 71/] Serial Number=119 Type=Wire/Wire [/Component 71/Connections/] Number=2 [/Component 71/Connections/Connection 0/] Component=116 Connector=Output [/Component 71/Connections/Connection 1/] Component=108 Connector=Reset [/Component 71/Property/] Type=wire/property/boolean [/Component 72/] Serial Number=120 Type=Wire/Wire [/Component 72/Connections/] Number=2 [/Component 72/Connections/Connection 0/] Component=117 Connector=Output [/Component 72/Connections/Connection 1/] Component=108 Connector=Data [/Component 72/Property/] Type=wire/property/boolean [/Component 73/] Serial Number=121 Type=Wire/Wire [/Component 73/Connections/] Number=2 [/Component 73/Connections/Connection 0/] Component=118 Connector=Output [/Component 73/Connections/Connection 1/] Component=108 Connector=Set [/Component 73/Property/] Type=wire/property/boolean [/Component 74/] Serial Number=123 Type=Wire/Wire [/Component 74/Connections/] Number=2 [/Component 74/Connections/Connection 0/] Component=122 Connector=Output [/Component 74/Connections/Connection 1/] Component=4 Connector=Clock Up [/Component 74/Property/] Type=wire/property/boolean [/Component 75/] Serial Number=124 Type=Wire/Wire [/Component 75/Connections/] Number=2 [/Component 75/Connections/Connection 0/] Component=6 Connector=Output [/Component 75/Connections/Connection 1/] Component=122 Connector=Input B [/Component 75/Property/] Type=wire/property/boolean [/Component 76/] Serial Number=126 Type=Wire/Wire [/Component 76/Connections/] Number=2 [/Component 76/Connections/Connection 0/] Component=125 Connector=Output [/Component 76/Connections/Connection 1/] Component=122 Connector=Input C [/Component 76/Property/] Type=wire/property/boolean [/Component 8/] Serial Number=60 Type=Boolean/Gates/AND [/Component 8/Sheet/] Pos=616,392 [/Component 8/connPack/Input/] Connector Count=2 [/Component 9/] Serial Number=61 Type=Boolean/Gates/AND [/Component 9/Conn0/] Neg=true [/Component 9/Sheet/] Pos=728,296 [/Component 9/connPack/Input/] Connector Count=2 [/Document Property/] Last View=Sheet View Sheet Pos=0,221 User Pos=0,0 [/Document Property/Timing/] Dummy=true [/Document Property/Timing/Execution/] Time=100000000 Unit=ms [/Document Property/Timing/Simulation/] Sychronized=true Time=100000000 Unit=ms [/Document Property/Timing/Update/] Time=500000000 Unit=ms [/Property/] Last Serial Number=126 Sheetsize=1000,936 Usersize=1000,504 [/Property/Module/] Pixmap Store=Absolute ViewType=None
