[/] Components=183 Document Type=KSimus Document Version=KSimus 0.3.5 [/Component 0/] Serial Number=18 Type=Boolean/Mux & Demux/Multiplexer [/Component 0/Sheet/] Pos=376,136 [/Component 0/connPack/Address/] Connector Count=1 [/Component 0/connPack/Input/] Connector Count=2 [/Component 1/] Serial Number=19 Type=Boolean/Mux & Demux/Demultiplexer [/Component 1/Sheet/] Pos=504,56 [/Component 1/connPack/Address/] Connector Count=1 [/Component 1/connPack/Output/] Connector Count=2 [/Component 10/] Serial Number=40 Type=Boolean/Input/Const True [/Component 10/Sheet/] Pos=168,2112 [/Component 100/] Serial Number=259 Type=Boolean/Output/7 Segment Display [/Component 100/Sheet/] Pos=1312,440 Size=40,104 [/Component 100/User/] Pos=80,64 Size=32,48 [/Component 101/] Serial Number=265 Type=Boolean/Output/LED [/Component 101/Sheet/] Pos=1560,232 Size=32,24 [/Component 101/User/] Pos=80,112 Size=24,24 [/Component 102/] Serial Number=266 Type=Boolean/Output/LED [/Component 102/Sheet/] Pos=1568,280 Size=32,24 [/Component 102/User/] Pos=80,144 Size=24,24 [/Component 103/] Serial Number=267 Type=Boolean/Output/LED [/Component 103/Sheet/] Pos=1568,336 Size=32,24 [/Component 103/User/] Pos=80,176 Size=24,24 [/Component 104/] Serial Number=268 Type=Boolean/Output/LED [/Component 104/Sheet/] Pos=1568,456 Size=32,24 [/Component 104/User/] Pos=80,208 Size=24,24 [/Component 105/] Serial Number=269 Type=Boolean/Output/LED [/Component 105/Sheet/] Pos=1656,248 Size=32,24 [/Component 105/User/] Pos=80,240 Size=24,24 [/Component 106/] Serial Number=270 Type=Boolean/Output/LED [/Component 106/Sheet/] Pos=1656,400 Size=32,24 [/Component 106/User/] Pos=80,272 Size=24,24 [/Component 107/] Serial Number=271 Type=Boolean/Output/LED [/Component 107/Sheet/] Pos=1784,400 Size=32,24 [/Component 107/User/] Pos=80,304 Size=24,24 [/Component 108/] Serial Number=307 Type=Boolean/Output/LED [/Component 108/Sheet/] Pos=1624,600 Size=32,24 [/Component 108/User/] Pos=80,336 Size=24,24 [/Component 109/] Serial Number=309 Type=Boolean/Output/LED [/Component 109/Sheet/] Pos=1176,512 Size=32,24 [/Component 109/User/] Pos=80,368 Size=24,24 [/Component 11/] Serial Number=43 Type=Boolean/Gates/AND [/Component 11/Sheet/] Pos=376,1728 [/Component 11/connPack/Input/] Connector Count=3 [/Component 110/] Serial Number=310 Type=Boolean/Output/LED [/Component 110/Sheet/] Pos=1176,552 Size=32,24 [/Component 110/User/] Pos=96,0 Size=24,24 [/Component 111/] Serial Number=311 Type=Boolean/Output/LED [/Component 111/Sheet/] Pos=1192,576 Size=32,24 [/Component 111/User/] Pos=96,400 Size=24,24 [/Component 112/] Serial Number=312 Type=Boolean/Output/LED [/Component 112/Sheet/] Pos=1216,600 Size=32,24 [/Component 112/User/] Pos=96,432 Size=24,24 [/Component 113/] Serial Number=341 Type=Boolean/Output/LED [/Component 113/Sheet/] Pos=1008,432 Size=32,24 [/Component 113/User/] Pos=112,32 Size=24,24 [/Component 114/] Serial Number=342 Type=Boolean/Output/LED [/Component 114/Sheet/] Pos=1008,464 Size=32,24 [/Component 114/User/] Pos=112,64 Size=24,24 [/Component 115/] Serial Number=343 Type=Boolean/Output/LED [/Component 115/Sheet/] Pos=1008,496 Size=32,24 [/Component 115/User/] Pos=112,96 Size=24,24 [/Component 116/] Serial Number=344 Type=Boolean/Output/LED [/Component 116/Sheet/] Pos=1016,392 Size=32,24 [/Component 116/User/] Pos=112,128 Size=24,24 [/Component 117/] Serial Number=59 Type=Wire/Wire [/Component 117/Connections/] Number=2 [/Component 117/Connections/Connection 0/] Component=22 Connector=Output [/Component 117/Connections/Connection 1/] Component=58 Connector=Input A [/Component 117/Property/] Type=wire/property/boolean [/Component 118/] Serial Number=79 Type=Wire/Wire [/Component 118/Connections/] Number=2 [/Component 118/Connections/Connection 0/] Component=45 Connector=Output [/Component 118/Connections/Connection 1/] Component=58 Connector=Input B [/Component 118/Property/] Type=wire/property/boolean [/Component 119/] Serial Number=84 Type=Wire/Wire [/Component 119/Connections/] Number=2 [/Component 119/Connections/Connection 0/] Component=58 Connector=Output [/Component 119/Connections/Connection 1/] Component=21 Connector=Input C [/Component 119/Property/] Type=wire/property/boolean [/Component 12/] Serial Number=44 Type=Boolean/Gates/AND [/Component 12/Sheet/] Pos=384,1936 [/Component 12/connPack/Input/] Connector Count=3 [/Component 120/] Serial Number=89 Type=Wire/Wire [/Component 120/Connections/] Number=2 [/Component 120/Connections/Connection 0/] Component=21 Connector=Output [/Component 120/Connections/Connection 1/] Component=88 Connector=Input A [/Component 120/Property/] Type=wire/property/boolean [/Component 121/] Serial Number=92 Type=Wire/Wire [/Component 121/Connections/] Number=2 [/Component 121/Connections/Connection 0/] Component=91 Connector=Output [/Component 121/Connections/Connection 1/] Component=88 Connector=Input B [/Component 121/Property/] Type=wire/property/boolean [/Component 122/] Serial Number=95 Type=Wire/Wire [/Component 122/Connections/] Number=2 [/Component 122/Connections/Connection 0/] Component=94 Connector=Output [/Component 122/Connections/Connection 1/] Component=91 Connector=Input C [/Component 122/Property/] Type=wire/property/boolean [/Component 123/] Serial Number=125 Type=Wire/Wire [/Component 123/Connections/] Number=2 [/Component 123/Connections/Connection 0/] Component=97 Connector=Output [/Component 123/Connections/Connection 1/] Component=88 Connector=Input C [/Component 123/Property/] Type=wire/property/boolean [/Component 124/] Serial Number=139 Type=Wire/Wire [/Component 124/Connections/] Number=2 [/Component 124/Connections/Connection 0/] Component=115 Connector=Output [/Component 124/Connections/Connection 1/] Component=97 Connector=Input B [/Component 124/Property/] Type=wire/property/boolean [/Component 125/] Serial Number=144 Type=Wire/Wire [/Component 125/Connections/] Number=2 [/Component 125/Connections/Connection 0/] Component=116 Connector=Output [/Component 125/Connections/Connection 1/] Component=112 Connector=Input C [/Component 125/Property/] Type=wire/property/boolean [/Component 126/] Serial Number=145 Type=Wire/Wire [/Component 126/Connections/] Number=2 [/Component 126/Connections/Connection 0/] Component=112 Connector=Output [/Component 126/Connections/Connection 1/] Component=88 Connector=Input D [/Component 126/Property/] Type=wire/property/boolean [/Component 127/] Serial Number=151 Type=Wire/Wire [/Component 127/Connections/] Number=2 [/Component 127/Connections/Connection 0/] Component=117 Connector=Output [/Component 127/Connections/Connection 1/] Component=119 Connector=Input A [/Component 127/Property/] Type=wire/property/boolean [/Component 128/] Serial Number=152 Type=Wire/Wire [/Component 128/Connections/] Number=2 [/Component 128/Connections/Connection 0/] Component=121 Connector=Output [/Component 128/Connections/Connection 1/] Component=119 Connector=Input B [/Component 128/Property/] Type=wire/property/boolean [/Component 129/] Serial Number=155 Type=Wire/Wire [/Component 129/Connections/] Number=2 [/Component 129/Connections/Connection 0/] Component=113 Connector=Output [/Component 129/Connections/Connection 1/] Component=88 Connector=Input E [/Component 129/Property/] Type=wire/property/boolean [/Component 13/] Serial Number=45 Type=Boolean/Gates/AND [/Component 13/Sheet/] Pos=272,584 [/Component 13/connPack/Input/] Connector Count=2 [/Component 130/] Serial Number=156 Type=Wire/Wire [/Component 130/Connections/] Number=2 [/Component 130/Connections/Connection 0/] Component=119 Connector=Output [/Component 130/Connections/Connection 1/] Component=113 Connector=Input C [/Component 130/Property/] Type=wire/property/boolean [/Component 131/] Serial Number=157 Type=Wire/Wire [/Component 131/Connections/] Number=4 [/Component 131/Connections/Connection 0/] Component=3 Connector=Output [/Component 131/Connections/Connection 1/] Component=113 Connector=Input B [/Component 131/Connections/Connection 2/] Component=117 Connector=Input A [/Component 131/Connections/Connection 3/] Component=121 Connector=Input A [/Component 131/Property/] Type=wire/property/boolean [/Component 132/] Serial Number=159 Type=Wire/Wire [/Component 132/Connections/] Number=3 [/Component 132/Connections/Connection 0/] Component=2 Connector=Output [/Component 132/Connections/Connection 1/] Component=112 Connector=Input B [/Component 132/Connections/Connection 2/] Component=116 Connector=Input B [/Component 132/Property/] Type=wire/property/boolean [/Component 133/] Serial Number=160 Type=Wire/Wire [/Component 133/Connections/] Number=3 [/Component 133/Connections/Connection 0/] Component=8 Connector=Output [/Component 133/Connections/Connection 1/] Component=97 Connector=Input C [/Component 133/Connections/Connection 2/] Component=115 Connector=Input B [/Component 133/Property/] Type=wire/property/boolean [/Component 134/] Serial Number=163 Type=Wire/Wire [/Component 134/Connections/] Number=4 [/Component 134/Connections/Connection 0/] Component=1 Connector=Output [/Component 134/Connections/Connection 1/] Component=21 Connector=Input B [/Component 134/Connections/Connection 2/] Component=22 Connector=Input A [/Component 134/Connections/Connection 3/] Component=45 Connector=Input A [/Component 134/Property/] Type=wire/property/boolean [/Component 135/] Serial Number=164 Type=Wire/Wire [/Component 135/Connections/] Number=2 [/Component 135/Connections/Connection 0/] Component=114 Connector=Output [/Component 135/Connections/Connection 1/] Component=88 Connector=Input F [/Component 135/Property/] Type=wire/property/boolean [/Component 136/] Serial Number=165 Type=Wire/Wire [/Component 136/Connections/] Number=2 [/Component 136/Connections/Connection 0/] Component=118 Connector=Output [/Component 136/Connections/Connection 1/] Component=114 Connector=Input C [/Component 136/Property/] Type=wire/property/boolean [/Component 137/] Serial Number=166 Type=Wire/Wire [/Component 137/Connections/] Number=3 [/Component 137/Connections/Connection 0/] Component=4 Connector=Output [/Component 137/Connections/Connection 1/] Component=114 Connector=Input B [/Component 137/Connections/Connection 2/] Component=118 Connector=Input B [/Component 137/Property/] Type=wire/property/boolean [/Component 138/] Serial Number=167 Type=Wire/Wire [/Component 138/Connections/] Number=2 [/Component 138/Connections/Connection 0/] Component=110 Connector=Output [/Component 138/Connections/Connection 1/] Component=88 Connector=Input G [/Component 138/Property/] Type=wire/property/boolean [/Component 139/] Serial Number=168 Type=Wire/Wire [/Component 139/Connections/] Number=2 [/Component 139/Connections/Connection 0/] Component=43 Connector=Output [/Component 139/Connections/Connection 1/] Component=88 Connector=Input H [/Component 139/Property/] Type=wire/property/boolean [/Component 14/] Serial Number=58 Type=Boolean/Gates/AND [/Component 14/Conn0/] Neg=true [/Component 14/Sheet/] Pos=392,584 [/Component 14/connPack/Input/] Connector Count=2 [/Component 140/] Serial Number=169 Type=Wire/Wire [/Component 140/Connections/] Number=2 [/Component 140/Connections/Connection 0/] Component=44 Connector=Output [/Component 140/Connections/Connection 1/] Component=88 Connector=Input I [/Component 140/Property/] Type=wire/property/boolean [/Component 141/] Serial Number=173 Type=Wire/Wire [/Component 141/Connections/] Number=2 [/Component 141/Connections/Connection 0/] Component=124 Connector=Output [/Component 141/Connections/Connection 1/] Component=171 Connector=Input A [/Component 141/Property/] Type=wire/property/boolean [/Component 142/] Serial Number=174 Type=Wire/Wire [/Component 142/Connections/] Number=2 [/Component 142/Connections/Connection 0/] Component=123 Connector=Output [/Component 142/Connections/Connection 1/] Component=171 Connector=Input B [/Component 142/Property/] Type=wire/property/boolean [/Component 143/] Serial Number=175 Type=Wire/Wire [/Component 143/Connections/] Number=2 [/Component 143/Connections/Connection 0/] Component=171 Connector=Output [/Component 143/Connections/Connection 1/] Component=172 Connector=Input A [/Component 143/Property/] Type=wire/property/boolean [/Component 144/] Serial Number=176 Type=Wire/Wire [/Component 144/Connections/] Number=2 [/Component 144/Connections/Connection 0/] Component=120 Connector=Output [/Component 144/Connections/Connection 1/] Component=172 Connector=Input B [/Component 144/Property/] Type=wire/property/boolean [/Component 145/] Serial Number=178 Type=Wire/Wire [/Component 145/Connections/] Number=4 [/Component 145/Connections/Connection 0/] Component=5 Connector=Output [/Component 145/Connections/Connection 1/] Component=43 Connector=Input B [/Component 145/Connections/Connection 2/] Component=122 Connector=Input A [/Component 145/Connections/Connection 3/] Component=111 Connector=Input A [/Component 145/Property/] Type=wire/property/boolean [/Component 146/] Serial Number=179 Type=Wire/Wire [/Component 146/Connections/] Number=4 [/Component 146/Connections/Connection 0/] Component=6 Connector=Output [/Component 146/Connections/Connection 1/] Component=44 Connector=Input B [/Component 146/Connections/Connection 2/] Component=183 Connector=Input A [/Component 146/Connections/Connection 3/] Component=182 Connector=Input A [/Component 146/Property/] Type=wire/property/boolean [/Component 147/] Serial Number=180 Type=Wire/Wire [/Component 147/Connections/] Number=2 [/Component 147/Connections/Connection 0/] Component=122 Connector=Output [/Component 147/Connections/Connection 1/] Component=161 Connector=Input A [/Component 147/Property/] Type=wire/property/boolean [/Component 148/] Serial Number=181 Type=Wire/Wire [/Component 148/Connections/] Number=2 [/Component 148/Connections/Connection 0/] Component=111 Connector=Output [/Component 148/Connections/Connection 1/] Component=161 Connector=Input B [/Component 148/Property/] Type=wire/property/boolean [/Component 149/] Serial Number=185 Type=Wire/Wire [/Component 149/Connections/] Number=2 [/Component 149/Connections/Connection 0/] Component=182 Connector=Output [/Component 149/Connections/Connection 1/] Component=184 Connector=Input B [/Component 149/Property/] Type=wire/property/boolean [/Component 15/] Serial Number=85 Type=Boolean/Flip Flop/Multiple D Latches [/Component 15/Sheet/] Pos=624,2072 [/Component 15/connPack/Input/] Connector Count=4 [/Component 15/connPack/Output/] Connector Count=4 [/Component 150/] Serial Number=186 Type=Wire/Wire [/Component 150/Connections/] Number=2 [/Component 150/Connections/Connection 0/] Component=183 Connector=Output [/Component 150/Connections/Connection 1/] Component=184 Connector=Input A [/Component 150/Property/] Type=wire/property/boolean [/Component 151/] Serial Number=187 Type=Wire/Wire [/Component 151/Connections/] Number=2 [/Component 151/Connections/Connection 0/] Component=172 Connector=Output [/Component 151/Connections/Connection 1/] Component=110 Connector=Input C [/Component 151/Property/] Type=wire/property/boolean [/Component 152/] Serial Number=188 Type=Wire/Wire [/Component 152/Connections/] Number=2 [/Component 152/Connections/Connection 0/] Component=161 Connector=Output [/Component 152/Connections/Connection 1/] Component=43 Connector=Input C [/Component 152/Property/] Type=wire/property/boolean [/Component 153/] Serial Number=189 Type=Wire/Wire [/Component 153/Connections/] Number=2 [/Component 153/Connections/Connection 0/] Component=184 Connector=Output [/Component 153/Connections/Connection 1/] Component=44 Connector=Input C [/Component 153/Property/] Type=wire/property/boolean [/Component 154/] Serial Number=191 Type=Wire/Wire [/Component 154/Connections/] Number=5 [/Component 154/Connections/Connection 0/] Component=7 Connector=Output [/Component 154/Connections/Connection 1/] Component=124 Connector=Input A [/Component 154/Connections/Connection 2/] Component=110 Connector=Input B [/Component 154/Connections/Connection 3/] Component=123 Connector=Input A [/Component 154/Connections/Connection 4/] Component=120 Connector=Input A [/Component 154/Property/] Type=wire/property/boolean [/Component 155/] Serial Number=202 Type=Wire/Wire [/Component 155/Connections/] Number=2 [/Component 155/Connections/Connection 0/] Component=26 Connector=Output [/Component 155/Connections/Connection 1/] Component=200 Connector=Input A [/Component 155/Property/] Type=wire/property/boolean [/Component 156/] Serial Number=203 Type=Wire/Wire [/Component 156/Connections/] Number=2 [/Component 156/Connections/Connection 0/] Component=10 Connector=Output [/Component 156/Connections/Connection 1/] Component=200 Connector=Input B [/Component 156/Property/] Type=wire/property/boolean [/Component 157/] Serial Number=204 Type=Wire/Wire [/Component 157/Connections/] Number=2 [/Component 157/Connections/Connection 0/] Component=200 Connector=Output [/Component 157/Connections/Connection 1/] Component=24 Connector=Reset [/Component 157/Property/] Type=wire/property/boolean [/Component 158/] Serial Number=241 Type=Wire/Wire [/Component 158/Connections/] Number=3 [/Component 158/Connections/Connection 0/] Component=330 Connector=Output [/Component 158/Connections/Connection 1/] Component=238 Connector=Input A [/Component 158/Connections/Connection 2/] Component=265 Connector=Input [/Component 158/Property/] Type=wire/property/boolean [/Component 159/] Serial Number=242 Type=Wire/Wire [/Component 159/Connections/] Number=3 [/Component 159/Connections/Connection 0/] Component=329 Connector=Output [/Component 159/Connections/Connection 1/] Component=238 Connector=Input B [/Component 159/Connections/Connection 2/] Component=266 Connector=Input [/Component 159/Property/] Type=wire/property/boolean [/Component 16/] Serial Number=88 Type=Boolean/Gates/XOR [/Component 16/Sheet/] Pos=744,1008 [/Component 16/connPack/Input/] Connector Count=10 [/Component 160/] Serial Number=243 Type=Wire/Wire [/Component 160/Connections/] Number=3 [/Component 160/Connections/Connection 0/] Component=328 Connector=Output [/Component 160/Connections/Connection 1/] Component=239 Connector=Input A [/Component 160/Connections/Connection 2/] Component=267 Connector=Input [/Component 160/Property/] Type=wire/property/boolean [/Component 161/] Serial Number=244 Type=Wire/Wire [/Component 161/Connections/] Number=3 [/Component 161/Connections/Connection 0/] Component=331 Connector=Output [/Component 161/Connections/Connection 1/] Component=239 Connector=Input B [/Component 161/Connections/Connection 2/] Component=268 Connector=Input [/Component 161/Property/] Type=wire/property/boolean [/Component 162/] Serial Number=245 Type=Wire/Wire [/Component 162/Connections/] Number=3 [/Component 162/Connections/Connection 0/] Component=239 Connector=Output [/Component 162/Connections/Connection 1/] Component=240 Connector=Input B [/Component 162/Connections/Connection 2/] Component=270 Connector=Input [/Component 162/Property/] Type=wire/property/boolean [/Component 163/] Serial Number=246 Type=Wire/Wire [/Component 163/Connections/] Number=3 [/Component 163/Connections/Connection 0/] Component=238 Connector=Output [/Component 163/Connections/Connection 1/] Component=240 Connector=Input A [/Component 163/Connections/Connection 2/] Component=269 Connector=Input [/Component 163/Property/] Type=wire/property/boolean [/Component 164/] Serial Number=262 Type=Wire/Wire [/Component 164/Connections/] Number=11 [/Component 164/Connections/Connection 0/] Component=25 Connector=Output [/Component 164/Connections/Connection 1/] Component=112 Connector=Input A [/Component 164/Connections/Connection 10/] Component=252 Connector=Input C [/Component 164/Connections/Connection 2/] Component=97 Connector=Input A [/Component 164/Connections/Connection 3/] Component=113 Connector=Input A [/Component 164/Connections/Connection 4/] Component=114 Connector=Input A [/Component 164/Connections/Connection 5/] Component=91 Connector=Input A [/Component 164/Connections/Connection 6/] Component=110 Connector=Input A [/Component 164/Connections/Connection 7/] Component=21 Connector=Input A [/Component 164/Connections/Connection 8/] Component=43 Connector=Input A [/Component 164/Connections/Connection 9/] Component=44 Connector=Input A [/Component 164/Property/] Type=wire/property/boolean [/Component 165/] Serial Number=284 Type=Wire/Wire [/Component 165/Connections/] Number=3 [/Component 165/Connections/Connection 0/] Component=12 Connector=Output [/Component 165/Connections/Connection 1/] Component=252 Connector=Input A [/Component 165/Connections/Connection 2/] Component=332 Connector=Enable [/Component 165/Property/] Type=wire/property/boolean [/Component 166/] Serial Number=316 Type=Wire/Wire [/Component 166/Connections/] Number=3 [/Component 166/Connections/Connection 0/] Component=240 Connector=Output [/Component 166/Connections/Connection 1/] Component=271 Connector=Input [/Component 166/Connections/Connection 2/] Component=252 Connector=Input B [/Component 166/Property/] Type=wire/property/boolean [/Component 167/] Serial Number=213 Type=Wire/Wire [/Component 167/Connections/] Number=3 [/Component 167/Connections/Connection 0/] Component=109 Connector=Output A [/Component 167/Connections/Connection 1/] Component=212 Connector=Input [/Component 167/Connections/Connection 2/] Component=330 Connector=Input A [/Component 167/Property/] Type=wire/property/boolean [/Component 168/] Serial Number=214 Type=Wire/Wire [/Component 168/Connections/] Number=3 [/Component 168/Connections/Connection 0/] Component=109 Connector=Output B [/Component 168/Connections/Connection 1/] Component=209 Connector=Input [/Component 168/Connections/Connection 2/] Component=329 Connector=Input A [/Component 168/Property/] Type=wire/property/boolean [/Component 169/] Serial Number=215 Type=Wire/Wire [/Component 169/Connections/] Number=3 [/Component 169/Connections/Connection 0/] Component=109 Connector=Output C [/Component 169/Connections/Connection 1/] Component=211 Connector=Input [/Component 169/Connections/Connection 2/] Component=328 Connector=Input A [/Component 169/Property/] Type=wire/property/boolean [/Component 17/] Serial Number=91 Type=Boolean/Gates/AND [/Component 17/Sheet/] Pos=344,840 [/Component 17/connPack/Input/] Connector Count=3 [/Component 170/] Serial Number=216 Type=Wire/Wire [/Component 170/Connections/] Number=3 [/Component 170/Connections/Connection 0/] Component=109 Connector=Output D [/Component 170/Connections/Connection 1/] Component=210 Connector=Input [/Component 170/Connections/Connection 2/] Component=331 Connector=Input A [/Component 170/Property/] Type=wire/property/boolean [/Component 171/] Serial Number=162 Type=Wire/Wire [/Component 171/Connections/] Number=3 [/Component 171/Connections/Connection 0/] Component=9 Connector=Output [/Component 171/Connections/Connection 1/] Component=91 Connector=Input B [/Component 171/Connections/Connection 2/] Component=94 Connector=Input A [/Component 171/Property/] Type=wire/property/boolean [/Component 172/] Serial Number=318 Type=Wire/Wire [/Component 172/Connections/] Number=2 [/Component 172/Connections/Connection 0/] Component=88 Connector=Output [/Component 172/Connections/Connection 1/] Component=24 Connector=Clock Up [/Component 172/Property/] Type=wire/property/boolean [/Component 173/] Serial Number=319 Type=Wire/Wire [/Component 173/Connections/] Number=2 [/Component 173/Connections/Connection 0/] Component=252 Connector=Output [/Component 173/Connections/Connection 1/] Component=88 Connector=Input J [/Component 173/Property/] Type=wire/property/boolean [/Component 174/] Serial Number=333 Type=Wire/Wire [/Component 174/Connections/] Number=7 [/Component 174/Connections/Connection 0/] Component=24 Connector=Output D [/Component 174/Connections/Connection 1/] Component=312 Connector=Input [/Component 174/Connections/Connection 2/] Component=20 Connector=Input 8 [/Component 174/Connections/Connection 3/] Component=109 Connector=Input D [/Component 174/Connections/Connection 4/] Component=45 Connector=Input B [/Component 174/Connections/Connection 5/] Component=115 Connector=Input A [/Component 174/Connections/Connection 6/] Component=332 Connector=Input D [/Component 174/Property/] Type=wire/property/boolean [/Component 175/] Serial Number=334 Type=Wire/Wire [/Component 175/Connections/] Number=9 [/Component 175/Connections/Connection 0/] Component=24 Connector=Output C [/Component 175/Connections/Connection 1/] Component=311 Connector=Input [/Component 175/Connections/Connection 2/] Component=118 Connector=Input A [/Component 175/Connections/Connection 3/] Component=20 Connector=Input 4 [/Component 175/Connections/Connection 4/] Component=120 Connector=Input B [/Component 175/Connections/Connection 5/] Component=109 Connector=Input C [/Component 175/Connections/Connection 6/] Component=111 Connector=Input B [/Component 175/Connections/Connection 7/] Component=182 Connector=Input B [/Component 175/Connections/Connection 8/] Component=332 Connector=Input C [/Component 175/Property/] Type=wire/property/boolean [/Component 176/] Serial Number=335 Type=Wire/Wire [/Component 176/Connections/] Number=9 [/Component 176/Connections/Connection 0/] Component=24 Connector=Output B [/Component 176/Connections/Connection 1/] Component=116 Connector=Input A [/Component 176/Connections/Connection 2/] Component=310 Connector=Input [/Component 176/Connections/Connection 3/] Component=121 Connector=Input B [/Component 176/Connections/Connection 4/] Component=20 Connector=Input 2 [/Component 176/Connections/Connection 5/] Component=109 Connector=Input B [/Component 176/Connections/Connection 6/] Component=123 Connector=Input B [/Component 176/Connections/Connection 7/] Component=183 Connector=Input B [/Component 176/Connections/Connection 8/] Component=332 Connector=Input B [/Component 176/Property/] Type=wire/property/boolean [/Component 177/] Serial Number=336 Type=Wire/Wire [/Component 177/Connections/] Number=10 [/Component 177/Connections/Connection 0/] Component=24 Connector=Output A [/Component 177/Connections/Connection 1/] Component=94 Connector=Input B [/Component 177/Connections/Connection 2/] Component=22 Connector=Input B [/Component 177/Connections/Connection 3/] Component=309 Connector=Input [/Component 177/Connections/Connection 4/] Component=20 Connector=Input 1 [/Component 177/Connections/Connection 5/] Component=117 Connector=Input B [/Component 177/Connections/Connection 6/] Component=109 Connector=Input A [/Component 177/Connections/Connection 7/] Component=124 Connector=Input B [/Component 177/Connections/Connection 8/] Component=122 Connector=Input B [/Component 177/Connections/Connection 9/] Component=332 Connector=Input A [/Component 177/Property/] Type=wire/property/boolean [/Component 178/] Serial Number=337 Type=Wire/Wire [/Component 178/Connections/] Number=3 [/Component 178/Connections/Connection 0/] Component=332 Connector=Output A [/Component 178/Connections/Connection 1/] Component=330 Connector=Input B [/Component 178/Connections/Connection 2/] Component=344 Connector=Input [/Component 178/Property/] Type=wire/property/boolean [/Component 179/] Serial Number=338 Type=Wire/Wire [/Component 179/Connections/] Number=3 [/Component 179/Connections/Connection 0/] Component=332 Connector=Output B [/Component 179/Connections/Connection 1/] Component=329 Connector=Input B [/Component 179/Connections/Connection 2/] Component=341 Connector=Input [/Component 179/Property/] Type=wire/property/boolean [/Component 18/] Serial Number=94 Type=Boolean/Gates/AND [/Component 18/Conn0/] Neg=true [/Component 18/Sheet/] Pos=248,808 [/Component 18/connPack/Input/] Connector Count=2 [/Component 180/] Serial Number=339 Type=Wire/Wire [/Component 180/Connections/] Number=3 [/Component 180/Connections/Connection 0/] Component=332 Connector=Output C [/Component 180/Connections/Connection 1/] Component=328 Connector=Input B [/Component 180/Connections/Connection 2/] Component=342 Connector=Input [/Component 180/Property/] Type=wire/property/boolean [/Component 181/] Serial Number=340 Type=Wire/Wire [/Component 181/Connections/] Number=3 [/Component 181/Connections/Connection 0/] Component=332 Connector=Output D [/Component 181/Connections/Connection 1/] Component=331 Connector=Input B [/Component 181/Connections/Connection 2/] Component=343 Connector=Input [/Component 181/Property/] Type=wire/property/boolean [/Component 182/] Serial Number=345 Type=Wire/Wire [/Component 182/Connections/] Number=3 [/Component 182/Connections/Connection 0/] Component=11 Connector=Output [/Component 182/Connections/Connection 1/] Component=109 Connector=Enable [/Component 182/Connections/Connection 2/] Component=200 Connector=Input C [/Component 182/Property/] Type=wire/property/boolean [/Component 19/] Serial Number=97 Type=Boolean/Gates/AND [/Component 19/Sheet/] Pos=352,968 [/Component 19/connPack/Input/] Connector Count=3 [/Component 2/] Serial Number=21 Type=Boolean/Gates/AND [/Component 2/Sheet/] Pos=424,496 [/Component 2/connPack/Input/] Connector Count=3 [/Component 20/] Serial Number=102 Type=Boolean/Flip Flop/Multiple D Latches [/Component 20/Sheet/] Pos=448,2072 [/Component 20/connPack/Input/] Connector Count=4 [/Component 20/connPack/Output/] Connector Count=4 [/Component 21/] Serial Number=103 Type=Boolean/Flip Flop/Multiple D Latches [/Component 21/Sheet/] Pos=328,2072 [/Component 21/connPack/Input/] Connector Count=4 [/Component 21/connPack/Output/] Connector Count=4 [/Component 22/] Serial Number=104 Type=Boolean/Flip Flop/Multiple D Latches [/Component 22/Sheet/] Pos=272,2072 [/Component 22/connPack/Input/] Connector Count=4 [/Component 22/connPack/Output/] Connector Count=4 [/Component 23/] Serial Number=105 Type=Boolean/Flip Flop/Multiple D Latches [/Component 23/Sheet/] Pos=216,2072 [/Component 23/connPack/Input/] Connector Count=4 [/Component 23/connPack/Output/] Connector Count=4 [/Component 24/] Serial Number=106 Type=Boolean/Flip Flop/Multiple D Latches [/Component 24/Sheet/] Pos=568,2072 [/Component 24/connPack/Input/] Connector Count=4 [/Component 24/connPack/Output/] Connector Count=4 [/Component 25/] Serial Number=107 Type=Boolean/Flip Flop/Multiple D Latches [/Component 25/Sheet/] Pos=384,2072 [/Component 25/connPack/Input/] Connector Count=4 [/Component 25/connPack/Output/] Connector Count=4 [/Component 26/] Serial Number=108 Type=Boolean/Flip Flop/Multiple D Latches [/Component 26/Sheet/] Pos=680,2072 [/Component 26/connPack/Input/] Connector Count=4 [/Component 26/connPack/Output/] Connector Count=4 [/Component 27/] Serial Number=110 Type=Boolean/Gates/AND [/Component 27/Sheet/] Pos=376,1528 [/Component 27/connPack/Input/] Connector Count=3 [/Component 28/] Serial Number=111 Type=Boolean/Gates/AND [/Component 28/Sheet/] Pos=96,1800 [/Component 28/connPack/Input/] Connector Count=2 [/Component 29/] Serial Number=112 Type=Boolean/Gates/AND [/Component 29/Sheet/] Pos=344,1112 [/Component 29/connPack/Input/] Connector Count=3 [/Component 3/] Serial Number=22 Type=Boolean/Gates/AND [/Component 3/Sheet/] Pos=272,504 [/Component 3/connPack/Input/] Connector Count=2 [/Component 30/] Serial Number=113 Type=Boolean/Gates/AND [/Component 30/Sheet/] Pos=368,1280 [/Component 30/connPack/Input/] Connector Count=3 [/Component 31/] Serial Number=114 Type=Boolean/Gates/AND [/Component 31/Sheet/] Pos=376,1376 [/Component 31/connPack/Input/] Connector Count=3 [/Component 32/] Serial Number=115 Type=Boolean/Gates/AND [/Component 32/Conn0/] Neg=true [/Component 32/Sheet/] Pos=208,1000 [/Component 32/connPack/Input/] Connector Count=2 [/Component 33/] Serial Number=116 Type=Boolean/Gates/AND [/Component 33/Conn0/] Neg=true [/Component 33/Sheet/] Pos=192,1152 [/Component 33/connPack/Input/] Connector Count=2 [/Component 34/] Serial Number=117 Type=Boolean/Gates/AND [/Component 34/Sheet/] Pos=200,1280 [/Component 34/connPack/Input/] Connector Count=2 [/Component 35/] Serial Number=118 Type=Boolean/Gates/AND [/Component 35/Conn0/] Neg=true [/Component 35/Sheet/] Pos=200,1440 [/Component 35/connPack/Input/] Connector Count=2 [/Component 36/] Serial Number=119 Type=Boolean/Gates/AND [/Component 36/Conn0/] Neg=true [/Component 36/Sheet/] Pos=264,1304 [/Component 36/connPack/Input/] Connector Count=2 [/Component 37/] Serial Number=120 Type=Boolean/Gates/AND [/Component 37/Sheet/] Pos=200,1624 [/Component 37/connPack/Input/] Connector Count=2 [/Component 38/] Serial Number=121 Type=Boolean/Gates/AND [/Component 38/Sheet/] Pos=200,1328 [/Component 38/connPack/Input/] Connector Count=2 [/Component 39/] Serial Number=122 Type=Boolean/Gates/AND [/Component 39/Sheet/] Pos=96,1712 [/Component 39/connPack/Input/] Connector Count=2 [/Component 4/] Serial Number=23 Type=Boolean/Flip Flop/Multiple D Latches [/Component 4/Sheet/] Pos=512,2072 [/Component 4/connPack/Input/] Connector Count=4 [/Component 4/connPack/Output/] Connector Count=4 [/Component 40/] Serial Number=123 Type=Boolean/Gates/AND [/Component 40/Sheet/] Pos=208,1568 [/Component 40/connPack/Input/] Connector Count=2 [/Component 41/] Serial Number=124 Type=Boolean/Gates/AND [/Component 41/Sheet/] Pos=224,1520 [/Component 41/connPack/Input/] Connector Count=2 [/Component 42/] Serial Number=127 Type=Boolean/Input/Const True [/Component 42/Sheet/] Pos=144,2120 [/Component 43/] Serial Number=128 Type=Boolean/Input/Const True [/Component 43/Sheet/] Pos=0,2128 [/Component 44/] Serial Number=129 Type=Boolean/Input/Const True [/Component 44/Sheet/] Pos=56,2080 [/Component 45/] Serial Number=130 Type=Boolean/Input/Const True [/Component 45/Sheet/] Pos=88,2080 [/Component 46/] Serial Number=131 Type=Boolean/Input/Const True [/Component 46/Sheet/] Pos=120,2128 [/Component 47/] Serial Number=132 Type=Boolean/Input/Const True [/Component 47/Sheet/] Pos=8,2096 [/Component 48/] Serial Number=133 Type=Boolean/Input/Const True [/Component 48/Sheet/] Pos=40,2144 [/Component 49/] Serial Number=134 Type=Boolean/Input/Const True [/Component 49/Sheet/] Pos=96,2120 [/Component 5/] Max Count=0xf Min Count=0x0 Reset Count=0x0 Serial Number=24 Type=Boolean/Counter/with RCO and RBO [/Component 5/Conn0/] Hide=false [/Component 5/Sheet/] Pos=496,336 [/Component 5/connPack/Output/] Connector Count=4 [/Component 50/] Serial Number=135 Type=Boolean/Input/Const True [/Component 50/Sheet/] Pos=72,2144 [/Component 51/] Serial Number=136 Type=Boolean/Input/Const True [/Component 51/Sheet/] Pos=0,2064 [/Component 52/] Serial Number=137 Type=Boolean/Input/Const True [/Component 52/Sheet/] Pos=120,2080 [/Component 53/] Serial Number=161 Type=Boolean/Gates/AND [/Component 53/Conn0/] Neg=true [/Component 53/Sheet/] Pos=160,1752 [/Component 53/connPack/Input/] Connector Count=2 [/Component 54/] Serial Number=171 Type=Boolean/Gates/AND [/Component 54/Sheet/] Pos=264,1544 [/Component 54/connPack/Input/] Connector Count=2 [/Component 55/] Serial Number=172 Type=Boolean/Gates/AND [/Component 55/Conn0/] Neg=true [/Component 55/Sheet/] Pos=304,1592 [/Component 55/connPack/Input/] Connector Count=2 [/Component 56/] Serial Number=182 Type=Boolean/Gates/AND [/Component 56/Sheet/] Pos=32,1936 [/Component 56/connPack/Input/] Connector Count=2 [/Component 57/] Serial Number=183 Type=Boolean/Gates/AND [/Component 57/Sheet/] Pos=48,1848 [/Component 57/connPack/Input/] Connector Count=2 [/Component 58/] Serial Number=184 Type=Boolean/Gates/AND [/Component 58/Conn0/] Neg=true [/Component 58/Sheet/] Pos=96,1888 [/Component 58/connPack/Input/] Connector Count=2 [/Component 59/] Serial Number=190 Type=Boolean/Gates/AND [/Component 59/Sheet/] Pos=8,2008 [/Component 59/connPack/Input/] Connector Count=2 [/Component 6/] Serial Number=25 Type=Boolean/Gates/Clock Generator [/Component 6/High Time/] Time=50000000 Unit=s [/Component 6/Low Time/] Time=50000000 Unit=s [/Component 6/Sheet/] Pos=264,352 [/Component 6/Start Delay/] Time=0 Unit=s [/Component 60/] Serial Number=194 Type=Boolean/Input/Const True [/Component 60/Sheet/] Pos=24,2072 [/Component 61/] Serial Number=198 Type=Boolean/Input/Const True [/Component 61/Sheet/] Pos=80,2032 [/Component 62/] Serial Number=200 Type=Boolean/Gates/XOR [/Component 62/Sheet/] Pos=800,48 [/Component 62/connPack/Input/] Connector Count=3 [/Component 63/] Serial Number=206 Type=Boolean/Input/Const True [/Component 63/Sheet/] Pos=1024,136 [/Component 64/] Max Count=0xf Min Count=0x0 Reset Count=0x0 Serial Number=217 Type=Boolean/Counter/with RCO and RBO [/Component 64/Sheet/] Pos=1544,568 [/Component 64/connPack/Output/] Connector Count=4 [/Component 65/] Serial Number=228 Type=Boolean/Gates/AND [/Component 65/Sheet/] Pos=1280,792 [/Component 65/connPack/Input/] Connector Count=3 [/Component 66/] Serial Number=238 Type=Boolean/Gates/AND [/Component 66/Sheet/] Pos=1608,280 [/Component 66/connPack/Input/] Connector Count=2 [/Component 67/] Serial Number=239 Type=Boolean/Gates/AND [/Component 67/Sheet/] Pos=1600,392 [/Component 67/connPack/Input/] Connector Count=2 [/Component 68/] Serial Number=240 Type=Boolean/Gates/AND [/Component 68/Conn0/] Neg=true [/Component 68/Sheet/] Pos=1688,336 [/Component 68/connPack/Input/] Connector Count=2 [/Component 69/] Serial Number=252 Type=Boolean/Gates/AND [/Component 69/Sheet/] Pos=1168,728 [/Component 69/connPack/Input/] Connector Count=3 [/Component 7/] Serial Number=37 Type=Boolean/Input/Const True [/Component 7/Sheet/] Pos=176,2144 [/Component 70/] Serial Number=256 Type=Boolean/Input/Const True [/Component 70/Sheet/] Pos=1168,448 [/Component 71/] Serial Number=288 Type=Boolean/Gates/AND [/Component 71/Sheet/] Pos=1544,520 [/Component 71/connPack/Input/] Connector Count=2 [/Component 72/] Serial Number=295 Type=Boolean/Gates/Clock Generator [/Component 72/High Time/] Time=5000000000 Unit=s [/Component 72/Low Time/] Time=5000000000 Unit=s [/Component 72/Sheet/] Pos=1224,872 [/Component 72/Start Delay/] Time=10000000000 Unit=s [/Component 73/] Serial Number=297 Type=Boolean/Flip Flop/D Latch [/Component 73/Conn2/] Hide=false [/Component 73/Conn3/] Hide=false [/Component 73/Sheet/] Pos=1400,792 [/Component 74/] Serial Number=109 Type=Boolean/Flip Flop/Multiple D Latches [/Component 74/Sheet/] Pos=1296,296 [/Component 74/connPack/Input/] Connector Count=4 [/Component 74/connPack/Output/] Connector Count=4 [/Component 75/] Serial Number=328 Type=Boolean/Gates/XNOR [/Component 75/Sheet/] Pos=1440,328 [/Component 75/connPack/Input/] Connector Count=2 [/Component 76/] Serial Number=329 Type=Boolean/Gates/XNOR [/Component 76/Sheet/] Pos=1448,280 [/Component 76/connPack/Input/] Connector Count=2 [/Component 77/] Serial Number=330 Type=Boolean/Gates/XNOR [/Component 77/Sheet/] Pos=1464,216 [/Component 77/connPack/Input/] Connector Count=2 [/Component 78/] Serial Number=331 Type=Boolean/Gates/XNOR [/Component 78/Sheet/] Pos=1448,376 [/Component 78/connPack/Input/] Connector Count=2 [/Component 79/] Serial Number=332 Type=Boolean/Flip Flop/Multiple D Latches [/Component 79/Sheet/] Pos=952,528 [/Component 79/connPack/Input/] Connector Count=4 [/Component 79/connPack/Output/] Connector Count=4 [/Component 8/] Serial Number=38 Type=Boolean/Input/Const True [/Component 8/Sheet/] Pos=56,2112 [/Component 80/] Frame Enabled=false Name=9 Serial Number=1 Type=Boolean/Input/Button [/Component 80/Sheet/] Pos=712,296 Size=88,24 [/Component 80/User/] Pos=0,32 Size=80,24 [/Component 81/] Frame Enabled=false Name=2 Serial Number=2 Type=Boolean/Input/Button [/Component 81/Sheet/] Pos=832,240 Size=88,24 [/Component 81/User/] Pos=0,64 Size=80,24 [/Component 82/] Frame Enabled=false Name=3 Serial Number=3 Type=Boolean/Input/Button [/Component 82/Sheet/] Pos=960,232 Size=88,24 [/Component 82/User/] Pos=0,96 Size=80,24 [/Component 83/] Frame Enabled=false Name=4 Serial Number=4 Type=Boolean/Input/Button [/Component 83/Sheet/] Pos=952,272 Size=88,24 [/Component 83/User/] Pos=0,128 Size=80,24 [/Component 84/] Frame Enabled=false Name=5 Serial Number=5 Type=Boolean/Input/Button [/Component 84/Sheet/] Pos=816,176 Size=88,24 [/Component 84/User/] Pos=0,160 Size=80,24 [/Component 85/] Frame Enabled=false Name=6 Serial Number=6 Type=Boolean/Input/Button [/Component 85/Sheet/] Pos=968,192 Size=88,24 [/Component 85/User/] Pos=0,192 Size=80,24 [/Component 86/] Frame Enabled=false Name=7 Serial Number=7 Type=Boolean/Input/Button [/Component 86/Sheet/] Pos=712,184 Size=88,24 [/Component 86/User/] Pos=0,224 Size=80,24 [/Component 87/] Frame Enabled=false Name=8 Serial Number=8 Type=Boolean/Input/Button [/Component 87/Sheet/] Pos=824,280 Size=88,24 [/Component 87/User/] Pos=0,256 Size=80,24 [/Component 88/] Frame Enabled=false Name=1 Serial Number=9 Type=Boolean/Input/Button [/Component 88/Sheet/] Pos=1112,248 Size=88,24 [/Component 88/User/] Pos=0,288 Size=80,24 [/Component 89/] Frame Enabled=false Name=0 Serial Number=10 Type=Boolean/Input/Button [/Component 89/Sheet/] Pos=824,120 Size=88,24 [/Component 89/User/] Pos=0,320 Size=80,24 [/Component 9/] Serial Number=39 Type=Boolean/Input/Const True [/Component 9/Sheet/] Pos=160,2072 [/Component 90/] Frame Enabled=false Name=+ Serial Number=11 Type=Boolean/Input/Button [/Component 90/Sheet/] Pos=1112,288 Size=88,24 [/Component 90/User/] Pos=0,352 Size=80,24 [/Component 91/] Frame Enabled=false Name== Serial Number=12 Type=Boolean/Input/Button [/Component 91/Sheet/] Pos=1168,480 Size=88,24 [/Component 91/User/] Pos=0,384 Size=80,24 [/Component 92/] Serial Number=16 Type=Boolean/Output/LED [/Component 92/Sheet/] Pos=368,64 Size=32,24 [/Component 92/User/] Pos=0,416 Size=24,24 [/Component 93/] Serial Number=17 Type=Boolean/Output/LED [/Component 93/Sheet/] Pos=424,32 Size=32,24 [/Component 93/User/] Pos=0,448 Size=24,24 [/Component 94/] Serial Number=20 Type=Boolean/Output/7 Segment Display [/Component 94/Sheet/] Pos=1200,376 Size=64,80 [/Component 94/User/] Pos=32,416 Size=32,48 [/Component 95/] Frame Enabled=false Name=clear Serial Number=26 Type=Boolean/Input/Button [/Component 95/Sheet/] Pos=696,120 Size=88,24 [/Component 95/User/] Pos=32,464 Size=80,24 [/Component 96/] Serial Number=209 Type=Boolean/Output/LED [/Component 96/Sheet/] Pos=1384,264 Size=32,24 [/Component 96/User/] Pos=32,0 Size=24,24 [/Component 97/] Serial Number=210 Type=Boolean/Output/LED [/Component 97/Sheet/] Pos=1368,328 Size=32,24 [/Component 97/User/] Pos=64,0 Size=24,24 [/Component 98/] Serial Number=211 Type=Boolean/Output/LED [/Component 98/Sheet/] Pos=1376,296 Size=32,24 [/Component 98/User/] Pos=64,416 Size=24,24 [/Component 99/] Serial Number=212 Type=Boolean/Output/LED [/Component 99/Sheet/] Pos=1384,224 Size=32,24 [/Component 99/User/] Pos=80,32 Size=24,24 [/Document Property/] Last View=Sheet View Sheet Pos=1106,175 User Pos=0,0 [/Document Property/Timing/] Dummy=true [/Document Property/Timing/Execution/] Time=10000000 Unit=s [/Document Property/Timing/Simulation/] Sychronized=true Time=10000000 Unit=s [/Document Property/Timing/Update/] Sychronized=true Time=10000000 Unit=s [/Property/] Last Serial Number=345 Sheetsize=2536,2168 Usersize=1000,504 [/Property/Module/] Pixmap Store=Absolute ViewType=None
