#include <12F683.h>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOCPD                    //No EE protection
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES PUT                      //Power Up Timer
#FUSES NOBROWNOUT               //No brownout reset
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#use delay(clock=4000000)
//#use rs232(baud=9600,parity=N,xmit=PIN_A3,rcv=PIN_A2,bits=8)
void main()
   setup_adc_ports(NO_ANALOGS|VSS_VDD);
   setup_adc(ADC_OFF);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED,0,1);
   setup_comparator(NC_NC);
   setup_vref(FALSE);
   setup_oscillator(OSC_4MHZ);
while(1)
      Output_high (PIN_A5);   //A portA 5-ös kimenete legyen H szintű
      Delay_ms(500);          //Várakozz most 0,5 másodpercet és addig ne csinálj semmit
      Output_low (PIN_A5);    //A portA 5-ös kimenete legyen L szintű
