; Binary LED Clock
; By Hein Ragas
; http://home.publishnet.nl/~hragas
; Version 1.0
; Clock functionality ONLY
	title "Binary LED Clock"
	ifdef __16F716
		list P = 16F716
		include		<p16f716.inc>
		__config	_XT_OSC & _WDT_OFF & _PWRTE_ON
	endif
	ifdef __16F627
		list P = 16F627
		include		<p16f627.inc>
		__config	_XT_OSC & _WDT_OFF & _PWRTE_ON & _LVP_OFF
	endif
	ifdef __16F627A
		list P = 16F627A
		include		<p16f627A.inc>
	endif
	ifdef __16F628
		list P = 16F628
		include <p16F628.inc>
		__CONFIG _CP_OFF & _XT_OSC & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _BODEN_OFF & _LVP_OFF
	endif
	ifdef __16F628A
		list P = 16F628A
		include <p16F628A.inc>
	endif
	ifdef __16F870
		list P = 16F870
		include <p16F870.inc>
		__CONFIG _CP_OFF & _XT_OSC & _WDT_OFF & _PWRTE_ON & _BODEN_OFF & _LVP_OFF
	endif
	ifdef __16F872
		list P = 16F872
		include <p16F872.inc>
	endif
	ifdef __16F873
		list P = 16F873
		include <p16F873.inc>
	endif
	ifdef __16F873A
		list P = 16F873A
		include <p16F873A.inc>
	endif
	ifdef __16F876
		list P = 16F876
		include <p16F876.inc>
	endif
	ifdef __16F876A
		list P = 16F876A
		include <p16F876A.inc>
	endif
; Variables for delay loop
teller		EQU	070h
teller2	    EQU	071h
; Variables for time-keeping
sece		EQU	072h	; Second units
sect		EQU	073h	; Second tens
mine		EQU	07Bh	; Minute units
mint		EQU	07Ch	; Minute tens
hre			EQU	07Dh	; Hour units
hrt			EQU	07Eh	; Hour tens
; Variables for the one second timer
bres_hi		EQU	076h	; hi byte of our 24bit variable
bres_mid	EQU	077h	; mid byte
bres_lo		EQU	078h	; lo byte
; Variables to save register statusses during interrupt
temp_s		EQU	079h
temp_w		EQU	07Ah
; Variables for debouncing and inputs
bounce_timer	EQU	07Fh	; Counter for the debounce routine
csa			EQU	060h
cva			EQU	061h
count_A		EQU	062h
count_B		EQU	063h
prev_val	EQU	064h
		org		0x0
		GOTO	init
        ORG	0x4		; Choose starting adress
; Interrupt routine. This is called every 256 instructions.
isr		MOVWF	temp_w          ; save w register
        MOVF	STATUS, W       ; W = STATUS
		clrf	STATUS
        MOVWF	temp_s          ; save STATUS register
          	; First, see if we need to call the debouncing routine
          	; We don't call the debouncing routine every interrupt, but every 10
          	;   interrupts. That's once every 2560 instructions. Because an input needs
          	;   to be the same for 4 consecutive calls to the debouncing routine, it
          	;   needs to be the same for roughly 0.01 seconds.
        DECFSZ	bounce_timer, f	; Decrement bounce_timer, see if it's 0
		GOTO 	bookkeeping	; Not 0, skip the debouncing routine
		MOVLW	009h		; Bounce_timer == 0
		MOVWF	bounce_timer; Reset bounce_timer to 9
		CALL	read_inputs
		CALL	debounce
		CALL	process_inputs
          	; Here comes the bookkeeping for the timer routine
bookkeeping
		TSTF	bres_mid	; first test for mid==0
		SKPNZ				; nz = no underflow needed
		DECF	bres_hi,f	; z, so is underflow, so dec the msb
		DECFSZ	bres_mid,f	; dec the mid byte (subtract 256)
		GOTO	end_isr	; nz, so definitely not one second yet.
		TSTF	bres_hi	; test hi for zero too
		SKPZ				; z = both hi and mid are zero, is one second!
		GOTO	end_isr	; nz, so not one second yet.
		MOVLW	0x0F		; get msb value 
		MOVWF	bres_hi	; load in msb
		MOVLW 	0x42		; get mid value
		MOVWF 	bres_mid	; load in mid
		MOVLW 	0x40		; lsb value to add
		ADDWF 	bres_lo,f	; add it to the remainder already in lsb
		SKPNC				; nc = no overflow, so mid is still ok
		INCF	bres_mid,f	; c, so lsb overflowed, so inc mid
        CALL 	continue	; A second has passed, increase the second count          	
		; End of the interrupt routine
end_isr
       	BCF		INTCON, T0IF; clear the TMR0 flag bit
		MOVF	temp_s, W	; Put STATUS and W back where they belong
        MOVWF	STATUS
        SWAPF	temp_w, F
        SWAPF	temp_w, W
        RETFIE				; Return from interrupt
; Initialisation routine
init	BSF 	STATUS,5	; Choose bank 1
		CLRF	TRISA		; All pins of port A are outputs
		CLRF	TRISB		; All pins of port B are outputs...
		BSF		TRISB, 6
		BSF		TRISB, 7	; ...except for the last two
	ifdef	TRISC
		clrf	TRISC
	endif
		MOVLW	b'10001000'	; Set the options (prescaler for watchdog timer)
		MOVWF	OPTION_REG
		movlw	0x07
	ifdef	ADCON1
		movwf	ADCON1
	endif
	ifdef	CMCON
		movwf	CMCON
	endif
	    BCF 	STATUS,5	; Choose bank 0
		CALL	 initial_vals	; Set initial values
		MOVWF 	bres_hi		; put in hi
		MOVLW 	0x42 +1		; get mid value (note we added 1 to it)
		MOVWF 	bres_mid	; put in mid
		MOVLW 	0x40		; get lsb value
		MOVWF 	bres_lo		; put in mid
		CLRF	INTCON
		BSF		INTCON, T0IE
		BSF		INTCON, GIE	; Set Timer interrupt
; Routine to show the numbers on the display
shownumbers		
		MOVLW	000h
		MOVWF	PORTB		; All LEDs off
		MOVF	sece,w		; Load sece into W
		MOVWF	PORTA		; Set the LEDs
		BSF		PORTB, 0	; Show the first row
		CALL 	delay		; Call our delay routine
		MOVLW	000h
		MOVF	sect,w		; Load sect in W
		BSF		PORTB, 1	; Show the second row
		CALL 	delay
		MOVLW	000h
		MOVF	mine,w		; Load mine into W
		BSF		PORTB, 2	; Show the third row
		CALL 	delay
		MOVLW	000h
		MOVF	mint,w		; Load mint into W
		BSF		PORTB, 3	; Show the fourth row
		CALL 	delay
		MOVLW	000h
		MOVF	hre,w		; Load hre into W
		BSF		PORTB, 4	; Show the fifth row
		CALL 	delay
		MOVLW	000h
		MOVF	hrt,w		; Load hrt into W
		BSF		PORTB, 5	; Show the sixth row
		CALL 	delay
		GOTO 	shownumbers	; Just keep on showing those numbers -- the
							;   rest of the functionality is called from the interrupt
							;   routine.
; This routine is called whenever a second has passed.
continue
		INCF	sece, 1		; Increase sece
		MOVF	sece, w
		ADDLW	0F6h		; sece > 9?
		SKPNC
		GOTO 	overflow_sece; sece == 10, so increment sect
		RETURN
overflow_sece
		CLRF	sece		; Set sece back to 0
		INCF	sect, 1		; Increase sect with 1
		MOVF	sect, w
		ADDLW	0FAh		; sect > 5?
		SKPNC
		GOTO 	overflow_sect	; sect == 5, so increment mine
		RETURN
overflow_sect
		CLRF	sect		; Set sect back to 0
		CLRF	sece
		INCF	mine, 1		; Increase mine
		MOVF	mine, w
		ADDLW	0F6h		; mine > 9?
		SKPNC
		GOTO 	overflow_mine; mine == 10, so increment sect
		RETURN
overflow_mine
		CLRF	mine		; Set mine back to 0
		INCF	mint, 1		; Increase mint
		MOVF	mint, w
		ADDLW	0FAh		; mint > 5?
		SKPNC
		GOTO 	overflow_mint; mint == 5, so increment hre
		RETURN
overflow_mint
		CLRF	mint		; Reset mint to 0
incr_hre
		INCF	hre, 1		; Increase hre
		MOVF	hre, w
		ADDLW	0FCh		; hre > 4?
		SKPNC
		GOTO 	check_hre	; hre > 4, so we need to check whether we need
							;   to overflow hrt
		RETURN
check_hre
		MOVF	hrt, w
		ADDLW	0FEh		; hrt > 1?
		SKPNC
		GOTO	overflow_hre; hrt == 2, hre == 5 -> overflow!
		MOVF	hre, w		; hrt == 1
		ADDLW	0F6h		; hre > 9?
		SKPNC
		GOTO	overflow_hre; hrt == 1, hre == 10 -> overflow!
		RETURN
overflow_hre
		CLRF	hre			; Reset hre to 0
		INCF	hrt, 1		; Increase hrt
		MOVF	hrt, w
		ADDLW	0FDh		; hrt > 2?
		SKPNC
		GOTO 	overflow_hrt; hrt == 2; overflow hrt (it's midnight!)
		RETURN
overflow_hrt
		CLRF	sece		; Midnight, reset everything to 0!
		CLRF	sect
		CLRF	mine
		CLRF	mint
		CLRF	hre
		CLRF	hrt
		RETURN
; Sets the initial values. We start 9 seconds before midnight!
initial_vals
		MOVLW	001h
		MOVWF	sece
		CLRF	sect
		CLRF	mine
		CLRF	mint
		CLRF	hre
		CLRF	hrt
		MOVLW	005h
		MOVWF	sect
		MOVLW	009h
		MOVWF	mine
		MOVLW	005h
		MOVWF	mint
		MOVLW	003h
		MOVWF	hre
		MOVLW	002h
		MOVWF	hrt
		; Also, set the variables for the counters etc.
		MOVLW	009h
		MOVWF	bounce_timer
		CLRF	csa
		CLRF	cva
		CLRF	count_A
		CLRF	count_B
		CLRF	prev_val
		RETURN
; Our delay loop. Waits roughly 1000 instructions, that's 1 msec
delay					
		MOVLW	00Ah		;10 times...
		MOVWF	teller
outerloop
		MOVLW	064h		;100 times...
		MOVWF	teller2
innerloop
		DECFSZ	teller2, 1
		GOTO	innerloop
		DECFSZ	teller, 1
		GOTO	outerloop
		RETURN
; Read the inputs
read_inputs	
		; Check minute pin, sets the appropriate bit in the csa variable
		BTFSC	PORTB, 6
		GOTO	minute_een
minute_nul
		BCF	csa, 0
		GOTO	einde_minute
minute_een
		BSF	csa, 0
einde_minute
		; Check hour pin, sets the appropriate bit in the csa variable
		BTFSC	PORTB, 7
		GOTO	hour_een
hour_nul
		BCF	csa, 1
		GOTO	einde_hour
hour_een
		BSF	csa, 1
einde_hour
		RETURN
; Debounce routine
debounce
		;Increment the vertical counter
		MOVF    count_B,W
		XORWF   count_A,F
		COMF    count_B,F
		;See if any changes occurred
		MOVF    csa,W
		XORWF   cva,W
		;Reset the counter if no change has occurred
		ANDWF   count_B,F
		ANDWF   count_A,F
		;Determine the counter's state
		MOVF    count_B,W
		IORWF   count_A,W
		;Clear all bits that are filtered-or more accurately, save
		;the state of those that are being filtered
		ANDWF   cva,F
		XORLW   0xff
		;Re-write the bits that haven't changed.
		ANDWF   csa,W
		IORWF   cva,F
		RETURN
; Process the debounced inputs
; We have two variables to work with: prev_val, which contains the previous (debounced) states of the inputs;
;   and cva, the debounced current state of the inputs.
; Each input is set as a bit in both the variables.
process_inputs
								; Check the previous value of the minute-input
		BTFSS	prev_val, 0
		GOTO	minute_was_zero
minute_was_one
		BTFSS	cva, 0
		BCF		prev_val, 0		; from 1 to 0 -> reset prev_val to 0
		GOTO	check_hour
minute_was_zero
		BTFSC	cva, 0
		GOTO	minute_press
		GOTO	check_hour
minute_press
		BSF		prev_val, 0
		CALL	overflow_sect	; from 0 to 1 -> tick!
check_hour						; Check the previous value of the hour input
		BTFSS	prev_val, 1
		GOTO	hour_was_zero
hour_was_one
		BTFSS	cva, 1
		BCF		prev_val, 1		; from 1 to 0 -> reset prev_val to 0
		RETURN
hour_was_zero
		BTFSC	cva, 1
		GOTO	hour_press
		RETURN
hour_press
		BSF		prev_val, 1
		CALL	incr_hre		; from 0 to 1 -> tick!
		RETURN
		END
