; CLOCK	10MHz
errorlevel 2
list p=16f88
include "p16f88.inc"
__CONFIG    _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_OFF & _PWRTE_OFF & _WDT_OFF &_HS_OSC 
;MAKRÓK  
JNZ MACRO J1		;ugrás ha nem nulla
BTFSS	STATUS,2
GOTO	J1
ENDM
JZ	MACRO J2		;ugrás ha nulla
BTFSC	STATUS,2
GOTO	J2
ENDM
JNC MACRO J3		;ugrás, ha carry alacsony
BTFSS	STATUS,0
GOTO	J3
ENDM
JC	MACRO J4		;ugrás ha carry magas
BTFSC	STATUS,0
GOTO	J4
ENDM
CLC	MACRO			;CARRY TÖRLÉSE
BCF	STATUS,0
ENDM
SEC MACRO			;CARRY =1
BSF	STATUS,0
ENDM
#DEFINE MEMLAP0		STATUS,RP0
#DEFINE MEMLAP1 	STATUS,RP1
CBLOCK	0X20
W_		;W MENTÉSE VAGY ÁTMENETI REGISZTER
AC0		;SEGÉDREG	
AC1		;SEGÉDREG		
AC2		;SEGÉDREG
SZ1		;SZÁMLÁLÓ
SZ2
ADATH	;PARANCS FELSŐBYTE
ADATL	;PARANCS ALSÓBYTE
COUNT1	;SZÁMLÁLÓ
COUNT2
endc
#define SDO 	PORTB,7	;IN
#define NSEL	PORTB,5	;OUT
#define SCK 	PORTB,4	;OUT
#define SDI 	PORTB,3	;OUT
#DEFINE	LED		PORTB,0	;OUT
#DEFINE NUM		6		;6DB SZÁM MEGY KI
#DEFINE TABL	0X70    ;IDE KELL TENNI AZ 5 DB SZÁMOT
#DEFINE	SUM		TABL+5	;A 6. A KISZÁMOLT ÖSSZEG LESZ
org	0x00
CALL	INIT
GOTO	PRG
NOP
NOP
RETFIE ;NINCS MEGSZAK.
INIT
	CLRF	PORTB
	CLRF	PORTA
	BSF		MEMLAP0
	MOVLW	B'11000000'
	MOVWF		TRISB
	MOVLW	B'00000000'
	MOVWF		ANSEL		;EGYENLŐRE MIND I/O
	BCF		MEMLAP0
	BSF		NSEL
	BCF		SCK	
	CLRF	COUNT1
	CLRF	COUNT2
	CALL	RXINIT		;MODULINIT
	RETURN
D20mS
	MOVLW	0XED;
	MOVWF	SZ1
	MOVLW	0X41
	MOVWF	SZ2
D00	DECFSZ	SZ1
	GOTO	D00
	DECFSZ	SZ2
	GOTO	D00
	RETURN
D250u
	MOVLW	0XCD	;250uSEC KÉSLELTETÉS
DX	MOVWF		SZ1		
	MOVLW	0X01
	MOVWF		SZ2
D20	DECFSZ	SZ1
	GOTO	D20
	DECFSZ	SZ2
	GOTO	D20
	NOP
	RETURN
RXINIT
	CALL	D20mS	;ALAP 1MHz MIATT MÉG 200mSEC
	MOVLW	0X80	;nem írjuk újra az azonos parancsokat (POR)
	MOVWF	ADATH	;tehát csak a szükségeseket
	MOVLW	0XA8
	MOVWF	ADATL
	CALL	WRITECMD	;enable TX REGISTER,868MHz,12.5pF
	MOVLW	0X82
	MOVWF	ADATH
	MOVLW	0X08
	MOVWF	ADATL
	CALL	WRITECMD	; !receive,!PA,CRIST OSC,SZINTÉZER, CLKOUT
	MOVLW	0XC6
	MOVWF	ADATH
	MOVLW	0X11		;19.157 BAUDRATE 
	MOVWF	ADATL
	CALL	WRITECMD
	MOVLW	0X90
	MOVWF	ADATH
	MOVLW	0X60		;VDI,FAST,270kHz,0dBm,-103dBm
	MOVWF	ADATL
	CALL	WRITECMD
	MOVLW	0XC2
	MOVWF	ADATH
	MOVLW	0XAC		
	MOVWF	ADATL
	CALL	WRITECMD;Data Filter Command
	MOVLW	0XC4
	MOVWF	ADATH
	MOVLW	0X83		
	MOVWF	ADATL
	CALL	WRITECMD;
	MOVLW	0X98
	MOVWF	ADATH
	MOVLW	0X68	;105kHZ -10.5DB		
	MOVWF	ADATL
	CALL	WRITECMD
	MOVLW	0XE0
	MOVWF	ADATH
	CLRF	ADATL
	CALL	WRITECMD
	MOVLW	0XC0
	MOVWF	ADATH
	MOVLW	0XE0	;clock 10MHz PIC részére			
	MOVWF	ADATL
	CALL	WRITECMD
	RETURN
ADATKI
	MOVWF	ADATL	;ADAT
	MOVLW	0XB8	;ADÁSPARANCSKÓD
	MOVWF	ADATH
	BCF		SDI
AD1	BCF		NSEL	
	BSF		SCK
	BTFSC	SDO		;VÁRUNK A FOGADÓ JELRE( A SZIMULÁCIÓHOZ KIMENENEK
					;KELL DEFINIÁLNI AZ SDO LÁBAT,EZUTÁN ÍRHATÓ AZ SDO
					;SZINTJE TEHÁT A 80. SOR IGY MÓDOSUL:
					;MOVLW	0X00
					; A BPORT 7.BITJÉNEK MAGASRA ÁLLÍTÁSÁVAL LEHET TESZTELNI
					;ÉGETÉS ELŐTT VISSZAÁLLÍTANI A HELYES ÉRTÉKET!)
	GOTO	AD0
	BCF		SCK
	BSF		NSEL
	GOTO	AD1
AD0	BCF		SCK
	BSF		NSEL	;MEHET A BYTE
WRITECMD
	BSF		COUNT2,4	;16 lépés
	BCF		NSEL
W01	BCF		SCK
	RLF		ADATL,F
	RLF		ADATH,F
	BSF		SDI
	JC		W00
	BCF		SDI
W00	BSF		SCK
	DECFSZ	COUNT2
	GOTO	W01
	BCF		SCK
	BSF		NSEL
	RETURN
DATAOUT
	MOVLW	0X82
	MOVWF	ADATH
	MOVLW	0X38	;0X28
	MOVWF	ADATL
	CALL	WRITECMD	;p.a. ÉS SZINTÉZER  bekapcs
	CALL	D250u		;250uSEC VÁRAKOZÁS KELL IDE!
	BSF		LED
	MOVLW	NUM			;KÜLDENDŐ ADATOK SZÁMA
	MOVWF	COUNT1	 
	CLRF	SUM		;ELLENÖRZŐ ÖSSZEG = 0
	MOVLW	TABL	;INDIREKT MUTATÓ ADATOK ELEJÉRE
	MOVWF	FSR
	MOVLW	0XAA		;ELSŐ BYTE
	CALL	ADATKI
	MOVLW	0XAA	;78 uSec + VÁRAKOZÁS READY
	CALL	ADATKI
	MOVLW	0XAA
	CALL	ADATKI
	MOVLW	0X2D	;ID0
	CALL	ADATKI
	MOVLW	0XD4	;ID1
	CALL	ADATKI
P00	MOVF	INDF,0	;110.8uSEC
	ADDWF	SUM,F	;ELLENÖRZŐÖSSZEGHEZ HOZZÁADÁS
	CALL	ADATKI
	INCF	FSR
	DECFSZ	COUNT1
	GOTO	P00
	MOVLW	0XAA
	CALL	ADATKI
	MOVLW	0XAA
	CALL	ADATKI
	MOVLW	0X82
	MOVWF	ADATH
	MOVLW	0X08
	MOVWF	ADATL
	CALL	WRITECMD	;ADÓFOKOZAT LEÁLLÍTÁSA
	BCF		LED			;
	RETURN
PRG	
	CALL	DATAOUT	;1,43 mSEC ADATÁTVITEL
	CALL	D20mS
	GOTO	PRG
END
;FONTOS, HOGY AZ ADÓT KI ÉS BEKAPCSOLJUK, MERT JELEN BEÁLLÍTÁSBAN 
;1,4mSec IDEIG MEGY ÉS 20 mSEC IDEIG NEM AZ ADÓ IGY NEM ZAVARJA 
;ÁLLANDÓAN A KÖRNYEZETET ÉS A FOGYASZTÁS IS CSAK 250mA HELYETT
;17.5 mA. (RFM12BP)
