;// Code Generator: BoostC Compiler - http://www.sourceboost.com
;// Version       : 6.95
;// License Type  : Full License
;// Limitations   : PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited, Non commercial use only
	include "P16F887.inc"
; Heap block 0, size:111 (0x00000110 - 0x0000017E)
__HEAP_BLOCK0_BANK               EQU	0x00000002
__HEAP_BLOCK0_START_OFFSET       EQU	0x00000010
__HEAP_BLOCK0_END_OFFSET         EQU	0x0000007E
; Heap block 1, size:96 (0x00000190 - 0x000001EF)
__HEAP_BLOCK1_BANK               EQU	0x00000003
__HEAP_BLOCK1_START_OFFSET       EQU	0x00000010
__HEAP_BLOCK1_END_OFFSET         EQU	0x0000006F
; Heap block 2, size:80 (0x000000A0 - 0x000000EF)
__HEAP_BLOCK2_BANK               EQU	0x00000001
__HEAP_BLOCK2_START_OFFSET       EQU	0x00000020
__HEAP_BLOCK2_END_OFFSET         EQU	0x0000006F
; Heap block 3, size:25 (0x00000057 - 0x0000006F)
__HEAP_BLOCK3_BANK               EQU	0x00000000
__HEAP_BLOCK3_START_OFFSET       EQU	0x00000057
__HEAP_BLOCK3_END_OFFSET         EQU	0x0000006F
gbl_status                       EQU	0x00000003 ; bytes:1
gbl_16_LSR                       EQU	0x00000020 ; bytes:4
gbl_float_detect_tininess        EQU	0x00000039 ; bytes:1
gbl_float_rounding_mode          EQU	0x0000003A ; bytes:1
gbl_float_exception_flags        EQU	0x0000003B ; bytes:1
gbl_17_gbl_aSig                  EQU	0x00000024 ; bytes:4
gbl_17_gbl_bSig                  EQU	0x00000028 ; bytes:4
gbl_17_gbl_zSig                  EQU	0x0000002C ; bytes:4
gbl_17_gbl_aExp                  EQU	0x0000003C ; bytes:1
gbl_17_gbl_bExp                  EQU	0x0000003D ; bytes:1
gbl_17_gbl_zExp                  EQU	0x00000037 ; bytes:2
gbl_17_gbl_aSign                 EQU	0x0000003E ; bytes:1
gbl_17_gbl_bSign                 EQU	0x0000003F ; bytes:1
gbl_17_gbl_zSign                 EQU	0x00000040 ; bytes:1
gbl_17_gbl_zSigZero              EQU	0x00000041 ; bytes:1
gbl_17_gbl_ret                   EQU	0x00000030 ; bytes:4
gbl_indf                         EQU	0x00000000 ; bytes:1
gbl_tmr0                         EQU	0x00000001 ; bytes:1
gbl_pcl                          EQU	0x00000002 ; bytes:1
gbl_fsr                          EQU	0x00000004 ; bytes:1
gbl_porta                        EQU	0x00000005 ; bytes:1
gbl_portb                        EQU	0x00000006 ; bytes:1
gbl_portc                        EQU	0x00000007 ; bytes:1
gbl_portd                        EQU	0x00000008 ; bytes:1
gbl_porte                        EQU	0x00000009 ; bytes:1
gbl_pclath                       EQU	0x0000000A ; bytes:1
gbl_intcon                       EQU	0x0000000B ; bytes:1
gbl_pir1                         EQU	0x0000000C ; bytes:1
gbl_pir2                         EQU	0x0000000D ; bytes:1
gbl_tmr1l                        EQU	0x0000000E ; bytes:1
gbl_tmr1h                        EQU	0x0000000F ; bytes:1
gbl_t1con                        EQU	0x00000010 ; bytes:1
gbl_tmr2                         EQU	0x00000011 ; bytes:1
gbl_t2con                        EQU	0x00000012 ; bytes:1
gbl_sspbuf                       EQU	0x00000013 ; bytes:1
gbl_sspcon                       EQU	0x00000014 ; bytes:1
gbl_ccpr1l                       EQU	0x00000015 ; bytes:1
gbl_ccpr1h                       EQU	0x00000016 ; bytes:1
gbl_ccp1con                      EQU	0x00000017 ; bytes:1
gbl_rcsta                        EQU	0x00000018 ; bytes:1
gbl_txreg                        EQU	0x00000019 ; bytes:1
gbl_rcreg                        EQU	0x0000001A ; bytes:1
gbl_ccpr2l                       EQU	0x0000001B ; bytes:1
gbl_ccpr2h                       EQU	0x0000001C ; bytes:1
gbl_ccp2con                      EQU	0x0000001D ; bytes:1
gbl_adresh                       EQU	0x0000001E ; bytes:1
gbl_adcon0                       EQU	0x0000001F ; bytes:1
gbl_option_reg                   EQU	0x00000081 ; bytes:1
gbl_trisa                        EQU	0x00000085 ; bytes:1
gbl_trisb                        EQU	0x00000086 ; bytes:1
gbl_trisc                        EQU	0x00000087 ; bytes:1
gbl_trisd                        EQU	0x00000088 ; bytes:1
gbl_trise                        EQU	0x00000089 ; bytes:1
gbl_pie1                         EQU	0x0000008C ; bytes:1
gbl_pie2                         EQU	0x0000008D ; bytes:1
gbl_pcon                         EQU	0x0000008E ; bytes:1
gbl_osccon                       EQU	0x0000008F ; bytes:1
gbl_osctune                      EQU	0x00000090 ; bytes:1
gbl_sspcon2                      EQU	0x00000091 ; bytes:1
gbl_pr2                          EQU	0x00000092 ; bytes:1
gbl_sspadd                       EQU	0x00000093 ; bytes:1
gbl_sspmsk                       EQU	0x00000093 ; bytes:1
gbl_msk                          EQU	0x00000093 ; bytes:1
gbl_sspstat                      EQU	0x00000094 ; bytes:1
gbl_wpub                         EQU	0x00000095 ; bytes:1
gbl_iocb                         EQU	0x00000096 ; bytes:1
gbl_vrcon                        EQU	0x00000097 ; bytes:1
gbl_txsta                        EQU	0x00000098 ; bytes:1
gbl_spbrg                        EQU	0x00000099 ; bytes:1
gbl_spbrgh                       EQU	0x0000009A ; bytes:1
gbl_pwm1con                      EQU	0x0000009B ; bytes:1
gbl_eccpas                       EQU	0x0000009C ; bytes:1
gbl_pstrcon                      EQU	0x0000009D ; bytes:1
gbl_adresl                       EQU	0x0000009E ; bytes:1
gbl_adcon1                       EQU	0x0000009F ; bytes:1
gbl_wdtcon                       EQU	0x00000105 ; bytes:1
gbl_cm1con0                      EQU	0x00000107 ; bytes:1
gbl_cm2con0                      EQU	0x00000108 ; bytes:1
gbl_cm2con1                      EQU	0x00000109 ; bytes:1
gbl_eedata                       EQU	0x0000010C ; bytes:1
gbl_eeadr                        EQU	0x0000010D ; bytes:1
gbl_eedath                       EQU	0x0000010E ; bytes:1
gbl_eeadrh                       EQU	0x0000010F ; bytes:1
gbl_srcon                        EQU	0x00000185 ; bytes:1
gbl_baudctl                      EQU	0x00000187 ; bytes:1
gbl_ansel                        EQU	0x00000188 ; bytes:1
gbl_anselh                       EQU	0x00000189 ; bytes:1
gbl_eecon1                       EQU	0x0000018C ; bytes:1
gbl_eecon2                       EQU	0x0000018D ; bytes:1
Wdt_msDela_00045_1_i             EQU	0x00000048 ; bytes:1
Wdt_Delay__00047_arg_delay       EQU	0x00000044 ; bytes:2
Wdt_Delay__00047_1_i             EQU	0x00000046 ; bytes:2
CompTempVar2178                  EQU	0x00000048 ; bytes:1
FCD_LCDDis_0004A_arg_in          EQU	0x00000053 ; bytes:1
FCD_LCDDis_0004A_arg_mask        EQU	0x00000054 ; bytes:1
FCD_LCDDis_0004A_1_pt            EQU	0x00000055 ; bytes:1
FCD_LCDDis_00049_arg_Character   EQU	0x00000042 ; bytes:1
FCD_LCDDis_00048_arg_x           EQU	0x00000042 ; bytes:1
FCD_LCDDis_00048_arg_y           EQU	0x00000043 ; bytes:1
FCD_LCDDis_0004F_arg_String      EQU	0x00000042 ; bytes:2
FCD_LCDDis_0004F_arg_MSZ_String  EQU	0x00000051 ; bytes:1
FCD_LCDDis_0004F_1_idx           EQU	0x00000052 ; bytes:1
CompTempVar2234                  EQU	0x00000044 ; bytes:12
CompTempVar2236                  EQU	0x00000044 ; bytes:13
CompTempVar2238                  EQU	0x00000044 ; bytes:13
CompTempVar2240                  EQU	0x00000044 ; bytes:12
delay_us_00000_arg_del           EQU	0x00000049 ; bytes:1
delay_10us_00000_arg_del         EQU	0x00000056 ; bytes:1
delay_ms_00000_arg_del           EQU	0x00000043 ; bytes:1
delay_s_00000_arg_del            EQU	0x00000042 ; bytes:1
Int1Context                      EQU	0x0000007F ; bytes:1
Int1BContext                     EQU	0x00000034 ; bytes:3
	ORG 0x00000000
	GOTO	_startup
	ORG 0x00000004
	MOVWF Int1Context
	SWAPF STATUS, W
	BCF STATUS, RP0
	BCF STATUS, RP1
	MOVWF Int1BContext
	SWAPF PCLATH, W
	MOVWF Int1BContext+D'1'
	SWAPF FSR, W
	MOVWF Int1BContext+D'2'
	BCF PCLATH,3
	BCF PCLATH,4
	GOTO	interrupt
	ORG 0x00000010
delay_us_00000
; { delay_us ; function begin
	MOVLW 0x03
	ADDWF delay_us_00000_arg_del, F
	RRF delay_us_00000_arg_del, F
	MOVLW 0x7F
	ANDWF delay_us_00000_arg_del, F
label1
	NOP
	DECFSZ delay_us_00000_arg_del, F
	GOTO	label1
	RETURN
; } delay_us function end
	ORG 0x0000001A
delay_10us_00000
; { delay_10us ; function begin
label2
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	DECFSZ delay_10us_00000_arg_del, F
	GOTO	label2
	RETURN
; } delay_10us function end
	ORG 0x00000024
delay_ms_00000
; { delay_ms ; function begin
	MOVF delay_ms_00000_arg_del, F
	BTFSS STATUS,Z
	GOTO	label3
	RETURN
label3
	MOVLW 0xF9
label4
	ADDLW 0xFF
	BTFSS STATUS,Z
	GOTO	label4
	NOP
	DECFSZ delay_ms_00000_arg_del, F
	GOTO	label3
	RETURN
; } delay_ms function end
	ORG 0x00000030
delay_s_00000
; { delay_s ; function begin
label5
	MOVLW 0xFA
	MOVWF delay_ms_00000_arg_del
	CALL delay_ms_00000
	MOVLW 0xFA
	CALL delay_ms_00000
	MOVLW 0xFA
	CALL delay_ms_00000
	MOVLW 0xFA
	CALL delay_ms_00000
	DECFSZ delay_s_00000_arg_del, F
	GOTO	label5
	RETURN
; } delay_s function end
	ORG 0x0000003F
Wdt_msDela_00045
; { Wdt_msDelay ; function begin
	BCF STATUS, RP0
	BCF STATUS, RP1
	CLRF Wdt_msDela_00045_1_i
label6
	MOVLW 0x4B
	SUBWF Wdt_msDela_00045_1_i, W
	BTFSC STATUS,C
	RETURN
	CLRWDT
	MOVLW 0x0A
	MOVWF delay_us_00000_arg_del
	CALL delay_us_00000
	INCF Wdt_msDela_00045_1_i, F
	GOTO	label6
; } Wdt_msDelay function end
	ORG 0x0000004C
Wdt_Delay__00047
; { Wdt_Delay_Ms ; function begin
	CLRF Wdt_Delay__00047_1_i
	CLRF Wdt_Delay__00047_1_i+D'1'
label7
	MOVF Wdt_Delay__00047_1_i+D'1', W
	XORLW 0x80
	MOVWF CompTempVar2178
	MOVF Wdt_Delay__00047_arg_delay+D'1', W
	XORLW 0x80
	SUBWF CompTempVar2178, W
	BTFSS STATUS,Z
	GOTO	label8
	MOVF Wdt_Delay__00047_arg_delay, W
	SUBWF Wdt_Delay__00047_1_i, W
label8
	BTFSC STATUS,C
	RETURN
	CALL Wdt_msDela_00045
	INCF Wdt_Delay__00047_1_i, F
	BTFSC STATUS,Z
	INCF Wdt_Delay__00047_1_i+D'1', F
	GOTO	label7
; } Wdt_Delay_Ms function end
	ORG 0x0000005F
FCD_LCDDis_0004A
; { FCD_LCDDisplay1_RawSend ; function begin
	BCF gbl_portb,0
	BCF gbl_portb,1
	BCF gbl_portb,2
	BCF gbl_portb,3
	BCF gbl_portb,4
	BCF gbl_portb,5
	SWAPF FCD_LCDDis_0004A_arg_in, W
	ANDLW 0x0F
	MOVWF FCD_LCDDis_0004A_1_pt
	MOVLW 0x0F
	ANDWF FCD_LCDDis_0004A_1_pt, F
	BTFSC FCD_LCDDis_0004A_1_pt,0
	BSF gbl_portb,0
	BTFSC FCD_LCDDis_0004A_1_pt,1
	BSF gbl_portb,1
	BTFSC FCD_LCDDis_0004A_1_pt,2
	BSF gbl_portb,2
	BTFSC FCD_LCDDis_0004A_1_pt,3
	BSF gbl_portb,3
	MOVF FCD_LCDDis_0004A_arg_mask, F
	BTFSS STATUS,Z
	BSF gbl_portb,4
	MOVLW 0x0A
	MOVWF delay_10us_00000_arg_del
	CALL delay_10us_00000
	BSF gbl_portb,5
	MOVLW 0x0A
	BCF gbl_portb,5
	MOVLW 0x0F
	ANDWF FCD_LCDDis_0004A_arg_in, W
	MOVLW 0x0A
	BCF gbl_portb,0
	BCF gbl_portb,1
	BCF gbl_portb,2
	BCF gbl_portb,3
	BCF gbl_portb,4
	BCF gbl_portb,5
	BSF gbl_portb,0
	BSF gbl_portb,1
	BSF gbl_portb,2
	BSF gbl_portb,3
	BTFSS STATUS,Z
	BSF gbl_portb,4
	MOVLW 0x0A
	BSF gbl_portb,5
	MOVLW 0x0A
	BCF gbl_portb,5
	MOVLW 0x0A
	RETURN
; } FCD_LCDDisplay1_RawSend function end
	ORG 0x000000A0
FCD_LCDDis_00049
; { FCD_LCDDisplay1_PrintASCII ; function begin
	MOVF FCD_LCDDis_00049_arg_Character, W
	MOVWF FCD_LCDDis_0004A_arg_in
	MOVLW 0x10
	MOVWF FCD_LCDDis_0004A_arg_mask
	CALL FCD_LCDDis_0004A
	RETURN
; } FCD_LCDDisplay1_PrintASCII function end
	ORG 0x000000A6
FCD_LCDDis_00048
; { FCD_LCDDisplay1_Cursor ; function begin
	MOVF FCD_LCDDis_00048_arg_y, F
	BTFSS STATUS,Z
	GOTO	label9
	MOVLW 0x80
	MOVWF FCD_LCDDis_00048_arg_y
	GOTO	label10
label9
	MOVLW 0xC0
label10
	MOVF FCD_LCDDis_00048_arg_x, W
	ADDWF FCD_LCDDis_00048_arg_y, W
	CLRF FCD_LCDDis_0004A_arg_mask
	MOVLW 0x02
	MOVWF Wdt_Delay__00047_arg_delay
	CLRF Wdt_Delay__00047_arg_delay+D'1'
	CALL Wdt_Delay__00047
	RETURN
; } FCD_LCDDisplay1_Cursor function end
	ORG 0x000000B8
FCM_HELLO_00000
; { FCM_HELLO ; function begin
	MOVLW 0x02
	BCF STATUS, RP0
	BCF STATUS, RP1
	MOVWF FCD_LCDDis_00048_arg_x
	CLRF FCD_LCDDis_00048_arg_y
	CALL FCD_LCDDis_00048
	MOVLW 0x48
	MOVWF FCD_LCDDis_00049_arg_Character
	CALL FCD_LCDDis_00049
	MOVLW 0x45
	MOVLW 0x4C
	MOVLW 0x4C
	MOVLW 0x4F
	MOVLW 0x20
	MOVLW 0x57
	MOVLW 0x4F
	MOVLW 0x52
	MOVLW 0x4C
	MOVLW 0x44
	MOVLW 0x2E
	RETURN
; } FCM_HELLO function end
	ORG 0x000000E3
FCD_LCDDis_0004F
; { FCD_LCDDisplay1_PrintString ; function begin
	CLRF FCD_LCDDis_0004F_1_idx
label11
	MOVF FCD_LCDDis_0004F_arg_MSZ_String, W
	SUBWF FCD_LCDDis_0004F_1_idx, W
	BTFSC STATUS,C
	RETURN
	BCF STATUS,IRP
	BTFSC FCD_LCDDis_0004F_arg_String+D'1',0
	BSF STATUS,IRP
	MOVF FCD_LCDDis_0004F_arg_String, W
	ADDWF FCD_LCDDis_0004F_1_idx, W
	MOVWF FSR
	MOVF INDF, F
	BTFSC STATUS,Z
	RETURN
	BCF STATUS,IRP
	BSF STATUS,IRP
	MOVWF FSR
	MOVF INDF, W
	MOVLW 0x10
	INCF FCD_LCDDis_0004F_1_idx, F
	GOTO	label11
; } FCD_LCDDisplay1_PrintString function end
	ORG 0x000000FF
FCD_LCDDis_0004C
; { FCD_LCDDisplay1_Clear ; function begin
	MOVLW 0x01
	BCF STATUS, RP0
	BCF STATUS, RP1
	MOVLW 0x02
	MOVLW 0x02
	MOVLW 0x02
	RETURN
; } FCD_LCDDisplay1_Clear function end
	ORG 0x00000112
FCD_LCDDis_0004B
; { FCD_LCDDisplay1_Start ; function begin
	BSF STATUS, RP0
	BCF STATUS, RP1
	BCF gbl_trisb,0
	BCF gbl_trisb,1
	BCF gbl_trisb,2
	BCF gbl_trisb,3
	BCF gbl_trisb,4
	BCF gbl_trisb,5
	MOVLW 0x0C
	BCF STATUS, RP0
	MOVLW 0x33
	MOVLW 0x02
	MOVLW 0x33
	MOVLW 0x02
	MOVLW 0x32
	MOVLW 0x02
	MOVLW 0x2C
	MOVLW 0x02
	MOVLW 0x06
	MOVLW 0x02
	MOVLW 0x0C
	MOVLW 0x02
	MOVLW 0x01
	MOVLW 0x02
	MOVLW 0x02
	MOVLW 0x02
	RETURN
; } FCD_LCDDisplay1_Start function end
	ORG 0x00000160
main
; { main ; function begin
	BSF STATUS, RP0
	BSF STATUS, RP1
	CLRF gbl_ansel
	CLRF gbl_anselh
	MOVLW 0xC0
	BCF STATUS, RP1
	MOVWF gbl_option_reg
	CALL FCD_LCDDis_0004B
label12
	MOVLW 0x01
	MOVWF delay_s_00000_arg_del
	CALL delay_s_00000
	MOVLW 0x02
	MOVLW 0x20
	MOVWF CompTempVar2234+D'5'
	MOVLW 0x44
	MOVWF CompTempVar2234+D'10'
	MOVLW 0x45
	MOVWF CompTempVar2234+D'1'
	MOVLW 0x48
	MOVLW 0x4C
	MOVWF CompTempVar2234+D'2'
	MOVWF CompTempVar2234+D'3'
	MOVWF CompTempVar2234+D'9'
	MOVLW 0x4F
	MOVWF CompTempVar2234+D'4'
	MOVWF CompTempVar2234+D'7'
	MOVLW 0x52
	MOVWF CompTempVar2234+D'8'
	MOVLW 0x57
	MOVWF CompTempVar2234+D'6'
	CLRF CompTempVar2234+D'11'
	MOVLW HIGH(CompTempVar2234+D'0')
	MOVWF FCD_LCDDis_0004F_arg_String+D'1'
	MOVLW LOW(CompTempVar2234+D'0')
	MOVLW 0x0B
	MOVWF FCD_LCDDis_0004F_arg_MSZ_String
	CALL FCD_LCDDis_0004F
	MOVLW 0x02
	MOVLW 0x01
	MOVLW 0x20
	MOVWF CompTempVar2236+D'5'
	MOVWF CompTempVar2236+D'11'
	MOVLW 0x64
	MOVWF CompTempVar2236+D'10'
	MOVLW 0x65
	MOVWF CompTempVar2236+D'1'
	MOVLW 0x68
	MOVLW 0x6C
	MOVWF CompTempVar2236+D'2'
	MOVWF CompTempVar2236+D'3'
	MOVWF CompTempVar2236+D'9'
	MOVLW 0x6F
	MOVWF CompTempVar2236+D'4'
	MOVWF CompTempVar2236+D'7'
	MOVLW 0x72
	MOVWF CompTempVar2236+D'8'
	MOVLW 0x77
	MOVWF CompTempVar2236+D'6'
	CLRF CompTempVar2236+D'12'
	MOVLW HIGH(CompTempVar2236+D'0')
	MOVLW LOW(CompTempVar2236+D'0')
	MOVLW 0x0C
	MOVLW 0x02
	CALL delay_s_00000
	MOVLW 0x02
	MOVLW 0x20
	MOVWF CompTempVar2238+D'5'
	MOVWF CompTempVar2238+D'11'
	MOVLW 0x64
	MOVWF CompTempVar2238+D'10'
	MOVLW 0x65
	MOVWF CompTempVar2238+D'1'
	MOVLW 0x68
	MOVLW 0x6C
	MOVWF CompTempVar2238+D'2'
	MOVWF CompTempVar2238+D'3'
	MOVWF CompTempVar2238+D'9'
	MOVLW 0x6F
	MOVWF CompTempVar2238+D'4'
	MOVWF CompTempVar2238+D'7'
	MOVLW 0x72
	MOVWF CompTempVar2238+D'8'
	MOVLW 0x77
	MOVWF CompTempVar2238+D'6'
	CLRF CompTempVar2238+D'12'
	MOVLW HIGH(CompTempVar2238+D'0')
	MOVLW LOW(CompTempVar2238+D'0')
	MOVLW 0x0C
	MOVLW 0x02
	MOVLW 0x01
	MOVLW 0x20
	MOVWF CompTempVar2240+D'5'
	MOVLW 0x44
	MOVWF CompTempVar2240+D'10'
	MOVLW 0x45
	MOVWF CompTempVar2240+D'1'
	MOVLW 0x48
	MOVLW 0x4C
	MOVWF CompTempVar2240+D'2'
	MOVWF CompTempVar2240+D'3'
	MOVWF CompTempVar2240+D'9'
	MOVLW 0x4F
	MOVWF CompTempVar2240+D'4'
	MOVWF CompTempVar2240+D'7'
	MOVLW 0x52
	MOVWF CompTempVar2240+D'8'
	MOVLW 0x57
	MOVWF CompTempVar2240+D'6'
	CLRF CompTempVar2240+D'11'
	MOVLW HIGH(CompTempVar2240+D'0')
	MOVLW LOW(CompTempVar2240+D'0')
	MOVLW 0x0B
	MOVLW 0x02
	CALL delay_s_00000
	CALL FCD_LCDDis_0004C
	MOVLW 0x01
	CALL delay_ms_00000
	CALL FCM_HELLO_00000
	GOTO	label12
; } main function end
	ORG 0x000001F7
_startup
	MOVLW 0xD5
	BCF STATUS, RP0
	BCF STATUS, RP1
	MOVWF gbl_16_LSR
	MOVLW 0xC4
	MOVWF gbl_16_LSR+D'1'
	MOVLW 0xBB
	MOVWF gbl_16_LSR+D'2'
	MOVLW 0xDC
	MOVWF gbl_16_LSR+D'3'
	CLRF gbl_17_gbl_aSig
	CLRF gbl_17_gbl_aSig+D'1'
	CLRF gbl_17_gbl_aSig+D'2'
	CLRF gbl_17_gbl_aSig+D'3'
	CLRF gbl_17_gbl_bSig
	CLRF gbl_17_gbl_bSig+D'1'
	CLRF gbl_17_gbl_bSig+D'2'
	CLRF gbl_17_gbl_bSig+D'3'
	CLRF gbl_17_gbl_zSig
	CLRF gbl_17_gbl_zSig+D'1'
	CLRF gbl_17_gbl_zSig+D'2'
	CLRF gbl_17_gbl_zSig+D'3'
	CLRF gbl_17_gbl_aExp
	CLRF gbl_17_gbl_bExp
	CLRF gbl_17_gbl_zExp
	CLRF gbl_17_gbl_zExp+D'1'
	CLRF gbl_17_gbl_aSign
	CLRF gbl_17_gbl_bSign
	CLRF gbl_17_gbl_zSign
	CLRF gbl_17_gbl_zSigZero
	CLRF gbl_17_gbl_ret
	CLRF gbl_17_gbl_ret+D'1'
	CLRF gbl_17_gbl_ret+D'2'
	CLRF gbl_17_gbl_ret+D'3'
	CLRF gbl_float_rounding_mode
	CLRF gbl_float_exception_flags
	CLRF gbl_float_detect_tininess
	BCF PCLATH,3
	BCF PCLATH,4
	GOTO	main
	ORG 0x0000021F
interrupt
; { interrupt ; function begin
	BCF STATUS, RP0
	BCF STATUS, RP1
	SWAPF Int1BContext+D'2', W
	MOVWF FSR
	SWAPF Int1BContext+D'1', W
	MOVWF PCLATH
	SWAPF Int1BContext, W
	MOVWF STATUS
	SWAPF Int1Context, F
	SWAPF Int1Context, W
	RETFIE
; } interrupt function end
	ORG 0x00002007
	DW 0x3FE1
	DW 0x3FFF
	END
