 * Project name:
     Lcd_Test (Demonstration of the LCD library routines)
 * Copyright:
     (c) Mikroelektronika, 2009.
 * Revision History:
     20080930:
       - initial release;
       - 20090720 - modified by Slavisa Zlatanovic;
 * Description:
     This code demonstrates how to use LCD 4-bit library. LCD is first
     initialized, then some text is written, then the text is moved.
 * Test configuration:
     MCU:             PIC16F887
                      http://ww1.microchip.com/downloads/en/DeviceDoc/41291F.pdf
     Dev.Board:       EasyPIC6 - ac:LCD
                      http://www.mikroe.com/eng/products/view/297/easypic6-development-system/
     Oscillator:      HS, 08.0000 MHz
     Ext. Modules:    Character LCD 2x16
                      http://www.mikroe.com/eng/categories/view/43/components/#other
     SW:              mikroC PRO for PIC
                      http://www.mikroe.com/eng/products/view/7/mikroc-pro-for-pic/
 * NOTES:
     - Turn on LCD backlight switch (SW6.8) on the development board.
// LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
char txt1[] = "mikroElektronika";    
char txt2[] = "EasyPIC6";
char txt3[] = "Lcd4bit";
char txt4[] = "example";
char i;                              // Loop variable
void Move_Delay() {                  // Function used for text moving
  Delay_ms(500);                     // You can change the moving speed here
void main(){
  ANSEL  = 0;                        // Configure AN pins as digital I/O
  ANSELH = 0;
  C1ON_bit = 0;                      // Disable comparators
  C2ON_bit = 0;
  Lcd_Init();                        // Initialize LCD
  Lcd_Cmd(_LCD_CLEAR);               // Clear display
  Lcd_Cmd(_LCD_CURSOR_OFF);          // Cursor off
  Lcd_Out(1,6,txt3);                 // Write text in first row
  Lcd_Out(2,6,txt4);                 // Write text in second row
  Delay_ms(2000);
  Lcd_Out(1,1,txt1);                 // Write text in first row
  Lcd_Out(2,5,txt2);                 // Write text in second row
  Delay_ms(2000);
  // Moving text
  for(i=0; i<4; i++) {               // Move text to the right 4 times
    Lcd_Cmd(_LCD_SHIFT_RIGHT);
    Move_Delay();
  while(1) {                         // Endless loop
    for(i=0; i<8; i++) {             // Move text to the left 7 times
      Lcd_Cmd(_LCD_SHIFT_LEFT);
      Move_Delay();
    for(i=0; i<8; i++) {             // Move text to the right 7 times
      Move_Delay();
