; VF_Controller.asm
; Voltage-Frequency Converter
; PIC 12F683 firmware
; to drive my VF Controller Mk II circuit
; V1.00: tested OK with scope on breadboard.
; did not test it with the switching
; hardware yet.
; tjl Sep 20,2007
; This program implements a half-bridge voltage-frequency
; speed controller for small single phase shaded pole
; induction motors.
; Speed range is from approx 60 Hz to 20 Hz, with the
; voltage reduced by the following formula:
; motor V = design V * motor freq / design freq
; The wiper of a pot connected between +5v and ground
; is connected to physical pin 3. The pot setting
; determines the motor speed.
; Active low -> open outputs on physical pins 7 and 6
; drive the high side and low side half-H switches,
; respectively.
; A half-cycle sinewave is synthesized via PWM, and
; appears as an active high PWM signal on physical
; pin 5.
; Connect pins 7 and 6 to the cathodes of optoisolator
; LEDs, and the PWM pin paralleled to the anodes through
; a 330 ohm series resistor.
; Use the optoisolator transistors to drive a high side
; P-channel MOSFET and a low side N-channel MOSFET.
; Connect the motor between the junction of the two
; MOSFETs and neutral.
; Physical pin 3 (AN3) - Speed pot
; Physical pin 5 (CCP1) - PWM output
; Physical pin 6 (GP1) - Neg Switch (active low)
; Physical pin 7 (GP0) - Pos Switch (active low)
; 12F683 RAM:
; 96 bytes in bank0, 0x20-0x7f
; 32 bytes in bank1, 0xa0-0xbf
; Program memory:
; 2k 14-bit words, 0x000-0x7ff
; Data EEPROM:
; 256 bytes, accessed through DE decls or
; the four EExxx registers
; Config section
	list p=12F683
	#include <p12F683.inc>
	__CONFIG _FCMEN_ON & _IESO_OFF & _CP_OFF & _CPD_OFF & _BOD_OFF & _MCLRE_OFF & _WDT_OFF & _PWRTE_ON & _INTOSCIO
; Radix, Defines, and Constants
	radix dec
	errorlevel -302
; I/O
#define PosSw 0
#define NegSw 1
#define PWMpin 2
#define Pot 4
; constants
#define Tmrbase 60 ; tune this for 60 Hz at max speed setting
#define PWM_val 254 ; 7.8 kHz w/ 8 MHz clock and no prescaling
; Macro definitions
bank0 macro
	bcf STATUS,RP0
	endm
bank1 macro
	bsf STATUS,RP0
	endm
; Storage
; EEPROM table data
	org 0x2100
SineTbl
	de 0,13,25,37,50,62,74,86
	de 98,109,120,131,142,152,162,171
	de 180,189,197,205,212,219,225,231
	de 236,240,244,247,250,252,254,255
	de 255,255,254,252,250,247,244,240
	de 236,231,225,219,212,205,197,189
	de 180,171,162,152,142,131,120,109
	de 98,86,74,62,50,37,25,13
VoltTbl
	de 255,247,240,233,227,221,215,210
	de 205,200,195,191,186,182,178,174
	de 171,168,164,161,158,155,152,149
	de 147,144,142,139,137,135,133,131
	de 129,126,125,123,121,119,118,116
	de 114,113,111,110,108,107,106,104
	de 103,102,101,99,98,97,96,95
	de 94,92,92,90,90,89,88,87
; Un-init RAM
	cblock 0x20
	w_bup ; save W and STATUS from ISR
	stat_bup
	semaphore ; semaphore set by ISR when TMR0 times out
	rawspeed ; raw ADC speed pot measurement value
	speedval ; speed value to load into TMR0
	sineptr ; SineTbl pointer
	sineval ; from SineTbl
	voltval ; from VoltTbl
	pwmvalhi ; high byte of sine x volt mult
	pwmvallo ; low byte of sine x volt mult
	running
	temp0
	temp1
	temp2
	temp3
	endc
; Program code begins here
	org 0 ; processor reset vector
	goto main
	org 0x04 ; interrupt vector
	goto Int_Svc_Rtn
; Interrupt service routine
Int_Svc_Rtn
	movwf w_bup ; save the W and STATUS regs
	movf STATUS,W
	movwf stat_bup
	btfss INTCON,T0IF ; TMR0 overflow?
	goto enableints ; no, just enable ints and
;;;	return
	bcf INTCON,T0IF
	movf speedval,W ; reload the TMR0 preset
	movwf TMR0
	movlw 1
	movwf semaphore ; tell SendCycle that an int has occurred
enableints
	movf stat_bup,W ; restore the W and STATUS regs
	movwf STATUS
	movf w_bup,W
;; Tilos	bsf INTCON,GIE ; enable system interrupts
	retfie
; Main program routine begins here
main
; Disable system interrupts
	bcf INTCON,GIE
; set the internal oscillator to 8 MHz
	bank1
	movlw 0x71
	movwf OSCCON
	bank0
; init I/O & ADC
	movlw 0x07
	movwf CMCON0 ; 0,1,2 are digital I/O
	bank1
	movlw b'01011000' ; AN3 analog, others digital I/O, Fosc/16
	movwf ANSEL
	movlw b'00010011' ; Preset PosSw and NegSw as inputs
	movwf TRISIO
	bank0
	movlw b'00001101' ; AN3, left-justified,ADON
	movwf ADCON0
	bcf GPIO,PWMpin ; set PWM output low
; set up PWM
	call StartPWM
; begin
	clrf running ; force parm init at first
	call	GetSpeed
	call Dly1Sec ; 1 sec pause to let HV pwr supply settle
mainloop
	call GetSpeed
	call SetPosPhase
	call SendCycle
	call SetNegPhase
	call SendCycle
	goto mainloop
; Subroutines
PWMcalc ; 8 x 8 unsigned mult of sineval x voltval
; result in pwmvalhi and pwmvallo
; modifies sineval, temp0,temp1,temp3
	bank0
	clrf pwmvalhi
	clrf pwmvallo
	movf voltval,W
	movwf temp0 ; holds low byte of shifted voltval
	clrf temp1 ; holds high byte of shifted voltval
	movlw 8
	movwf temp3 ; counter
mult1
	rrf sineval,F
	btfss STATUS,C
	goto mult2
	movf temp0,W
	addwf pwmvallo,F
	btfss STATUS,C
	goto mult3
	incf pwmvalhi,F
mult3 movf temp1,W
	addwf pwmvalhi,F
mult2 bcf STATUS,C
	rlf temp0,F
	rlf temp1,F
	decfsz temp3,F
	goto mult1
	return
LoadPWM ; pwmvalhi to CCPR1L, pwmvallo<7:6> to CCP1CON<5:4>
	bank0
	bcf CCP1CON,5
	bcf CCP1CON,4
	btfsc pwmvallo,7
	bsf CCP1CON,5
	btfsc pwmvallo,6
	bsf CCP1CON,4
	movf pwmvalhi,W
	movwf CCPR1L
	return
GetSpeed ; read speed pot setting, set delay,
; then set TMR0 and semaphore
	bsf ADCON0,1 ; start an ADC measurement
	btfss PIR1,ADIF ; wait for completion
	goto $-1
	bcf PIR1,ADIF
	movf ADRESH,W ; get the reading
	movwf temp0
	movf running,F ; running?
	btfss STATUS,Z
	goto gslp2 ; if not, force parm initialization
	movlw 1
	movwf running
	goto gslp1
gslp2 subwf rawspeed,W ; exit if it speed pot setting has not changed
	btfsc STATUS,Z
	return
gslp1 movf temp0,W ; save the new reading
	movwf rawspeed
	comf temp0,F ; subtract speed reading from 255...
	bcf STATUS,C ; ...and divide it by 4
	rrf temp0,F
	bcf STATUS,C
	rrf temp0,F ; temp0 contains 0 (max) to 63 (min)
	movlw low(VoltTbl) ; calc addr of volt table
	addwf temp0,W
	call EERead
	movwf voltval
	bcf STATUS,C ; double the speed index
	rlf temp0,F
	movlw Tmrbase ; add speed factor to timer base value
	addwf temp0,W
	movwf speedval
	comf speedval,F ; subtract from 256 (255), save as TMR0
; preload value
	bcf INTCON,GIE ; disable interrupts
	movf TMR0,F ; write to TMR0
	bcf INTCON,T0IF
	bsf INTCON,T0IE
	clrf semaphore ; clear interrupt semaphore
	bsf INTCON,GIE ; enable interrupts
	return
SendCycle ; set pwm from sine table and volts tbl,
; wait for interrupt, set next step's vals
	clrf sineptr
sclp1 movf sineptr,W ; get sine value
	call EERead
	movwf sineval
	call PWMcalc ; calc PWM from sine & pre-calc'd volts val
	call LoadPWM ; set new PWM duty cycle
	movf semaphore,F ; wait for TMR0 interrupt
	btfsc STATUS,Z
	goto $-2
	clrf semaphore
	incf sineptr,F ; loop through the sine table
	movlw 64 ; (SineTbl size)
	subwf sineptr,W
	btfss STATUS,Z
	goto sclp1
	return
EERead ; EEPROM read. Enter with addr in W,
; exit with data in W
	bank1
	movwf EEADR
	bsf EECON1,RD
	movf EEDAT,W
	bank0
	return
SetPosPhase ; Open PWM path to Q1
	bank0
	bsf GPIO,NegSw
	bsf GPIO,PosSw
	bank1
	movlw b'0010010'
	movwf TRISIO
	bank0
	bcf GPIO,PosSw
	return
SetNegPhase ; Open PWM path to Q2
	bank0
	bsf GPIO,PosSw
	bsf GPIO,NegSw
	bank1
	movlw b'0010001'
	movwf TRISIO
	bank0
	bcf GPIO,NegSw
	return
StartPWM ; Set up and start PWM
	bank1
	bsf TRISIO,PWMpin ; Disable the PWM output pin
	movlw PWM_val ; Set the PWM period into TMR2
	movwf PR2
	bank0
	movlw b'00001100' ; Set CCP module for PWM mode
	movwf CCP1CON
	movlw 0 ; Inital duty cycle = 0%
	movwf CCPR1L
	clrf T2CON ; Set TMR2 scalers for 1:1
	bsf T2CON,TMR2ON ; Start TMR2
	bcf PIR1,TMR2IF ; Clear TMR2's interrupt flag
	btfss PIR1,TMR2IF ; Wait for TMR2 overflow
	goto $-1
	bcf PIR1,TMR2IF
	bank1 ; Start PWM by setting the PWM pin
	bcf TRISIO,PWMpin ; as an output
	bank0
	return
Dly1Sec ; 1 sec delay at 8 MHz
	movlw 7
	bank1
	movwf OPTION_REG ; set for 1:256 prescaling for TMR0
	bank0
	movlw 31
	movwf temp0
dlylp clrf TMR0 ; TMR0: 254 ticks of 256 instr cycles
	bcf INTCON,T0IF
	btfss INTCON,T0IF
	goto $-1
	decf temp0,F
	btfss STATUS,Z
	goto dlylp
	movlw 1
	bank1
	movwf OPTION_REG ; restore 1:4 prescaling for TMR0
	bank0
	return
end
