Release notes for EAGLE 6.1.1 ============================= * Miscellaneous: - Add an icon for cutout polygons to the parameter bar of the POLYGON command in board and package editor. If the layer is changed to a non signal layer, the pour style switches to the default "solid". * Bugfixes: - Fixed a possible crash after removing a device in the library editor. - Fixed routing to off-grid contacts, in particular rotated ones. - Fixed a crash if running the CAM processor with a board containing an invalid polygon. - Fixed a bug in the Autorouter/Follow-me router ignoring holes in packages. - Added handling of blanks in device, gate, package and symbol names if updating files from older versions by substitution with '_'. - Enhanced resolution in dialog input fields according to the increased resolution of coordinates. - Fixed copying from the empty variant in the connect dialog (library editor). - Fixed handling of alignment tag of attributes if reading a V6 drawing - Fixed subtracting mirrored texts from polygons if placed in packages. - Fix for crash in CAM processor in case of polygons with 'positive coordinates' switched off. - Fixed copying instances if selected with an offset (jump effect of instances in COPY). - Resolve consistency problem after CHANGE PACKAGE for packages with pads names starting with '+' or '-'. - Ensure that the new polygon pour style "cutout" is only used if the polygon is in a signal layer (1-16). - Fixed deleting polygon edges: Drop the currently calculated polygon data for correct update after delete. - Copy-Paste: Adapt net class of pasted net if net with same name already exists. - ULP: Fix syntax problem for instances() loop of UL_SHEET. - Fixed renaming of signal polygons: The polygon sometimes vanishes if already calculated. - Fixed UNDO/REDO renaming of calculated signal polygons: Drop the obsolete calculation. - Fixed a crash if mirroring instances during MOVE command if a pin is directly connected to another. - Fixed possible corruptness of symbol names after drag&drop of devices from control panel into the library editor. - Fixed the DRC calculation of 'Stop Mask' errors of long/offset pads.
