<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.05" unitdist="inch" unit="mm" style="lines" multiple="1" display="no" altdistance="0.025" altunitdist="inch" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="0" y1="0" x2="100" y2="0" width="0" layer="20"/>
<wire x1="100" y1="0" x2="100" y2="80" width="0" layer="20"/>
<wire x1="100" y1="80" x2="0" y2="80" width="0" layer="20"/>
<wire x1="0" y1="80" x2="0" y2="0" width="0" layer="20"/>
<hole x="2.54" y="76.2" drill="0.6"/>
<hole x="2.54" y="2.54" drill="0.6"/>
<hole x="97.79" y="2.54" drill="0.6"/>
<hole x="97.79" y="77.47" drill="0.6"/>
<text x="88.9" y="76.2" size="1.778" layer="16" rot="MR0">By Boros</text>
<dimension x1="0" y1="0" x2="0" y2="80.01" x3="-2.54" y3="40.005" layer="1"/>
<dimension x1="0" y1="0" x2="100.33" y2="0" x3="50.165" y3="-5.08" layer="1"/>
</plain>
<libraries>
<library name="con-amp">
<description>&lt;b&gt;AMP Connectors&lt;/b&gt;&lt;p&gt;
RJ45 Jack connectors&lt;br&gt;
 Based on the previous libraris:
 &lt;ul&gt;
 &lt;li&gt;amp.lbr
 &lt;li&gt;amp-j.lbr
 &lt;li&gt;amp-mta.lbr
 &lt;li&gt;amp-nlok.lbr
 &lt;li&gt;amp-sim.lbr
 &lt;li&gt;amp-micro-match.lbr
 &lt;/ul&gt;
 Sources :
 &lt;ul&gt;
 &lt;li&gt;Catalog 82066 Revised 11-95
 &lt;li&gt;Product Guide 296785 Rev. 8-99
 &lt;li&gt;Product Guide CD-ROM 1999
 &lt;li&gt;www.amp.com
 &lt;/ul&gt;
 &lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="350759-4">
<description>&lt;b&gt;Universal MATE-N-LOK&lt;/b&gt; .250" Centerline, 600 V, 19 - 36 A max&lt;p&gt;
Source: http://catalog.tycoelectronics.com/ .. ENG_CD_350759_R.pdf</description>
<wire x1="-6.1593" y1="-2.9846" x2="-6.1593" y2="0" width="0.2032" layer="21"/>
<wire x1="-5.7783" y1="-2.6036" x2="-5.7783" y2="0" width="0.2032" layer="21"/>
<wire x1="-5.7783" y1="-2.6036" x2="-6.1593" y2="-2.9846" width="0.2032" layer="21"/>
<wire x1="6.1596" y1="-2.9846" x2="0.1907" y2="-2.9846" width="0.2032" layer="21"/>
<wire x1="-0.1903" y1="-2.9846" x2="-6.1593" y2="-2.9846" width="0.2032" layer="21"/>
<wire x1="5.7786" y1="-2.6036" x2="0.5717" y2="-2.6036" width="0.2032" layer="21"/>
<wire x1="-0.5713" y1="-2.6036" x2="-5.7783" y2="-2.6036" width="0.2032" layer="21"/>
<wire x1="-0.5713" y1="-2.6036" x2="-0.1903" y2="-2.9846" width="0.2032" layer="21"/>
<wire x1="-0.5713" y1="0" x2="-0.5713" y2="-2.6036" width="0.2032" layer="21"/>
<wire x1="-0.1903" y1="0" x2="-0.1903" y2="-2.9846" width="0.2032" layer="21"/>
<wire x1="0.1907" y1="-2.9846" x2="0.1907" y2="0" width="0.2032" layer="21"/>
<wire x1="0.5717" y1="-2.6036" x2="0.5717" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.1903" y1="0" x2="-0.1907" y2="0" width="0.2032" layer="21"/>
<wire x1="0.5717" y1="-2.6036" x2="0.1907" y2="-2.9846" width="0.2032" layer="21"/>
<wire x1="5.7786" y1="-2.6036" x2="6.1596" y2="-2.9846" width="0.2032" layer="21"/>
<wire x1="5.7786" y1="0" x2="5.7786" y2="-2.6036" width="0.2032" layer="21"/>
<wire x1="6.1596" y1="0" x2="6.1596" y2="-2.9846" width="0.2032" layer="21"/>
<wire x1="-6.1596" y1="0.0636" x2="-0.1907" y2="0.0636" width="0.2032" layer="21" curve="-177.354971"/>
<wire x1="0.1903" y1="0.0636" x2="6.1593" y2="0.0636" width="0.2032" layer="21" curve="-177.358853"/>
<wire x1="-5.7786" y1="0.0636" x2="-0.5717" y2="0.0636" width="0.2032" layer="21" curve="-177.095614"/>
<wire x1="0.5713" y1="0.0636" x2="5.7783" y2="0.0636" width="0.2032" layer="21" curve="-177.012098"/>
<wire x1="0.5713" y1="0" x2="0.5713" y2="0.0636" width="0.2032" layer="21"/>
<wire x1="0.1903" y1="0" x2="0.1903" y2="0.0636" width="0.2032" layer="21"/>
<wire x1="-0.1907" y1="0.0636" x2="-0.1907" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.5717" y1="0.0636" x2="-0.5717" y2="0" width="0.2032" layer="21"/>
<wire x1="-6.875" y1="3.7" x2="6.875" y2="3.7" width="0.2032" layer="21"/>
<wire x1="6.875" y1="3.7" x2="6.875" y2="1.175" width="0.2032" layer="21"/>
<wire x1="6.875" y1="1.175" x2="6.875" y2="1.15" width="0.2032" layer="21"/>
<wire x1="6.875" y1="1.175" x2="7.225" y2="1.175" width="0.2032" layer="21"/>
<wire x1="7.225" y1="1.175" x2="7.225" y2="-1.175" width="0.2032" layer="21"/>
<wire x1="7.225" y1="-1.175" x2="6.875" y2="-1.175" width="0.2032" layer="21"/>
<wire x1="6.875" y1="-1.175" x2="6.875" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="6.875" y1="-3.7" x2="-6.875" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="-6.875" y1="-3.7" x2="-6.875" y2="-1.175" width="0.2032" layer="21"/>
<wire x1="-6.875" y1="-1.175" x2="-7.225" y2="-1.175" width="0.2032" layer="21"/>
<wire x1="-7.225" y1="-1.175" x2="-7.225" y2="1.175" width="0.2032" layer="21"/>
<wire x1="-7.225" y1="1.175" x2="-6.875" y2="1.175" width="0.2032" layer="21"/>
<wire x1="-6.875" y1="1.175" x2="-6.875" y2="3.7" width="0.2032" layer="21"/>
<wire x1="-7.25" y1="1.175" x2="-9.425" y2="1.175" width="0.2032" layer="21"/>
<wire x1="-9.425" y1="1.175" x2="-9.425" y2="-1.175" width="0.2032" layer="21"/>
<wire x1="-9.425" y1="-1.175" x2="-7.25" y2="-1.175" width="0.2032" layer="21"/>
<wire x1="7.25" y1="1.175" x2="9.425" y2="1.175" width="0.2032" layer="21"/>
<wire x1="9.425" y1="1.175" x2="9.425" y2="-1.175" width="0.2032" layer="21"/>
<wire x1="9.425" y1="-1.175" x2="7.25" y2="-1.175" width="0.2032" layer="21"/>
<wire x1="6.875" y1="-3.75" x2="6.875" y2="-4.975" width="0.2032" layer="21"/>
<wire x1="6.875" y1="-4.975" x2="5.825" y2="-4.975" width="0.2032" layer="21"/>
<wire x1="5.825" y1="-4.975" x2="5.825" y2="-3.825" width="0.2032" layer="21"/>
<wire x1="0.525" y1="-3.775" x2="0.525" y2="-4.975" width="0.2032" layer="21"/>
<wire x1="0.525" y1="-4.975" x2="-0.525" y2="-4.975" width="0.2032" layer="21"/>
<wire x1="-0.525" y1="-4.975" x2="-0.525" y2="-3.775" width="0.2032" layer="21"/>
<wire x1="-6.875" y1="-3.725" x2="-6.875" y2="-4.975" width="0.2032" layer="21"/>
<wire x1="-6.875" y1="-4.975" x2="-5.825" y2="-4.975" width="0.2032" layer="21"/>
<wire x1="-5.825" y1="-4.975" x2="-5.825" y2="-3.8" width="0.2032" layer="21"/>
<circle x="3.175" y="0" radius="1.5876" width="0.2032" layer="51"/>
<circle x="-3.175" y="0" radius="1.5877" width="0.2032" layer="51"/>
<pad name="1" x="-3.175" y="0" drill="1.8" diameter="3.81"/>
<pad name="2" x="3.175" y="0" drill="1.8" diameter="3.81"/>
<text x="0" y="2.54" size="1.016" layer="21" rot="SR90">1</text>
<text x="6.477" y="2.54" size="1.016" layer="21" rot="SR90">2</text>
<text x="-6.985" y="4.445" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="350760-4">
Source: http://catalog.tycoelectronics.com/ .. ENG_CD_350760_T.pdf</description>
<wire x1="-9.3343" y1="-2.9846" x2="-9.3343" y2="0" width="0.2032" layer="21"/>
<wire x1="-8.9533" y1="-2.6036" x2="-8.9533" y2="0" width="0.2032" layer="21"/>
<wire x1="-8.9533" y1="-2.6036" x2="-9.3343" y2="-2.9846" width="0.2032" layer="21"/>
<wire x1="9.3346" y1="-2.9846" x2="3.3657" y2="-2.9846" width="0.2032" layer="21"/>
<wire x1="-3.3653" y1="-2.9846" x2="-9.3343" y2="-2.9846" width="0.2032" layer="21"/>
<wire x1="8.9536" y1="-2.6036" x2="3.7467" y2="-2.6036" width="0.2032" layer="21"/>
<wire x1="-3.7463" y1="-2.6036" x2="-8.9533" y2="-2.6036" width="0.2032" layer="21"/>
<wire x1="-3.7463" y1="-2.6036" x2="-3.3653" y2="-2.9846" width="0.2032" layer="21"/>
<wire x1="-3.7463" y1="0" x2="-3.7463" y2="-2.6036" width="0.2032" layer="21"/>
<wire x1="-3.3653" y1="0" x2="-3.3653" y2="-2.9846" width="0.2032" layer="21"/>
<wire x1="3.3657" y1="-2.9846" x2="3.3657" y2="0" width="0.2032" layer="21"/>
<wire x1="3.7467" y1="-2.6036" x2="3.7467" y2="0" width="0.2032" layer="21"/>
<wire x1="-3.3653" y1="0" x2="-3.3657" y2="0" width="0.2032" layer="21"/>
<wire x1="3.7467" y1="-2.6036" x2="3.3657" y2="-2.9846" width="0.2032" layer="21"/>
<wire x1="8.9536" y1="-2.6036" x2="9.3346" y2="-2.9846" width="0.2032" layer="21"/>
<wire x1="8.9536" y1="0" x2="8.9536" y2="-2.6036" width="0.2032" layer="21"/>
<wire x1="9.3346" y1="0" x2="9.3346" y2="-2.9846" width="0.2032" layer="21"/>
<wire x1="-9.3346" y1="0.0636" x2="-3.3657" y2="0.0636" width="0.2032" layer="21" curve="-177.354971"/>
<wire x1="3.3653" y1="0.0636" x2="9.3343" y2="0.0636" width="0.2032" layer="21" curve="-177.358853"/>
<wire x1="-8.9536" y1="0.0636" x2="-3.7467" y2="0.0636" width="0.2032" layer="21" curve="-177.095614"/>
<wire x1="3.7463" y1="0.0636" x2="8.9533" y2="0.0636" width="0.2032" layer="21" curve="-177.012098"/>
<wire x1="3.7463" y1="0" x2="3.7463" y2="0.0636" width="0.2032" layer="21"/>
<wire x1="3.3653" y1="0" x2="3.3653" y2="0.0636" width="0.2032" layer="21"/>
<wire x1="-3.3657" y1="0.0636" x2="-3.3657" y2="0" width="0.2032" layer="21"/>
<wire x1="-3.7467" y1="0.0636" x2="-3.7467" y2="0" width="0.2032" layer="21"/>
<wire x1="-10.05" y1="3.7" x2="10.05" y2="3.7" width="0.2032" layer="21"/>
<wire x1="10.05" y1="3.7" x2="10.05" y2="1.175" width="0.2032" layer="21"/>
<wire x1="10.05" y1="1.175" x2="10.05" y2="1.15" width="0.2032" layer="21"/>
<wire x1="10.05" y1="1.175" x2="10.4" y2="1.175" width="0.2032" layer="21"/>
<wire x1="10.4" y1="1.175" x2="10.4" y2="-1.175" width="0.2032" layer="21"/>
<wire x1="10.4" y1="-1.175" x2="10.05" y2="-1.175" width="0.2032" layer="21"/>
<wire x1="10.05" y1="-1.175" x2="10.05" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="10.05" y1="-3.7" x2="-10.05" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="-10.05" y1="-3.7" x2="-10.05" y2="-1.175" width="0.2032" layer="21"/>
<wire x1="-10.05" y1="-1.175" x2="-10.4" y2="-1.175" width="0.2032" layer="21"/>
<wire x1="-10.4" y1="-1.175" x2="-10.4" y2="1.175" width="0.2032" layer="21"/>
<wire x1="-10.4" y1="1.175" x2="-10.05" y2="1.175" width="0.2032" layer="21"/>
<wire x1="-10.05" y1="1.175" x2="-10.05" y2="3.7" width="0.2032" layer="21"/>
<wire x1="-10.425" y1="1.175" x2="-12.6" y2="1.175" width="0.2032" layer="21"/>
<wire x1="-12.6" y1="1.175" x2="-12.6" y2="-1.175" width="0.2032" layer="21"/>
<wire x1="-12.6" y1="-1.175" x2="-10.425" y2="-1.175" width="0.2032" layer="21"/>
<wire x1="10.425" y1="1.175" x2="12.6" y2="1.175" width="0.2032" layer="21"/>
<wire x1="12.6" y1="1.175" x2="12.6" y2="-1.175" width="0.2032" layer="21"/>
<wire x1="12.6" y1="-1.175" x2="10.425" y2="-1.175" width="0.2032" layer="21"/>
<wire x1="10.05" y1="-3.75" x2="10.05" y2="-4.975" width="0.2032" layer="21"/>
<wire x1="10.05" y1="-4.975" x2="9" y2="-4.975" width="0.2032" layer="21"/>
<wire x1="9" y1="-4.975" x2="9" y2="-3.825" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="-3.775" x2="-2.65" y2="-4.975" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="-4.975" x2="-3.7" y2="-4.975" width="0.2032" layer="21"/>
<wire x1="-3.7" y1="-4.975" x2="-3.7" y2="-3.775" width="0.2032" layer="21"/>
<wire x1="-10.05" y1="-3.725" x2="-10.05" y2="-4.975" width="0.2032" layer="21"/>
<wire x1="-10.05" y1="-4.975" x2="-9" y2="-4.975" width="0.2032" layer="21"/>
<wire x1="-9" y1="-4.975" x2="-9" y2="-3.8" width="0.2032" layer="21"/>
<wire x1="-2.9847" y1="0.0636" x2="2.9843" y2="0.0636" width="0.2032" layer="21" curve="-177.358853"/>
<wire x1="-2.6037" y1="0.0636" x2="2.6033" y2="0.0636" width="0.2032" layer="21" curve="-177.012098"/>
<wire x1="2.9847" y1="-0.0636" x2="-2.9843" y2="-0.0636" width="0.2032" layer="21" curve="-177.358853"/>
<wire x1="2.6037" y1="-0.0636" x2="-2.6033" y2="-0.0636" width="0.2032" layer="21" curve="-177.012098"/>
<wire x1="3.7" y1="-3.775" x2="3.7" y2="-4.975" width="0.2032" layer="21"/>
<wire x1="3.7" y1="-4.975" x2="2.65" y2="-4.975" width="0.2032" layer="21"/>
<wire x1="2.65" y1="-4.975" x2="2.65" y2="-3.775" width="0.2032" layer="21"/>
<circle x="6.35" y="0" radius="1.5876" width="0.2032" layer="51"/>
<circle x="-6.35" y="0" radius="1.5877" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="1.5876" width="0.2032" layer="51"/>
<pad name="1" x="-6.35" y="0" drill="1.8" diameter="3.81"/>
<pad name="2" x="0" y="0" drill="1.8" diameter="3.81"/>
<pad name="3" x="6.35" y="0" drill="1.8" diameter="3.81"/>
<text x="-3.175" y="2.54" size="1.016" layer="21" rot="SR90">1</text>
<text x="3.302" y="2.54" size="1.016" layer="21" rot="SR90">2</text>
<text x="9.652" y="2.54" size="1.016" layer="21" rot="SR90">3</text>
<text x="-10.16" y="4.445" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="st-microelectronics">
<description>&lt;b&gt;ST Microelectronics Devices&lt;/b&gt;&lt;p&gt;
Microcontrollers,  I2C components, linear devices&lt;p&gt;
http://www.st.com&lt;p&gt;
&lt;i&gt;Include st-microelectronics-2.lbr, st-microelectronics-3.lbr.&lt;p&gt;&lt;/i&gt;
<packages>
<package name="DIL-08">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="5.08" y1="2.921" x2="-5.08" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="-5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-5.334" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.556" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="v-reg">
<description>&lt;b&gt;Voltage Regulators&lt;/b&gt;&lt;p&gt;
<packages>
<package name="78LXX">
<description>&lt;b&gt;VOLTAGE REGULATOR&lt;/b&gt;</description>
<wire x1="-2.0946" y1="-1.651" x2="-0.7863" y2="2.5485" width="0.1524" layer="21" curve="-111.098957"/>
<wire x1="0.7868" y1="2.5484" x2="2.095" y2="-1.651" width="0.1524" layer="21" curve="-111.09954"/>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.655" y1="-0.254" x2="-2.254" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="2.254" y1="-0.254" x2="2.655" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-0.7863" y1="2.5485" x2="0.7863" y2="2.5485" width="0.1524" layer="51" curve="-34.293591"/>
<pad name="OUT" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="GND" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<pad name="IN" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-0.635" y="0.889" size="1.27" layer="51" ratio="10">-</text>
<text x="3.175" y="0.635" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-1.778" y="-0.635" size="1.27" layer="51" ratio="10">O</text>
<text x="0.635" y="-0.635" size="1.27" layer="51" ratio="10">I</text>
</package>
</packages>
</library>
<library name="pot">
<description>&lt;b&gt;Potentiometers&lt;/b&gt;&lt;p&gt;
Beckman, Copal, Piher, Spectrol, Schukat&lt;p&gt;
<packages>
<package name="PT-10">
<description>&lt;b&gt;POTENTIOMETER&lt;/b&gt;</description>
<wire x1="-3.175" y1="-4.064" x2="3.175" y2="-4.064" width="0.1524" layer="21" curve="-288.924644"/>
<wire x1="3.175" y1="-4.064" x2="3.175" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="-5.715" x2="-3.175" y2="-4.064" width="0.1524" layer="51"/>
<wire x1="-2.794" y1="-5.715" x2="-2.794" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-2.794" y1="-3.175" x2="-1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="-0.635" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-3.175" x2="-0.635" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-4.445" x2="-1.27" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-4.445" x2="-1.27" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-5.715" x2="1.27" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-4.445" x2="0.635" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-4.445" x2="0.635" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-3.175" x2="1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-2.54" x2="2.794" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-3.175" x2="2.794" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="-5.715" x2="3.175" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="0.889" y1="1.397" x2="-0.127" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0.381" x2="-0.508" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.762" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-1.397" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.397" y1="0.889" x2="0.381" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.127" x2="0.762" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.762" y1="-0.508" x2="0" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.508" x2="-0.889" y2="-1.397" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="1.8034" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.794" width="0.0508" layer="21"/>
<pad name="A" x="-2.54" y="-5.08" drill="1.016" shape="octagon"/>
<pad name="E" x="2.54" y="-5.08" drill="1.016" shape="octagon"/>
<pad name="S" x="0" y="5.08" drill="1.016" shape="octagon"/>
<text x="-3.175" y="6.35" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.048" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
<packages>
<package name="DO41-10">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2.54 mm, horizontal, grid 10.16 mm</description>
<wire x1="2.032" y1="-1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<pad name="A" x="5.08" y="0" drill="1.1176"/>
<pad name="C" x="-5.08" y="0" drill="1.1176"/>
<text x="-2.032" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.27" x2="-1.143" y2="1.27" layer="21"/>
<rectangle x1="2.032" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.032" y2="0.381" layer="21"/>
</package>
</packages>
</library>
<library name="fuse">
<description>&lt;b&gt;Fuses and Fuse Holders&lt;/b&gt;&lt;p&gt;
<packages>
<package name="SHK20Q">
<description>&lt;b&gt;FUSE HOLDER&lt;/b&gt;&lt;p&gt; 5 x 20 mm, SH contact, E1207 Buerklin 46G6061</description>
<wire x1="-5.08" y1="2.921" x2="5.08" y2="2.921" width="0.0508" layer="21"/>
<wire x1="-9.652" y1="3.683" x2="-6.096" y2="3.683" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-3.683" x2="-10.414" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="3.683" x2="-10.414" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="2.54" x2="-5.842" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-6.096" y1="-3.683" x2="-9.652" y2="-3.683" width="0.1524" layer="51"/>
<wire x1="-5.842" y1="-3.683" x2="-5.842" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-3.683" x2="-11.049" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-3.429" x2="-10.414" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-3.429" x2="-10.414" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="2.54" x2="-5.842" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="-3.683" x2="-11.049" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="0.889" x2="-10.795" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="0.889" x2="-10.795" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="-5.08" y2="0" width="0.0508" layer="21"/>
<wire x1="5.08" y1="-2.921" x2="-5.08" y2="-2.921" width="0.0508" layer="21"/>
<wire x1="9.652" y1="-3.683" x2="6.096" y2="-3.683" width="0.1524" layer="51"/>
<wire x1="10.414" y1="3.683" x2="10.414" y2="3.429" width="0.1524" layer="21"/>
<wire x1="9.906" y1="2.54" x2="5.842" y2="2.54" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-3.683" x2="10.414" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="9.906" y1="-2.54" x2="5.842" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="6.096" y1="3.683" x2="9.652" y2="3.683" width="0.1524" layer="51"/>
<wire x1="5.842" y1="3.683" x2="5.842" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.414" y1="3.683" x2="11.049" y2="3.683" width="0.1524" layer="21"/>
<wire x1="10.795" y1="3.429" x2="10.414" y2="3.429" width="0.1524" layer="21"/>
<wire x1="10.414" y1="3.429" x2="10.414" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-2.54" x2="5.842" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-3.683" x2="11.049" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-3.429" x2="10.414" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-3.429" x2="10.414" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-3.429" x2="10.795" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="11.049" y1="3.683" x2="11.049" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="3.683" x2="-11.049" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="3.429" x2="-10.414" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="3.429" x2="-10.414" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="2.54" x2="-10.414" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="3.429" x2="-10.795" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="0.889" x2="-11.049" y2="3.683" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-0.889" x2="11.049" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-0.889" x2="10.795" y2="3.429" width="0.1524" layer="21"/>
<wire x1="11.049" y1="-0.889" x2="11.049" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="9.906" y1="2.54" x2="10.414" y2="2.54" width="0.1524" layer="21"/>
<wire x1="9.652" y1="3.683" x2="10.414" y2="3.683" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.683" x2="5.842" y2="3.683" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.683" x2="5.842" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="9.652" y1="-3.683" x2="10.414" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="9.906" y1="-2.54" x2="10.414" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-2.54" x2="10.414" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-3.683" x2="-5.842" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-9.652" y1="-3.683" x2="-10.414" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-2.54" x2="-10.414" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="2.54" x2="-9.906" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="3.683" x2="-9.652" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="3.683" x2="-5.842" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-2.54" x2="-5.842" y2="-2.54" width="0.1524" layer="51"/>
<pad name="1A" x="-7.874" y="2.54" drill="1.5" diameter="3.81" shape="octagon"/>
<pad name="2A" x="7.874" y="2.54" drill="1.5" diameter="3.81" shape="octagon"/>
<pad name="2B" x="7.874" y="-2.54" drill="1.5" diameter="3.81" shape="octagon"/>
<pad name="1B" x="-7.874" y="-2.54" drill="1.5" diameter="3.81" shape="octagon"/>
<text x="-3.81" y="-5.08" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.81" y="3.302" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-5.08" y1="1.651" x2="5.08" y2="2.159" layer="21"/>
<rectangle x1="-5.08" y1="-2.159" x2="5.08" y2="-1.651" layer="21"/>
<rectangle x1="5.08" y1="-3.175" x2="5.588" y2="3.175" layer="21"/>
<rectangle x1="10.795" y1="-0.889" x2="11.049" y2="3.683" layer="21"/>
<rectangle x1="-10.795" y1="-3.683" x2="-10.414" y2="-3.429" layer="21"/>
<rectangle x1="-5.588" y1="-3.175" x2="-5.08" y2="3.175" layer="21"/>
<rectangle x1="-11.049" y1="-3.683" x2="-10.795" y2="0.889" layer="21"/>
<rectangle x1="5.588" y1="-3.175" x2="5.842" y2="-2.159" layer="21"/>
<rectangle x1="5.588" y1="2.159" x2="5.842" y2="3.175" layer="21"/>
<rectangle x1="9.906" y1="-2.54" x2="10.16" y2="2.54" layer="21"/>
<rectangle x1="5.842" y1="-2.54" x2="9.906" y2="-2.159" layer="51"/>
<rectangle x1="5.842" y1="2.159" x2="9.906" y2="2.54" layer="51"/>
<rectangle x1="-10.16" y1="-2.54" x2="-9.906" y2="2.54" layer="21"/>
<rectangle x1="-9.906" y1="2.159" x2="-5.842" y2="2.54" layer="51"/>
<rectangle x1="-5.842" y1="2.159" x2="-5.588" y2="3.175" layer="21"/>
<rectangle x1="-9.906" y1="-2.54" x2="-5.842" y2="-2.159" layer="51"/>
<rectangle x1="-5.842" y1="-3.175" x2="-5.588" y2="-2.159" layer="21"/>
</package>
</packages>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="0207/15">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0207, grid 15mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="5.715" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-5.715" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.175" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
<rectangle x1="5.715" y1="-0.3048" x2="6.5786" y2="0.3048" layer="21"/>
<rectangle x1="-6.5786" y1="-0.3048" x2="-5.715" y2="0.3048" layer="21"/>
</package>
</packages>
</library>
<library name="capacitor-wima">
<description>&lt;b&gt;WIMA Capacitors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="C7.5B3">
<description>&lt;B&gt;MKS3&lt;/B&gt;, 10 x 3 mm, grid 7.62 mm</description>
<wire x1="4.826" y1="1.524" x2="-4.826" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-1.524" x2="4.826" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.27" x2="5.08" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.826" y1="1.524" x2="5.08" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-1.524" x2="5.08" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.27" x2="-4.826" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.27" x2="-4.826" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="0.508" y1="0" x2="2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0.889" x2="0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="-0.889" width="0.4064" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.9144" diameter="1.905" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.9144" diameter="1.905" shape="octagon"/>
<text x="-3.81" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="led">
<description>&lt;b&gt;LEDs&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;br&gt;
Extended by Federico Battaglin &lt;author&gt;&amp;lt;federico.rd@fdpinternational.com&amp;gt;&lt;/author&gt; with DUOLED</description>
<packages>
<package name="LED3MM">
<description>&lt;B&gt;LED&lt;/B&gt;&lt;p&gt;
3 mm, round</description>
<wire x1="1.5748" y1="-1.27" x2="1.5748" y2="1.27" width="0.254" layer="51"/>
<wire x1="-1.524" y1="0" x2="-1.1708" y2="0.9756" width="0.1524" layer="51" curve="-39.80361"/>
<wire x1="-1.524" y1="0" x2="-1.1391" y2="-1.0125" width="0.1524" layer="51" curve="41.633208"/>
<wire x1="1.1571" y1="0.9918" x2="1.524" y2="0" width="0.1524" layer="51" curve="-40.601165"/>
<wire x1="1.1708" y1="-0.9756" x2="1.524" y2="0" width="0.1524" layer="51" curve="39.80361"/>
<wire x1="0" y1="1.524" x2="1.2401" y2="0.8858" width="0.1524" layer="21" curve="-54.461337"/>
<wire x1="-1.2192" y1="0.9144" x2="0" y2="1.524" width="0.1524" layer="21" curve="-53.130102"/>
<wire x1="0" y1="-1.524" x2="1.203" y2="-0.9356" width="0.1524" layer="21" curve="52.126876"/>
<wire x1="-1.203" y1="-0.9356" x2="0" y2="-1.524" width="0.1524" layer="21" curve="52.126876"/>
<wire x1="-0.635" y1="0" x2="0" y2="0.635" width="0.1524" layer="51" curve="-90"/>
<wire x1="-1.016" y1="0" x2="0" y2="1.016" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-0.635" x2="0.635" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0" y1="-1.016" x2="1.016" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0" y1="2.032" x2="1.561" y2="1.3009" width="0.254" layer="21" curve="-50.193108"/>
<wire x1="-1.7929" y1="0.9562" x2="0" y2="2.032" width="0.254" layer="21" curve="-61.926949"/>
<wire x1="0" y1="-2.032" x2="1.5512" y2="-1.3126" width="0.254" layer="21" curve="49.763022"/>
<wire x1="-1.7643" y1="-1.0082" x2="0" y2="-2.032" width="0.254" layer="21" curve="60.255215"/>
<wire x1="-2.032" y1="0" x2="-1.7891" y2="0.9634" width="0.254" layer="51" curve="-28.301701"/>
<wire x1="-2.032" y1="0" x2="-1.7306" y2="-1.065" width="0.254" layer="51" curve="31.60822"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="K" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="1.905" y="0.381" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="1.905" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="relay">
<description>&lt;b&gt;Relays&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;Eichhoff
&lt;li&gt;Finder
&lt;li&gt;Fujitsu
&lt;li&gt;HAMLIN
&lt;li&gt;OMRON
&lt;li&gt;Matsushita
&lt;li&gt;NAiS
&lt;li&gt;Siemens
&lt;li&gt;Schrack
&lt;/ul&gt;
<packages>
<package name="JS-M">
<description>&lt;b&gt;Automotive Ultra-Miniature Power Relay&lt;/b&gt; NAiS&lt;p&gt;
Source: http://www.mew-europe.com/.. en_ds_61211_0000.pdf</description>
<wire x1="-10.9" y1="7.2904" x2="-10.2904" y2="7.9" width="0.2032" layer="21" curve="-90"/>
<wire x1="-10.2904" y1="7.9" x2="10.2904" y2="7.9" width="0.2032" layer="21"/>
<wire x1="10.2904" y1="7.9" x2="10.9" y2="7.2904" width="0.2032" layer="21" curve="-90"/>
<wire x1="10.9" y1="7.2904" x2="10.9" y2="-7.2904" width="0.2032" layer="21"/>
<wire x1="10.9" y1="-7.2904" x2="10.2904" y2="-7.9" width="0.2032" layer="21" curve="-90"/>
<wire x1="10.2904" y1="-7.9" x2="-10.2904" y2="-7.9" width="0.2032" layer="21"/>
<wire x1="-10.2904" y1="-7.9" x2="-10.9" y2="-7.2904" width="0.2032" layer="21" curve="-90"/>
<wire x1="-10.9" y1="-7.2904" x2="-10.9" y2="7.2904" width="0.2032" layer="21"/>
<pad name="C" x="8.7" y="0" drill="1.3" rot="R180"/>
<pad name="1" x="6.7" y="6" drill="1.3" rot="R180"/>
<pad name="2" x="6.7" y="-6" drill="1.3" rot="R180"/>
<pad name="NO" x="-5.5" y="6" drill="1.3" rot="R180"/>
<pad name="NC" x="-5.5" y="-6" drill="1.3" rot="R180"/>
<text x="-8.89" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.89" y="-1.27" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="transistor">
<description>&lt;b&gt;Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TO92-ECB">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line E C B from top&lt;p&gt;</description>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.127" layer="21"/>
<wire x1="-2.413" y1="1.1359" x2="2.413" y2="1.1359" width="0.127" layer="21" curve="-129.583"/>
<wire x1="1.136" y1="-0.127" x2="-1.136" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.413" y1="1.1359" x2="-2.664" y2="-0.127" width="0.127" layer="51" curve="27.9407"/>
<wire x1="-2.664" y1="-0.127" x2="-2.413" y2="-1.1359" width="0.127" layer="51" curve="22.4788"/>
<wire x1="-1.404" y1="-0.127" x2="-2.664" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.4135" y1="-1.1359" x2="-2.095" y2="-1.651" width="0.127" layer="21" curve="13.0385"/>
<wire x1="-1.136" y1="-0.127" x2="-1.404" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.413" y1="-1.1359" x2="2.664" y2="-0.127" width="0.127" layer="51" curve="22.4788"/>
<wire x1="2.664" y1="-0.127" x2="2.413" y2="1.1359" width="0.127" layer="51" curve="27.9333"/>
<wire x1="2.664" y1="-0.127" x2="1.404" y2="-0.127" width="0.127" layer="51"/>
<wire x1="1.404" y1="-0.127" x2="1.136" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.095" y1="-1.651" x2="2.4247" y2="-1.1118" width="0.127" layer="21" curve="13.6094"/>
<pad name="C" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules>
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<description language="hu">&lt;b&gt;EAGLE Tervezési Szabályok&lt;/b&gt;&lt;p&gt;Az alapértelmezett Tervezési Szabályok úgy lettek megállapítva, hogy használhatók legyenek minél többféle alkalmazás megtervezéséhez.A Te általad tervezni kívánt termék más beállításokat követelhet meg,így megkérlek, hogy tedd meg a neked szükséges beállításokat, és mentsd elegy másik néven.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="1"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="J1" library="con-amp" package="350759-4" value="350759-4" x="92.71" y="11.43" rot="R270"/>
<element name="IC1" library="st-microelectronics" package="DIL-08" value="NE555" x="54.61" y="20.32" rot="R180">
<attribute name="OC_NEWARK" value="89K1486" x="-10.16" y="26.67" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="NE555N" x="-10.16" y="26.67" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="Arrow Electronics" x="-10.16" y="26.67" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="1467742" x="-10.16" y="26.67" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="IC2" library="st-microelectronics" package="DIL-08" value="NE555" x="72.39" y="20.32" rot="R180">
<attribute name="OC_NEWARK" value="89K1486" x="53.34" y="43.18" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="NE555N" x="53.34" y="43.18" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="Arrow Electronics" x="53.34" y="43.18" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="1467742" x="53.34" y="43.18" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="IC3" library="v-reg" package="78LXX" value="78L10" x="21.59" y="41.91" rot="R180"/>
<element name="R1" library="pot" package="PT-10" value="4M7" x="93.98" y="71.12" rot="R180"/>
<element name="R2" library="pot" package="PT-10" value="4M7" x="93.98" y="53.34"/>
<element name="D1" library="diode" package="DO41-10" value="1N4004" x="30.48" y="48.26"/>
<element name="F1" library="fuse" package="SHK20Q" value="200mA" x="71.12" y="6.35">
<attribute name="OC_NEWARK" value="unknown" x="109.22" y="-16.51" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="109.22" y="-16.51" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="109.22" y="-16.51" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="109.22" y="-16.51" size="1.778" layer="27" display="off"/>
</element>
<element name="R3" library="rcl" package="0207/15" value="10k" x="83.82" y="53.34" rot="R90"/>
<element name="R4" library="rcl" package="0207/15" value="10k" x="45.72" y="53.34" rot="R90"/>
<element name="R5" library="rcl" package="0207/15" value="10k" x="40.64" y="43.18" rot="R270"/>
<element name="R6" library="rcl" package="0207/15" value="47k" x="69.85" y="64.77"/>
<element name="R7" library="rcl" package="0207/15" value="10k" x="52.07" y="64.77"/>
<element name="R8" library="rcl" package="0207/15" value="10k" x="34.29" y="64.77"/>
<element name="R9" library="rcl" package="0207/15" value="1M" x="69.85" y="69.85"/>
<element name="R10" library="rcl" package="0207/15" value="10k" x="52.07" y="69.85"/>
<element name="R11" library="rcl" package="0207/15" value="360k" x="34.29" y="69.85"/>
<element name="R12" library="rcl" package="0207/15" value="2k7" x="69.85" y="74.93"/>
<element name="R13" library="rcl" package="0207/15" value="47k" x="52.07" y="74.93" rot="R180"/>
<element name="R16" library="rcl" package="0207/15" value="10k" x="34.29" y="74.93" rot="R180"/>
<element name="C1" library="capacitor-wima" package="C7.5B3" value="1uF 63V" x="36.83" y="26.67" rot="R90"/>
<element name="C2" library="capacitor-wima" package="C7.5B3" value="100nF" x="20.32" y="25.4" smashed="yes">
<attribute name="NAME" x="16.51" y="27.178" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="16.51" y="22.352" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C3" library="capacitor-wima" package="C7.5B3" value="100nF" x="78.74" y="35.56" rot="R90"/>
<element name="C4" library="capacitor-wima" package="C7.5B3" value="1uF" x="68.58" y="35.56" rot="R270"/>
<element name="C5" library="capacitor-wima" package="C7.5B3" value="1uF" x="45.72" y="35.56" rot="R270"/>
<element name="C6" library="capacitor-wima" package="C7.5B3" value="10nF" x="49.53" y="5.08" rot="R180"/>
<element name="C7" library="capacitor-wima" package="C7.5B3" value="10nF/K" x="57.15" y="35.56" rot="R90"/>
<element name="C9" library="capacitor-wima" package="C7.5B3" value="100nF" x="55.88" y="49.53"/>
<element name="C8" library="capacitor-wima" package="C7.5B3" value="10uF" x="72.39" y="49.53"/>
<element name="D2" library="diode" package="DO41-10" value="1N4004" x="16.51" y="55.88" rot="R90"/>
<element name="LED1" library="led" package="LED3MM" value="3S" x="3.81" y="66.04"/>
<element name="K1" library="relay" package="JS-M" value="JS-M1F-12V-5" x="25.4" y="10.16">
<attribute name="OC_NEWARK" value="unknown" x="73.66" y="1.27" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="73.66" y="1.27" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="73.66" y="1.27" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="73.66" y="1.27" size="1.778" layer="27" display="off"/>
</element>
<element name="J2" library="con-amp" package="350760-4" value="350760-4" x="5.08" y="13.97" rot="R90"/>
<element name="T1" library="transistor" package="TO92-ECB" value="BC182B" x="5.08" y="45.72" rot="R90"/>
<element name="T2" library="transistor" package="TO92-ECB" value="BC557" x="5.08" y="34.29" rot="R90"/>
</elements>
<signals>
<signal name="VCC+">
<contactref element="IC1" pad="8"/>
<contactref element="IC2" pad="8"/>
<wire x1="60.96" y1="19.05" x2="58.42" y2="16.51" width="0.254" layer="16"/>
<wire x1="73.66" y1="19.05" x2="60.96" y2="19.05" width="0.254" layer="16"/>
<wire x1="76.2" y1="16.51" x2="73.66" y2="19.05" width="0.254" layer="16"/>
</signal>
<signal name="N$1">
<contactref element="F1" pad="2A"/>
<contactref element="F1" pad="2B"/>
<contactref element="J1" pad="2"/>
<wire x1="78.74" y1="8.89" x2="78.74" y2="3.81" width="0.254" layer="1"/>
<wire x1="78.74" y1="3.81" x2="78.994" y2="3.81" width="0.254" layer="1"/>
<wire x1="78.74" y1="8.89" x2="78.994" y2="8.89" width="0.254" layer="1"/>
<wire x1="78.994" y1="8.89" x2="92.71" y2="8.89" width="0.254" layer="1"/>
<wire x1="92.71" y1="8.89" x2="92.71" y2="8.255" width="0.254" layer="1"/>
</signal>
<signal name="N$2">
<contactref element="D1" pad="C"/>
<contactref element="C2" pad="1"/>
<contactref element="IC3" pad="IN"/>
<contactref element="R12" pad="2"/>
<contactref element="D2" pad="C"/>
<contactref element="K1" pad="1"/>
<wire x1="25.4" y1="46.99" x2="20.32" y2="41.91" width="0.254" layer="1"/>
<wire x1="25.4" y1="48.26" x2="25.4" y2="46.99" width="0.254" layer="1"/>
<wire x1="20.32" y1="29.21" x2="16.51" y2="25.4" width="0.254" layer="1"/>
<wire x1="20.32" y1="41.91" x2="20.32" y2="29.21" width="0.254" layer="1"/>
<wire x1="25.4" y1="22.86" x2="32.1" y2="16.16" width="0.254" layer="16"/>
<wire x1="19.05" y1="22.86" x2="25.4" y2="22.86" width="0.254" layer="16"/>
<wire x1="16.51" y1="25.4" x2="19.05" y2="22.86" width="0.254" layer="16"/>
<wire x1="74.93" y1="77.47" x2="77.47" y2="74.93" width="0.254" layer="16"/>
<wire x1="26.67" y1="77.47" x2="74.93" y2="77.47" width="0.254" layer="16"/>
<wire x1="17.78" y1="68.58" x2="26.67" y2="77.47" width="0.254" layer="16"/>
<wire x1="17.78" y1="50.8" x2="17.78" y2="68.58" width="0.254" layer="16"/>
<wire x1="16.51" y1="50.8" x2="17.78" y2="50.8" width="0.254" layer="16"/>
<wire x1="22.86" y1="50.8" x2="25.4" y2="48.26" width="0.254" layer="16"/>
<wire x1="17.78" y1="50.8" x2="22.86" y2="50.8" width="0.254" layer="16"/>
</signal>
<signal name="GND">
<contactref element="C4" pad="2"/>
<contactref element="C1" pad="1"/>
<contactref element="IC1" pad="1"/>
<contactref element="C7" pad="2"/>
<contactref element="J1" pad="1"/>
<contactref element="C2" pad="2"/>
<contactref element="IC3" pad="GND"/>
<contactref element="C3" pad="2"/>
<contactref element="IC2" pad="1"/>
<contactref element="C5" pad="2"/>
<contactref element="C9" pad="2"/>
<contactref element="R6" pad="1"/>
<contactref element="R13" pad="1"/>
<contactref element="C6" pad="2"/>
<contactref element="T1" pad="E"/>
<contactref element="T2" pad="E"/>
<wire x1="7.62" y1="34.29" x2="5.08" y2="31.75" width="0.254" layer="1"/>
<wire x1="7.62" y1="40.64" x2="7.62" y2="34.29" width="0.254" layer="1"/>
<wire x1="5.08" y1="43.18" x2="7.62" y2="40.64" width="0.254" layer="1"/>
<wire x1="21.59" y1="43.18" x2="21.59" y2="40.005" width="0.254" layer="16"/>
<wire x1="5.08" y1="43.18" x2="21.59" y2="43.18" width="0.254" layer="16"/>
<wire x1="21.59" y1="27.94" x2="24.13" y2="25.4" width="0.254" layer="1"/>
<wire x1="21.59" y1="40.005" x2="21.59" y2="27.94" width="0.254" layer="1"/>
<wire x1="45.72" y1="31.75" x2="45.72" y2="5.08" width="0.254" layer="1"/>
<wire x1="45.72" y1="31.75" x2="36.83" y2="22.86" width="0.254" layer="16"/>
<wire x1="36.83" y1="25.4" x2="24.13" y2="25.4" width="0.254" layer="1"/>
<wire x1="36.83" y1="22.86" x2="36.83" y2="25.4" width="0.254" layer="1"/>
<wire x1="85.09" y1="15.24" x2="76.2" y2="24.13" width="0.254" layer="16"/>
<wire x1="92.71" y1="15.24" x2="85.09" y2="15.24" width="0.254" layer="16"/>
<wire x1="92.71" y1="15.24" x2="92.71" y2="14.605" width="0.254" layer="16"/>
<wire x1="59.69" y1="25.4" x2="58.42" y2="24.13" width="0.254" layer="1"/>
<wire x1="59.69" y1="49.53" x2="59.69" y2="39.37" width="0.254" layer="1"/>
<wire x1="59.69" y1="39.37" x2="59.69" y2="31.75" width="0.254" layer="1"/>
<wire x1="59.69" y1="31.75" x2="59.69" y2="25.4" width="0.254" layer="1"/>
<wire x1="59.69" y1="62.23" x2="62.23" y2="64.77" width="0.254" layer="1"/>
<wire x1="59.69" y1="49.53" x2="59.69" y2="62.23" width="0.254" layer="1"/>
<wire x1="58.42" y1="73.66" x2="59.69" y2="74.93" width="0.254" layer="1"/>
<wire x1="58.42" y1="63.5" x2="58.42" y2="73.66" width="0.254" layer="1"/>
<wire x1="59.69" y1="62.23" x2="58.42" y2="63.5" width="0.254" layer="1"/>
<wire x1="59.69" y1="39.37" x2="57.15" y2="39.37" width="0.254" layer="1"/>
<wire x1="59.69" y1="31.75" x2="68.58" y2="31.75" width="0.254" layer="1"/>
<wire x1="71.12" y1="31.75" x2="78.74" y2="39.37" width="0.254" layer="16"/>
<wire x1="68.58" y1="31.75" x2="71.12" y2="31.75" width="0.254" layer="16"/>
<wire x1="76.2" y1="36.83" x2="76.2" y2="24.13" width="0.254" layer="1"/>
<wire x1="78.74" y1="39.37" x2="76.2" y2="36.83" width="0.254" layer="1"/>
<wire x1="53.34" y1="39.37" x2="45.72" y2="31.75" width="0.254" layer="16"/>
<wire x1="57.15" y1="39.37" x2="53.34" y2="39.37" width="0.254" layer="16"/>
</signal>
<signal name="N$4">
<contactref element="IC1" pad="4"/>
<contactref element="R5" pad="1"/>
<contactref element="C4" pad="1"/>
<wire x1="50.8" y1="35.56" x2="50.8" y2="24.13" width="0.254" layer="16"/>
<wire x1="64.77" y1="35.56" x2="50.8" y2="35.56" width="0.254" layer="16"/>
<wire x1="68.58" y1="39.37" x2="64.77" y2="35.56" width="0.254" layer="16"/>
<wire x1="44.45" y1="54.61" x2="40.64" y2="50.8" width="0.254" layer="1"/>
<wire x1="44.45" y1="62.23" x2="44.45" y2="54.61" width="0.254" layer="1"/>
<wire x1="49.53" y1="62.23" x2="44.45" y2="62.23" width="0.254" layer="1"/>
<wire x1="49.53" y1="49.53" x2="49.53" y2="62.23" width="0.254" layer="1"/>
<wire x1="50.8" y1="48.26" x2="49.53" y2="49.53" width="0.254" layer="1"/>
<wire x1="50.8" y1="24.13" x2="50.8" y2="48.26" width="0.254" layer="1"/>
</signal>
<signal name="N$5">
<contactref element="R3" pad="2"/>
<contactref element="IC1" pad="2"/>
<contactref element="C8" pad="2"/>
<wire x1="60.96" y1="29.21" x2="55.88" y2="24.13" width="0.254" layer="16"/>
<wire x1="82.55" y1="29.21" x2="60.96" y2="29.21" width="0.254" layer="16"/>
<wire x1="85.09" y1="31.75" x2="82.55" y2="29.21" width="0.254" layer="16"/>
<wire x1="85.09" y1="49.53" x2="85.09" y2="31.75" width="0.254" layer="16"/>
<wire x1="76.2" y1="49.53" x2="85.09" y2="49.53" width="0.254" layer="16"/>
<wire x1="85.09" y1="59.69" x2="83.82" y2="60.96" width="0.254" layer="1"/>
<wire x1="85.09" y1="44.45" x2="85.09" y2="59.69" width="0.254" layer="1"/>
<wire x1="76.2" y1="44.45" x2="85.09" y2="44.45" width="0.254" layer="1"/>
<wire x1="76.2" y1="49.53" x2="76.2" y2="44.45" width="0.254" layer="1"/>
</signal>
<signal name="VCC">
<contactref element="R3" pad="1"/>
<contactref element="R5" pad="2"/>
<contactref element="R1" pad="A"/>
<contactref element="R1" pad="S"/>
<contactref element="R10" pad="2"/>
<contactref element="IC3" pad="OUT"/>
<contactref element="C3" pad="1"/>
<contactref element="R9" pad="2"/>
<contactref element="C9" pad="1"/>
<wire x1="96.52" y1="68.58" x2="93.98" y2="66.04" width="0.254" layer="1"/>
<wire x1="96.52" y1="76.2" x2="96.52" y2="68.58" width="0.254" layer="1"/>
<wire x1="60.96" y1="71.12" x2="59.69" y2="69.85" width="0.254" layer="16"/>
<wire x1="76.2" y1="71.12" x2="60.96" y2="71.12" width="0.254" layer="16"/>
<wire x1="77.47" y1="69.85" x2="76.2" y2="71.12" width="0.254" layer="16"/>
<wire x1="90.17" y1="69.85" x2="93.98" y2="66.04" width="0.254" layer="16"/>
<wire x1="77.47" y1="69.85" x2="90.17" y2="69.85" width="0.254" layer="16"/>
<wire x1="83.82" y1="31.75" x2="83.82" y2="45.72" width="0.254" layer="16"/>
<wire x1="78.74" y1="31.75" x2="83.82" y2="31.75" width="0.254" layer="16"/>
<wire x1="40.64" y1="39.37" x2="40.64" y2="35.56" width="0.254" layer="16"/>
<wire x1="41.91" y1="39.37" x2="40.64" y2="39.37" width="0.254" layer="16"/>
<wire x1="52.07" y1="49.53" x2="49.53" y2="46.99" width="0.254" layer="16"/>
<wire x1="49.53" y1="46.99" x2="41.91" y2="39.37" width="0.254" layer="16"/>
<wire x1="29.21" y1="35.56" x2="22.86" y2="41.91" width="0.254" layer="16"/>
<wire x1="40.64" y1="35.56" x2="29.21" y2="35.56" width="0.254" layer="16"/>
<wire x1="82.55" y1="46.99" x2="83.82" y2="45.72" width="0.254" layer="16"/>
<wire x1="49.53" y1="46.99" x2="82.55" y2="46.99" width="0.254" layer="16"/>
<wire x1="82.55" y1="64.77" x2="77.47" y2="69.85" width="0.254" layer="1"/>
<wire x1="82.55" y1="46.99" x2="82.55" y2="64.77" width="0.254" layer="1"/>
<wire x1="83.82" y1="45.72" x2="82.55" y2="46.99" width="0.254" layer="1"/>
</signal>
<signal name="N$8">
<contactref element="IC1" pad="7"/>
<contactref element="R11" pad="1"/>
<contactref element="R4" pad="2"/>
<wire x1="53.34" y1="13.97" x2="55.88" y2="16.51" width="0.254" layer="1"/>
<wire x1="49.53" y1="13.97" x2="53.34" y2="13.97" width="0.254" layer="1"/>
<wire x1="49.53" y1="48.26" x2="49.53" y2="13.97" width="0.254" layer="1"/>
<wire x1="45.72" y1="52.07" x2="49.53" y2="48.26" width="0.254" layer="1"/>
<wire x1="45.72" y1="60.96" x2="45.72" y2="52.07" width="0.254" layer="1"/>
<wire x1="22.86" y1="66.04" x2="26.67" y2="69.85" width="0.254" layer="16"/>
<wire x1="22.86" y1="60.96" x2="22.86" y2="66.04" width="0.254" layer="16"/>
<wire x1="45.72" y1="60.96" x2="22.86" y2="60.96" width="0.254" layer="16"/>
</signal>
<signal name="N$3">
<contactref element="R11" pad="2"/>
<contactref element="R1" pad="E"/>
<wire x1="45.72" y1="73.66" x2="41.91" y2="69.85" width="0.254" layer="16"/>
<wire x1="88.9" y1="73.66" x2="45.72" y2="73.66" width="0.254" layer="16"/>
<wire x1="91.44" y1="76.2" x2="88.9" y2="73.66" width="0.254" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="R4" pad="1"/>
<contactref element="IC1" pad="6"/>
<contactref element="C1" pad="2"/>
<wire x1="49.53" y1="20.32" x2="53.34" y2="16.51" width="0.254" layer="16"/>
<wire x1="36.83" y1="20.32" x2="49.53" y2="20.32" width="0.254" layer="16"/>
<wire x1="34.29" y1="22.86" x2="36.83" y2="20.32" width="0.254" layer="16"/>
<wire x1="34.29" y1="30.48" x2="34.29" y2="22.86" width="0.254" layer="16"/>
<wire x1="36.83" y1="30.48" x2="34.29" y2="30.48" width="0.254" layer="16"/>
<wire x1="36.83" y1="36.83" x2="45.72" y2="45.72" width="0.254" layer="16"/>
<wire x1="36.83" y1="30.48" x2="36.83" y2="36.83" width="0.254" layer="1"/>
<via x="36.83" y="36.83" extent="1-16" drill="0.6096"/>
</signal>
<signal name="N$10">
<contactref element="IC1" pad="5"/>
<contactref element="C7" pad="1"/>
<wire x1="57.15" y1="22.86" x2="50.8" y2="16.51" width="0.254" layer="1"/>
<wire x1="57.15" y1="31.75" x2="57.15" y2="22.86" width="0.254" layer="1"/>
</signal>
<signal name="N$11">
<contactref element="IC1" pad="3"/>
<contactref element="R16" pad="1"/>
<wire x1="54.61" y1="25.4" x2="53.34" y2="24.13" width="0.254" layer="1"/>
<wire x1="54.61" y1="62.23" x2="54.61" y2="25.4" width="0.254" layer="1"/>
<wire x1="41.91" y1="74.93" x2="54.61" y2="62.23" width="0.254" layer="1"/>
</signal>
<signal name="N$12">
<contactref element="R16" pad="2"/>
<contactref element="R13" pad="2"/>
<contactref element="T1" pad="B"/>
<wire x1="15.24" y1="58.42" x2="5.08" y2="48.26" width="0.254" layer="1"/>
<wire x1="15.24" y1="63.5" x2="15.24" y2="58.42" width="0.254" layer="1"/>
<wire x1="26.67" y1="74.93" x2="15.24" y2="63.5" width="0.254" layer="1"/>
<wire x1="43.18" y1="76.2" x2="44.45" y2="74.93" width="0.254" layer="16"/>
<wire x1="27.94" y1="76.2" x2="43.18" y2="76.2" width="0.254" layer="16"/>
<wire x1="26.67" y1="74.93" x2="27.94" y2="76.2" width="0.254" layer="16"/>
</signal>
<signal name="N$13">
<contactref element="IC2" pad="4"/>
<contactref element="R10" pad="1"/>
<contactref element="T1" pad="C"/>
<wire x1="27.94" y1="68.58" x2="5.08" y2="45.72" width="0.254" layer="1"/>
<wire x1="44.45" y1="68.58" x2="27.94" y2="68.58" width="0.254" layer="1"/>
<wire x1="44.45" y1="69.85" x2="44.45" y2="68.58" width="0.254" layer="1"/>
<wire x1="72.39" y1="27.94" x2="68.58" y2="24.13" width="0.254" layer="16"/>
<wire x1="82.55" y1="27.94" x2="72.39" y2="27.94" width="0.254" layer="16"/>
<wire x1="97.79" y1="43.18" x2="82.55" y2="27.94" width="0.254" layer="16"/>
<wire x1="97.79" y1="72.39" x2="97.79" y2="43.18" width="0.254" layer="16"/>
<wire x1="46.99" y1="72.39" x2="97.79" y2="72.39" width="0.254" layer="16"/>
<wire x1="44.45" y1="69.85" x2="46.99" y2="72.39" width="0.254" layer="16"/>
</signal>
<signal name="N$7">
<contactref element="F1" pad="1A"/>
<contactref element="D1" pad="A"/>
<contactref element="F1" pad="1B"/>
<wire x1="43.18" y1="40.64" x2="35.56" y2="48.26" width="0.254" layer="1"/>
<wire x1="43.18" y1="5.08" x2="43.18" y2="40.64" width="0.254" layer="1"/>
<wire x1="45.72" y1="2.54" x2="43.18" y2="5.08" width="0.254" layer="1"/>
<wire x1="62.23" y1="2.54" x2="45.72" y2="2.54" width="0.254" layer="1"/>
<wire x1="62.23" y1="3.81" x2="62.23" y2="2.54" width="0.254" layer="1"/>
<wire x1="62.23" y1="3.81" x2="63.246" y2="3.81" width="0.254" layer="1"/>
<wire x1="63.5" y1="3.81" x2="63.5" y2="8.89" width="0.254" layer="1"/>
<wire x1="63.5" y1="8.89" x2="63.246" y2="8.89" width="0.254" layer="1"/>
<wire x1="63.5" y1="3.81" x2="63.246" y2="3.81" width="0.254" layer="1"/>
</signal>
<signal name="N$9">
<contactref element="IC2" pad="5"/>
<contactref element="C6" pad="1"/>
<wire x1="68.58" y1="6.35" x2="68.58" y2="16.51" width="0.254" layer="16"/>
<wire x1="54.61" y1="6.35" x2="68.58" y2="6.35" width="0.254" layer="16"/>
<wire x1="53.34" y1="5.08" x2="54.61" y2="6.35" width="0.254" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="IC2" pad="7"/>
<contactref element="R7" pad="1"/>
<contactref element="R2" pad="E"/>
<wire x1="96.52" y1="39.37" x2="73.66" y2="16.51" width="0.254" layer="1"/>
<wire x1="96.52" y1="48.26" x2="96.52" y2="39.37" width="0.254" layer="1"/>
<wire x1="45.72" y1="63.5" x2="44.45" y2="64.77" width="0.254" layer="16"/>
<wire x1="78.74" y1="63.5" x2="45.72" y2="63.5" width="0.254" layer="16"/>
<wire x1="93.98" y1="48.26" x2="78.74" y2="63.5" width="0.254" layer="16"/>
<wire x1="96.52" y1="48.26" x2="93.98" y2="48.26" width="0.254" layer="16"/>
</signal>
<signal name="N$15">
<contactref element="R7" pad="2"/>
<contactref element="C5" pad="1"/>
<contactref element="IC2" pad="6"/>
<contactref element="IC2" pad="2"/>
<wire x1="60.96" y1="66.04" x2="59.69" y2="64.77" width="0.254" layer="1"/>
<wire x1="73.66" y1="66.04" x2="60.96" y2="66.04" width="0.254" layer="1"/>
<wire x1="73.66" y1="24.13" x2="73.66" y2="66.04" width="0.254" layer="1"/>
<wire x1="73.66" y1="19.05" x2="71.12" y2="16.51" width="0.254" layer="1"/>
<wire x1="73.66" y1="24.13" x2="73.66" y2="19.05" width="0.254" layer="1"/>
<wire x1="48.26" y1="36.83" x2="45.72" y2="39.37" width="0.254" layer="1"/>
<wire x1="48.26" y1="13.97" x2="48.26" y2="36.83" width="0.254" layer="1"/>
<wire x1="49.53" y1="12.7" x2="48.26" y2="13.97" width="0.254" layer="1"/>
<wire x1="71.12" y1="12.7" x2="49.53" y2="12.7" width="0.254" layer="1"/>
<wire x1="71.12" y1="16.51" x2="71.12" y2="12.7" width="0.254" layer="1"/>
</signal>
<signal name="N$16">
<contactref element="R9" pad="1"/>
<contactref element="R2" pad="A"/>
<contactref element="R2" pad="S"/>
<wire x1="64.77" y1="67.31" x2="62.23" y2="69.85" width="0.254" layer="16"/>
<wire x1="85.09" y1="67.31" x2="64.77" y2="67.31" width="0.254" layer="16"/>
<wire x1="93.98" y1="58.42" x2="85.09" y2="67.31" width="0.254" layer="16"/>
<wire x1="93.98" y1="50.8" x2="91.44" y2="48.26" width="0.254" layer="1"/>
<wire x1="93.98" y1="58.42" x2="93.98" y2="50.8" width="0.254" layer="1"/>
</signal>
<signal name="N$17">
<contactref element="IC2" pad="3"/>
<contactref element="C8" pad="1"/>
<contactref element="R8" pad="1"/>
<wire x1="29.21" y1="62.23" x2="26.67" y2="64.77" width="0.254" layer="16"/>
<wire x1="55.88" y1="62.23" x2="29.21" y2="62.23" width="0.254" layer="16"/>
<wire x1="68.58" y1="49.53" x2="55.88" y2="62.23" width="0.254" layer="16"/>
<wire x1="71.12" y1="46.99" x2="71.12" y2="24.13" width="0.254" layer="1"/>
<wire x1="68.58" y1="49.53" x2="71.12" y2="46.99" width="0.254" layer="1"/>
</signal>
<signal name="N$18">
<contactref element="R8" pad="2"/>
<contactref element="R6" pad="2"/>
<contactref element="T2" pad="B"/>
<wire x1="6.35" y1="38.1" x2="5.08" y2="36.83" width="0.254" layer="16"/>
<wire x1="22.86" y1="38.1" x2="6.35" y2="38.1" width="0.254" layer="16"/>
<wire x1="41.91" y1="57.15" x2="22.86" y2="38.1" width="0.254" layer="1"/>
<wire x1="41.91" y1="64.77" x2="41.91" y2="57.15" width="0.254" layer="1"/>
<wire x1="76.2" y1="66.04" x2="77.47" y2="64.77" width="0.254" layer="16"/>
<wire x1="43.18" y1="66.04" x2="76.2" y2="66.04" width="0.254" layer="16"/>
<wire x1="41.91" y1="64.77" x2="43.18" y2="66.04" width="0.254" layer="16"/>
<via x="22.86" y="38.1" extent="1-16" drill="0.6096"/>
</signal>
<signal name="N$19">
<contactref element="D2" pad="A"/>
<contactref element="LED1" pad="K"/>
<contactref element="K1" pad="2"/>
<contactref element="T2" pad="C"/>
<wire x1="2.54" y1="36.83" x2="5.08" y2="34.29" width="0.254" layer="1"/>
<wire x1="2.54" y1="63.5" x2="2.54" y2="36.83" width="0.254" layer="1"/>
<wire x1="5.08" y1="66.04" x2="2.54" y2="63.5" width="0.254" layer="1"/>
<wire x1="11.43" y1="66.04" x2="16.51" y2="60.96" width="0.254" layer="16"/>
<wire x1="5.08" y1="66.04" x2="11.43" y2="66.04" width="0.254" layer="16"/>
<wire x1="21.59" y1="5.08" x2="31.75" y2="5.08" width="0.254" layer="1"/>
<wire x1="21.59" y1="11.43" x2="21.59" y2="5.08" width="0.254" layer="1"/>
<wire x1="2.54" y1="30.48" x2="21.59" y2="11.43" width="0.254" layer="1"/>
<wire x1="2.54" y1="36.83" x2="2.54" y2="30.48" width="0.254" layer="1"/>
<wire x1="31.75" y1="5.08" x2="32.1" y2="4.16" width="0.254" layer="1"/>
</signal>
<signal name="N$20">
<contactref element="LED1" pad="A"/>
<contactref element="R12" pad="1"/>
<wire x1="12.7" y1="76.2" x2="2.54" y2="66.04" width="0.254" layer="1"/>
<wire x1="62.23" y1="76.2" x2="12.7" y2="76.2" width="0.254" layer="1"/>
<wire x1="62.23" y1="74.93" x2="62.23" y2="76.2" width="0.254" layer="1"/>
</signal>
<signal name="N$21">
<contactref element="K1" pad="C"/>
<contactref element="J2" pad="1"/>
<wire x1="31.75" y1="7.62" x2="34.29" y2="10.16" width="0.254" layer="16"/>
<wire x1="5.08" y1="7.62" x2="31.75" y2="7.62" width="0.254" layer="16"/>
<wire x1="34.29" y1="10.16" x2="34.1" y2="10.16" width="0.254" layer="16"/>
</signal>
<signal name="N$23">
<contactref element="K1" pad="NO"/>
<contactref element="J2" pad="3"/>
<wire x1="15.24" y1="20.32" x2="19.05" y2="16.51" width="0.254" layer="16"/>
<wire x1="5.08" y1="20.32" x2="15.24" y2="20.32" width="0.254" layer="16"/>
<wire x1="19.05" y1="16.51" x2="19.9" y2="16.16" width="0.254" layer="16"/>
</signal>
<signal name="N$22">
<contactref element="K1" pad="NC"/>
<contactref element="J2" pad="2"/>
<wire x1="7.62" y1="15.24" x2="19.05" y2="3.81" width="0.254" layer="1"/>
<wire x1="5.08" y1="15.24" x2="7.62" y2="15.24" width="0.254" layer="1"/>
<wire x1="5.08" y1="13.97" x2="5.08" y2="15.24" width="0.254" layer="1"/>
<wire x1="19.05" y1="3.81" x2="19.9" y2="4.16" width="0.254" layer="1"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
