<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="no"/>
<layer number="17" name="Pads" color="2" fill="1" visible="no" active="no"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="no"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="no"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="no"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="no"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="no"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="no"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="no"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="no"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="no"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="no"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="no"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="no"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="no"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="no"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="no"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="no"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="no"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="no"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="no"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="no"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="no"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="no"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="no"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="no"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="no"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="no"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="no"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="6" fill="1" visible="no" active="no"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<schematic xreflabel="%F%N/%S.%C%R" xrefpart="/%S.%C%R">
<libraries>
<library name="relay">
<description>&lt;b&gt;Relays&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;Eichhoff
&lt;li&gt;Finder
&lt;li&gt;Fujitsu
&lt;li&gt;HAMLIN
&lt;li&gt;OMRON
&lt;li&gt;Matsushita
&lt;li&gt;NAiS
&lt;li&gt;Siemens
&lt;li&gt;Schrack
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="K2EBP">
<description>&lt;b&gt;UNIQUELY DESIGNED RELAY&lt;/b&gt; NAiS&lt;p&gt;
Source: http://www.mew-europe.com/..  en_ds_61013_0000.pdf</description>
<wire x1="-8.9" y1="12.75" x2="8.9" y2="12.75" width="0.2032" layer="21"/>
<wire x1="9.4" y1="12.25" x2="9.4" y2="-10.15" width="0.2032" layer="21"/>
<wire x1="8.9" y1="-10.65" x2="-8.9" y2="-10.65" width="0.2032" layer="21"/>
<wire x1="-9.4" y1="-10.15" x2="-9.4" y2="12.25" width="0.2032" layer="21"/>
<wire x1="-9.4" y1="12.25" x2="-8.9" y2="12.75" width="0.2032" layer="21" curve="-90"/>
<wire x1="8.9" y1="12.75" x2="9.4" y2="12.25" width="0.2032" layer="21" curve="-90"/>
<wire x1="9.4" y1="-10.15" x2="8.9" y2="-10.65" width="0.2032" layer="21" curve="-90"/>
<wire x1="-8.9" y1="-10.65" x2="-9.4" y2="-10.15" width="0.2032" layer="21" curve="-90"/>
<pad name="1" x="6.25" y="-6.25" drill="1.3" rot="R180"/>
<pad name="2" x="-6.25" y="-8.75" drill="1.3" rot="R180"/>
<pad name="NC2" x="-6.25" y="6.25" drill="1.3" rot="R180"/>
<pad name="C2" x="-1.25" y="6.25" drill="1.3" rot="R180"/>
<pad name="NC1" x="3.75" y="6.25" drill="1.3" rot="R180"/>
<pad name="NO1" x="6.25" y="8.75" drill="1.3" rot="R180"/>
<pad name="C1" x="1.25" y="8.75" drill="1.3" rot="R180"/>
<pad name="NO2" x="-3.75" y="8.75" drill="1.3" rot="R180"/>
<pad name="G" x="-3.75" y="3.75" drill="1.3" rot="R180"/>
<text x="-6.35" y="0.14" size="1.27" layer="25">&gt;NAME</text>
<text x="-6.35" y="-2.4" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="K2-PS">
<description>&lt;b&gt;RELAY Socked&lt;/b&gt; NAiS&lt;p&gt;
<wire x1="-8.9" y1="13.5" x2="-1.9" y2="13.5" width="0.2032" layer="21"/>
<wire x1="-1.9" y1="13.5" x2="1.9" y2="13.5" width="0.2032" layer="21"/>
<wire x1="1.9" y1="13.5" x2="8.9" y2="13.5" width="0.2032" layer="21"/>
<wire x1="9.4" y1="13" x2="9.4" y2="-10.15" width="0.2032" layer="21"/>
<wire x1="-9.4" y1="-10.15" x2="-9.4" y2="13" width="0.2032" layer="21"/>
<wire x1="-9.4" y1="13" x2="-8.9" y2="13.5" width="0.2032" layer="21" curve="-90"/>
<wire x1="8.9" y1="13.5" x2="9.4" y2="13" width="0.2032" layer="21" curve="-90"/>
<wire x1="-1.9" y1="13.5" x2="1.9" y2="13.5" width="0.2032" layer="21" curve="-106.465055"/>
<wire x1="1.9" y1="-10.75" x2="-1.9" y2="-10.75" width="0.2032" layer="21" curve="-106.465055"/>
<text x="-5" y="11.25" size="1.27" layer="21">NAiS Socked</text>
</package>
</packages>
<symbols>
<symbol name="U">
<wire x1="3.175" y1="5.08" x2="1.905" y2="5.08" width="0.254" layer="94"/>
<wire x1="-3.175" y1="5.08" x2="-1.905" y2="5.08" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="2.54" y2="5.715" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="0" y2="0" width="0.254" layer="94"/>
<circle x="0" y="1.27" radius="0.127" width="0.4064" layer="94"/>
<text x="2.54" y="0" size="1.778" layer="95">&gt;PART</text>
<pin name="O" x="5.08" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="S" x="-5.08" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="P" x="0" y="-2.54" visible="pad" length="short" direction="pas" rot="R90"/>
</symbol>
<symbol name="K">
<wire x1="-3.81" y1="-1.905" x2="-1.905" y2="-1.905" width="0.254" layer="94"/>
<wire x1="3.81" y1="-1.905" x2="3.81" y2="1.905" width="0.254" layer="94"/>
<wire x1="3.81" y1="1.905" x2="1.905" y2="1.905" width="0.254" layer="94"/>
<wire x1="-3.81" y1="1.905" x2="-3.81" y2="-1.905" width="0.254" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-1.905" width="0.1524" layer="94"/>
<wire x1="0" y1="-1.905" x2="3.81" y2="-1.905" width="0.254" layer="94"/>
<wire x1="0" y1="2.54" x2="0" y2="1.905" width="0.1524" layer="94"/>
<wire x1="0" y1="1.905" x2="-3.81" y2="1.905" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-1.905" x2="1.905" y2="1.905" width="0.1524" layer="94"/>
<wire x1="-1.905" y1="-1.905" x2="0" y2="-1.905" width="0.254" layer="94"/>
<wire x1="1.905" y1="1.905" x2="0" y2="1.905" width="0.254" layer="94"/>
<text x="1.27" y="2.921" size="1.778" layer="96">&gt;VALUE</text>
<text x="1.27" y="5.08" size="1.778" layer="95">&gt;PART</text>
<pin name="2" x="0" y="-5.08" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="1" x="0" y="5.08" visible="pad" length="short" direction="pas" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="K2EBP*" prefix="K">
<gates>
<gate name="_" symbol="K" x="-10.16" y="0" addlevel="must"/>
<gate name="1" symbol="U" x="7.62" y="5.08" addlevel="always" swaplevel="1"/>
<gate name="2" symbol="U" x="7.62" y="-7.62" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="" package="K2EBP">
<connects>
<connect gate="1" pin="O" pad="NC1"/>
<connect gate="1" pin="P" pad="C1"/>
<connect gate="1" pin="S" pad="NO1"/>
<connect gate="2" pin="O" pad="NC2"/>
<connect gate="2" pin="P" pad="C2"/>
<connect gate="2" pin="S" pad="NO2"/>
<connect gate="_" pin="1" pad="1"/>
<connect gate="_" pin="2" pad="2"/>
</connects>
<technologies>
<technology name="-110V-1">
<attribute name="MF" value="" constant="no"/>
<attribute name="MPN" value="" constant="no"/>
<attribute name="OC_FARNELL" value="unknown" constant="no"/>
<attribute name="OC_NEWARK" value="unknown" constant="no"/>
</technology>
<technology name="-12V-1">
</technology>
<technology name="-24V-1">
</technology>
<technology name="-28V-1">
</technology>
<technology name="-3V-1">
</technology>
<technology name="-48V-1">
</technology>
<technology name="-6V-1">
</technology>
</technologies>
</device>
<device name="S" package="K2-PS">
<connects>
</connects>
<technologies>
<technology name="">
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="special">
<description>&lt;b&gt;Special Devices&lt;/b&gt;&lt;p&gt;
7-segment displays, switches, heatsinks, crystals, transformers, etc.&lt;p&gt;
<packages>
<package name="BATTERY">
<description>&lt;B&gt;BATTERY&lt;/B&gt;&lt;p&gt;
22 mm</description>
<wire x1="0.635" y1="2.54" x2="0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-3.175" x2="2.54" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-2.54" x2="1.905" y2="-3.81" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="11.43" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="10.2362" width="0.1524" layer="21"/>
<pad name="-" x="-5.715" y="0" drill="1.016" shape="long"/>
<pad name="+" x="9.525" y="-5.08" drill="1.016" shape="long"/>
<pad name="+@1" x="9.525" y="5.08" drill="1.016" shape="long"/>
<text x="-4.1656" y="6.35" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.445" y="3.81" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-0.635" y1="-1.27" x2="0" y2="1.27" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="BATTERY">
<wire x1="-1.27" y1="3.81" x2="-1.27" y2="-3.81" width="0.4064" layer="94"/>
<wire x1="0" y1="1.27" x2="0" y2="-1.27" width="0.4064" layer="94"/>
<wire x1="1.27" y1="3.81" x2="1.27" y2="-3.81" width="0.4064" layer="94"/>
<wire x1="2.54" y1="1.27" x2="2.54" y2="-1.27" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="0" x2="-1.524" y2="0" width="0.1524" layer="94"/>
<text x="-3.81" y="5.08" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-6.35" size="1.778" layer="96">&gt;VALUE</text>
<pin name="-" x="5.08" y="0" visible="off" length="short" direction="pwr" rot="R180"/>
<pin name="+" x="-5.08" y="0" visible="off" length="short" direction="pwr"/>
<pin name="+@1" x="-2.54" y="0" visible="off" length="short" direction="pwr" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="BATTERY" prefix="BAT" uservalue="yes">
<description>&lt;B&gt;BATTERY&lt;/B&gt;</description>
<gates>
<gate name="G$1" symbol="BATTERY" x="0" y="0"/>
</gates>
<devices>
<device name="" package="BATTERY">
<connects>
<connect gate="G$1" pin="+" pad="+"/>
<connect gate="G$1" pin="+@1" pad="+@1"/>
<connect gate="G$1" pin="-" pad="-"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="con-ptr500">
<description>&lt;b&gt;PTR Connectors&lt;/b&gt;&lt;p&gt;
Aug. 2004 / PTR Meßtechnik:&lt;br&gt;
Die Bezeichnung der Serie AK505 wurde geändert.&lt;br&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.&lt;p&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=LEFT&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Alte Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Neue Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2DS,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2DS-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AKZ505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AKZ500/2-5.08-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TABLE&gt;
<packages>
<package name="AK300/2">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;</description>
<wire x1="5.08" y1="6.223" x2="5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.08" y1="6.223" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="5.08" y1="6.223" x2="5.588" y2="6.223" width="0.1524" layer="21"/>
<wire x1="5.588" y1="6.223" x2="5.588" y2="1.397" width="0.1524" layer="21"/>
<wire x1="5.588" y1="1.397" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-5.461" x2="5.08" y2="-5.207" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-5.207" x2="5.08" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.81" x2="5.08" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-4.064" x2="5.08" y2="-5.207" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.81" x2="5.588" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-6.223" x2="0.4572" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="0.254" x2="4.5212" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-6.223" x2="4.5212" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="-6.223" x2="5.08" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-6.223" x2="-0.4826" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-6.223" x2="0.4572" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="0.254" x2="-4.5466" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-6.223" x2="-4.5466" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="-6.223" x2="-0.4826" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-4.318" x2="4.5212" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-4.318" x2="0.4572" y2="0.254" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="-4.318" x2="4.5212" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-4.318" x2="-4.5466" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-4.318" x2="-0.4826" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="-4.318" x2="-4.5466" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="4.1402" y1="-3.683" x2="4.1402" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="4.1402" y1="-3.683" x2="0.8382" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="0.8382" y1="-3.683" x2="0.8382" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-0.8636" y1="-3.683" x2="-0.8636" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-0.8636" y1="-3.683" x2="-4.1656" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-4.1656" y1="-3.683" x2="-4.1656" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-4.1656" y1="-0.508" x2="-3.7846" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-0.8636" y1="-0.508" x2="-1.2446" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="0.8382" y1="-0.508" x2="1.2192" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="4.1402" y1="-0.508" x2="3.7592" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="-6.223" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.651" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="5.08" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.175" x2="5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.175" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.175" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="3.429" x2="0.4572" y2="5.969" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="5.969" x2="4.5212" y2="5.969" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="5.969" x2="4.5212" y2="3.429" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="3.429" x2="0.4572" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="3.429" x2="-0.4826" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="3.429" x2="-4.5466" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="3.429" x2="-4.5466" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="5.969" x2="-4.5466" y2="5.969" width="0.1524" layer="21"/>
<wire x1="3.9574" y1="4.0849" x2="4.0131" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="1.016" y1="4.1656" x2="4.0038" y2="4.1189" width="0.1524" layer="21" curve="75.530157"/>
<wire x1="0.8636" y1="5.0038" x2="4.0178" y2="5.0586" width="0.1524" layer="21" curve="-100.0232"/>
<wire x1="0.9144" y1="5.0546" x2="1.0581" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="0.8636" y1="4.445" x2="3.9116" y2="5.08" width="0.1524" layer="21"/>
<wire x1="0.9906" y1="4.318" x2="4.0386" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-1.0464" y1="4.0849" x2="-0.9907" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="-3.9878" y1="4.1656" x2="-1" y2="4.1188" width="0.1524" layer="21" curve="75.528719"/>
<wire x1="-4.1402" y1="5.0038" x2="-0.9858" y2="5.0588" width="0.1524" layer="21" curve="-100.022513"/>
<wire x1="-4.0894" y1="5.0546" x2="-3.9457" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="-4.1402" y1="4.445" x2="-1.0922" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-4.0132" y1="4.318" x2="-0.9652" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="0.254" x2="-4.1656" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="0.254" x2="-0.8636" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-0.8636" y1="0.254" x2="-4.1656" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="0.635" x2="-4.1656" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.1656" y1="0.635" x2="-0.8636" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.8636" y1="0.635" x2="0.8382" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="4.1402" y2="0.635" width="0.1524" layer="21"/>
<wire x1="4.1402" y1="0.635" x2="0.8382" y2="0.635" width="0.1524" layer="51"/>
<wire x1="4.5212" y1="0.254" x2="4.1402" y2="0.254" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="0.254" x2="0.8382" y2="0.254" width="0.1524" layer="21"/>
<wire x1="0.8382" y1="0.254" x2="4.1402" y2="0.254" width="0.1524" layer="51"/>
<pad name="1" x="-2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="2.4892" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-5.08" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-8.636" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.4958" y="1.27" size="1.27" layer="21" ratio="10">1</text>
<text x="0.5842" y="1.27" size="1.27" layer="21" ratio="10">2</text>
<rectangle x1="-3.7846" y1="-2.54" x2="-1.2446" y2="0.254" layer="51"/>
<rectangle x1="1.2192" y1="-2.54" x2="3.7592" y2="0.254" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="KL">
<circle x="1.27" y="0" radius="1.27" width="0.254" layer="94"/>
<text x="-1.27" y="0.889" size="1.778" layer="95" rot="R180">&gt;NAME</text>
<pin name="KL" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="KLV">
<text x="-3.81" y="-3.683" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="AK300/2" prefix="X" uservalue="yes">
<gates>
<gate name="-1" symbol="KL" x="0" y="5.08" addlevel="always"/>
<gate name="-2" symbol="KLV" x="0" y="0" addlevel="always"/>
</gates>
<devices>
<device name="" package="AK300/2">
<connects>
<connect gate="-1" pin="KL" pad="1"/>
<connect gate="-2" pin="KL" pad="2"/>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<parts>
<part name="K2" library="relay" deviceset="K2EBP*" device="" technology="-110V-1"/>
<part name="BAT1" library="special" deviceset="BATTERY" device=""/>
<part name="K1" library="relay" deviceset="K2EBP*" device="" technology="-110V-1"/>
<part name="X1" library="con-ptr500" deviceset="AK300/2" device=""/>
<part name="X2" library="con-ptr500" deviceset="AK300/2" device=""/>
</parts>
<sheets>
<sheet>
<plain>
<circle x="53.34" y="38.1" radius="2.54" width="0.1524" layer="91"/>
<text x="53.34" y="33.02" size="1.778" layer="91">motor</text>
<rectangle x1="27.94" y1="35.56" x2="35.56" y2="40.64" layer="91"/>
<text x="53.34" y="38.1" size="1.778" layer="91">M</text>
<text x="30.48" y="91.44" size="1.778" layer="91">220~</text>
<text x="27.94" y="30.48" size="1.778" layer="91">Inverter</text>
<rectangle x1="2.54" y1="5.08" x2="15.24" y2="10.16" layer="91"/>
<text x="7.62" y="2.54" size="1.778" layer="91">Töltő</text>
<text x="-7.62" y="-7.62" size="1.778" layer="91">220~</text>
</plain>
<instances>
<instance part="K2" gate="_" x="0" y="68.58" rot="R270"/>
<instance part="K2" gate="1" x="5.08" y="50.8" rot="R270"/>
<instance part="K2" gate="2" x="-7.62" y="50.8" rot="R270"/>
<instance part="BAT1" gate="G$1" x="7.62" y="20.32"/>
<instance part="K1" gate="_" x="58.42" y="71.12" rot="R270"/>
<instance part="K1" gate="1" x="63.5" y="53.34" rot="R270"/>
<instance part="K1" gate="2" x="50.8" y="53.34" rot="R270"/>
<instance part="X1" gate="-1" x="27.94" y="91.44" rot="R270"/>
<instance part="X1" gate="-2" x="25.4" y="91.44" rot="R270"/>
<instance part="X2" gate="-1" x="-5.08" y="2.54"/>
<instance part="X2" gate="-2" x="-5.08" y="-2.54"/>
</instances>
<busses>
</busses>
<nets>
<net name="N$1" class="0">
<segment>
<pinref part="K2" gate="_" pin="2"/>
<wire x1="-5.08" y1="68.58" x2="-5.08" y2="76.2" width="0.1524" layer="91"/>
<wire x1="-5.08" y1="76.2" x2="-2.54" y2="78.74" width="0.1524" layer="91"/>
<wire x1="-2.54" y1="78.74" x2="30.48" y2="78.74" width="0.1524" layer="91"/>
<wire x1="30.48" y1="78.74" x2="35.56" y2="78.74" width="0.1524" layer="91"/>
<wire x1="30.48" y1="78.74" x2="27.94" y2="81.28" width="0.1524" layer="91"/>
<wire x1="27.94" y1="81.28" x2="27.94" y2="86.36" width="0.1524" layer="91"/>
<pinref part="X1" gate="-1" pin="KL"/>
</segment>
</net>
<net name="N$2" class="0">
<segment>
<pinref part="K2" gate="_" pin="1"/>
<wire x1="5.08" y1="68.58" x2="5.08" y2="76.2" width="0.1524" layer="91"/>
<pinref part="K1" gate="_" pin="1"/>
<wire x1="63.5" y1="71.12" x2="63.5" y2="78.74" width="0.1524" layer="91"/>
<wire x1="63.5" y1="78.74" x2="40.64" y2="78.74" width="0.1524" layer="91"/>
<wire x1="40.64" y1="78.74" x2="38.1" y2="81.28" width="0.1524" layer="91"/>
<wire x1="5.08" y1="76.2" x2="10.16" y2="81.28" width="0.1524" layer="91"/>
<wire x1="10.16" y1="81.28" x2="22.86" y2="81.28" width="0.1524" layer="91"/>
<wire x1="22.86" y1="81.28" x2="38.1" y2="81.28" width="0.1524" layer="91"/>
<wire x1="22.86" y1="81.28" x2="25.4" y2="83.82" width="0.1524" layer="91"/>
<wire x1="25.4" y1="83.82" x2="25.4" y2="86.36" width="0.1524" layer="91"/>
<pinref part="X1" gate="-2" pin="KL"/>
</segment>
</net>
<net name="N$3" class="0">
<segment>
<pinref part="K2" gate="2" pin="O"/>
<wire x1="-2.54" y1="45.72" x2="-2.54" y2="38.1" width="0.1524" layer="91"/>
<wire x1="-2.54" y1="38.1" x2="27.94" y2="38.1" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$5" class="0">
<segment>
<pinref part="K2" gate="1" pin="P"/>
<wire x1="2.54" y1="50.8" x2="2.54" y2="27.94" width="0.1524" layer="91"/>
<pinref part="BAT1" gate="G$1" pin="-"/>
<wire x1="12.7" y1="20.32" x2="12.7" y2="27.94" width="0.1524" layer="91"/>
<wire x1="12.7" y1="27.94" x2="2.54" y2="27.94" width="0.1524" layer="91"/>
<wire x1="12.7" y1="20.32" x2="15.24" y2="17.78" width="0.1524" layer="91"/>
<wire x1="15.24" y1="17.78" x2="15.24" y2="10.16" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$6" class="0">
<segment>
<pinref part="K2" gate="2" pin="P"/>
<pinref part="BAT1" gate="G$1" pin="+"/>
<wire x1="2.54" y1="20.32" x2="-10.16" y2="20.32" width="0.1524" layer="91"/>
<wire x1="-10.16" y1="20.32" x2="-10.16" y2="50.8" width="0.1524" layer="91"/>
<wire x1="2.54" y1="20.32" x2="2.54" y2="10.16" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$4" class="0">
<segment>
<pinref part="K2" gate="1" pin="O"/>
<wire x1="10.16" y1="45.72" x2="15.24" y2="40.64" width="0.1524" layer="91"/>
<wire x1="15.24" y1="40.64" x2="27.94" y2="40.64" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$7" class="0">
<segment>
<pinref part="K1" gate="2" pin="P"/>
<wire x1="35.56" y1="40.64" x2="48.26" y2="53.34" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$8" class="0">
<segment>
<pinref part="K1" gate="2" pin="O"/>
<wire x1="55.88" y1="48.26" x2="53.34" y2="45.72" width="0.1524" layer="91"/>
<wire x1="53.34" y1="45.72" x2="53.34" y2="40.64" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$9" class="0">
<segment>
<wire x1="35.56" y1="38.1" x2="40.64" y2="43.18" width="0.1524" layer="91"/>
<wire x1="40.64" y1="43.18" x2="58.42" y2="43.18" width="0.1524" layer="91"/>
<pinref part="K1" gate="1" pin="P"/>
<wire x1="58.42" y1="43.18" x2="60.96" y2="45.72" width="0.1524" layer="91"/>
<wire x1="60.96" y1="45.72" x2="60.96" y2="53.34" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$10" class="0">
<segment>
<pinref part="K1" gate="1" pin="O"/>
<wire x1="68.58" y1="48.26" x2="58.42" y2="38.1" width="0.1524" layer="91"/>
<wire x1="58.42" y1="38.1" x2="55.88" y2="38.1" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$11" class="0">
<segment>
<pinref part="K1" gate="_" pin="2"/>
<wire x1="53.34" y1="71.12" x2="48.26" y2="76.2" width="0.1524" layer="91"/>
<wire x1="48.26" y1="76.2" x2="35.56" y2="76.2" width="0.1524" layer="91"/>
<wire x1="35.56" y1="76.2" x2="35.56" y2="78.74" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$12" class="0">
<segment>
<pinref part="X2" gate="-1" pin="KL"/>
<wire x1="0" y1="2.54" x2="5.08" y2="2.54" width="0.1524" layer="91"/>
<wire x1="5.08" y1="2.54" x2="5.08" y2="5.08" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$13" class="0">
<segment>
<pinref part="X2" gate="-2" pin="KL"/>
<wire x1="0" y1="-2.54" x2="12.7" y2="-2.54" width="0.1524" layer="91"/>
<wire x1="12.7" y1="-2.54" x2="12.7" y2="5.08" width="0.1524" layer="91"/>
</segment>
</net>
</nets>
</sheet>
</sheets>
</schematic>
</drawing>
</eagle>
