<?xml version="1.0" encoding="UTF-8"?>
<module fritzingVersion="0.7.0b.02.01.5801" moduleId="ff7b501695a6246faeeb506f44768cc8">
    <author>Gabcsi</author>
    <label>MCP23008</label>
    <date>2012-02-14</date>
    <tags>
        <tag>DIP</tag>
        <tag>I2C</tag>
    </tags>
    <properties>
        <property name="family">MCP23x008</property>
        <property name="part number"></property>
    </properties>
    <description>I2C bus 8 bit I/O expander</description>
    <views>
        <iconView>
            <layers image="icon/mcp23008__5980c78da6f5c26ca0aab66f46083d__icon__cf3ea4a049fb70e1bc5ca2e5927fd039.svg">
                <layer layerId="icon"/>
            </layers>
        </iconView>
        <breadboardView>
            <layers image="breadboard/mcp23008__5980c78da6f5c26ca0aab66f46083d__breadboard__4938f475ef57e124986395b19610ba47.svg">
                <layer layerId="breadboard"/>
            </layers>
        </breadboardView>
        <schematicView>
            <layers image="schematic/mcp23008__5980c78da6f5c26ca0aab66f46083d__schematic__abb25c06585957318bdf1e6308acef9c.svg">
                <layer layerId="schematic"/>
            </layers>
        </schematicView>
        <pcbView>
            <layers image="pcb/mcp23008__5980c78da6f5c26ca0aab66f46083d__pcb__4e7174eef5ea18057a909d488a1027ea.svg">
                <layer layerId="copper0"/>
                <layer layerId="silkscreen"/>
                <layer layerId="copper1"/>
            </layers>
        </pcbView>
    </views>
    <connectors>
        <connector id="connector15" type="male" name="GP2">
            <description>I/O port bit 2</description>
            <views>
                <breadboardView>
                    <p layer="breadboard" svgId="connector15"/>
                </breadboardView>
                <schematicView>
                    <p layer="schematic" svgId="connector15"/>
                </schematicView>
                <pcbView>
                    <p layer="copper0" svgId="connector15"/>
                </pcbView>
            </views>
        </connector>
        <connector id="connector7" type="male" name="A1">
            <description>Addres select bit 1</description>
            <views>
                <breadboardView>
                    <p layer="breadboard" svgId="connector7"/>
                </breadboardView>
                <schematicView>
                    <p layer="schematic" svgId="connector7"/>
                </schematicView>
                <pcbView>
                    <p layer="copper0" svgId="connector7"/>
                </pcbView>
            </views>
        </connector>
        <connector id="connector16" type="male" name="GP3">
            <description>I/O port bit 3</description>
            <views>
                <breadboardView>
                    <p layer="breadboard" svgId="connector16"/>
                </breadboardView>
                <schematicView>
                    <p layer="schematic" svgId="connector16"/>
                </schematicView>
                <pcbView>
                    <p layer="copper0" svgId="connector16"/>
                </pcbView>
            </views>
        </connector>
        <connector id="connector8" type="male" name="A0">
            <description>Addres select bit 0</description>
            <views>
                <breadboardView>
                    <p layer="breadboard" svgId="connector8"/>
                </breadboardView>
                <schematicView>
                    <p layer="schematic" svgId="connector8"/>
                </schematicView>
                <pcbView>
                    <p layer="copper0" svgId="connector8"/>
                </pcbView>
            </views>
        </connector>
        <connector id="connector17" type="male" name="GP4">
            <description>I/O port bit 4</description>
            <views>
                <breadboardView>
                    <p layer="breadboard" svgId="connector17"/>
                </breadboardView>
                <schematicView>
                    <p layer="schematic" svgId="connector17"/>
                </schematicView>
                <pcbView>
                    <p layer="copper0" svgId="connector17"/>
                </pcbView>
            </views>
        </connector>
        <connector id="connector9" type="male" name="R">
            <description>Reset</description>
            <views>
                <breadboardView>
                    <p layer="breadboard" svgId="connector9"/>
                </breadboardView>
                <schematicView>
                    <p layer="schematic" svgId="connector9"/>
                </schematicView>
                <pcbView>
                    <p layer="copper0" svgId="connector9"/>
                </pcbView>
            </views>
        </connector>
        <connector id="connector18" type="male" name="GP5">
            <description>I/O port bit 5</description>
            <views>
                <breadboardView>
                    <p layer="breadboard" svgId="connector18"/>
                </breadboardView>
                <schematicView>
                    <p layer="schematic" svgId="connector18"/>
                </schematicView>
                <pcbView>
                    <p layer="copper0" svgId="connector18"/>
                </pcbView>
            </views>
        </connector>
        <connector id="connector19" type="male" name="GP6">
            <description>I/O port bit 6</description>
            <views>
                <breadboardView>
                    <p layer="breadboard" svgId="connector19"/>
                </breadboardView>
                <schematicView>
                    <p layer="schematic" svgId="connector19"/>
                </schematicView>
                <pcbView>
                    <p layer="copper0" svgId="connector19"/>
                </pcbView>
            </views>
        </connector>
        <connector id="connector20" type="male" name="GP7">
            <description>I/O port bit 7</description>
            <views>
                <breadboardView>
                    <p layer="breadboard" svgId="connector20"/>
                </breadboardView>
                <schematicView>
                    <p layer="schematic" svgId="connector20"/>
                </schematicView>
                <pcbView>
                    <p layer="copper0" svgId="connector20"/>
                </pcbView>
            </views>
        </connector>
        <connector id="connector21" type="male" name="Vdd">
            <description>VDD</description>
            <views>
                <breadboardView>
                    <p layer="breadboard" svgId="connector21"/>
                </breadboardView>
                <schematicView>
                    <p layer="schematic" svgId="connector21"/>
                </schematicView>
                <pcbView>
                    <p layer="copper0" svgId="connector21"/>
                </pcbView>
            </views>
        </connector>
        <connector id="connector10" type="male" name="NC">
            <description>NC</description>
            <views>
                <breadboardView>
                    <p layer="breadboard" svgId="connector10"/>
                </breadboardView>
                <schematicView>
                    <p layer="schematic" svgId="connector10"/>
                </schematicView>
                <pcbView>
                    <p layer="copper0" svgId="connector10"/>
                </pcbView>
            </views>
        </connector>
        <connector id="connector11" type="male" name="INT">
            <description>Interrupt</description>
            <views>
                <breadboardView>
                    <p layer="breadboard" svgId="connector11"/>
                </breadboardView>
                <schematicView>
                    <p layer="schematic" svgId="connector11"/>
                </schematicView>
                <pcbView>
                    <p layer="copper0" svgId="connector11"/>
                </pcbView>
            </views>
        </connector>
        <connector id="connector4" type="male" name="SCL">
            <description>I2C Clock</description>
            <views>
                <breadboardView>
                    <p layer="breadboard" svgId="connector4"/>
                </breadboardView>
                <schematicView>
                    <p layer="schematic" svgId="connector4"/>
                </schematicView>
                <pcbView>
                    <p layer="copper0" svgId="connector4"/>
                </pcbView>
            </views>
        </connector>
        <connector id="connector12" type="male" name="Vss">
            <description>Vss-GND</description>
            <views>
                <breadboardView>
                    <p layer="breadboard" svgId="connector12"/>
                </breadboardView>
                <schematicView>
                    <p layer="schematic" svgId="connector12"/>
                </schematicView>
                <pcbView>
                    <p layer="copper0" svgId="connector12"/>
                </pcbView>
            </views>
        </connector>
        <connector id="connector5" type="male" name="SDA">
            <description>I2C Data</description>
            <views>
                <breadboardView>
                    <p layer="breadboard" svgId="connector5"/>
                </breadboardView>
                <schematicView>
                    <p layer="schematic" svgId="connector5"/>
                </schematicView>
                <pcbView>
                    <p layer="copper0" svgId="connector5"/>
                </pcbView>
            </views>
        </connector>
        <connector id="connector13" type="male" name="GP0">
            <description>I/O port bit 0</description>
            <views>
                <breadboardView>
                    <p layer="breadboard" svgId="connector13"/>
                </breadboardView>
                <schematicView>
                    <p layer="schematic" svgId="connector13"/>
                </schematicView>
                <pcbView>
                    <p layer="copper0" svgId="connector13"/>
                </pcbView>
            </views>
        </connector>
        <connector id="connector6" type="male" name="A2">
            <description>Addres select bit 2</description>
            <views>
                <breadboardView>
                    <p layer="breadboard" svgId="connector6"/>
                </breadboardView>
                <schematicView>
                    <p layer="schematic" svgId="connector6"/>
                </schematicView>
                <pcbView>
                    <p layer="copper0" svgId="connector6"/>
                </pcbView>
            </views>
        </connector>
        <connector id="connector14" type="male" name="GP1">
            <description>I/O port bit 1</description>
            <views>
                <breadboardView>
                    <p layer="breadboard" svgId="connector14"/>
                </breadboardView>
                <schematicView>
                    <p layer="schematic" svgId="connector14"/>
                </schematicView>
                <pcbView>
                    <p layer="copper0" svgId="connector14"/>
                </pcbView>
            </views>
        </connector>
    </connectors>
</module>
