<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="1.27" unitdist="mm" unit="mm" style="lines" multiple="1" display="yes" altdistance="0.025" altunitdist="inch" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="yes" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="yes" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<text x="64.77" y="12.7" size="2.54" layer="16" ratio="9" rot="MR0" align="center">By ALFA007</text>
<text x="57.15" y="62.23" size="2.54" layer="16" ratio="9" rot="MR0" align="center">CSÖVES ERŐSÍTŐ</text>
<text x="13.97" y="59.69" size="5.08" layer="16" ratio="9" rot="MR0" align="center">+</text>
<text x="13.97" y="53.34" size="5.08" layer="16" ratio="9" rot="MR0" align="center">-</text>
<text x="8.89" y="25.4" size="2.1844" layer="16" ratio="9" rot="MR0" align="center">IN</text>
<text x="29.21" y="12.7" size="2.1844" layer="16" ratio="9" rot="MR0" align="center">HEAT</text>
<text x="72.39" y="38.1" size="2.1844" layer="16" ratio="9" rot="MR0" align="center">OUT</text>
<circle x="7.62" y="63.5" radius="1.27" width="0.6096" layer="16"/>
<circle x="78.74" y="63.5" radius="1.27" width="0.6096" layer="16"/>
<circle x="7.62" y="10.16" radius="1.27" width="0.6096" layer="16"/>
<circle x="78.74" y="10.16" radius="1.27" width="0.6096" layer="16"/>
</plain>
<libraries>
<library name="belton-engineering">
<description>&lt;b&gt;Belton Engineering Co., Ltd.&lt;/b&gt;&lt;p&gt;
Unit 1208, Daerung Techno town 8&lt;br&gt;
481-11, Gasan-Dong&lt;br&gt;
Geumcheon-Gu, Seoul, Korea&lt;br&gt;
E-mail :&amp;lt;belton@unitel.co.kr&amp;gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="VT9-PT-C">
<description>&lt;b&gt;VACUUM TUBE SOCKET&lt;/b&gt;&lt;p&gt;
Source: 00004280-VT9-PT.pdf</description>
<wire x1="-7.325" y1="-1.4" x2="-7.325" y2="1.375" width="0.2032" layer="21"/>
<wire x1="-7.325" y1="1.375" x2="-5.325" y2="1.375" width="0.2032" layer="21"/>
<wire x1="-7.325" y1="-1.4" x2="-5.325" y2="-1.4" width="0.2032" layer="21"/>
<wire x1="-5.325" y1="-1.4" x2="-5.325" y2="1.375" width="0.2032" layer="21" curve="140.387625"/>
<wire x1="-5.05" y1="0" x2="-6.65" y2="0" width="0.2032" layer="21" curve="-106.333579"/>
<wire x1="-6.65" y1="0" x2="-5.05" y2="0" width="0.2032" layer="21" curve="-106.333579"/>
<wire x1="-6.7489" y1="3.1729" x2="-5.1178" y2="5.4179" width="0.2032" layer="21"/>
<wire x1="-5.1178" y1="5.4179" x2="-3.4998" y2="4.2423" width="0.2032" layer="21"/>
<wire x1="-6.7489" y1="3.1729" x2="-5.1309" y2="1.9973" width="0.2032" layer="21"/>
<wire x1="-5.1309" y1="1.9973" x2="-3.4998" y2="4.2423" width="0.2032" layer="21" curve="140.388692"/>
<wire x1="-4.0855" y1="2.9683" x2="-5.3799" y2="3.9087" width="0.2032" layer="21" curve="-106.328225"/>
<wire x1="-5.3799" y1="3.9087" x2="-4.0855" y2="2.9683" width="0.2032" layer="21" curve="-106.328225"/>
<wire x1="-5.1031" y1="-5.4381" x2="-6.7342" y2="-3.1931" width="0.2032" layer="21"/>
<wire x1="-6.7342" y1="-3.1931" x2="-5.1162" y2="-2.0175" width="0.2032" layer="21"/>
<wire x1="-5.1031" y1="-5.4381" x2="-3.4851" y2="-4.2625" width="0.2032" layer="21"/>
<wire x1="-3.4851" y1="-4.2625" x2="-5.1162" y2="-2.0175" width="0.2032" layer="21" curve="140.388692"/>
<wire x1="-4.0855" y1="-2.9683" x2="-5.3799" y2="-3.9087" width="0.2032" layer="21" curve="-106.328225"/>
<wire x1="-5.3799" y1="-3.9087" x2="-4.0855" y2="-2.9683" width="0.2032" layer="21" curve="-106.328225"/>
<wire x1="-0.932" y1="-7.3991" x2="-3.5712" y2="-6.5415" width="0.2032" layer="21"/>
<wire x1="-3.5712" y1="-6.5415" x2="-2.9532" y2="-4.6394" width="0.2032" layer="21"/>
<wire x1="-0.932" y1="-7.3991" x2="-0.314" y2="-5.4969" width="0.2032" layer="21"/>
<wire x1="-0.314" y1="-5.4969" x2="-2.9532" y2="-4.6394" width="0.2032" layer="21" curve="140.387334"/>
<wire x1="-1.5605" y1="-4.8028" x2="-2.0549" y2="-6.3245" width="0.2032" layer="21" curve="-106.331326"/>
<wire x1="-2.0549" y1="-6.3245" x2="-1.5605" y2="-4.8028" width="0.2032" layer="21" curve="-106.331326"/>
<wire x1="3.595" y1="-6.5338" x2="0.9558" y2="-7.3912" width="0.2032" layer="21"/>
<wire x1="0.9558" y1="-7.3912" x2="0.3377" y2="-5.4892" width="0.2032" layer="21"/>
<wire x1="3.595" y1="-6.5338" x2="2.9769" y2="-4.6316" width="0.2032" layer="21"/>
<wire x1="2.9769" y1="-4.6316" x2="0.3377" y2="-5.4892" width="0.2032" layer="21" curve="140.391178"/>
<wire x1="1.5605" y1="-4.8027" x2="2.0549" y2="-6.3244" width="0.2032" layer="21" curve="-106.331326"/>
<wire x1="2.0549" y1="-6.3244" x2="1.5605" y2="-4.8027" width="0.2032" layer="21" curve="-106.331326"/>
<wire x1="6.7489" y1="-3.1728" x2="5.1177" y2="-5.4178" width="0.2032" layer="21"/>
<wire x1="5.1177" y1="-5.4178" x2="3.4997" y2="-4.2423" width="0.2032" layer="21"/>
<wire x1="6.7489" y1="-3.1728" x2="5.1308" y2="-1.9972" width="0.2032" layer="21"/>
<wire x1="5.1308" y1="-1.9972" x2="3.4997" y2="-4.2423" width="0.2032" layer="21" curve="140.390319"/>
<wire x1="4.0855" y1="-2.9682" x2="5.3799" y2="-3.9087" width="0.2032" layer="21" curve="-106.333896"/>
<wire x1="5.3799" y1="-3.9087" x2="4.0855" y2="-2.9682" width="0.2032" layer="21" curve="-106.322554"/>
<wire x1="7.3248" y1="1.4" x2="7.3248" y2="-1.3749" width="0.2032" layer="21"/>
<wire x1="7.3248" y1="-1.3749" x2="5.3248" y2="-1.375" width="0.2032" layer="21"/>
<wire x1="7.3248" y1="1.4" x2="5.3248" y2="1.4" width="0.2032" layer="21"/>
<wire x1="5.3248" y1="1.4" x2="5.3248" y2="-1.375" width="0.2032" layer="21" curve="140.387625"/>
<wire x1="5.0499" y1="0" x2="6.6499" y2="0" width="0.2032" layer="21" curve="-106.342755"/>
<wire x1="6.6499" y1="0" x2="5.0499" y2="0" width="0.2032" layer="21" curve="-106.324403"/>
<wire x1="5.103" y1="5.4381" x2="6.734" y2="3.193" width="0.2032" layer="21"/>
<wire x1="6.734" y1="3.193" x2="5.1161" y2="2.0174" width="0.2032" layer="21"/>
<wire x1="5.103" y1="5.4381" x2="3.4849" y2="4.2625" width="0.2032" layer="21"/>
<wire x1="3.4849" y1="4.2625" x2="5.1161" y2="2.0174" width="0.2032" layer="21" curve="140.394837"/>
<wire x1="4.0854" y1="2.9683" x2="5.3798" y2="3.9087" width="0.2032" layer="21" curve="-106.328225"/>
<wire x1="5.3798" y1="3.9087" x2="4.0854" y2="2.9683" width="0.2032" layer="21" curve="-106.316884"/>
<wire x1="0.9319" y1="7.3989" x2="3.5711" y2="6.5413" width="0.2032" layer="21"/>
<wire x1="3.5711" y1="6.5413" x2="2.9532" y2="4.6392" width="0.2032" layer="21"/>
<wire x1="0.9319" y1="7.3989" x2="0.3139" y2="5.4968" width="0.2032" layer="21"/>
<wire x1="0.3139" y1="5.4968" x2="2.9532" y2="4.6392" width="0.2032" layer="21" curve="140.400249"/>
<wire x1="1.5604" y1="4.8027" x2="2.0548" y2="6.3243" width="0.2032" layer="21" curve="-106.327712"/>
<wire x1="2.0548" y1="6.3243" x2="1.5604" y2="4.8027" width="0.2032" layer="21" curve="-106.318065"/>
<wire x1="-9.7068" y1="8.8731" x2="-2.7989" y2="16.2574" width="0.2032" layer="21"/>
<wire x1="-2.7989" y1="16.2574" x2="2.7989" y2="16.2574" width="0.2032" layer="21" curve="-99.208325"/>
<wire x1="2.7989" y1="16.2574" x2="9.4091" y2="9.1709" width="0.2032" layer="21"/>
<wire x1="9.7068" y1="-8.8731" x2="2.7989" y2="-16.2574" width="0.2032" layer="21"/>
<wire x1="2.7989" y1="-16.2574" x2="-2.7989" y2="-16.2574" width="0.2032" layer="21" curve="-99.208325"/>
<wire x1="-2.7989" y1="-16.2574" x2="-9.4091" y2="-9.1709" width="0.2032" layer="21"/>
<wire x1="0.0596" y1="9.1709" x2="6.7293" y2="9.1709" width="0.2032" layer="51"/>
<wire x1="0.0596" y1="9.1709" x2="-6.7293" y2="9.1709" width="0.2032" layer="51"/>
<wire x1="-0.0596" y1="-9.1709" x2="-6.7293" y2="-9.1709" width="0.2032" layer="51"/>
<wire x1="-0.0596" y1="-9.1709" x2="6.7293" y2="-9.1709" width="0.2032" layer="51"/>
<wire x1="-3.3349" y1="12.6844" x2="-1.3697" y2="12.2675" width="0.2032" layer="21" curve="-53.145267"/>
<wire x1="-1.3697" y1="12.2675" x2="1.3697" y2="12.2675" width="0.2032" layer="21" curve="77.102205"/>
<wire x1="1.3697" y1="12.2675" x2="3.3944" y2="12.6844" width="0.2032" layer="21" curve="-53.832477"/>
<wire x1="3.3944" y1="12.6844" x2="3.5731" y2="-12.6248" width="0.2032" layer="21" curve="-148.626837"/>
<wire x1="3.5731" y1="-12.6248" x2="1.3101" y2="-12.208" width="0.2032" layer="21" curve="-53.055257"/>
<wire x1="1.3101" y1="-12.208" x2="-1.3697" y2="-12.208" width="0.2032" layer="21" curve="73.929045"/>
<wire x1="-1.3697" y1="-12.208" x2="-3.6326" y2="-12.6248" width="0.2032" layer="21" curve="-53.057275"/>
<wire x1="-3.6326" y1="-12.6248" x2="-3.3349" y2="12.6844" width="0.2032" layer="21" curve="-149.162192"/>
<wire x1="-11.0169" y1="4.5854" x2="-9.4091" y2="7.2652" width="0.2032" layer="21" curve="-159.839172"/>
<circle x="0" y="0" radius="9.15" width="0.2032" layer="21"/>
<circle x="0" y="0" radius="1.7365" width="0.2032" layer="21"/>
<circle x="0" y="0" radius="2.9817" width="0.2032" layer="21"/>
<circle x="0" y="0" radius="11.4" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="11.8" width="0.2032" layer="51"/>
<circle x="0" y="-14.1136" radius="1.728" width="0.2032" layer="21"/>
<circle x="0" y="14.1136" radius="1.6716" width="0.2032" layer="21"/>
<pad name="1" x="-8.4946" y="6.1717" drill="1.8" diameter="2.4" rot="R342"/>
<pad name="2" x="-10.5" y="0" drill="1.8" diameter="2.4" rot="R90"/>
<pad name="3" x="-8.4946" y="-6.1717" drill="1.8" diameter="2.4" rot="R126"/>
<pad name="4" x="-3.2446" y="-9.986" drill="1.8" diameter="2.4" rot="R162"/>
<pad name="5" x="3.2446" y="-9.9859" drill="1.8" diameter="2.4" rot="R198"/>
<pad name="6" x="8.4946" y="-6.1716" drill="1.8" diameter="2.4" rot="R234"/>
<pad name="7" x="10.4998" y="0" drill="1.8" diameter="2.4" rot="R270"/>
<pad name="8" x="8.4945" y="6.1717" drill="1.8" diameter="2.4" rot="R306"/>
<pad name="9" x="3.2445" y="9.9859" drill="1.8" diameter="2.4" rot="R342"/>
<pad name="G" x="0" y="14.25" drill="1.3" diameter="2.4"/>
<text x="-12.065" y="7.62" size="1.27" layer="25" font="vector" rot="R90">&gt;NAME</text>
<text x="15.24" y="-3.175" size="1.27" layer="27" font="vector" rot="R90">&gt;VALUE</text>
<text x="-7.2652" y="4.3472" size="1.5" layer="21" font="vector" rot="SR0">1</text>
<text x="-9.0518" y="-0.8337" size="1.5" layer="21" font="vector">2</text>
<text x="-7.027" y="-5.836" size="1.5" layer="21" font="vector">3</text>
<text x="-3.1562" y="-8.6349" size="1.5" layer="21" font="vector">4</text>
<text x="1.9056" y="-8.6349" size="1.5" layer="21" font="vector">5</text>
<text x="6.1338" y="-5.4191" size="1.5" layer="21" font="vector">6</text>
<text x="7.8012" y="-0.8337" size="1.5" layer="21" font="vector">7</text>
<text x="6.0742" y="4.1686" size="1.5" layer="21" font="vector">8</text>
<text x="1.8461" y="7.1461" size="1.5" layer="21" font="vector">9</text>
</package>
</packages>
</library>
<library name="resistor">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;map name="nav_main"&gt;
&lt;area shape="rect" coords="0,1,140,23" href="../military_specs.asp" title=""&gt;
&lt;area shape="rect" coords="0,24,140,51" href="../about.asp" title=""&gt;
&lt;area shape="rect" coords="1,52,140,77" href="../rfq.asp" title=""&gt;
&lt;area shape="rect" coords="0,78,139,103" href="../products.asp" title=""&gt;
&lt;area shape="rect" coords="1,102,138,128" href="../excess_inventory.asp" title=""&gt;
&lt;area shape="rect" coords="1,129,138,150" href="../edge.asp" title=""&gt;
&lt;area shape="rect" coords="1,151,139,178" href="../industry_links.asp" title=""&gt;
&lt;area shape="rect" coords="0,179,139,201" href="../comments.asp" title=""&gt;
&lt;area shape="rect" coords="1,203,138,231" href="../directory.asp" title=""&gt;
&lt;area shape="default" nohref&gt;
&lt;/map&gt;
&lt;html&gt;
&lt;title&gt;&lt;/title&gt;
 &lt;LINK REL="StyleSheet" TYPE="text/css" HREF="style-sheet.css"&gt;
&lt;body bgcolor="#ffffff" text="#000000" marginwidth="0" marginheight="0" topmargin="0" leftmargin="0"&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0 height="55%"&gt;
&lt;tr valign="top"&gt;
&lt;/td&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;
&lt;/BODY&gt;&lt;/HTML&gt;</description>
<packages>
<package name="0411/15">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0411, grid 15 mm</description>
<wire x1="5.08" y1="-1.651" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.032" x2="5.08" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.08" y1="-1.651" x2="-4.699" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="4.699" y1="-2.032" x2="5.08" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.651" x2="-4.699" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="2.032" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="1.905" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.032" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-1.905" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="3.937" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="3.937" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.651" x2="-5.08" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.032" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-2.032" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0" x2="-6.35" y2="0" width="0.762" layer="51"/>
<wire x1="6.35" y1="0" x2="7.62" y2="0" width="0.762" layer="51"/>
<pad name="1" x="-7.62" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.9144" shape="octagon"/>
<text x="-5.08" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.5814" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="5.08" y1="-0.381" x2="6.477" y2="0.381" layer="21"/>
<rectangle x1="-6.477" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
</package>
<package name="C025-025X050">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 2.5 mm, outline 2.5 x 5 mm</description>
<wire x1="-2.159" y1="1.27" x2="2.159" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.27" x2="-2.159" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.27" x2="2.413" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.016" x2="-2.159" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.27" x2="2.413" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.016" x2="-2.159" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.286" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0204/7">
type 0204, grid 7.5 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0.762" x2="-2.286" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.286" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-1.016" x2="2.54" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.016" x2="2.54" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.54" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.889" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.889" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="-1.778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="-1.778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.762" x2="2.54" y2="0.762" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="1.2954" size="0.9906" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.6256" y="-0.4826" size="0.9906" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.54" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.54" y2="0.254" layer="21"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules>
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<description language="hu">&lt;b&gt;EAGLE Tervezési Szabályok&lt;/b&gt;&lt;p&gt;Az alapértelmezett Tervezési Szabályok úgy lettek megállapítva, hogy használhatók legyenek minél többféle alkalmazás megtervezéséhez.A Te általad tervezni kívánt termék más beállításokat követelhet meg,így megkérlek, hogy tedd meg a neked szükséges beállításokat, és mentsd elegy másik néven.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="E$1" library="belton-engineering" package="VT9-PT-C" value="" x="43.18" y="36.83"/>
<element name="R7" library="resistor" package="0411/15" value="10k" x="57.15" y="52.07"/>
<element name="E$3" library="resistor" package="0411/15" value="470k" x="64.77" y="41.91" rot="R270"/>
<element name="R1" library="resistor" package="0411/15" value="100k" x="30.48" y="54.61" rot="R90"/>
<element name="R3" library="resistor" package="0411/15" value="560" x="22.86" y="26.67"/>
<element name="R4" library="resistor" package="0411/15" value="150" x="54.61" y="16.51" rot="R180"/>
<element name="R5" library="resistor" package="0411/15" value="1k" x="58.42" y="33.02" rot="R90"/>
<element name="C3" library="resistor" package="C025-025X050" value="10n" x="62.23" y="58.42" rot="R180"/>
<element name="C1" library="resistor" package="C025-025X050" value="10n" x="21.59" y="35.56"/>
<element name="C2" library="resistor" package="C025-025X050" value="22p" x="41.91" y="57.15" rot="R90"/>
<element name="R2" library="resistor" package="0204/7" value="3,3M" x="21.59" y="41.91"/>
</elements>
<signals>
<signal name="S$1">
<via x="35.56" y="10.16" extent="1-16" drill="0.6" diameter="2.54"/>
<wire x1="39.37" y1="26.67" x2="35.56" y2="22.86" width="1.9304" layer="16" curve="90"/>
<wire x1="35.56" y1="22.86" x2="35.56" y2="10.16" width="1.9304" layer="16"/>
</signal>
<signal name="S$2">
<via x="40.64" y="10.16" extent="1-16" drill="0.6" diameter="2.54"/>
<wire x1="46.99" y1="26.67" x2="40.64" y2="20.32" width="1.9304" layer="16" curve="90"/>
<wire x1="40.64" y1="20.32" x2="40.64" y2="10.16" width="1.9304" layer="16"/>
</signal>
<signal name="S$4">
<via x="12.7" y="35.56" extent="1-16" drill="0.6" diameter="2.54"/>
<contactref element="C1" pad="1"/>
<wire x1="20.32" y1="35.56" x2="12.7" y2="35.56" width="1.9304" layer="16"/>
</signal>
<signal name="S$5">
<contactref element="R3" pad="2"/>
<wire x1="30.48" y1="26.67" x2="34.29" y2="30.48" width="1.9304" layer="16" curve="90"/>
<contactref element="E$1" pad="4"/>
<wire x1="30.48" y1="26.67" x2="39.9354" y2="26.844" width="0" layer="19" extent="1-16"/>
</signal>
<signal name="S$6">
<contactref element="R2" pad="2"/>
<wire x1="25.4" y1="35.56" x2="25.4" y2="36.83" width="1.9304" layer="16"/>
<wire x1="25.4" y1="36.83" x2="33.02" y2="36.83" width="1.9304" layer="16"/>
<contactref element="C1" pad="2"/>
<wire x1="22.86" y1="35.56" x2="25.4" y2="35.56" width="1.9304" layer="16"/>
<wire x1="25.4" y1="36.83" x2="25.4" y2="41.91" width="1.9304" layer="16"/>
</signal>
<signal name="S$9">
<via x="19.05" y="58.42" extent="1-16" drill="0.6" diameter="2.54"/>
<contactref element="R1" pad="2"/>
<wire x1="19.05" y1="58.42" x2="22.86" y2="62.23" width="1.9304" layer="16" curve="-90"/>
<wire x1="22.86" y1="62.23" x2="30.48" y2="62.23" width="1.9304" layer="16"/>
</signal>
<signal name="S$11">
<wire x1="45.72" y1="46.99" x2="46.99" y2="46.99" width="1.9304" layer="16"/>
<contactref element="R7" pad="1"/>
<wire x1="46.99" y1="46.99" x2="49.53" y2="49.53" width="1.9304" layer="16" curve="90"/>
<wire x1="49.53" y1="49.53" x2="49.53" y2="52.07" width="1.9304" layer="16"/>
</signal>
<signal name="S$12">
<contactref element="R7" pad="2"/>
<contactref element="E$3" pad="1"/>
<wire x1="64.77" y1="52.07" x2="64.77" y2="49.53" width="1.9304" layer="16"/>
<contactref element="C3" pad="1"/>
<wire x1="63.5" y1="58.42" x2="64.77" y2="52.07" width="1.9304" layer="16"/>
</signal>
<signal name="S$3">
<contactref element="C3" pad="2"/>
<wire x1="60.96" y1="58.42" x2="40.64" y2="58.42" width="1.9304" layer="16"/>
<wire x1="40.64" y1="58.42" x2="35.56" y2="53.34" width="1.9304" layer="16" curve="90"/>
<wire x1="35.56" y1="53.34" x2="35.56" y2="49.53" width="1.9304" layer="16"/>
<contactref element="R1" pad="1"/>
<wire x1="34.29" y1="43.18" x2="33.02" y2="44.45" width="1.9304" layer="16" curve="-90"/>
<wire x1="33.02" y1="44.45" x2="30.48" y2="46.99" width="1.9304" layer="16"/>
<wire x1="35.56" y1="49.53" x2="33.02" y2="46.99" width="1.9304" layer="16" curve="-90"/>
<wire x1="33.02" y1="46.99" x2="30.48" y2="46.99" width="1.9304" layer="16"/>
</signal>
<signal name="S$10">
<contactref element="R5" pad="2"/>
<wire x1="53.34" y1="36.83" x2="58.42" y2="40.64" width="1.9304" layer="16"/>
</signal>
<signal name="S$14">
<via x="73.66" y="27.94" extent="1-16" drill="0.6" diameter="1.778"/>
<contactref element="R5" pad="1"/>
<wire x1="58.42" y1="25.4" x2="60.96" y2="27.94" width="1.9304" layer="16" curve="-90"/>
<wire x1="60.96" y1="27.94" x2="73.66" y2="27.94" width="1.9304" layer="16"/>
</signal>
<signal name="S$7">
<contactref element="E$3" pad="2"/>
<wire x1="64.77" y1="34.29" x2="63.5" y2="33.02" width="1.9304" layer="16" curve="-90"/>
<wire x1="63.5" y1="33.02" x2="58.42" y2="33.02" width="1.9304" layer="16"/>
<wire x1="58.42" y1="33.02" x2="54.61" y2="29.21" width="1.9304" layer="16" curve="90"/>
<wire x1="54.61" y1="29.21" x2="54.61" y2="26.67" width="1.9304" layer="16"/>
<wire x1="54.61" y1="26.67" x2="52.07" y2="24.13" width="1.9304" layer="16" curve="-90"/>
<wire x1="52.07" y1="24.13" x2="49.53" y2="24.13" width="1.9304" layer="16"/>
<wire x1="49.53" y1="24.13" x2="46.99" y2="21.59" width="1.9304" layer="16" curve="90"/>
<wire x1="46.99" y1="21.59" x2="46.99" y2="16.51" width="1.9304" layer="16"/>
<via x="19.05" y="52.07" extent="1-16" drill="0.6" diameter="2.54"/>
<via x="12.7" y="31.75" extent="1-16" drill="0.6" diameter="2.54"/>
<contactref element="R3" pad="1"/>
<wire x1="15.24" y1="26.67" x2="12.7" y2="29.21" width="1.9304" layer="16" curve="-90"/>
<wire x1="12.7" y1="29.21" x2="12.7" y2="31.75" width="1.9304" layer="16"/>
<wire x1="12.7" y1="31.75" x2="7.62" y2="31.75" width="1.9304" layer="16"/>
<wire x1="7.62" y1="31.75" x2="7.62" y2="39.37" width="1.9304" layer="16"/>
<wire x1="7.62" y1="39.37" x2="17.78" y2="39.37" width="1.9304" layer="16"/>
<contactref element="R2" pad="1"/>
<wire x1="17.78" y1="39.37" x2="17.78" y2="41.91" width="1.9304" layer="16"/>
<wire x1="19.05" y1="52.07" x2="17.78" y2="50.8" width="1.9304" layer="16" curve="90"/>
<wire x1="17.78" y1="50.8" x2="17.78" y2="41.91" width="1.9304" layer="16"/>
<wire x1="15.24" y1="26.67" x2="25.4" y2="16.51" width="1.9304" layer="16" curve="90"/>
<wire x1="25.4" y1="16.51" x2="30.48" y2="16.51" width="1.9304" layer="16"/>
<via x="30.48" y="16.51" extent="1-16" drill="0.6" diameter="1.778"/>
<via x="44.45" y="16.51" extent="1-16" drill="0.6" diameter="1.778"/>
<wire x1="30.48" y1="16.51" x2="44.45" y2="16.51" width="1.9304" layer="1"/>
<wire x1="46.99" y1="16.51" x2="44.45" y2="16.51" width="1.9304" layer="16"/>
</signal>
<signal name="S$8">
<via x="48.26" y="33.02" extent="1-16" drill="0.6" diameter="1.778"/>
<contactref element="C2" pad="1"/>
<wire x1="41.91" y1="55.88" x2="40.64" y2="54.61" width="1.9304" layer="16" curve="90"/>
<wire x1="40.64" y1="54.61" x2="40.64" y2="36.83" width="1.9304" layer="16"/>
<wire x1="40.64" y1="36.83" x2="46.99" y2="30.48" width="1.9304" layer="16" curve="90"/>
<wire x1="46.99" y1="30.48" x2="48.26" y2="30.48" width="1.9304" layer="16"/>
<wire x1="48.26" y1="30.48" x2="52.07" y2="30.48" width="1.9304" layer="16"/>
<wire x1="48.26" y1="33.02" x2="48.26" y2="30.48" width="1.9304" layer="16"/>
<via x="68.58" y="33.02" extent="1-16" drill="0.6" diameter="1.778"/>
<via x="73.66" y="33.02" extent="1-16" drill="0.6" diameter="1.778"/>
<wire x1="68.58" y1="33.02" x2="73.66" y2="33.02" width="1.9304" layer="16"/>
<wire x1="48.26" y1="33.02" x2="68.58" y2="33.02" width="1.9304" layer="1"/>
</signal>
<signal name="R6">
<wire x1="52.07" y1="43.18" x2="76.2" y2="43.18" width="1.9304" layer="16"/>
<wire x1="76.2" y1="43.18" x2="77.47" y2="41.91" width="1.9304" layer="16" curve="-90"/>
<wire x1="77.47" y1="41.91" x2="77.47" y2="24.13" width="1.9304" layer="16"/>
<wire x1="77.47" y1="24.13" x2="76.2" y2="22.86" width="1.9304" layer="16" curve="-90"/>
<wire x1="76.2" y1="22.86" x2="67.31" y2="22.86" width="1.9304" layer="16"/>
<contactref element="R4" pad="1"/>
<wire x1="67.31" y1="22.86" x2="62.23" y2="17.78" width="1.9304" layer="16" curve="90"/>
<wire x1="62.23" y1="17.78" x2="62.23" y2="16.51" width="1.9304" layer="16"/>
</signal>
<signal name="S$13">
<wire x1="5.08" y1="7.62" x2="5.08" y2="66.04" width="0.8128" layer="16"/>
<wire x1="5.08" y1="66.04" x2="81.28" y2="66.04" width="0.8128" layer="16"/>
<wire x1="81.28" y1="66.04" x2="81.28" y2="7.62" width="0.8128" layer="16"/>
<wire x1="81.28" y1="7.62" x2="5.08" y2="7.62" width="0.8128" layer="16"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
