	list    	p=18f4523            ; list directive to define processor
	radix		dec
	errorlevel 	0,-302
	errorlevel 	0,-306
	#include 	<p18f4523.inc>        ; processor specific variable definitions
	#include 	<C:\\Users\Reechee\Desktop\csirke\program\macro_18f.asm>	;tamogato2
;*		CONFIGURATION REGISTER			*							*
;   IMPORTANT: For the PIC18 devices, the __CONFIG directive has been
;              superseded by the CONFIG directive.  The following settings
;              are available for this device.
;   Oscillator Selection bits:
;     OSC = LP             LP oscillator
;     OSC = XT             XT oscillator
;     OSC = HS             HS oscillator
;     OSC = RC             External RC oscillator, CLKO function on RA6
;     OSC = EC             EC oscillator, CLKO function on RA6
;     OSC = ECIO6          EC oscillator, port function on RA6
;     OSC = HSPLL          HS oscillator, PLL enabled (Clock Frequency = 4 x FOSC1)
;     OSC = RCIO6          External RC oscillator, port function on RA6
	  CONFIG      OSC = INTIO67        ;Internal oscillator block, port function on RA6 and RA7
;     OSC = INTIO7         Internal oscillator block, CLKO function on RA6, port function on RA7
;   Fail-Safe Clock Monitor Enable bit:
;     FCMEN = OFF          Fail-Safe Clock Monitor disabled
;     FCMEN = ON           Fail-Safe Clock Monitor enabled
;   Internal/External Oscillator Switchover bit:
;     IESO = OFF           Oscillator Switchover mode disabled
;     IESO = ON            Oscillator Switchover mode enabled
;   Power-up Timer Enable bit:
	CONFIG     PWRT = ON           ; PWRT enabled
;     PWRT = OFF           PWRT disabled
;   Brown-out Reset Enable bits:
;     BOREN = OFF          Brown-out Reset disabled in hardware and software
      CONFIG BOREN = OFF          ; Brown-out Reset enabled and controlled by software (SBOREN is enabled)
;     BOREN = NOSLP        Brown-out Reset enabled in hardware only and disabled in Sleep mode (SBOREN is disabled)
;     BOREN = SBORDIS      Brown-out Reset enabled in hardware only (SBOREN is disabled)
;   Brown Out Reset Voltage bits:
;     BORV = 0             Maximum setting
;     BORV = 1             
;     BORV = 2             
;     BORV = 3             Minimum setting
;   Watchdog Timer Enable bit:
      CONFIG WDT = OFF           ;WDT disabled (control is placed on the SWDTEN bit)
;     WDT = ON             WDT enabled
;   Watchdog Timer Postscale Select bits:
;     WDTPS = 1            1:1
;     WDTPS = 2            1:2
;     WDTPS = 4            1:4
;     WDTPS = 8            1:8
;     WDTPS = 16           1:16
;     WDTPS = 32           1:32
;     WDTPS = 64           1:64
;     WDTPS = 128          1:128
;     WDTPS = 256          1:256
;     WDTPS = 512          1:512
;     WDTPS = 1024         1:1024
;     WDTPS = 2048         1:2048
	  CONFIG     WDTPS = 4096         ;1:4096
;     WDTPS = 8192         1:8192
;     WDTPS = 16384        1:16384
;     WDTPS = 32768        1:32768
;   CCP2 MUX bit:
;     CCP2MX = PORTB       CCP2 input/output is multiplexed with RB3
;     CCP2MX = PORTC       CCP2 input/output is multiplexed with RC1
;   PORTB A/D Enable bit:
;     PBADEN = OFF         PORTB<4:0> pins are configured as digital I/O on Reset
;     PBADEN = ON          PORTB<4:0> pins are configured as analog input channels on Reset
;   Low-Power Timer1 Oscillator Enable bit:
 	  CONFIG     LPT1OSC = OFF       ; Timer1 configured for higher power operation
;     LPT1OSC = ON         Timer1 configured for low-power operation
;   MCLR Pin Enable bit:
;     MCLRE = OFF          RE3 input pin enabled; MCLR disabled
     CONFIG MCLRE = ON           ;MCLR pin enabled; RE3 input pin disabled
;   Stack Full/Underflow Reset Enable bit:
;     STVREN = OFF         Stack full/underflow will not cause Reset
;      CONFIG STVREN = ON         ;Stack full/underflow will cause Reset
;   Single-Supply ICSP Enable bit:
      CONFIG LVP = OFF           ; Single-Supply ICSP disabled
;     LVP = ON             Single-Supply ICSP enabled
;   Extended Instruction Set Enable bit:
      CONFIG XINST = OFF        ;  Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
;     XINST = ON           Instruction set extension and Indexed Addressing mode enabled
;   Background Debugger Enable bit:
      ;CONFIG DEBUG = ON          ; Background debugger enabled, RB6 and RB7 are dedicated to In-Circuit Debug
;     DEBUG = OFF          Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins
;   Code Protection bit:
;     CP0 = ON             Block 0 (000800-001FFFh) code-protected
      CONFIG CP0 = OFF           ; Block 0 (000800-001FFFh) not code-protected
;     CP1 = ON             Block 1 (002000-003FFFh) code-protected
      CONFIG	CP1 = OFF            ;Block 1 (002000-003FFFh) not code-protected
;     CP2 = ON             Block 2 (004000-005FFFh) code-protected
      CONFIG	CP2 = OFF            ;Block 2 (004000-005FFFh) not code-protected
;     CP3 = ON             Block 3 (006000-007FFFh) code-protected
      CONFIG	CP3 = OFF            ;Block 3 (006000-007FFFh) not code-protected
;   Boot Block Code Protection bit:
;     CPB = ON             Boot block (000000-0007FFh) code-protected
;     CPB = OFF            Boot block (000000-0007FFh) not code-protected
;   Data EEPROM Code Protection bit:
;     CPD = ON             Data EEPROM code-protected
;     CPD = OFF            Data EEPROM not code-protected
;   Write Protection bit:
;     WRT0 = ON            Block 0 (000800-001FFFh) write-protected
;     WRT0 = OFF           Block 0 (000800-001FFFh) not write-protected
;     WRT1 = ON            Block 1 (002000-003FFFh) write-protected
;     WRT1 = OFF           Block 1 (002000-003FFFh) not write-protected
;     WRT2 = ON            Block 2 (004000-005FFFh) write-protected
;     WRT2 = OFF           Block 2 (004000-005FFFh) not write-protected
;     WRT3 = ON            Block 3 (006000-007FFFh) write-protected
;     WRT3 = OFF           Block 3 (006000-007FFFh) not write-protected
;   Configuration Register Write Protection bit:
;     WRTC = ON            Configuration registers (300000-3000FFh) write-protected
;     WRTC = OFF           Configuration registers (300000-3000FFh) not write-protected
;   Boot Block Write Protection bit:
;     WRTB = ON            Boot block (000000-0007FFh) write-protected
;     WRTB = OFF           Boot block (000000-0007FFh) not write-protected
;   Data EEPROM Write Protection bit:
;     WRTD = ON            Data EEPROM write-protected
;     WRTD = OFF           Data EEPROM not write-protected
;   Table Read Protection bit:
;     EBTR0 = ON           Block 0 (000800-001FFFh) protected from table reads executed in other blocks
;     EBTR0 = OFF          Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
;     EBTR1 = ON           Block 1 (002000-003FFFh) protected from table reads executed in other blocks
;     EBTR1 = OFF          Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
;     EBTR2 = ON           Block 2 (004000-005FFFh) protected from table reads executed in other blocks
;     EBTR2 = OFF          Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
;     EBTR3 = ON           Block 3 (006000-007FFFh) protected from table reads executed in other blocks
;     EBTR3 = OFF          Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
;   Boot Block Table Read Protection bit:
;     EBTRB = ON           Boot block (000000-0007FFh) protected from table reads executed in other blocks
;     EBTRB = OFF          Boot block (000000-0007FFh) not protected from table reads executed in other blocks
; RÉGI
;		CONFIG	OSC=INTIO67
		;CONFIG	FCMEN=OFF
		;CONFIG	IESO=OFF
		;CONFIG	WDT=OFF
		;CONFIG	PWRT=OFF
		;CONFIG	BOREN=OFF
		;CONFIG	MCLRE=ON
		;CONFIG	STVREN=ON
		;CONFIG	LVP=OFF
		;CONFIG	DEBUG=ON;!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
		;CONFIG	PBADEN = OFF 
		;CONFIG	CP0=Off
;		CONFIG	CP1=Off
;		CONFIG	CPB=Off
;		CONFIG	CPD=Off
;		CONFIG	WRT0=Off
;		CONFIG	WRT1=Off
;		CONFIG	WRTB=Off
;		CONFIG	WRTC=Off
;		CONFIG	EBTR0=Off
;		CONFIG	EBTR1=Off
;		CONFIG	EBTRB=Off
;*		D E F I N E		*
#define 	led		PORTB,4
#define		DB4		PORTD,0
#define		DB5		PORTD,1
#define		DB6		PORTD,2
#define		DB7		PORTD,3
#define		lcd_rs	PORTE,0
#define		lcd_rw	PORTE,1
#define		lcd_e	PORTE,2
#define		lcd		PORTD
;***** SPECIAL FILE REGISTERS *******
	CBLOCK	0x000
	del1
	del2
	del3
	ENDC
	org	0
	bra	pos		;power on
;*	I N T E R U P T                                                   			*
;	M A I N - P R O G R A M 	          	    *
pos	call	inic
;************ LCD INIC **********************
	call	del20ms
	call	del20ms
	call	del20ms
	call	del20ms
	call	del20ms
	movlw	b'00000011' ;8bit mode x1
	movwf	PORTD
	bsf		lcd_e
	bsf		lcd_e
	nop
	nop
	nop
	nop
	bcf		lcd_e
	bcf		lcd_e
	call	del20ms
	movlw	b'00000011' ;8bit mode x2
	movwf	PORTD
	bsf		lcd_e
	bsf		lcd_e
	nop
	nop
	nop
	nop
	bcf		lcd_e
	bcf		lcd_e
	call	del20ms
	movlw	b'00000011' ;8bit mode x3
	movwf	PORTD
	bsf		lcd_e
	bsf		lcd_e
	nop
	nop
	nop
	nop
	bcf		lcd_e
	bcf		lcd_e
	call	del20ms
;*** SIMA KIÍRÁS ***
	movlw	b'00000010' ;4bit mode
	movwf	PORTD
	bsf		lcd_e
	bsf		lcd_e
	nop
	nop
	nop
	nop
	bcf		lcd_e
	bcf		lcd_e
	call	del20ms
	movlw	b'00000010' ;5x8
	movwf	PORTD
	bsf		lcd_e
	bsf		lcd_e
	nop
	nop
	nop
	nop
	bcf		lcd_e
	bcf		lcd_e
	call	del20ms
	movlw	b'00000000' 
	movwf	PORTD
	bsf		lcd_e
	bsf		lcd_e
	nop
	nop
	nop
	nop
	bcf		lcd_e
	bcf		lcd_e
	call	del20ms
	movlw	b'00000000' ;control: display OFF, cursor OFF, blink OFF,
	movwf	PORTD
	bsf		lcd_e
	bsf		lcd_e
	nop
	nop
	nop
	nop
	bcf		lcd_e
	bcf		lcd_e
	call	del20ms
	movlw	b'00001000' 
	movwf	PORTD
	bsf		lcd_e
	bsf		lcd_e
	nop
	nop
	nop
	nop
	bcf		lcd_e
	bcf		lcd_e
	call	del20ms
	movlw	b'00000000' ; Clear display.
	movwf	PORTD
	bsf		lcd_e
	bsf		lcd_e
	nop
	nop
	nop
	nop
	bcf		lcd_e
	bcf		lcd_e
	call	del20ms
	movlw	b'00000001' 
	movwf	PORTD
	bsf		lcd_e
	bsf		lcd_e
	nop
	nop
	nop
	nop
	bcf		lcd_e
	bcf		lcd_e
	call	del20ms
	movlw	b'00000000' ; Display ON/OFF control: display ON, cursor ON, blink OFF, 
	movwf	PORTD
	bsf		lcd_e
	bsf		lcd_e
	nop
	nop
	nop
	nop
	bcf		lcd_e
	bcf		lcd_e
	call	del20ms
	movlw	b'00001110' 
	movwf	PORTD
	bsf		lcd_e
	bsf		lcd_e
	nop
	nop
	nop
	nop
	bcf		lcd_e
	bcf		lcd_e
	call	del20ms
;**** MAIN LOOP  ***************************************************
villog
	bsf		led
	call	del1s
	bcf		led
	call	del1s
	goto 	villog
;*				S U B R U T I N S 			*
inic
	clrf	PORTD
	clrf	PORTE
	movlw	B'11101111' 
				;7:1 PGD
				;6:1 PGC
				;5:1 PGM
				;4:0 led
				;3:1 
				;2:1 
				;1:1 
				;0:1 
	movwf	TRISB
	movlw	B'11110000' 
				;7:1 
				;6:1
				;5:1 
				;4:1 
				;3:1 lcd db7
				;2:1 lcd db6
				;1:1 lcd db5
				;0:0 lcd db4
	movwf	TRISD	
	movlw	B'11111000' 
				;7:1 
				;6:1
				;5:1 
				;4:1 
				;3:1 
				;2:1 E
				;1:1 R/W_
				;0:0 RS
	movwf	TRISE
;******** A/D ********************
	clrf	ADCON0
	movlw	B'00001111'	; ALL digital
	movwf	ADCON1
	return
;*	D E L A Y 			*
del1us	nop
	nop
	nop
	nop
	nop
	nop
	return
;*	delay 100us (OK)		*
;*	4MHz;20MHz			*
;   	*** ALAP ***		
del100us	
	movlw	31	;osc:4MHz 1us/inst
;	movlw	.165	;osc:20Mhz 0,2us/inst
	nop
	nop
	nop
	movwf	del1
del_2	decfsz	del1,F
	bra	del_2
	return
;*	delay 20ms			*
;->del100us
del20ms	movlw	200
	movwf	del2
del_20ms	dcfsnz	del2,F
	return
	call	del100us	;ALAP	
	bra	del_20ms
;*	delay 1ms	(??)		*
del1ms	movlw	10
	movwf	del2
del_1ms	dcfsnz	del2,F
	return
	call	del100us	;alap
	bra	del_1ms
;	delay 0,1 sec		*
del01s	load	del3,5
d01s	dcfsnz	del3,F
	return
	call	del20ms
	bra	d01s
;*	delay 1sec			*
del1s	load	del3,50
del_1s	dcfsnz	del3,F
	return
	call	del20ms
	bra	del_1s
	end
