<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.0125" unitdist="inch" unit="inch" style="lines" multiple="1" display="yes" altdistance="0.000004" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="no"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="250" name="Descript" color="7" fill="1" visible="yes" active="yes"/>
<layer number="251" name="SMDround" color="7" fill="1" visible="yes" active="yes"/>
</layers>
<board>
<plain>
<wire x1="-0.0659" y1="-0.1593" x2="43.9349" y2="-0.1593" width="0" layer="20"/>
<wire x1="43.9349" y1="-0.1593" x2="43.8" y2="60.795" width="0" layer="20"/>
<wire x1="43.8" y1="60.795" x2="-0.0659" y2="60.795" width="0" layer="20"/>
<wire x1="-0.0659" y1="60.795" x2="-0.0659" y2="-0.1593" width="0" layer="20"/>
</plain>
<libraries>
<library name="transistor-fet">
<packages>
<package name="TO92-">
<description>&lt;b&gt;&lt;/b&gt;</description>
<wire x1="-2.0945" y1="-1.651" x2="2.0945" y2="-1.651" width="0.127" layer="21"/>
<wire x1="-2.413" y1="1.1359" x2="2.413" y2="1.1359" width="0.127" layer="21" curve="-129.583345" cap="flat"/>
<wire x1="1.1359" y1="-0.127" x2="-1.1359" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.413" y1="1.1359" x2="-2.413" y2="-1.1359" width="0.127" layer="51" curve="50.416655" cap="flat"/>
<wire x1="-1.4041" y1="-0.127" x2="-2.664" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.413" y1="-1.1359" x2="-2.0945" y2="-1.651" width="0.127" layer="21" curve="13.038528" cap="flat"/>
<wire x1="-1.1359" y1="-0.127" x2="-1.4041" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.413" y1="-1.1359" x2="2.413" y2="1.1359" width="0.127" layer="51" curve="50.416655" cap="flat"/>
<wire x1="2.664" y1="-0.127" x2="1.4041" y2="-0.127" width="0.127" layer="51"/>
<wire x1="1.4041" y1="-0.127" x2="1.1359" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.0945" y1="-1.651" x2="2.4242" y2="-1.1118" width="0.127" layer="21" curve="13.609443" cap="flat"/>
<pad name="3" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="1" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="pot">
<packages>
<package name="PT-SPIN">
<description>&lt;b&gt;POTENTIOMETER&lt;/b&gt;</description>
<wire x1="-8.89" y1="-2.54" x2="8.89" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-2.54" x2="8.89" y2="2.54" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.54" x2="-8.89" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.54" x2="-8.89" y2="-2.54" width="0.1524" layer="21"/>
<pad name="S" x="-1.27" y="1.27" drill="0.8128" shape="long"/>
<pad name="E" x="6.35" y="-1.27" drill="0.8128" shape="long"/>
<pad name="A" x="-6.35" y="-1.27" drill="0.8128" shape="long"/>
<text x="-3.175" y="3.175" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-1.778" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-9.525" y1="-1.27" x2="-8.89" y2="1.27" layer="21"/>
<rectangle x1="-10.16" y1="0.381" x2="-9.525" y2="1.27" layer="21"/>
<rectangle x1="-10.16" y1="-1.27" x2="-9.525" y2="-0.381" layer="21"/>
</package>
</packages>
</library>
<library name="transistor-npn">
<packages>
<package name="TO92-EBC">
<description>&lt;b&gt;TO-92&lt;/b&gt;&lt;p&gt;
 grid 5.08 mm</description>
<wire x1="-2.095" y1="-2.921" x2="2.095" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-2.413" y1="-0.1341" x2="2.413" y2="-0.1341" width="0.127" layer="21" curve="-129.583"/>
<wire x1="1.136" y1="-1.397" x2="-1.136" y2="-1.397" width="0.127" layer="51"/>
<wire x1="-2.413" y1="-0.1341" x2="-2.664" y2="-1.397" width="0.127" layer="51" curve="27.9376"/>
<wire x1="-2.664" y1="-1.397" x2="-2.413" y2="-2.4059" width="0.127" layer="51" curve="22.4788"/>
<wire x1="-1.404" y1="-1.397" x2="-2.664" y2="-1.397" width="0.127" layer="51"/>
<wire x1="-2.4135" y1="-2.4059" x2="-2.095" y2="-2.921" width="0.127" layer="21" curve="13.0385"/>
<wire x1="-1.136" y1="-1.397" x2="-1.404" y2="-1.397" width="0.127" layer="21"/>
<wire x1="2.413" y1="-2.4059" x2="2.664" y2="-1.397" width="0.127" layer="51" curve="22.4788"/>
<wire x1="2.664" y1="-1.397" x2="2.413" y2="-0.1341" width="0.127" layer="51" curve="27.9376"/>
<wire x1="2.664" y1="-1.397" x2="1.404" y2="-1.397" width="0.127" layer="51"/>
<wire x1="1.404" y1="-1.397" x2="1.136" y2="-1.397" width="0.127" layer="21"/>
<wire x1="2.095" y1="-2.921" x2="2.4247" y2="-2.3818" width="0.127" layer="21" curve="13.6094"/>
<pad name="C" x="-2.54" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="2.54" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="0" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-4.572" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="transistor-pnp">
<packages>
<wire x1="-2.413" y1="-0.1341" x2="-2.413" y2="-2.4059" width="0.127" layer="51" curve="50.4167"/>
<wire x1="2.413" y1="-2.4059" x2="2.413" y2="-0.1341" width="0.127" layer="51" curve="50.4167"/>
</package>
</packages>
</library>
<library name="rcl">
<packages>
<package name="0207/10">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
<package name="E5-8,5">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 5.08 mm, diameter 8.5 mm</description>
<wire x1="-1.143" y1="0" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.143" x2="-0.254" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.143" x2="-0.254" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.143" x2="-0.889" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.143" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="2.032" x2="-3.302" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-2.921" y2="1.651" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="0" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="4.445" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="1.016" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="4.1402" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.5146" y="-3.0226" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.889" y2="1.143" layer="21"/>
</package>
<package name="C050-035X075">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 5 mm, outline 3.5 x 7.5 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.524" x2="-3.683" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.778" x2="3.429" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.524" x2="3.683" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="-3.429" y2="1.778" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="3.683" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.778" x2="3.683" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.524" x2="-3.429" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.524" x2="-3.429" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.556" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/12">
type 0207, grid 12 mm</description>
<wire x1="6.35" y1="0" x2="5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="4.445" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-4.445" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.175" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.445" y1="-0.3048" x2="5.3086" y2="0.3048" layer="21"/>
<rectangle x1="-5.3086" y1="-0.3048" x2="-4.445" y2="0.3048" layer="21"/>
</package>
</packages>
</library>
<library name="con-wago-508">
<packages>
<package name="W237-132">
<description>&lt;b&gt;WAGO SREW CLAMP&lt;/b&gt;</description>
<wire x1="-3.5306" y1="-1.651" x2="-1.524" y2="0.3556" width="0.254" layer="51"/>
<wire x1="1.6256" y1="-1.6764" x2="3.5306" y2="0.3556" width="0.254" layer="51"/>
<wire x1="-5.08" y1="4.191" x2="5.08" y2="4.191" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-4.826" x2="5.08" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-4.826" x2="-5.08" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.191" x2="-5.08" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.413" x2="-3.429" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.413" x2="-1.651" y2="-2.413" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-2.413" x2="1.651" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-2.413" x2="5.08" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.413" x2="-5.08" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.413" x2="5.08" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.191" x2="-5.08" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.445" x2="5.08" y2="4.445" width="0.1524" layer="21"/>
<wire x1="5.08" y1="4.191" x2="5.08" y2="4.445" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-2.413" x2="3.429" y2="-2.413" width="0.1524" layer="51"/>
<circle x="-2.54" y="-0.635" radius="1.4986" width="0.1524" layer="51"/>
<circle x="-2.54" y="2.8448" radius="0.508" width="0.1524" layer="21"/>
<circle x="2.54" y="-0.635" radius="1.4986" width="0.1524" layer="51"/>
<circle x="2.54" y="2.8448" radius="0.508" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="-0.635" drill="1.1938" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="-0.635" drill="1.1938" shape="long" rot="R90"/>
<text x="-4.445" y="1.27" size="1.27" layer="51" ratio="10">1</text>
<text x="0.6858" y="1.2192" size="1.27" layer="51" ratio="10">2</text>
<text x="-3.81" y="-6.985" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.81" y="-4.318" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
</packages>
</library>
<library name="transistor-power">
<packages>
<package name="TOP3AV">
<description>&lt;b&gt;Molded Package&lt;/b&gt;&lt;p&gt;
grid 5.45 mm</description>
<wire x1="6.985" y1="-5.08" x2="7.366" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="7.366" y1="-4.699" x2="7.493" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-5.08" x2="-7.366" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="-4.699" x2="-7.493" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-5.08" x2="6.35" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-5.08" x2="4.572" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="4.572" y1="-5.08" x2="0.889" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-5.08" x2="-0.889" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="-5.08" x2="-4.572" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-5.08" x2="-6.35" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="-6.35" y1="-5.08" x2="-6.985" y2="-5.08" width="0.1524" layer="21"/>
<pad name="B" x="-5.461" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<pad name="C" x="0" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<pad name="E" x="5.461" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<text x="-7.62" y="-6.858" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-6.858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-7.874" y1="-1.143" x2="7.874" y2="0" layer="21"/>
<rectangle x1="-7.874" y1="-1.524" x2="-6.858" y2="-1.143" layer="21"/>
<rectangle x1="-4.064" y1="-1.524" x2="-1.397" y2="-1.143" layer="21"/>
<rectangle x1="1.397" y1="-1.524" x2="4.064" y2="-1.143" layer="21"/>
<rectangle x1="6.858" y1="-1.524" x2="7.874" y2="-1.143" layer="21"/>
<rectangle x1="-6.858" y1="-1.524" x2="-4.064" y2="-1.143" layer="51"/>
<rectangle x1="-1.397" y1="-1.524" x2="1.397" y2="-1.143" layer="51"/>
<rectangle x1="4.064" y1="-1.524" x2="6.858" y2="-1.143" layer="51"/>
</package>
</packages>
</library>
<library name="resistor-power">
<packages>
<package name="KP290">
<description>&lt;b&gt;POWER RESISTOR&lt;/b&gt;&lt;p&gt;
To202 10W grid 7.5</description>
<wire x1="-5.08" y1="2.54" x2="-5.08" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-5.08" y1="-2.54" x2="7.62" y2="-2.54" width="0.127" layer="21"/>
<wire x1="7.62" y1="-2.54" x2="7.62" y2="2.54" width="0.127" layer="21"/>
<wire x1="7.62" y1="2.54" x2="-5.08" y2="2.54" width="0.127" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="1.3208" diameter="3.1496" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="1.3208" diameter="3.1496" shape="octagon"/>
<text x="-2.54" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="testpad">
<description>&lt;b&gt;Test Pins/Pads&lt;/b&gt;&lt;p&gt;
Cream on SMD OFF.&lt;br&gt;
new: Attribute TP_SIGNAL_NAME&lt;br&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="P1-20Y">
<description>&lt;b&gt;TEST PAD&lt;/b&gt;</description>
<circle x="0" y="0" radius="1.016" width="0.1524" layer="51"/>
<pad name="TP" x="0" y="0" drill="2.0066" diameter="2.54" shape="long" rot="R90"/>
<text x="-1.27" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="0" size="0.0254" layer="27">&gt;VALUE</text>
<text x="-1.27" y="-4.445" size="1" layer="37">&gt;TP_SIGNAL_NAME</text>
<rectangle x1="-0.3302" y1="-0.3302" x2="0.3302" y2="0.3302" layer="51"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<description language="hu">&lt;b&gt;EAGLE Tervezési Szabályok&lt;/b&gt;&lt;p&gt;Az alapértelmezett Tervezési Szabályok úgy lettek megállapítva, hogy használhatók legyenek minél többféle alkalmazás megtervezéséhez.A Te általad tervezni kívánt termék más beállításokat követelhet meg,így megkérlek, hogy tedd meg a neked szükséges beállításokat, és mentsd elegy másik néven.</description>
<param name="layerSetup" value="16"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm 1.5mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
</autorouter>
<elements>
<element name="T2" library="transistor-fet" package="TO92-" value="2SJ74" x="18.8176" y="24.1049" rot="R180"/>
<element name="T1" library="transistor-fet" package="TO92-" value="2SK170" x="18.8246" y="37.138"/>
<element name="R1" library="pot" package="PT-SPIN" value="100" x="24.6739" y="30.5797" rot="R90"/>
<element name="T3" library="transistor-npn" package="TO92-EBC" value="BC546B" x="14.2875" y="41.4564" rot="R180"/>
<element name="R2" library="rcl" package="0207/10" value="1k" x="21.0765" y="53.4257" rot="R90"/>
<element name="R3" library="rcl" package="0207/10" value="1k" x="21.6393" y="7.0442" rot="R90"/>
<element name="R4" library="rcl" package="0207/10" value="2k" x="17.891" y="53.4374" rot="R90"/>
<element name="R5" library="rcl" package="0207/10" value="2k" x="8.4884" y="43.289" rot="R90"/>
<element name="R6" library="rcl" package="0207/10" value="2k" x="8.5262" y="17.1275" rot="R90"/>
<element name="R7" library="rcl" package="0207/10" value="2k" x="18.5304" y="7.0276" rot="R90"/>
<element name="R8" library="rcl" package="0207/12" value="1.2k" x="12.4065" y="33.7915"/>
<element name="R9" library="rcl" package="0207/10" value="47k" x="13.5904" y="27.9643"/>
<element name="X1" library="con-wago-508" package="W237-132" value="" x="4.5088" y="31.1128" rot="R270"/>
<element name="T5" library="transistor-pnp" package="TO92-EBC" value="BC556" x="29.845" y="44.7675" rot="R270"/>
<element name="T7" library="transistor-power" package="TOP3AV" value="" x="40.005" y="42.545" rot="R270"/>
<element name="T6" library="transistor-npn" package="TO92-EBC" value="BC546B" x="29.7891" y="17.6067" rot="R270"/>
<element name="T8" library="transistor-power" package="TOP3AV" value="" x="40.005" y="19.685" rot="R270"/>
<element name="R10" library="rcl" package="0207/12" value="10" x="14.7818" y="30.9105"/>
<element name="R11" library="rcl" package="0207/10" value="220" x="29.9365" y="33.4084" rot="R270"/>
<element name="C1" library="rcl" package="E5-8,5" value="100uF" x="10.2048" y="55.9015" rot="R270"/>
<element name="C2" library="rcl" package="E5-8,5" value="100uF" x="10.548" y="4.4728" rot="R270"/>
<element name="C3" library="rcl" package="C050-035X075" value="1uF" x="14.774" y="55.9955" rot="R270"/>
<element name="C4" library="rcl" package="C050-035X075" value="1uF" x="15.2657" y="4.5386" rot="R270"/>
<element name="T4" library="transistor-pnp" package="TO92-EBC" value="BC556B" x="14.3714" y="16.2789" rot="R180"/>
<element name="R12" library="resistor-power" package="KP290" value="1" x="30.6485" y="57.3913" rot="R180"/>
<element name="R13" library="resistor-power" package="KP290" value="1" x="27.9054" y="2.9532"/>
<element name="TP1" library="testpad" package="P1-20Y" value="TPPAD1-20Y" x="5.3975" y="58.42" rot="R90">
<attribute name="TP_SIGNAL_NAME" value="" x="5.3975" y="58.42" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="TP2" library="testpad" package="P1-20Y" value="TPPAD1-20Y" x="5.3975" y="1.905" rot="R90">
<attribute name="TP_SIGNAL_NAME" value="" x="5.3975" y="1.905" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="TP3" library="testpad" package="P1-20Y" value="TPPAD1-20Y" x="35.56" y="31.115" rot="R270">
<attribute name="TP_SIGNAL_NAME" value="" x="35.56" y="31.115" size="1.778" layer="27" rot="R270" display="off"/>
</element>
<element name="TP4" library="testpad" package="P1-20Y" value="TPPAD1-20Y" x="5.08" y="22.225" rot="R90">
<attribute name="TP_SIGNAL_NAME" value="" x="5.08" y="22.225" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="TP5" library="testpad" package="P1-20Y" value="TPPAD1-20Y" x="5.08" y="38.735" rot="R90">
<attribute name="TP_SIGNAL_NAME" value="" x="5.08" y="38.735" size="1.778" layer="27" rot="R90" display="off"/>
</element>
</elements>
<signals>
<signal name="N$1">
<contactref element="T1" pad="1"/>
<contactref element="R1" pad="E"/>
<wire x1="21.3646" y1="37.138" x2="21.3646" y2="36.9297" width="1.778" layer="16"/>
<wire x1="21.3646" y1="36.9297" x2="25.9439" y2="36.9297" width="1.778" layer="16"/>
</signal>
<signal name="N$3">
<contactref element="T1" pad="2"/>
<contactref element="R8" pad="2"/>
<contactref element="R9" pad="2"/>
<contactref element="T2" pad="2"/>
<wire x1="18.8091" y1="33.7915" x2="18.7565" y2="33.7915" width="1.778" layer="16"/>
<wire x1="18.8091" y1="37.138" x2="18.8091" y2="33.7915" width="1.778" layer="16"/>
<wire x1="18.8091" y1="37.138" x2="18.8246" y2="37.138" width="1.778" layer="16"/>
<wire x1="18.8091" y1="28.369" x2="18.8091" y2="33.7915" width="1.778" layer="16"/>
<wire x1="18.8091" y1="24.1049" x2="18.8091" y2="23.992" width="1.778" layer="16"/>
<wire x1="18.8176" y1="24.1049" x2="18.8091" y2="24.1049" width="1.778" layer="16"/>
<wire x1="18.8091" y1="28.369" x2="18.6704" y2="27.9643" width="1.778" layer="16"/>
<wire x1="18.8091" y1="24.1049" x2="18.8091" y2="28.369" width="1.778" layer="16"/>
</signal>
<signal name="N$4">
<contactref element="R2" pad="1"/>
<contactref element="T3" pad="C"/>
<contactref element="T5" pad="B"/>
<wire x1="16.8275" y1="42.7264" x2="20.955" y2="42.7264" width="1.778" layer="16"/>
<wire x1="20.955" y1="42.7264" x2="20.955" y2="44.7675" width="1.778" layer="16"/>
<wire x1="20.955" y1="44.7675" x2="20.955" y2="48.26" width="1.778" layer="16"/>
<wire x1="28.575" y1="44.7675" x2="20.955" y2="44.7675" width="1.778" layer="16"/>
<wire x1="20.955" y1="48.26" x2="21.0765" y2="48.3457" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$5">
<contactref element="T3" pad="E"/>
<contactref element="T1" pad="3"/>
<wire x1="11.707" y1="40.005" x2="11.7475" y2="42.7264" width="1.778" layer="16"/>
<wire x1="11.707" y1="37.1448" x2="11.707" y2="40.005" width="1.778" layer="16"/>
<wire x1="16.445" y1="37.1448" x2="16.445" y2="37.138" width="1.778" layer="16"/>
<wire x1="16.445" y1="37.138" x2="16.2846" y2="37.138" width="1.778" layer="16"/>
<wire x1="11.707" y1="37.1448" x2="16.445" y2="37.1448" width="1.778" layer="16"/>
<wire x1="16.445" y1="37.1448" x2="16.445" y2="37.2797" width="1.778" layer="16"/>
</signal>
<signal name="N$7">
<contactref element="R3" pad="2"/>
<contactref element="T4" pad="C"/>
<contactref element="T6" pad="B"/>
<wire x1="16.9114" y1="17.5489" x2="21.6393" y2="17.5489" width="1.778" layer="16"/>
<wire x1="21.6393" y1="17.5489" x2="21.6393" y2="17.5184" width="1.778" layer="16"/>
<wire x1="21.6393" y1="17.5184" x2="21.6393" y2="12.1242" width="1.778" layer="16"/>
<wire x1="21.6393" y1="17.5184" x2="21.6393" y2="17.5489" width="1.778" layer="16"/>
<wire x1="28.5191" y1="17.6067" x2="21.59" y2="17.6067" width="1.778" layer="16"/>
<wire x1="21.59" y1="17.6067" x2="21.2725" y2="17.6067" width="1.778" layer="16"/>
<wire x1="21.2725" y1="17.6067" x2="21.2725" y2="17.4625" width="1.778" layer="16"/>
<wire x1="21.6393" y1="17.5489" x2="21.59" y2="17.5489" width="1.778" layer="16"/>
<wire x1="21.59" y1="17.5489" x2="21.59" y2="17.6067" width="1.778" layer="16"/>
</signal>
<signal name="N$8">
<contactref element="R2" pad="2"/>
<contactref element="R4" pad="2"/>
<contactref element="C1" pad="+"/>
<contactref element="C3" pad="1"/>
<contactref element="R12" pad="2"/>
<wire x1="13.4771" y1="58.5174" x2="13.4771" y2="58.5057" width="2.54" layer="16"/>
<wire x1="17.891" y1="58.5174" x2="13.4771" y2="58.5174" width="2.54" layer="16"/>
<wire x1="13.4771" y1="58.5057" x2="20.2222" y2="58.5057" width="2.54" layer="16"/>
<wire x1="20.2222" y1="58.5057" x2="21.0765" y2="58.5057" width="2.54" layer="16"/>
<wire x1="9.089" y1="58.5355" x2="9.089" y2="58.5174" width="2.54" layer="16"/>
<wire x1="14.774" y1="58.5355" x2="9.089" y2="58.5355" width="2.54" layer="16"/>
<wire x1="9.089" y1="58.5174" x2="17.891" y2="58.5174" width="2.54" layer="16"/>
<wire x1="9.089" y1="58.5174" x2="9.089" y2="58.4555" width="2.54" layer="16"/>
<wire x1="13.4771" y1="58.3243" x2="13.4771" y2="58.42" width="1.778" layer="16"/>
<wire x1="13.4771" y1="58.5057" x2="13.4771" y2="58.42" width="1.778" layer="16"/>
<wire x1="13.4771" y1="58.42" x2="13.335" y2="58.42" width="1.778" layer="16"/>
<wire x1="20.2222" y1="58.5057" x2="20.2222" y2="58.42" width="1.778" layer="16"/>
<wire x1="20.2222" y1="58.1894" x2="20.2222" y2="58.42" width="1.778" layer="16"/>
<wire x1="20.2222" y1="58.42" x2="20.32" y2="58.42" width="1.778" layer="16"/>
<contactref element="TP1" pad="TP"/>
<wire x1="9.089" y1="58.5355" x2="5.08" y2="58.5355" width="2.54" layer="16"/>
<wire x1="5.08" y1="58.5355" x2="5.08" y2="58.42" width="2.54" layer="16"/>
<wire x1="10.2048" y1="58.4415" x2="3.81" y2="58.4415" width="2.54" layer="16"/>
<wire x1="3.81" y1="58.4415" x2="5.3975" y2="58.42" width="2.54" layer="16"/>
<wire x1="9.089" y1="58.5174" x2="8.89" y2="58.5174" width="2.54" layer="16"/>
<wire x1="8.89" y1="58.5174" x2="8.89" y2="58.42" width="2.54" layer="16"/>
<wire x1="8.89" y1="58.42" x2="8.2998" y2="58.42" width="2.54" layer="16"/>
<wire x1="8.2998" y1="58.42" x2="10.2048" y2="58.4415" width="2.54" layer="16"/>
<wire x1="25.5685" y1="57.3913" x2="25.5685" y2="58.42" width="2.54" layer="16"/>
<wire x1="25.5685" y1="58.42" x2="21.0765" y2="58.42" width="2.54" layer="16"/>
<wire x1="21.0765" y1="58.5057" x2="21.0765" y2="58.42" width="2.54" layer="16"/>
<wire x1="21.0765" y1="58.42" x2="20.955" y2="58.42" width="2.54" layer="16"/>
</signal>
<signal name="N$9">
<contactref element="R3" pad="1"/>
<contactref element="R7" pad="1"/>
<contactref element="C2" pad="-"/>
<contactref element="C4" pad="2"/>
<contactref element="R13" pad="1"/>
<wire x1="20.7618" y1="1.9642" x2="20.7618" y2="1.9357" width="2.54" layer="16"/>
<wire x1="20.7618" y1="1.9642" x2="21.6393" y2="1.9642" width="2.54" layer="16"/>
<wire x1="20.7618" y1="1.9642" x2="20.7618" y2="1.9987" width="2.54" layer="16"/>
<wire x1="14.0167" y1="1.9476" x2="14.0167" y2="1.9357" width="2.54" layer="16"/>
<wire x1="14.0167" y1="1.9476" x2="18.5304" y2="1.9476" width="2.54" layer="16"/>
<wire x1="14.0167" y1="1.9642" x2="20.7618" y2="1.9642" width="2.54" layer="16"/>
<wire x1="14.0167" y1="1.9642" x2="14.0167" y2="1.9476" width="2.54" layer="16"/>
<wire x1="9.5514" y1="1.9986" x2="9.5514" y2="1.9642" width="2.54" layer="16"/>
<wire x1="15.2657" y1="1.9986" x2="9.5514" y2="1.9986" width="2.54" layer="16"/>
<wire x1="9.5514" y1="1.9642" x2="14.0167" y2="1.9642" width="2.54" layer="16"/>
<wire x1="9.5514" y1="1.9642" x2="9.5514" y2="1.9125" width="2.54" layer="16"/>
<wire x1="5.7778" y1="1.9328" x2="4.5078" y2="1.9125" width="2.54" layer="16"/>
<wire x1="10.548" y1="1.9328" x2="5.7778" y2="1.9328" width="2.54" layer="16"/>
<wire x1="7.0478" y1="1.9986" x2="15.2657" y2="1.9986" width="2.54" layer="16"/>
<wire x1="5.7778" y1="1.9328" x2="7.0478" y2="1.9986" width="2.54" layer="16"/>
<wire x1="25.3654" y1="2.9532" x2="25.3654" y2="1.9642" width="1.778" layer="16"/>
<wire x1="25.3654" y1="1.9642" x2="21.6393" y2="1.9642" width="1.778" layer="16"/>
<contactref element="TP2" pad="TP"/>
<wire x1="5.3975" y1="1.905" x2="5.7778" y2="1.9328" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$10">
<contactref element="T3" pad="B"/>
<contactref element="R4" pad="1"/>
<contactref element="R5" pad="2"/>
<wire x1="8.4884" y1="48.369" x2="13.6525" y2="48.369" width="1.778" layer="16"/>
<wire x1="13.6525" y1="48.369" x2="14.2875" y2="48.26" width="1.778" layer="16"/>
<wire x1="17.891" y1="48.3574" x2="13.6525" y2="48.3574" width="1.778" layer="16"/>
<wire x1="13.6525" y1="48.3574" x2="14.2875" y2="48.26" width="1.778" layer="16"/>
<wire x1="14.2875" y1="42.7264" x2="14.2875" y2="48.26" width="1.778" layer="16"/>
</signal>
<signal name="N$11">
<contactref element="R6" pad="1"/>
<contactref element="R7" pad="2"/>
<contactref element="T4" pad="B"/>
<wire x1="8.5262" y1="12.0475" x2="14.3714" y2="12.0475" width="1.778" layer="16"/>
<wire x1="14.3714" y1="12.0475" x2="14.3714" y2="17.5489" width="1.778" layer="16"/>
<wire x1="18.5304" y1="12.1076" x2="14.3714" y2="12.1076" width="1.778" layer="16"/>
<wire x1="14.3714" y1="12.1076" x2="14.3714" y2="12.0475" width="1.778" layer="16"/>
</signal>
<signal name="GND">
<contactref element="R9" pad="1"/>
<contactref element="X1" pad="2"/>
<contactref element="R10" pad="1"/>
<contactref element="R5" pad="1"/>
<contactref element="R6" pad="2"/>
<contactref element="C1" pad="-"/>
<contactref element="C3" pad="2"/>
<contactref element="C2" pad="+"/>
<contactref element="C4" pad="1"/>
<wire x1="8.4858" y1="38.209" x2="8.4858" y2="38.2241" width="1.778" layer="16"/>
<wire x1="8.4858" y1="38.2241" x2="8.3624" y2="38.2241" width="1.778" layer="16"/>
<wire x1="8.3624" y1="38.2241" x2="4.8435" y2="38.2241" width="1.778" layer="16"/>
<wire x1="8.4284" y1="22.1708" x2="5.2482" y2="22.1708" width="1.778" layer="16"/>
<wire x1="8.4284" y1="22.1708" x2="8.4858" y2="22.1708" width="1.778" layer="16"/>
<wire x1="8.4858" y1="22.1708" x2="8.4858" y2="22.0359" width="1.778" layer="16"/>
<wire x1="8.4318" y1="30.9105" x2="8.4858" y2="30.9105" width="1.778" layer="16"/>
<wire x1="8.4858" y1="38.209" x2="8.4884" y2="38.209" width="1.778" layer="16"/>
<wire x1="8.4858" y1="30.9105" x2="8.4858" y2="38.209" width="1.778" layer="16"/>
<wire x1="8.5104" y1="27.9643" x2="8.6207" y2="27.9643" width="1.778" layer="16"/>
<wire x1="8.6207" y1="30.9105" x2="8.4318" y2="30.9105" width="1.778" layer="16"/>
<wire x1="8.6207" y1="27.9643" x2="8.6207" y2="30.9105" width="1.778" layer="16"/>
<wire x1="8.4858" y1="22.1708" x2="8.4858" y2="22.2075" width="1.778" layer="16"/>
<wire x1="8.4858" y1="22.2075" x2="8.5262" y2="22.2075" width="1.778" layer="16"/>
<wire x1="8.4858" y1="27.9643" x2="8.5104" y2="27.9643" width="1.778" layer="16"/>
<wire x1="8.4858" y1="22.2075" x2="8.4858" y2="27.9643" width="1.778" layer="16"/>
<wire x1="8.4858" y1="27.9643" x2="8.4858" y2="28.5728" width="1.778" layer="16"/>
<wire x1="4.3629" y1="53.3615" x2="4.3629" y2="53.3032" width="2.54" layer="16"/>
<wire x1="4.3629" y1="53.3615" x2="10.2048" y2="53.3615" width="2.54" layer="16"/>
<wire x1="4.3629" y1="53.4555" x2="4.3629" y2="53.3615" width="2.54" layer="16"/>
<wire x1="3.794" y1="53.4555" x2="4.3629" y2="53.4555" width="2.54" layer="16"/>
<wire x1="4.3629" y1="53.4555" x2="14.774" y2="53.4555" width="2.54" layer="16"/>
<wire x1="3.794" y1="38.2427" x2="3.794" y2="53.4555" width="2.54" layer="16"/>
<wire x1="8.3624" y1="38.2241" x2="8.3624" y2="38.2427" width="2.54" layer="16"/>
<wire x1="8.3624" y1="38.2427" x2="3.794" y2="38.2427" width="2.54" layer="16"/>
<wire x1="10.548" y1="7.0128" x2="3.9388" y2="7.0128" width="2.54" layer="16"/>
<wire x1="3.9388" y1="7.0128" x2="3.6213" y2="7.0786" width="2.54" layer="16"/>
<wire x1="3.6213" y1="7.0786" x2="15.2657" y2="7.0786" width="2.54" layer="16"/>
<wire x1="3.6213" y1="7.0786" x2="3.6213" y2="22.1913" width="2.54" layer="16"/>
<wire x1="8.4284" y1="22.1913" x2="8.4284" y2="22.1708" width="2.54" layer="16"/>
<wire x1="3.6213" y1="22.1913" x2="3.81" y2="22.1913" width="2.54" layer="16"/>
<wire x1="3.81" y1="22.1913" x2="8.4284" y2="22.1913" width="2.54" layer="16"/>
<wire x1="8.4858" y1="28.5728" x2="3.8738" y2="28.5728" width="1.778" layer="16"/>
<contactref element="TP5" pad="TP"/>
<contactref element="TP4" pad="TP"/>
<wire x1="5.08" y1="38.735" x2="8.4884" y2="38.735" width="1.778" layer="16"/>
<wire x1="8.4884" y1="38.735" x2="8.4884" y2="38.209" width="1.778" layer="16"/>
<wire x1="5.08" y1="22.225" x2="3.81" y2="22.1913" width="1.778" layer="16"/>
</signal>
<signal name="N$17">
<contactref element="X1" pad="1"/>
<contactref element="R8" pad="1"/>
<wire x1="6.0565" y1="33.7915" x2="6.0565" y2="33.6528" width="1.778" layer="16"/>
<wire x1="6.0565" y1="33.6528" x2="3.8738" y2="33.6528" width="1.778" layer="16"/>
</signal>
<signal name="N$19">
<contactref element="T5" pad="C"/>
<contactref element="T7" pad="B"/>
<wire x1="28.575" y1="47.3075" x2="28.575" y2="47.9425" width="1.778" layer="16"/>
<wire x1="28.575" y1="47.9425" x2="36.83" y2="47.9425" width="1.778" layer="16"/>
<wire x1="36.83" y1="48.006" x2="36.83" y2="47.9425" width="1.778" layer="16"/>
</signal>
<signal name="N$20">
<contactref element="T5" pad="E"/>
<contactref element="T7" pad="C"/>
<contactref element="R12" pad="1"/>
<wire x1="33.1885" y1="57.3913" x2="41.91" y2="57.3913" width="2.54" layer="16"/>
<wire x1="41.91" y1="57.3913" x2="41.91" y2="42.545" width="2.54" layer="16"/>
<wire x1="41.91" y1="42.545" x2="36.83" y2="42.545" width="2.54" layer="16"/>
<wire x1="36.83" y1="42.545" x2="36.83" y2="42.2275" width="1.778" layer="16"/>
<wire x1="36.83" y1="42.2275" x2="28.575" y2="42.2275" width="1.778" layer="16"/>
</signal>
<signal name="N$13">
<contactref element="T6" pad="E"/>
<contactref element="T8" pad="C"/>
<contactref element="R13" pad="2"/>
<wire x1="32.9854" y1="2.9532" x2="32.7025" y2="2.9532" width="2.54" layer="16"/>
<wire x1="32.7025" y1="2.9532" x2="32.7025" y2="15.24" width="2.54" layer="16"/>
<wire x1="32.7025" y1="15.24" x2="32.7025" y2="19.685" width="2.54" layer="16"/>
<wire x1="32.7025" y1="19.685" x2="36.83" y2="19.685" width="2.54" layer="16"/>
<wire x1="28.5191" y1="15.0667" x2="32.7025" y2="15.0667" width="1.778" layer="16"/>
<wire x1="32.7025" y1="15.0667" x2="32.7025" y2="15.24" width="1.778" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="T7" pad="E"/>
<contactref element="T8" pad="E"/>
<contactref element="R11" pad="1"/>
<wire x1="36.83" y1="37.084" x2="29.9365" y2="37.084" width="1.9304" layer="16"/>
<wire x1="29.9365" y1="37.084" x2="29.9365" y2="38.4884" width="1.9304" layer="16"/>
<contactref element="TP3" pad="TP"/>
<wire x1="36.83" y1="14.224" x2="41.91" y2="14.224" width="2.54" layer="16"/>
<wire x1="41.91" y1="14.224" x2="41.91" y2="31.115" width="2.54" layer="16"/>
<wire x1="41.91" y1="31.115" x2="35.56" y2="31.115" width="2.54" layer="16"/>
<wire x1="36.83" y1="37.084" x2="41.91" y2="37.084" width="2.54" layer="16"/>
<wire x1="41.91" y1="37.084" x2="41.91" y2="31.115" width="2.54" layer="16"/>
</signal>
<signal name="N$15">
<contactref element="R1" pad="S"/>
<contactref element="R11" pad="2"/>
<contactref element="R10" pad="2"/>
<wire x1="21.1318" y1="30.9105" x2="23.495" y2="30.9105" width="1.778" layer="16"/>
<wire x1="23.495" y1="30.9105" x2="23.495" y2="29.21" width="1.778" layer="16"/>
<wire x1="29.9365" y1="28.3284" x2="29.9365" y2="29.3097" width="1.778" layer="16"/>
<wire x1="29.9365" y1="29.3097" x2="23.4039" y2="29.3097" width="1.778" layer="16"/>
<wire x1="23.495" y1="29.21" x2="23.495" y2="29.3097" width="1.778" layer="16"/>
<wire x1="23.495" y1="29.3097" x2="23.4039" y2="29.3097" width="1.778" layer="16"/>
</signal>
<signal name="N$2">
<contactref element="T2" pad="3"/>
<contactref element="R1" pad="A"/>
<wire x1="21.3576" y1="24.1049" x2="21.3576" y2="24.2297" width="1.778" layer="16"/>
<wire x1="21.3576" y1="24.2297" x2="25.9439" y2="24.2297" width="1.778" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="T2" pad="1"/>
<contactref element="T4" pad="E"/>
<wire x1="16.2776" y1="24.1049" x2="11.7475" y2="24.1049" width="1.778" layer="16"/>
<wire x1="11.7475" y1="24.1049" x2="11.7475" y2="17.4625" width="1.778" layer="16"/>
<wire x1="11.7475" y1="17.4625" x2="11.8314" y2="17.5489" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$12">
<contactref element="T8" pad="B"/>
<contactref element="T6" pad="C"/>
<wire x1="28.5191" y1="20.1467" x2="28.575" y2="20.1467" width="1.778" layer="16"/>
<wire x1="28.575" y1="20.1467" x2="28.575" y2="25.0825" width="1.778" layer="16"/>
<wire x1="28.575" y1="25.0825" x2="36.83" y2="25.0825" width="1.778" layer="16"/>
<wire x1="36.83" y1="25.0825" x2="36.83" y2="25.146" width="1.778" layer="16"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
