24-bit RGB Persistence of Vision Toy
by Matt Pandina
INTRODUCTION
Persistence of vision toys have been done before, but this one will
allow you to display actual photographs.
I call it 24-bit RGB color, but internally it is actually using 36-bit
color. Twelve bits are used to represent each red, green, and blue
color channel, however I limit the colors I display to the ones that
can be represented in 24-bits. The extra bits are used to obtain extra
precision when gamma correcting each 8-bit red, green, and blue color
channel.
The project is split into two parts: software, and firmware.
The software, called png2tlc, runs on Linux and functions to convert a
standard PNG file into the native format that can be sent directly to
a TLC5940. When given a PNG file as input, it produces (on stdout) a C
source code file that, when linked with the rest of the firmware,
stores the image data from the PNG file into an array in the flash
memory of an ATmega328P. The Makefile provided with the firmware
expects this data to be in a file called data.c, so the output of
png2tlc should be redirected to ../firmware/data.c
SOFTWARE BUILD INSTRUCTIONS:
png2tlc depends on libpng, so before building, make sure you have the
libpng12-dev package installed. To install it on Debian or Ubuntu, use
the following command:
    sudo apt-get install libpng12-dev
If you are using another variant of Linux, (or Windows, or OS X), you
will want to have libpng and its development headers on the standard
include path. You will also want to use the gcc compiler, since the
code is written using C99 with GNU extensions.
Once libpng12-dev is installed, change to the software directory and
build png2tlc using the following commands:
    cd software
    make
This should produce a file called png2tlc. You can run it with the -h
argument to see all the supported command line arguments.
CHANGING THE IMAGE
Using your favorite image editor, create a PNG file (with or without
an alpha channel) and save it somewhere. For this example, I'm going
to assume your file is called nyan16.png, and that it has been saved
to the software/ directory.
Next type:
    ./png2tlc -n 1 nyan16.png > ../firmware/data.c
replacing '-n 1' with the number of TLC5940 chips connected in series,
to redirect the output to a file called data.c in the firmware
directory.
Now, the next time you build the firmware, it will include the new image.
CONNECTING THE HARDWARE
Depending on how many TLC5940 chips are linked in series, you may have
to change the TLC5940_N variable in firmware/Makefile.
If TLC5940_USART_MSPIM = 0 in firmware/Makefile, connect the hardware
according to ../../schematics/multiplexing.sch, or
../../schematics/multiplexing-multi.sch depending on how many TLC5940
chips are linked in series.
If TLC5940_USART_MSPIM = 1 in firmware/Makefile, connect the hardware
according to ../../schematics/usart_mspim-multiplexing.sch, or
../../schematics/usart_mspim-multiplexing-multi.sch depending on how
many TLC5940 chips are linked in series.
FIRMWARE BUILD INSTRUCTIONS
Once you have png2tlc'd the data from a PNG file into the
../firmware/data.c file, change to the firmware directory using the
following command:
    cd ../firmware
Open the Makefile, and verify that DEVICE, CLOCK, PROGRAMMER, and
FUSES are set correctly in the Makefile based on your hardware
setup. The provided Makefile is configured for an ATmega328P running
at 20 MHz, using an AVR ISP mkII programmer, with FUSES set to remove
the clock divider, to use the external crystal, and to enable clock
output.
Again, be sure to set TLC5940_N to the number of TLC5940 chips you
have linked in series.
The COMPILE parameter is set to use the non-standard -mint8 option, so
beware if you add code incompatible with -mint8, such as some
functions that are part of avr-libc, and any code that doesn't use the
types from <stdint.h>. Also, be sure to upcast the first parameter of
any math operations that might overflow an 8-bit integer.
To build the firmware, type:
    make
With your programmer connected, type:
    make fuse
to program the fuse bits, and type:
    make flash
to load the program onto the AVR.
Sit back and enjoy painting full color images in the air with LEDs!
