[Main] FileType=CIR Version=10.01 Program=Micro-Cap Component Version=10.00 Shape Version=10.01 Screen=1366,768 MCAPVersion=10.0.7.0 Key ID=Demo NLCnt=15 TXCnt=2 [shapedef] Name=Ground Line=0,0,12,0 Line=12,-8,12,8 Line=18,-4,18,4 Line=24,0,24,0 [shapedef] Name=Plus.root Line=-2,0,2,0 Line=0,-2,0,2 [shapedef] Name=Resistor PolyOpen=12 PolyLine=0,0 PolyLine=0,0 PolyLine=12,0 PolyLine=14,-4 PolyLine=18,4 PolyLine=22,-4 PolyLine=26,4 PolyLine=30,-4 PolyLine=34,4 PolyLine=36,0 PolyLine=48,0 PolyLine=48,0 Current=32,8,16,8 [shapedef] Name=Sine_Source Root="Vsource.root",0,0,0 Line=24,-6,26,-4 Line=26,-4,26,-2 Line=26,-2,22,2 Line=22,2,22,4 Line=22,4,24,6 [shapedef] Name=Trans.root Arc=1,4,15,18 , 8,18,15,11 Arc=1,5,15,17 , 15,11,8,5 Line=48,0,40,0 Line=24,5,24,43 Line=40,0,40,5 Line=48,48,40,48 Line=40,48,40,42 Line=22,43,22,5 Line=26,43,26,5 Line=8,0,0,0 Line=8,0,8,5 Line=0,48,8,48 Line=8,48,8,42 Arc=5,12,11,18 , 5,15,8,18 Arc=5,13,11,17 , 8,13,5,15 Arc=1,13,15,25 , 15,19,8,13 Arc=1,12,15,26 , 8,26,15,19 Arc=5,20,11,26 , 5,23,8,26 Arc=5,21,11,25 , 8,21,5,23 Arc=1,21,15,33 , 15,27,8,21 Arc=1,20,15,34 , 8,34,15,27 Arc=5,28,11,34 , 5,31,8,34 Arc=5,29,11,33 , 8,29,5,31 Arc=1,29,15,41 , 15,35,8,29 Arc=1,28,15,42 , 8,42,15,35 Arc=33,30,47,42 , 33,36,40,42 Arc=33,29,47,43 , 40,29,33,36 Arc=37,29,43,35 , 43,32,40,29 Arc=37,30,43,34 , 40,34,43,32 Arc=33,22,47,34 , 33,28,40,34 Arc=33,21,47,35 , 40,21,33,28 Arc=37,21,43,27 , 43,24,40,21 Arc=37,22,43,26 , 40,26,43,24 Arc=33,14,47,26 , 33,20,40,26 Arc=33,13,47,27 , 40,13,33,20 Arc=37,13,43,19 , 43,16,40,13 Arc=37,14,43,18 , 40,18,43,16 Arc=33,6,47,18 , 33,12,40,18 Arc=33,5,47,19 , 40,5,33,12 [shapedef] Name=Transformer Root="Trans.root",0,0,0 Current=0,16,0,32 Current=48,16,48,32 Ellipse=2,4,4,6 Ellipse=44,4,46,6 [shapedef] Name=Vsource.root Line=0,0,12,0 Line=36,0,48,0 Ellipse=12,-12,36,12 FColor=None Line=7,5,7,9 Root="Plus.root",41,7,0 Current=32,16,16,16 [compdef] Name=Sine Source Definition=Sine source Shape=Sine_Source Mask=4865 memo=Sine Source Label Offset=18,12,15,12 PinCnt=2 Pin="Plus",6,0,-6,-6 Pin="Minus",0,0,-19,-6 [compdef] Name=Ground Definition=Ground Shape=Ground Mask=1793 memo=Ground Label Offset=0,0,0,0 PinCnt=1 Pin="PinA",0,0,-3,-7 [compdef] Name=Resistor Definition=Resistor Shape=Resistor Mask=6913 memo=Resistor Label Offset=18,6,8,11 PinCnt=2 Pin="Plus",6,0,-10,-4 Pin="Minus",0,0,-14,-4 [compdef] Name=Transformer Definition=Transformer Shape=Transformer Mask=4096 memo=Transformer Label Offset=18,45,-1,12 PinCnt=4 Pin="Plus Output",6,0,-19,-4 Pin="Minus Output",6,6,-20,18 Pin="Plus Input",0,0,-31,-4 Pin="Minus Input",0,6,-41,18 [Circuit] Window Placement=2,3, -1,-1, -8,-30, 100,81,911,450 Default Object=Color=#008000,Pattern=Dash Default Object Font=Height=-15,FStyle=0,Color=#000080,Name=Arial Default Object Apply Border To Text=No Default Object Apply Fill To Text=No WinBackGround Color=#FFFFFF Select Color=#FF0000 Select Box Color=#000080 Grid Text Color=Height=-12,FStyle=0,Color=#0000FF,Name=Verdana Component Color=#0000FF Attribute Text=Height=-12,FStyle=0,Color=#008000,Name=Verdana Wire Color=#008000 Bus Color=#008000 Pin Connection=Height=-10,FStyle=0,Color=#FF0000,Name=Arial Node Number=Height=-11,FStyle=0,Color=#FF00FF,Name=Arial Node Voltage Color=Height=-11,FStyle=0,Color=#000000,Name=Arial Dynamic AC Voltage Color=#E4E4E4 Text Banner Text=Height=-15,FStyle=0,Color=#800000,Name=Arial Title Block Background=#C0C0C0 Current=Height=-11,FStyle=0,Color=#0000FF,Name=Arial Power/Condition=Height=-11,FStyle=0,Color=#FF0000,Name=Arial Digital Path Color=#FF0000 Title Block=Height=-15,FStyle=0,Color=#000000,Name=Arial Title Block Border=#000000 Disabled Color=#C0C0C0 KeyWord Color=#0000FF Error Color=#FF0000 Search Color=#FFFF00 Grid Color=#000000 Digital 0 Color=#000000 Digital R Color=#FFFF00 Digital F Color=#FFFF00 Digital 1 Color=#FF0000 Digital X Color=#C0C0C0 Digital Z Color=#808080 NodeVoltageFormat=3 PathDelayFormat=3 WarningFormat=3 GridTextFormulaFormat=3 Window Placement in Transient Analysis=2,3, -1,-1, -8,-30, 125,125,1019,458 Window Placement in AC Analysis=2,3, -1,-1, -8,-30, 200,123,1271,526 SpiceType=AMBIGUOUS Block Select Color=#51F998 TitleBlock Field_1=$name TitleBlock Field_2=$user $company TitleBlock Field_3 TitleBlock Field_4=$date TitleBlock Field_5=Page $page of $maxpage TitleBlock One Title=False Title_Block_Border=False Title_Block=False Show Nodes=False Show Voltages=True Show Current=False Show Power=False Show Condition=False Show Pin Connections=False Show Cross=False Show Attribute Text=True Show Grid Text=True [Comp] Name=Sine Source Grid=24,34 Rot=3 COff=8,170,221,40,18 [Attr] ON=-22,-51,PART V=V1 Style=8192 [Attr] ON=-72,-40,MODEL V=3PHASEA [Comp] Name=Ground Grid=24,38 Rot=1 [Wire] Grids=24,34,24,38 [Comp] Name=Resistor Grid=38,24 Rot=6 COff=7,271,154,-2,33 [Attr] ON=-32,-22,PART V=R3 Style=8192 [Attr] ON=-33,-38,RESISTANCE V=300 Style=8192 [Wire] Grids=24,24,32,24 [Wire] Grids=24,24,24,28 [Comp] Name=Transformer Grid=54,24 [Attr] ON=18,45,PART V=K1 Style=8192 [Attr] ON=18,59,VALUE V=1,1,1 [Comp] Name=Ground Grid=54,30 Rot=1 [Comp] Name=Ground Grid=60,30 Rot=1 [Comp] Name=Resistor Grid=81,24 Rot=6 COff=40,616,170,-5,33 [Attr] ON=-32,-22,PART V=R4 Style=8192 [Attr] ON=-33,-38,RESISTANCE V=300 Style=8192 [Comp] Name=Resistor Grid=100,24 Rot=6 [Attr] ON=-31,-22,PART V=R5 Style=8192 [Attr] ON=-36,-38,RESISTANCE V=314 Style=8192 [Wire] Grids=60,24,75,24 [Wire] Grids=81,24,94,24 [Comp] Name=Ground Grid=100,24 Rot=1 [Wire] Grids=38,24,54,24 [Grid Text] Text="3 fazisu komplex aramkor" Grid=37,10 Height=-18 Color=#800000 CBorder=None [Grid Text] Text="0°" Grid=21,28 Height=-16 Color=#FE7900 Font=Times New Roman CBorder=None [Schematic] CurrentSection 0=0 CurrentSection 1=0 CurrentSection 2=0 CurrentSection 3=0 Splitter.xs=0 Splitter.ys=0 TextQuad=4099 Scale=1 PrinterScale=1 GridUser=10 ShapeGroups="Main","Euro","DeMorgan","Polarity","Electrolytic","GroundArrow" CalcRMS=False CalcAVG=False CalcPeak=False CalcVoltage=True DisplayMeasure=Last [Tools] Pos=Top FILESAVEASOLD=No BOM=No FILEPCB=No PROBE=Yes SELECT=Yes COMP=Yes TEXT=Yes WIRE=Yes WIRED=Yes BUS=Yes GRAPHIC=Yes LINE=No ELLIPSE=No RECT=No DIAM=No ARC=No PIE=No LEFTBRK=No RIGHTBRK=No BOTHBRK=No META=No FLAG=Yes INFO=Yes HELP=Yes HELP_SPICE=No LINK=Yes REGION_ENABLE=Yes DIGTRC=No DIGTRC2=No DIGALL=No GRIDTEXT=Yes COMPTEXT=Yes NODE=Yes MEASURED=Yes NODEV=Yes CURRENT=Yes POWER=Yes CONDITIN=Yes PIN=Yes CROSS=No GRID=Yes BORDER=No TITLE=Yes RUBBER=Yes PROPERTY=Yes STEP=Yes MIRROR=Yes ROTATE=Yes FLIPY=Yes FLIPX=Yes CIR_MAKEMACRO=No CLEARCUTWIRE=No FINDCOMP=Yes FIND=Yes REPEAT=No REPLACE=No MODEL=Yes CIR2CKT=No ATTDISP=No ENABLE=Yes DISABLE=Yes TOFRONT=Yes TOBACK=Yes SELNEXT=No PAGEADD=No PAGEADDTEXT=No ADDSECTION=No PAGEDEL=No ZOOMIN=Yes ZOOMOUT=Yes GOTOFLAG=No UPLEVEL=Yes COLOR=Yes FONT=Yes DM_LAST=No DM_RMS=No DM_AVG=No DM_PEAK=No GRID_NONE=No GRID_NORMAL=No GRID_BOLD_5=No GRID_BOLD_6=No GRID_BOLD_USER=No SPLITCIRTEXTH=No SPLITCIRTEXTV=No SPACE_SPLITTERS_EVENLY=No NORMALCIR=No RENAMEDEFINE=No RENAMECMP=No ATTALIGN=No RESETNODEPOS=No FIT2STANDARD=No NODESNAP=No MOVETEXT=No TEXTINC=No TOGGLETEXT=No TOGGLEMODE=No TOLERANCE=No ALIGNLEFT=No ALIGNRIGHT=No ALIGNTOP=No ALIGNBOTTOM=No [Section] Index=0 Name="3fazis" Type=Main Enable=True CurrentPage 0=0 CurrentPage 1=0 CurrentPage 2=0 CurrentPage 3=0 TabSize 0=425 TabSize 1=425 TabSize 2=425 TabSize 3=425 [Page] Index=0 Section=0 Print=True Enable=True Name=Main Scale 0=1 Scale 1=1 Scale 2=1 Scale 3=1 Grid=107,22 [Page] Index=1 Section=0 Type=Text Print=False Enable=True Name=Text [Page] Index=2 Section=0 Type=Text Print=False Enable=True Name=Models SB 0=0,4 [Page] Index=3 Section=0 Type=Info Print=False Enable=True Name=Info [Text Area] Section=0 Page=1 Font=Height=-15,FStyle=0,Color=#000000,Name=Courier New Comment Color=#008000 Background Color=#FFFFFF [Text Area] Section=0 Page=2 Font=Height=-15,FStyle=0,Color=#000000,Name=Courier New Comment Color=#008000 Background Color=#FFFFFF Text= Text=.MODEL 220 SIN (F=50) Text=*** From file D:\Program Files\Spectrum Software\MC9DEMO\library\UTILITY.LBR Text=*** 0 Phase Leg Text=.MODEL 3PHASEA SIN (F=50 RS=0) Text=*** From file D:\Program Files\Spectrum Software\MC9DEMO\library\UTILITY.LBR Text=*** 120 Phase Leg Text=.MODEL 3PHASEB SIN (F=50 PH=2.0944 RS=0) Text=*** From file D:\Program Files\Spectrum Software\MC9DEMO\library\UTILITY.LBR Text=*** 240 Phase Leg Text=.MODEL 3PHASEC SIN (F=50 PH=4.1888 RS=0) [Transient] Window Placement=2,3, -1,-1, -8,-30, 125,125,1019,458 Font=Height=-15,FStyle=0,Color=#0000FF,Name=Arial WinBackGround Color=#FFFFFF Select Color=#FF0000 Select Box Color=#000080 Title AutoTitle=Yes Grid Color=#808080 Grid Weight=1 Grid Pattern=Dot6 Tracker Foreground=Height=-15,FStyle=0,Color=#000000,Name=Arial Tracker Background=#FFFF00 Baseline color=#0000FF BaseLine Weight=1 Static Grids=False PlusMark=False MinorLog25=Off LabelMinor=Off DataPoints=False Token=False Ruler=False XAxisGrids=True YAxisGrids=True MinorLogGrids=True BaseLine=False AlignZ=True Align Cursors=True TagFormatX=3 TagFormatY=3 FormulaFormat=2 Graph Background=#FFFFFF Tracker Intercept=False Tracker Mouse=True Tracker Cursor=True Tracker Cursor BranchInfo=False Horizontal Cursor=True Same Y Scales=Yes Enable X Scaling=True Enable Y Scaling=True Keep X Scales The Same=False Number of Grids X=5 Number of Grids Y=5 Cursor Select Color Primary=#C0C0C0 Cursor Select Color Secondary=#FF0000 Data Point Labels Color Fore=Height=-15,FStyle=0,Color=#000000,Name=Arial Data Point Labels Color Back=#FFFF00 OperPoint=True OperPointOnly=False AutoScaleRanges=True FixedTimeStep=False DoPSS=False PSS_Periods="1" PSS_Iterations="5" PSS_Error="1u" PSS_ShowPlots=True FFT_NPts="1024" FFT_IncludeDCHarmonic=False FFT_AutoScale_Harmonics="10" PrinterAutoTile=No PrinterBlackBorder=No MonMaxShow=3 MonPageWidth=66 MonPlotWidth=21 MonExprXWidth=142 MonExprYWidth=260 MonRangeXWidth=90 MonRangeYWidth=90 AnimateWait=None AnimateWaitTime=500 Save_For_Future=No Reduce_Display=1 Reduce_Save=1 Reduce_ThrowDataOut=0 Num Out Header Left Num Out Header Center="$MC\n$user\n$company\n$Analysis of $name" Num Out Header Right Num Out Delimiter=32 Num Out Write=True Num Out Write Main Header=True Num Out Write Limits=True Num Out Write Branch Header=True Num Out Write Models=True Num Out Write Zero Models=True Num Out Write Undefined Models=True Num Out Write Operating Point=True Num Out Write Values=True Num Out Write Waveform Header=True Num Out Allow Dup Y Expr=False Num Out Low="TSTART" Num Out High="TMAX" Num Out Font=Height=-15,FStyle=0,Color=#000000,Name=Courier New Num Out Format=3 Num Out HideNonSelected=False AutoSaveWave=False Wave Format=16E State Variables Format=5E Print Individual Pages=False [Tools] Pos=Top SELECT=Yes GRAPHIC=Yes LINE=No ELLIPSE=No RECT=No DIAM=No ARC=No PIE=No LEFTBRK=No RIGHTBRK=No BOTHBRK=No META=No POLYCLOS=No SCALE=Yes CURSOR=Yes MEASUREH=Yes MEASUREV=Yes TAG=Yes PTAG=Yes TEXT=Yes PROPERTY=Yes START=Yes STOP=Yes PAUSE=Yes RESUME=No DATAPTS=Yes TOKENS=Yes RULER=Yes PLUS=Yes XAXIS=Yes YAXIS=Yes MINORLOG=Yes LOG25=Yes BASELINE=Yes HORIZCUR=Yes GOTOX=Yes GOTOY=Yes GOTOPERF=Yes GOTOBRNC=Yes CLEAR_ACCUMULATED=Yes PDELETE_ALL_PLOTS=Yes NEXT=Yes NEXTIN=Yes PEAK=Yes VALLEY=Yes HIGH=Yes LOW=Yes INFLECTN=Yes GHIGH=Yes GLOW=Yes BOTTOM=Yes TOP=Yes WAVEFORMBUFFER=Yes AOUTPUT=Yes PKEY=Yes ENXSCALE=Yes ENYSCALE=Yes ZOOMIN=Yes ZOOMOUT=Yes AUTOSCALE=Yes RESTORESCALE=No COLOR=Yes FONT=Yes SELNEXT=No NORMALIZE=No NORMALIZE_MIN=No NORMALIZE_MAX=No ADD_TAG_LEFT=No ADD_TAG_RIGHT=No ADD_HORZ_TAG=No ADD_VERT_TAG=No ALIGN_CURSORS=No ALIGN_CURSORSZ=No CURSORTOCLIPBOARD=No TRACKER_CURSOR=No TRACKER_CURSOR_BRANCHINFO=No TRACKER_INTERCEPT=No TRACKER_MOUSE=No TOFRONT=Yes TOBACK=Yes SPLITCIRTEXTH=No SPLITCIRTEXTV=No SPACE_SPLITTERS_EVENLY=No NORMALCIR=No LABEL_WAVEFORM=No LABEL_DATA_POINTS=No WFB_ADD_TO_LIMITS=No ENVELOPE=No SAMEYSCALES=No KEEPXSCALESTHESAME=No SHOWWATCH=No BP=No TOGGLEMODE=No REMOVEALLTEXT=No AUTOSCALEX=No LABELALLMINOR=No ALIGNLEFT=No ALIGNRIGHT=No ALIGNTOP=No ALIGNBOTTOM=No [APage] Analysis=Transient Name="Main" [AC] Window Placement=2,3, -1,-1, -8,-30, 200,123,1271,526 Font=Height=-15,FStyle=0,Color=#0000FF,Name=Arial WinBackGround Color=#FFFFFF Select Color=#FF0000 Select Box Color=#000080 Title AutoTitle=Yes Grid Color=#808080 Grid Weight=1 Grid Pattern=Dot6 Tracker Foreground=Height=-15,FStyle=0,Color=#000000,Name=Arial Tracker Background=#FFFF00 Baseline color=#0000FF BaseLine Weight=1 Static Grids=False PlusMark=False MinorLog25=Off LabelMinor=Off DataPoints=False Token=False Ruler=False XAxisGrids=True YAxisGrids=True MinorLogGrids=True BaseLine=False AlignZ=True Align Cursors=True TagFormatX=3 TagFormatY=3 FormulaFormat=2 Graph Background=#FFFFFF Tracker Intercept=False Tracker Mouse=True Tracker Cursor=True Tracker Cursor BranchInfo=False Horizontal Cursor=False Same Y Scales=Yes Enable X Scaling=True Enable Y Scaling=True Keep X Scales The Same=False Number of Grids X=5 Number of Grids Y=5 Cursor Select Color Primary=#C0C0C0 Cursor Select Color Secondary=#FF0000 Data Point Labels Color Fore=Height=-15,FStyle=0,Color=#000000,Name=Arial Data Point Labels Color Back=#FFFF00 OperPoint=True AutoScaleRanges=False FFT_NPts="1024" FFT_IncludeDCHarmonic=False FFT_AutoScale_Harmonics="10" PrinterAutoTile=No PrinterBlackBorder=No MonMaxShow=3 MonPageWidth=66 MonPlotWidth=21 MonExprXWidth=142 MonExprYWidth=260 MonRangeXWidth=90 MonRangeYWidth=90 AnimateWait=None AnimateWaitTime=500 Save_For_Future=No Reduce_Display=1 Reduce_Save=1 Reduce_ThrowDataOut=0 Num Out Header Left Num Out Header Center="$MC\n$user\n$company\n$Analysis of $name" Num Out Header Right Num Out Delimiter=32 Num Out Write=True Num Out Write Main Header=True Num Out Write Limits=True Num Out Write Branch Header=True Num Out Write Models=True Num Out Write Zero Models=True Num Out Write Undefined Models=True Num Out Write Operating Point=True Num Out Write Noise=True Num Out Write Values=True Num Out Write Waveform Header=True Num Out Allow Dup Y Expr=False Num Out Low="FMIN" Num Out High="FMAX" Num Out Font=Height=-15,FStyle=0,Color=#000000,Name=Courier New Num Out Format=3 Num Out HideNonSelected=False AutoSaveWave=False Wave Format=16E State Variables Format=5E Print Individual Pages=False [Tools] Pos=Top SELECT=Yes GRAPHIC=Yes LINE=No ELLIPSE=No RECT=No DIAM=No ARC=No PIE=No LEFTBRK=No RIGHTBRK=No BOTHBRK=No META=No POLYCLOS=No SCALE=Yes CURSOR=Yes MEASUREH=Yes MEASUREV=Yes TAG=Yes PTAG=Yes TEXT=Yes PROPERTY=Yes START=Yes STOP=Yes PAUSE=Yes RESUME=No DATAPTS=Yes TOKENS=Yes RULER=Yes PLUS=Yes XAXIS=Yes YAXIS=Yes MINORLOG=Yes LOG25=Yes BASELINE=Yes HORIZCUR=Yes GOTOX=Yes GOTOY=Yes GOTOPERF=Yes GOTOBRNC=Yes CLEAR_ACCUMULATED=Yes PDELETE_ALL_PLOTS=Yes NEXT=Yes NEXTIN=Yes PEAK=Yes VALLEY=Yes HIGH=Yes LOW=Yes INFLECTN=Yes GHIGH=Yes GLOW=Yes BOTTOM=Yes TOP=Yes WAVEFORMBUFFER=Yes AOUTPUT=Yes PKEY=Yes ENXSCALE=Yes ENYSCALE=Yes ZOOMIN=Yes ZOOMOUT=Yes AUTOSCALE=Yes RESTORESCALE=No COLOR=Yes FONT=Yes SELNEXT=No NORMALIZE=No NORMALIZE_MIN=No NORMALIZE_MAX=No ADD_TAG_LEFT=No ADD_TAG_RIGHT=No ADD_HORZ_TAG=No ADD_VERT_TAG=No ALIGN_CURSORS=No ALIGN_CURSORSZ=No CURSORTOCLIPBOARD=No TRACKER_CURSOR=No TRACKER_CURSOR_BRANCHINFO=No TRACKER_INTERCEPT=No TRACKER_MOUSE=No TOFRONT=Yes TOBACK=Yes SPLITCIRTEXTH=No SPLITCIRTEXTV=No SPACE_SPLITTERS_EVENLY=No NORMALCIR=No LABEL_WAVEFORM=No LABEL_DATA_POINTS=No WFB_ADD_TO_LIMITS=No ENVELOPE=No SAMEYSCALES=No KEEPXSCALESTHESAME=No SHOWWATCH=No BP=No TOGGLEMODE=No REMOVEALLTEXT=No AUTOSCALEX=No LABELALLMINOR=No ALIGNLEFT=No ALIGNRIGHT=No ALIGNTOP=No ALIGNBOTTOM=No [APage] Analysis=AC Name="Main" [Monte Carlo Options] Analysis=Transient Status=Off Zero Tolerance=False Eliminate Outliers=False Distribution=Normal Number of Runs=10 Seed=0 [Monte Carlo Options] Analysis=AC Status=Off Zero Tolerance=False Eliminate Outliers=False Distribution=Normal Number of Runs=10 Seed=0 [Limits] Analysis=Transient TRange=0.1 TStep=0 NPts=51 Temp=27 RetraceRuns=1 StateVar=Zero RunOption=Normal Temperature Type=Linear Accumulate Plots=False [WaveForm] Analysis=Transient Plt=1 AliasID=12 XExp=T YExp=V(1) XRng=0.1 YRng=1.5,-1 Options=LINEARX,LINEARY Range Grid X=0.02 Range Grid Y=0.5 Enable=Enable Line Color=#FF0000 Text Color=#FF0000 Rainbow=False VFmtX=3 VFmtY=3 ScaleFactorX="None" ScaleFactorY="None" ScaleUnitsX="Auto" ScaleUnitsY="Auto" SFmtX=3 SFmtY=3 NOFmtX=3 NOFmtY=3 [WaveForm] Analysis=Transient Plt=2 AliasID=1 XExp=T YExp=i(R3) XRng=0.1 YRng=0.0036,-0.0024 Options=LINEARX,LINEARY Range Grid X=0.02 Range Grid Y=0.0012 Enable=Enable Line Color=#FF0000 Text Color=#FF0000 Rainbow=False VFmtX=3 VFmtY=3 ScaleFactorX="None" ScaleFactorY="None" ScaleUnitsX="Auto" ScaleUnitsY="Auto" SFmtX=3 SFmtY=3 NOFmtX=3 NOFmtY=3 [WaveForm] Analysis=Transient Plt=3 AliasID=2 XExp=T YExp=V(R4)+V(R5) XRng=0.1 YRng=0.9,-0.6 Options=LINEARX,LINEARY Range Grid X=0.02 Range Grid Y=0.3 Enable=Enable Line Color=#008000 Text Color=#008000 Rainbow=False VFmtX=3 VFmtY=3 ScaleFactorX="None" ScaleFactorY="None" ScaleUnitsX="Auto" ScaleUnitsY="Auto" SFmtX=3 SFmtY=3 NOFmtX=3 NOFmtY=3 [Limits] Analysis=AC FRange=100 NPts=51 Temp=27 MaxChng=5 NInput=NONE NOutput=2 Sweep type=Log StateVar=Zero RunOption=Normal Temperature Type=Linear Accumulate Plots=False [WaveForm] Analysis=AC Plt=1 AliasID=1 XExp=F YExp=db(v(1)) XRng=1e8,1e6 YRng=1,-1 Options=LINEARY Range Grid X=1.98e7 Range Grid Y=0.5 Enable=Enable Line Color=#0000FF Text Color=#0000FF Rainbow=False VFmtX=3 VFmtY=3 ScaleFactorX="None" ScaleFactorY="None" ScaleUnitsX="Auto" ScaleUnitsY="Auto" SFmtX=3 SFmtY=3 NOFmtX=3 NOFmtY=3 [WaveForm] Analysis=AC Plt=2 AliasID=2 XExp=F YExp=ph(v(1)) XRng=1e8,1e6 YRng=1,-1 Options=LINEARY Range Grid X=1.98e7 Range Grid Y=0.5 Enable=Enable Line Color=#FF0000 Text Color=#FF0000 Rainbow=False VFmtX=3 VFmtY=3 ScaleFactorX="None" ScaleFactorY="None" ScaleUnitsX="Auto" ScaleUnitsY="Auto" SFmtX=3 SFmtY=3 NOFmtX=3 NOFmtY=3 [WaveForm] Analysis=AC AliasID=-1 Options=LINEARY Enable=Enable Line Color=#008000 Text Color=#008000 Rainbow=False VFmtX=3 VFmtY=3 ScaleFactorX="None" ScaleFactorY="None" ScaleUnitsX="Auto" ScaleUnitsY="Auto" SFmtX=3 SFmtY=3 NOFmtX=3 NOFmtY=3 [Limits] Analysis=DynamicAC Temp=27 FreqList=50 SliderPer=10 FirstValueDisplay=Real SecondValueDisplay=Imag PlaceText=True TextGrid=1,13 [Limits] Analysis=DynamicDC Temp=27 SliderPer=10 PlaceText=True [Pane] Analysis=Transient CurrentPage 0="Main" [Pane] Analysis=AC CurrentPage 0="Main" [Pane] Analysis=DC [Pane] Analysis=HmDistortion [Pane] Analysis=ImDistortion [Watch] Analysis=Transient Format=3 ExprPercentWidth=80 [Watch] Analysis=AC Format=3 ExprPercentWidth=80 [OPMethods] Analysis=Transient Standard Newton-Raphson=0,0 Source Stepping=0,0 Diagonal Gmin Stepping=0,0 Junction Gmin Stepping=0,0 Pseudo Transient=0,0 [OPMethods] Analysis=AC Standard Newton-Raphson=0,0 Source Stepping=0,0 Diagonal Gmin Stepping=0,0 Junction Gmin Stepping=0,0 Pseudo Transient=0,0 [OPMethods] Analysis=DC Standard Newton-Raphson=0,0 Source Stepping=0,0 Diagonal Gmin Stepping=0,0 Junction Gmin Stepping=0,0 Pseudo Transient=0,0
