;	Nicad/NiMH Battery Charger
;	4/98 Luhan Monat
	device	PIC16C84,hs_osc,wdt_off,pwrte_on
NOBAT	=	40		;0.87 volts
NOCHRG	=	75		;1.48  volts (?)
	org	12
w_save	ds	1
s_save	ds	1
data	ds	1
temp	ds	1
temp1	ds	1
count	ds	1
xcnt	ds	1
mtime	ds	1
mvon	ds	1
mvoff	ds	1
addr	ds	1
bcnt	ds	1
bmask	ds	1
lochrg	ds	1
hichrg	ds	1
ischrg	ds	1
flag	ds	1
; FLAG bit definitions
BATIN	=	0		;battery inserted
	org	0
	goto	start
	org	4
; interrupt routine with context save
inter	movwf	w_save		;save w register
	swapf	status,w	;reverse nibble of status
	movwf	s_save		;in status save
	bcf	status,5	;now, force to primary registers
;	end of entrance code
	bcf	INTCON,2	;clear rtcc int flag
;	begin exit code	
	swapf	s_save,w	;re-reverse status data
	movwf	status		;restore to status register
	swapf	w_save		;pre-swap w saved
	swapf	w_save,w	;swap into w without affection status
	reti			;enable global interrupt
start	bsf	STATUS,5	;alt regs
	movlw	01000000b	;only bit 6 is input
	movwf	TRISB
	movlw	00000b
	movwf	TRISA
	movlw	10001000b
	movwf	OPTION		;clk/4 -> rtcc
	bcf	STATUS,5
	clrf	mvon
	incf	mvon
	call	adjust
	bsf	rb,4
	bcf	rb,5
	clrf	hichrg
	clrf	ischrg
	movlw	0fh
	movwf	lochrg
main	movlw	0
	movwf	mtime
	call	dobats
:m1	movlw	50
	movwf	xcnt
	call	adjust		;adjust switching voltage
	call	engage		;engage battery power
:m2	call	pulse
	decfsz	xcnt
	goto	:m2
	decfsz	mtime
	goto	:m1
	goto	main
engage	movf	mtime,w		;get cycle counter
	andlw	7		;divide into 1/4, 3/4 timeslots
	btfss	z
	goto	:e2		;most of the time
	call	setlo		;only if high charging
	goto	:e5
:e2	call	sethi		;low charge for dead cells
:e5	movf	mtime,w
	sublw	250
	btfss	c		;
	call	setis		;for fully charged
	ret
setlo	movf	rb,w		;port rb data
	iorlw	0Fh		;clear bits for battery enables
	xorwf	lochrg,w	;set battery bits
	movwf	rb		;back out to port
	ret
sethi	movf	rb,w		;port rb data
	xorwf	hichrg,w	;set battery bits
	ret
setis	movf	rb,w
	andlw	0F0h		;all bits on
	movwf	rb
	ret
dobats	bcf	flag,BATIN	;assume no battery present
	movlw	0fh
	iorwf	rb		;disconnect all batteries
	movlw	1
	movwf	addr		;first address
	movlw	4
	movwf	bcnt
	movlw	1
	movwf	bmask		;battery bit
:bat	movf	addr,w
	movwf	ra
	movlw	10
	call	sdelay
	call	atod		;read battery
	movf	data,w
	sublw	NOBAT		;battery present?
	btfsc	c		;under threshhold?
	goto	:no		;yes - skip it.
	bsf	flag,BATIN	;got at least one.
	movf	data,w
	sublw	NOCHRG
	btfsc	c
	goto	:chrg
	goto	:done		;all charged up
:chrg	movf	bmask,w
	andwf	ischrg,w	;already charged?
	btfss	z		;
	goto	:done		;yes.
	movf	bmask,w
	iorwf	hichrg		;set for max charge rate
	goto	:end
:no	movf	bmask,w
	iorwf	lochrg		;low charge for dead cells
	xorlw	0ffh		;reverse bits
	andwf	ischrg		;clear is-charged bit
	andwf	hichrg
	goto	:end
:done	movf	bmask,w
	iorwf	ischrg		;mark already charged
	movf	bmask,w
	xorlw	0ffh		;invert all bits
	andwf	lochrg		;no low charge
	andwf	hichrg		;no high charge
:end	incf	addr		;next address
	bcf	c
	rlf	bmask
	decfsz	bcnt
	goto	:bat
	ret
adjust	clrf	ra		;address = 0
	call	atod		;read voltage
	sublw	170		;2.2 volts for charging
	btfsc	c
	goto	:up
	decf	mvon
	btfsc	z
	incf	mvon
	goto	:off
:up	incf	mvon
	btfsc	mvon,3		;max of 63
	decf	mvon
:off	movf	mvon,w
	sublw	16
	movwf	mvoff
	ret
pulse	bcf	rb,7
	movf	mvon,w
	movwf	temp
:p2	decfsz	temp
	goto	:p2
	bsf	rb,7
	movf	mvoff,w
	movwf	temp
:p4	decfsz	temp
	goto	:p4
	ret
delay	movwf	temp
	clrf	temp1
:d2	decfsz	temp1
	goto	:d2
	decfsz	temp
	goto	:d2
	ret
sdelay	movwf	temp
del2	nop
	nop
	decfsz	temp
	goto	del2
	ret
; reads ADC0831 serial d/a in 73 usec
; coded for maximum conversion w/ 10mhz pic16f84
atod	bcf	rb,4		;CS low
	clrf	data		;clear data byte
	bsf	rb,5		;first clock
	nop
	nop
	nop
	bcf	rb,5
	nop
	nop
	nop
	bsf	rb,5		;second clock
	nop
	nop
	nop
	bcf	rb,5
	movlw	8		;set bit count
	movwf	count		;into count
	clrf	data		;zero out data
	bcf	c		;clear carry bit
atod2	bsf	rb,5		;clock hi
	rlf	data		;hi order is first
	btfsc	rb,6		;test input bit
	bsf	data,0		;if hi - set data bit
	bcf	rb,5		;clock low
	decfsz	count		;8 times
	goto	atod2
	bsf	rb,4		;CS hi
	movf	data,w		;data in w
	ret
	end
QED   
