<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.2">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.05" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
</plain>
<libraries>
<library name="motorola-sensor-driver">
<description>&lt;b&gt;Motorola pressure sensor&lt;/b&gt;&lt;p&gt;
SEMICONDUCTOR TECHNICAL DATA mpx2050.pdf</description>
<packages>
<package name="DIP08">
<description>&lt;b&gt;Dual In Line&lt;/b&gt;</description>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="0.635" width="0.1524" layer="21" curve="180"/>
<wire x1="5.08" y1="-2.54" x2="-5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.54" x2="5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-5.2578" y="-2.54" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="7.239" y="-2.54" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="discrete">
<description>Discrete devices (Antenna, Arrrester, Thermistor)</description>
<packages>
<package name="R-5">
<description>&lt;b&gt;Resistor&lt;/b&gt;</description>
<wire x1="-1.27" y1="0.635" x2="1.27" y2="0.635" width="0.127" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="-1.27" y2="-0.635" width="0.127" layer="21"/>
<wire x1="1.27" y1="0" x2="1.778" y2="0" width="0.127" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.27" y2="0" width="0.127" layer="21"/>
<wire x1="-1.778" y1="0" x2="-1.27" y2="0" width="0.127" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="0" width="0.127" layer="21"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-0.635" width="0.127" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-0.635" width="0.127" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<text x="-2.54" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-1.27" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="R-7,5">
<wire x1="-2.54" y1="-1.27" x2="2.54" y2="-1.27" width="0.127" layer="21"/>
<wire x1="2.54" y1="1.27" x2="-2.54" y2="1.27" width="0.127" layer="21"/>
<wire x1="2.54" y1="0" x2="3.048" y2="0" width="0.127" layer="21"/>
<wire x1="2.54" y1="-1.27" x2="2.54" y2="0" width="0.127" layer="21"/>
<wire x1="-2.54" y1="0" x2="-3.048" y2="0" width="0.127" layer="21"/>
<wire x1="-2.54" y1="1.27" x2="-2.54" y2="0" width="0.127" layer="21"/>
<wire x1="2.54" y1="0" x2="2.54" y2="1.27" width="0.127" layer="21"/>
<wire x1="-2.54" y1="0" x2="-2.54" y2="-1.27" width="0.127" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<text x="-2.54" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DO35-7B">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2 mm, horizontal, grid 7.62 mm</description>
<wire x1="3.81" y1="0" x2="2.667" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.667" y2="0" width="0.508" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.016" x2="2.286" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="0.762" x2="-2.032" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="-0.762" x2="-2.032" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.032" y1="-1.016" x2="2.286" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="0.762" x2="2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.016" x2="2.032" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.016" x2="2.032" y2="-1.016" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="long"/>
<text x="-2.286" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.016" x2="-1.397" y2="1.016" layer="21"/>
<rectangle x1="-2.667" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
<rectangle x1="2.286" y1="-0.254" x2="2.667" y2="0.254" layer="21"/>
</package>
<package name="DO35-7">
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<text x="-2.286" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="2.286" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
</packages>
</library>
<library name="ref-packages">
<description>&lt;b&gt;Reference Package&lt;/b&gt;&lt;p&gt;</description>
<packages>
<package name="E5-5">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 5.08 mm, diameter 5 mm</description>
<wire x1="-2.1557" y1="1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="21" curve="-116.146571"/>
<wire x1="-2.1557" y1="-1.3432" x2="2.1557" y2="-1.3432" width="0.1524" layer="21" curve="116.146571"/>
<wire x1="-2.1557" y1="1.3432" x2="-2.1557" y2="-1.3432" width="0.1524" layer="51" curve="63.853429"/>
<wire x1="2.1557" y1="-1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="51" curve="63.853429"/>
<wire x1="-1.397" y1="0" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.016" x2="-0.254" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.016" x2="-0.254" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.016" x2="-0.762" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.016" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.635" x2="-1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.381" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="1.905"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="1.905" shape="octagon"/>
<text x="2.54" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.016" x2="0.762" y2="1.016" layer="21"/>
</package>
</packages>
</library>
<library name="transistor-fet">
<description>&lt;b&gt;Field Effect Transistors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
Symbols changed according to IEC617&lt;p&gt;
All types, packages and assignment to symbols and pins checked&lt;p&gt;
Package outlines partly checked&lt;p&gt;
&lt;p&gt;
JFET = junction FET&lt;p&gt;
IGBT-x = insulated gate bipolar transistor&lt;p&gt;
x=N: NPN; x=P: PNP&lt;p&gt;
IGFET-mc-nnn; (IGFET=insulated gate field effect transistor)&lt;P&gt;
m=D: depletion mode (Verdr&amp;auml;ngungstyp)&lt;p&gt;
m=E: enhancement mode (Anreicherungstyp)&lt;p&gt;
c: N=N-channel; P=P-Channel&lt;p&gt;
GDSB: gate, drain, source, bulk&lt;p&gt;
&lt;p&gt;
by R. Vogg  15.March.2002</description>
<packages>
<package name="TO92">
<description>&lt;b&gt;TO 92&lt;/b&gt;</description>
<wire x1="-2.0946" y1="-1.651" x2="-2.6549" y2="-0.254" width="0.127" layer="21" curve="-32.781"/>
<wire x1="-2.6549" y1="-0.254" x2="-0.7863" y2="2.5485" width="0.127" layer="21" curve="-78.3185"/>
<wire x1="0.7863" y1="2.5484" x2="2.0945" y2="-1.651" width="0.127" layer="21" curve="-111.1"/>
<wire x1="-2.0945" y1="-1.651" x2="2.0945" y2="-1.651" width="0.127" layer="21"/>
<wire x1="-2.2537" y1="-0.254" x2="-0.2863" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-2.6549" y1="-0.254" x2="-2.2537" y2="-0.254" width="0.127" layer="21"/>
<wire x1="-0.2863" y1="-0.254" x2="0.2863" y2="-0.254" width="0.127" layer="21"/>
<wire x1="2.2537" y1="-0.254" x2="2.6549" y2="-0.254" width="0.127" layer="21"/>
<wire x1="0.2863" y1="-0.254" x2="2.2537" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-0.7863" y1="2.5485" x2="0.7863" y2="2.5485" width="0.127" layer="51" curve="-34.2936"/>
<pad name="1" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<pad name="3" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0.635" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.635" y="0.635" size="1.27" layer="51" ratio="10">2</text>
<text x="-2.159" y="0" size="1.27" layer="51" ratio="10">3</text>
<text x="1.143" y="0" size="1.27" layer="51" ratio="10">1</text>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules>
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="E$1" library="motorola-sensor-driver" package="DIP08" value="" x="54.61" y="46.99"/>
<element name="E$2" library="discrete" package="R-5" value="" x="45.72" y="41.91" rot="R270"/>
<element name="E$3" library="discrete" package="R-5" value="" x="50.8" y="55.88"/>
<element name="E$4" library="diode" package="DO35-7B" value="" x="41.91" y="40.64" rot="R270"/>
<element name="E$5" library="diode" package="DO35-7B" value="" x="44.45" y="53.34" rot="R270"/>
<element name="E$7" library="discrete" package="R-5" value="" x="62.23" y="40.64" rot="R90"/>
<element name="E$6" library="discrete" package="R-5" value="" x="62.23" y="52.07" rot="R90"/>
<element name="E$8" library="discrete" package="R-5" value="" x="67.31" y="52.07" rot="R90"/>
<element name="E$9" library="discrete" package="R-7,5" value="" x="40.64" y="53.34" rot="R90"/>
<element name="E$10" library="discrete" package="R-7,5" value="" x="38.1" y="40.64" rot="R90"/>
<element name="E$12" library="discrete" package="R-7,5" value="" x="73.66" y="49.53" rot="R180"/>
<element name="E$13" library="discrete" package="R-7,5" value="" x="90.17" y="44.45"/>
<element name="E$11" library="ref-packages" package="E5-5" value="" x="68.58" y="41.91"/>
<element name="E$14" library="diode" package="DO35-7" value="" x="76.2" y="41.91" rot="R90"/>
<element name="E$15" library="diode" package="DO35-7" value="" x="83.82" y="57.15"/>
<element name="E$16" library="transistor-fet" package="TO92" value="" x="83.82" y="50.8" rot="R90"/>
<element name="E$17" library="ref-packages" package="E5-5" value="" x="90.17" y="39.37"/>
<element name="E$18" library="discrete" package="R-7,5" value="" x="73.66" y="54.61"/>
</elements>
<signals>
<signal name="S$1">
<contactref element="E$1" pad="1"/>
<contactref element="E$1" pad="2"/>
<wire x1="50.8" y1="43.18" x2="53.34" y2="43.18" width="0" layer="19" extent="1-1"/>
<wire x1="50.8" y1="43.18" x2="53.34" y2="43.18" width="0.4064" layer="16"/>
</signal>
<signal name="S$2">
<contactref element="E$1" pad="3"/>
<wire x1="55.88" y1="43.18" x2="55.88" y2="39.37" width="0.4064" layer="16"/>
<wire x1="55.88" y1="39.37" x2="48.26" y2="39.37" width="0.4064" layer="16"/>
<contactref element="E$2" pad="2"/>
<wire x1="48.26" y1="39.37" x2="45.72" y2="39.37" width="0.4064" layer="16"/>
<wire x1="48.26" y1="39.37" x2="48.26" y2="55.88" width="0.4064" layer="16"/>
<contactref element="E$3" pad="1"/>
</signal>
<signal name="S$3">
<contactref element="E$2" pad="1"/>
<contactref element="E$5" pad="A"/>
<wire x1="45.72" y1="44.45" x2="44.45" y2="44.45" width="0.4064" layer="16"/>
<wire x1="44.45" y1="44.45" x2="44.45" y2="49.53" width="0.4064" layer="16"/>
<contactref element="E$4" pad="C"/>
<wire x1="44.45" y1="44.45" x2="41.91" y2="44.45" width="0.4064" layer="16"/>
<wire x1="41.91" y1="44.45" x2="41.91" y2="46.99" width="0.4064" layer="16"/>
<wire x1="41.91" y1="46.99" x2="40.64" y2="46.99" width="0.4064" layer="16"/>
<contactref element="E$9" pad="1"/>
<wire x1="40.64" y1="46.99" x2="38.1" y2="46.99" width="0.4064" layer="16"/>
<wire x1="40.64" y1="49.53" x2="40.64" y2="46.99" width="0.4064" layer="16"/>
<wire x1="38.1" y1="44.45" x2="38.1" y2="46.99" width="0.4064" layer="16"/>
</signal>
<signal name="S$5">
<contactref element="E$3" pad="2"/>
<wire x1="53.34" y1="55.88" x2="62.23" y2="55.88" width="0.4064" layer="16"/>
<wire x1="62.23" y1="55.88" x2="62.23" y2="54.61" width="0.4064" layer="16"/>
<wire x1="62.23" y1="55.88" x2="64.77" y2="55.88" width="0.4064" layer="16"/>
<contactref element="E$8" pad="2"/>
<wire x1="64.77" y1="55.88" x2="67.31" y2="55.88" width="0.4064" layer="16"/>
<wire x1="67.31" y1="55.88" x2="67.31" y2="54.61" width="0.4064" layer="16"/>
<wire x1="64.77" y1="55.88" x2="64.77" y2="41.91" width="0.4064" layer="16"/>
<wire x1="64.77" y1="41.91" x2="66.04" y2="41.91" width="0.4064" layer="16"/>
<contactref element="E$18" pad="1"/>
<wire x1="67.31" y1="54.61" x2="69.85" y2="54.61" width="0.4064" layer="16"/>
</signal>
<signal name="S$7">
<contactref element="E$1" pad="5"/>
<wire x1="58.42" y1="50.8" x2="60.96" y2="50.8" width="0.4064" layer="16"/>
<wire x1="60.96" y1="50.8" x2="60.96" y2="46.99" width="0.4064" layer="16"/>
<contactref element="E$6" pad="1"/>
<contactref element="E$7" pad="2"/>
<wire x1="62.23" y1="49.53" x2="62.23" y2="46.99" width="0.4064" layer="16"/>
<wire x1="62.23" y1="46.99" x2="62.23" y2="43.18" width="0.4064" layer="16"/>
<wire x1="60.96" y1="46.99" x2="62.23" y2="46.99" width="0.4064" layer="16"/>
</signal>
<signal name="S$6">
<contactref element="E$10" pad="1"/>
<wire x1="38.1" y1="36.83" x2="35.56" y2="36.83" width="0.4064" layer="16"/>
<wire x1="35.56" y1="36.83" x2="35.56" y2="50.8" width="0.4064" layer="16"/>
<wire x1="35.56" y1="50.8" x2="36.83" y2="50.8" width="0.4064" layer="16"/>
</signal>
<signal name="S$8">
<contactref element="E$1" pad="7"/>
<wire x1="53.34" y1="50.8" x2="53.34" y2="53.34" width="0.4064" layer="16"/>
<wire x1="53.34" y1="53.34" x2="60.96" y2="53.34" width="0.4064" layer="16"/>
<wire x1="60.96" y1="53.34" x2="60.96" y2="52.07" width="0.4064" layer="16"/>
<wire x1="60.96" y1="52.07" x2="63.5" y2="52.07" width="0.4064" layer="16"/>
<wire x1="63.5" y1="52.07" x2="63.5" y2="39.37" width="0.4064" layer="16"/>
<wire x1="63.5" y1="39.37" x2="68.58" y2="39.37" width="0.4064" layer="16"/>
<wire x1="68.58" y1="39.37" x2="68.58" y2="43.18" width="0.4064" layer="16"/>
<wire x1="68.58" y1="43.18" x2="67.31" y2="43.18" width="0.4064" layer="16"/>
<wire x1="67.31" y1="43.18" x2="67.31" y2="44.45" width="0.4064" layer="16"/>
<wire x1="67.31" y1="44.45" x2="66.04" y2="44.45" width="0.4064" layer="16"/>
<wire x1="66.04" y1="44.45" x2="66.04" y2="52.07" width="0.4064" layer="16"/>
<wire x1="66.04" y1="52.07" x2="69.85" y2="52.07" width="0.4064" layer="16"/>
<contactref element="E$12" pad="2"/>
<wire x1="69.85" y1="52.07" x2="69.85" y2="49.53" width="0.4064" layer="16"/>
</signal>
<signal name="S$10">
<contactref element="E$14" pad="A"/>
<wire x1="76.2" y1="45.72" x2="77.47" y2="45.72" width="0.4064" layer="16"/>
<contactref element="E$12" pad="1"/>
<wire x1="77.47" y1="49.53" x2="77.47" y2="45.72" width="0.4064" layer="16"/>
</signal>
<signal name="S$11">
<contactref element="E$14" pad="C"/>
<wire x1="76.2" y1="38.1" x2="81.28" y2="39.37" width="0.4064" layer="16"/>
<wire x1="81.28" y1="39.37" x2="83.82" y2="39.37" width="0.4064" layer="16"/>
<contactref element="E$13" pad="1"/>
<wire x1="83.82" y1="39.37" x2="83.82" y2="44.45" width="0.4064" layer="16"/>
<wire x1="83.82" y1="44.45" x2="86.36" y2="44.45" width="0.4064" layer="16"/>
<contactref element="E$17" pad="+"/>
<wire x1="83.82" y1="39.37" x2="87.63" y2="39.37" width="0.4064" layer="16"/>
<wire x1="81.28" y1="39.37" x2="81.28" y2="50.8" width="0.4064" layer="16"/>
<wire x1="81.28" y1="50.8" x2="82.55" y2="50.8" width="0.4064" layer="16"/>
</signal>
<signal name="S$12">
<contactref element="E$16" pad="1"/>
<wire x1="83.82" y1="52.07" x2="83.82" y2="53.34" width="0.4064" layer="16"/>
<wire x1="83.82" y1="53.34" x2="80.01" y2="53.34" width="0.4064" layer="16"/>
<wire x1="80.01" y1="53.34" x2="80.01" y2="41.91" width="0.4064" layer="16"/>
<wire x1="80.01" y1="41.91" x2="74.93" y2="41.91" width="0.4064" layer="16"/>
<wire x1="71.12" y1="41.91" x2="71.12" y2="35.56" width="0.4064" layer="16"/>
<contactref element="E$8" pad="1"/>
<wire x1="67.31" y1="49.53" x2="67.31" y2="45.72" width="0.4064" layer="16"/>
<wire x1="67.31" y1="45.72" x2="73.66" y2="45.72" width="0.4064" layer="16"/>
<wire x1="73.66" y1="45.72" x2="73.66" y2="35.56" width="0.4064" layer="16"/>
<wire x1="34.29" y1="35.56" x2="41.91" y2="35.56" width="0.4064" layer="16"/>
<wire x1="41.91" y1="35.56" x2="62.23" y2="35.56" width="0.4064" layer="16"/>
<wire x1="62.23" y1="35.56" x2="71.12" y2="35.56" width="0.4064" layer="16"/>
<wire x1="71.12" y1="35.56" x2="73.66" y2="35.56" width="0.4064" layer="16"/>
<contactref element="E$7" pad="1"/>
<wire x1="62.23" y1="38.1" x2="62.23" y2="35.56" width="0.4064" layer="16"/>
<contactref element="E$4" pad="A"/>
<wire x1="41.91" y1="36.83" x2="41.91" y2="35.56" width="0.4064" layer="16"/>
<wire x1="73.66" y1="35.56" x2="74.93" y2="35.56" width="0.4064" layer="16"/>
<contactref element="E$17" pad="-"/>
<wire x1="74.93" y1="35.56" x2="92.71" y2="35.56" width="0.4064" layer="16"/>
<wire x1="92.71" y1="35.56" x2="93.98" y2="35.56" width="0.4064" layer="16"/>
<wire x1="92.71" y1="39.37" x2="92.71" y2="35.56" width="0.4064" layer="16"/>
<contactref element="E$13" pad="2"/>
<wire x1="93.98" y1="44.45" x2="93.98" y2="35.56" width="0.4064" layer="16"/>
<wire x1="74.93" y1="41.91" x2="74.93" y2="35.56" width="0.4064" layer="16"/>
<wire x1="34.29" y1="35.56" x2="34.29" y2="34.29" width="0.4064" layer="16"/>
<wire x1="34.29" y1="34.29" x2="96.52" y2="34.29" width="0.4064" layer="16"/>
<wire x1="96.52" y1="34.29" x2="96.52" y2="35.56" width="0.4064" layer="16"/>
<wire x1="96.52" y1="35.56" x2="93.98" y2="35.56" width="0.4064" layer="16"/>
</signal>
<signal name="S$9">
<contactref element="E$18" pad="2"/>
<wire x1="77.47" y1="54.61" x2="77.47" y2="59.69" width="0.4064" layer="16"/>
<contactref element="E$5" pad="C"/>
<wire x1="44.45" y1="57.15" x2="44.45" y2="59.69" width="0.4064" layer="16"/>
<wire x1="44.45" y1="59.69" x2="50.8" y2="59.69" width="0.4064" layer="16"/>
<contactref element="E$1" pad="8"/>
<wire x1="50.8" y1="59.69" x2="67.31" y2="59.69" width="0.4064" layer="16"/>
<wire x1="50.8" y1="50.8" x2="50.8" y2="59.69" width="0.4064" layer="16"/>
<wire x1="67.31" y1="59.69" x2="77.47" y2="59.69" width="0.4064" layer="16"/>
<contactref element="E$15" pad="C"/>
<wire x1="77.47" y1="59.69" x2="92.71" y2="59.69" width="0.4064" layer="16"/>
<wire x1="77.47" y1="59.69" x2="80.01" y2="57.15" width="0.4064" layer="16" curve="90"/>
</signal>
<signal name="S$13">
<contactref element="E$16" pad="3"/>
<wire x1="83.82" y1="49.53" x2="90.17" y2="49.53" width="0.4064" layer="16"/>
<contactref element="E$15" pad="A"/>
<wire x1="90.17" y1="49.53" x2="90.17" y2="54.61" width="0.4064" layer="16"/>
<wire x1="90.17" y1="54.61" x2="87.63" y2="57.15" width="0.4064" layer="16" curve="90"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
