;* Software License Agreement                                         *
;* The software supplied herewith by Microchip Technology             *
;* Incorporated (the "Company") is intended and supplied to you, the  *
;* Company’s customer, for use solely and exclusively on Microchip    *
;* products. The software is owned by the Company and/or its supplier,*
;* and is protected under applicable copyright laws. All rights are   *
;* reserved. Any use in violation of the foregoing restrictions may   *
;* subject the user to criminal sanctions under applicable laws, as   *
;* well as to civil liability for the breach of the terms and         *
;* conditions of this license.                                        *
;* THIS SOFTWARE IS PROVIDED IN AN "AS IS" CONDITION. NO WARRANTIES,  *
;* WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED  *
;* TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A        *
;* PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE COMPANY SHALL NOT,  *
;* IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR         *
;* CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.                  *
;    Filename:	    SensBLDC.asm                                      *
;    Date:          11 Feb 2002                                       *
;    File Version:  1.0                                               *
;    Author:        W.R.Brown                                         *
;    Company:       Microchip Technolgy Incorporated                  *
;    Files required: p16f877.inc                                      *
;    Notes: Sensored brushless motor control                          *
	list      p=16f877            ; list directive to define processor
	#include <p16f877.inc>        ; processor specific variable definitions
	__CONFIG _CP_OFF & _WDT_OFF & _BODEN_ON & _PWRTE_ON & _HS_OSC & _WRT_ENABLE_OFF & _LVP_ON & _DEBUG_OFF & _CPD_OFF 
;* Define variable storage
	CBLOCK 0x20
	ADC		; PWM threshold is ADC result
	LastSensor	; last read motor sensor data
	DriveWord	; six bit motor drive data
	ENDC
;* Define I/O
#define	OffMask		B'11010101'
#define	DrivePort	PORTC
#define DrivePortTris	TRISC
#define	SensorMask	B'00000111'
#define	SensorPort	PORTE
#define DirectionBit	PORTA,1
	org	0x000		; startup vector
	nop			; required for ICD operation
	clrf    PCLATH          ; ensure page bits are cleared
  	goto    Initialize      ; go to beginning of program
	ORG     0x004           ; interrupt vector location
	retfie                  ; return from interrupt
;* Initialize I/O ports and peripherals
Initialize
	clrf	DrivePort	; all drivers off
	banksel TRISA
; setup I/O
	clrf	DrivePortTris	; set motor drivers as outputs
	movlw	B'00000011'	; A/D on RA0, Direction on RA1, Motor sensors on RE<2:0>
	movwf	TRISA		; 
; setup Timer0
	movlw	B'11010000'	; Timer0: Fosc, 1:2
	movwf	OPTION_REG
; Setup ADC (bank1)
	movlw	B'00001110'	; ADC left justified, AN0 only
	movwf	ADCON1
	banksel	ADCON0
; setup ADC (bank0)
	movlw	B'11000001'	; ADC clock from int RC, AN0, ADC on
	movwf	ADCON0
	bsf	ADCON0,GO	; start ADC
	clrf	LastSensor	; initialize last sensor reading
	call 	Commutate	; determine present motor positon
	clrf	ADC		; start speed control threshold at zero until first ADC reading
;* Main control loop
Loop
	call	ReadADC		; get the speed control from the ADC
	incfsz	ADC,w		; if ADC is 0xFF we're at full speed - skip timer add
	goto	PWM		; add timer 0 to ADC for PWM 
	movf	DriveWord,w	; force on condition
	goto	Drive		; continue
PWM
	movf	ADC,w		; restore ADC reading
	addwf	TMR0,w		; add it to current timer0
	movf	DriveWord,w	; restore commutation drive data
	btfss	STATUS,C	; test if ADC + timer0 resulted in carry
	andlw	OffMask		; no carry - supress high drivers
Drive	
	movwf	DrivePort	; enable motor drivers
	call	Commutate	; test for commutation change
	goto	Loop		; repeat loop
ReadADC
;* If the ADC is ready then read the speed control potentiometer
;* and start the next reading
	btfsc	ADCON0,NOT_DONE	; is ADC ready?
	return			; no - return
	movf	ADRESH,w	; get ADC result
	bsf	ADCON0,GO	; restart ADC
	movwf	ADC		; save result in speed control threshold
	return			; 
;* Read the sensor inputs and if a change is sensed then get the
;* corresponding drive word from the drive table
Commutate
	movlw	SensorMask	; retain only the sensor bits
	andwf	SensorPort,w	; get sensor data
	xorwf	LastSensor,w	; test if motion sensed
	btfsc	STATUS,Z	; zero if no change
	return			; no change - back to the PWM loop
	xorwf	LastSensor,f	; replace last sensor data with current
	btfss	DirectionBit	; test direction bit
	goto	FwdCom		; bit is zero - do forward commutation
				; reverse commutation
	movlw	HIGH RevTable	; get MS byte of table
	movwf	PCLATH		; prepare for computed GOTO
	movlw	LOW RevTable	; get LS byte of table
	goto	Com2
FwdCom				; forward commutation
	movlw	HIGH FwdTable	; get MS byte of table
	movlw	LOW FwdTable	; get LS byte of table
Com2
	addwf	LastSensor,w	; add sensor offset
	btfsc	STATUS,C	; page change in table?
	incf	PCLATH,f	; yes - adjust MS byte
	call	GetDrive	; get drive word from table
	movwf	DriveWord	; save as current drive word
	return
GetDrive
	movwf	PCL
;* The drive tables are built based on the following assumptions:
;* 1) There are six drivers in three pairs of two
;* 2) Each driver pair consists of a high side (+V to motor) and low side (motor to ground) drive
;* 3) A 1 in the drive word will turn the corresponding driver on
;* 4) The three driver pairs correspond to the three motor windings: A, B and C
;* 5) Winding A is driven by bits <1> and <0> where <1> is A's high side drive
;* 6) Winding B is driven by bits <3> and <2> where <3> is B's high side drive
;* 7) Winding C is driven by bits <5> and <4> where <5> is C's high side drive
;* 8) Three sensor bits consitute the address offset to the drive table
;* 9) A sensor bit transitions from a 0 to 1 at the moment that the corresponding 
;*    winding's high side forward drive begins.
;* 10) Sensor bit <0> corresponds to winding A
;* 11) Sensor bit <1> corresponds to winding B
;* 12) Sensor bit <2> corresponds to winding C
FwdTable
	retlw	B'00000000'	; invalid
	retlw	B'00010010'	; phase 6
	retlw	B'00001001'	; phase 4
	retlw	B'00011000'	; phase 5
	retlw	B'00100100'	; phase 2
	retlw	B'00000110'	; phase 1
	retlw	B'00100001'	; phase 3
RevTable
	retlw	B'00100001'	; phase /6
	retlw	B'00000110'	; phase /4
	retlw	B'00100100'	; phase /5
	retlw	B'00011000'	; phase /2
	retlw	B'00001001'	; phase /1
	retlw	B'00010010'	; phase /3
	END                       ; directive 'end of program'
