;* Software License Agreement                                         *
;* The software supplied herewith by Microchip Technology             *
;* Incorporated (the "Company") is intended and supplied to you, the  *
;* Company’s customer, for use solely and exclusively on Microchip    *
;* products. The software is owned by the Company and/or its supplier,*
;* and is protected under applicable copyright laws. All rights are   *
;* reserved. Any use in violation of the foregoing restrictions may   *
;* subject the user to criminal sanctions under applicable laws, as   *
;* well as to civil liability for the breach of the terms and         *
;* conditions of this license.                                        *
;* THIS SOFTWARE IS PROVIDED IN AN "AS IS" CONDITION. NO WARRANTIES,  *
;* WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED  *
;* TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A        *
;* PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE COMPANY SHALL NOT,  *
;* IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR         *
;* CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.                  *
;    Filename:	    snsrless.asm                                      *
;    Date:          14 Jan 2002                                       *
;    File Version:  1.0                                               *
;    Author:        W.R.Brown                                         *
;    Company:       Microchip Technolgy Incorporated                  *
;    Files required: p16f877.inc                                      *
;    Notes: Sensorless brushless motor control                        *
;	Closed loop 3 phase brushless DC motor control.               *
;	Two potentiometers control operation. One potentiometer (A0)  *
;	controls PWM (voltage) and RPM (from table). The other        *
;	potentiometer (A1) provides a PWM offset to the PWM derived   *
;	from A0. Phase A motor terminal is connected via voltage      *
;	divider to A3. This is read while the drive is on during      *
;	phase 4. The result is the peak applied voltage (Vsupply).    * 
;	A3 is also read while the drive is on at two times during     *
;	phase 5. The result is the BEMF voltage. The BEMF voltage is  *
;	read at the quarter (t1) and mid (t2) points of the phase 5   *
;	period. BEMF is compared to VSupply/2. If BEMF is above       *
;	VSupply/2 at t1 and below VSupply/2w at t2 then no speed      *
;	adjustment is made. If BEMF is high at both t1 and t2 then    *
;	the speed is reduced. If BEMF is low at t1 and t2 then the    *
;	speed is increased.                                           *
	list P = PIC16F877
	include "p16f877.inc"
	__CONFIG _CP_OFF & _WRT_ENABLE_OFF & _HS_OSC & _WDT_OFF & _PWRTE_ON & _BODEN_ON
; Acceleration/Deceleration Time = RampRate * 256 * 256 * Timer 0 prescale / Fosc
#define		AccelDelay	D'255'		; determines full range acceleration time
#define		DecelDelay	D'200'		; determines full range deceleration time
#define		ManThresh	0x3f		; Manual threshold is the PWM potentiomenter
						; reading above which RPM is adjusted automatically
#define		AutoThresh	0x100-ManThresh
OffMask	equ	B'11010101'	; PWM off kills the high drives
Invalid	equ	B'00000000'	; invalid
Phase1	equ	B'00100001'	; phase 1 C high, A low
Phase2	equ	B'00100100'	; phase 2 C high, B low
Phase3	equ	B'00000110'	; phase 3 A high, B low
Phase4	equ	B'00010010'	; phase 4 A high, C low
Phase5	equ	B'00011000'	; phase 5 B high, C low
Phase6	equ	B'00001001'	; phase 6 B high, A low
#define	CARRY	STATUS,C
#define ZERO	STATUS,Z
#define subwl	sublw
;*	Define I/O Ports
#define	ReadIndicator	PORTB,0		; diagnostic scope trigger for BEMF readings
#define DrivePort	PORTC		; motor drive and lock status
;*	Define RAM variables
	CBLOCK 0x20
	STATE		; Machine state
	PWMThresh	; PWM threshold
	PhaseIndx	; Current motor phase index
	Drive		; Motor drive word
	RPMIndex	; RPM Index workspace
	ADCRPM		; ADC RPM value
	ADCOffset	; Delta offset to ADC PWM threshold
	PresetHi	; speed control timer compare MS byte
	PresetLo	; speed control timer compare LS byte
	Flags		; general purpose flags
	Vsupply		; Supply voltage ADC reading
	DeltaV1		; Difference between expected and actual BEMF at T/4
	DeltaV2		; Difference between expected and actual BEMF at T/2
	CCPSaveH	; Storage for phase time when finding DeltaV
	CCPSaveL	; Storage for phase time when finding DeltaV
	CCPT2H		; Workspace for determining T/2 and T/4
	CCPT2L		; Workspace for determining T/2 and T/4
	RampTimer	; Timer 0 post scaler for accel/decel ramp rate
	xCount		; general purpose counter workspace
	Status		; relative speed indicator status
	ENDC
;*	Define Flags
#define DriveOnFlag	Flags,0		; Flag for invoking drive disable mask when clear
#define AutoRPM		Flags,1		; RPM timer is adjusted automatically
;			Flags,3		; Undefined
#define FullOnFlag	Flags,4		; PWM threshold is set to maximum drive
#define Tmr0Ovf		Flags,5		; Timer 0 overflow flag
#define Tmr0Sync	Flags,6		; Second Timer 0 overflow flag
;			Flags,7		; undefined
#define	BEMF1Low	DeltaV1,7	; BEMF1 is low if DeltaV1 is negative
#define	BEMF2Low	DeltaV2,7	; BEMF2 is low if DeltaV2 is negative
;*	Define State machine states and index numbers
sRPMSetup	equ	D'0'		; Wait for Phase1, Set ADC GO, RA1->ADC
sRPMRead	equ	sRPMSetup+1	; Wait for ADC nDONE, Read ADC->RPM
sOffsetSetup	equ	sRPMRead+1	; Wait for Phase2, Set ADC GO, RA3->ADC
sOffsetRead	equ	sOffsetSetup+1	; Wait for ADC nDONE, Read ADC->ADCOffset
sVSetup		equ	sOffsetRead+1	; Wait for Phase4, Drive On, wait 9 uSec, Set ADC GO
sVIdle		equ	sVSetup+1	; Wait for Drive On, wait Tacq, set ADC GO				
sVRead		equ	sVIdle+1	; Wait for ADC nDONE, Read ADC->Vsupply
sBEMFSetup	equ	sVRead+1	; Wait for Phase5, set Timer1 compare to half phase time
sBEMFIdle	equ	sBEMFSetup+1	; Wait for Timer1 compare, Force Drive on and wait 9 uSec,
				 	; Set ADC GO, RA0->ADC
sBEMFRead	equ	sBEMFIdle+1	; Wait for ADC nDONE, Read ADC->Vbemf
sBEMF2Idle	equ	sBEMFRead+1	; Wait for Timer1 compare, Force Drive on and wait 9 uSec,
sBEMF2Read	equ	sBEMF2Idle+1	; Wait for ADC nDONE, Read ADC->Vbemf
;*	The ADC input is changed depending on the STATE
;*	Each STATE assumes a previous input selection and changes the selection
;* 	by XORing the control register with the appropriate ADC input change mask
;*	defined here:
ADC0to1		equ	B'00001000'	; changes ADCON0<5:3> from 000 to 001
ADC1to3		equ	B'00010000'	; changes ADCON0<5:3> from 001 to 011
ADC3to0		equ	B'00011000'	; changes ADCON0<5:3> from 011 to 000
;**************************** PROGRAM STARTS HERE ********************************
	org	0x000
	nop
	goto	Initialize
	org	0x004
	bsf	Tmr0Ovf		; Timer 0 overflow flag used by accel/decel timer
	bsf	Tmr0Sync	; Timer 0 overflow flag used to synchronize code execution
	bcf	INTCON,T0IF
	retfie			;
Initialize
	clrf	PORTC		; all drivers off
	clrf	PORTB
	banksel TRISA
; setup I/O
	clrf	TRISC		; motor drivers on PORTC
	movlw	B'00001011'	; A/D on RA0 (PWM), RA1 (Speed) and RA3 (BEMF)
	movwf	TRISA		; 
	movlw	B'11111110'	; RB0 is locked indicator
	movwf	TRISB
; setup Timer0
	movlw	B'11010000'	; Timer0: Fosc, 1:2
	movwf	OPTION_REG
	bsf	INTCON,T0IE	; enable timer 0 interrupts
; Setup ADC
	movlw	B'00000100'	; ADC left justified, AN0, AN1
	movwf	ADCON1
	banksel	PORTA
	movlw	B'10000001'	; ADC clk = Fosc/32, AN0, ADC on
	movwf	ADCON0
; setup Timer 1
	movlw	B'00100001'	; 1:4 prescale, internal clock, timer on
	movwf	T1CON
; setup Timer 1 compare
	movlw	0xFF		; set compare to maximum count
	movwf	CCPR1L		; LS compare register
	movwf	CCPR1H		; MS compare register
	movlw	B'00001011'	; Timer 1 compare mode, special event - clears timer1
	movwf	CCP1CON
; initialize RAM
	clrf	PWMThresh
	movlw	D'6'
	movwf	PhaseIndx
	clrf	Flags
	clrf	Status		;
	clrf	STATE		; LoopIdle->STATE
	bcf	INTCON,T0IF	; ensure timer 0 overflow flag is cleared
	bsf	INTCON,GIE	; enable interrupts
MainLoop
;	PWM, Commutation, State machine loop
	btfsc	PIR1,CCP1IF	; time for phase change?
	call	Commutate	; yes - change motor drive
PWM
	bsf	DriveOnFlag	; pre-set flag
	btfsc	FullOnFlag	; is PWM level at maximum?
	goto	PWM02		; yes - only commutation is necessary
	movf	PWMThresh,w	; get PWM threshold
	addwf	TMR0,w		; compare to timer 0
	btfss	CARRY		; drive is on if carry is set
	bcf	DriveOnFlag	; timer has not reached threshold, disable drive
	call	DriveMotor	; output drive word
PWM02
	call	LockTest
	call	StateMachine	; service state machine
	goto	MainLoop	; repeat loop
StateMachine
	movlw	SMTableEnd-SMTable-1	; STATE table must have 2^n entries
	andwf	STATE,f		; limit STATE index to state table
	movlw	high SMTable	; get high byte of table address
	movwf	PCLATH		; prepare for computed goto
	movlw	low SMTable	; get low byte of table address
	addwf	STATE,w		; add STATE index to table root
	btfsc	CARRY		; test for page change in table
	incf	PCLATH,f	; page change adjust
	movwf	PCL		; jump into table
SMTable				; number of STATE table entries MUST be evenly divisible by 2
	goto	RPMSetup	; Wait for Phase1, Set ADC GO, RA1->ADC, clear timer0 overflow
	goto	RPMRead		; Wait for ADC nDONE, Read ADC->RPM
	goto	OffsetSetup	; Wait for Phase2, Set ADC GO, RA3->ADC
	goto	OffsetRead	; Wait for ADC nDONE, Read ADC->ADCOffset
	goto	VSetup		; Wait for Phase4
	goto	VIdle		; Wait for Drive On, wait Tacq, set ADC GO				
	goto	VRead		; Wait for ADC nDONE, Read ADC->Vsupply
	goto	BEMFSetup	; Wait for Phase5, set Timer1 compare to half phase time
	goto	BEMFIdle	; When Timer1 compares force Drive on, Set ADC GO after Tacq, RA0->ADC
	goto	BEMFRead	; Wait for ADC nDONE, Read ADC->Vbemf
	goto	BEMF2Idle	; When Timer1 compares force Drive on, Set ADC GO after Tacq, RA0->ADC
	goto	BEMF2Read	; Wait for ADC nDONE, Read ADC->Vbemf
; fill out table with InvalidStates to make number of table entries evenly divisible by 2	
	goto	InvalidState	; invalid state - reset state machine
SMTableEnd	
	movlw	Phase1		; compare Phase1 word...
	xorwf	Drive,w		; ...with current drive word
	btfss	ZERO		; ZERO if equal
	return			; not Phase1 - remain in current STATE
	bsf	ADCON0,GO	; start ADC
	movlw	ADC0to1		; prepare to change ADC input
	xorwf	ADCON0,f	; change from AN0 to AN1
	incf	STATE,f		; next STATE
	bcf	Tmr0Sync	; clear timer0 overflow
	return			; back to Main Loop
	btfsc	ADCON0,GO	; is ADC conversion finished?
	return			; no - remain in current STATE
	movf	ADRESH,w	; get ADC result
	movwf	ADCRPM		; save in RPM
	movlw	Phase2		; compare Phase2 word...
	return			; not Phase2 - remain in current STATE
	movlw	ADC1to3		; prepare to change ADC input
	xorwf	ADCON0,f	; change from AN1 to AN3
	xorlw	H'80'		; complement MSB for +/- offset
	movwf	ADCOffset	; save in offset
	addwf	ADCRPM,w	; add offset to PWM result
	btfss	ADCOffset,7	; is offset a negative number?
	goto	OverflowTest	; no - test for overflow
	btfss	CARRY		; underflow?
	andlw	H'00'		; yes - force minimum
	goto	Threshold	;
OverflowTest	
	btfsc	CARRY		; overflow?
	movlw	H'ff'		; yes - force maximum
Threshold	
	movwf	PWMThresh	; PWM threshold is RPM result plus offset
	btfsc	ZERO		; is drive off?
	goto	DriveOff	; yes - skip voltage measurements
	bcf	FullOnFlag	; pre-clear flag in preparation of compare
	sublw	0xFD		; full on threshold
	btfss	CARRY		; CY = 0 if PWMThresh > FullOn
	bsf	FullOnFlag	; set full on flag
DriveOff
	clrf	Status		; clear speed indicators
	movlw	B'11000111'	; reset ADC input to AN0
	andwf	ADCON0,f	;
	clrf	STATE		; reset state machine
	return
	movlw	Phase4		; compare Phase4 word...
	xorwf	Drive,w		; ...with current Phase drive word
	return			; not Phase4 - remain in current STATE
	call	SetTimer	; set timer value from RPM table
	btfss	DriveOnFlag	; is Drive active?
	bsf	ReadIndicator	; Diagnostic	
	call	Tacq		; motor Drive is active - wait ADC Tacq time
	bcf	ReadIndicator	; Diagnostic
	movwf	Vsupply		; save as supply voltage
	bcf	Tmr0Sync	; clear timer 0 overflow
	movlw	Phase5		; compare Phase5 word...
	return			; not Phase5 - remain in current STATE
	btfss	Tmr0Sync	; synchronize with timer 0
	return			;
	btfss	PWMThresh,7	; if PWMThresh > 0x80 then ON is longer than OFF
	goto	BEMFS1		; OFF is longer and motor is currently off - compute now
	btfss	DriveOnFlag	; ON is longer - wait for drive cycle to start
	return			; not started - wait
BEMFS1
	bcf	CCP1CON,0	; disable special event on compare
	movf	CCPR1H,w	; save current capture compare state
	movwf	CCPSaveH	; 
	movwf	CCPT2H		; save copy in workspace
	movf	CCPR1L,w	; low byte
	movwf	CCPSaveL	; save
	movwf	CCPT2L		; and save copy
	bcf	CARRY		; pre-clear carry for rotate
	rrf	CCPT2H,f	; divide phase time by 2
	rrf	CCPT2L,f	; 
	rrf	CCPT2H,w	; divide phase time by another 2
	movwf	CCPR1H		; first BEMF reading at phase T/4
	rrf	CCPT2L,w	; 
	movwf	CCPR1L		;
	btfss	PIR1,CCP1IF	; timer compare?
	bsf	DriveOnFlag	; force drive on for BEMF reading
	call	DriveMotor	; activate motor drive
	call	Tacq		; wait ADC acqisition time
; setup to capture BEMF at phase 3/4 T 
	movf	CCPT2H,w
	addwf	CCPR1H,f	; next compare at phase 3/4 T
	movf	CCPT2L,w	; 
	addwf	CCPR1L,f	; set T/2 lsb
	btfsc	CARRY		; test for carry into MSb
	incf	CCPR1H,f	; perform carry
	bcf	PIR1,CCP1IF	; clear timer compare interrupt flag
	rrf	Vsupply,w	; divide supply voltage by 2	
	subwf	ADRESH,w	; Vbemf - Vsupply/2
	movwf	DeltaV1		; save error voltage
	movlw	ADC3to0		; prepare to change ADC input
	xorwf	ADCON0,f	; change from AN3 to AN0
; restore Timer1 phase time and special event compare mode
	movf	CCPSaveH,w
	movwf	CCPR1H		; next compare at phase T
	movf	CCPSaveL,w	; 
	movwf	CCPR1L		; set T lsb
	bsf	CCP1CON,0	; enable special event on compare
	movwf	DeltaV2		; save error voltage
	clrf	STATE		; reset state machine to beginning 
InvalidState			; trap for invalid STATE index
	andwf	ADCON0,f	;
	clrf	STATE
	return	
;______________________________________________________________________________________________________
Tacq
;	Software delay for ADC acquisition time
;	Delay time = Tosc*(3+3*xCount)
	movlw	D'14'		; 14 equates to approx 9 uSec delay
	movwf	xCount	;
	decfsz	xCount,f	;
	goto	$-1		; loop here until time complete
	return
LockTest
;	T is the commutation phase period. Back EMF is measured on the
;	floating motor terminal at two times during T to determine
;	the approximate zero crossing of the BEMF. BEMF low means that
;	the measured BEMF is below (supply voltage)/2.
;	If BEMF is low at 1/4 T then accelerate.
;	If BEMF is high at 1/4 T and low at 3/4 T then speed is OK.
;	If BEMF is high at 1/4 T and 3/4 T then decelerate.
;	Lock test computation is synchronized to the PWM clock such
;	that the computation is performed during the PWM ON or OFF
;	time whichever is longer.
; synchronize test with start of timer 0	
	btfss	Tmr0Ovf		; has timer 0 wrapped around?
	return			; no - skip lock test
	goto	LT05		; OFF is longer and motor is currently off - compute now
LT05
	bcf	Tmr0Ovf		; clear synchronization flag
	decfsz	RampTimer,f	; RampTimer controls the acceleration/deceleration rate
	return
; use lock results to control RPM only if not manual mode		
	bsf	AutoRPM		; preset flag
	movf	ADCRPM,w	; compare RPM potentiometer...
	addlw	AutoThresh	; ...to the auto control threshold
	btfss	CARRY		; CARRY is set if RPM is > auto threshold
	bcf	AutoRPM		; not in auto range - reset flag
	btfss	BEMF1Low	; is first BEMF below Supply/2
	goto	LT20		; no - test second BEMF
LT10
; accelerate if BEMF at 1/4 T is below Supply/2
	movlw	B'10000000'	; indicate lock test results
	movwf	Status		; status is OR'd with drive word later	
	movlw	AccelDelay	; set the timer for acceleration delay
	movwf	RampTimer	;
	btfss	AutoRPM		; is RPM in auto range?
	goto	ManControl	; no - skip RPM adjustment
	incfsz	RPMIndex,f	; increment the RPM table index
	return			; return if Index didn't wrap around
	decf	RPMIndex,f	; top limit is 0xFF
	return
LT20	
	btfsc	BEMF2Low	; BEMF1 was high...
	goto	ShowLocked	; ... and BEMF2 is low - show locked
; decelerate if BEMF at 3/4 T is above Supply/2
	movlw	B'01000000'	; indicate lock test results
	movlw	DecelDelay	; set the timer for deceleration delay
	movwf	RampTimer	;
	decfsz	RPMIndex,f	; set next lower RPM table index
	return			; return if index didn't wrap around
	incf	RPMIndex,f	; bottom limit is 0x01
	return
ShowLocked
	movlw	B'11000000'	; indicate lock test results 
	movwf	RampTimer	;
	btfsc	AutoRPM		; was RPM set automatically?
	return			; yes - we're done
ManControl
	movf	ADCRPM,w	; get RPM potentiometer reading...
	movwf	RPMIndex	; ...and set table index directly
	return
Commutate
;	Commutation is triggered by PIR1<CCP1IF> flag.
;	This flag is set when timer1 equals the compare register.
;	When BEMF measurement is active the compare time is not
;	cleared automatically (special event trigger is off).
;       Ignore the PIR1<CCP1IF> flag when special trigger is off
;	because the flag is for BEMF measurment.
;	If BEMF measurement is not active then decrement phase table
;	index and get the drive word from the table. Save the
;	drive word in a global variable and output to motor drivers.
	btfss	CCP1CON,0	; is special event on compare enabled?
	return			; no - this is a BEMF measurment, let state machine handle this
	bcf	PIR1,CCP1IF	; clear interrupt flag
	movlw	high OnTable	; set upper program counter bits
	movwf	PCLATH
	decfsz	PhaseIndx,w	; decrement to next phase
	goto	$+2		; skip reset if not zero
	movlw	D'6'		; phase counts 6 to 1
	movwf	PhaseIndx	; save the phase index
	addlw	LOW OnTable
	btfsc	CARRY		; test for possible page boundry
	incf	PCLATH,f	; page boundry adjust
	call	GetDrive
	movwf	Drive		; save motor drive word
DriveMotor
	movf	Drive,w		; restore motor drive word
	btfss	DriveOnFlag	; test drive enable flag
	andlw	OffMask		; kill high drive if PWM is off
	iorwf	Status,w	; show speed indicators
	movwf	DrivePort	; output to motor drivers
	return
GetDrive
	movwf	PCL		; computed goto
OnTable
	retlw	Invalid
	retlw	Phase6
	retlw	Phase5
	retlw	Phase4
	retlw	Phase3
	retlw	Phase2
	retlw	Phase1
	retlw	Invalid
SetTimer
;	This sets the CCP module compare registers for timer 1. 
; 	The motor phase period is the time it takes timer 1
;	to count from 0 to the compare value. The CCP module
;	is configured to clear timer 1 when the compare occurs.
; 	Get the timer1 compare variable from two lookup tables, one
;	for the compare high byte and the other for the low byte.
	call	SetTimerHigh
	movwf	CCPR1H			; Timer1 High byte preset
	call	SetTimerLow
	movwf	CCPR1L			; Timer1 Low byte preset
	return
SetTimerHigh
	movlw	high T1HighTable	; lookup preset values
	movwf	PCLATH			; high bytes first
	movlw	low T1HighTable		;
	addwf	RPMIndex,w		; add table index
	btfsc	STATUS,C		; test for table page crossing
	incf	PCLATH,f		;
	movwf	PCL			; lookup - result returned in W
SetTimerLow
	movlw	high T1LowTable		; repeat for lower byte 
	movwf	PCLATH			; 
	movlw	low T1LowTable		;
	incf	PCLATH,f		;
#include "BLDCspd4.inc"
	end
