<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.2">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="yes" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
</layers>
<library>
<packages>
<package name="TSSOP28">
<wire x1="-4.7896" y1="-2.2828" x2="4.7896" y2="-2.2828" width="0.1524" layer="21"/>
<wire x1="4.7896" y1="2.2828" x2="4.7896" y2="-2.2828" width="0.1524" layer="21"/>
<wire x1="4.7896" y1="2.2828" x2="-4.7896" y2="2.2828" width="0.1524" layer="21"/>
<wire x1="-4.7896" y1="-2.2828" x2="-4.7896" y2="2.2828" width="0.1524" layer="21"/>
<wire x1="-4.561" y1="-2.0542" x2="4.561" y2="-2.0542" width="0.0508" layer="21"/>
<wire x1="4.561" y1="2.0542" x2="4.561" y2="-2.0542" width="0.0508" layer="21"/>
<wire x1="4.561" y1="2.0542" x2="-4.561" y2="2.0542" width="0.0508" layer="21"/>
<wire x1="-4.561" y1="-2.0542" x2="-4.561" y2="2.0542" width="0.0508" layer="21"/>
<circle x="-3.5756" y="-1.2192" radius="0.4572" width="0.1524" layer="21"/>
<smd name="1" x="-4.225" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="2" x="-3.575" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="3" x="-2.925" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="4" x="-2.275" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="5" x="-1.625" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="6" x="-0.975" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="7" x="-0.325" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="8" x="0.325" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="9" x="0.975" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="10" x="1.625" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="11" x="2.275" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="12" x="2.925" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="13" x="3.575" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="14" x="4.225" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="15" x="4.225" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="16" x="3.575" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="17" x="2.925" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="18" x="2.275" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="19" x="1.625" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="20" x="0.975" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="21" x="0.325" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="22" x="-0.325" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="23" x="-0.975" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="24" x="-1.625" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="25" x="-2.275" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="26" x="-2.925" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="27" x="-3.575" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="28" x="-4.225" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<text x="-5.1706" y="-2.0828" size="1.016" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="6.1612" y="-2.0828" size="1.016" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-4.3266" y1="-3.121" x2="-4.1234" y2="-2.2828" layer="51"/>
<rectangle x1="-3.6766" y1="-3.121" x2="-3.4734" y2="-2.2828" layer="51"/>
<rectangle x1="-3.0266" y1="-3.121" x2="-2.8234" y2="-2.2828" layer="51"/>
<rectangle x1="-2.3766" y1="-3.121" x2="-2.1734" y2="-2.2828" layer="51"/>
<rectangle x1="-1.7266" y1="-3.121" x2="-1.5234" y2="-2.2828" layer="51"/>
<rectangle x1="-1.0766" y1="-3.121" x2="-0.8734" y2="-2.2828" layer="51"/>
<rectangle x1="-0.4266" y1="-3.121" x2="-0.2234" y2="-2.2828" layer="51"/>
<rectangle x1="0.2234" y1="-3.121" x2="0.4266" y2="-2.2828" layer="51"/>
<rectangle x1="0.8734" y1="-3.121" x2="1.0766" y2="-2.2828" layer="51"/>
<rectangle x1="1.5234" y1="-3.121" x2="1.7266" y2="-2.2828" layer="51"/>
<rectangle x1="2.1734" y1="-3.121" x2="2.3766" y2="-2.2828" layer="51"/>
<rectangle x1="2.8234" y1="-3.121" x2="3.0266" y2="-2.2828" layer="51"/>
<rectangle x1="3.4734" y1="-3.121" x2="3.6766" y2="-2.2828" layer="51"/>
<rectangle x1="4.1234" y1="-3.121" x2="4.3266" y2="-2.2828" layer="51"/>
<rectangle x1="4.1234" y1="2.2828" x2="4.3266" y2="3.121" layer="51"/>
<rectangle x1="3.4734" y1="2.2828" x2="3.6766" y2="3.121" layer="51"/>
<rectangle x1="2.8234" y1="2.2828" x2="3.0266" y2="3.121" layer="51"/>
<rectangle x1="2.1734" y1="2.2828" x2="2.3766" y2="3.121" layer="51"/>
<rectangle x1="1.5234" y1="2.2828" x2="1.7266" y2="3.121" layer="51"/>
<rectangle x1="0.8734" y1="2.2828" x2="1.0766" y2="3.121" layer="51"/>
<rectangle x1="0.2234" y1="2.2828" x2="0.4266" y2="3.121" layer="51"/>
<rectangle x1="-0.4266" y1="2.2828" x2="-0.2234" y2="3.121" layer="51"/>
<rectangle x1="-1.0766" y1="2.2828" x2="-0.8734" y2="3.121" layer="51"/>
<rectangle x1="-1.7266" y1="2.2828" x2="-1.5234" y2="3.121" layer="51"/>
<rectangle x1="-2.3766" y1="2.2828" x2="-2.1734" y2="3.121" layer="51"/>
<rectangle x1="-3.0266" y1="2.2828" x2="-2.8234" y2="3.121" layer="51"/>
<rectangle x1="-3.6766" y1="2.2828" x2="-3.4734" y2="3.121" layer="51"/>
<rectangle x1="-4.3266" y1="2.2828" x2="-4.1234" y2="3.121" layer="51"/>
</package>
<package name="SO08">
<description>&lt;b&gt;8 Lead SOIC&lt;/b&gt;&lt;p&gt;
Data Sheet No. PD60212 Rev A&lt;br&gt;
Source: www.irf.com .. ir2520.pdf</description>
<wire x1="2.4" y1="1.9" x2="2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.9" x2="-2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.9" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.4" x2="-2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="1.9" x2="2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<smd name="2" x="-0.635" y="-2.35" dx="0.72" dy="1.78" layer="1"/>
<smd name="7" x="-0.635" y="2.35" dx="0.72" dy="1.78" layer="1"/>
<smd name="1" x="-1.905" y="-2.35" dx="0.72" dy="1.78" layer="1"/>
<smd name="3" x="0.635" y="-2.35" dx="0.72" dy="1.78" layer="1"/>
<smd name="4" x="1.905" y="-2.35" dx="0.72" dy="1.78" layer="1"/>
<smd name="8" x="-1.905" y="2.35" dx="0.72" dy="1.78" layer="1"/>
<smd name="6" x="0.635" y="2.35" dx="0.72" dy="1.78" layer="1"/>
<smd name="5" x="1.905" y="2.35" dx="0.72" dy="1.78" layer="1"/>
<text x="-2.667" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.937" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.15" y1="-3.1" x2="-1.66" y2="-2" layer="51"/>
<rectangle x1="-0.88" y1="-3.1" x2="-0.39" y2="-2" layer="51"/>
<rectangle x1="0.39" y1="-3.1" x2="0.88" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="-3.1" x2="2.15" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="2" x2="2.15" y2="3.1" layer="51"/>
<rectangle x1="0.39" y1="2" x2="0.88" y2="3.1" layer="51"/>
<rectangle x1="-0.88" y1="2" x2="-0.39" y2="3.1" layer="51"/>
<rectangle x1="-2.15" y1="2" x2="-1.66" y2="3.1" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="A3941">
<pin name="VDRAIN" x="7.62" y="30.48" length="middle" rot="R270"/>
<pin name="LSS" x="12.7" y="30.48" length="middle" rot="R270"/>
<pin name="GLB" x="-20.32" y="10.16" length="middle"/>
<pin name="SB" x="22.86" y="-38.1" length="middle" rot="R90"/>
<pin name="GHB" x="-20.32" y="5.08" length="middle"/>
<pin name="CB" x="20.32" y="-38.1" length="middle" rot="R90"/>
<pin name="VREG" x="2.54" y="30.48" length="middle" rot="R270"/>
<pin name="VREG2" x="-2.54" y="30.48" length="middle" rot="R270"/>
<pin name="CA" x="12.7" y="-38.1" length="middle" rot="R90"/>
<pin name="GHA" x="-20.32" y="-5.08" length="middle"/>
<pin name="SA" x="15.24" y="-38.1" length="middle" rot="R90"/>
<pin name="GLA" x="-20.32" y="0" length="middle"/>
<pin name="VBB" x="30.48" y="20.32" length="middle" rot="R180"/>
<pin name="VBB2" x="30.48" y="22.86" length="middle" rot="R180"/>
<pin name="CP2" x="5.08" y="-38.1" length="middle" rot="R90"/>
<pin name="CP1" x="7.62" y="-38.1" length="middle" rot="R90"/>
<pin name="GND" x="30.48" y="-20.32" length="middle" rot="R180"/>
<pin name="GND2" x="30.48" y="-17.78" length="middle" rot="R180"/>
<pin name="PHASE" x="30.48" y="-12.7" length="middle" rot="R180"/>
<pin name="5V_REG" x="30.48" y="2.54" length="middle" rot="R180"/>
<pin name="SR" x="30.48" y="-2.54" length="middle" rot="R180"/>
<pin name="PWML" x="30.48" y="-5.08" length="middle" rot="R180"/>
<pin name="PWMH" x="30.48" y="-7.62" length="middle" rot="R180"/>
<pin name="RESET" x="30.48" y="7.62" length="middle" rot="R180"/>
<pin name="FF1" x="30.48" y="12.7" length="middle" rot="R180"/>
<pin name="FF2" x="30.48" y="15.24" length="middle" rot="R180"/>
<pin name="RDEAD" x="-5.08" y="-38.1" length="middle" rot="R90"/>
<pin name="VDSTH" x="-10.16" y="-38.1" length="middle" rot="R90"/>
<wire x1="-15.24" y1="25.4" x2="25.4" y2="25.4" width="0.254" layer="94"/>
<wire x1="25.4" y1="25.4" x2="25.4" y2="-33.02" width="0.254" layer="94"/>
<wire x1="25.4" y1="-33.02" x2="-15.24" y2="-33.02" width="0.254" layer="94"/>
<wire x1="-15.24" y1="-33.02" x2="-15.24" y2="25.4" width="0.254" layer="94"/>
<text x="-2.54" y="10.16" size="1.778" layer="94">&gt;NAME</text>
<text x="-2.54" y="5.08" size="1.778" layer="94">&gt;VALUE</text>
</symbol>
<symbol name="IRF8734">
<pin name="D" x="2.54" y="10.16" length="middle" rot="R270"/>
<pin name="S" x="2.54" y="-10.16" length="middle" rot="R90"/>
<pin name="G" x="-7.62" y="0" length="middle"/>
<wire x1="2.54" y1="2.54" x2="0" y2="2.54" width="0.254" layer="94"/>
<wire x1="0" y1="2.54" x2="0" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0" y1="-2.54" x2="2.54" y2="-2.54" width="0.254" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="2.54" y2="-5.08" width="0.254" layer="94"/>
<wire x1="2.54" y1="2.54" x2="2.54" y2="5.08" width="0.254" layer="94"/>
<wire x1="-2.54" y1="2.54" x2="-2.54" y2="-2.54" width="0.254" layer="94"/>
<text x="-10.16" y="12.7" size="1.778" layer="94">&gt;NAME</text>
<text x="-10.16" y="7.62" size="1.778" layer="94">&gt;VALUE</text>
<circle x="0" y="0" radius="5.6796125" width="0.254" layer="94"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="A3941KLPTR">
<gates>
<gate name="G$1" symbol="A3941" x="0" y="0"/>
</gates>
<devices>
<device name="" package="TSSOP28">
<connects>
<connect gate="G$1" pin="5V_REG" pad="20"/>
<connect gate="G$1" pin="CA" pad="9"/>
<connect gate="G$1" pin="CB" pad="6"/>
<connect gate="G$1" pin="CP1" pad="16"/>
<connect gate="G$1" pin="CP2" pad="15"/>
<connect gate="G$1" pin="FF1" pad="25"/>
<connect gate="G$1" pin="FF2" pad="26"/>
<connect gate="G$1" pin="GHA" pad="10"/>
<connect gate="G$1" pin="GHB" pad="5"/>
<connect gate="G$1" pin="GLA" pad="12"/>
<connect gate="G$1" pin="GLB" pad="3"/>
<connect gate="G$1" pin="GND" pad="17"/>
<connect gate="G$1" pin="GND2" pad="18"/>
<connect gate="G$1" pin="LSS" pad="2"/>
<connect gate="G$1" pin="PHASE" pad="19"/>
<connect gate="G$1" pin="PWMH" pad="23"/>
<connect gate="G$1" pin="PWML" pad="22"/>
<connect gate="G$1" pin="RDEAD" pad="27"/>
<connect gate="G$1" pin="RESET" pad="24"/>
<connect gate="G$1" pin="SA" pad="11"/>
<connect gate="G$1" pin="SB" pad="4"/>
<connect gate="G$1" pin="SR" pad="21"/>
<connect gate="G$1" pin="VBB" pad="13"/>
<connect gate="G$1" pin="VBB2" pad="14"/>
<connect gate="G$1" pin="VDRAIN" pad="1"/>
<connect gate="G$1" pin="VDSTH" pad="28"/>
<connect gate="G$1" pin="VREG" pad="7"/>
<connect gate="G$1" pin="VREG2" pad="8"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="IRF8734">
<gates>
<gate name="G$1" symbol="IRF8734" x="-2.54" y="0"/>
</gates>
<devices>
<device name="" package="SO08">
<connects>
<connect gate="G$1" pin="D" pad="5 6 7 8"/>
<connect gate="G$1" pin="G" pad="4"/>
<connect gate="G$1" pin="S" pad="1 2 3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
