  list      p=16f628A    
	      #include <p16F628A.inc>
	ERRORLEVEL -302	; disable warning (Bankswitching)
	__CONFIG   _CP_OFF & _DATA_CP_OFF & _LVP_OFF & _BOREN_OFF & _MCLRE_ON & _WDT_OFF & _PWRTE_ON & _XT_OSC
	ORG 0000
	movlw   0x07
	movwf   CMCON
	goto    __main
 	ORG 0004
 	ORG 0004
__interrupt: ; 0004
__main: ; 0004
; var H'00C:000'  transfer_bit
; var H'00D:000'  transfer_byte
;; 043 : var volatile byte port_b       at  6
; var H'006:000' port_b
;; 093 : var volatile bit  pin_b0 at port_b : 0
; var H'006:000' pin_b0
;; 094 : var volatile bit  pin_b1 at port_b : 1
; var H'006:001' pin_b1
;; 095 : var volatile bit  pin_b2 at port_b : 2
; var H'006:002' pin_b2
;; 096 : var volatile bit  pin_b3 at port_b : 3
; var H'006:003' pin_b3
;; 097 : var volatile bit  pin_b4 at port_b : 4
; var H'006:004' pin_b4
;; 098 : var volatile bit  pin_b5 at port_b : 5
; var H'006:005' pin_b5
;; 099 : var volatile bit  pin_b6 at port_b : 6
; var H'006:006' pin_b6
;; 100 : var volatile bit  pin_b7 at port_b : 7
; var H'006:007' pin_b7
;; 276 : var byte trisa
; var H'00E:000' trisa
;; 277 : var byte trisb
; var H'00F:000' trisb
;; 284 : trisa = all_input
  	movlw   H'FF'
  	movwf   H'2E'
;; 286 :    trisb = all_input
  	movlw   H'FF'
  	movwf   H'2F'
;; 580 : var byte _port_a_buffer
; var H'010:000' _port_a_buffer
;; 581 : var byte _port_b_buffer
; var H'011:000' _port_b_buffer
;; 022 : port_a_direction = all_output 
  	movlw   H'00'
  	call    _2894__vector
;; 023 : pin_b0_direction = output 
  	bcf     H'2F',0
  	call    _3343__vector
;; 024 : pin_b1_direction = output
  	bcf     H'2F',1
  	call    _3372__vector
;; 025 : pin_b2_direction = output 
  	bcf     H'2F',2
  	call    _3401__vector
;; 026 : pin_b3_direction = output 
  	bcf     H'2F',3
  	call    _3430__vector
;; 027 : pin_b4_direction = output 
  	bcf     H'2F',4
  	call    _3459__vector
;; 028 : pin_b5_direction = input 
  	bsf     H'2F',5
  	call    _3488__vector
;; 029 : pin_b6_direction = input 
  	bsf     H'2F',6
  	call    _3517__vector
;; 030 : pin_b7_direction = input 
  	bsf     H'2F',7
  	call    _3546__vector
;; 137 : var byte steps  = 0b_01101   -- StepTab[0] := 13; { binary 01101 }
; var H'012:000' steps
  	movlw   H'2D'
  	movwf   H'32'
;; 138 : var bit state_prev = high    -- Step pulse logic-hi
; var H'00C:001' state_prev
  	bsf     H'2C',1
;; 140 : forever loop
w_8227_ag: ; 001D
;; 143 :    if pin_b7 then
  	btfss   H'06',7
  	goto    if_8096_by
if_8096_th: ; 001F
;; 144 :          run_stepper(0b_00000)            -- Stepper motor Disable (cutt off power)
  	movlw   H'00'
  	call    _7679__vector
;; 145 :          pin_a0 = pin_b0
  	bcf     H'30',0
  	btfsc   H'06',0
ass_8393_t: ; 0023
  	bsf     H'30',0
ass_8393_f: ; 0024
  	call    _5910__vector
;; 146 :          pin_a1 = pin_b1
  	bcf     H'30',1
  	btfsc   H'06',1
ass_8399_t: ; 0027
  	bsf     H'30',1
ass_8399_f: ; 0028
  	call    _5939__vector
;; 147 :          pin_a2 = pin_b2
  	bcf     H'30',2
  	btfsc   H'06',2
ass_8405_t: ; 002B
  	bsf     H'30',2
ass_8405_f: ; 002C
  	call    _5968__vector
;; 148 :          pin_a3 = pin_b3
  	bcf     H'30',3
  	btfsc   H'06',3
ass_8411_t: ; 002F
  	bsf     H'30',3
ass_8411_f: ; 0030
  	call    _5997__vector
;; 149 :          pin_a4 = pin_b4
  	bcf     H'30',4
  	btfsc   H'06',4
ass_8417_t: ; 0033
  	bsf     H'30',4
ass_8417_f: ; 0034
  	call    _6026__vector
if_8096_by: ; 0035
;; 151 :    if ! pin_b7 then                       -- Stepper Enable (lo-logic)
  	btfsc   H'06',7
  	goto    if_8133_by
if_8133_th: ; 0037
;; 152 :       if (! pin_b5) & state_prev then     -- Step pulse detect (lo-logic)
  	btfsc   H'06',5
  	goto    if_8137_by
e_8140: ; 0039
  	btfss   H'2C',1
  	goto    if_8137_by
if_8137_th: ; 003B
;; 153 :          state_prev = low
  	bcf     H'2C',1
;; 154 :          if pin_b6 then                   -- Direction forward (hi-logic)
  	btfss   H'06',6
  	goto    if_8148_by
if_8148_th: ; 003E
;; 155 :             stepper_motor_forward( steps )
  	movf    H'32',w
  	call    _7702__vector
  	movf    H'33',w
  	movwf   H'32'
if_8148_by: ; 0042
;; 157 :          if ! pin_b6 then                 -- Direction backward (lo-logic)
  	btfsc   H'06',6
  	goto    if_8166_by
if_8166_th: ; 0044
;; 158 :             stepper_motor_backward( steps )
  	movf    H'32',w
  	call    _7889__vector
  	movf    H'33',w
  	movwf   H'32'
if_8166_by: ; 0048
;; 160 :          run_stepper( steps )
  	movf    H'32',w
  	call    _7679__vector
;; 164 :          pin_a0 = pin_b0
  	bcf     H'30',0
  	btfsc   H'06',0
ass_8423_t: ; 004C
  	bsf     H'30',0
ass_8423_f: ; 004D
  	call    _5910__vector
;; 165 :          pin_a1 = pin_b1
  	bcf     H'30',1
  	btfsc   H'06',1
ass_8429_t: ; 0050
  	bsf     H'30',1
ass_8429_f: ; 0051
  	call    _5939__vector
;; 166 :          pin_a2 = pin_b2
  	bcf     H'30',2
  	btfsc   H'06',2
ass_8435_t: ; 0054
  	bsf     H'30',2
ass_8435_f: ; 0055
  	call    _5968__vector
;; 167 :          pin_a3 = pin_b3
  	bcf     H'30',3
  	btfsc   H'06',3
ass_8441_t: ; 0058
  	bsf     H'30',3
ass_8441_f: ; 0059
  	call    _5997__vector
;; 168 :          pin_a4 = pin_b4
  	bcf     H'30',4
  	btfsc   H'06',4
ass_8447_t: ; 005C
  	bsf     H'30',4
ass_8447_f: ; 005D
  	call    _6026__vector
if_8137_by: ; 005E
;; 170 :       if pin_b5 then state_prev = high    -- Clear step pulse (1 cycle pulse)
  	btfsc   H'06',5
if_8217_th: ; 005F
  	bsf     H'2C',1
if_8217_by: ; 0060
if_8133_by: ; 0060
  	goto    w_8227_ag
;; 003 :   idle_loop: page goto idle_loop
as_8230_idle_loop: ; 0061
  	goto    as_8230_idle_loop
_7889__vector: ; 0062
;; 091 : procedure stepper_motor_backward( byte in out x ) is
; var H'013:000' x
p_7889_stepper_motor_backward: ; 0062
  	movwf   H'33'
;; 092 :    x = x & 0b_11111
  	movlw   H'3F'
  	andwf   H'33',f
;; 093 :    if x == 0b_00101 then     -- StepTab[9] := 5;  { binary 00101 }
  	movf    H'33',w
  	sublw   H'05'
  	btfss   H'03',2
  	goto    if_7911_by
if_7911_th: ; 0069
;; 094 :       x = 0b_10101
  	movlw   H'35'
  	movwf   H'33'
;; 096 :    end if
  goto    e_7889_stepper_motor_backward
if_7911_by: ; 006C
;; 097 :    if x == 0b_10101 then     -- StepTab[8] := 21; { binary 10101 }
  	movf    H'33',w
  	sublw   H'35'
  	btfss   H'03',2
  	goto    if_7927_by
if_7927_th: ; 0070
;; 098 :       x = 0b_10100
  	movlw   H'34'
  	movwf   H'33'
;; 100 :    end if
if_7927_by: ; 0073
;; 101 :    if x == 0b_10100 then     -- StepTab[7] := 20; { binary 10100 }
  	movf    H'33',w
  	sublw   H'34'
  	btfss   H'03',2
  	goto    if_7943_by
if_7943_th: ; 0077
;; 102 :       x = 0b_10110
  	movlw   H'36'
  	movwf   H'33'
;; 104 :    end if
if_7943_by: ; 007A
;; 105 :    if x == 0b_10110 then     -- StepTab[6] := 22; { binary 10110 }
  	movf    H'33',w
  	sublw   H'36'
  	btfss   H'03',2
  	goto    if_7959_by
if_7959_th: ; 007E
;; 106 :       x = 0b_10010
  	movlw   H'32'
  	movwf   H'33'
;; 108 :    end if
if_7959_by: ; 0081
;; 109 :    if x == 0b_10010 then     -- StepTab[5] := 18; { binary 10010 }
  	movf    H'33',w
  	sublw   H'32'
  	btfss   H'03',2
  	goto    if_7975_by
if_7975_th: ; 0085
;; 110 :       x = 0b_11010
  	movlw   H'3A'
  	movwf   H'33'
;; 112 :    end if
if_7975_by: ; 0088
;; 113 :    if x == 0b_11010 then     -- StepTab[4] := 26; { binary 11010 }
  	movf    H'33',w
  	sublw   H'3A'
  	btfss   H'03',2
  	goto    if_7991_by
if_7991_th: ; 008C
;; 114 :       x = 0b_01010
  	movlw   H'0A'
  	movwf   H'33'
;; 116 :    end if
if_7991_by: ; 008F
;; 117 :    if x == 0b_01010 then     -- StepTab[3] := 10; { binary 01010 }
  	movf    H'33',w
  	sublw   H'0A'
  	btfss   H'03',2
  	goto    if_8007_by
if_8007_th: ; 0093
;; 118 :       x = 0b_01011
  	movlw   H'0B'
  	movwf   H'33'
;; 120 :    end if
if_8007_by: ; 0096
;; 121 :    if x == 0b_01011 then     -- StepTab[2] := 11; { binary 01011 }
  	movf    H'33',w
  	sublw   H'0B'
  	btfss   H'03',2
  	goto    if_8023_by
if_8023_th: ; 009A
;; 122 :       x = 0b_01001
  	movlw   H'09'
  	movwf   H'33'
;; 124 :    end if
if_8023_by: ; 009D
;; 125 :    if x == 0b_01001 then     -- StepTab[1] := 9;  { binary 01001 }
  	movf    H'33',w
  	sublw   H'09'
  	btfss   H'03',2
  	goto    if_8039_by
if_8039_th: ; 00A1
;; 126 :       x = 0b_01101
  	movlw   H'2D'
  	movwf   H'33'
;; 128 :    end if
if_8039_by: ; 00A4
;; 129 :    if x == 0b_01101 then     -- StepTab[0] := 13; { binary 01101 }
  	movf    H'33',w
  	sublw   H'2D'
  	btfss   H'03',2
  	goto    if_8055_by
if_8055_th: ; 00A8
;; 130 :       x = 0b_00101           -- StepTab[9] := 5;  { binary 00101 }
  	movlw   H'05'
  	movwf   H'33'
;; 132 :    end if
if_8055_by: ; 00AB
e_7889_stepper_motor_backward: ; 00AB
  	return  
_7702__vector: ; 00AC
;; 047 : procedure stepper_motor_forward( byte in out x ) is
; var H'013:000' x
p_7702_stepper_motor_forward: ; 00AC
  	movwf   H'33'
;; 048 :    x = x & 0b_11111
  	movlw   H'3F'
  	andwf   H'33',f
;; 049 :    if x == 0b_01101 then     -- StepTab[0] := 13; { binary 01101 }
  	movf    H'33',w
  	sublw   H'2D'
  	btfss   H'03',2
  	goto    if_7724_by
if_7724_th: ; 00B3
;; 050 :       x = 0b_01001
  	movlw   H'09'
  	movwf   H'33'
;; 052 :    end if
  	goto    e_7702_stepper_motor_forward
if_7724_by: ; 00B6
;; 053 :    if x == 0b_01001 then     -- StepTab[1] := 9;  { binary 01001 }
  	movf    H'33',w
  	sublw   H'09'
  	btfss   H'03',2
  	goto    if_7740_by
if_7740_th: ; 00BA
;; 054 :       x = 0b_01011
  	movlw   H'0B'
  	movwf   H'33'
;; 056 :    end if
if_7740_by: ; 00BD
;; 057 :    if x == 0b_01011 then     -- StepTab[2] := 11; { binary 01011 }
  	movf    H'33',w
  	sublw   H'0B'
  	btfss   H'03',2
  	goto    if_7756_by
if_7756_th: ; 00C1
;; 058 :       x = 0b_01010
  	movlw   H'0A'
  	movwf   H'33'
;; 060 :    end if
if_7756_by: ; 00C4
;; 061 :    if x == 0b_01010 then     -- StepTab[3] := 10; { binary 01010 }
  	movf    H'33',w
  	sublw   H'0A'
  	btfss   H'03',2
  	goto    if_7772_by
if_7772_th: ; 00C8
;; 062 :       x = 0b_11010
  	movlw   H'3A'
  	movwf   H'33'
;; 064 :    end if
if_7772_by: ; 00CB
;; 065 :    if x == 0b_11010 then     -- StepTab[4] := 26; { binary 11010 }
  	movf    H'33',w
  	sublw   H'3A'
  	btfss   H'03',2
  	goto    if_7788_by
if_7788_th: ; 00CF
;; 066 :       x = 0b_10010
  	movlw   H'32'
  	movwf   H'33'
;; 068 :    end if
if_7788_by: ; 00D2
;; 069 :    if x == 0b_10010 then     -- StepTab[5] := 18; { binary 10010 }
  	movf    H'33',w
  	sublw   H'32'
  	btfss   H'03',2
  	goto    if_7804_by
if_7804_th: ; 00D6
;; 070 :       x = 0b_10110
  	movlw   H'36'
  	movwf   H'33'
;; 072 :    end if
if_7804_by: ; 00D9
;; 073 :    if x == 0b_10110 then     -- StepTab[6] := 22; { binary 10110 }
  	movf    H'33',w
  	sublw   H'36'
  	btfss   H'03',2
  	goto    if_7820_by
if_7820_th: ; 00DD
;; 074 :       x = 0b_10100
  	movlw   H'34'
  	movwf   H'33'
;; 076 :    end if
if_7820_by: ; 00E0
;; 077 :    if x == 0b_10100 then     -- StepTab[7] := 20; { binary 10100 }
 	movf    H'33',w
 	sublw   H'34'
  	btfss   H'03',2
  	goto    if_7836_by
if_7836_th: ; 00E4
;; 078 :       x = 0b_10101
  	movlw   H'35'
  	movwf   H'33'
;; 080 :    end if
if_7836_by: ; 00E7
;; 081 :    if x == 0b_10101 then     -- StepTab[8] := 21; { binary 10101 }
  	movf    H'33',w
  	sublw   H'35'
  	btfss   H'03',2
  	goto    if_7852_by
if_7852_th: ; 00EB
;; 082 :       x = 0b_00101
  	movlw   H'05'
  	movwf   H'33'
;; 084 :    end if
if_7852_by: ; 00EE
;; 085 :    if x == 0b_00101 then     -- StepTab[9] := 5;  { binary 00101 }
  	movf    H'33',w
  	sublw   H'05'
  	btfss   H'03',2
  	goto    if_7868_by
if_7868_th: ; 00F2
;; 086 :       x = 0b_01101           -- StepTab[0] := 13; { binary 01101 }
  	movlw   H'2D'
  	movwf   H'33'
;; 088 :    end if
if_7868_by: ; 00F5
e_7702_stepper_motor_forward: ; 00F5
  	return  
_7679__vector: ; 00F6
;; 042 : procedure run_stepper( byte in a ) is
; var H'013:000' a
p_7679_run_stepper: ; 00F6
  	movwf   H'33'
;; 043 :    port_b = a
  	movf    H'33',w
  	goto    _5202__vector
e_7679_run_stepper: ; 00F9
;; 694 : procedure pin_a4'put( bit in x at _port_a_buffer : 4 ) is
p_6026__pin_a4__put_t: ; 00F9
_6026__vector: ; 00F9
; var H'010:004' x
p_6026_put: ; 00F9
;; 695 :    _port_a_flush
  	goto    _5056__vector
e_6026_put: ; 00FA
;; 691 : procedure pin_a3'put( bit in x at _port_a_buffer : 3 ) is
p_5997__pin_a3__put_t: ; 00FA
_5997__vector: ; 00FA
; var H'010:003' x
p_5997_put: ; 00FA
;; 692 :    _port_a_flush
  	goto    _5056__vector
e_5997_put: ; 00FB
;; 688 : procedure pin_a2'put( bit in x at _port_a_buffer : 2 ) is
p_5968__pin_a2__put_t: ; 00FB
_5968__vector: ; 00FB
; var H'010:002' x
p_5968_put: ; 00FB
;; 689 :    _port_a_flush
  	goto    _5056__vector
e_5968_put: ; 00FC
;; 685 : procedure pin_a1'put( bit in x at _port_a_buffer : 1 ) is
p_5939__pin_a1__put_t: ; 00FC
_5939__vector: ; 00FC
; var H'010:001' x
p_5939_put: ; 00FC
;; 686 :    _port_a_flush
  	goto    _5056__vector
e_5939_put: ; 00FD
;; 682 : procedure pin_a0'put( bit in x at _port_a_buffer : 0 ) is
p_5910__pin_a0__put_t: ; 00FD
_5910__vector: ; 00FD
; var H'010:000' x
p_5910_put: ; 00FD
;; 683 :    _port_a_flush
  	goto    _5056__vector
e_5910_put: ; 00FE
;; 605 : procedure port_b'put( byte in x at _port_b_buffer ) is
p_5202__port_b__put_t: ; 00FE
_5202__vector: ; 00FE
; var H'011:000' x
p_5202_put: ; 00FE
  	movwf   H'31'
;; 606 :    _port_b_flush
  	goto    _5079__vector
e_5202_put: ; 0100
_5079__vector: ; 0100
p_5079__port_b_flush: ; 0100
;; 590 :    var volatile byte port_b at 6 = _port_b_buffer
  	movf    H'31',w
  	movwf   H'06'
e_5079__port_b_flush: ; 0102
  	return  
_5056__vector: ; 0103
p_5056__port_a_flush: ; 0103
;; 587 :    var volatile byte port_a at 5 = _port_a_buffer
; var H'005:000' port_a
  	movf    H'30',w
  	movwf   H'05'
e_5056__port_a_flush: ; 0105
  	return  
;; 410 : procedure pin_b7_direction'put( bit in d at trisb : 7 ) is
p_3546__pin_b7_direction__put_t: ; 0106
_3546__vector: ; 0106
; var H'00F:007' d
p_3546_put: ; 0106
;; 411 :    _trisb_flush
  	goto    _2785__vector
e_3546_put: ; 0107
;; 407 : procedure pin_b6_direction'put( bit in d at trisb : 6 ) is
p_3517__pin_b6_direction__put_t: ; 0107
_3517__vector: ; 0107
; var H'00F:006' d
p_3517_put: ; 0107
;; 408 :    _trisb_flush
  	goto    _2785__vector
e_3517_put: ; 0108
;; 404 : procedure pin_b5_direction'put( bit in d at trisb : 5 ) is
p_3488__pin_b5_direction__put_t: ; 0108
_3488__vector: ; 0108
; var H'00F:005' d
p_3488_put: ; 0108
;; 405 :    _trisb_flush
  	goto    _2785__vector
e_3488_put: ; 0109
;; 401 : procedure pin_b4_direction'put( bit in d at trisb : 4 ) is
p_3459__pin_b4_direction__put_t: ; 0109
_3459__vector: ; 0109
; var H'00F:004' d
p_3459_put: ; 0109
;; 402 :    _trisb_flush
  	goto    _2785__vector
e_3459_put: ; 010A
;; 398 : procedure pin_b3_direction'put( bit in d at trisb : 3 ) is
p_3430__pin_b3_direction__put_t: ; 010A
_3430__vector: ; 010A
; var H'00F:003' d
p_3430_put: ; 010A
;; 399 :    _trisb_flush
  	goto    _2785__vector
e_3430_put: ; 010B
;; 395 : procedure pin_b2_direction'put( bit in d at trisb : 2 ) is
p_3401__pin_b2_direction__put_t: ; 010B
_3401__vector: ; 010B
; var H'00F:002' d
p_3401_put: ; 010B
;; 396 :    _trisb_flush
  	goto    _2785__vector
e_3401_put: ; 010C
;; 392 : procedure pin_b1_direction'put( bit in d at trisb : 1 ) is
p_3372__pin_b1_direction__put_t: ; 010C
_3372__vector: ; 010C
; var H'00F:001' d
p_3372_put: ; 010C
;; 393 :    _trisb_flush
  	goto    _2785__vector
e_3372_put: ; 010D
;; 389 : procedure pin_b0_direction'put( bit in d at trisb : 0 ) is
p_3343__pin_b0_direction__put_t: ; 010D
_3343__vector: ; 010D
; var H'00F:000' d
p_3343_put: ; 010D
;; 390 :    _trisb_flush
  	goto    _2785__vector
e_3343_put: ; 010E
;; 332 : procedure port_a_direction'put( byte in x at trisa ) is
p_2894__port_a_direction__put_t: ; 010E
_2894__vector: ; 010E
; var H'00E:000' x
p_2894_put: ; 010E
  	movwf   H'2E'
;; 333 :    _trisa_flush
  	goto    _2764__vector
e_2894_put: ; 0110
_2785__vector: ; 0110
p_2785__trisb_flush: ; 0110
;; 305 :       bank movfw trisb
  	movf    H'2F',w
;; 306 :            tris  6
  	tris    H'06'
e_2785__trisb_flush: ; 0112
  	return  
_2764__vector: ; 0113
p_2764__trisa_flush: ; 0113
;; 298 :       bank movfw trisa
  	movf    H'2E',w
;; 299 :            tris  5
  	tris    H'05'
e_2764__trisa_flush: ; 0115
  	return  
 	END
; ********** variable mapping
; 05:0 : ;
;   port_a                         * 0587:22 jpic.jal 
; 06:0 : ;
;   port_b                         * 0590:22 jpic.jal 
;   pin_b0                         * 0093:19 jpic.jal 
;   port_b                         * 0043:19 jpic.jal 
; 06:1 : ;
;   pin_b1                         * 0094:19 jpic.jal 
; 06:2 : ;
;   pin_b2                         * 0095:19 jpic.jal 
; 06:3 : ;
;   pin_b3                         * 0096:19 jpic.jal 
; 06:4 : ;
;   pin_b4                         * 0097:19 jpic.jal 
; 06:5 : ;
;   pin_b5                         * 0098:19 jpic.jal 
; 06:6 : ;
;   pin_b6                         * 0099:19 jpic.jal 
; 06:7 : ;
;   pin_b7                         * 0100:19 jpic.jal 
; 0C:0 : ;
;    transfer_bit                    
; 0C:1 : ;
;   state_prev                       0138:09 5-phase_final.jal 
; 0D:0 : ;
;    transfer_byte                   
; 0E:0 : ;
;   x                              * 0332:33 jpic.jal 
;   trisa                            0276:10 jpic.jal 
; 0F:0 : ;
;   d                              * 0389:33 jpic.jal 
;   trisb                            0277:10 jpic.jal 
; 0F:1 : ;
;   d                              * 0392:33 jpic.jal 
; 0F:2 : ;
;   d                              * 0395:33 jpic.jal 
; 0F:3 : ;
;   d                              * 0398:33 jpic.jal 
; 0F:4 : ;
;   d                              * 0401:33 jpic.jal 
; 0F:5 : ;
;   d                              * 0404:33 jpic.jal 
; 0F:6 : ;
;   d                              * 0407:33 jpic.jal 
; 0F:7 : ;
;   d                              * 0410:33 jpic.jal 
; 10:0 : ;
;   x                              * 0682:23 jpic.jal 
;   _port_a_buffer                   0580:10 jpic.jal 
; 10:1 : ;
;   x                              * 0685:23 jpic.jal 
; 10:2 : ;
;   x                              * 0688:23 jpic.jal 
; 10:3 : ;
;   x                              * 0691:23 jpic.jal 
; 10:4 : ;
;   x                              * 0694:23 jpic.jal 
; 11:0 : ;
;   x                              * 0605:23 jpic.jal 
;   _port_b_buffer                   0581:10 jpic.jal 
; 12:0 : ;
;   steps                            0137:10 5-phase_final.jal 
; 13:0 : ;
;   a                                0042:24 5-phase_final.jal 
;   x                                0047:34 5-phase_final.jal 
;   x                                0091:35 5-phase_final.jal 
