# Changes the layer colors # # This script defines the colors and the fill styles of all layers. # The 'Set Used_Layers' command determins which layers can be # selected from the DISPLAY menu. SET COLOR_LAYER 1 15; SET COLOR_LAYER 2 1; SET COLOR_LAYER 3 4; SET COLOR_LAYER 4 1; SET COLOR_LAYER 5 4; SET COLOR_LAYER 6 1; SET COLOR_LAYER 7 4; SET COLOR_LAYER 8 1; SET COLOR_LAYER 9 4; SET COLOR_LAYER 10 1; SET COLOR_LAYER 11 4; SET COLOR_LAYER 12 1; SET COLOR_LAYER 13 4; SET COLOR_LAYER 14 1; SET COLOR_LAYER 15 4; SET COLOR_LAYER 16 1; SET COLOR_LAYER 17 15; SET COLOR_LAYER 18 15; SET COLOR_LAYER 19 6; SET COLOR_LAYER 20 15; SET COLOR_LAYER 21 7; SET COLOR_LAYER 22 7; SET COLOR_LAYER 23 15; SET COLOR_LAYER 24 15; SET COLOR_LAYER 25 7; SET COLOR_LAYER 26 7; SET COLOR_LAYER 27 7; SET COLOR_LAYER 28 7; SET COLOR_LAYER 29 7; SET COLOR_LAYER 30 7; SET COLOR_LAYER 31 7; SET COLOR_LAYER 32 7; SET COLOR_LAYER 33 6; SET COLOR_LAYER 34 6; SET COLOR_LAYER 35 7; SET COLOR_LAYER 36 7; SET COLOR_LAYER 37 7; SET COLOR_LAYER 38 7; SET COLOR_LAYER 39 4; SET COLOR_LAYER 40 1; SET COLOR_LAYER 41 4; SET COLOR_LAYER 42 1; SET COLOR_LAYER 43 2; SET COLOR_LAYER 44 7; SET COLOR_LAYER 45 7; SET COLOR_LAYER 46 3; SET COLOR_LAYER 47 7; SET COLOR_LAYER 48 7; SET COLOR_LAYER 49 7; SET COLOR_LAYER 50 7; SET COLOR_LAYER 51 7; SET COLOR_LAYER 52 7; SET COLOR_LAYER 53 7; SET COLOR_LAYER 91 2; SET COLOR_LAYER 92 1; SET COLOR_LAYER 93 2; SET COLOR_LAYER 94 4; SET COLOR_LAYER 95 7; SET COLOR_LAYER 96 7; #SET FILL_LAYER layer fill; SET FILL_LAYER 1 1; SET FILL_LAYER 2 3; SET FILL_LAYER 3 3; SET FILL_LAYER 4 4; SET FILL_LAYER 5 4; SET FILL_LAYER 6 8; SET FILL_LAYER 7 8; SET FILL_LAYER 8 2; SET FILL_LAYER 9 2; SET FILL_LAYER 10 7; SET FILL_LAYER 11 7; SET FILL_LAYER 12 5; SET FILL_LAYER 13 5; SET FILL_LAYER 14 6; SET FILL_LAYER 15 6; SET FILL_LAYER 16 1; SET FILL_LAYER 17 1; SET FILL_LAYER 18 1; SET FILL_LAYER 19 1; SET FILL_LAYER 20 1; SET FILL_LAYER 21 1; SET FILL_LAYER 22 1; SET FILL_LAYER 23 1; SET FILL_LAYER 24 1; SET FILL_LAYER 25 1; SET FILL_LAYER 26 1; SET FILL_LAYER 27 1; SET FILL_LAYER 28 1; SET FILL_LAYER 29 3; SET FILL_LAYER 30 6; SET FILL_LAYER 31 4; SET FILL_LAYER 32 5; SET FILL_LAYER 33 3; SET FILL_LAYER 34 6; SET FILL_LAYER 35 4; SET FILL_LAYER 36 5; SET FILL_LAYER 37 1; SET FILL_LAYER 38 1; SET FILL_LAYER 39 11; SET FILL_LAYER 40 11; SET FILL_LAYER 41 10; SET FILL_LAYER 42 10; SET FILL_LAYER 43 10; SET FILL_LAYER 44 1; SET FILL_LAYER 45 1; SET FILL_LAYER 46 1; SET FILL_LAYER 47 1; SET FILL_LAYER 48 1; SET FILL_LAYER 49 1; SET FILL_LAYER 50 1; SET FILL_LAYER 51 1; SET FILL_LAYER 52 1; SET FILL_LAYER 91 1; SET FILL_LAYER 92 1; SET FILL_LAYER 93 1; SET FILL_LAYER 94 1; SET FILL_LAYER 95 1; SET FILL_LAYER 96 1; Set Used_Layers 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 \ 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 \ 47 48 49 50 51 52 91 92 93 94 95 96; DISPLAY NONE 1 17 18 20; GRID DEFAULT MM; WINDOW FIT;
