<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.003125" unitdist="mic" unit="mm" style="lines" multiple="1" display="yes" altdistance="0.025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="yes" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="199" name="Contour" color="7" fill="1" visible="no" active="yes"/>
</layers>
<board>
<plain>
<wire x1="0" y1="0" x2="236.887828125" y2="-0.052071875" width="0" layer="20"/>
<wire x1="236.887828125" y1="-0.052071875" x2="236.887828125" y2="99.947928125" width="0" layer="20"/>
<wire x1="236.887828125" y1="99.947928125" x2="0" y2="100" width="0" layer="20"/>
<wire x1="0" y1="100" x2="0" y2="0" width="0" layer="20"/>
<wire x1="224.975140625" y1="100.0208875" x2="225.184596875" y2="100.0208875" width="0.4064" layer="47"/>
<wire x1="225.184596875" y1="100.0208875" x2="225.184596875" y2="-0.26186875" width="0.4064" layer="47"/>
<circle x="55.848075" y="45.820228125" radius="0.375240625" width="6.4516" layer="16"/>
</plain>
<libraries>
<library name="rectifier">
<description>&lt;b&gt;Rectifiers&lt;/b&gt;&lt;p&gt;
General Instrument, Semikron, Diotec, Fagor&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="GBU4S">
<description>&lt;b&gt;GENERAL INSTRUMENT RECTIFIER&lt;/b&gt;</description>
<wire x1="-11.43" y1="-1.27" x2="-11.43" y2="2.54" width="0.1524" layer="21"/>
<wire x1="11.43" y1="2.54" x2="11.43" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="2.54" x2="6.35" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.35" y1="2.54" x2="11.43" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.16" y1="1.905" x2="10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="9.525" y1="1.27" x2="10.795" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="1.27" x2="-9.525" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-5.0546" y1="1.27" x2="-4.3942" y2="1.27" width="0.1524" layer="21" curve="180"/>
<wire x1="-5.715" y1="1.27" x2="-5.0546" y2="1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="0.0254" y1="1.27" x2="0.6858" y2="1.27" width="0.1524" layer="21" curve="180"/>
<wire x1="-0.635" y1="1.27" x2="0.0254" y2="1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="11.43" y1="-1.27" x2="8.89" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-1.27" x2="6.35" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="3.81" y1="-1.27" x2="6.35" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.27" x2="1.27" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="-1.27" x2="1.27" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.27" x2="-3.81" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-6.35" y1="-1.27" x2="-3.81" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="6.35" y1="2.54" x2="6.35" y2="1.27" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-1.27" x2="6.35" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-6.35" y1="-1.27" x2="-8.89" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-8.89" y1="-1.27" x2="-11.43" y2="-1.27" width="0.1524" layer="21"/>
<pad name="-" x="-7.62" y="0" drill="1" diameter="2.1844" shape="long" rot="R90"/>
<pad name="AC2" x="-2.54" y="0" drill="1" diameter="2.1844" shape="long" rot="R90"/>
<pad name="AC1" x="2.54" y="0" drill="1" diameter="2.1844" shape="long" rot="R90"/>
<pad name="+" x="7.62" y="0" drill="1" diameter="2.1844" shape="long" rot="R90"/>
<text x="-11.43" y="3.048" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="3.048" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-11.43" y1="-1.905" x2="11.43" y2="2.54" layer="43"/>
</package>
</packages>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="EB22,5D">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 10.16 mm, diameter 22.5 mm</description>
<wire x1="-2.54" y1="0" x2="-1.5748" y2="0" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="0" x2="-1.5748" y2="2.54" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="2.54" x2="-0.4318" y2="2.54" width="0.254" layer="21"/>
<wire x1="-0.4318" y1="2.54" x2="-0.4318" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-0.4318" y1="-2.54" x2="-1.5748" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="-2.54" x2="-1.5748" y2="0" width="0.254" layer="21"/>
<wire x1="0.635" y1="0" x2="2.54" y2="0" width="0.254" layer="21"/>
<wire x1="-2.794" y1="2.54" x2="-2.794" y2="1.27" width="0.254" layer="21"/>
<wire x1="-2.159" y1="1.905" x2="-3.429" y2="1.905" width="0.254" layer="21"/>
<circle x="0" y="0" radius="8.89" width="0.254" layer="21"/>
<circle x="0" y="0" radius="11.303" width="0.1524" layer="21"/>
<pad name="+" x="-5.08" y="0" drill="1" diameter="4.5974"/>
<pad name="-" x="5.08" y="0" drill="1" diameter="4.5974" shape="octagon"/>
<text x="8.4074" y="8.509" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.3302" y1="-2.54" x2="1.6002" y2="2.54" layer="21"/>
</package>
<package name="E7,5-16">
grid 7.62 mm, diameter 16 mm</description>
<wire x1="0.635" y1="0" x2="2.032" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-2.032" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.905" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.905" x2="-0.254" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.905" x2="-0.254" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.905" x2="-0.889" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0" x2="-5.969" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-0.762" x2="-6.731" y2="0.762" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="8.255" width="0.1524" layer="21"/>
<pad name="-" x="3.81" y="0" drill="1.016" diameter="3.1496" shape="octagon"/>
<pad name="+" x="-3.81" y="0" drill="1.016" diameter="3.1496"/>
<text x="7.874" y="3.81" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.2926" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.905" x2="0.889" y2="1.905" layer="21"/>
</package>
<package name="C025-030X050">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 2.5 mm, outline 3 x 5 mm</description>
<wire x1="-2.159" y1="2.024" x2="2.159" y2="2.024" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.024" x2="-2.159" y2="-2.024" width="0.1524" layer="21"/>
<wire x1="2.913" y1="1.27" x2="2.913" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.913" y1="1.27" x2="-2.913" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.024" x2="2.913" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.913" y1="1.27" x2="-2.159" y2="2.024" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.024" x2="2.913" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.913" y1="-1.27" x2="-2.159" y2="-2.024" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-2" y="0" drill="1" diameter="1.8" shape="square"/>
<pad name="2" x="2" y="0" drill="1" diameter="1.8" shape="square"/>
<text x="-2.286" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-6E">
grid 2.54 mm, diameter 6 mm</description>
<wire x1="-2.159" y1="0" x2="-2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-0.254" x2="-2.413" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="2.794" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.5748" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.5748"/>
<text x="2.667" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.667" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="0207/10">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.24" y="0" drill="1" diameter="2.1844"/>
<pad name="2" x="5.24" y="0" drill="1" diameter="2.1844"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
<package name="E5-10,5">
grid 5.08 mm, diameter 10.5 mm</description>
<wire x1="-1.143" y1="0" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.143" x2="-0.254" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.143" x2="-0.254" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.143" x2="-0.889" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.143" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.651" x2="-3.81" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.27" x2="-4.191" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="0" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="1" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="1" diameter="2.54" shape="octagon"/>
<text x="4.699" y="2.7432" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.1242" y="-3.2258" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.889" y2="1.143" layer="21"/>
</package>
<package name="E2-5">
grid 2.032 mm, diameter 5 mm</description>
<wire x1="-1.524" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.016" x2="-0.254" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.016" x2="-0.254" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.016" x2="-0.762" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.016" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.524" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.778" x2="-0.762" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="1.524" x2="-1.016" y2="2.032" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<pad name="-" x="1.266" y="0" drill="1" diameter="1.6764" shape="octagon"/>
<pad name="+" x="-1.266" y="0" drill="1" diameter="1.778"/>
<text x="2.54" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.016" x2="0.762" y2="1.016" layer="51"/>
</package>
<package name="0922/22">
type 0922, grid 22.5 mm</description>
<wire x1="11.43" y1="0" x2="10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-11.43" y1="0" x2="-10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-10.16" y1="-4.191" x2="-10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="4.572" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.318" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="-4.572" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="-4.318" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="-8.636" y2="4.318" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="-8.636" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="9.779" y1="4.572" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="9.779" y1="-4.572" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.191" x2="-9.779" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-10.16" y1="4.191" x2="-9.779" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<wire x1="9.779" y1="-4.572" x2="10.16" y2="-4.191" width="0.1524" layer="21" curve="90"/>
<wire x1="9.779" y1="4.572" x2="10.16" y2="4.191" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-11.43" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="11.43" y="0" drill="1.016" shape="octagon"/>
<text x="-10.16" y="5.1054" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.477" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-10.7188" y1="-0.4064" x2="-10.16" y2="0.4064" layer="51"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-10.16" y2="0.4064" layer="21"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.7188" y2="0.4064" layer="51"/>
</package>
<package name="0207/15">
type 0207, grid 15mm</description>
<wire x1="15.62" y1="-1" x2="12.104" y2="-1" width="0.6096" layer="51"/>
<wire x1="-9.62" y1="-1" x2="-6.104" y2="-1" width="0.6096" layer="51"/>
<pad name="1" x="-9.62" y="-1" drill="1" diameter="3.81"/>
<pad name="2" x="15.62" y="-1" drill="1" diameter="3.81"/>
<text x="-3.675" y="0.897" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.214" y="0.8142" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<wire x1="-3" y1="-1" x2="0" y2="-1" width="0.127" layer="21" curve="198.924644"/>
<wire x1="0" y1="-1" x2="3" y2="-1" width="0.127" layer="21" curve="198.924644"/>
<wire x1="3" y1="-1" x2="6" y2="-1" width="0.127" layer="21" curve="198.924644"/>
<wire x1="6" y1="-1" x2="9" y2="-1" width="0.127" layer="21" curve="198.924644"/>
<wire x1="9" y1="-1" x2="12" y2="-1" width="0.127" layer="21" curve="198.924644"/>
<wire x1="-6" y1="-1" x2="-3" y2="-1" width="0.127" layer="21" curve="198.924644"/>
</package>
</packages>
</library>
<library name="pot">
<description>&lt;b&gt;Potentiometers&lt;/b&gt;&lt;p&gt;
Beckman, Copal, Piher, Spectrol, Schukat&lt;p&gt;
<packages>
<package name="3RP/1610N">
<description>&lt;b&gt;16mm Potentiometer&lt;/b&gt; one level&lt;p&gt;
Source: http://www.alphapotentiometers.net/html/16mm_pot_2.html</description>
<wire x1="-8.35" y1="-3.7" x2="8.35" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="-8.35" y1="-5.7" x2="-7.25" y2="-5.7" width="0.2032" layer="21"/>
<wire x1="-8.35" y1="-3.7" x2="-8.35" y2="-5.7" width="0.2032" layer="21"/>
<wire x1="-7.25" y1="-5.7" x2="-7.25" y2="-3.8" width="0.2032" layer="21"/>
<wire x1="-8.35" y1="-1.7" x2="8.35" y2="-1.7" width="0.2032" layer="21"/>
<wire x1="-8.35" y1="5.4" x2="8.35" y2="5.4" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="-10.2" x2="-2.9" y2="-13.7" width="0.2032" layer="21"/>
<wire x1="2.9" y1="-13.7" x2="2.9" y2="-10.2" width="0.2032" layer="21"/>
<wire x1="-3.4" y1="-3.8" x2="-3.4" y2="-9.9" width="0.2032" layer="21"/>
<wire x1="-3.4" y1="-9.9" x2="-2.9" y2="-10.2" width="0.2032" layer="21"/>
<wire x1="2.9" y1="-10.2" x2="3.4" y2="-9.9" width="0.2032" layer="21"/>
<wire x1="3.4" y1="-9.9" x2="3.4" y2="-3.8" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="-10.2" x2="2.9" y2="-10.2" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="-13.7" x2="2.9" y2="-13.7" width="0.2032" layer="21"/>
<wire x1="-8.35" y1="-3.7" x2="-8.35" y2="5.4" width="0.2032" layer="21"/>
<wire x1="8.35" y1="-3.7" x2="8.35" y2="5.4" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-9.525" x2="3.3" y2="-9" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-9.025" x2="3.3" y2="-8.5" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-8.525" x2="3.3" y2="-8" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-8.025" x2="3.3" y2="-7.5" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-7.525" x2="3.3" y2="-7" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-7.025" x2="3.3" y2="-6.5" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-6.525" x2="3.3" y2="-6" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-6.025" x2="3.3" y2="-5.5" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-5.525" x2="3.3" y2="-5" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-5.025" x2="3.3" y2="-4.5" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-4.525" x2="3.3" y2="-4" width="0.2032" layer="21"/>
<wire x1="-3.075" y1="-10.025" x2="3.3" y2="-9.5" width="0.2032" layer="21"/>
<pad name="1" x="-5" y="0" drill="1" diameter="3"/>
<pad name="2" x="0" y="0" drill="1" diameter="3"/>
<pad name="3" x="5" y="0" drill="1" diameter="3"/>
<text x="-8.255" y="5.715" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="3RP/1610G">
<description>&lt;b&gt;16mm Potentiometer&lt;/b&gt; two level&lt;p&gt;
<wire x1="-8.35" y1="-3.7" x2="-8.35" y2="7.6" width="0.2032" layer="21"/>
<wire x1="8.35" y1="-3.7" x2="8.35" y2="7.6" width="0.2032" layer="21"/>
<wire x1="-8.35" y1="7.6" x2="8.35" y2="7.6" width="0.2032" layer="21"/>
<pad name="1-1" x="-5" y="0" drill="1" diameter="3"/>
<pad name="1-2" x="0" y="0" drill="1" diameter="3"/>
<pad name="1-3" x="5" y="0" drill="1" diameter="3"/>
<pad name="2-1" x="-5" y="5" drill="1" diameter="3"/>
<pad name="2-2" x="0" y="5" drill="1" diameter="3"/>
<pad name="2-3" x="5" y="5" drill="1" diameter="3"/>
<text x="-8.255" y="8.255" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.445" y="1.905" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="B25P">
<description>&lt;b&gt;POTENTIOMETER&lt;/b&gt;&lt;p&gt;
Beckman Helitrim 25</description>
<wire x1="3.175" y1="3.429" x2="-3.175" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-3.429" x2="-2.54" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="3.175" y1="3.429" x2="3.429" y2="3.175" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-3.429" x2="3.429" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-3.175" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-1.524" x2="3.429" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-0.254" x2="3.429" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-3.429" x2="-3.429" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="3.429" x2="-3.429" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="3.175" x2="-3.429" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-0.254" x2="-3.429" y2="-1.524" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-1.524" x2="-3.429" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="0.762" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0" x2="1.524" y2="0.762" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.762" x2="0.762" y2="0.762" width="0.1524" layer="21"/>
<wire x1="0.762" y1="0.762" x2="0.381" y2="1.143" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.143" x2="0.381" y2="1.524" width="0.1524" layer="21"/>
<wire x1="0.381" y1="2.286" x2="-0.381" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="2.286" x2="-0.381" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.143" x2="-0.762" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0.762" x2="-1.524" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.762" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-0.381" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-0.381" x2="-0.381" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-1.524" x2="0.381" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-1.524" x2="0.381" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.381" x2="0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-1.397" x2="-2.032" y2="-1.651" width="0.3048" layer="51"/>
<wire x1="1.778" y1="-1.397" x2="2.032" y2="-1.651" width="0.3048" layer="51"/>
<wire x1="2.3876" y1="0.381" x2="2.7686" y2="0.381" width="0.3048" layer="21"/>
<wire x1="1.778" y1="2.032" x2="2.032" y2="2.286" width="0.3048" layer="21"/>
<wire x1="0" y1="2.7178" x2="0" y2="3.0988" width="0.3048" layer="21"/>
<wire x1="-1.905" y1="2.032" x2="-2.159" y2="2.286" width="0.3048" layer="21"/>
<wire x1="-2.3876" y1="0.381" x2="-2.7686" y2="0.381" width="0.3048" layer="21"/>
<wire x1="0.381" y1="1.524" x2="-0.381" y2="1.524" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.524" x2="0.381" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.524" x2="-0.381" y2="1.143" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.762" x2="-0.381" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.762" x2="0.381" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-0.762" x2="-0.381" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-3.048" x2="-2.54" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-3.048" x2="1.016" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="2.54" y1="-3.429" x2="2.54" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-3.429" x2="-0.635" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-3.429" x2="0.635" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="0.635" y1="-3.429" x2="2.54" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-3.429" x2="3.175" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-3.048" x2="-1.016" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-3.048" x2="2.54" y2="-3.048" width="0.1524" layer="21"/>
<circle x="0" y="0.381" radius="2.032" width="0.1524" layer="51"/>
<pad name="A" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="E" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="S" x="0" y="2.54" drill="0.8128" shape="octagon"/>
<text x="-3.175" y="3.81" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.1496" y="-5.08" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.413" y="-2.794" size="0.9906" layer="21" ratio="12">3</text>
<text x="-2.921" y="-2.794" size="0.9906" layer="21" ratio="12">1</text>
</package>
<package name="PT-10">
<description>&lt;b&gt;POTENTIOMETER&lt;/b&gt;</description>
<wire x1="-3.175" y1="-4.064" x2="3.175" y2="-4.064" width="0.1524" layer="21" curve="-288.924644"/>
<wire x1="3.175" y1="-4.064" x2="3.175" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="-5.715" x2="-3.175" y2="-4.064" width="0.1524" layer="51"/>
<wire x1="-2.794" y1="-5.715" x2="-2.794" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-2.794" y1="-3.175" x2="-1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="-0.635" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-3.175" x2="-0.635" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-4.445" x2="-1.27" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-4.445" x2="-1.27" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-5.715" x2="1.27" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-4.445" x2="0.635" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-4.445" x2="0.635" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-3.175" x2="1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-2.54" x2="2.794" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-3.175" x2="2.794" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="-3.175" y1="-5.715" x2="3.175" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="0.889" y1="1.397" x2="-0.127" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0.381" x2="-0.508" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.762" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-1.397" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.397" y1="0.889" x2="0.381" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.127" x2="0.762" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.762" y1="-0.508" x2="0" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.508" x2="-0.889" y2="-1.397" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="1.8034" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.794" width="0.0508" layer="21"/>
<pad name="A" x="-2.54" y="-5.08" drill="1.016" shape="octagon"/>
<pad name="E" x="2.54" y="-5.08" drill="1.016" shape="octagon"/>
<pad name="S" x="0" y="5.08" drill="1.016" shape="octagon"/>
<text x="-3.175" y="6.35" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.048" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="linear">
<description>&lt;b&gt;Linear Devices&lt;/b&gt;&lt;p&gt;
Operational amplifiers,  comparators, voltage regulators, ADCs, DACs, etc.&lt;p&gt;
<packages>
<package name="DIL14">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="8.89" y1="2.921" x2="-8.89" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.921" x2="-8.89" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="-8.89" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.016" x2="-8.89" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-9.271" y="-3.048" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-6.731" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="switch">
<description>&lt;b&gt;Switches&lt;/b&gt;&lt;p&gt;
Marquardt, Siemens, C&amp;K, ITT, and others&lt;p&gt;
<packages>
<package name="320-916">
<description>&lt;b&gt;TOGGLE SWITCH&lt;/b&gt;&lt;p&gt;
distributor RS Components</description>
<wire x1="-2.8702" y1="6.6802" x2="-3.5052" y2="6.0452" width="0.1524" layer="21"/>
<wire x1="-2.8702" y1="6.6802" x2="2.8702" y2="6.6802" width="0.1524" layer="21"/>
<wire x1="3.5052" y1="6.0452" x2="2.8702" y2="6.6802" width="0.1524" layer="21"/>
<wire x1="2.8702" y1="-6.6802" x2="3.5052" y2="-6.0452" width="0.1524" layer="21"/>
<wire x1="2.8702" y1="-6.6802" x2="-2.8702" y2="-6.6802" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="-6.0452" x2="-2.8702" y2="-6.6802" width="0.1524" layer="21"/>
<wire x1="4.318" y1="2.286" x2="4.318" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="2.286" x2="-4.318" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="1.905" y1="-3.175" x2="2.54" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="1.905" y1="-3.175" x2="-1.905" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-2.54" x2="-1.905" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-2.54" x2="-2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-1.905" y1="-1.27" x2="-2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-1.905" y1="-1.27" x2="1.905" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="1.6002" y1="1.27" x2="2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="3.5052" y1="-6.0452" x2="3.5052" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="3.5052" y1="6.0452" x2="3.5052" y2="2.8702" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="2.8702" x2="-3.5052" y2="6.0452" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="-6.0452" x2="-3.5052" y2="-2.8194" width="0.1524" layer="21"/>
<wire x1="-1.6002" y1="1.27" x2="-2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-2.54" x2="2.54" y2="-2.54" width="0.1524" layer="51" curve="-270"/>
<wire x1="-2.54" y1="-1.27" x2="2.54" y2="-1.27" width="0.1524" layer="51" curve="-233.130102"/>
<wire x1="-1.6002" y1="1.27" x2="1.6002" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="-2.286" x2="-3.5052" y2="-2.8194" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="-2.8194" x2="0" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="4.318" y1="-2.286" x2="3.5052" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="3.5052" y1="-2.8702" x2="0" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="4.318" y1="2.286" x2="3.5052" y2="2.8702" width="0.1524" layer="21"/>
<wire x1="3.5052" y1="2.8702" x2="0" y2="5.08" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="2.286" x2="-3.5052" y2="2.8702" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="2.8702" x2="0" y2="5.08" width="0.1524" layer="51"/>
<pad name="3" x="0" y="-4.0132" drill="2.0066" shape="long"/>
<pad name="2" x="0" y="0" drill="2.0066" shape="long"/>
<pad name="1" x="0" y="4.0132" drill="2.0066" shape="long"/>
<text x="-2.54" y="7.62" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-9.525" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="transistor-small-signal">
<description>&lt;b&gt;Small Signal Transistors&lt;/b&gt;&lt;p&gt;
Packages from :&lt;br&gt;
www.infineon.com; &lt;br&gt;
www.semiconductors.com;&lt;br&gt;
www.irf.com&lt;p&gt;
<packages>
<package name="SOT54D">
<description>&lt;b&gt;SOT-54&lt;/b&gt;&lt;p&gt;
grid 2.54 mm</description>
<wire x1="-0.9692" y1="2.2098" x2="0.9692" y2="2.2098" width="0.1524" layer="51" curve="-47.3637"/>
<wire x1="-1.631" y1="-1.778" x2="-0.9689" y2="2.2098" width="0.1524" layer="21" curve="-113.782"/>
<wire x1="0.9689" y1="2.2098" x2="1.631" y2="-1.778" width="0.1524" layer="21" curve="-113.782"/>
<wire x1="-1.631" y1="-1.778" x2="1.631" y2="-1.778" width="0.1524" layer="21"/>
<pad name="E" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="C" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<pad name="B" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="3.175" y="0" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
</packages>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
<packages>
<package name="DO35Z10">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2 mm, horizontal, grid 10.16mm</description>
<wire x1="5.08" y1="0" x2="4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.635" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.016" x2="2.286" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="0.762" x2="-2.032" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="-0.762" x2="-2.032" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.032" y1="-1.016" x2="2.286" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="0.762" x2="2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.016" x2="2.032" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.016" x2="2.032" y2="-1.016" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="5.08" y="0" drill="0.8128" shape="long"/>
<text x="-2.286" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.016" x2="-1.397" y2="1.016" layer="21"/>
<rectangle x1="2.286" y1="-0.254" x2="4.191" y2="0.254" layer="21"/>
<rectangle x1="-4.191" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
</packages>
</library>
<library name="transistor-npn">
<description>&lt;b&gt;NPN Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TO126">
<description>&lt;b&gt;TO 126 horizontal&lt;/b&gt;</description>
<wire x1="-3.937" y1="-1.27" x2="-3.937" y2="9.144" width="0.127" layer="21"/>
<wire x1="-3.937" y1="9.144" x2="3.937" y2="9.144" width="0.127" layer="21"/>
<wire x1="3.937" y1="9.144" x2="3.937" y2="-1.27" width="0.127" layer="21"/>
<wire x1="-3.937" y1="-1.27" x2="3.937" y2="-1.27" width="0.127" layer="21"/>
<wire x1="1.2393" y1="3.1591" x2="1.9493" y2="3.8858" width="0.127" layer="21" curve="25.6775"/>
<wire x1="0.7687" y1="3.6188" x2="1.2393" y2="3.1591" width="0.127" layer="21"/>
<wire x1="-0.7687" y1="3.6188" x2="-1.2393" y2="3.1591" width="0.127" layer="21"/>
<wire x1="-1.4787" y1="4.3456" x2="-1.9493" y2="3.8858" width="0.127" layer="21"/>
<wire x1="-1.9493" y1="3.8858" x2="-1.2393" y2="3.1591" width="0.127" layer="21" curve="25.6775"/>
<wire x1="0.508" y1="6.6509" x2="0.508" y2="7.3088" width="0.127" layer="21"/>
<wire x1="-0.508" y1="6.6509" x2="-0.508" y2="7.3088" width="0.127" layer="21"/>
<wire x1="-0.508" y1="7.3088" x2="0.508" y2="7.3088" width="0.127" layer="21" curve="-25.6796"/>
<wire x1="1.4787" y1="4.3456" x2="1.9493" y2="3.8858" width="0.127" layer="21"/>
<circle x="-3.1242" y="-0.4826" radius="0.4318" width="0" layer="21"/>
<circle x="0" y="5.08" radius="3.81" width="0" layer="42"/>
<circle x="0" y="5.08" radius="3.81" width="0" layer="43"/>
<circle x="0" y="5.08" radius="1.651" width="0.127" layer="21"/>
<pad name="1" x="-2.286" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.286" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<text x="-2.54" y="7.62" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="1.397" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-2.54" y="-0.889" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.508" y="-0.889" size="1.27" layer="51" ratio="10">2</text>
<text x="1.778" y="-0.889" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-0.635" y1="-3.048" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="-2.667" y1="-3.429" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-2.667" y1="-5.207" x2="-1.905" y2="-3.429" layer="51"/>
<rectangle x1="-0.381" y1="-3.429" x2="0.381" y2="-1.27" layer="21"/>
<rectangle x1="-0.381" y1="-5.207" x2="0.381" y2="-3.429" layer="51"/>
<rectangle x1="1.905" y1="-3.429" x2="2.667" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-5.207" x2="2.667" y2="-3.429" layer="51"/>
<hole x="0" y="5.08" drill="3.302"/>
</package>
<package name="TOP3">
<description>&lt;b&gt;TOP 3 horizontal&lt;/b&gt;</description>
<wire x1="-7.874" y1="-1.778" x2="7.874" y2="-1.778" width="0.127" layer="21"/>
<wire x1="7.874" y1="8.763" x2="7.874" y2="-1.778" width="0.127" layer="21"/>
<wire x1="-7.874" y1="-1.778" x2="-7.874" y2="8.763" width="0.127" layer="21"/>
<wire x1="-7.874" y1="8.763" x2="-7.874" y2="11.811" width="0.127" layer="21"/>
<wire x1="-7.874" y1="11.811" x2="-3.1242" y2="15.8496" width="0.127" layer="21"/>
<wire x1="7.874" y1="8.763" x2="-7.874" y2="8.763" width="0.127" layer="21"/>
<wire x1="7.874" y1="8.763" x2="7.874" y2="11.811" width="0.127" layer="21"/>
<wire x1="-7.366" y1="-1.27" x2="7.366" y2="-1.27" width="0.0508" layer="21"/>
<wire x1="7.366" y1="8.255" x2="7.366" y2="-1.27" width="0.0508" layer="21"/>
<wire x1="7.366" y1="8.255" x2="-7.366" y2="8.255" width="0.0508" layer="21"/>
<wire x1="-7.366" y1="-1.27" x2="-7.366" y2="8.255" width="0.0508" layer="21"/>
<wire x1="0" y1="17.145" x2="3.1431" y2="15.8431" width="0.127" layer="21" curve="-45.0001"/>
<wire x1="-3.1431" y1="15.8431" x2="0" y2="17.145" width="0.127" layer="21" curve="-45.0001"/>
<wire x1="7.874" y1="11.811" x2="3.1242" y2="15.875" width="0.127" layer="21"/>
<circle x="0" y="12.7" radius="2.159" width="0.127" layer="21"/>
<circle x="0" y="12.7" radius="5.08" width="0" layer="42"/>
<circle x="0" y="12.7" radius="5.08" width="0" layer="43"/>
<pad name="1" x="-5.588" y="-7.62" drill="1.397" shape="long" rot="R90"/>
<pad name="2" x="0" y="-7.62" drill="1.397" shape="long" rot="R90"/>
<pad name="3" x="5.588" y="-7.62" drill="1.397" shape="long" rot="R90"/>
<text x="-5.08" y="5.08" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-7.366" y="9.144" size="0.9906" layer="21" ratio="12">A20,3mm</text>
<text x="-5.715" y="-0.635" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="-0.635" size="1.27" layer="51" ratio="10">2</text>
<text x="4.445" y="-0.635" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-6.223" y1="-3.81" x2="-3.81" y2="-1.778" layer="21"/>
<rectangle x1="-1.397" y1="-3.81" x2="1.397" y2="-1.778" layer="21"/>
<rectangle x1="3.81" y1="-3.81" x2="6.223" y2="-1.778" layer="21"/>
<rectangle x1="-6.223" y1="-5.715" x2="-4.953" y2="-3.81" layer="21"/>
<rectangle x1="-6.223" y1="-7.62" x2="-4.953" y2="-5.715" layer="51"/>
<rectangle x1="-0.635" y1="-5.715" x2="0.635" y2="-3.81" layer="21"/>
<rectangle x1="-0.635" y1="-7.62" x2="0.635" y2="-5.715" layer="51"/>
<rectangle x1="4.953" y1="-5.715" x2="6.223" y2="-3.81" layer="21"/>
<rectangle x1="4.953" y1="-7.62" x2="6.223" y2="-5.715" layer="51"/>
<hole x="0" y="12.7" drill="4.1148"/>
</package>
</packages>
</library>
<library name="transistor-pnp">
<description>&lt;b&gt;PNP Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<description>&lt;b&gt;TO-126&lt;/b&gt;&lt;p&gt;
grid 2.3 mm, vertical</description>
<wire x1="-3.937" y1="-1.27" x2="-3.937" y2="9.144" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="9.144" x2="3.937" y2="9.144" width="0.1524" layer="21"/>
<wire x1="3.937" y1="9.144" x2="3.937" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.27" x2="3.937" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.239" y1="3.159" x2="1.949" y2="3.8857" width="0.1524" layer="21" curve="25.6775"/>
<wire x1="0.769" y1="3.619" x2="1.239" y2="3.159" width="0.1524" layer="21"/>
<wire x1="-0.769" y1="3.619" x2="-1.239" y2="3.159" width="0.1524" layer="21"/>
<wire x1="-1.479" y1="4.346" x2="-1.949" y2="3.886" width="0.1524" layer="21"/>
<wire x1="-1.949" y1="3.886" x2="-1.239" y2="3.1593" width="0.1524" layer="21" curve="25.6775"/>
<wire x1="0.508" y1="6.651" x2="0.508" y2="7.309" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="6.651" x2="-0.508" y2="7.309" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="7.309" x2="0.508" y2="7.309" width="0.1524" layer="21" curve="-25.6796"/>
<wire x1="1.479" y1="4.346" x2="1.949" y2="3.886" width="0.1524" layer="21"/>
<circle x="0" y="5.08" radius="1.651" width="0.1524" layer="21"/>
</package>
<package name="TO220">
<description>&lt;b&gt;TO-220&lt;/b&gt;&lt;p&gt;
grid 2.54 mm, horinzontal</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.1524" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.1524" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.1524" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.1524" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.1524" layer="21"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="42"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="43"/>
<pad name="1" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<text x="-3.81" y="5.207" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.937" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="7.874" size="1.016" layer="21" ratio="10">A17,5mm</text>
<text x="-3.175" y="0" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="0" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="0" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="2.159" y1="-4.699" x2="2.921" y2="-4.064" layer="21"/>
<rectangle x1="-0.381" y1="-4.699" x2="0.381" y2="-4.064" layer="21"/>
<rectangle x1="-2.921" y1="-4.699" x2="-2.159" y2="-4.064" layer="21"/>
<rectangle x1="-3.175" y1="-4.064" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-0.635" y1="-4.064" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-4.064" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="-2.921" y1="-6.604" x2="-2.159" y2="-4.699" layer="51"/>
<rectangle x1="-0.381" y1="-6.604" x2="0.381" y2="-4.699" layer="51"/>
<rectangle x1="2.159" y1="-6.604" x2="2.921" y2="-4.699" layer="51"/>
<hole x="0" y="11.176" drill="3.302"/>
</package>
<description>&lt;b&gt;TOP-3&lt;/b&gt;&lt;p&gt;
grid 5.45 mm, horizonal</description>
<wire x1="-7.874" y1="-1.778" x2="7.874" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="7.874" y1="8.763" x2="7.874" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-1.778" x2="-7.874" y2="8.763" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="8.763" x2="-7.874" y2="11.811" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="11.811" x2="-3.1242" y2="15.8496" width="0.1524" layer="21"/>
<wire x1="7.874" y1="8.763" x2="-7.874" y2="8.763" width="0.1524" layer="21"/>
<wire x1="7.874" y1="8.763" x2="7.874" y2="11.811" width="0.1524" layer="21"/>
<wire x1="0" y1="17.145" x2="3.1431" y2="15.8431" width="0.1524" layer="21" curve="-45.0001"/>
<wire x1="-3.1431" y1="15.8431" x2="0" y2="17.145" width="0.1524" layer="21" curve="-45.0001"/>
<wire x1="7.874" y1="11.811" x2="3.1242" y2="15.875" width="0.1524" layer="21"/>
<circle x="0" y="12.7" radius="2.159" width="0.1524" layer="21"/>
<text x="-7.366" y="9.144" size="1.016" layer="21" ratio="10">A20,3mm</text>
</package>
</packages>
</library>
<library name="transistor">
<description>&lt;b&gt;Transistors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<description>&lt;b&gt;TO 220 horizontal&lt;/b&gt;</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.127" layer="21"/>
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.127" layer="21"/>
<text x="-4.445" y="7.874" size="0.9906" layer="21" ratio="12">A17,5mm</text>
</package>
</packages>
</library>
<library name="fuse">
<description>&lt;b&gt;Fuses and Fuse Holders&lt;/b&gt;&lt;p&gt;
<packages>
<package name="SH22,5A">
<description>&lt;b&gt;FUSE HOLDER&lt;/b&gt;&lt;p&gt; grid 22,5 mm, isolated cap&lt;p&gt; OGN0031 8201 Schurter (Buerklin)</description>
<wire x1="-12.573" y1="-5.461" x2="12.573" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="12.573" y1="5.461" x2="-12.573" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="5.08" y2="-2.921" width="0.0508" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="5.08" y2="2.921" width="0.0508" layer="21"/>
<wire x1="-10.795" y1="3.683" x2="-5.715" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-3.683" x2="-10.795" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-2.54" x2="-5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="3.683" x2="-10.795" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="2.54" x2="-5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-3.683" x2="-10.795" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-3.683" x2="-5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-3.683" x2="-11.43" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-3.683" x2="-11.43" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-11.176" y1="-2.032" x2="-11.176" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-11.176" y1="-3.175" x2="-10.795" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-3.175" x2="-10.795" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.54" x2="-5.715" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-2.032" x2="-11.43" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-11.43" y1="-1.27" x2="-11.176" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-11.176" y1="-1.27" x2="-11.176" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="10.795" y1="-3.683" x2="5.715" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="10.795" y1="3.683" x2="10.795" y2="3.175" width="0.1524" layer="21"/>
<wire x1="10.795" y1="2.54" x2="5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-3.683" x2="10.795" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-2.54" x2="5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="3.683" x2="10.795" y2="3.683" width="0.1524" layer="21"/>
<wire x1="5.715" y1="3.683" x2="5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.795" y1="3.683" x2="11.43" y2="3.683" width="0.1524" layer="21"/>
<wire x1="11.43" y1="3.683" x2="11.43" y2="2.032" width="0.1524" layer="21"/>
<wire x1="11.176" y1="2.032" x2="11.176" y2="3.175" width="0.1524" layer="21"/>
<wire x1="11.176" y1="3.175" x2="10.795" y2="3.175" width="0.1524" layer="21"/>
<wire x1="10.795" y1="3.175" x2="10.795" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.54" x2="5.715" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="11.43" y1="2.032" x2="11.43" y2="1.27" width="0.1524" layer="51"/>
<wire x1="11.43" y1="1.27" x2="11.176" y2="1.27" width="0.1524" layer="51"/>
<wire x1="11.176" y1="1.27" x2="11.176" y2="2.032" width="0.1524" layer="51"/>
<wire x1="-5.207" y1="0" x2="5.207" y2="0" width="0.0508" layer="21"/>
<wire x1="12.573" y1="5.461" x2="12.573" y2="1.651" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-1.651" x2="12.573" y2="1.651" width="0.1524" layer="51"/>
<wire x1="12.573" y1="-1.651" x2="12.573" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="5.461" x2="-12.573" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-1.651" x2="-12.573" y2="1.651" width="0.1524" layer="51"/>
<wire x1="-12.573" y1="-1.651" x2="-12.573" y2="-5.461" width="0.1524" layer="21"/>
<pad name="1" x="-11.2522" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<pad name="2" x="11.2522" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<text x="-12.7" y="-7.62" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="0.0254" y="-7.62" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-10.541" y1="-2.032" x2="-10.16" y2="2.032" layer="51"/>
<rectangle x1="-10.541" y1="1.905" x2="-9.652" y2="2.032" layer="51"/>
<rectangle x1="-10.541" y1="-2.032" x2="-9.652" y2="-1.905" layer="51"/>
<rectangle x1="-5.715" y1="-3.175" x2="-5.08" y2="-2.032" layer="21"/>
<rectangle x1="-5.715" y1="2.032" x2="-5.08" y2="3.175" layer="21"/>
<rectangle x1="-5.715" y1="-2.032" x2="-5.08" y2="2.032" layer="21"/>
<rectangle x1="10.16" y1="-2.032" x2="10.541" y2="2.032" layer="51"/>
<rectangle x1="9.652" y1="-2.032" x2="10.541" y2="-1.905" layer="51"/>
<rectangle x1="9.652" y1="1.905" x2="10.541" y2="2.032" layer="51"/>
<rectangle x1="5.08" y1="2.032" x2="5.715" y2="3.175" layer="21"/>
<rectangle x1="5.08" y1="-3.175" x2="5.715" y2="-2.032" layer="21"/>
<rectangle x1="5.08" y1="-2.032" x2="5.715" y2="2.032" layer="21"/>
<rectangle x1="-5.08" y1="2.159" x2="5.08" y2="2.667" layer="21"/>
<rectangle x1="-5.08" y1="-2.667" x2="5.08" y2="-2.159" layer="21"/>
<rectangle x1="5.715" y1="-2.032" x2="9.652" y2="-1.905" layer="21"/>
<rectangle x1="5.715" y1="1.905" x2="9.652" y2="2.032" layer="21"/>
<rectangle x1="-9.652" y1="1.905" x2="-5.715" y2="2.032" layer="21"/>
<rectangle x1="-9.652" y1="-2.032" x2="-5.715" y2="-1.905" layer="21"/>
<rectangle x1="-10.541" y1="-2.54" x2="-5.715" y2="-2.032" layer="21"/>
<rectangle x1="-10.541" y1="2.032" x2="-5.715" y2="2.54" layer="21"/>
<rectangle x1="5.715" y1="2.032" x2="10.541" y2="2.54" layer="21"/>
<rectangle x1="5.715" y1="-2.54" x2="10.541" y2="-2.032" layer="21"/>
</package>
</packages>
</library>
<library name="con-ptr500">
<description>&lt;b&gt;PTR Connectors&lt;/b&gt;&lt;p&gt;
Aug. 2004 / PTR Meßtechnik:&lt;br&gt;
Die Bezeichnung der Serie AK505 wurde geändert.&lt;br&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.&lt;p&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=LEFT&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Alte Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Neue Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2DS,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2DS-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AKZ505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AKZ500/2-5.08-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TABLE&gt;
<packages>
<package name="AK500/2">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;</description>
<wire x1="-5.08" y1="-3.556" x2="-5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.937" x2="-5.08" y2="3.937" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.937" x2="5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.556" x2="5.08" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.048" x2="-5.588" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.048" x2="-5.08" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="3.175" x2="-5.588" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="2.032" x2="-5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.159" x2="-5.08" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.159" x2="5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.159" x2="5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.159" x2="5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.159" x2="-5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.159" x2="5.08" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="1.4986" y1="-1.397" x2="3.9116" y2="1.016" width="0.1524" layer="51"/>
<wire x1="1.1176" y1="-1.016" x2="3.5306" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-3.9116" y1="-1.016" x2="-1.4986" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-3.5306" y1="-1.397" x2="-1.1176" y2="1.016" width="0.1524" layer="51"/>
<wire x1="1.4986" y1="-1.016" x2="3.5306" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-3.5306" y1="-1.016" x2="-1.4986" y2="1.016" width="0.6096" layer="51"/>
<wire x1="1.1176" y1="-1.016" x2="1.4986" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="3.5306" y1="1.397" x2="3.9116" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-3.9116" y1="-1.016" x2="-3.5306" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-1.4986" y1="1.397" x2="-1.1176" y2="1.016" width="0.1524" layer="51"/>
<circle x="2.5146" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-2.5146" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="2.5146" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="-2.5146" y="0" radius="1.778" width="0.1524" layer="51"/>
<pad name="1" x="-2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-5.08" y="4.445" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="2.54" size="0.9906" layer="21" ratio="12">1</text>
<text x="0.635" y="2.54" size="0.9906" layer="21" ratio="12">2</text>
<rectangle x1="-0.381" y1="-1.905" x2="0.381" y2="1.905" layer="21"/>
</package>
<package name="AK500/3">
<wire x1="-7.5184" y1="-3.556" x2="-7.5184" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="3.937" x2="-7.5184" y2="3.937" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="3.937" x2="7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="-3.556" x2="7.5184" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="3.048" x2="-8.0264" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="3.048" x2="-7.5184" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.0264" y1="3.175" x2="-8.0264" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-8.0264" y1="2.032" x2="-7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="2.159" x2="-7.5184" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="2.159" x2="7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="2.159" x2="7.5184" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="-2.159" x2="7.5184" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="-2.159" x2="-7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="-2.159" x2="7.5184" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-1.397" x2="1.397" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-1.397" y1="-1.016" x2="1.016" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-6.4008" y1="-1.016" x2="-3.9878" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-6.0198" y1="-1.397" x2="-3.6068" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="-1.016" x2="1.016" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-6.0198" y1="-1.016" x2="-3.9878" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-1.397" y1="-1.016" x2="-1.016" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="1.016" y1="1.397" x2="1.397" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-6.4008" y1="-1.016" x2="-6.0198" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-3.9878" y1="1.397" x2="-3.6068" y2="1.016" width="0.1524" layer="51"/>
<wire x1="3.9878" y1="-1.016" x2="6.0198" y2="1.016" width="0.6096" layer="51"/>
<wire x1="3.9878" y1="-1.397" x2="6.4008" y2="1.016" width="0.1524" layer="51"/>
<wire x1="3.6068" y1="-1.016" x2="6.0198" y2="1.397" width="0.1524" layer="51"/>
<wire x1="3.6068" y1="-1.016" x2="3.9878" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="6.0198" y1="1.397" x2="6.4008" y2="1.016" width="0.1524" layer="51"/>
<circle x="0" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-5.0038" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="-5.0038" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="5.0038" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="5.0038" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<pad name="1" x="-5.0038" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="3" x="5.0038" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-7.5946" y="4.445" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.5946" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.731" y="2.54" size="0.9906" layer="21" ratio="12">1</text>
<text x="-1.905" y="2.54" size="0.9906" layer="21" ratio="12">2</text>
<text x="3.175" y="2.54" size="0.9906" layer="21" ratio="12">3</text>
<rectangle x1="-2.8956" y1="-1.905" x2="-2.1336" y2="1.905" layer="21"/>
<rectangle x1="2.1336" y1="-1.905" x2="2.8956" y2="1.905" layer="21"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules>
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<description language="hu">&lt;b&gt;EAGLE Tervezési Szabályok&lt;/b&gt;&lt;p&gt;Az alapértelmezett Tervezési Szabályok úgy lettek megállapítva, hogy használhatók legyenek minél többféle alkalmazás megtervezéséhez.A Te általad tervezni kívánt termék más beállításokat követelhet meg,így megkérlek, hogy tedd meg a neked szükséges beállításokat, és mentsd elegy másik néven.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="B1" library="rectifier" package="GBU4S" value="" x="20.32" y="45.72" rot="R90"/>
<element name="C1" library="rcl" package="EB22,5D" value="" x="35.333546875" y="60.52105625" rot="R90"/>
<element name="C2" library="rcl" package="EB22,5D" value="" x="34.774528125" y="29.731490625" rot="R90"/>
<element name="C9" library="rcl" package="E7,5-16" value="1000u" x="56.107334375" y="28.242475" rot="R270"/>
<element name="C10" library="rcl" package="E7,5-16" value="1000u" x="55.97604375" y="59.381275" rot="R270"/>
<element name="C7" library="rcl" package="C025-030X050" value="" x="79.989546875" y="27.545890625" rot="R90"/>
<element name="C8" library="rcl" package="C025-030X050" value="" x="71.9430875" y="27.63330625" rot="R90"/>
<element name="C11" library="rcl" package="E2,5-6E" value="" x="95.254778125" y="28.282534375" rot="R90"/>
<element name="C12" library="rcl" package="E2,5-6E" value="" x="87.228390625" y="27.8829625" rot="R90"/>
<element name="R1" library="rcl" package="0207/10" value="" x="79.982084375" y="38.636734375" rot="R90"/>
<element name="R2" library="rcl" package="0207/10" value="" x="71.87338125" y="38.5717125" rot="R90"/>
<element name="R3" library="rcl" package="0207/10" value="" x="95.257221875" y="38.453690625" rot="R90"/>
<element name="R4" library="rcl" package="0207/10" value="" x="87.232571875" y="38.633096875" rot="R90"/>
<element name="R5" library="pot" package="3RP/1610N" value="" x="108.782025" y="17.465440625"/>
<element name="IC1" library="linear" package="DIL14" value="TL084P" x="113.69239375" y="42.417978125"/>
<element name="R6" library="rcl" package="0207/10" value="2,2k" x="108.65655" y="27.73321875" rot="R90"/>
<element name="R7" library="rcl" package="0207/10" value="47k" x="117.91625" y="32.995196875"/>
<element name="R8" library="rcl" package="0207/10" value="10k" x="127.057953125" y="33.353778125" rot="R90"/>
<element name="R9" library="rcl" package="0207/10" value="47k" x="133.8650125" y="30.98623125" rot="R270"/>
<element name="S1" library="switch" package="320-916" value="" x="127.146859375" y="20.525309375" rot="R90"/>
<element name="R10" library="rcl" package="0207/10" value="10k" x="129.72495625" y="46.192" rot="R180"/>
<element name="R11" library="pot" package="3RP/1610G" value="" x="100.026475" y="83.4804375" rot="R180"/>
<element name="R12" library="rcl" package="0207/10" value="10k" x="119.320671875" y="62.2639125"/>
<element name="R13" library="rcl" package="0207/10" value="100k" x="105.4325375" y="58.27803125"/>
<element name="R14" library="rcl" package="0207/10" value="10k" x="105.678428125" y="54.6217"/>
<element name="C13" library="rcl" package="C025-030X050" value="47n" x="81.903309375" y="60.67405" rot="R270"/>
<element name="C14" library="rcl" package="C025-030X050" value="47n" x="104.673171875" y="62.939046875"/>
<element name="R15" library="rcl" package="0207/10" value="10k" x="91.053609375" y="55.517690625" rot="R180"/>
<element name="R16" library="rcl" package="0207/10" value="8,2k" x="90.995040625" y="58.6556125" rot="R180"/>
<element name="R17" library="rcl" package="0207/10" value="10k" x="90.966990625" y="49.011978125" rot="R180"/>
<element name="R18" library="rcl" package="0207/10" value="3,9k" x="160.28703125" y="72.72756875"/>
<element name="Q1" library="transistor-small-signal" package="SOT54D" value="BC639" x="165.594575" y="48.986975" rot="R90"/>
<element name="Q2" library="transistor-small-signal" package="SOT54D" value="BC640" x="165.442234375" y="66.149025" rot="R90"/>
<element name="C15" library="rcl" package="E5-10,5" value="470u" x="152.044703125" y="55.825721875" rot="R180"/>
<element name="C16" library="rcl" package="E5-10,5" value="470u" x="149.2739625" y="26.44794375" rot="R180"/>
<element name="R19" library="rcl" package="0207/10" value="100" x="146.80930625" y="38.988109375" rot="R90"/>
<element name="R20" library="rcl" package="0207/10" value="100" x="148.861946875" y="47.133721875"/>
<element name="R21" library="rcl" package="0207/10" value="820" x="158.728909375" y="53.391009375" rot="R90"/>
<element name="R22" library="rcl" package="0207/10" value="820" x="105.4237" y="71.15796875"/>
<element name="R23" library="rcl" package="0207/10" value="1k" x="48.085015625" y="88.419025" rot="R270"/>
<element name="R24" library="rcl" package="0207/10" value="1k" x="52.634884375" y="78.05743125" rot="R270"/>
<element name="D1" library="diode" package="DO35Z10" value="ZPD15" x="68.9366125" y="55.6924375" rot="R270"/>
<element name="D2" library="diode" package="DO35Z10" value="ZPD15" x="72.88338125" y="55.776596875" rot="R90"/>
<element name="R25" library="rcl" package="0207/10" value="1k" x="79.7191625" y="78.2338"/>
<element name="R26" library="rcl" package="0207/10" value="1k" x="79.593078125" y="73.340559375" rot="R180"/>
<element name="C3" library="rcl" package="E2-5" value="100u" x="67.7873375" y="65.944953125" rot="R90"/>
<element name="C4" library="rcl" package="E2-5" value="100u" x="74.269471875" y="65.937815625" rot="R270"/>
<element name="R27" library="rcl" package="0207/10" value="3,9k" x="62.686109375" y="73.184890625"/>
<element name="R28" library="rcl" package="0207/10" value="3,3k" x="127.859309375" y="53.017459375" rot="R180"/>
<element name="R29" library="pot" package="B25P" value="" x="116.53573125" y="52.976721875"/>
<element name="R30" library="rcl" package="0207/10" value="2,2k" x="62.5513625" y="82.513609375" rot="R180"/>
<element name="R31" library="rcl" package="0207/10" value="2,2k" x="62.705340625" y="78.45283125" rot="R180"/>
<element name="C5" library="rcl" package="C025-030X050" value="56" x="159.75301875" y="26.243509375"/>
<element name="C6" library="rcl" package="C025-030X050" value="56" x="137.698746875" y="54.78445625" rot="R90"/>
<element name="Q3" library="transistor-small-signal" package="SOT54D" value="BC639" x="161.44875625" y="62.40633125" rot="R90"/>
<element name="Q4" library="transistor-small-signal" package="SOT54D" value="BC640" x="162.722171875" y="44.004140625" rot="R90"/>
<element name="R32" library="rcl" package="0207/10" value="1k" x="57.263878125" y="93.72309375"/>
<element name="R33" library="rcl" package="0207/10" value="1k" x="138.647328125" y="68.473175" rot="R180"/>
<element name="Q5" library="transistor-npn" package="TO126" value="MJE340" x="195.8601875" y="44.024365625" rot="R270"/>
<element name="Q6" library="transistor-pnp" package="TO126" value="MJE350" x="195.902840625" y="52.53905" rot="R270"/>
<element name="R34" library="rcl" package="0207/10" value="150" x="79.725503125" y="82.652878125" rot="R180"/>
<element name="R35" library="rcl" package="0207/10" value="150" x="166.662540625" y="56.375" rot="R180"/>
<element name="C17" library="rcl" package="E2-5" value="100u" x="149.98164375" y="77.276796875" rot="R180"/>
<element name="C18" library="rcl" package="E2-5" value="100u" x="78.45641875" y="55.508415625"/>
<element name="Q7" library="transistor-npn" package="TO126" value="BD139" x="230.162571875" y="49.112803125" rot="R270"/>
<element name="R36" library="rcl" package="0207/10" value="1k" x="162.73109375" y="35.918390625"/>
<element name="R37" library="pot" package="PT-10" value="" x="179.5856375" y="39.04488125"/>
<element name="C19" library="rcl" package="C025-030X050" value="100n" x="178.798465625" y="26.683471875" rot="R90"/>
<element name="R38" library="rcl" package="0207/10" value="6,2k" x="152.0280375" y="38.9989875" rot="R270"/>
<element name="R39" library="rcl" package="0207/10" value="6,2k" x="141.12378125" y="31.533771875" rot="R90"/>
<element name="T1" library="transistor" package="TO220" value="BD243" x="231.25523125" y="68.389640625" rot="R270"/>
<element name="Q8" library="transistor-pnp" package="TO220" value="BD240" x="231.520125" y="28.962796875" rot="R270"/>
<element name="R40" library="rcl" package="0207/10" value="1k" x="46.782815625" y="96.932359375"/>
<element name="R41" library="rcl" package="0207/10" value="1k" x="88.0135375" y="68.196140625" rot="R180"/>
<element name="C20" library="rcl" package="C025-030X050" value="120" x="141.010853125" y="61.9785" rot="R270"/>
<element name="C21" library="rcl" package="C025-030X050" value="120" x="143.1887875" y="16.255715625" rot="R90"/>
<element name="R42" library="rcl" package="0207/10" value="100" x="194.123303125" y="84.5335" rot="R90"/>
<element name="C22" library="rcl" package="C025-030X050" value="100n" x="143.099665625" y="77.326121875"/>
<element name="C23" library="rcl" package="C025-030X050" value="100n" x="88.757728125" y="81.666609375" rot="R270"/>
<element name="Q9" library="transistor-npn" package="TOP3" value="BD249" x="232.838846875" y="86.776034375" rot="R270"/>
<element name="Q10" library="transistor-pnp" package="TOP3" value="BD250" x="233.062225" y="10.07876875" rot="R270"/>
<element name="R43" library="rcl" package="0922/22" value="" x="204.221659375" y="69.80145625" rot="R90"/>
<element name="R44" library="rcl" package="0922/22" value="" x="215.197353125" y="69.66399375" rot="R90"/>
<element name="R45" library="rcl" package="0922/22" value="" x="215.20321875" y="16.046496875" rot="R90"/>
<element name="R46" library="rcl" package="0922/22" value="" x="203.545334375" y="15.991353125" rot="R90"/>
<element name="R47" library="rcl" package="0207/10" value="10" x="71.2747375" y="87.721996875" rot="R270"/>
<element name="C24" library="rcl" package="C025-030X050" value="100n" x="78.170884375" y="92.99234375"/>
<element name="F1" library="fuse" package="SH22,5A" value="" x="31.75" y="10.16" rot="R180">
<attribute name="OC_NEWARK" value="04F1224" x="-24.13" y="69.85" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="0031.7701.11" x="-24.13" y="69.85" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="-24.13" y="69.85" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="-24.13" y="69.85" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="F2" library="fuse" package="SH22,5A" value="" x="30.268903125" y="86.360421875" rot="R180">
<attribute name="OC_NEWARK" value="04F1224" x="-52.281096875" y="146.050421875" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="0031.7701.11" x="-52.281096875" y="146.050421875" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="-52.281096875" y="146.050421875" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="-52.281096875" y="146.050421875" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="L1" library="rcl" package="0207/15" value="3uH" x="205.5581625" y="34.0706875" rot="R180"/>
<element name="R48" library="rcl" package="0207/10" value="1,5k" x="29.928021875" y="97.892296875"/>
<element name="D3" library="diode" package="DO35Z10" value="ZPD15" x="19.52044375" y="93.744971875" rot="R180"/>
<element name="Q11" library="transistor-npn" package="TO126" value="BD139" x="17.8553375" y="103.67475625"/>
<element name="X1" library="con-ptr500" package="AK500/2" value="" x="150.259809375" y="16.16208125" rot="R180">
<attribute name="OC_NEWARK" value="unknown" x="150.259809375" y="16.16208125" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="150.259809375" y="16.16208125" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="150.259809375" y="16.16208125" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="150.259809375" y="16.16208125" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="X2" library="con-ptr500" package="AK500/2" value="" x="10.7812875" y="86.502459375" rot="R270">
<attribute name="OC_NEWARK" value="unknown" x="10.7812875" y="86.502459375" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="" x="10.7812875" y="86.502459375" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MF" value="" x="10.7812875" y="86.502459375" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="10.7812875" y="86.502459375" size="1.778" layer="27" rot="R270" display="off"/>
</element>
<element name="X4" library="con-ptr500" package="AK500/3" value="" x="12.15889375" y="45.616671875" rot="R90">
<attribute name="OC_NEWARK" value="unknown" x="12.15889375" y="45.616671875" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="12.15889375" y="45.616671875" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="12.15889375" y="45.616671875" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="12.15889375" y="45.616671875" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="X5" library="con-ptr500" package="AK500/3" value="" x="75.09133125" y="18.74195" rot="R180">
<attribute name="OC_NEWARK" value="unknown" x="75.09133125" y="18.74195" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="75.09133125" y="18.74195" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="75.09133125" y="18.74195" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="75.09133125" y="18.74195" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="X6" library="con-ptr500" package="AK500/3" value="" x="90.248046875" y="18.72773125" rot="R180">
<attribute name="OC_NEWARK" value="unknown" x="90.248046875" y="18.72773125" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="90.248046875" y="18.72773125" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="90.248046875" y="18.72773125" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="90.248046875" y="18.72773125" size="1.778" layer="27" rot="R180" display="off"/>
</element>
</elements>
<signals>
<signal name="N$2">
<contactref element="B1" pad="AC1"/>
<contactref element="X4" pad="3"/>
<wire x1="12.15889375" y1="50.620471875" x2="17.959528125" y2="50.620471875" width="2" layer="16"/>
<wire x1="17.959528125" y1="50.620471875" x2="20.32" y2="48.26" width="2" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="B1" pad="AC2"/>
<contactref element="X4" pad="1"/>
<wire x1="12.15889375" y1="40.612871875" x2="17.752871875" y2="40.612871875" width="2" layer="16"/>
<wire x1="17.752871875" y1="40.612871875" x2="20.32" y2="43.18" width="2" layer="16"/>
</signal>
<signal name="N$1">
<contactref element="C7" pad="2"/>
<contactref element="R1" pad="1"/>
<wire x1="79.982084375" y1="33.396734375" x2="79.989546875" y2="33.396734375" width="0.8128" layer="16"/>
<wire x1="79.989546875" y1="33.396734375" x2="79.989546875" y2="29.545890625" width="0.8128" layer="16"/>
</signal>
<signal name="N$3">
<contactref element="C8" pad="2"/>
<contactref element="R2" pad="1"/>
<wire x1="71.9430875" y1="29.63330625" x2="71.87338125" y2="29.63330625" width="0.8128" layer="16"/>
<wire x1="71.87338125" y1="29.63330625" x2="71.87338125" y2="33.3317125" width="0.8128" layer="16"/>
</signal>
<signal name="N$8">
<contactref element="C11" pad="-"/>
<contactref element="R3" pad="1"/>
<wire x1="95.257221875" y1="33.213690625" x2="95.254778125" y2="33.213690625" width="0.8128" layer="16"/>
<wire x1="95.254778125" y1="33.213690625" x2="95.254778125" y2="29.552534375" width="0.8128" layer="16"/>
</signal>
<signal name="N$9">
<contactref element="C12" pad="-"/>
<contactref element="R4" pad="1"/>
<wire x1="87.228390625" y1="29.1529625" x2="87.232571875" y2="29.1529625" width="0.8128" layer="16"/>
<wire x1="87.232571875" y1="29.1529625" x2="87.232571875" y2="33.393096875" width="0.8128" layer="16"/>
</signal>
<signal name="N$10">
<contactref element="R4" pad="2"/>
<contactref element="R3" pad="2"/>
<contactref element="R2" pad="2"/>
<contactref element="R1" pad="2"/>
<contactref element="R5" pad="3"/>
<wire x1="71.87338125" y1="43.8117125" x2="79.982084375" y2="43.8117125" width="0.8128" layer="16"/>
<wire x1="79.982084375" y1="43.8117125" x2="79.982084375" y2="43.876734375" width="0.8128" layer="16"/>
<wire x1="79.982084375" y1="43.876734375" x2="87.232571875" y2="43.876734375" width="0.8128" layer="16"/>
<wire x1="87.232571875" y1="43.876734375" x2="87.232571875" y2="43.873096875" width="0.8128" layer="16"/>
<wire x1="87.232571875" y1="43.873096875" x2="95.257221875" y2="43.873096875" width="0.8128" layer="16"/>
<wire x1="95.257221875" y1="43.873096875" x2="95.257221875" y2="43.693690625" width="0.8128" layer="16"/>
<wire x1="113.782025" y1="17.465440625" x2="113.782025" y2="23.581259375" width="1.016" layer="16"/>
<wire x1="113.782025" y1="23.581259375" x2="110.41189375" y2="26.951390625" width="1.016" layer="16"/>
<wire x1="110.41189375" y1="26.951390625" x2="107.54068125" y2="26.951390625" width="1.016" layer="16"/>
<wire x1="107.54068125" y1="26.951390625" x2="95.313953125" y2="39.17811875" width="1.016" layer="16"/>
<wire x1="95.313953125" y1="39.17811875" x2="95.313953125" y2="43.38535" width="1.016" layer="16"/>
<wire x1="95.313953125" y1="43.38535" x2="95.445240625" y2="43.5166375" width="1.016" layer="16"/>
<wire x1="95.445240625" y1="43.5166375" x2="95.434275" y2="43.5166375" width="1.016" layer="16"/>
<wire x1="95.434275" y1="43.5166375" x2="95.257221875" y2="43.693690625" width="1.016" layer="16"/>
</signal>
<signal name="GND">
<contactref element="C2" pad="+"/>
<contactref element="C1" pad="-"/>
<contactref element="C10" pad="-"/>
<contactref element="C9" pad="+"/>
<contactref element="R5" pad="1"/>
<contactref element="IC1" pad="3"/>
<contactref element="IC1" pad="5"/>
<contactref element="C14" pad="1"/>
<contactref element="R15" pad="2"/>
<contactref element="R17" pad="2"/>
<contactref element="R19" pad="2"/>
<contactref element="R20" pad="1"/>
<contactref element="C4" pad="+"/>
<contactref element="D2" pad="C"/>
<contactref element="C3" pad="-"/>
<contactref element="D1" pad="A"/>
<contactref element="Q3" pad="C"/>
<contactref element="Q4" pad="C"/>
<contactref element="C18" pad="-"/>
<contactref element="C17" pad="-"/>
<contactref element="R38" pad="1"/>
<contactref element="R39" pad="2"/>
<contactref element="C22" pad="2"/>
<contactref element="C23" pad="1"/>
<contactref element="C24" pad="2"/>
<contactref element="D3" pad="A"/>
<contactref element="X4" pad="2"/>
<contactref element="X6" pad="2"/>
<contactref element="X5" pad="2"/>
<contactref element="X1" pad="2"/>
<contactref element="X2" pad="2"/>
<wire x1="75.09133125" y1="18.74195" x2="75.09133125" y2="17.046234375" width="0.8128" layer="16"/>
<wire x1="75.09133125" y1="17.046234375" x2="76.566975" y2="15.570590625" width="0.8128" layer="16"/>
<wire x1="76.566975" y1="15.570590625" x2="90.38879375" y2="15.570590625" width="0.8128" layer="16"/>
<wire x1="90.38879375" y1="15.570590625" x2="101.887175" y2="15.570590625" width="0.8128" layer="16"/>
<wire x1="101.887175" y1="15.570590625" x2="103.782025" y2="17.465440625" width="0.8128" layer="16"/>
<wire x1="90.248046875" y1="18.72773125" x2="90.248046875" y2="15.7113375" width="0.8128" layer="16"/>
<wire x1="90.248046875" y1="15.7113375" x2="90.38879375" y2="15.570590625" width="0.8128" layer="16"/>
<wire x1="75.09133125" y1="18.74195" x2="75.09133125" y2="26.0890625" width="0.8128" layer="16"/>
<wire x1="75.09133125" y1="26.0890625" x2="73.6811" y2="27.49929375" width="0.8128" layer="16"/>
<wire x1="73.6811" y1="27.49929375" x2="68.17113125" y2="27.49929375" width="0.8128" layer="16"/>
<wire x1="55.845409375" y1="45.616671875" x2="55.876171875" y2="45.647434375" width="2" layer="16"/>
<wire x1="55.876171875" y1="45.647434375" x2="55.876171875" y2="45.584121875" width="2" layer="16"/>
<wire x1="55.876171875" y1="45.584121875" x2="55.876171875" y2="45.447153125" width="2" layer="16"/>
<wire x1="55.876171875" y1="45.447153125" x2="55.8497125" y2="45.42069375" width="2" layer="16"/>
<wire x1="55.8497125" y1="45.42069375" x2="55.56488125" y2="45.1358625" width="2" layer="16"/>
<wire x1="55.56488125" y1="45.1358625" x2="34.993796875" y2="24.564778125" width="2" layer="16"/>
<wire x1="34.993796875" y1="24.564778125" x2="34.861240625" y2="24.564778125" width="2" layer="16"/>
<wire x1="34.861240625" y1="24.564778125" x2="34.774528125" y2="24.651490625" width="2" layer="16"/>
<wire x1="55.93945" y1="45.14094375" x2="55.93945" y2="45.52084375" width="2" layer="16"/>
<wire x1="55.93945" y1="45.52084375" x2="55.876171875" y2="45.584121875" width="2" layer="16"/>
<wire x1="55.894834375" y1="45.13960625" x2="55.9381125" y2="45.13960625" width="2" layer="16"/>
<wire x1="55.9381125" y1="45.13960625" x2="55.93945" y2="45.14094375" width="2" layer="16"/>
<wire x1="55.876171875" y1="45.447153125" x2="55.876171875" y2="45.267503125" width="2" layer="16"/>
<wire x1="55.876171875" y1="45.267503125" x2="56.00273125" y2="45.14094375" width="2" layer="16"/>
<wire x1="56.00273125" y1="45.14094375" x2="56.00273125" y2="46.01456875" width="2" layer="16"/>
<wire x1="56.00273125" y1="46.01456875" x2="56.00273125" y2="48.878253125" width="2" layer="16"/>
<wire x1="45.936484375" y1="54.764259375" x2="55.56488125" y2="45.1358625" width="2" layer="16"/>
<wire x1="45.936484375" y1="54.764259375" x2="46.126865625" y2="54.59641875" width="2" layer="16"/>
<wire x1="46.126865625" y1="54.59641875" x2="45.70213125" y2="54.929696875" width="2" layer="16"/>
<wire x1="45.70213125" y1="54.929696875" x2="35.4038625" y2="65.419675" width="2" layer="16"/>
<wire x1="35.4038625" y1="65.419675" x2="35.333546875" y2="65.60105625" width="2" layer="16"/>
<wire x1="14.44044375" y1="93.744971875" x2="14.44044375" y2="83.5368625" width="1.016" layer="16"/>
<wire x1="14.44044375" y1="83.5368625" x2="14.44044375" y2="55.53990625" width="1.016" layer="16"/>
<wire x1="14.44044375" y1="55.53990625" x2="13.65715" y2="54.7566125" width="1.016" layer="16"/>
<wire x1="13.65715" y1="54.7566125" x2="9.08065" y2="54.7566125" width="1.016" layer="16"/>
<wire x1="9.08065" y1="54.7566125" x2="8.2016125" y2="53.877575" width="1.016" layer="16"/>
<wire x1="8.2016125" y1="53.877575" x2="8.2016125" y2="46.18581875" width="1.016" layer="16"/>
<wire x1="8.2016125" y1="46.18581875" x2="8.78744375" y2="45.5999875" width="1.016" layer="16"/>
<wire x1="8.78744375" y1="45.5999875" x2="12.142209375" y2="45.5999875" width="1.016" layer="16"/>
<wire x1="12.142209375" y1="45.5999875" x2="12.15889375" y2="45.616671875" width="1.016" layer="16"/>
<wire x1="147.745209375" y1="16.16208125" x2="141.14153125" y2="16.16208125" width="1.27" layer="16"/>
<wire x1="141.14153125" y1="16.16208125" x2="138.11333125" y2="13.014475" width="1.27" layer="16"/>
<wire x1="138.11333125" y1="13.014475" x2="68.14285" y2="13.014475" width="1.27" layer="16"/>
<wire x1="68.14285" y1="13.014475" x2="64.19906875" y2="16.95825625" width="1.27" layer="16"/>
<wire x1="64.19906875" y1="16.95825625" x2="64.19906875" y2="37.0826" width="1.27" layer="16"/>
<wire x1="64.19906875" y1="37.0826" x2="56.0576125" y2="45.22405625" width="1.27" layer="16"/>
<wire x1="56.0576125" y1="45.22405625" x2="55.796734375" y2="45.484934375" width="1.27" layer="16"/>
<wire x1="55.796734375" y1="45.484934375" x2="55.838390625" y2="45.484934375" width="1.27" layer="16"/>
<wire x1="55.838390625" y1="45.484934375" x2="55.876171875" y2="45.447153125" width="1.27" layer="16"/>
<wire x1="68.17113125" y1="27.49929375" x2="67.0727125" y2="28.5977125" width="0.8128" layer="16"/>
<wire x1="67.0727125" y1="28.5977125" x2="67.0727125" y2="38.25804375" width="0.8128" layer="16"/>
<wire x1="67.0727125" y1="38.25804375" x2="59.6066375" y2="45.808103125" width="0.8128" layer="16"/>
<wire x1="59.6066375" y1="45.808103125" x2="56.05225" y2="45.6402625" width="0.8128" layer="16"/>
<wire x1="56.05225" y1="45.6402625" x2="55.841196875" y2="45.429209375" width="0.8128" layer="16"/>
<wire x1="55.841196875" y1="45.429209375" x2="55.8497125" y2="45.42069375" width="0.8128" layer="16"/>
<wire x1="111.15239375" y1="38.607978125" x2="111.15239375" y2="40.672978125" width="1.016" layer="16"/>
<wire x1="111.15239375" y1="40.672978125" x2="110.434725" y2="41.390646875" width="1.016" layer="16"/>
<wire x1="110.434725" y1="41.390646875" x2="110.14931875" y2="41.676053125" width="1.016" layer="16"/>
<wire x1="110.14931875" y1="41.676053125" x2="102.54150625" y2="41.676053125" width="1.016" layer="16"/>
<wire x1="102.54150625" y1="41.676053125" x2="97.677109375" y2="46.54045" width="1.016" layer="16"/>
<wire x1="97.677109375" y1="46.54045" x2="89.111490625" y2="46.54045" width="1.016" layer="16"/>
<wire x1="89.111490625" y1="46.54045" x2="85.64318125" y2="46.54045" width="1.016" layer="16"/>
<wire x1="85.64318125" y1="46.54045" x2="59.362990625" y2="46.54045" width="1.016" layer="16"/>
<wire x1="59.362990625" y1="46.54045" x2="56.88596875" y2="46.54045" width="1.016" layer="16"/>
<wire x1="56.88596875" y1="46.54045" x2="56.19133125" y2="46.54045" width="1.016" layer="16"/>
<wire x1="56.19133125" y1="46.54045" x2="55.66545" y2="46.01456875" width="1.016" layer="16"/>
<wire x1="55.66545" y1="46.01456875" x2="56.00273125" y2="46.01456875" width="1.016" layer="16"/>
<wire x1="56.107334375" y1="32.052475" x2="56.107334375" y2="31.63610625" width="1.9304" layer="16"/>
<wire x1="56.107334375" y1="31.63610625" x2="56.19059375" y2="31.552846875" width="1.9304" layer="16"/>
<wire x1="56.19059375" y1="45.091075" x2="56.0576125" y2="45.22405625" width="1.9304" layer="16"/>
<wire x1="56.00273125" y1="48.878253125" x2="56.00273125" y2="45.15085625" width="1.9304" layer="16"/>
<wire x1="56.00273125" y1="45.15085625" x2="56.059309375" y2="45.094278125" width="1.9304" layer="16"/>
<wire x1="56.059309375" y1="45.094278125" x2="56.059309375" y2="45.35721875" width="1.9304" layer="16"/>
<wire x1="56.059309375" y1="45.35721875" x2="56.059309375" y2="55.488009375" width="1.9304" layer="16"/>
<wire x1="56.059309375" y1="55.488009375" x2="55.97604375" y2="55.571275" width="1.9304" layer="16"/>
<wire x1="56.19059375" y1="31.552846875" x2="56.19059375" y2="45.35721875" width="1.9304" layer="16"/>
<wire x1="56.19059375" y1="45.35721875" x2="56.059309375" y2="45.35721875" width="1.9304" layer="16"/>
<wire x1="31.671209375" y1="45.616671875" x2="24.68185" y2="45.620159375" width="1.9304" layer="16"/>
<wire x1="24.68185" y1="45.620159375" x2="12.34129375" y2="45.620159375" width="1.6764" layer="16"/>
<wire x1="12.34129375" y1="45.620159375" x2="12.078353125" y2="45.35721875" width="1.6764" layer="16"/>
<wire x1="12.078353125" y1="45.35721875" x2="12.078353125" y2="45.53613125" width="1.6764" layer="16"/>
<wire x1="12.078353125" y1="45.53613125" x2="12.15889375" y2="45.616671875" width="1.6764" layer="16"/>
<wire x1="31.671209375" y1="45.616671875" x2="55.679534375" y2="45.616671875" width="1.9304" layer="16"/>
<wire x1="55.679534375" y1="45.616671875" x2="55.843040625" y2="45.453165625" width="1.9304" layer="16"/>
<wire x1="55.843040625" y1="45.453165625" x2="55.843040625" y2="45.431053125" width="1.9304" layer="16"/>
<wire x1="55.843040625" y1="45.431053125" x2="55.841196875" y2="45.429209375" width="1.9304" layer="16"/>
<wire x1="85.726990625" y1="49.011978125" x2="85.726990625" y2="46.624259375" width="1.016" layer="16"/>
<wire x1="85.726990625" y1="46.624259375" x2="85.64318125" y2="46.54045" width="1.016" layer="16"/>
<wire x1="61.042115625" y1="50.696596875" x2="56.88596875" y2="46.54045" width="1.016" layer="16"/>
<wire x1="102.673171875" y1="62.939046875" x2="86.1249125" y2="62.939046875" width="1.016" layer="16"/>
<wire x1="86.1249125" y1="62.939046875" x2="83.904784375" y2="60.71891875" width="1.016" layer="16"/>
<wire x1="83.904784375" y1="60.71891875" x2="80.6619125" y2="60.71891875" width="1.016" layer="16"/>
<wire x1="80.6619125" y1="60.71891875" x2="79.380925" y2="59.43793125" width="1.016" layer="16"/>
<wire x1="79.380925" y1="59.43793125" x2="79.380925" y2="55.849909375" width="1.016" layer="16"/>
<wire x1="79.380925" y1="55.849909375" x2="79.72241875" y2="55.508415625" width="1.016" layer="16"/>
<wire x1="85.813609375" y1="55.517690625" x2="79.73169375" y2="55.517690625" width="1.016" layer="16"/>
<wire x1="79.73169375" y1="55.517690625" x2="79.72241875" y2="55.508415625" width="1.016" layer="16"/>
<wire x1="85.813609375" y1="55.517690625" x2="87.993128125" y2="55.517690625" width="1.016" layer="16"/>
<wire x1="87.993128125" y1="55.517690625" x2="89.196846875" y2="54.313971875" width="1.016" layer="16"/>
<wire x1="89.196846875" y1="54.313971875" x2="89.196846875" y2="46.62580625" width="1.016" layer="16"/>
<wire x1="89.196846875" y1="46.62580625" x2="89.111490625" y2="46.54045" width="1.016" layer="16"/>
<wire x1="67.7873375" y1="67.210953125" x2="74.262334375" y2="67.210953125" width="1.016" layer="16"/>
<wire x1="74.262334375" y1="67.210953125" x2="74.269471875" y2="67.203815625" width="1.016" layer="16"/>
<wire x1="74.269471875" y1="67.203815625" x2="70.85079375" y2="67.203815625" width="1.016" layer="16"/>
<wire x1="70.85079375" y1="67.203815625" x2="70.845340625" y2="67.20926875" width="1.016" layer="16"/>
<wire x1="70.845340625" y1="67.20926875" x2="70.845340625" y2="58.81524375" width="1.016" layer="16"/>
<wire x1="70.845340625" y1="58.81524375" x2="64.993090625" y2="52.96299375" width="1.016" layer="16"/>
<wire x1="64.993090625" y1="52.96299375" x2="63.364196875" y2="52.96299375" width="1.016" layer="16"/>
<wire x1="63.364196875" y1="52.96299375" x2="61.09153125" y2="50.690328125" width="1.016" layer="16"/>
<wire x1="61.09153125" y1="50.690328125" x2="61.048384375" y2="50.690328125" width="1.016" layer="16"/>
<wire x1="61.048384375" y1="50.690328125" x2="61.042115625" y2="50.696596875" width="1.016" layer="16"/>
<wire x1="68.9366125" y1="50.6124375" x2="63.434978125" y2="50.6124375" width="1.016" layer="16"/>
<wire x1="63.434978125" y1="50.6124375" x2="59.362990625" y2="46.54045" width="1.016" layer="16"/>
<wire x1="72.88338125" y1="50.696596875" x2="69.020771875" y2="50.696596875" width="1.016" layer="16"/>
<wire x1="69.020771875" y1="50.696596875" x2="68.9366125" y2="50.6124375" width="1.016" layer="16"/>
<wire x1="143.621946875" y1="47.133721875" x2="143.49898125" y2="45.625325" width="1.016" layer="16"/>
<wire x1="143.49898125" y1="45.625325" x2="145.069675" y2="44.05463125" width="1.016" layer="16"/>
<wire x1="145.069675" y1="44.05463125" x2="146.635828125" y2="44.05463125" width="1.016" layer="16"/>
<wire x1="146.635828125" y1="44.05463125" x2="146.80930625" y2="44.228109375" width="1.016" layer="16"/>
<wire x1="146.80930625" y1="44.228109375" x2="146.98545" y2="44.228109375" width="1.016" layer="16"/>
<wire x1="146.98545" y1="44.228109375" x2="147.281984375" y2="43.931575" width="1.016" layer="16"/>
<wire x1="147.281984375" y1="43.931575" x2="151.720625" y2="43.931575" width="1.016" layer="16"/>
<wire x1="151.720625" y1="43.931575" x2="152.0280375" y2="44.2389875" width="1.016" layer="16"/>
<wire x1="160.817171875" y1="44.004140625" x2="157.974478125" y2="44.0304625" width="1.016" layer="16"/>
<wire x1="157.974478125" y1="44.0304625" x2="152.116375" y2="44.0304625" width="1.016" layer="16"/>
<wire x1="152.116375" y1="44.0304625" x2="152.0280375" y2="44.1188" width="1.016" layer="16"/>
<wire x1="152.0280375" y1="44.1188" x2="152.0280375" y2="44.2389875" width="1.016" layer="16"/>
<wire x1="116.23239375" y1="38.607978125" x2="116.19175" y2="38.648621875" width="1.016" layer="16"/>
<wire x1="116.19175" y1="38.648621875" x2="116.19175" y2="40.589771875" width="1.016" layer="16"/>
<wire x1="116.19175" y1="40.589771875" x2="115.06425625" y2="41.717265625" width="1.016" layer="16"/>
<wire x1="115.06425625" y1="41.717265625" x2="110.556346875" y2="41.717265625" width="1.016" layer="16"/>
<wire x1="110.556346875" y1="41.717265625" x2="110.434725" y2="41.59564375" width="1.016" layer="16"/>
<wire x1="110.434725" y1="41.59564375" x2="110.434725" y2="41.390646875" width="1.016" layer="16"/>
<wire x1="10.7812875" y1="83.987859375" x2="14.44044375" y2="83.987859375" width="1.27" layer="16"/>
<wire x1="14.44044375" y1="83.987859375" x2="14.44044375" y2="83.5368625" width="1.27" layer="16"/>
<wire x1="145.099665625" y1="77.326121875" x2="148.71564375" y2="77.276796875" width="0" layer="19" extent="1-1"/>
<wire x1="159.54375625" y1="62.40633125" x2="148.71564375" y2="77.276796875" width="0" layer="19" extent="1-1"/>
<wire x1="160.817171875" y1="44.004140625" x2="159.54375625" y2="62.40633125" width="0" layer="19" extent="1-1"/>
<wire x1="141.12378125" y1="36.773771875" x2="145.069675" y2="44.05463125" width="0" layer="19" extent="16-16"/>
<wire x1="141.14153125" y1="16.16208125" x2="141.12378125" y2="36.773771875" width="0" layer="19" extent="16-16"/>
<wire x1="88.757728125" y1="83.666609375" x2="86.1249125" y2="62.939046875" width="0" layer="19" extent="16-16"/>
<wire x1="80.170884375" y1="92.99234375" x2="88.757728125" y2="83.666609375" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$4">
<contactref element="C7" pad="1"/>
<wire x1="79.989546875" y1="25.545890625" x2="80.010171875" y2="25.545890625" width="0.8128" layer="16"/>
<contactref element="X5" pad="1"/>
<wire x1="80.09513125" y1="18.74195" x2="80.09513125" y2="25.44030625" width="0.8128" layer="16"/>
<wire x1="80.09513125" y1="25.44030625" x2="79.989546875" y2="25.545890625" width="0.8128" layer="16"/>
</signal>
<signal name="N$5">
<contactref element="C8" pad="1"/>
<wire x1="71.937615625" y1="25.661190625" x2="71.9430875" y2="25.661190625" width="0.8128" layer="16"/>
<wire x1="71.9430875" y1="25.661190625" x2="71.9430875" y2="25.63330625" width="0.8128" layer="16"/>
<contactref element="X5" pad="3"/>
<wire x1="71.937615625" y1="25.661190625" x2="71.937615625" y2="25.148865625" width="0.8128" layer="16"/>
<wire x1="71.937615625" y1="25.148865625" x2="69.959840625" y2="23.171090625" width="0.8128" layer="16"/>
<wire x1="69.959840625" y1="23.171090625" x2="69.959840625" y2="18.838684375" width="0.8128" layer="16"/>
<wire x1="69.959840625" y1="18.838684375" x2="70.111728125" y2="18.686796875" width="0.8128" layer="16"/>
<wire x1="70.111728125" y1="18.686796875" x2="70.111728125" y2="18.717753125" width="0.8128" layer="16"/>
<wire x1="70.111728125" y1="18.717753125" x2="70.08753125" y2="18.74195" width="0.8128" layer="16"/>
</signal>
<signal name="N$7">
<contactref element="C11" pad="+"/>
<contactref element="X6" pad="1"/>
<wire x1="95.254778125" y1="18.9659875" x2="95.251846875" y2="18.72773125" width="0" layer="19" extent="16-16"/>
<wire x1="95.254778125" y1="18.9659875" x2="95.254778125" y2="27.012534375" width="0.8128" layer="16"/>
</signal>
<signal name="N$11">
<contactref element="C12" pad="+"/>
<contactref element="X6" pad="3"/>
<wire x1="87.228390625" y1="26.6129625" x2="87.228390625" y2="20.78788125" width="0.8128" layer="16"/>
<wire x1="87.228390625" y1="20.78788125" x2="85.244246875" y2="18.72773125" width="0.8128" layer="16"/>
</signal>
<signal name="N$12">
<contactref element="R5" pad="2"/>
<contactref element="R6" pad="1"/>
<wire x1="108.65655" y1="22.49321875" x2="108.65655" y2="17.32765" width="1.27" layer="16"/>
<wire x1="108.65655" y1="17.32765" x2="108.740225" y2="17.243975" width="1.27" layer="16"/>
<wire x1="108.740225" y1="17.243975" x2="108.740225" y2="17.423640625" width="1.27" layer="16"/>
<wire x1="108.740225" y1="17.423640625" x2="108.782025" y2="17.465440625" width="1.27" layer="16"/>
</signal>
<signal name="N$13">
<contactref element="R6" pad="2"/>
<contactref element="IC1" pad="2"/>
<contactref element="R7" pad="1"/>
<wire x1="108.65655" y1="32.97321875" x2="112.654271875" y2="32.97321875" width="1.016" layer="16"/>
<wire x1="112.654271875" y1="32.97321875" x2="112.67625" y2="32.995196875" width="1.016" layer="16"/>
<wire x1="108.61239375" y1="38.607978125" x2="108.61239375" y2="33.017375" width="1.016" layer="16"/>
<wire x1="108.61239375" y1="33.017375" x2="108.65655" y2="32.97321875" width="1.016" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="R7" pad="2"/>
<contactref element="IC1" pad="1"/>
<contactref element="R8" pad="1"/>
<contactref element="S1" pad="1"/>
<wire x1="106.07239375" y1="38.607978125" x2="106.07239375" y2="31.68805625" width="1.016" layer="16"/>
<wire x1="106.07239375" y1="31.68805625" x2="108.442596875" y2="29.317853125" width="1.016" layer="16"/>
<wire x1="108.442596875" y1="29.317853125" x2="112.698834375" y2="29.317853125" width="1.016" layer="16"/>
<wire x1="112.698834375" y1="29.317853125" x2="123.141696875" y2="29.317853125" width="1.27" layer="16"/>
<wire x1="123.141696875" y1="29.317853125" x2="123.50629375" y2="29.317853125" width="1.27" layer="16"/>
<wire x1="123.50629375" y1="29.317853125" x2="125.844434375" y2="29.317853125" width="1.27" layer="16"/>
<wire x1="125.844434375" y1="29.317853125" x2="127.152234375" y2="28.010053125" width="1.27" layer="16"/>
<wire x1="127.152234375" y1="28.010053125" x2="127.152234375" y2="28.019496875" width="1.27" layer="16"/>
<wire x1="127.152234375" y1="28.019496875" x2="127.057953125" y2="28.113778125" width="1.27" layer="16"/>
<wire x1="123.15625" y1="32.995196875" x2="123.15625" y2="29.667896875" width="1.27" layer="16"/>
<wire x1="123.15625" y1="29.667896875" x2="123.50629375" y2="29.317853125" width="1.27" layer="16"/>
<wire x1="123.133659375" y1="20.525309375" x2="123.133659375" y2="29.309815625" width="1.27" layer="16"/>
<wire x1="123.133659375" y1="29.309815625" x2="123.141696875" y2="29.317853125" width="1.27" layer="16"/>
</signal>
<signal name="N$15">
<contactref element="R8" pad="2"/>
<contactref element="IC1" pad="6"/>
<contactref element="R9" pad="1"/>
<wire x1="127.057953125" y1="38.593778125" x2="127.057953125" y2="39.14600625" width="1.27" layer="16"/>
<wire x1="127.057953125" y1="39.14600625" x2="125.238115625" y2="40.96584375" width="1.27" layer="16"/>
<wire x1="125.238115625" y1="40.96584375" x2="119.587709375" y2="40.96584375" width="1.27" layer="16"/>
<wire x1="119.587709375" y1="40.96584375" x2="118.76656875" y2="40.144703125" width="1.27" layer="16"/>
<wire x1="118.76656875" y1="40.144703125" x2="118.76656875" y2="38.613803125" width="1.27" layer="16"/>
<wire x1="118.76656875" y1="38.613803125" x2="118.77239375" y2="38.607978125" width="1.27" layer="16"/>
<wire x1="133.8650125" y1="36.22623125" x2="129.4255" y2="36.22623125" width="1.27" layer="16"/>
<wire x1="129.4255" y1="36.22623125" x2="127.057953125" y2="38.593778125" width="1.27" layer="16"/>
</signal>
<signal name="N$17">
<contactref element="R9" pad="2"/>
<contactref element="IC1" pad="7"/>
<contactref element="S1" pad="3"/>
<wire x1="131.160059375" y1="20.525309375" x2="131.160059375" y2="25.85183125" width="1.27" layer="16"/>
<wire x1="131.160059375" y1="25.85183125" x2="131.160059375" y2="29.570875" width="1.27" layer="16"/>
<wire x1="131.160059375" y1="29.570875" x2="123.962034375" y2="36.7689" width="1.27" layer="16"/>
<wire x1="123.962034375" y1="36.7689" x2="123.151471875" y2="36.7689" width="1.27" layer="16"/>
<wire x1="123.151471875" y1="36.7689" x2="121.31239375" y2="38.607978125" width="1.27" layer="16"/>
<wire x1="133.8650125" y1="25.74623125" x2="131.250140625" y2="25.74623125" width="1.27" layer="16"/>
<wire x1="131.250140625" y1="25.74623125" x2="131.144540625" y2="25.85183125" width="1.27" layer="16"/>
<wire x1="131.144540625" y1="25.85183125" x2="131.160059375" y2="25.85183125" width="1.27" layer="16"/>
</signal>
<signal name="N$18">
<contactref element="S1" pad="2"/>
<contactref element="IC1" pad="10"/>
<wire x1="127.146859375" y1="20.525309375" x2="127.146859375" y2="17.703215625" width="1.27" layer="16"/>
<wire x1="127.146859375" y1="17.703215625" x2="129.522096875" y2="15.327978125" width="1.27" layer="16"/>
<wire x1="129.522096875" y1="15.327978125" x2="133.712159375" y2="15.327978125" width="1.27" layer="16"/>
<wire x1="133.712159375" y1="15.327978125" x2="136.540534375" y2="18.156353125" width="1.27" layer="16"/>
<wire x1="136.540534375" y1="18.156353125" x2="136.540534375" y2="37.100778125" width="1.27" layer="16"/>
<wire x1="125.967303125" y1="43.33803125" x2="117.2179375" y2="43.33803125" width="1.27" layer="16"/>
<wire x1="117.2179375" y1="43.33803125" x2="116.30555625" y2="44.2504125" width="1.27" layer="16"/>
<wire x1="116.30555625" y1="44.2504125" x2="116.30555625" y2="46.154815625" width="1.27" layer="16"/>
<wire x1="116.30555625" y1="46.154815625" x2="116.23239375" y2="46.227978125" width="1.27" layer="16"/>
<wire x1="136.540534375" y1="37.100778125" x2="134.754025" y2="38.8872875" width="1.27" layer="16"/>
<wire x1="134.754025" y1="38.8872875" x2="130.418046875" y2="38.8872875" width="1.27" layer="16"/>
<wire x1="130.418046875" y1="38.8872875" x2="125.967303125" y2="43.33803125" width="1.27" layer="16"/>
</signal>
<signal name="N$19">
<contactref element="IC1" pad="9"/>
<contactref element="IC1" pad="8"/>
<contactref element="R10" pad="2"/>
<wire x1="121.31239375" y1="46.227978125" x2="118.77239375" y2="46.227978125" width="1.27" layer="16"/>
<wire x1="121.31239375" y1="46.227978125" x2="119.0106125" y2="46.227978125" width="1.27" layer="16"/>
<wire x1="119.0106125" y1="46.227978125" x2="118.76656875" y2="45.983934375" width="1.27" layer="16"/>
<wire x1="118.76656875" y1="45.983934375" x2="124.276890625" y2="45.983934375" width="1.016" layer="16"/>
<wire x1="124.276890625" y1="45.983934375" x2="124.48495625" y2="46.192" width="1.016" layer="16"/>
</signal>
<signal name="N$25">
<contactref element="R14" pad="2"/>
<contactref element="IC1" pad="12"/>
<contactref element="C14" pad="2"/>
<wire x1="111.15239375" y1="46.227978125" x2="111.15239375" y2="54.213125" width="1.016" layer="16"/>
<wire x1="111.15239375" y1="54.213125" x2="111.068325" y2="54.29719375" width="1.016" layer="16"/>
<wire x1="111.068325" y1="54.29719375" x2="111.068325" y2="54.471803125" width="1.016" layer="16"/>
<wire x1="111.068325" y1="54.471803125" x2="110.918428125" y2="54.6217" width="1.016" layer="16"/>
<wire x1="110.918428125" y1="54.6217" x2="110.918428125" y2="54.84186875" width="1.016" layer="16"/>
<wire x1="110.918428125" y1="54.84186875" x2="110.805753125" y2="54.95454375" width="1.016" layer="16"/>
<wire x1="110.805753125" y1="54.95454375" x2="110.805753125" y2="54.691603125" width="1.016" layer="16"/>
<wire x1="106.673171875" y1="62.939046875" x2="106.673171875" y2="57.379665625" width="1.016" layer="16"/>
<wire x1="106.673171875" y1="57.379665625" x2="109.624175" y2="54.4286625" width="1.016" layer="16"/>
<wire x1="109.624175" y1="54.4286625" x2="110.725390625" y2="54.4286625" width="1.016" layer="16"/>
<wire x1="110.725390625" y1="54.4286625" x2="110.918428125" y2="54.6217" width="1.016" layer="16"/>
</signal>
<signal name="N$26">
<contactref element="C13" pad="2"/>
<contactref element="IC1" pad="14"/>
<contactref element="R16" pad="2"/>
<contactref element="R17" pad="1"/>
<contactref element="R18" pad="1"/>
<wire x1="85.297475" y1="58.67405" x2="85.59875625" y2="58.37276875" width="1.016" layer="16"/>
<wire x1="85.59875625" y1="58.37276875" x2="85.861328125" y2="58.37276875" width="1.016" layer="16"/>
<wire x1="85.861328125" y1="58.37276875" x2="85.861328125" y2="58.549325" width="1.016" layer="16"/>
<wire x1="85.861328125" y1="58.549325" x2="85.755040625" y2="58.6556125" width="1.016" layer="16"/>
<wire x1="85.297475" y1="58.67405" x2="81.903309375" y2="58.67405" width="1.016" layer="16"/>
<wire x1="106.07239375" y1="46.227978125" x2="101.371328125" y2="46.227978125" width="1.016" layer="16"/>
<wire x1="101.371328125" y1="46.227978125" x2="98.739628125" y2="48.859678125" width="1.016" layer="16"/>
<wire x1="98.739628125" y1="48.859678125" x2="96.28046875" y2="48.859678125" width="1.016" layer="16"/>
<wire x1="96.28046875" y1="48.859678125" x2="96.157396875" y2="48.98275" width="1.016" layer="16"/>
<wire x1="96.157396875" y1="48.98275" x2="96.1777625" y2="48.98275" width="1.016" layer="16"/>
<wire x1="96.1777625" y1="48.98275" x2="96.206990625" y2="49.011978125" width="1.016" layer="16"/>
<wire x1="96.157396875" y1="48.98275" x2="96.157396875" y2="50.958759375" width="1.016" layer="16"/>
<wire x1="96.157396875" y1="50.958759375" x2="88.4107" y2="58.70545625" width="1.016" layer="16"/>
<wire x1="88.4107" y1="58.70545625" x2="85.804884375" y2="58.70545625" width="1.016" layer="16"/>
<wire x1="85.804884375" y1="58.70545625" x2="85.755040625" y2="58.6556125" width="1.016" layer="16"/>
<wire x1="106.07239375" y1="46.227978125" x2="155.04703125" y2="72.72756875" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$16">
<contactref element="R10" pad="1"/>
<contactref element="R11" pad="1-2"/>
<contactref element="R12" pad="2"/>
<wire x1="124.560671875" y1="62.2639125" x2="100.026475" y2="83.4804375" width="0" layer="19" extent="1-1"/>
<wire x1="134.96495625" y1="46.192" x2="124.560671875" y2="62.2639125" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$20">
<contactref element="R11" pad="1-3"/>
<contactref element="R11" pad="2-1"/>
<contactref element="C13" pad="1"/>
<contactref element="R12" pad="1"/>
<contactref element="R13" pad="2"/>
<wire x1="110.6725375" y1="58.27803125" x2="110.6725375" y2="58.855778125" width="1.016" layer="16"/>
<wire x1="110.6725375" y1="58.855778125" x2="114.080671875" y2="62.2639125" width="1.016" layer="16"/>
<wire x1="114.080671875" y1="62.2639125" x2="114.534365625" y2="62.2639125" width="1.016" layer="16"/>
<wire x1="114.534365625" y1="62.2639125" x2="114.74434375" y2="62.053934375" width="1.016" layer="16"/>
<wire x1="81.903309375" y1="62.67405" x2="81.903309375" y2="63.08001875" width="1.016" layer="16"/>
<wire x1="81.903309375" y1="63.08001875" x2="83.394134375" y2="64.57084375" width="1.016" layer="16"/>
<wire x1="83.394134375" y1="64.57084375" x2="97.32215" y2="64.57084375" width="1.016" layer="16"/>
<wire x1="97.32215" y1="64.57084375" x2="98.982375" y2="66.23106875" width="1.016" layer="16"/>
<wire x1="98.982375" y1="66.23106875" x2="105.442903125" y2="66.23106875" width="1.016" layer="16"/>
<wire x1="105.442903125" y1="66.23106875" x2="110.113515625" y2="66.23106875" width="1.016" layer="16"/>
<wire x1="110.113515625" y1="66.23106875" x2="114.080671875" y2="62.2639125" width="1.016" layer="16"/>
<wire x1="105.026475" y1="78.4804375" x2="105.026475" y2="66.647496875" width="1.016" layer="16"/>
<wire x1="105.026475" y1="66.647496875" x2="105.442903125" y2="66.23106875" width="1.016" layer="16"/>
<wire x1="95.026475" y1="83.4804375" x2="95.7266625" y2="83.4804375" width="1.016" layer="16"/>
<wire x1="95.7266625" y1="83.4804375" x2="98.0933125" y2="81.1137875" width="1.016" layer="16"/>
<wire x1="98.0933125" y1="81.1137875" x2="102.393125" y2="81.1137875" width="1.016" layer="16"/>
<wire x1="102.393125" y1="81.1137875" x2="105.026475" y2="78.4804375" width="1.016" layer="16"/>
</signal>
<signal name="N$22">
<contactref element="R13" pad="1"/>
<contactref element="R11" pad="2-2"/>
<contactref element="R14" pad="1"/>
<wire x1="100.438428125" y1="54.6217" x2="100.438428125" y2="54.424175" width="1.016" layer="16"/>
<wire x1="100.438428125" y1="54.424175" x2="100.565409375" y2="54.29719375" width="1.016" layer="16"/>
<wire x1="100.565409375" y1="54.29719375" x2="100.565409375" y2="57.905159375" width="1.016" layer="16"/>
<wire x1="100.565409375" y1="57.905159375" x2="100.1925375" y2="58.27803125" width="1.016" layer="16"/>
<wire x1="100.1925375" y1="58.27803125" x2="100.026475" y2="78.4804375" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$23">
<contactref element="IC1" pad="13"/>
<contactref element="R15" pad="1"/>
<contactref element="R16" pad="1"/>
<wire x1="96.235040625" y1="55.3510375" x2="96.23295625" y2="55.348953125" width="1.016" layer="16"/>
<wire x1="96.23295625" y1="55.348953125" x2="96.23295625" y2="55.217484375" width="1.016" layer="16"/>
<wire x1="96.23295625" y1="55.217484375" x2="96.357078125" y2="55.217484375" width="1.016" layer="16"/>
<wire x1="96.293609375" y1="55.517690625" x2="96.235040625" y2="55.3510375" width="0" layer="19" extent="16-16"/>
<wire x1="96.357078125" y1="55.217484375" x2="96.357078125" y2="54.8093625" width="1.016" layer="16"/>
<wire x1="96.357078125" y1="54.8093625" x2="100.95296875" y2="50.213471875" width="1.016" layer="16"/>
<wire x1="100.95296875" y1="50.213471875" x2="106.60754375" y2="50.213471875" width="1.016" layer="16"/>
<wire x1="106.60754375" y1="50.213471875" x2="108.5767" y2="48.244315625" width="1.016" layer="16"/>
<wire x1="108.5767" y1="48.244315625" x2="108.5767" y2="46.263671875" width="1.016" layer="16"/>
<wire x1="108.5767" y1="46.263671875" x2="108.61239375" y2="46.227978125" width="1.016" layer="16"/>
<wire x1="96.235040625" y1="58.6556125" x2="96.235040625" y2="55.576259375" width="1.016" layer="16"/>
<wire x1="96.235040625" y1="55.576259375" x2="96.293609375" y2="55.517690625" width="1.016" layer="16"/>
</signal>
<signal name="N$21">
<contactref element="Q1" pad="B"/>
<contactref element="Q2" pad="B"/>
<contactref element="R18" pad="2"/>
<wire x1="165.594575" y1="50.256975" x2="165.594575" y2="60.509453125" width="1.016" layer="16"/>
<wire x1="165.594575" y1="60.509453125" x2="167.7311375" y2="62.646015625" width="1.016" layer="16"/>
<wire x1="167.7311375" y1="62.646015625" x2="167.7311375" y2="65.130121875" width="1.016" layer="16"/>
<wire x1="167.7311375" y1="65.130121875" x2="165.442234375" y2="67.419025" width="1.016" layer="16"/>
<wire x1="165.442234375" y1="67.419025" x2="165.442234375" y2="72.642771875" width="1.016" layer="16"/>
<wire x1="165.442234375" y1="72.642771875" x2="165.52703125" y2="72.72756875" width="1.016" layer="16"/>
</signal>
<signal name="N$24">
<contactref element="Q2" pad="E"/>
<contactref element="C16" pad="+"/>
<contactref element="R27" pad="1"/>
<contactref element="R31" pad="2"/>
<contactref element="C5" pad="1"/>
<wire x1="57.465340625" y1="78.45283125" x2="57.465340625" y2="73.204121875" width="1.016" layer="16"/>
<wire x1="57.465340625" y1="73.204121875" x2="57.446109375" y2="73.184890625" width="1.016" layer="16"/>
<wire x1="151.8139625" y1="26.44794375" x2="152.1736875" y2="26.08821875" width="1.016" layer="16"/>
<wire x1="152.1736875" y1="26.08821875" x2="157.880790625" y2="26.08821875" width="1.016" layer="16"/>
<wire x1="157.880790625" y1="26.08821875" x2="157.75301875" y2="26.215990625" width="1.016" layer="16"/>
<wire x1="157.75301875" y1="26.215990625" x2="157.75301875" y2="26.243509375" width="1.016" layer="16"/>
<wire x1="157.75301875" y1="26.243509375" x2="165.442234375" y2="64.879025" width="0" layer="19" extent="1-1"/>
<wire x1="57.465340625" y1="73.204121875" x2="151.8139625" y2="26.44794375" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$27">
<contactref element="C16" pad="-"/>
<contactref element="R19" pad="1"/>
<wire x1="146.80930625" y1="33.748109375" x2="146.80930625" y2="26.230240625" width="1.016" layer="16"/>
<wire x1="146.80930625" y1="26.230240625" x2="146.667284375" y2="26.08821875" width="1.016" layer="16"/>
<wire x1="146.667284375" y1="26.08821875" x2="147.158925" y2="26.08821875" width="1.016" layer="16"/>
<wire x1="147.158925" y1="26.08821875" x2="147.281984375" y2="25.965159375" width="1.016" layer="16"/>
<wire x1="147.281984375" y1="25.965159375" x2="147.216746875" y2="25.965159375" width="1.016" layer="16"/>
<wire x1="147.216746875" y1="25.965159375" x2="146.7339625" y2="26.44794375" width="1.016" layer="16"/>
</signal>
<signal name="N$29">
<contactref element="R20" pad="2"/>
<contactref element="C15" pad="+"/>
<wire x1="154.584703125" y1="55.825721875" x2="154.5847" y2="48.1274" width="1.016" layer="16"/>
<wire x1="154.5847" y1="48.1274" x2="154.101946875" y2="47.133721875" width="1.016" layer="16"/>
</signal>
<signal name="N$30">
<contactref element="C15" pad="-"/>
<contactref element="Q1" pad="E"/>
<contactref element="R28" pad="1"/>
<contactref element="C6" pad="1"/>
<contactref element="R30" pad="2"/>
<wire x1="57.3113625" y1="82.513609375" x2="133.099309375" y2="53.017459375" width="0" layer="19" extent="1-1"/>
<wire x1="165.594575" y1="47.716975" x2="57.3113625" y2="82.513609375" width="0" layer="19" extent="1-1"/>
<wire x1="137.698746875" y1="52.78445625" x2="133.165959375" y2="52.950809375" width="1.016" layer="16"/>
<wire x1="133.165959375" y1="52.950809375" x2="133.099309375" y2="53.017459375" width="1.016" layer="16"/>
<wire x1="137.698746875" y1="52.78445625" x2="142.60005625" y2="52.78445625" width="1.016" layer="16"/>
<wire x1="142.60005625" y1="52.78445625" x2="145.683765625" y2="55.868165625" width="1.016" layer="16"/>
<wire x1="145.683765625" y1="55.868165625" x2="145.683765625" y2="55.834790625" width="1.016" layer="16"/>
<wire x1="145.683765625" y1="55.834790625" x2="149.504703125" y2="55.825721875" width="1.016" layer="16"/>
</signal>
<signal name="N$31">
<contactref element="Q1" pad="C"/>
<contactref element="R21" pad="1"/>
<contactref element="Q4" pad="B"/>
<wire x1="162.722171875" y1="45.274140625" x2="162.722171875" y2="48.019571875" width="1.016" layer="16"/>
<wire x1="162.722171875" y1="48.019571875" x2="163.689575" y2="48.986975" width="1.016" layer="16"/>
<wire x1="158.728909375" y1="48.151009375" x2="162.590734375" y2="48.151009375" width="1.016" layer="16"/>
<wire x1="162.590734375" y1="48.151009375" x2="162.722171875" y2="48.019571875" width="1.016" layer="16"/>
</signal>
<signal name="N$32">
<contactref element="R22" pad="2"/>
<contactref element="Q2" pad="C"/>
<contactref element="Q3" pad="B"/>
<wire x1="161.44875625" y1="63.67633125" x2="161.44875625" y2="64.060546875" width="1.016" layer="16"/>
<wire x1="161.44875625" y1="64.060546875" x2="163.537234375" y2="66.149025" width="1.016" layer="16"/>
<wire x1="110.6637" y1="71.15796875" x2="161.44875625" y2="64.060546875" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$28">
<contactref element="R23" pad="2"/>
<contactref element="R24" pad="1"/>
<wire x1="48.085015625" y1="83.179025" x2="52.516478125" y2="83.179025" width="1.016" layer="16"/>
<wire x1="52.516478125" y1="83.179025" x2="52.634884375" y2="83.29743125" width="1.016" layer="16"/>
</signal>
<signal name="N$33">
<contactref element="R25" pad="2"/>
<contactref element="R26" pad="1"/>
<wire x1="84.9591625" y1="78.2338" x2="84.9591625" y2="73.46664375" width="1.016" layer="16"/>
<wire x1="84.9591625" y1="73.46664375" x2="84.833078125" y2="73.340559375" width="1.016" layer="16"/>
</signal>
<signal name="N$34">
<contactref element="R23" pad="1"/>
<contactref element="R21" pad="2"/>
<contactref element="R32" pad="1"/>
<contactref element="R35" pad="2"/>
<contactref element="C17" pad="+"/>
<contactref element="R40" pad="2"/>
<wire x1="52.022815625" y1="96.932359375" x2="158.728909375" y2="58.631009375" width="0" layer="19" extent="1-1"/>
<wire x1="151.24764375" y1="77.276796875" x2="158.728909375" y2="58.631009375" width="0" layer="19" extent="1-1"/>
<wire x1="158.728909375" y1="58.631009375" x2="159.16653125" y2="58.631009375" width="1.016" layer="16"/>
<wire x1="159.16653125" y1="58.631009375" x2="161.422540625" y2="56.375" width="1.016" layer="16"/>
<wire x1="48.085015625" y1="93.659025" x2="51.959809375" y2="93.659025" width="1.016" layer="16"/>
<wire x1="51.959809375" y1="93.659025" x2="52.023878125" y2="93.72309375" width="1.016" layer="16"/>
<wire x1="52.023878125" y1="93.72309375" x2="52.023878125" y2="96.931296875" width="1.016" layer="16"/>
<wire x1="52.023878125" y1="96.931296875" x2="52.022815625" y2="96.932359375" width="1.016" layer="16"/>
</signal>
<signal name="N$36">
<contactref element="R25" pad="1"/>
<contactref element="R22" pad="1"/>
<contactref element="R33" pad="2"/>
<contactref element="R34" pad="2"/>
<contactref element="C18" pad="+"/>
<contactref element="R41" pad="2"/>
<wire x1="74.485503125" y1="82.652878125" x2="74.485503125" y2="78.240140625" width="1.016" layer="16"/>
<wire x1="74.485503125" y1="78.240140625" x2="74.4791625" y2="78.2338" width="1.016" layer="16"/>
<wire x1="77.19041875" y1="55.508415625" x2="133.407328125" y2="68.473175" width="0" layer="19" extent="1-1"/>
<wire x1="82.7735375" y1="68.196140625" x2="77.19041875" y2="55.508415625" width="0" layer="19" extent="1-1"/>
<wire x1="100.1837" y1="71.15796875" x2="82.7735375" y2="68.196140625" width="0" layer="19" extent="1-1"/>
<wire x1="74.485503125" y1="78.240140625" x2="74.485503125" y2="76.122025" width="1.016" layer="16"/>
<wire x1="74.485503125" y1="76.122025" x2="80.056078125" y2="70.55145" width="1.016" layer="16"/>
<wire x1="80.056078125" y1="70.55145" x2="80.056078125" y2="63.781759375" width="1.016" layer="16"/>
<wire x1="80.056078125" y1="63.781759375" x2="77.191640625" y2="60.917321875" width="1.016" layer="16"/>
<wire x1="77.191640625" y1="60.917321875" x2="77.191640625" y2="55.63085" width="1.016" layer="16"/>
<wire x1="77.191640625" y1="55.63085" x2="77.339803125" y2="55.4826875" width="1.016" layer="16"/>
<wire x1="77.339803125" y1="55.4826875" x2="77.216146875" y2="55.4826875" width="1.016" layer="16"/>
<wire x1="77.216146875" y1="55.4826875" x2="77.19041875" y2="55.508415625" width="1.016" layer="16"/>
</signal>
<signal name="N$38">
<contactref element="R29" pad="E"/>
<contactref element="R28" pad="2"/>
<wire x1="119.07573125" y1="52.976721875" x2="122.570978125" y2="52.976721875" width="1.016" layer="16"/>
<wire x1="122.570978125" y1="52.976721875" x2="122.570978125" y2="52.86218125" width="1.016" layer="16"/>
<wire x1="122.570978125" y1="52.86218125" x2="122.619309375" y2="52.86218125" width="1.016" layer="16"/>
<wire x1="122.619309375" y1="52.86218125" x2="122.619309375" y2="53.017459375" width="1.016" layer="16"/>
</signal>
<signal name="N$41">
<contactref element="R31" pad="1"/>
<contactref element="R30" pad="1"/>
<contactref element="C6" pad="2"/>
<contactref element="C5" pad="2"/>
<contactref element="R44" pad="1"/>
<contactref element="R46" pad="2"/>
<contactref element="R45" pad="2"/>
<contactref element="R43" pad="1"/>
<contactref element="R47" pad="2"/>
<contactref element="L1" pad="1"/>
<wire x1="204.221659375" y1="58.37145625" x2="215.131065625" y2="58.30028125" width="1.27" layer="16"/>
<wire x1="215.131065625" y1="58.30028125" x2="215.197353125" y2="58.23399375" width="1.27" layer="16"/>
<wire x1="215.20321875" y1="27.476496875" x2="203.600478125" y2="27.476496875" width="1.27" layer="16"/>
<wire x1="203.600478125" y1="27.476496875" x2="203.545334375" y2="27.421353125" width="1.27" layer="16"/>
<wire x1="215.24878125" y1="27.522059375" x2="215.20321875" y2="27.476496875" width="1.27" layer="16"/>
<wire x1="215.197353125" y1="58.23399375" x2="215.197353125" y2="39.006853125" width="1.5" layer="16"/>
<wire x1="215.197353125" y1="39.006853125" x2="215.197353125" y2="35.002546875" width="1.5" layer="16"/>
<wire x1="215.197353125" y1="35.002546875" x2="215.197353125" y2="34.870834375" width="1.5" layer="16"/>
<wire x1="215.197353125" y1="34.870834375" x2="215.344309375" y2="34.723878125" width="1.5" layer="16"/>
<wire x1="215.344309375" y1="34.723878125" x2="215.344309375" y2="34.82570625" width="1.5" layer="16"/>
<wire x1="215.344309375" y1="34.723878125" x2="215.344309375" y2="27.6175875" width="1.5" layer="16"/>
<wire x1="215.344309375" y1="27.6175875" x2="215.20321875" y2="27.476496875" width="1.5" layer="16"/>
<wire x1="215.1781625" y1="35.0706875" x2="215.1781625" y2="35.0217375" width="1.5" layer="16"/>
<wire x1="215.1781625" y1="35.0217375" x2="215.197353125" y2="35.002546875" width="1.5" layer="16"/>
<wire x1="67.7913625" y1="82.513609375" x2="67.7913625" y2="78.606809375" width="1.016" layer="16"/>
<wire x1="67.7913625" y1="78.606809375" x2="67.945340625" y2="78.45283125" width="1.016" layer="16"/>
<wire x1="161.75301875" y1="26.243509375" x2="157.60129375" y2="30.395234375" width="1.016" layer="16"/>
<wire x1="157.60129375" y1="30.395234375" x2="151.117984375" y2="30.395234375" width="1.016" layer="16"/>
<wire x1="151.117984375" y1="30.395234375" x2="149.27358125" y2="32.2396375" width="1.016" layer="16"/>
<wire x1="149.27358125" y1="32.2396375" x2="149.27358125" y2="36.425059375" width="1.016" layer="16"/>
<wire x1="149.27358125" y1="36.425059375" x2="145.581853125" y2="40.1167875" width="1.016" layer="16"/>
<wire x1="145.581853125" y1="40.1167875" x2="140.420453125" y2="40.1167875" width="1.016" layer="16"/>
<wire x1="140.420453125" y1="40.1167875" x2="137.469409375" y2="43.06783125" width="1.016" layer="16"/>
<wire x1="137.469409375" y1="43.06783125" x2="137.469409375" y2="47.7463625" width="1.016" layer="16"/>
<wire x1="137.469409375" y1="47.7463625" x2="135.746603125" y2="49.46916875" width="1.016" layer="16"/>
<wire x1="135.746603125" y1="49.46916875" x2="129.947459375" y2="49.46916875" width="1.016" layer="16"/>
<wire x1="129.947459375" y1="49.46916875" x2="128.1033625" y2="51.313265625" width="1.016" layer="16"/>
<wire x1="128.1033625" y1="51.313265625" x2="128.1033625" y2="55.252878125" width="1.016" layer="16"/>
<wire x1="128.1033625" y1="55.252878125" x2="129.45699375" y2="56.606509375" width="1.016" layer="16"/>
<wire x1="129.45699375" y1="56.606509375" x2="137.692671875" y2="56.606509375" width="1.016" layer="16"/>
<wire x1="137.692671875" y1="56.606509375" x2="137.698746875" y2="56.612584375" width="1.016" layer="16"/>
<wire x1="137.698746875" y1="56.612584375" x2="137.698746875" y2="56.78445625" width="1.016" layer="16"/>
<wire x1="161.75301875" y1="26.243509375" x2="161.9573375" y2="26.447828125" width="1.016" layer="16"/>
<wire x1="161.9573375" y1="26.447828125" x2="181.47873125" y2="26.447828125" width="1.016" layer="16"/>
<wire x1="181.47873125" y1="26.447828125" x2="185.757496875" y2="30.72659375" width="1.016" layer="16"/>
<wire x1="185.757496875" y1="30.72659375" x2="185.757496875" y2="36.199540625" width="1.016" layer="16"/>
<wire x1="185.757496875" y1="36.199540625" x2="188.12155" y2="38.56359375" width="1.016" layer="16"/>
<wire x1="188.12155" y1="38.56359375" x2="189.003459375" y2="38.56359375" width="1.016" layer="16"/>
<wire x1="189.003459375" y1="38.56359375" x2="189.44671875" y2="39.006853125" width="1.016" layer="16"/>
<wire x1="189.44671875" y1="39.006853125" x2="215.197353125" y2="39.006853125" width="1.016" layer="16"/>
<wire x1="128.1033625" y1="55.252878125" x2="67.945340625" y2="78.45283125" width="0" layer="19" extent="16-16"/>
<wire x1="71.2747375" y1="82.481996875" x2="67.7913625" y2="82.513609375" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$42">
<contactref element="Q4" pad="E"/>
<contactref element="R32" pad="2"/>
<contactref element="Q6" pad="3"/>
<wire x1="62.503878125" y1="93.72309375" x2="190.822840625" y2="50.25305" width="0" layer="19" extent="1-1"/>
<wire x1="162.722171875" y1="42.734140625" x2="171.90663125" y2="42.734140625" width="1.016" layer="16"/>
<wire x1="171.90663125" y1="42.734140625" x2="178.694628125" y2="49.5221375" width="1.016" layer="16"/>
<wire x1="178.694628125" y1="49.5221375" x2="190.0675625" y2="49.5221375" width="1.016" layer="16"/>
<wire x1="190.0675625" y1="49.5221375" x2="190.68274375" y2="50.13731875" width="1.016" layer="16"/>
<wire x1="190.68274375" y1="50.13731875" x2="62.503878125" y2="93.72309375" width="0" layer="19" extent="1-16"/>
</signal>
<signal name="N$43">
<contactref element="Q3" pad="E"/>
<contactref element="R33" pad="1"/>
<contactref element="Q5" pad="3"/>
<wire x1="143.887328125" y1="68.473175" x2="190.7801875" y2="41.738365625" width="0" layer="19" extent="1-1"/>
<wire x1="161.44875625" y1="61.13633125" x2="161.44875625" y2="60.9342875" width="1.016" layer="16"/>
<wire x1="161.44875625" y1="60.9342875" x2="162.8129375" y2="59.57010625" width="1.016" layer="16"/>
<wire x1="162.8129375" y1="59.57010625" x2="143.887328125" y2="68.473175" width="0" layer="19" extent="1-16"/>
</signal>
<signal name="N$44">
<contactref element="Q6" pad="1"/>
<contactref element="R35" pad="1"/>
<wire x1="171.902540625" y1="56.375" x2="189.272890625" y2="56.375" width="1.016" layer="16"/>
<wire x1="189.272890625" y1="56.375" x2="190.822840625" y2="54.82505" width="1.016" layer="16"/>
</signal>
<signal name="N$45">
<contactref element="Q5" pad="1"/>
<contactref element="R34" pad="1"/>
<wire x1="84.965503125" y1="82.652878125" x2="190.7801875" y2="46.310365625" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$39">
<contactref element="Q6" pad="2"/>
<contactref element="R36" pad="1"/>
<contactref element="Q7" pad="2"/>
<contactref element="C19" pad="2"/>
<contactref element="R38" pad="2"/>
<contactref element="T1" pad="1"/>
<contactref element="C20" pad="2"/>
<wire x1="152.0280375" y1="33.7589875" x2="155.331690625" y2="33.7589875" width="1.016" layer="16"/>
<wire x1="155.331690625" y1="33.7589875" x2="157.49109375" y2="35.918390625" width="1.016" layer="16"/>
<wire x1="190.9786" y1="52.383290625" x2="190.822840625" y2="52.53905" width="1.4224" layer="16"/>
<wire x1="225.082571875" y1="49.112803125" x2="227.5913375" y2="49.112803125" width="1.4224" layer="16"/>
<wire x1="227.5913375" y1="49.112803125" x2="229.060153125" y2="50.58161875" width="1.4224" layer="16"/>
<wire x1="229.060153125" y1="50.58161875" x2="229.060153125" y2="60.49483125" width="1.4224" layer="16"/>
<wire x1="229.060153125" y1="60.49483125" x2="226.5842875" y2="62.970696875" width="1.4224" layer="16"/>
<wire x1="226.5842875" y1="62.970696875" x2="223.597790625" y2="62.970696875" width="1.4224" layer="16"/>
<wire x1="223.597790625" y1="62.970696875" x2="221.547184375" y2="65.021303125" width="1.4224" layer="16"/>
<wire x1="221.547184375" y1="65.021303125" x2="221.547184375" y2="69.29474375" width="1.4224" layer="16"/>
<wire x1="221.547184375" y1="69.29474375" x2="223.254678125" y2="71.0022375" width="1.4224" layer="16"/>
<wire x1="223.254678125" y1="71.0022375" x2="224.705909375" y2="71.0022375" width="1.4224" layer="16"/>
<wire x1="224.705909375" y1="71.0022375" x2="224.87679375" y2="70.831353125" width="1.4224" layer="16"/>
<wire x1="224.87679375" y1="70.831353125" x2="218.90548125" y2="70.831353125" width="1.4224" layer="16"/>
<wire x1="218.90548125" y1="70.831353125" x2="212.668221875" y2="77.0686125" width="1.4224" layer="16"/>
<wire x1="212.668221875" y1="77.0686125" x2="203.8774625" y2="77.0686125" width="1.4224" layer="16"/>
<wire x1="203.8774625" y1="77.0686125" x2="200.2889" y2="80.657175" width="1.4224" layer="16"/>
<wire x1="200.2889" y1="80.657175" x2="200.2889" y2="80.745171875" width="1.4224" layer="16"/>
<wire x1="200.2889" y1="80.745171875" x2="197.02481875" y2="84.38635625" width="1.4224" layer="16"/>
<wire x1="197.02481875" y1="84.38635625" x2="191.30249375" y2="84.465746875" width="1.4224" layer="16"/>
<wire x1="191.30249375" y1="84.465746875" x2="189.422771875" y2="82.586025" width="1.4224" layer="16"/>
<wire x1="189.422771875" y1="82.586025" x2="189.529925" y2="62.5704875" width="1.4224" layer="16"/>
<wire x1="189.529925" y1="62.5704875" x2="193.544303125" y2="58.613159375" width="1.4224" layer="16"/>
<wire x1="193.544303125" y1="58.613159375" x2="193.544303125" y2="58.612215625" width="1.4224" layer="16"/>
<wire x1="193.544303125" y1="58.612215625" x2="194.739546875" y2="57.416971875" width="1.4224" layer="16"/>
<wire x1="194.739546875" y1="57.416971875" x2="194.739546875" y2="53.912709375" width="1.4224" layer="16"/>
<wire x1="194.739546875" y1="53.912709375" x2="193.288178125" y2="52.461340625" width="1.4224" layer="16"/>
<wire x1="193.288178125" y1="52.461340625" x2="190.90055" y2="52.461340625" width="1.4224" layer="16"/>
<wire x1="190.90055" y1="52.461340625" x2="190.822840625" y2="52.53905" width="1.4224" layer="16"/>
<wire x1="157.49109375" y1="35.918390625" x2="178.798465625" y2="28.683471875" width="0" layer="19" extent="1-1"/>
<wire x1="190.9786" y1="52.383290625" x2="178.798465625" y2="28.683471875" width="0" layer="19" extent="16-16"/>
<wire x1="224.90523125" y1="70.929640625" x2="224.87679375" y2="70.831353125" width="0" layer="19" extent="16-16"/>
<wire x1="152.0280375" y1="33.7589875" x2="152.0280375" y2="37.49515625" width="1.4224" layer="16"/>
<wire x1="152.0280375" y1="37.49515625" x2="148.170921875" y2="41.352271875" width="1.4224" layer="16"/>
<wire x1="148.170921875" y1="41.352271875" x2="147.9255375" y2="41.352271875" width="1.4224" layer="16"/>
<wire x1="147.9255375" y1="41.352271875" x2="147.310178125" y2="41.96763125" width="1.4224" layer="16"/>
<wire x1="147.310178125" y1="41.96763125" x2="144.240121875" y2="41.96763125" width="1.4224" layer="16"/>
<wire x1="144.240121875" y1="41.96763125" x2="139.686446875" y2="46.52130625" width="1.4224" layer="16"/>
<wire x1="139.686446875" y1="46.52130625" x2="139.686446875" y2="48.61505625" width="1.4224" layer="16"/>
<wire x1="139.686446875" y1="48.61505625" x2="141.407934375" y2="50.33654375" width="1.4224" layer="16"/>
<wire x1="141.407934375" y1="50.33654375" x2="148.2905125" y2="50.33654375" width="1.4224" layer="16"/>
<wire x1="148.2905125" y1="50.33654375" x2="152.105753125" y2="54.151784375" width="1.4224" layer="16"/>
<wire x1="152.105753125" y1="54.151784375" x2="152.105753125" y2="58.214471875" width="1.4224" layer="16"/>
<wire x1="152.105753125" y1="58.214471875" x2="150.630190625" y2="59.690034375" width="1.4224" layer="16"/>
<wire x1="150.630190625" y1="59.690034375" x2="141.531115625" y2="59.690034375" width="1.4224" layer="16"/>
<wire x1="141.531115625" y1="59.690034375" x2="141.284971875" y2="59.936178125" width="1.4224" layer="16"/>
<wire x1="141.284971875" y1="59.936178125" x2="141.053175" y2="59.936178125" width="1.4224" layer="16"/>
<wire x1="141.053175" y1="59.936178125" x2="141.010853125" y2="59.9785" width="1.4224" layer="16"/>
</signal>
<signal name="N$40">
<contactref element="Q7" pad="1"/>
<contactref element="Q5" pad="2"/>
<contactref element="R37" pad="A"/>
<contactref element="R37" pad="S"/>
<contactref element="C19" pad="1"/>
<contactref element="R39" pad="1"/>
<contactref element="Q8" pad="1"/>
<contactref element="C21" pad="2"/>
<wire x1="225.082571875" y1="51.398803125" x2="222.082934375" y2="51.398803125" width="1.27" layer="16"/>
<wire x1="222.082934375" y1="51.398803125" x2="220.87074375" y2="50.1866125" width="1.27" layer="16"/>
<wire x1="220.87074375" y1="50.1866125" x2="220.87074375" y2="35.802178125" width="1.27" layer="16"/>
<wire x1="220.87074375" y1="35.802178125" x2="225.170125" y2="31.502796875" width="1.27" layer="16"/>
<wire x1="179.5856375" y1="44.12488125" x2="177.0456375" y2="41.58488125" width="1.016" layer="16"/>
<wire x1="177.0456375" y1="41.58488125" x2="177.0456375" y2="33.96488125" width="1.016" layer="16"/>
<wire x1="190.7801875" y1="44.024365625" x2="190.679671875" y2="44.12488125" width="1.016" layer="16"/>
<wire x1="190.679671875" y1="44.12488125" x2="179.5856375" y2="44.12488125" width="1.016" layer="16"/>
<wire x1="141.12378125" y1="26.293771875" x2="141.12378125" y2="20.320721875" width="1.016" layer="16"/>
<wire x1="141.12378125" y1="20.320721875" x2="143.1887875" y2="18.255715625" width="1.016" layer="16"/>
<wire x1="143.1887875" y1="18.255715625" x2="144.264778125" y2="18.255715625" width="1.016" layer="16"/>
<wire x1="144.264778125" y1="18.255715625" x2="145.465728125" y2="19.456665625" width="1.016" layer="16"/>
<wire x1="145.465728125" y1="19.456665625" x2="156.530996875" y2="19.456665625" width="1.016" layer="16"/>
<wire x1="156.530996875" y1="19.456665625" x2="157.51614375" y2="18.47151875" width="1.016" layer="16"/>
<wire x1="157.51614375" y1="18.47151875" x2="175.5870875" y2="18.47151875" width="1.016" layer="16"/>
<wire x1="175.5870875" y1="18.47151875" x2="178.788815625" y2="21.673246875" width="1.016" layer="16"/>
<wire x1="178.788815625" y1="21.673246875" x2="178.788815625" y2="24.382584375" width="1.016" layer="16"/>
<wire x1="178.788815625" y1="24.382584375" x2="178.911778125" y2="24.505546875" width="1.016" layer="16"/>
<wire x1="178.911778125" y1="24.505546875" x2="178.911778125" y2="24.570159375" width="1.016" layer="16"/>
<wire x1="178.911778125" y1="24.570159375" x2="178.798465625" y2="24.683471875" width="1.016" layer="16"/>
<wire x1="178.798465625" y1="24.683471875" x2="178.798465625" y2="24.618859375" width="1.016" layer="16"/>
<wire x1="178.798465625" y1="24.618859375" x2="178.911778125" y2="24.505546875" width="1.016" layer="16"/>
<wire x1="178.911778125" y1="24.505546875" x2="178.788815625" y2="24.505546875" width="1.016" layer="16"/>
<wire x1="178.788815625" y1="24.505546875" x2="178.788815625" y2="24.50536875" width="1.016" layer="16"/>
<wire x1="178.788815625" y1="24.50536875" x2="178.66585" y2="24.382403125" width="1.016" layer="16"/>
<wire x1="178.66585" y1="24.382403125" x2="177.0456375" y2="33.96488125" width="0" layer="19" extent="1-16"/>
<wire x1="220.87074375" y1="50.1866125" x2="220.87074375" y2="61.771453125" width="1.4224" layer="16"/>
<wire x1="220.87074375" y1="61.771453125" x2="216.42470625" y2="66.217490625" width="1.4224" layer="16"/>
<wire x1="216.42470625" y1="66.217490625" x2="211.229096875" y2="66.217490625" width="1.4224" layer="16"/>
<wire x1="211.229096875" y1="66.217490625" x2="195.916803125" y2="82.323646875" width="1.4224" layer="16"/>
<wire x1="195.916803125" y1="82.323646875" x2="192.5874625" y2="82.323646875" width="1.4224" layer="16"/>
<wire x1="192.5874625" y1="82.323646875" x2="191.809115625" y2="81.445996875" width="1.4224" layer="16"/>
<wire x1="191.809115625" y1="81.445996875" x2="192.007559375" y2="63.3076875" width="1.4224" layer="16"/>
<wire x1="192.007559375" y1="63.3076875" x2="198.069159375" y2="57.2460875" width="1.4224" layer="16"/>
<wire x1="198.069159375" y1="57.2460875" x2="198.069159375" y2="46.3076375" width="1.4224" layer="16"/>
<wire x1="198.069159375" y1="46.3076375" x2="195.67866875" y2="43.917146875" width="1.4224" layer="16"/>
<wire x1="195.67866875" y1="43.917146875" x2="190.88740625" y2="43.917146875" width="1.4224" layer="16"/>
<wire x1="190.88740625" y1="43.917146875" x2="190.7801875" y2="44.024365625" width="1.4224" layer="16"/>
</signal>
<signal name="N$46">
<contactref element="R37" pad="E"/>
<contactref element="Q7" pad="3"/>
<contactref element="R36" pad="2"/>
<wire x1="167.97109375" y1="35.918390625" x2="225.082571875" y2="46.826803125" width="0" layer="19" extent="1-1"/>
<wire x1="167.97109375" y1="35.918390625" x2="168.19055" y2="35.918390625" width="1.016" layer="16"/>
<wire x1="168.19055" y1="35.918390625" x2="171.37768125" y2="31.873215625" width="1.016" layer="16"/>
<wire x1="171.37768125" y1="31.873215625" x2="180.523125" y2="31.873215625" width="1.016" layer="16"/>
<wire x1="180.523125" y1="31.873215625" x2="182.1256375" y2="33.96488125" width="1.016" layer="16"/>
</signal>
<signal name="N$48">
<contactref element="C21" pad="1"/>
<contactref element="Q8" pad="2"/>
<contactref element="R41" pad="1"/>
<contactref element="C23" pad="2"/>
<contactref element="Q10" pad="2"/>
<contactref element="F1" pad="1"/>
<wire x1="225.442225" y1="10.07876875" x2="143.129459375" y2="10.10234375" width="2" layer="16"/>
<wire x1="143.129459375" y1="10.10234375" x2="43.62835625" y2="10.130840625" width="2" layer="16"/>
<wire x1="43.62835625" y1="10.130840625" x2="43.357953125" y2="9.8604375" width="2" layer="16"/>
<wire x1="43.357953125" y1="9.8604375" x2="43.3017625" y2="9.8604375" width="2" layer="16"/>
<wire x1="43.3017625" y1="9.8604375" x2="43.0022" y2="10.16" width="2" layer="16"/>
<wire x1="225.442225" y1="10.07876875" x2="228.071365625" y2="10.07876875" width="1.5" layer="16"/>
<wire x1="228.071365625" y1="10.07876875" x2="229.086915625" y2="11.09431875" width="1.5" layer="16"/>
<wire x1="229.086915625" y1="11.09431875" x2="229.086915625" y2="27.842625" width="1.5" layer="16"/>
<wire x1="229.086915625" y1="27.842625" x2="227.9571125" y2="28.972428125" width="1.5" layer="16"/>
<wire x1="227.9571125" y1="28.972428125" x2="225.344496875" y2="28.972428125" width="1.5" layer="16"/>
<wire x1="225.344496875" y1="28.972428125" x2="225.27383125" y2="28.9017625" width="1.5" layer="16"/>
<wire x1="225.27383125" y1="28.9017625" x2="225.231159375" y2="28.9017625" width="1.5" layer="16"/>
<wire x1="225.231159375" y1="28.9017625" x2="225.170125" y2="28.962796875" width="1.5" layer="16"/>
<wire x1="143.1887875" y1="14.255715625" x2="143.129421875" y2="14.255715625" width="1.016" layer="16"/>
<wire x1="143.129421875" y1="14.255715625" x2="143.129421875" y2="9.97461875" width="1.016" layer="16"/>
<wire x1="143.129421875" y1="9.97461875" x2="143.129459375" y2="9.97461875" width="1.016" layer="16"/>
<wire x1="143.129459375" y1="9.97461875" x2="143.129459375" y2="10.10234375" width="1.016" layer="16"/>
<wire x1="93.2535375" y1="68.196140625" x2="88.757728125" y2="79.666609375" width="0" layer="19" extent="1-1"/>
<wire x1="143.129421875" y1="14.255715625" x2="93.2535375" y2="68.196140625" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$49">
<contactref element="C20" pad="1"/>
<contactref element="T1" pad="2"/>
<contactref element="R40" pad="1"/>
<contactref element="C22" pad="1"/>
<contactref element="Q9" pad="2"/>
<contactref element="F2" pad="1"/>
<wire x1="225.218846875" y1="86.776034375" x2="200.700828125" y2="86.784775" width="2" layer="16"/>
<wire x1="200.700828125" y1="86.784775" x2="141.77696875" y2="86.800815625" width="2" layer="16"/>
<wire x1="141.77696875" y1="86.800815625" x2="41.521103125" y2="86.82810625" width="2" layer="16"/>
<wire x1="41.521103125" y1="86.82810625" x2="41.521103125" y2="86.360421875" width="2" layer="16"/>
<wire x1="200.488784375" y1="86.57273125" x2="200.700828125" y2="86.784775" width="1.5" layer="16"/>
<wire x1="224.90523125" y1="68.389640625" x2="229.049103125" y2="68.389640625" width="1.778" layer="16"/>
<wire x1="229.049103125" y1="68.389640625" x2="229.127840625" y2="68.468378125" width="1.778" layer="16"/>
<wire x1="229.127840625" y1="68.468378125" x2="229.127840625" y2="85.265975" width="1.778" layer="16"/>
<wire x1="229.127840625" y1="85.265975" x2="227.633990625" y2="86.759825" width="1.778" layer="16"/>
<wire x1="227.633990625" y1="86.759825" x2="225.23505625" y2="86.759825" width="1.778" layer="16"/>
<wire x1="225.23505625" y1="86.759825" x2="225.218846875" y2="86.776034375" width="1.778" layer="16"/>
<wire x1="141.010853125" y1="63.9785" x2="141.010853125" y2="77.122325" width="1.4224" layer="16"/>
<wire x1="141.010853125" y1="77.122325" x2="141.010853125" y2="86.0347" width="1.4224" layer="16"/>
<wire x1="141.010853125" y1="86.0347" x2="141.77696875" y2="86.800815625" width="1.4224" layer="16"/>
<wire x1="141.099665625" y1="77.326121875" x2="141.548875" y2="77.326121875" width="0.4064" layer="16"/>
<wire x1="141.548875" y1="77.326121875" x2="141.548875" y2="77.122325" width="0.4064" layer="16"/>
<wire x1="141.010853125" y1="77.122325" x2="141.099665625" y2="77.122325" width="0.4064" layer="16"/>
<wire x1="141.099665625" y1="77.122325" x2="141.099665625" y2="77.326121875" width="0.4064" layer="16"/>
<wire x1="41.542815625" y1="96.932359375" x2="41.542815625" y2="86.382134375" width="1.016" layer="16"/>
<wire x1="41.542815625" y1="86.382134375" x2="41.521103125" y2="86.360421875" width="1.016" layer="16"/>
</signal>
<signal name="N$50">
<contactref element="T1" pad="3"/>
<contactref element="R42" pad="2"/>
<contactref element="Q9" pad="1"/>
<wire x1="225.005175" y1="65.7279875" x2="225.005175" y2="65.749696875" width="1.5" layer="16"/>
<wire x1="225.218846875" y1="92.364034375" x2="231.20855625" y2="92.364034375" width="1.778" layer="16"/>
<wire x1="231.20855625" y1="92.364034375" x2="232.471215625" y2="91.101375" width="1.778" layer="16"/>
<wire x1="232.471215625" y1="91.101375" x2="232.471215625" y2="67.328753125" width="1.778" layer="16"/>
<wire x1="232.471215625" y1="67.328753125" x2="230.83509375" y2="65.69263125" width="1.778" layer="16"/>
<wire x1="230.83509375" y1="65.69263125" x2="225.001975" y2="65.69263125" width="1.778" layer="16"/>
<wire x1="225.001975" y1="65.69263125" x2="225.001975" y2="65.752896875" width="1.778" layer="16"/>
<wire x1="225.001975" y1="65.752896875" x2="224.90523125" y2="65.849640625" width="1.778" layer="16"/>
<wire x1="225.218846875" y1="92.364034375" x2="196.815196875" y2="92.364034375" width="1.778" layer="16"/>
<wire x1="196.815196875" y1="92.364034375" x2="194.20025" y2="89.7490875" width="1.778" layer="16"/>
<wire x1="194.20025" y1="89.7490875" x2="194.147715625" y2="89.7490875" width="1.778" layer="16"/>
<wire x1="194.147715625" y1="89.7490875" x2="194.123303125" y2="89.7735" width="1.778" layer="16"/>
<wire x1="225.001975" y1="65.752896875" x2="225.005175" y2="65.7279875" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$51">
<contactref element="R42" pad="1"/>
<contactref element="Q8" pad="3"/>
<contactref element="Q10" pad="1"/>
<wire x1="225.170125" y1="26.422796875" x2="225.170125" y2="15.93886875" width="1.5" layer="16"/>
<wire x1="225.170125" y1="15.93886875" x2="225.442225" y2="15.66676875" width="1.5" layer="16"/>
<wire x1="194.123303125" y1="79.2935" x2="194.123303125" y2="78.01816875" width="1.4224" layer="16"/>
<wire x1="194.123303125" y1="78.01816875" x2="208.852640625" y2="63.28883125" width="1.4224" layer="16"/>
<wire x1="208.852640625" y1="63.28883125" x2="215.42924375" y2="63.28883125" width="1.4224" layer="16"/>
<wire x1="215.42924375" y1="63.28883125" x2="218.38879375" y2="60.32928125" width="1.4224" layer="16"/>
<wire x1="218.38879375" y1="60.32928125" x2="218.38879375" y2="29.813453125" width="1.4224" layer="16"/>
<wire x1="218.38879375" y1="29.813453125" x2="222.021615625" y2="26.18063125" width="1.4224" layer="16"/>
<wire x1="222.021615625" y1="26.18063125" x2="224.927959375" y2="26.18063125" width="1.4224" layer="16"/>
<wire x1="224.927959375" y1="26.18063125" x2="225.170125" y2="26.422796875" width="1.4224" layer="16"/>
</signal>
<signal name="N$56">
<contactref element="R45" pad="1"/>
<contactref element="Q10" pad="3"/>
<contactref element="R46" pad="1"/>
<wire x1="203.545334375" y1="4.561353125" x2="215.148075" y2="4.561353125" width="1.5" layer="16"/>
<wire x1="215.148075" y1="4.561353125" x2="215.20321875" y2="4.616496875" width="1.5" layer="16"/>
<wire x1="215.20321875" y1="4.616496875" x2="225.316496875" y2="4.616496875" width="1.5" layer="16"/>
<wire x1="225.316496875" y1="4.616496875" x2="225.442225" y2="4.49076875" width="1.5" layer="16"/>
</signal>
<signal name="N$47">
<contactref element="R43" pad="2"/>
<contactref element="Q9" pad="3"/>
<contactref element="R44" pad="2"/>
<wire x1="225.218846875" y1="81.188034375" x2="215.914596875" y2="81.188034375" width="1.27" layer="16"/>
<wire x1="215.914596875" y1="81.188034375" x2="215.598465625" y2="80.871903125" width="1.27" layer="16"/>
<wire x1="215.598465625" y1="80.871903125" x2="215.41944375" y2="80.871903125" width="1.27" layer="16"/>
<wire x1="215.41944375" y1="80.871903125" x2="215.197353125" y2="81.09399375" width="1.27" layer="16"/>
<wire x1="215.197353125" y1="81.09399375" x2="204.287946875" y2="81.14284375" width="1.27" layer="16"/>
<wire x1="204.287946875" y1="81.14284375" x2="204.221659375" y2="81.23145625" width="1.27" layer="16"/>
</signal>
<signal name="N$54">
<contactref element="R47" pad="1"/>
<contactref element="C24" pad="1"/>
<wire x1="76.170884375" y1="92.99234375" x2="71.2747375" y2="92.961996875" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$55">
<contactref element="L1" pad="2"/>
<wire x1="189.9381625" y1="35.0706875" x2="189.885840625" y2="25.2252625" width="1.27" layer="16"/>
<contactref element="X1" pad="1"/>
<wire x1="189.885840625" y1="25.2252625" x2="183.728475" y2="16.14929375" width="1.27" layer="16"/>
<wire x1="183.728475" y1="16.14929375" x2="152.774409375" y2="16.16208125" width="1.27" layer="16"/>
</signal>
<signal name="N$58">
<contactref element="Q11" pad="1"/>
<contactref element="X2" pad="1"/>
<wire x1="15.5693375" y1="98.59475625" x2="10.626978125" y2="98.59475625" width="1.27" layer="16"/>
<wire x1="10.626978125" y1="98.59475625" x2="10.626978125" y2="88.856140625" width="1.27" layer="16"/>
<wire x1="10.626978125" y1="88.856140625" x2="10.7812875" y2="88.856140625" width="1.27" layer="16"/>
<wire x1="10.7812875" y1="88.856140625" x2="10.7812875" y2="89.017059375" width="1.27" layer="16"/>
</signal>
<signal name="N$35">
<contactref element="D3" pad="C"/>
<contactref element="R48" pad="1"/>
<contactref element="Q11" pad="3"/>
<wire x1="20.1413375" y1="98.59475625" x2="20.1413375" y2="98.196934375" width="1.27" layer="16"/>
<wire x1="20.1413375" y1="98.196934375" x2="24.66624375" y2="93.672028125" width="1.27" layer="16"/>
<wire x1="24.66624375" y1="93.672028125" x2="24.66624375" y2="93.679171875" width="1.27" layer="16"/>
<wire x1="24.66624375" y1="93.679171875" x2="24.60044375" y2="93.744971875" width="1.27" layer="16"/>
<wire x1="20.1413375" y1="98.196934375" x2="24.298884375" y2="98.196934375" width="1.27" layer="16"/>
<wire x1="24.298884375" y1="98.196934375" x2="24.66624375" y2="97.829575" width="1.27" layer="16"/>
<wire x1="24.66624375" y1="97.829575" x2="24.66624375" y2="97.87051875" width="1.27" layer="16"/>
<wire x1="24.66624375" y1="97.87051875" x2="24.688021875" y2="97.892296875" width="1.27" layer="16"/>
</signal>
<signal name="N$37">
<contactref element="B1" pad="+"/>
<contactref element="C1" pad="+"/>
<contactref element="C10" pad="+"/>
<contactref element="F2" pad="2"/>
<contactref element="R48" pad="2"/>
<contactref element="Q11" pad="2"/>
<wire x1="17.8553375" y1="98.59475625" x2="17.8553375" y2="87.422003125" width="1.27" layer="16"/>
<wire x1="17.8553375" y1="87.422003125" x2="18.987075" y2="86.290265625" width="1.27" layer="16"/>
<wire x1="18.987075" y1="86.290265625" x2="18.987075" y2="86.33079375" width="1.27" layer="16"/>
<wire x1="18.987075" y1="86.33079375" x2="19.016703125" y2="86.360421875" width="1.27" layer="16"/>
<wire x1="35.168021875" y1="97.892296875" x2="31.344240625" y2="97.892296875" width="1.27" layer="16"/>
<wire x1="31.344240625" y1="97.892296875" x2="27.5482125" y2="94.09626875" width="1.27" layer="16"/>
<wire x1="27.5482125" y1="94.09626875" x2="27.5482125" y2="92.313203125" width="1.27" layer="16"/>
<wire x1="27.5482125" y1="92.313203125" x2="26.27675625" y2="91.041746875" width="1.27" layer="16"/>
<wire x1="26.27675625" y1="91.041746875" x2="23.698028125" y2="91.041746875" width="1.27" layer="16"/>
<wire x1="23.698028125" y1="91.041746875" x2="19.016703125" y2="86.360421875" width="1.27" layer="16"/>
<wire x1="18.987075" y1="86.290265625" x2="18.987075" y2="70.65436875" width="1.9304" layer="16"/>
<wire x1="18.987075" y1="70.65436875" x2="18.987075" y2="54.594528125" width="1.9304" layer="16"/>
<wire x1="18.987075" y1="54.594528125" x2="20.34435625" y2="53.237246875" width="1.9304" layer="16"/>
<wire x1="20.34435625" y1="53.237246875" x2="32.710840625" y2="53.237246875" width="1.9304" layer="16"/>
<wire x1="32.710840625" y1="53.237246875" x2="35.333546875" y2="55.44105625" width="1.9304" layer="16"/>
<wire x1="55.97604375" y1="63.191275" x2="55.97604375" y2="64.99281875" width="1.9304" layer="16"/>
<wire x1="55.97604375" y1="64.99281875" x2="49.98586875" y2="70.98299375" width="1.9304" layer="16"/>
<wire x1="49.98586875" y1="70.98299375" x2="19.3157" y2="70.98299375" width="1.9304" layer="16"/>
<wire x1="19.3157" y1="70.98299375" x2="18.987075" y2="70.65436875" width="1.9304" layer="16"/>
<wire x1="20.34435625" y1="53.237246875" x2="20.32" y2="53.34" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$52">
<contactref element="C2" pad="-"/>
<contactref element="B1" pad="-"/>
<contactref element="C9" pad="-"/>
<contactref element="F1" pad="2"/>
<wire x1="20.32" y1="38.1" x2="20.32" y2="34.93138125" width="2" layer="16"/>
<wire x1="20.32" y1="34.93138125" x2="20.32" y2="18.557296875" width="2" layer="16"/>
<wire x1="20.32" y1="18.557296875" x2="20.32" y2="10.3378" width="2" layer="16"/>
<wire x1="20.32" y1="10.3378" x2="20.4978" y2="10.16" width="2" layer="16"/>
<wire x1="21.169025" y1="19.406321875" x2="20.32" y2="18.557296875" width="2" layer="16"/>
<wire x1="34.774528125" y1="34.811490625" x2="20.439890625" y2="34.811490625" width="2" layer="16"/>
<wire x1="20.439890625" y1="34.811490625" x2="20.32" y2="34.93138125" width="2" layer="16"/>
<wire x1="21.169025" y1="19.406321875" x2="51.143459375" y2="19.406321875" width="1.9304" layer="16"/>
<wire x1="51.143459375" y1="19.406321875" x2="56.19059375" y2="24.45345625" width="1.9304" layer="16"/>
<wire x1="56.19059375" y1="24.45345625" x2="56.128315625" y2="24.45345625" width="1.9304" layer="16"/>
<wire x1="56.128315625" y1="24.45345625" x2="56.107334375" y2="24.432475" width="1.9304" layer="16"/>
</signal>
<signal name="N$53">
<contactref element="R24" pad="2"/>
<contactref element="D1" pad="C"/>
<contactref element="C3" pad="+"/>
<contactref element="R27" pad="2"/>
<wire x1="67.926109375" y1="73.184890625" x2="67.886759375" y2="73.184890625" width="1.016" layer="16"/>
<wire x1="67.886759375" y1="73.184890625" x2="64.40056875" y2="69.6987" width="1.016" layer="16"/>
<wire x1="64.40056875" y1="69.6987" x2="64.40056875" y2="67.45813125" width="1.016" layer="16"/>
<wire x1="64.40056875" y1="67.45813125" x2="64.40056875" y2="65.821378125" width="1.016" layer="16"/>
<wire x1="64.40056875" y1="65.821378125" x2="65.53973125" y2="64.682215625" width="1.016" layer="16"/>
<wire x1="65.53973125" y1="64.682215625" x2="67.741984375" y2="64.682215625" width="1.016" layer="16"/>
<wire x1="68.9366125" y1="60.7724375" x2="68.9366125" y2="63.4875875" width="1.016" layer="16"/>
<wire x1="68.9366125" y1="63.4875875" x2="67.741984375" y2="64.682215625" width="1.016" layer="16"/>
<contactref element="IC1" pad="4"/>
<wire x1="113.69239375" y1="38.607978125" x2="113.835125" y2="38.465246875" width="1.016" layer="16"/>
<wire x1="113.835125" y1="38.465246875" x2="113.835125" y2="35.362303125" width="1.016" layer="16"/>
<wire x1="52.634884375" y1="72.81743125" x2="53.45136875" y2="72.81743125" width="1.27" layer="16"/>
<wire x1="53.45136875" y1="72.81743125" x2="58.81066875" y2="67.45813125" width="1.27" layer="16"/>
<wire x1="58.81066875" y1="67.45813125" x2="64.40056875" y2="67.45813125" width="1.27" layer="16"/>
<wire x1="68.9366125" y1="60.7724375" x2="113.69239375" y2="38.607978125" width="0" layer="19" extent="1-1"/>
<wire x1="67.7873375" y1="64.678953125" x2="67.741984375" y2="64.682215625" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$57">
<contactref element="D2" pad="A"/>
<contactref element="R26" pad="2"/>
<contactref element="C4" pad="-"/>
<contactref element="R29" pad="S"/>
<contactref element="R29" pad="A"/>
<contactref element="IC1" pad="11"/>
<wire x1="113.69239375" y1="46.227978125" x2="113.69239375" y2="52.673384375" width="1.016" layer="16"/>
<wire x1="113.69239375" y1="52.673384375" x2="113.99573125" y2="52.976721875" width="1.016" layer="16"/>
<wire x1="113.99573125" y1="52.976721875" x2="116.53573125" y2="55.516721875" width="1.016" layer="16"/>
<wire x1="72.88338125" y1="60.856596875" x2="72.88338125" y2="63.285725" width="1.016" layer="16"/>
<wire x1="72.88338125" y1="63.285725" x2="74.269471875" y2="64.671815625" width="1.016" layer="16"/>
<wire x1="74.353078125" y1="73.340559375" x2="74.353078125" y2="72.199940625" width="1.016" layer="16"/>
<wire x1="74.353078125" y1="72.199940625" x2="78.14644375" y2="68.406575" width="1.016" layer="16"/>
<wire x1="78.14644375" y1="68.406575" x2="78.14644375" y2="65.44165625" width="1.016" layer="16"/>
<wire x1="78.14644375" y1="65.44165625" x2="77.387003125" y2="64.682215625" width="1.016" layer="16"/>
<wire x1="77.387003125" y1="64.682215625" x2="74.279871875" y2="64.682215625" width="1.016" layer="16"/>
<wire x1="74.279871875" y1="64.682215625" x2="74.269471875" y2="64.671815625" width="1.016" layer="16"/>
<wire x1="78.14644375" y1="65.44165625" x2="113.69239375" y2="52.673384375" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$59">
<wire x1="57.041809375" y1="44.564009375" x2="57.23899375" y2="44.564009375" width="1.016" layer="16"/>
<wire x1="57.23899375" y1="44.564009375" x2="58.17770625" y2="45.502721875" width="1.016" layer="16"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
